Re: [Mpi-22] Higher-level languages proposal
Dear Jeff, Thanks. I'm looking forward to a lot of discussion. To start it, I've answered your questions and added some clarifications to the proposal. The main point is that in the newcomm, all processes (i.e., threads) have their own unique rank as do processes in the original "normal" MPI communicator comm. The number of threads per original MPI process that join the newcomm is given by the local_num_threads argument. After this, the usual (comm,rank) addressing works both in the old-fashioned process-only communicators and in the new thread-based ones. By using the usual communicator and group management calls one can cut and splice these new communicators as needed. This is why the syntax comparable to that of the MPI_COMM_SPLIT looks superfluous to me, at least for now. And since we can create and free these communicators as often as needed, we can follow the OpenMP parallel regions and other threading constructs very closely throughout the course of the program execution. Best regards. Alexander -----Original Message----- From: mpi-22-bounces_at_[hidden] [mailto:mpi-22-bounces_at_[hidden]] On Behalf Of Jeff Squyres Sent: Wednesday, October 15, 2008 3:44 PM To: MPI 2.2 Subject: Re: [Mpi-22] Higher-level languages proposal I just added 2 lengthy comments on ticket 39 ( https://svn.mpi-forum.org/trac/mpi-forum-web/ticket/39 ). I suspect that there will need to be a *lot* of discussion about this idea. On Oct 14, 2008, at 11:15 AM, Supalov, Alexander wrote:
The proposal is ready in draft, see https://svn.mpi-forum.org/trac/mpi-forum-web/ticket/39 . I targeted it to MPI-2.2 for now. As you will see, it resolves the problem of thread addressability without any extension to the Probe/Recv calls. I bet there are more things that will follow, too.
Here's the current text for reference:
"A collective MPI call, MPI_Comm_thread_register, with the following syntax (in C):
int MPI_Comm_thread_register(MPI_Comm comm, int index, int num, MPI_Comm *newcomm)
returns a newcomm for all num threads of the comm that called this function. All threads are treated as MPI processes in the newcomm, and their ranks are ordered according to the index argument that ranges between 0 and num-1. This argument must be unique in every thread on in the given MPI process of the comm.
From this moment on, all threads contained in the newcomm are considered as MPI processes, with all that this entails, including individual MPI rank that makes the respective thread addressable in the usual manner. All MPI communicator and group management calls can be applied to the newcomm in order to produce new communicators, reorder the processes in it, etc. (see Figure 1).
A slightly modified call MPI_Comm_free with the standard syntax (in C):
int MPI_Comm_free(MPI_Comm comm)
can be used to destroy the respective communicator comm and thus "demote" all the threads from the status of MPI processes in the comm back to the unnamed threads typical of the MPI standard.
This pair of calls, or their equivalent, allow threads to be addressed directly in all MPI calls, and since the sequence of the MPI_Comm_thread_register and MPI_Comm_free calls can be repeated as needed, OpenMP parallel sections or any equivalent groups of threads in the MPI program can become MPI processes for a while and then return to their original status.
If threads use (as they usually do) joint address space with one (former) MPI process, the MPI communication calls can certainly take advantage of this by copying data directly from the source to the destination buffer. This equally applies to all point-to-point, collective, one-sided, and file I/O calls.
This call certainly makes sense only at the thread support level MPI_THREAD_MULTIPLE."
Best regards.
Alexander
-----Original Message----- From: Supalov, Alexander Sent: Tuesday, October 14, 2008 2:44 PM To: 'MPI 2.2' Subject: RE: [Mpi-22] Higher-level languages proposal
Sure. This will most likely be a MPI-3 topic, though. I'll drop in a link here once ready.
-----Original Message----- From: mpi-22-bounces_at_[hidden] [mailto:mpi-22-bounces_at_[hidden]] On Behalf Of Jeff Squyres Sent: Tuesday, October 14, 2008 2:35 PM To: MPI 2.2 Subject: Re: [Mpi-22] Higher-level languages proposal
On Oct 14, 2008, at 7:07 AM, Supalov, Alexander wrote:
Thanks. I'd rather say that if the purpose of the extension is indeed to serialize the Probe/Recv pair, the better way to solve this and many other problems would be to make threads directly addressable, as if they were MPI processes.
One way to do this might be, say, to create a call like MPI_Comm_thread_enroll that creates an intra-communicator out of all threads that call this function in a loosely synchronous fashion, collectively over one or several MPI processes they constitute.
