Re: [Mpi-22] MPI-2.1 ambiguity?
What's about the C++ datatypes for complex ? MPI_COMPLEX and MPI_Double_Complex are already defined for Fortran datatypes. The complex Fortran datatypes within C++ have a special name in order to avoid a name collision. Hubert William Gropp wrote:
One piece of relevant text in MPI 2.0 is in section 4.12.6 (in MPI-2.0) says that "All predefined datatypes can be used in datatype constructors in any language." However, the example uses MPI_Type_f2c ton convert the Fortran handle to the C version before passing it into the MPI_Type_create_struct routine, so this text could be interpreted as allowing the use of those datatypes through the handle conversion mechanism without requiring them to be defined in each languages header file. Presumably the requirement is that they be predefined with the value that you'd get from the handle conversion function?
Bill
On Jul 16, 2008, at 8:18 AM, Hubert Ritzdorf wrote:
when I remember correctly, it was decided to provide the C MPI datatypes in Fortran since the Fortran datatypes are supported in C and C++.
Hubert
Jeff Squyres wrote:
I will file a proposal about this if there is a problem, but I wanted to ask the group before I did so. In the changelog for MPI-2.1:
2. Section 3.2.2 on page 27, Section 16.1.6 on page 453, and Annex A.1 on page 491. MPI_LONG_LONG_INT, MPI_LONG_LONG (as synonym), MPI_UNSIGNED_LONG_LONG, MPI_SIGNED_CHAR, and MPI_WCHAR are moved from optional to oï¬cial and they are therefore deï¬ned for all three language bindings.
Note that it says that these C datatype names must be in all three language bindings.
Are C MPI datatypes supposed to be available in Fortran? I looked in mpif.h for Open MPI, MPICH2, HP MPI, and Intel MPI, and I didn't see C MPI datatypes in there (e.g., MPI_INT and MPI_FLOAT).
So:
- is there language somewhere in MPI that says that C datatypes are not supposed to be in mpif.h? (and therefore the MPI-2.1 changelog is wrong)
or
- are all 4 of the above MPI's wrong for not including the C datatypes in mpif.h?
--Jeff Squyres Cisco Systems
_______________________________________________ mpi-22 mailing list mpi-22_at_[hidden] <mailto:mpi-22_at_[hidden]> http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-22
<smime.p7s><ATT00001.txt>
William Gropp Paul and Cynthia Saylor Professor of Computer Science University of Illinois Urbana-Champaign
_______________________________________________ mpi-22 mailing list mpi-22_at_[hidden] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-22
participants (1)
unknown@example.com
