Logwatch for berlin.mcs.anl.gov (Linux)
################### Logwatch 7.3 (03/24/06) #################### Processing Initiated: Fri Sep 21 04:02:02 2012 Date Range Processed: yesterday ( 2012-Sep-20 ) Period is day. Detail Level of Output: 0 Type of Output: unformatted Logfiles for Host: berlin.mcs.anl.gov ################################################################## --------------------- Automount Begin ------------------------ **Unmatched Entries** key "jobv3" not found in map source(s).: 1 Time(s) key "pi" not found in map source(s).: 1 Time(s) key "pu" not found in map source(s).: 1 Time(s) key "ac" not found in map source(s).: 1 Time(s) ---------------------- Automount End ------------------------- --------------------- pam_unix Begin ------------------------ sshd: Authentication Failures: dsouza (login1.mcs.anl.gov): 3 Time(s) su-l: Unknown Entries: session closed for user mgrastprod: 3 Time(s) session opened for user mgrastprod by jbischof(uid=0): 2 Time(s) session opened for user mgrastprod by tharriso(uid=0): 1 Time(s) sudo: Authentication Failures: dsouza(0) -> dsouza: 4 Time(s) jbischof(0) -> jbischof: 4 Time(s) tharriso(0) -> tharriso: 1 Time(s) ---------------------- pam_unix End ------------------------- --------------------- postfix Begin ------------------------ 4354 bytes transferred 1 messages sent 1 messages removed from queue ---------------------- postfix End ------------------------- --------------------- SSHD Begin ------------------------ Users logging in through sshd: dsouza: 140.221.9.199 (login1.mcs.anl.gov): 3 times 140.221.10.82 (dsouza.mcs.anl.gov): 2 times 140.221.76.12 (anzio-2.mcs.anl.gov): 1 time jbischof: 140.221.11.19 (jbischof.mcs.anl.gov): 2 times tharriso: 130.202.135.160 (mcswl160.mcs.anl.gov): 1 time Received disconnect: 11: disconnected by user : 7 Time(s) **Unmatched Entries** pam_krb5[17638]: TGT verified : 1 time(s) pam_krb5[17638]: error reading keytab 'FILE:/etc/krb5.keytab' : 1 time(s) pam_krb5[17653]: TGT verified : 1 time(s) pam_krb5[17653]: error reading keytab 'FILE:/etc/krb5.keytab' : 1 time(s) pam_krb5[21327]: error reading keytab 'FILE:/etc/krb5.keytab' : 1 time(s) pam_krb5[21327]: TGT verified : 1 time(s) ---------------------- SSHD End ------------------------- --------------------- Sudo (secure-log) Begin ------------------------ ============================================================================== dsouza => mgrastprod ------------------------------------------------------------------------------ /bin/zsh /bin/zsh dsouza => root ------------------------------------------------------------------------------ /bin/bash /bin/bash ============================================================================== jbischof => root ------------------------------------------------------------------------------ /bin/zsh /bin/zsh /bin/zsh /bin/zsh ============================================================================== tharriso => root ------------------------------------------------------------------------------ /bin/zsh ---------------------- Sudo (secure-log) End ------------------------- --------------------- Disk Space Begin ------------------------ Filesystem Size Used Avail Use% Mounted on /dev/mapper/Vol0-LV00 15G 8.1G 5.4G 60% / /dev/md0 99M 39M 55M 42% /boot /dev/mapper/Vol0-local 1.8T 138G 1.7T 8% /local ---------------------- Disk Space End ------------------------- ###################### Logwatch End #########################
participants (1)
logwatch@mcs.anl.gov
