Re: [Mpi-22] [Mpi-forum] MPI 2.2 proposal:resolving MPI_Request_free issues
I don't quite understand examples 1 and 2 (how would they cause segv's in the TCP stack). It is permissible to (pseudocode):
while (bytes_to_send > 0) { rc = write(fd, buffer, bytes_to_send); if (rc > 0) { buffer += rc; bytes_to_send -= rc; } else { ...error... } } free(buffer);
regardless of what the receiver does. I'm not a kernel guy; does updating TCP sequence numbers also interact with the payload buffer?
[erezh] it will never happen with your code above; but you are not using async zcopy. The pattern in windows is to use overlapped send (write) which is still active when the function returns, and is the most efficient way to send your buffer. I know it's possible with Linux but I don't' have the exact pattern.
So, how does this work for other users of zero copy? How do they know when the send buffer is truly free?
FWIW: I can see the RMA interconnect example much easier. You can imagine a scenario where a sender successfully sends and the receiver successfully receives, but the hardware ACK from the receiver gets lost. The receiver then sends an MPI message back to the sender, but the sender is still in the middle of a retransmit timeout (while waiting for the hardware ACK that was lost). In this case, the user app may free the buffer too soon, resulting in a segv (or some other lion, tiger, or bear) when the sending hardware tries to retransmit.
[erezh] Correct; this is the scenario I was describing with the RDMA write.
It would be interesting to see exactly what the error mode here is. Retransmitting corrupted data should be ok, since a correctly delivered message means that the retransmit must be dropped. I suppose that if the NIC speaks virtual addresses and the free actually results in a trap to the kernel that unmaps the pages, then the NIC could retransmit and find that there isn't a valid page table entry...
MPI_Request_free() is used in application programs. For example, it is the easiest (and portable) way to send a non-blocking acknowledge to a destination process.
[erezh] See Adam Moody proposal for MPI_REQUEST_IGNORE; I think it's safer than the current pattern
MPI_Isend (buf, 0, MPI_INT, dest, TAG_ACK, comm, lrequest) MPI_Request_free (lrequest)
Hrm. This example doesn't seem to trigger Erez's concern... That's a zero length buffer, right? Solution #5: Change the advice to users - "...the arrival of the reply informs the sender that the send has completed and the send buffer can be overwritten. If the buffer will ever be freed, the application should call MPI_Wait or MPI_Cancel instead of MPI_Request_free." If you have received your application level ack from the remote side, MPI_Cancel should give you the equivalent functionality of MPI_Request_free - allowing you to release the request without having to wait for local completion. I'm not entirely sure WHY you would want to do this, but... ;-) Keith
participants (1)
unknown@example.com
