Re: [AG-TECH] Setting web proxy for AG2 ?
You should only need to set the web proxy for requesting certificates, which can be done directly in the certificate request tool. If you're having a particular problem getting started, you can submit a bug report (from the Help menu) which will include relevant portions of the AG logfiles so we can understand the problem. Tom On 3/30/06 8:12 AM, Thierry Delaitre wrote:
I've installed AG2 under windows & MACOSX and was wondering how to set the web proxy for connecting to a venue server ? Our university does not have a transparent web proxy and we need to specify the url of the web proxy for applications otherwise applications like AG2 cannot contact web servers directly.
I tried to set the http_proxy env var under Windows but to no avail. Any help would be grately appreciated.
---------------------------------------- Dr Thierry DELAITRE Systems and Services Manager, CSCS University of Westminster 115 New Cavendish Street, London W1W 6UW
Tel: 020 7911 5000 ext: 3586 Fax: 020 7911 5089 Mobile short dial code 1788
http://www.cscs.wmin.ac.uk/~delaitt ----------------------------------------
This e-mail and its attachments are intended for the above named only and may be confidential. If they have come to you in error you must not copy or show them to anyone, nor should you take any action based on them, other than to notify the error by replying to the sender.
participants (1)
Thomas D. Uram
