Re: [MPIWG Fortran] Type of MPI_Status
On Mar 16, 2014, at 7:47 AM, Rolf Rabenseifner <[email protected]> wrote:
Dear Junchao,
I had not the time to go through all details, but I detected two issues:
1. TYPE(MPI_Status) must be declared with BIND(C). It is missing in your example below.
This seems to be needed only so that the routines that convert between the Fortran and C versions of MPI_Status are callable from C. It would have been a better design to have required that there be only one version of the MPI_Status struct - the Fortran and C structs are the same. That would require that the Fortran version have bind(c) for some uses, but a separate C_Status would not be needed. Also, the conversion routines could be discarded.
2. To declare an equivalent struct in C, i.e., the C type MPI_F08_status, you should use MPI_Fint and not int.
Similarly, this complication would not be needed either. Even with the current scheme, making a struct for C that looks like the Fortran struct would seem to not have any purpose. It is useful to have a type definition in Fortran for the C struct (C_Status in the earlier example), which would be used in the currently needed conversion routines. I have yet to find any use for MPI_Fint. It appears to be for a C function to call a non-bind(c) Fortran routine that has INTEGER arguments, but that seems unlikely to actually happen. The library is in C and Fortran calls to C, not the other way around. Unless there is some obscure usage in the Fortran tools interface. (Craig and Jeff both know my solution to that. :) ) Cheers, Bill
See MPI-3.0 p30:24-26 + ticket #415 and Sect. 17.2..5.
Best regards Rolf
----- Original Message -----
From: "Junchao Zhang" <[email protected]> To: "MPI-WG Fortran working group" <[email protected]> Sent: Saturday, March 15, 2014 10:52:42 PM Subject: Re: [MPIWG Fortran] Type of MPI_Status
Rolf, you are right. Passing MPI%MPI_SOURCE as an argument will cause problems. Thanks. I list why I wanted to use c_int in MPI_Status. It is amusing. Without c_int, the design is something like
type MPI_Status INTEGER :: MPI_SOURCE, MPI_ERROR, MPI_TAG ! other fields end type MPI_Status
type(MPI_Status), parameter :: MPI_STATUS_IGNORE = ...
type c_Status INTEGER(c_int) :: MPI_SOURCE, MPI_ERROR, MPI_TAG ! other fields end type c_Status
type(c_Status), BIND(C, name="MPIR_C_STATUS_IGNORE") :: MPIR_C_STATUS_IGNORE
! Declare the C function prototype to bind function MPIR_Example_c(len, counts, status) result(ierror) BIND(C, name="MPI_Example") integer(c_int), intent(in) :: len integer(c_int), intent(in) :: counts(len) type(c_Status) :: status integer(c_int) :: ierror end function
subroutine MPI_Example_f08(len, counts, status, ierror) integer, intent(in) :: len integer, intent(in) :: counts(len) type(MPI_Status) :: status integer, optional :: ierror_c
integer(c_int), intent(in) :: len_c integer(c_int), intent(in) :: counts_c(len) type(c_Status) :: status_c integer(c_int) :: ierror_c
if (c_int == kind(0) then ! Common case if (c_loc(status) == c_loc(MPI_STATUS_IGNORE)) then ! In C MPI_Example, it will checks again if status is 'IGNORE'. But we have to duplicate the work here due to type difference of MPI_STATUS_IGNORE and MPIR_C_STATUS_IGNORE. ierror = MPIR_Example_c(len, counts, MPIR_C_STATUS_IGNORE) else ! ierror = MPIR_Example_c(len, counts, status) ! Compile error since type(MPI_Status) mismatches type(c_Status) even c_int = INTEGER ierror = MPIR_Example_c(len, counts, status_c) status = status_c ! Note that = is overloaded. Can Compiler optimize away this copy propogation? probably not. endif ! This is bad since MPI_Status and c_Status are indeed the same. Even worse if status is an array. else len_c = len counts_c = counts if (c_loc(status) == c_loc(MPI_STATUS_IGNORE)) then ierror = MPIR_Example_c(len_c, counts_c, MPIR_C_STATUS_IGNORE) else ierror = MPIR_Example_c(len_c, counts_c, status_c) status = status_c endif endif
