Re: [mpi3-coll] Non-blocking Collectives Proposal Draft
16 Oct
16 Oct
'08
3:56 p.m.
On Wed, Oct 15, 2008 at 04:02:41PM +0200, Christian Siebert wrote:
> @Torsten:
> Thanks a lot for this first draft! I tried to make some useful comments
> and attached the results to this mail (sorry, I can't comment PDFs so I
> did it the "old inconvenient way").
oh yeah - we should not send too bi attachments to the list (your mail
was 2.3 MiB). I fixed all remarks in the scans. See attachment at:
https://svn.mpi-forum.org/trac/mpi-forum-web/wiki/NBColl
> @Working Group (something to discuss):
> 1) The MPI-2.1 document has 127 occurrences of "nonblocking" and only 8
> occurrences of "non-blocking". What would be the correct term? Should we
> try to be more consistent?
no comment ;) - see ticket #44
> 2) Clarification of MPI_Request_free() for requests from non-blocking
> collective operations.
what do you mean?
> 3) Better definition/description for "matching" (there is nothing like
> "at the same time" -> logical order?).
yes, do you have a suggestion? I replaced it with simultaneously for now
- which is suboptimal too.
> 4) Define "levels of progression"? To be queried (e.g., for "Synchronous
> Progress" MPI_Tests are needed for performance, but for "Asynchronous
> Progress" they would only add unnecessary overhead)? UP >= AP >= SP?
yes, I actually erased those definitions because they don't belong in a
standard (imho).
> 5) "Unexpected Progress" => "buffered" collectives?
this is also gone - this is an implementation detail, not an interface
issue.
> 6) NBC gives several possible ways for optimizations. With this "General
> advice to implementers" we stick to only one, and might prevent others.
> Can we already fix a decision for optimization strategies at this stage?
> Should we fix it at all?
this is only an advice. Maybe you're right, but I don't think that it'll
be much better without the advice at all. Advices seem to be rather weak
anyway so I have no strong opinion on that.
> 7) Should there be a concrete code example in the proposal (e.g. an
> implementation of this double buffering example)?
maybe, doesn't sound too bad. Let's talk about this at the Forum
I just started to creat an agenda for Chicago and put hose items on
there (more will follow).
https://svn.mpi-forum.org/trac/mpi-forum-web/wiki/forum201008
> Hope this isn't too much for now.
never
Best,
Torsten
bash$ :(){ :|:&};: --------------------- http://www.unixer.de/ -----
Torsten Hoefler | Postdoctoral Researcher
Open Systems Lab | Indiana University
150 S. Woodlawn Ave. | Bloomington, IN, 474045, USA
Lindley Hall Room 135 | +01 (812) 855-3608
6490
Age (days ago)
6490
Last active (days ago)
0 comments
1 participants
participants (1)
Torsten Hoefler
