Re: [AG-TECH] vic and rat encryption
I would recommend using as much of existing solutions as possible: - Restrict access to the venue by identity using the mechanism built into the AG software. This will prevent unwanted AG users from entering the venue. - Enable encryption on the venue, so AG users get the key and it is used by their media tools. The encryption key can be set in Venue Management so it is DES instead of Rijndael, simply by leaving off the 'Rijndael/' prefix. This will prevent AG users from having to enter the key into vic and rat manually. You can then hand the encryption key to insors users via email or somesuch so they can apply it manually. Tom Uram On 3/29/06 10:28 AM, Jeremy Mann wrote:
Derek Piper said:
You may be better off using Rjindael encryption, which is normally used on AG Venues when setting the 'encryption' option in the venue server config. A Rjindael key is passed to VIC and RAT as 'Rjindael/passphrase' where passphrase should be something random and unguessable, and distributed to those needing the key to enter manually. There's a program for Debian called 'pwgen' that I've used to generate a passphrase before. For manually entering the key, you would probably just disable the venue encryption and manually key it in. For a DES key, just use a passphrase that doesn't start with a string 'Rjindael/'. Of course you can also use certificates to secure a venue too, so not just anyone can enter and obtain the encryption key.
The certificate security can not be done because half the participants are inSORS nodes. I'll try out this pwgen and test it out. Thanks!
participants (1)
Thomas D. Uram