if(present(ierror)) ierror = ierror_c end subroutine
However, if I can use c_int in MPI_Status, then MPI_Status and c_Status are the same. I will have
type MPI_Status INTEGER(c_int) :: MPI_SOURCE, MPI_ERROR, MPI_TAG ! other fields end type MPI_Status
type(MPI_Status), BIND(C, name="MPI_STATUS_IGNORE") :: MPI_STATUS_IGNORE
function MPIR_Example_c(len, counts, status) result(ierror) BIND(C, name="MPI_Example") integer(c_int), intent(in) :: len integer(c_int), intent(in) :: counts(len) type(MPI_Status) :: status ! Now use MPI_Status instead of c_Status integer(c_int) :: ierror end function
integer(c_int), intent(in) :: len_c integer(c_int), intent(in) :: counts_c(len) integer(c_int) :: ierror_c
if (c_int == kind(0) then ierror = MPIR_Example_c(len, counts, status) ! Zero overhead incurred on status. else len_c = len counts_c = counts ierror = MPIR_Example_c(len_c, counts_c, status) endif
--Junchao Zhang
On Sat, Mar 15, 2014 at 7:38 AM, Rolf Rabenseifner < [email protected] > wrote:
Dear Junchao,
As long as you use status%MPI_SOURCE in an expression, all is fine.
If you pass it to an application routine dummy argument that is defined as INTEGER and your status%MPI_SOURCE is define as INTEGER(C_INT) then you may get compiler warnings or errors if size of both INTEGER types is different.
CALL foo(status%MPI_SOURCE)
with SUBROUTINE foo(rank) INTEGER :: rank
Best regards Rolf
From: "Junchao Zhang" < [email protected] > To: "MPI-WG Fortran working group" mpi-forum.org >
Sent: Saturday, March 15, 2014 11:54:38 AM Subject: Re: [MPIWG Fortran] Type of MPI_Status
My point is, with the C_INT implementation of MPI_Status, there should be no compilation warnings AND runtime errors, even if INTEGER kind is not c_int, since users can only operate MPI_Status through their public interfaces, in which we take care of data conversion.
But for other arguments of type INTEGER or array of INTEGERs, I can not change their type. Users pass in an array of INTEGERs, I can not pretend they are c_int and don't do conversion.
--Junchao Zhang
On Sat, Mar 15, 2014 at 3:33 AM, Rolf Rabenseifner < [email protected] > wrote:
Junchao,
With the erratum ticket #415, your implementation with INTEGER(C_INT) is clearly wrong, but who cares as long as an application programmer cannot write an application code that produces compilation errors or warnings or infos due to your wrong implementation of TYPE(MPI_Status).
I do not exactly now the rules about Fortran subroutine prototype and overloading where handing over a INTEGER rank or a INTEGER(C_INT) rank may cause to choose different interfaces.
Maybe that Bill Long should comment on such strange things before you define any field within TYPE(MPI_Status) or any dummy argument in a routine declaration as INTEGER(C_INT) instead of INTEGER as defined in MPI-3.0.
Best regards Rolf
Sent: Saturday, March 15, 2014 12:11:35 AM Subject: Re: [MPIWG Fortran] Type of MPI_Status
Not sure if it is worth discussing. Even if INTEGER and C_INT are of different size, I think I can still use C_INT in MPI_Status.
TYPE, BIND(C) :: MPI_Status INTEGER(C_INT) :: MPI_SOURCE, MPI_TAG, MPI_ERROR ... ! other fields END TYPE MPI_Status
Since MPI_Status is a derived datatype, users access it through its public interfaces(i.e., %MPI_SOURCE, ..., MPI_STATUS_SIZE). As long as MPI_STATUS_SIZE >= sizeof(MPI_STATUS)/sizeof(INTEGER), who cares its internals.
