Build failed in Jenkins: triton #201
See <https://jenkins-ci.mcs.anl.gov/job/triton/201/> ------------------------------------------ Started by an SCM change [EnvInject] - Loading node environment variables. Building remotely on trounce.mcs.anl.gov in workspace <https://jenkins-ci.mcs.anl.gov/job/triton/ws/> Deleting project workspace... done Checkout:triton / <https://jenkins-ci.mcs.anl.gov/job/triton/ws/> - hudson.remoting.Channel@2b65a035:trounce.mcs.anl.gov Using strategy: Default Last Built Revision: Revision 9c9d7b4da56fbac8bd3b1258198026ec6d0d91e2 (origin/master) Cloning the remote Git repository Cloning repository [email protected]:triton git --version git version 1.7.9.5 Fetching upstream changes from origin Commencing build of Revision 9c9d7b4da56fbac8bd3b1258198026ec6d0d91e2 (origin/master) Checking out Revision 9c9d7b4da56fbac8bd3b1258198026ec6d0d91e2 (origin/master) [triton] $ /bin/sh -xe /tmp/hudson5010303867522183592.sh + code/scripts/jenkins/build-jenkins.sh code misc sim ======================================================================= = Build 201 2015-03-15_00-02-05 = on trounce.mcs.anl.gov [mcs trounce.mcs.anl.gov] ======================================================================= Triton source in <https://jenkins-ci.mcs.anl.gov/job/triton/ws/> Building in <https://jenkins-ci.mcs.anl.gov/job/triton/ws/build> ==================================================================== ===== INFO ========================================================= ==================================================================== Triton Source tree : <https://jenkins-ci.mcs.anl.gov/job/triton/ws/> Workspace : <https://jenkins-ci.mcs.anl.gov/job/triton/ws/build> Cachedir : /tmp/triton-cache ======================================================================= ==== STEP 1: Fetch build dependencies ================================= ======================================================================= openpa.tar.gz: (found in cache) OK (3ad998bb26ac84ee7de262db94dd7656) bmi.tar.gz: (found in cache) OK (82a8efe604a80c80d18dab76dfc13c38) boost.tar.bz2: (found in cache) OK (d6eef4b4cacb2183f2bf265a5a03a354) c-utils.tar.gz: (cached but invalid. Removing) (fetching) Build step 'Execute shell' marked build as failure TAP Reports Processing: START Looking for TAP results report in workspace using pattern: build/tritonbuild/tests/results.tap Did not find any matching files.
participants (1)
jenkins-ci@mcs.anl.gov
