[MPI3 Fortran] Fwd: Serious problem/bug in MPI libraries with the alignment of MPI_DOUBLE_PRECISION
Here the summary of the feedback and a proposal to solve this inconsistency. ----- Forwarded Message ----- From: "Rolf Rabenseifner" <[email protected]> To: "Jeff Squyres" <[email protected]>, "Shinji Sumimoto" <[email protected]>, "Hubert Ritzdorf" <[email protected]>, "Howard Pritchard" <[email protected]>, "Brian Smith" <[email protected]>, "Charles J Archer" <[email protected]>, "Rajeev Thakur" <[email protected]>, "Fab Tillier" <[email protected]>, "Bill Long" <[email protected]>, "Bill Gropp" <[email protected]>, "Richard Graham" <[email protected]> Cc: "N.M. Maclaren" <[email protected]>, "Iain Bason" <[email protected]> Sent: Tuesday, September 27, 2011 11:38:45 PM Subject: Re: Serious problem/bug in MPI libraries with the alignment of MPI_DOUBLE_PRECISION Dear all, thank you very much for the fast answers. The result is maximal bad, i.e., about 50% of the MPIs use SEQUENCE alignments and other about 50% use BIND(C) based calculation of the alignment. Here the results (also attached as summary_out.txt). Please read carefully my proposal after this summary sheet. In all protocols: ----------------- Size of one Fortran REAL = 4 Size of one Fortran DOUBLE PRECISION = 8 Results: -------- a / b / c = Alignments of: - DOUBLE PRECISION within a SEQUENCE derived type = a - DOUBLE PRECISION within a BIND(C) derived type = b - MPI_DOUBLE_PRECISION (= k_i in MPI-2.2 p.78:45) = c A) The 4 / 8 / 4 group = alignment of MPI_DOUBLE_PRECISION is correct for (old-style) SEQUENCE derived types JeffSquyres_OpenMP_linux-x86-64-ifort.txt: Intel + OpenMPI on x86-64 Results: 4 / 8 / 4 FabTillier_Intel+MicrosoftMPI_out.txt: Intel + MS-MPI on ? Results: 4 / 8 / 4 B) The 4 / 8 / 8 group = alignment of MPI_DOUBLE_PRECISION is correct for (modern) BIND(C) derived types Rajeev_mpich_out.ifort.x86-64.txt: Intel + mpich2 on x86-64 Results: 4 / 8 / 8 Rolf_asama+cray_output.txt: Intel + NEC-MPI? on asama Results: 4 / 8 / 8 BillLong_Cray_5compiler_out.txt: Intel + CrayMPI on Cray XE6 Results: 4 / 8 / 8 BrianSmith-IBM_outlog-bgp-xl.txt: Intel + IBM-XL on BGP Results: 4 / 8 / 8 BrianSmith-IBM_outlog-xlf.txt: xlf + IBM-XL on ? Results: 4 / 8 / 8 C) No problems because all DOUBLE PRECISION alignments are identical = 8 BillLong_Cray_5compiler_out.txt: PGI + CrayMPI on Cray XE6 Results: 8 / 8 / 8 BillLong_Cray_5compiler_out.txt: Cray + CrayMPI on Cray XE6 Results: 8 / 8 / 8 BillLong_Cray_5compiler_out.txt: gfortran + CrayMPI on Cray XE6 Results: 8 / 8 / 8 BillLong_Cray_5compiler_out.txt: pathscale + CrayMPI on Cray XE6 Results: 8 / 8 / 8 BrianSmith-IBM_outlog-gcc.txt: gfortran + IBM-XL on BGQ Results: 8 / 8 / 8 JeffSquyres_OpenMP_linux-x86-64-gfortran.txt: gfortran + OpenMPI on x86-64 Results: 8 / 8 / 8 JeffSquyres_OpenMP_osx-x86-84-gfortran.txt: gfortran + OpenMPI on osx-x86-64 Results: 8 / 8 / 8 Rajeev_gnu_laptop_out.txt: gfortran + mpich2 on laptop Results: 8 / 8 / 8 Rajeev_mpich_out.gfortran.x86-64.txt: gfortran + mpich2 on x86-64 Results: 8 / 8 / 8 D) No problems because all DOUBLE PRECISION alignments are identical = 4 Rajeev_mpich_out.gfortran.ia32.txt: gfortran + mpich2 on ia32 Results: 4 / 4 / 4 Rajeev_mpich_out.ifort.ia32.txt: Intel + mpich2 on ia32 Results: 4 / 4 / 4 Proposal: --------- The goal of a standard is the possibility to write portable code. Therefore the answer should be standardized and not implementation-specific, or in other words, not defining it is the worst solution. I expect only a few Fortran codes are using arrays of derived types in Fortran. The oldest library is mpich. Therefore I would propose to standardize Fortran alignments are based on BIND(C) which should be the same as in C. This would imply that IBM-XL and mpich2 and derivatives need no change. But it also implies that the younger OpenMPI and Microsoft-MPI need a change. These implementation may add an environment switch to keep the old behavior if this switch is set, but I would expect that there is nearly no user who needs or want to use this switch. Fab and Jeff, could you live with this proposal? Best regards Rolf PS: Additional remarks: Yes, some compiler detect that DOUBLE PR. on 4 byte alignment is inefficient, but this is only an information. Other compilers detect, that we use DOUBLE PRECISION in BIND(C) derived types instead of using the C double through these new intrinsic C types in Fortran. This is also okay and all compiler work as expected, they use the C alignment.