--Junchao Zhang
On Thu, Mar 13, 2014 at 10:56 AM, Rolf Rabenseifner < [email protected] > wrote:
Jeff is right. Bill's theoretical statement is also correct.
And ticket#415 is also correct because it resolves an inconsistency within the mpi_f08 interface.
Strange theoretical discussions are also there for long Fortran INTEGER may not be identical with some shorter INTEGER(C_int). As a side effect also solved by this ticket.
Rolf
From: "Jeff Hammond" < [email protected] > To: "MPI-WG Fortran working group" mpi-forum.org > Sent: Thursday, March 13, 2014 4:12:56 PM Subject: Re: [MPIWG Fortran] Type of MPI_Status
MPI should test for interoperability of Fortran's default integer and light the machine room on fire if it is not.
Jeff
On Thu, Mar 13, 2014 at 8:58 AM, Bill Long < [email protected] > wrote:
This does raise an earlier issue that it is
possible that Fortran’s default INTEGER is not an interoperable type, and thus the MPI_Status type should not be a BIND(C) type if it has INTEGER components. Having BIND(C) does allow you to declare a C global name MPI_STATUS_IGNORE in Fortran, which solves one problem nicely. I don’t see any advantage to having INTEGER components (as opposed to INTEGER(C_Int), for example). So this seems to represent the worse of the two options.
Cheers, Bill
On Mar 13, 2014, at 8:36 AM, Jeff Squyres (jsquyres) < [email protected] > wrote:
Done. Good catch:
https://svn.mpi-forum.org/trac/mpi-forum-web/ticket/415
This is a trivial ticket, but if you could make sure it's ok, I'll send it to the mpi-forum list so that it can get added to the next meeting's agenda.
On Mar 13, 2014, at 1:51 AM, Rolf Rabenseifner < [email protected] > wrote:
Jeff and Junchao,
it is a missing word INTEGER in this part of the sentence
In whole MPI these three values are in Fortran INTEGER and nothing else
Junchao, thank you for the hint that an erratum is neede to prevent from such misinterpretation
Jeff, please can you file the errata ticket resulting in
... containing three public INTEGER fields named ...
Best regards Rolf
mpi-forum.org > Sent: Thursday, March 13, 2014 4:49:49 AM Subject: [MPIWG Fortran] Type of MPI_Status
Hello,
p30 of MPI3 says "In Fortran with USE mpi or INCLUDE ’mpif.h’, status is an array of INTEGERs of size MPI_STATUS_SIZE. ..., With Fortran USE mpi_f08, status is defined as the Fortran BIND(C) derived type TYPE(MPI_Status) containing three public fields named MPI_SOURCE , MPI_TAG , and MPI_ERROR"
In other words, it does't say type of the three public fields must be INTEGER. So, in mpi_f08, can I declare MPI_Status as
I find it makes MPI_Status binding easier. Since this type is interoperable with C, I do not need to allocate temp variables to do type conversion when INTEGER is not a C_INT.
--Junchao Zhang _______________________________________________ mpiwg-fortran mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpiwg-fortran
-- Dr. Rolf Rabenseifner . . . . . . . . . .. email [email protected] High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner Nobelstr. 19, D-70550 Stuttgart, Germany . . . . (Office: Room 1.307) _______________________________________________ mpiwg-fortran mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpiwg-fortran
-- Jeff Squyres [email protected] For corporate legal information go to: http://www.cisco.com/web/about/doing_business/legal/cri/
Bill Long [email protected] Fortran Technical Suport & voice: 651-605-9024 Bioinformatics Software Development fax: 651-605-9142 Cray Inc./ Cray Plaza, Suite 210/ 380 Jackson St./ St. Paul, MN 55101
-- Jeff Hammond [email protected] _______________________________________________ mpiwg-fortran mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpiwg-fortran
participants (1)
Bill Long
