Re: [Mpi3-ft] Con Call on 1/4/2009
Actually, something came up and I won't be able to make this con call either. However, I hope that we can have a good discussion over email. While I did not document the protocol in full algorithmic detail, I can point people to some of my prior papers such as http://greg.bronevetsky.com/papers/2003PPoPP.pdf as evidence that systems like this that work above MPI have successfully been implemented in the past. Josh, you make a good point that relying on heavy-weight support in order to make the API useful suggests that the API is insufficient. My point in drafting my solution is that the only component required to make the API useful is one that does not need additional API modifications and thus, does not need to be standardized. Of course, we could put in the appropriate components into the official API but that would make it weaker rather than stronger. I can point to the ABI debate as an analogy for what I'm suggesting here. Option 1 is to standardize the ABI. Option 2 is to develop a heavy-weight support tool like MorphMPI that makes the current API more useful (i.e. resolves most of the issues that motivate the ABI) and does not require any additional standardization. I think that most people agree that Option 2 is the better choice. The point here is that Fault Tolerance is hard and it requires a lot of runtime support to make application-implemented fault tolerance reasonably easy. We've identified much of the critical functionality that must be inside MPI in order for such functionality to be enjoyed by applications. We are now also identifying possible additional libraries that may also be necessary to make the API usable but that do not need to be standardized. In particular, we will probably come up with several such libraries that support a variety of application types (consider the minimal support required for monte carlo codes or non-modular codes), which is further evidence that this component, while important, should not be standardized. Greg Bronevetsky Post-Doctoral Researcher 1028 Building 451 Lawrence Livermore National Lab (925) 424-5756 [email protected] At 07:04 AM 1/21/2009, Josh Hursey wrote:
I am not going to be able to make it to today's call due to travel.
My primary concern is that the proposal relies a bit too heavily on some flavor of checkpointing or message logging in order to make the interface useful. There should be a set of guidelines that make the interface useful without a form of checkpointing or message logging on the system. Though I think the door should always be open to these types of additional functionality, but as far as the base specification I think it should be usable without them.
Best, Josh
P.S. I should have a revised interface for the following proposal in the next week or so: https:// svn.mpi-forum.org/trac/mpi-forum-web/wiki/Quiescence
On Jan 20, 2009, at 6:54 PM, Greg Bronevetsky wrote:
Here's my quick writeup of the major problems that we discussed with writing modular apps on top of our proposed MPI fault tolerance spec and an approach for making it relatively easy to write module- specific error recovery algorithms without worrying about other modules. I've attached a pdf version as well as a txt version that will be easier to edit.
At 06:58 PM 1/13/2009, Richard Graham wrote:
OK, we will resume the calls next week, 1/21/2009.
Rich
On 1/13/09 11:42 AM, "Greg Bronevetsky" <[email protected]> wrote:
Unfortunately, for reasons out of [my] control, I did not manage
to
get the time to update the wiki and I doubt I will find any time before the call tomorrow. I'll have time to get back to this starting from tomorrow morning.
I second your idea to cancel the call tomorrow.
I have a protocol worked out to do micro-rollbacks that will work well if we add to the API some kind of asynchronous event notification mechanism like active messages. It will work not as well without the extension. I'll update George's document once its posted so that we have a unified document that describes the problem and the proposed solutions.
_______________________________________________ mpi3-ft mailing list [email protected] http:// lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-ft
_______________________________________________ mpi3-ft mailing list [email protected] http:// lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-ft <Support for Developing Fault Tolerant Modular MPI Applications.pdf><Support for Developing Fault Tolerant Modular MPI Applications.txt>_______________________________________________ mpi3-ft mailing list [email protected] http:// lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-ft
participants (1)
Greg Bronevetsky