I'm still not sure I follow. Can you provide more details, perhaps with function prototypes and specific rules? (i.e., an alternate proposal)?
If paired with the appropriately extended MPI_Comm_free, this would allow, for example, all threads in an OpenMP parallel section to be addressed as if they were fully fledged MPI processes. Note that this would allow more than one parallel section during the program run.
Other threading models would profit from this "opt-in/opt-out" method, too. This may be a more flexible way of dealing with threads than the one-time MPI_Init variety mentioned by George Bosilica in his EuroPVM/MPI keynote, by the way.
Best regards.
Alexander
-----Original Message----- From: mpi-22-bounces_at_[hidden] [mailto:mpi-22-bounces_at_[hidden]] On Behalf Of Terry Dontje Sent: Tuesday, October 14, 2008 12:45 PM To: MPI 2.2 Subject: Re: [Mpi-22] Higher-level languages proposal
Dear Jeff,
Unfortunately, I won't be in Chicago, so we should rather discuss this here. I talked to Torsten last time about this extension. As far as I can remember, the main purpose of this extension is to make sure that the thread that called the MPI_Probe also calls the MPI_Recv and gets the message matched by the aforementioned MPI_Probe.
If so, the main problem here is not the matching. The main problem is that one cannot address threads in MPI. If we fix that, the proposed extension with the message handle and such will become superfluous.
See what I mean?
Interesting, so you are basically redefining the MPI_Probe/Recv pair to guarrantee a message to go to a specific thread. Or in other words lowering the proposal's MPI_Mprobe/recv to be in the implementation of MPI_Probe/Recv. This seems reasonable to me since MPI_Probe/Recv itself
is basically useless unless the programmer assures serialization when that combination is used.
--td
Best regards.
Alexander
-----Original Message----- From: mpi-22-bounces_at_[hidden] [mailto:mpi-22-bounces_at_[hidden]] On Behalf Of Jeff Squyres Sent: Monday, October 13, 2008 11:48 PM To: MPI 2.2 Subject: Re: [Mpi-22] Higher-level languages proposal
On Oct 13, 2008, at 10:46 AM, Supalov, Alexander wrote:
Thanks. The 2.1.1, which was presented last time, in my opinion does
not seem to solve the right problem. Instead of defining a way for unambiguous addressing of the threads in MPI, which would eliminate the MPI_Probe/Recv ambiguity and many other issues, it attempts to add yet another concept (this time, a message id) in the current situation where any thread can do what they please.
I'm not quite sure I understand your proposal.
<... after typing out a lengthy/rambling discourse that made very little sense and was fraught with questions and ambiguities :-) ...>
Let's discuss this in Chicago; Rich has allocated 5-7pm on Monday for
discussion of this proposal. These are exactly the kinds of larger issues that we want to raise via this proposal.
_______________________________________________ mpi-22 mailing list mpi-22_at_[hidden] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-22 --------------------------------------------------------------------- Intel GmbH Dornacher Strasse 1 85622 Feldkirchen/Muenchen Germany Sitz der Gesellschaft: Feldkirchen bei Muenchen Geschaeftsfuehrer: Douglas Lusk, Peter Gleissner, Hannes Schwaderer Registergericht: Muenchen HRB 47456 Ust.-IdNr. VAT Registration No.: DE129385895 Citibank Frankfurt (BLZ 502 109 00) 600119052
This e-mail and any attachments may contain confidential material for the sole use of the intended recipient(s). Any review or distribution by others is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies.
-- Jeff Squyres Cisco Systems
-- Jeff Squyres Cisco Systems _______________________________________________ mpi-22 mailing list mpi-22_at_[hidden] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-22 --------------------------------------------------------------------- Intel GmbH Dornacher Strasse 1 85622 Feldkirchen/Muenchen Germany Sitz der Gesellschaft: Feldkirchen bei Muenchen Geschaeftsfuehrer: Douglas Lusk, Peter Gleissner, Hannes Schwaderer Registergericht: Muenchen HRB 47456 Ust.-IdNr. VAT Registration No.: DE129385895 Citibank Frankfurt (BLZ 502 109 00) 600119052 This e-mail and any attachments may contain confidential material for the sole use of the intended recipient(s). Any review or distribution by others is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies.
participants (1)
unknown@example.com
