Re: [MPIWG Fortran] INTENT and ASYNCHRONOUS
Yeah, we haven't had any other reports about this issue (it's specifically complaining about MPI_ACCUMULATE), and I don't think Open MPI's code has changed here in quite a while. I should note that Open MPI's definition of MPI_ACCUMULATE agrees with what is in MPI-3.1. I wanted to check to ensure that we didn't accidentally have a bug in MPI-3.1 that somehow worked in Open MPI with a variety of compilers for years, but was technically incorrect.
On Jun 6, 2018, at 11:37 AM, Jeff Hammond <[email protected]> wrote:
This works with other compilers as well...
$ for fc in ifort gfortran-8 pgfortran ; do ${fc} -c f08-intent-async.f90 && echo SUCCESS with $fc || echo FAILURE with $fc ; done SUCCESS with ifort SUCCESS with gfortran-8 SUCCESS with pgfortran
$ cat f08-intent-async.f90 Subroutine csub (x) real,intent(inout),asynchronous :: x end Subroutine csub
On Wed, Jun 6, 2018 at 8:29 AM, Bill Long <[email protected]> wrote:
On Jun 6, 2018, at 10:08 AM, Jeff Squyres (jsquyres) <[email protected]> wrote:
Fortran gurus --
We just got a problem report in Open MPI (https://www.mail-archive.com/[email protected]/msg32381.html) for a Fortran compile failure:
----- OMPI_FORTRAN_IGNORE_TKR_TYPE, INTENT(IN), ASYNCHRONOUS :: origin_addr ^ "../../../../../openmpi-master-201806060243-64a5baa/ompi/mpi/fortran/use-mpi-f08/accumulate_f08.F90", Line = 16, Column = 46: ERROR: Attributes ASYNCHRONOUS and INTENT must not appear in the same attribute list. -----
Is that Fortran compiler correct? I.e., does Fortran forbid the use of INTENT and ASYNCHRONOUS in the same attribute list?
I don’t see a restriction like that, at least in F2018. I tried this:
with maximum diagnostics and got no messages with the Cray compiler which is quite good at testing conformance.
Or is this a compiler bug?
It would appear to be the case. It might be the case that the usage in the routine is incompatible with INTENT(IN), but that message should be differently worded. Of course, OMPI_FORTRAN_IGNORE_TKR_TYPE is certainly not a valid type declaration. I assume they intend TYPE(*).
Cheers, Bill
-- Jeff Squyres [email protected]
_______________________________________________ mpiwg-fortran mailing list [email protected] https://lists.mpi-forum.org/mailman/listinfo/mpiwg-fortran
Bill Long [email protected] Principal Engineer, Fortran Technical Support & voice: 651-605-9024 Bioinformatics Software Development fax: 651-605-9143 Cray Inc./ 2131 Lindau Lane/ Suite 1000/ Bloomington, MN 55425
-- Jeff Hammond [email protected] http://jeffhammond.github.io/ _______________________________________________ mpiwg-fortran mailing list [email protected] https://lists.mpi-forum.org/mailman/listinfo/mpiwg-fortran
participants (1)
