Build failed in Jenkins: triton #212
See <https://jenkins-ci.mcs.anl.gov/job/triton/212/> ------------------------------------------ Started by an SCM change [EnvInject] - Loading node environment variables. Building remotely on thrash.mcs.anl.gov in workspace <https://jenkins-ci.mcs.anl.gov/job/triton/ws/> Deleting project workspace... done Checkout:triton / <https://jenkins-ci.mcs.anl.gov/job/triton/ws/> - hudson.remoting.Channel@584202ec:thrash.mcs.anl.gov Using strategy: Default Last Built Revision: Revision 9c9d7b4da56fbac8bd3b1258198026ec6d0d91e2 (origin/master) Cloning the remote Git repository Cloning repository [email protected]:triton git --version git version 1.7.9.5 Fetching upstream changes from origin Commencing build of Revision 9c9d7b4da56fbac8bd3b1258198026ec6d0d91e2 (origin/master) Checking out Revision 9c9d7b4da56fbac8bd3b1258198026ec6d0d91e2 (origin/master) [triton] $ /bin/sh -xe /tmp/hudson5465923046073426187.sh + code/scripts/jenkins/build-jenkins.sh code misc sim ======================================================================= = Build 212 2015-03-26_00-03-23 = on thrash.mcs.anl.gov [mcs thrash.mcs.anl.gov] ======================================================================= Triton source in <https://jenkins-ci.mcs.anl.gov/job/triton/ws/> Building in <https://jenkins-ci.mcs.anl.gov/job/triton/ws/build> ==================================================================== ===== INFO ========================================================= ==================================================================== Triton Source tree : <https://jenkins-ci.mcs.anl.gov/job/triton/ws/> Workspace : <https://jenkins-ci.mcs.anl.gov/job/triton/ws/build> Cachedir : /tmp/triton-cache ======================================================================= ==== STEP 1: Fetch build dependencies ================================= ======================================================================= openpa.tar.gz: (found in cache) OK (3ad998bb26ac84ee7de262db94dd7656) bmi.tar.gz: (found in cache) OK (82a8efe604a80c80d18dab76dfc13c38) boost.tar.bz2: (found in cache) OK (d6eef4b4cacb2183f2bf265a5a03a354) c-utils.tar.gz: (found in cache) OK (2466f8d782b534a179d75cabab1ebd01) confuse.tar.gz: (found in cache) OK (45932fdeeccbb9ef4228f1c1a25e9c8f) libev.tar.gz: (found in cache) OK (3a73f247e790e2590c01f3492136ed31) aesop.tar.gz: (found in cache) OK (b8bf772e5403bdc884622b69affb1dcf) mercury: (fetching) Cloning into '/tmp/triton-cache/mercury'... Submodule 'Testing/driver/kwsys' (git://public.kitware.com/KWSys.git) registered for path 'Testing/driver/kwsys' Submodule 'src/mchecksum' (git://git.mcs.anl.gov/radix/mchecksum) registered for path 'src/mchecksum' Cloning into 'Testing/driver/kwsys'... Submodule path 'Testing/driver/kwsys': checked out '88c8cc7fd5a086020408cdce6c20477d2fba34be' Cloning into 'src/mchecksum'... Submodule path 'src/mchecksum': checked out '2e8aec552da8b2b5203803cd2dd09a0a50c7a826' error: pathspec 'next' did not match any file(s) known to git. Error: failed to checkout "next" Build step 'Execute shell' marked build as failure TAP Reports Processing: START Looking for TAP results report in workspace using pattern: build/tritonbuild/tests/results.tap Did not find any matching files.
participants (1)
jenkins-ci@mcs.anl.gov
