Re: [Release-team] Many errors on redeployment of IRIS
Unfortunately, the way we're doing the release - it is a complete redeploy, or iris doesn't get any of the clients. This was necessary because we also upgraded the operating system version. I'm having a hard time figuring out what dependency might be missing from the errors. It is continuing to run with those errors though. One other thing, for some reason it isn't constructing the auth/nonauth storage path properly from the deployment.cfg, even though we have KB_DEPLOYMENT_CONFIG set, and the following defined: [invocation] authenticated-storage-dir = /data/storage-auth nonauthenticated-storage-dir = /data/storage-nonauth authenticated-storage = /data/storage-auth nonauthenticated-storage = /data/storage-nonauth service-url = http://kbase.us/services/invocation ---- Daniel Murphy-Olson Sr. Systems Administrator Mathematics & Computer Science Division Argonne National Laboratory 630-252-0055 ________________________________________ From: Olson, Robert D. Sent: Monday, February 10, 2014 11:39 AM To: Thomason, James; Murphy-Olson, Daniel E. Cc: [email protected] Subject: RE: Many errors on redeployment of IRIS Those errors look like it's trying to use a build of perl that is missing packages or something. ________________________________________ From: Thomason, James [[email protected]] Sent: Monday, February 10, 2014 11:38 AM To: Murphy-Olson, Daniel E. Cc: Olson, Robert D.; [email protected] Subject: Re: Many errors on redeployment of IRIS I’m unfamiliar with what the problems may be. I didn’t touch anything in invocation this time around, only twiddling a few javascript settings. This is deeper down - either in invocation or below that. Could you try just doing a deploy-iris instead of a full invocation build? I’d rather touch as little as possible, what with the demos and all. -- -Jim Thomason... Computational Science Developer @ The Ware Lab, a USDA-ARS Laboratory at Cold Spring Harbor Laboratory http://www.warelab.org/ http://www.cshl.edu/ On Feb 10, 2014, at 9:20 AM, Murphy-Olson, Daniel E. <[email protected]<mailto:[email protected]>> wrote: I'm getting a lot of errors on startup of iris. Please see the attached log. ---- Daniel Murphy-Olson Sr. Systems Administrator Mathematics & Computer Science Division Argonne National Laboratory 630-252-0055 <start.log>
participants (1)
