Re: [mpich-devel] [mpich-discuss] Use of Signed-off-by in MPICH
IBM uses the "signed off by" feature to enforce/track code reviews before any code gets contributed to ANL. The intent is that the commit author != the commit signer when the code goes out. Often a developer at ANL will also review the code before it gets integrated into the master branch (IBM developers don't have push authority) and sign the commit again. We use the text "Signed-off-by:xxxx <yyy@zzz>" simply because this is what is supported by the git tools. You can use commands like `git cherry-pick -s`, `git commit --amend -s`, and `git am -s` to ease the signing effort. Michael Blocksome Parallel Environment MPI Middleware Team Lead, TCEM POWER, x86, and Blue Gene HPC Messaging [email protected] From: Pavan Balaji <[email protected]> To: [email protected], Date: 01/04/2014 10:00 PM Subject: Re: [mpich-discuss] Use of Signed-off-by in MPICH Sent by: [email protected] Please use [email protected] for developer oriented discussion. We use signoff as a way to get a second confirmation on the correctness of the patch. In some cases, multiple confirmations. There’s also a "silent signoff” done by the jenkins testing before things are merged into mpich/master. — Pavan On Jan 4, 2014, at 7:55 PM, Jed Brown <[email protected]> wrote:
I'm confused by the current use of Signed-off-by tags in MPICH. Is this intended to be a developer's certificate of origin (DCO) following the model of the Linux kernel [1]? I can't tell if IBM is using it that way, where Michael Blocksome is the one authorized by IBM to assert on IBM's behalf that the work has clean IP and may be distributed under the MPICH license. But what does this mean?
commit 87b20136ac20a0fbcffd8e29edcc500fcebbfc22 Author: Pavan Balaji <[email protected]> AuthorDate: Wed Jan 1 19:33:36 2014 -0600 Commit: Pavan Balaji <[email protected]> CommitDate: Thu Jan 2 15:39:07 2014 -0600
Move default eager threshold setting to ch3.
We were setting the default eager threshold inside nemesis, instead of in ch3. This was causing other ch3 channels, notably sock, to get a garbage default value for the eager threshold.
Signed-off-by: Wesley Bland <[email protected]>
If this were a DCO, we would interpret it as meaning that Wesley is the one certifying the IP, but Pavan is the author.
Or is Signed-off-by being used where Reviewed-by would be more appropriate?
[1] https://www.kernel.org/doc/Documentation/SubmittingPatches _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Pavan Balaji http://www.mcs.anl.gov/~balaji _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Michael Blocksome
