Re: [mpich-devel] binding a new MPI type with fortran
On Mar 28, 2013, at 2:16 PM CDT, Tatiana V. Martsinkevich <[email protected]> wrote:
We are implementing some fault tolerance related functionality in MPICH-3.0.2. We define a new MPI type in ~/mpich-3.0.2/src/include/mpi.h.in as:
typedef void* MPI_Pattern;
then in the same file we define:
int MPI_Pattern_declare(char* name, MPI_Pattern* handler);
However, when I run autogen.sh and fortran binding script executes it gives out:
Pattern_declare: No parm type for MPI_Pattern* (MPI_Pattern*) Use of uninitialized value $fparm in pattern match (m//) at ./buildiface line 1289, <FD> line 1710.
Do you want Fortran interfaces at this time or would you be just as happy to have C-only bindings right now? The former will require hacking on one or more of the "buildiface" scripts in the "src/binding/LANGUAGE" directories. The latter can be accomplished by moving your prototypes and types near the end of mpi.h.in, near the prototypes for "MPIX_Mutex_unlock" and "PMPIX_Mutex_unlock". Also, as a side note, please use "MPIX_" for nonstandard MPI extensions. It makes nonstandard interfaces very obvious to users and will help prevent potential issues with standardization in the future. -Dave
participants (1)
Dave Goodell
