Re: [MPIWG Fortran] INTENT and ASYNCHRONOUS
On Jun 6, 2018, at 11:29 AM, Bill Long <[email protected]> wrote:
----- OMPI_FORTRAN_IGNORE_TKR_TYPE, INTENT(IN), ASYNCHRONOUS :: origin_addr ^ "../../../../../openmpi-master-201806060243-64a5baa/ompi/mpi/fortran/use-mpi-f08/accumulate_f08.F90", Line = 16, Column = 46: ERROR: Attributes ASYNCHRONOUS and INTENT must not appear in the same attribute list. -----
I don’t see a restriction like that, at least in F2018. I tried this:
Subroutine csub (x) real,intent(inout),asynchronous :: x end Subroutine csub
with maximum diagnostics and got no messages with the Cray compiler which is quite good at testing conformance.
Ok. Thanks.
Or is this a compiler bug?
It would appear to be the case. It might be the case that the usage in the routine is incompatible with INTENT(IN), but that message should be differently worded. Of course, OMPI_FORTRAN_IGNORE_TKR_TYPE is certainly not a valid type declaration. I assume they intend TYPE(*).
Yeah, that's a #define. -- Jeff Squyres [email protected]
participants (1)
Jeff Squyres (jsquyres)
