Re: [Mpi-21] Review of MPI-2.1 combined document
Rolf -- This is *most* helpful. Thanks! On Mar 6, 2008, at 4:08 AM, Rolf Rabenseifner wrote:
Dear all MPI-2.1 reviewer,
I have produced an additional mpi-report-2.1draft-2008-03-06-blue.pdf on doc (via http://www.hlrs.de/mpi/mpi21/ )
There, all MPI-2.0 is blue. New text is still red. Content is the same as Feb. 23, 2008.
For all who have already printed: The red parts in MPI-2.1 Versions Feb 28 and blue March 06, 2008 are on (page/line): i, ii, iii, xiv/11, xv/7, (xvii is printed red without reason - it is unmodified 2.0), (some references are printed red without reason!) xviii, 4/38-46, 5/30-33, 5/46 - sorry, is not red, but new! 79/43-44, 82/47-48, 85/10-11, 93/43-44, 95/32-33, 98/3, 99/1-2 - sorry, is not red, but new! 99/15-16, (152/1-3 is printed red without reason - it is unmodified 1.1), 152/38-153/6 - is the MPI-1.2 correction MPI-2.0 Sect.3.2.7 that we discussed and modified at Jan.2008 meeting. 215/29-30, 217/28-29, 218/17-18, 219/20-21, 220/20-21, 248/2-3, 254/29-30, 255/39-40, 256/21-22, 258/28, 262/18-19, 465/30-31.
That's all!.
Important is also the removed text! You can find it at http://www.hlrs.de/mpi/mpi21/doc/removed_sources.tex
As reviewer, you should check, whether the removed text in your chapter must or should be really removed!
Best regards Rolf
On Wed, 5 Mar 2008 21:04:40 -0500 Jeff Squyres <jsquyres_at_[hidden]> wrote:
On Feb 23, 2008, at 4:19 PM, Rolf Rabenseifner wrote:
Dear reviewer: Please print your chapter with colors (!) and check all merging decisions. The colors will help to identify MPI 1.1-1.3 (black), MPI-2.0 (magenta) and new text that was necessary for the merge (red).
Is there a way to use different colors, perchance?
The language bindings chapter is all MPI-2 (magenta); it is nearly impossible to tell if there is any merge text in it (red).
-- Jeff Squyres Cisco Systems
_______________________________________________ mpi-21 mailing list mpi-21_at_[hidden] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-21
Dr. Rolf Rabenseifner . . . . . . . . . .. email rabenseifner_at_[hidden] High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner Nobelstr. 19, D-70550 Stuttgart, Germany . (Office: Allmandring 30) _______________________________________________ mpi-21 mailing list mpi-21_at_[hidden] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-21
participants (1)
unknown@example.com
