Re: [Mpi3-bwcompat] Notes from ATL Forum meeting
On Jan 26, 2010, at 9:38 AM, Jeff Squyres wrote:
On Jan 26, 2010, at 8:39 AM, Quincey Koziol wrote:
I think we need to pick a "preferred vector" through the name combinations for each version of the standard and use a feature-neutral suffix for the changed routines' names. Either a totally abstract sequential suffix like: (nothing)->2->3->4, or a standard version specific suffix: (nothing)->3->31->32->...->4->41->...
I think the single digits would be fine.
We have a precedent of keeping compatibility between minor MPI revs and only breaking compatibility if something is really broken. I.e., if we make MPI_Foo3 and then find out that it's broken, I think the gut reaction of the Forum would be to fix MPI_Foo3, not make MPI_Foo31.
I agree, I was just trying to make the sequences look [more] different. :-) The main difference is that the abstract sequence will never skip a value, whereas the version specific sequence could skip values (if a symbol was changed in version 3 of the standard, was the same in version 4 and changed again in version 5, etc.) Quincey
participants (1)
unknown@example.com
