[LCRC Accounts] Yearly Allocation Request from genomic_distribution
Hello, A yearly allocation for the LCRC cluster has been requested with the following updated information: Submitter/PI: Will Trimble Project Name: genomic_distribution Division: IGSB Project title: Distribution of kmers in metagenomic data Associated funding: Other Systems: Science: Next-generation sequencing technologies are currently producing data from nucleotide sequences extracted from the environment at an unprecedented rate. It is possible that probabilistic models of the character of DNA sequences can be used to substantially reduce the computational burden of sequence similarity searching and de novo assembly. This project aims to do exploratory work in characterizing the probabilistic properties of real and artificial metagenomic data and their usefulness in handling the same. Project description: Initial exploration of sequence-redundancy has shown promise for rapidly predicting the genome size in high-throughput genome sequencing projects and for determining the likely assembleability of metagenomic datasets. Error-correction in shotgun data sequencing data, a step that could improve the quality of assemblies, requires a memory- and compute- intensive traversal of the data. The desired all-against-all comparisons for error correction, assembly, and probing for redundancy at present require large memory (32Gb+) machines for input datasets in excess of 1 Gbase. Project URL: Current FY Hours Used: undetermined amount New FY Requested allocation: 32000 Q1: 8000 Q2: 8000 Q3: 8000 Q4: 8000 Justification: Thank You, The LCRC Accounts System
participants (1)
accounts@lcrc.anl.gov
