Logwatch for berlin.mcs.anl.gov (Linux)
################### Logwatch 7.3 (03/24/06) #################### Processing Initiated: Thu Sep 20 04:02:02 2012 Date Range Processed: yesterday ( 2012-Sep-19 ) Period is day. Detail Level of Output: 0 Type of Output: unformatted Logfiles for Host: berlin.mcs.anl.gov ################################################################## --------------------- Automount Begin ------------------------ **Unmatched Entries** rmdir_path: lstat of /mcs/bio/mg-rast/.bzr failed: 1 Time(s) rmdir_path: lstat of /mcs/bio/mg-rast/_MTN failed: 1 Time(s) key "pro" not found in map source(s).: 2 Time(s) rmdir_path: lstat of /mcs/bio/mg-rast/p failed: 1 Time(s) rmdir_path: lstat of /mcs/bio/mg-rast/{arch} failed: 1 Time(s) rmdir_path: lstat of /mcs/bio/mg-rast/pro failed: 1 Time(s) rmdir_path: lstat of /mcs/bio/mg-rast/.hg failed: 1 Time(s) rmdir_path: lstat of /mcs/bio/mg-rast/bi failed: 1 Time(s) rmdir_path: lstat of /mcs/bio/mg-rast/jbs failed: 1 Time(s) add_host_addrs:1038: hostname lookup failed: Unknown host: 2 Time(s) rmdir_path: lstat of /mcs/bio/mg-rast/.git failed: 1 Time(s) rmdir_path: lstat of /mcs/bio/mg-rast/pip failed: 1 Time(s) ---------------------- Automount End ------------------------- --------------------- pam_unix Begin ------------------------ su-l: Unknown Entries: session closed for user mgrastprod: 4 Time(s) session opened for user mgrastprod by jbischof(uid=0): 3 Time(s) session opened for user mgrastprod by tharriso(uid=0): 1 Time(s) sudo: Authentication Failures: jbischof(0) -> jbischof: 3 Time(s) dsouza(0) -> dsouza: 2 Time(s) tharriso(0) -> tharriso: 1 Time(s) ---------------------- pam_unix End ------------------------- --------------------- postfix Begin ------------------------ 3837 bytes transferred 1 messages sent 1 messages removed from queue ---------------------- postfix End ------------------------- --------------------- SSHD Begin ------------------------ Users logging in through sshd: dsouza: 140.221.10.82 (dsouza.mcs.anl.gov): 2 times jbischof: 140.221.11.19 (jbischof.mcs.anl.gov): 3 times root: 192.5.200.126 (warehouse13.mcs.anl.gov): 8 times tharriso: 130.202.135.201 (mcswl201.mcs.anl.gov): 1 time Received disconnect: 11: disconnected by user : 4 Time(s) ---------------------- SSHD End ------------------------- --------------------- Sudo (secure-log) Begin ------------------------ ============================================================================== dsouza => mgrastprod ------------------------------------------------------------------------------ /bin/bash /bin/zsh ============================================================================== jbischof => root ------------------------------------------------------------------------------ /bin/zsh /bin/zsh /bin/zsh -c mgrastprod /bin/su - mgrastprod ============================================================================== tharriso => root ------------------------------------------------------------------------------ /bin/zsh ---------------------- Sudo (secure-log) End ------------------------- --------------------- Disk Space Begin ------------------------ Filesystem Size Used Avail Use% Mounted on /dev/mapper/Vol0-LV00 15G 8.1G 5.5G 60% / /dev/md0 99M 39M 55M 42% /boot /dev/mapper/Vol0-local 1.8T 138G 1.7T 8% /local ---------------------- Disk Space End ------------------------- ###################### Logwatch End #########################
participants (1)
logwatch@mcs.anl.gov
