Re: [Mpi3-tools] [MPI3 Fortran] MPI function symbol naming convention for tools
-----Original Message----- From: [email protected] [mailto:mpi3-fortran- [email protected]] On Behalf Of Bill Long Sent: Saturday, June 25, 2011 11:33 AM To: Martin Schulz Cc: MPI3 Tools; MPI-3 Fortran working group Subject: Re: [MPI3 Fortran] MPI function symbol naming convention for tools
On 6/24/11 11:54 AM, Martin Schulz wrote:
This is probably my lack of knowledge in Fortran compilers, but is this all even possible with regular compilers: I would assume that you can use an MPI 3.0 implementation with Craig's proposal (case A) with an older F77 or F90 compiler, right? If so, one would use "use mpi" or "mpif.h", i.e., case A.1. Can you do the name mapping from mpi_send to mpi_send_f - I thought this was a new feature from F08?
If you still have an old f77 compiler on you system (from decades ago), it will not be adequate. If you have a current version of a Fortran compiler available, you are in much better shape. The meaning of "Fortran" changes over time, and the compilers progress accordingly, with some time delay.
The name mapping of a call to MPI_send into a call to mpi_send_f is accomplished with generic interfaces. These were part of Fortran 90 (20 year old technology now) - F08 is not required for this. Other details of the interfaces do require more recent standards, however.
Craig's proposal would require at least Fortran 2003. Otherwise, the compiler may still generate MPI_SEND_F, mpi_send_f, mpi_send_f_ or mpi_send_f__. Hubert
participants (1)
Hubert Ritzdorf
