Re: [mpich-devel] binding a new MPI type with fortran
Thanks for reply. Yes, unfortunately we need fortran interfaces because most of the applications that we use for testing are written in fortran. Will it be enough if I just add a conversion rule to %parmc2f in ./src/binding/f90/buildface? Something like: 'MPI_Pattern' => 'INTEGER(KIND=MPI_ADDRESS_KIND)', 'MPI_Pattern*' => 'INTEGER(KIND=MPI_ADDRESS_KIND)', And for f77 it will be: 'MPI_Pattern' => 'MPI_Fint *' 'MPI_Pattern*' => 'MPI_Fint *'
Also, as a side note, please use "MPIX_" for nonstandard MPI extensions. It makes nonstandard interfaces very obvious to users and will help prevent potential issues with standardization in the future.
Duly noted. Tatiana 2013/3/28 Dave Goodell <[email protected]>:
On Mar 28, 2013, at 2:16 PM CDT, Tatiana V. Martsinkevich <[email protected]> wrote:
We are implementing some fault tolerance related functionality in MPICH-3.0.2. We define a new MPI type in ~/mpich-3.0.2/src/include/mpi.h.in as:
typedef void* MPI_Pattern;
then in the same file we define:
int MPI_Pattern_declare(char* name, MPI_Pattern* handler);
However, when I run autogen.sh and fortran binding script executes it gives out:
Pattern_declare: No parm type for MPI_Pattern* (MPI_Pattern*) Use of uninitialized value $fparm in pattern match (m//) at ./buildiface line 1289, <FD> line 1710.
Do you want Fortran interfaces at this time or would you be just as happy to have C-only bindings right now? The former will require hacking on one or more of the "buildiface" scripts in the "src/binding/LANGUAGE" directories. The latter can be accomplished by moving your prototypes and types near the end of mpi.h.in, near the prototypes for "MPIX_Mutex_unlock" and "PMPIX_Mutex_unlock".
-Dave
participants (1)