Rolf Rabenseifner wrote on Tue, 27 Sep 2011 at 09:14:33
In my output from Cray, the compilers - gnu - pgi - cray all use 8 byte double alignment in C and Fortran. ==> no problem with those compilers on the tested platform. Maybe we have differences between IA64 and 32 architectures for the same compiler.
Important is to check MPI with those compilers that have Fortran 4 byte double precision alignment (e.g. Intel).
Best regards Rolf
On Sep 27, 2011, at 10:21 AM, Rolf Rabenseifner wrote:
Dear all, (now with attachment)
as far as I know, you represent some MPI libraries that are not directly based on another one in the list: - mpich2: Rajeev - OpenMPI: Jeff - IBM: Rich Treumann - NEC: Hubert - Fujitsu: Shinji Sumimoto - Microsoft: Fab (Which independent library is missing on this list?) (Who of the list uses already mich2 or OpenMPI as bases or does not provide a Fortran binding, and can be therefore removed from this list?)
The problem is simple and has at the end only three numbers:
Alignments of: - DOUBLE PRECISION within a SEQUENCE derived type = 4 (e.g. with Intel) - DOUBLE PRECISION within a BIND(C) derived type = 8 - MPI_DOUBLE_PRECISION (= k_i in MPI-2.2 p.78:45) = 4 or 8 The details: Which is the alignment of Fortran DOUBLE PRECISION according to k_i on MPI-2.2, page 78 line 45 and page 96 line 42.
Since 1977 (Fortran 77) in Fortran COMMON blocks and 1990 (Fortran 90) in Fortran SEQUENCE derived types (which have the same memory layout according to the SEQUENCE-rules), the MPI alignment and the Fortran alignment in such constructs should be the same, e.g., the Intel compiler has alignment 4 !!!
This may be significantly different to C, where Intel uses alignment 8!
With Fortran 2003, we got the Fortran BIND(C) derived types. Here, a Fortran DOUBLE PRECISION has with Intel's compiler the alignment 8.
As far as I understand, mpich2 and Cray produce following results with an Intel compiler:
Alignments of: - DOUBLE PRECISION within a SEQUENCE derived type = 4 - DOUBLE PRECISION within a BIND(C) derived type = 8 - MPI_DOUBLE_PRECISION (= k_i in MPI-2.2 p.78:45) = 8
This is definitely wrong compared to MPI-1.1 and MPI-2.0 but may be helpful for MPI-3.0 when we like to switch to a definition that is based on BIND(C).
Question: What is the output of the attached test program when running with - your MPI library - and your compiler - and with Intel's compiler
Please can you send me the output of such mpiruns?
Thanks in advance and best regards Rolf
PS: We need not to care about 8/8/8. Only 4/8/x causes problems: If all those have x=8 then I'll propose to adopt the MPI-3.0 to the reality. If we have some implementations with 4/8/8 and others with 4/8/4 then we have a serious problem because only one answer can be correct, and the question would be whether the historical answer (x=4) or the modern answer (x=8) should be chosen.
-- Dr. Rolf Rabenseifner . . . . . . . . . .. email [email protected] High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner Nobelstr. 19, D-70550 Stuttgart, Germany . (Office: Allmandring 30) -- Dr. Rolf Rabenseifner . . . . . . . . . .. email [email protected] High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner Nobelstr. 19, D-70550 Stuttgart, Germany . (Office: Allmandring 30)
participants (1)
Rolf Rabenseifner
