Re: [MPIWG Fortran] Type of MPI_Status
To be clear, to-be-released OMPI's type for MPI_Status is: ! Get the KIND value that will be compatible with C, but also be a ! default INTEGER. That way, all the BIND(C) types below will be ! compatible with BIND(C) (because their member(s) will be BIND(C) ! compatible). integer, parameter :: OMPI_INT_KIND = kind(INTEGER) type, BIND(C) :: MPI_Status integer(OMPI_INT_KIND) :: MPI_SOURCE integer(OMPI_INT_KIND) :: MPI_TAG integer(OMPI_INT_KIND) :: MPI_ERROR integer(C_INT) OMPI_PRIVATE :: c_cancelled integer(C_SIZE_T) OMPI_PRIVATE :: c_count end type MPI_Status and also type, BIND(C) :: MPI_Comm integer(OMPI_INT_KIND) :: MPI_VAL end type MPI_Comm etc. I have to think through the ABI implications of this, however -- it may not make it into the v1.7.5/1.8 series if it creates an ABI incompatibility with OMPI 1.7.3/1.7.4 (i.e., it may have to wait until 1.9). On Mar 17, 2014, at 12:52 PM, Craig Rasmussen <[email protected]> wrote:
Jeff and I had a similar conversation last week. It is my viewpoint that the MPI-3 interfaces are formal interfaces that can be adapted by an implementation in a way that formally meets the specification.
For Open MPI I believe that Jeff will add configuration magic to check is INTEGER(C_INT) and default INTEGER have the same KIND value. This should be true for 100% of the compilers. If not, then that compiler will not be able to build Open MPI.
The use of INTEGER(C_INT) to replace the default INTEGER in the MPI types is needed to stopped compiler warning from GNU. We did this work (adding BIND(C) to gfortran) at Los Alamos and I think we perhaps got carried away with the warning messages.
Craig Rasmussen CAS Scientific Programmer [email protected]
On Mar 14, 2014, at 4:11 PM, Junchao Zhang wrote:
Not sure if it is worth discussing. Even if INTEGER and C_INT are of different size, I think I can still use C_INT in MPI_Status.
TYPE, BIND(C) :: MPI_Status INTEGER(C_INT) :: MPI_SOURCE, MPI_TAG, MPI_ERROR ... ! other fields END TYPE MPI_Status
Since MPI_Status is a derived datatype, users access it through its public interfaces(i.e., %MPI_SOURCE, ..., MPI_STATUS_SIZE). As long as MPI_STATUS_SIZE >= sizeof(MPI_STATUS)/sizeof(INTEGER), who cares its internals.
--Junchao Zhang
On Thu, Mar 13, 2014 at 10:56 AM, Rolf Rabenseifner <[email protected]> wrote: Jeff is right. Bill's theoretical statement is also correct.
And ticket#415 is also correct because it resolves an inconsistency within the mpi_f08 interface.
Strange theoretical discussions are also there for long Fortran INTEGER may not be identical with some shorter INTEGER(C_int). As a side effect also solved by this ticket.
Rolf
----- Original Message -----
From: "Jeff Hammond" <[email protected]> To: "MPI-WG Fortran working group" mpi-forum.org> Sent: Thursday, March 13, 2014 4:12:56 PM Subject: Re: [MPIWG Fortran] Type of MPI_Status
MPI should test for interoperability of Fortran's default integer and light the machine room on fire if it is not.
Jeff
On Thu, Mar 13, 2014 at 8:58 AM, Bill Long <[email protected]> wrote:
This does raise an earlier issue that it is possible that Fortran’s default INTEGER is not an interoperable type, and thus the MPI_Status type should not be a BIND(C) type if it has INTEGER components. Having BIND(C) does allow you to declare a C global name MPI_STATUS_IGNORE in Fortran, which solves one problem nicely. I don’t see any advantage to having INTEGER components (as opposed to INTEGER(C_Int), for example). So this seems to represent the worse of the two options.
Cheers, Bill
On Mar 13, 2014, at 8:36 AM, Jeff Squyres (jsquyres) <[email protected]> wrote:
Done. Good catch:
https://svn.mpi-forum.org/trac/mpi-forum-web/ticket/415
This is a trivial ticket, but if you could make sure it's ok, I'll send it to the mpi-forum list so that it can get added to the next meeting's agenda.
On Mar 13, 2014, at 1:51 AM, Rolf Rabenseifner <[email protected]> wrote:
Jeff and Junchao,
it is a missing word INTEGER in this part of the sentence
In whole MPI these three values are in Fortran INTEGER and nothing else
Junchao, thank you for the hint that an erratum is neede to prevent from such misinterpretation
Jeff, please can you file the errata ticket resulting in
... containing three public INTEGER fields named ...
Best regards Rolf
From: "Junchao Zhang" <[email protected]> To: "MPI-WG Fortran working group" mpi-forum.org> Sent: Thursday, March 13, 2014 4:49:49 AM Subject: [MPIWG Fortran] Type of MPI_Status
Hello,
p30 of MPI3 says "In Fortran with USE mpi or INCLUDE ’mpif.h’, status is an array of INTEGERs of size MPI_STATUS_SIZE. ..., With Fortran USE mpi_f08, status is defined as the Fortran BIND(C) derived type TYPE(MPI_Status) containing three public fields named MPI_SOURCE , MPI_TAG , and MPI_ERROR"
In other words, it does't say type of the three public fields must be INTEGER. So, in mpi_f08, can I declare MPI_Status as
I find it makes MPI_Status binding easier. Since this type is interoperable with C, I do not need to allocate temp variables to do type conversion when INTEGER is not a C_INT.
--Junchao Zhang _______________________________________________ mpiwg-fortran mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpiwg-fortran
-- Dr. Rolf Rabenseifner . . . . . . . . . .. email [email protected] High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner Nobelstr. 19, D-70550 Stuttgart, Germany . . . . (Office: Room 1.307) _______________________________________________ mpiwg-fortran mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpiwg-fortran
-- Jeff Squyres [email protected] For corporate legal information go to: http://www.cisco.com/web/about/doing_business/legal/cri/
Bill Long [email protected] Fortran Technical Suport & voice: 651-605-9024 Bioinformatics Software Development fax: 651-605-9142 Cray Inc./ Cray Plaza, Suite 210/ 380 Jackson St./ St. Paul, MN 55101
-- Jeff Hammond [email protected] _______________________________________________ mpiwg-fortran mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpiwg-fortran
participants (1)
