Re: [mpi3-coll] Non-blocking Collectives Proposal Draft
Dear Torsten, Thank you. The pt2pt progress comment below was taken into account when you removed the nonblocking collective progress description. As for the example, if it is legal, we should probably count the blocking operations as well when we decide how many simultaneous ops are to be supported. Why "if" above: I'm not sure what a delayed nonblocking barrier would mean for process 1. Won't one process possibly block somewhere? Can you explain this please? The format matter is complicated. I think it is worth discussing at the Forum as we're likely to have more and more proposals approaching the final stage, when editing them in PDF format will become an issue. Best regards. Alexander -----Original Message----- From: [email protected] [mailto:[email protected]] On Behalf Of Torsten Hoefler Sent: Thursday, October 16, 2008 10:46 PM To: MPI-3 Collective Subgroup Discussions Subject: Re: [mpi3-coll] Non-blocking Collectives Proposal Draft Hello Alexander,
Generally, some sentences start with lower case letters that should be capitalized. yes, I fixed some but will re-read it later this week.
Page 3, top. We probably should not explain here how to ensure progress for nonblocking ops. This matter should be covered by the general progress description elsewhere. I agree, I deleted it (it's already in the nonblocking point-to-point chapter).
Page 3, lower half. Look how progress is defined in this list by referring to the pt2pt progress rules. what do you mean with that? I would just reference the current MPI definition - NBCs seem to fit this model nicely.
Ibid. There are already 3 classes of requests: pt2pt, generalized, and file I/O ones. yes
Page 3, bottom. How many nonblocking ops can overlap with a blocking one? I.e., can one have the following situation:
Process 0 Process 1
MPI_Ibarrier(req) MPI_Ibarrier(req) MPI_Wait(req) MPI Bcast MPI_Bcast MPI_Wait(req) yes, this is a legal code and should work. Any objections?
Page 5, bottom. 32767 simultaneous ops to support is a tall order. I'd say, 1 (one) would be a good lower limit, thus allowing no overlap. Or even 0 (zero), meaning no nonblocking collective support at all. The rest of this passage would probably be better reformulated as an advice to implementors. yes it is - I'm very indicisive. We have to discuss this at the Forum in Chicago.
In the margin: editing a PDF requires creativity (exemplified by the earlier comments) or a pretty expensive Acrobat. Maybe we can find some other way of distributing and commenting on our drafts? oh yes, I fully agree. But the final document should be in MPI style, so I thought I should start with LaTeX. Do you have any suggestions? Wiki seems suboptimal because we would have to re-format everything (which might be not too bad). LaTeX source in svn would be the best, but does everybody have LaTeX? I'm open for any suggestion!
For now, I uploaded the changed version to the wikipage (to avoid attachments on the mailinglist): https://svn.mpi-forum.org/trac/mpi-forum-web/wiki/NBColl Thanks for the comments! Best, Torsten -- bash$ :(){ :|:&};: --------------------- http://www.unixer.de/ ----- Torsten Hoefler | Postdoctoral Researcher Open Systems Lab | Indiana University 150 S. Woodlawn Ave. | Bloomington, IN, 474045, USA Lindley Hall Room 135 | +01 (812) 855-3608 _______________________________________________ mpi3-coll mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-coll --------------------------------------------------------------------- Intel GmbH Dornacher Strasse 1 85622 Feldkirchen/Muenchen Germany Sitz der Gesellschaft: Feldkirchen bei Muenchen Geschaeftsfuehrer: Douglas Lusk, Peter Gleissner, Hannes Schwaderer Registergericht: Muenchen HRB 47456 Ust.-IdNr. VAT Registration No.: DE129385895 Citibank Frankfurt (BLZ 502 109 00) 600119052 This e-mail and any attachments may contain confidential material for the sole use of the intended recipient(s). Any review or distribution by others is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies.
participants (1)
Supalov, Alexander
