[Gs-commits] r603 - trunk/code/src/gsl
Author: carns Date: 2009-06-29 14:29:26 -0500 (Mon, 29 Jun 2009) New Revision: 603 Modified: trunk/code/src/gsl/configure.in Log: remove deprecated references to gscc from configure.in Modified: trunk/code/src/gsl/configure.in =================================================================== --- trunk/code/src/gsl/configure.in 2009-06-26 22:05:32 UTC (rev 602) +++ trunk/code/src/gsl/configure.in 2009-06-29 19:29:26 UTC (rev 603) @@ -4,7 +4,7 @@ dnl Process this file with autoconf to produce a configure script. dnl You may need to use autoheader as well if changing any DEFINEs -AC_INIT(parser/gscc.in) +AC_INIT(include/gs.h) AC_CONFIG_HEADER(gs-config.h) AC_CONFIG_AUX_DIR(maint/config) @@ -91,6 +91,5 @@ parser/module.mk resources/scheduling/module.mk resources/scheduling/test/module.mk -examples/module.mk -parser/gscc) +examples/module.mk)
participants (1)
carns@mcs.anl.gov
