Re: [Release-team] Many errors on redeployment of IRIS
Is the service actually not starting? What we might be seeing is a set of warnings Class::MOP::load_class is deprecated at /kbase/runtimes/20140109-prod/lib/perl5/site_perl/5.16.2/x86_64-linux/Class/MOP.pm line 76. which are triggering backtraces due to the plack settings. I've seen this elsewhere with plack-based apps where warnings induced backtraces. At the very bottom of the log it looks like the service went on to log the storage locations which makes it look like it kept running until closed down. Or did it shut down on its own? ________________________________________ From: [email protected] [[email protected]] on behalf of Olson, Robert D. [[email protected]] Sent: Monday, February 10, 2014 11:39 AM To: Thomason, James; Murphy-Olson, Daniel E. Cc: [email protected] Subject: Re: [Release-team] Many errors on redeployment of IRIS Those errors look like it's trying to use a build of perl that is missing packages or something. ________________________________________ From: Thomason, James [[email protected]] Sent: Monday, February 10, 2014 11:38 AM To: Murphy-Olson, Daniel E. Cc: Olson, Robert D.; [email protected] Subject: Re: Many errors on redeployment of IRIS I’m unfamiliar with what the problems may be. I didn’t touch anything in invocation this time around, only twiddling a few javascript settings. This is deeper down - either in invocation or below that. Could you try just doing a deploy-iris instead of a full invocation build? I’d rather touch as little as possible, what with the demos and all. -- -Jim Thomason... Computational Science Developer @ The Ware Lab, a USDA-ARS Laboratory at Cold Spring Harbor Laboratory http://www.warelab.org/ http://www.cshl.edu/ On Feb 10, 2014, at 9:20 AM, Murphy-Olson, Daniel E. <[email protected]<mailto:[email protected]>> wrote: I'm getting a lot of errors on startup of iris. Please see the attached log. ---- Daniel Murphy-Olson Sr. Systems Administrator Mathematics & Computer Science Division Argonne National Laboratory 630-252-0055 <start.log> _______________________________________________ Release-team mailing list [email protected] https://lists.kbase.us/mailman/listinfo/release-team
participants (1)
Olson, Robert D.
