Re: [mpich-devel] build broken on 'master': 'mpitypedefs.h' file not found
Rob Latham <[email protected]> writes:
On Sat, Jan 04, 2014 at 08:08:16PM -0600, Jed Brown wrote:
Rob, this commit does not build, at least not if you configure out of source.
Jenkins did not find a problem with this commit, so I'd like to understand what's different in your environment.
I configure out of source. In this case, $ mkdir build-clang $ cd build-clang $ ../configure --prefix=/home/jed/usr/mpich-clang --enable-shared --enable-error-checking=runtime --enable-error-messages=all --enable-timer-type=clock_gettime --with-python=python2 CC=clang CXX=clang++ F77=gfortran FC=gfortran [...] $ make
Yeah, in the standalone ROMIO case I do not include that mpich-specific header, and MPI_AINT_CAST_TO_VOID_PTR becomes nothing thanks to macro magic.
But where is MPI_AINT_CAST_TO_VOID_PTR used (on BG/Q) and why can't that code use ADIOI_AINT_CAST_TO_VOID_PTR?
participants (1)
Jed Brown
