Re: [Mpi3-ft] Con Call on 1/4/2009
I am not going to be able to make it to today's call due to travel. My primary concern is that the proposal relies a bit too heavily on some flavor of checkpointing or message logging in order to make the interface useful. There should be a set of guidelines that make the interface useful without a form of checkpointing or message logging on the system. Though I think the door should always be open to these types of additional functionality, but as far as the base specification I think it should be usable without them. Best, Josh P.S. I should have a revised interface for the following proposal in the next week or so: https://svn.mpi-forum.org/trac/mpi-forum-web/wiki/Quiescence On Jan 20, 2009, at 6:54 PM, Greg Bronevetsky wrote:
Here's my quick writeup of the major problems that we discussed with writing modular apps on top of our proposed MPI fault tolerance spec and an approach for making it relatively easy to write module- specific error recovery algorithms without worrying about other modules. I've attached a pdf version as well as a txt version that will be easier to edit.
Greg Bronevetsky Post-Doctoral Researcher 1028 Building 451 Lawrence Livermore National Lab (925) 424-5756 [email protected]
At 06:58 PM 1/13/2009, Richard Graham wrote:
OK, we will resume the calls next week, 1/21/2009.
Rich
On 1/13/09 11:42 AM, "Greg Bronevetsky" <[email protected]> wrote:
Unfortunately, for reasons out of [my] control, I did not manage
to
get the time to update the wiki and I doubt I will find any time before the call tomorrow. I'll have time to get back to this starting from tomorrow morning.
I second your idea to cancel the call tomorrow.
I have a protocol worked out to do micro-rollbacks that will work well if we add to the API some kind of asynchronous event notification mechanism like active messages. It will work not as well without the extension. I'll update George's document once its posted so that we have a unified document that describes the problem and the proposed solutions.
_______________________________________________ mpi3-ft mailing list [email protected] http:// lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-ft
_______________________________________________ mpi3-ft mailing list [email protected] http:// lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-ft <Support for Developing Fault Tolerant Modular MPI Applications.pdf><Support for Developing Fault Tolerant Modular MPI Applications.txt>_______________________________________________ mpi3-ft mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-ft
participants (1)
Josh Hursey
