Re: [Mpi3-hybridpm] SHMEM Interface in Draft External Interfaces
I think we should extend the current view of the MPI_Shm handle. It shouldn't represent only a single shared memory region. It should be possible to handle several shared memory regions under a single MPI_shm handle. In this case, an attach function could look like MPI_Comm_shm_attach (MPI_Comm comm, MPI_shm shm_in, MPI_shm shmem_out, MPI_Info info) The Communicator "comm" would be any communicator created for example by an MPI_Comm_create_shmem () function call. "shm_in" might be any shared memory handle, located on the process call MPI_Comm_shm_attach. The function would create a new handle "shmem_out" containing the shared memory regions of all "shm_in" handles of comm. The communicator "comm" is associated to "shmem_out". The "shm_out" handle would represent N shared memory regions. An inquiry function MPI_Comm_shmem_num_regions could return the number of shared memory regions. An inquiry function MPI_Comm_shmem_region_info() could return a triple (baseptr, size and key) of the i-th shared memory region or a subset of shared memory regions. The unique key is required to identify the shared memory regions by the MPI processes. Hubert
participants (1)
Hubert Ritzdorf
