[Gs-commits] Grayskull Repository branch, master, updated. git-migration-317-g4236223
A ref change was pushed to the repository containing the project "Grayskull Repository". The branch, master has been updated via 42362233e2e4b5394fa45232d6293dd94bbc82b7 (commit) from 6c5845c03ea5522270cbd1851f3fbbb6fe5c6f7c (commit) Those revisions listed above that are new to this repository have not appeared on any other notification email; so we list those revisions in full, below. - Log ----------------------------------------------------------------- commit 42362233e2e4b5394fa45232d6293dd94bbc82b7 Author: Justin Wozniak <[email protected]> Date: Mon Dec 21 15:43:47 2009 -0600 Draft of component diagram from 12/21/2009. ----------------------------------------------------------------------- Summary of changes: wiki/proto-architecture.dot | 67 +++++++++++++++++++++++++++++++++++++++++++ 1 files changed, 67 insertions(+), 0 deletions(-) create mode 100644 wiki/proto-architecture.dot Diff of changes: diff --git a/wiki/proto-architecture.dot b/wiki/proto-architecture.dot new file mode 100644 index 0000000..5c574c4 --- /dev/null +++ b/wiki/proto-architecture.dot @@ -0,0 +1,67 @@ +digraph prototype { + + overlap = false; + splines = true; + + fs [label="FS"]; + kv [label="KV"]; + oslc [label="OSL Client"]; + + osl1 [label="OSL"]; + osl2 [label="OSL",color=transparent,fontcolor=transparent]; + placement [label="Placement"]; + rebuild [label="Rebuild"]; + gossip [label="Gossip"]; + cosd1 [label="COSD"]; + cosd2 [label="COSD"]; + dtc1 [label="DTC"]; + dtc2 [label="DTC"]; + + dummy1 [label="dummy",color=transparent,fontcolor=transparent]; + + fs -> oslc; + kv -> oslc; + + oslc -> osl1; + + subgraph cluster_node_0 { + + label = "node 0"; + color = black; + + rosd1 [label="ROSD"]; + + osl1 -> rosd1; + gossip -> rosd1; + rosd1 -> gossip; + + rosd1 -> dtc1; + rosd1 -> cosd1; + + dtc1 -> cosd1 [color=transparent]; + + placement -> rosd1; + + { rank = same; gossip; placement; } + gossip -> placement; + + subgraph { rankdir = RL; gossip -> rebuild; } + } + + dtc2 -> dtc1; + dtc1 -> dtc2; + + subgraph cluster_node_1 { + + label = "node 1"; + color = black; + + rosd2 [label="ROSD"]; + + rosd2 -> dtc2 [color=transparent]; + dtc2 -> cosd2; + } + + { rank = same; fs; kv; dummy1; } + { rank = same; dtc1; dtc2; } +} hooks/post-receive -- Grayskull Repository
participants (1)
noreply@mcs.anl.gov
