Re: [Mpi3-tools] [MPI3 Fortran] MPI function symbol naming convention for tools
It's not simply a re-compilation if you add all interface descriptions to mpif.h in order to change the interface names. In addition to the backward compatibility problem, nobody can guarantee that the re-compilation works independent on compiler bugs or other problems. Hubert
-----Original Message----- From: [email protected] [mailto:mpi3-tools- [email protected]] On Behalf Of Jeff Squyres Sent: Friday, June 24, 2011 6:46 PM To: MPI-3 Fortran working group Cc: MPI3 Tools Subject: Re: [Mpi3-tools] [MPI3 Fortran] MPI function symbol naming convention for tools
On Jun 24, 2011, at 12:20 PM, Hubert Ritzdorf wrote:
There are (compiled) libraries and object files containing the corresponding external references to MPI_SEND, mpi_send__, mpi_send_ or mpi_send. Therefore, you cannot simply change the interface of the MPI_Send routine without breaking these libraries. You can also not simply expect that they will be recompiled.
I think it is reasonable to ask applications / libraries / etc. to recompile with MPI-3. This has been the position of the Forum.
In addition, the mpif.h include file doesn't have an interface block (and will still generate the external references above)
It's actually not specified, right? Meaning that an implementation *could* use an interface block if they wanted to.
and Fortran 90 module doesn't have an optional error argument in the interface block even if you expect that the Fortran 90 module/compiler supports some NO_ARG_CHECK attribute.
We didn't add optional arguments to any of the existing MPI Fortran interfaces -- optional arguments are only (possibly) being added in the new F08 bindings.
-- Jeff Squyres [email protected] For corporate legal information go to: http://www.cisco.com/web/about/doing_business/legal/cri/
_______________________________________________ Mpi3-tools mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-tools
Click https://www.mailcontrol.com/sr/Jbc2kOnwVUbTndxI!oX7UlK7uOqmL!e8+HsCtP1TxJlQ 6Ug9oI5ig5!3Uqc1BfKxnNutHdm6V!yFfmYpsSvVwQ== to report this email as spam.
participants (1)
Hubert Ritzdorf
