Re: [MPI3 Fortran] Fwd: Serious problem/bug in MPI libraries with the alignment of MPI_DOUBLE_PRECISION
Hi Rolf, Although you list below a "CrayMPI", for organizing the results, keep in mind that it is based on mpich2. On 9/27/11 4:40 PM, Rolf Rabenseifner wrote:
Here the summary of the feedback and a proposal to solve this inconsistency.
A) The 4 / 8 / 4 group = alignment of MPI_DOUBLE_PRECISION is correct for (old-style) SEQUENCE derived types
JeffSquyres_OpenMP_linux-x86-64-ifort.txt: Intel + OpenMPI on x86-64 Results: 4 / 8 / 4 FabTillier_Intel+MicrosoftMPI_out.txt: Intel + MS-MPI on ? Results: 4 / 8 / 4
B) The 4 / 8 / 8 group = alignment of MPI_DOUBLE_PRECISION is correct for (modern) BIND(C) derived types
Rajeev_mpich_out.ifort.x86-64.txt: Intel + mpich2 on x86-64 Results: 4 / 8 / 8 Rolf_asama+cray_output.txt: Intel + NEC-MPI? on asama Results: 4 / 8 / 8 BillLong_Cray_5compiler_out.txt: Intel + CrayMPI on Cray XE6 Results: 4 / 8 / 8 BrianSmith-IBM_outlog-bgp-xl.txt: Intel + IBM-XL on BGP Results: 4 / 8 / 8 BrianSmith-IBM_outlog-xlf.txt: xlf + IBM-XL on ? Results: 4 / 8 / 8
C) No problems because all DOUBLE PRECISION alignments are identical = 8
BillLong_Cray_5compiler_out.txt: PGI + CrayMPI on Cray XE6 Results: 8 / 8 / 8 BillLong_Cray_5compiler_out.txt: Cray + CrayMPI on Cray XE6 Results: 8 / 8 / 8 BillLong_Cray_5compiler_out.txt: gfortran + CrayMPI on Cray XE6 Results: 8 / 8 / 8 BillLong_Cray_5compiler_out.txt: pathscale + CrayMPI on Cray XE6 Results: 8 / 8 / 8 BrianSmith-IBM_outlog-gcc.txt: gfortran + IBM-XL on BGQ Results: 8 / 8 / 8 JeffSquyres_OpenMP_linux-x86-64-gfortran.txt: gfortran + OpenMPI on x86-64 Results: 8 / 8 / 8 JeffSquyres_OpenMP_osx-x86-84-gfortran.txt: gfortran + OpenMPI on osx-x86-64 Results: 8 / 8 / 8 Rajeev_gnu_laptop_out.txt: gfortran + mpich2 on laptop Results: 8 / 8 / 8 Rajeev_mpich_out.gfortran.x86-64.txt: gfortran + mpich2 on x86-64 Results: 8 / 8 / 8
D) No problems because all DOUBLE PRECISION alignments are identical = 4
Rajeev_mpich_out.gfortran.ia32.txt: gfortran + mpich2 on ia32 Results: 4 / 4 / 4 Rajeev_mpich_out.ifort.ia32.txt: Intel + mpich2 on ia32 Results: 4 / 4 / 4
Proposal: ---------
The goal of a standard is the possibility to write portable code. Therefore the answer should be standardized and not implementation-specific, or in other words, not defining it is the worst solution.
I expect only a few Fortran codes are using arrays of derived types in Fortran.
My experience leads me to think that codes use arrays of derived types more often than you expect.
The oldest library is mpich. Therefore I would propose to standardize Fortran alignments are based on BIND(C) which should be the same as in C.
This would seem to be the efficient solution. Cheers, Bill -- Bill Long [email protected] Fortran Technical Support & voice: 651-605-9024 Bioinformatics Software Development fax: 651-605-9142 Cray Inc./Cray Plaza, Suite 210/380 Jackson St./St. Paul, MN 55101
participants (1)
Bill Long
