[Gs-commits] Triton Repository branch, master, updated. b8e3a58ae87d48de71cf52c07016931e38337e44
This is an automated email from the git hooks/post-receive script. It was generated because a ref change was pushed to the repository containing the project "Triton Repository". The branch, master has been updated via b8e3a58ae87d48de71cf52c07016931e38337e44 (commit) from ea05c744488a6a7d2e907bcee9531cfe91a95959 (commit) Those revisions listed above that are new to this repository have not appeared on any other notification email; so we list those revisions in full, below. - Log ----------------------------------------------------------------- commit b8e3a58ae87d48de71cf52c07016931e38337e44 Author: Samuel Lang <[email protected]> Date: Fri Mar 5 15:35:44 2010 -0600 remove autom4te.cache dir. Not needed by configure. ----------------------------------------------------------------------- Summary of changes: code/autom4te.cache/output.0 | 7798 ------------------------------------------ code/autom4te.cache/output.1 | 7798 ------------------------------------------ code/autom4te.cache/requests | 95 - code/autom4te.cache/traces.0 | 635 ---- code/autom4te.cache/traces.1 | 563 --- 5 files changed, 0 insertions(+), 16889 deletions(-) delete mode 100644 code/autom4te.cache/output.0 delete mode 100644 code/autom4te.cache/output.1 delete mode 100644 code/autom4te.cache/requests delete mode 100644 code/autom4te.cache/traces.0 delete mode 100644 code/autom4te.cache/traces.1 Diff of changes: diff --git a/code/autom4te.cache/output.0 b/code/autom4te.cache/output.0 deleted file mode 100644 index 1845017..0000000 --- a/code/autom4te.cache/output.0 +++ /dev/null @@ -1,7798 +0,0 @@ -@%:@! /bin/sh -@%:@ Guess values for system-dependent variables and create Makefiles. -@%:@ Generated by GNU Autoconf 2.61 for triton 0.1.1. -@%:@ -@%:@ Report bugs to <[email protected]>. -@%:@ -@%:@ Copyright (C) 1992, 1993, 1994, 1995, 1996, 1998, 1999, 2000, 2001, -@%:@ 2002, 2003, 2004, 2005, 2006 Free Software Foundation, Inc. -@%:@ This configure script is free software; the Free Software Foundation -@%:@ gives unlimited permission to copy, distribute and modify it. -## --------------------- ## -## M4sh Initialization. ## -## --------------------- ## - -# Be more Bourne compatible -DUALCASE=1; export DUALCASE # for MKS sh -if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then - emulate sh - NULLCMD=: - # Zsh 3.x and 4.x performs word splitting on ${1+"$@"}, which - # is contrary to our usage. Disable this feature. - alias -g '${1+"$@"}'='"$@"' - setopt NO_GLOB_SUBST -else - case `(set -o) 2>/dev/null` in - *posix*) set -o posix ;; -esac - -fi - - - - -# PATH needs CR -# Avoid depending upon Character Ranges. -as_cr_letters='abcdefghijklmnopqrstuvwxyz' -as_cr_LETTERS='ABCDEFGHIJKLMNOPQRSTUVWXYZ' -as_cr_Letters=$as_cr_letters$as_cr_LETTERS -as_cr_digits='0123456789' -as_cr_alnum=$as_cr_Letters$as_cr_digits - -# The user is always right. -if test "${PATH_SEPARATOR+set}" != set; then - echo "#! /bin/sh" >conf$$.sh - echo "exit 0" >>conf$$.sh - chmod +x conf$$.sh - if (PATH="/nonexistent;."; conf$$.sh) >/dev/null 2>&1; then - PATH_SEPARATOR=';' - else - PATH_SEPARATOR=: - fi - rm -f conf$$.sh -fi - -# Support unset when possible. -if ( (MAIL=60; unset MAIL) || exit) >/dev/null 2>&1; then - as_unset=unset -else - as_unset=false -fi - - -# IFS -# We need space, tab and new line, in precisely that order. Quoting is -# there to prevent editors from complaining about space-tab. -# (If _AS_PATH_WALK were called with IFS unset, it would disable word -# splitting by setting IFS to empty value.) -as_nl=' -' -IFS=" "" $as_nl" - -# Find who we are. Look in the path if we contain no directory separator. -case $0 in - *[\\/]* ) as_myself=$0 ;; - *) as_save_IFS=$IFS; IFS=$PATH_SEPARATOR -for as_dir in $PATH -do - IFS=$as_save_IFS - test -z "$as_dir" && as_dir=. - test -r "$as_dir/$0" && as_myself=$as_dir/$0 && break -done -IFS=$as_save_IFS - - ;; -esac -# We did not find ourselves, most probably we were run as `sh COMMAND' -# in which case we are not to be found in the path. -if test "x$as_myself" = x; then - as_myself=$0 -fi -if test ! -f "$as_myself"; then - echo "$as_myself: error: cannot find myself; rerun with an absolute file name" >&2 - { (exit 1); exit 1; } -fi - -# Work around bugs in pre-3.0 UWIN ksh. -for as_var in ENV MAIL MAILPATH -do ($as_unset $as_var) >/dev/null 2>&1 && $as_unset $as_var -done -PS1='$ ' -PS2='> ' -PS4='+ ' - -# NLS nuisances. -for as_var in \ - LANG LANGUAGE LC_ADDRESS LC_ALL LC_COLLATE LC_CTYPE LC_IDENTIFICATION \ - LC_MEASUREMENT LC_MESSAGES LC_MONETARY LC_NAME LC_NUMERIC LC_PAPER \ - LC_TELEPHONE LC_TIME -do - if (set +x; test -z "`(eval $as_var=C; export $as_var) 2>&1`"); then - eval $as_var=C; export $as_var - else - ($as_unset $as_var) >/dev/null 2>&1 && $as_unset $as_var - fi -done - -# Required to use basename. -if expr a : '\(a\)' >/dev/null 2>&1 && - test "X`expr 00001 : '.*\(...\)'`" = X001; then - as_expr=expr -else - as_expr=false -fi - -if (basename -- /) >/dev/null 2>&1 && test "X`basename -- / 2>&1`" = "X/"; then - as_basename=basename -else - as_basename=false -fi - - -# Name of the executable. -as_me=`$as_basename -- "$0" || -$as_expr X/"$0" : '.*/\([^/][^/]*\)/*$' \| \ - X"$0" : 'X\(//\)$' \| \ - X"$0" : 'X\(/\)' \| . 2>/dev/null || -echo X/"$0" | - sed '/^.*\/\([^/][^/]*\)\/*$/{ - s//\1/ - q - } - /^X\/\(\/\/\)$/{ - s//\1/ - q - } - /^X\/\(\/\).*/{ - s//\1/ - q - } - s/.*/./; q'` - -# CDPATH. -$as_unset CDPATH - - -if test "x$CONFIG_SHELL" = x; then - if (eval ":") 2>/dev/null; then - as_have_required=yes -else - as_have_required=no -fi - - if test $as_have_required = yes && (eval ": -(as_func_return () { - (exit \$1) -} -as_func_success () { - as_func_return 0 -} -as_func_failure () { - as_func_return 1 -} -as_func_ret_success () { - return 0 -} -as_func_ret_failure () { - return 1 -} - -exitcode=0 -if as_func_success; then - : -else - exitcode=1 - echo as_func_success failed. -fi - -if as_func_failure; then - exitcode=1 - echo as_func_failure succeeded. -fi - -if as_func_ret_success; then - : -else - exitcode=1 - echo as_func_ret_success failed. -fi - -if as_func_ret_failure; then - exitcode=1 - echo as_func_ret_failure succeeded. -fi - -if ( set x; as_func_ret_success y && test x = \"\$1\" ); then - : -else - exitcode=1 - echo positional parameters were not saved. -fi - -test \$exitcode = 0) || { (exit 1); exit 1; } - -( - as_lineno_1=\$LINENO - as_lineno_2=\$LINENO - test \"x\$as_lineno_1\" != \"x\$as_lineno_2\" && - test \"x\`expr \$as_lineno_1 + 1\`\" = \"x\$as_lineno_2\") || { (exit 1); exit 1; } -") 2> /dev/null; then - : -else - as_candidate_shells= - as_save_IFS=$IFS; IFS=$PATH_SEPARATOR -for as_dir in /bin$PATH_SEPARATOR/usr/bin$PATH_SEPARATOR$PATH -do - IFS=$as_save_IFS - test -z "$as_dir" && as_dir=. - case $as_dir in - /*) - for as_base in sh bash ksh sh5; do - as_candidate_shells="$as_candidate_shells $as_dir/$as_base" - done;; - esac -done -IFS=$as_save_IFS - - - for as_shell in $as_candidate_shells $SHELL; do - # Try only shells that exist, to save several forks. - if { test -f "$as_shell" || test -f "$as_shell.exe"; } && - { ("$as_shell") 2> /dev/null <<\_ASEOF -if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then - emulate sh - NULLCMD=: - # Zsh 3.x and 4.x performs word splitting on ${1+"$@"}, which - # is contrary to our usage. Disable this feature. - alias -g '${1+"$@"}'='"$@"' - setopt NO_GLOB_SUBST -else - case `(set -o) 2>/dev/null` in - *posix*) set -o posix ;; -esac - -fi - - -: -_ASEOF -}; then - CONFIG_SHELL=$as_shell - as_have_required=yes - if { "$as_shell" 2> /dev/null <<\_ASEOF -if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then - emulate sh - NULLCMD=: - # Zsh 3.x and 4.x performs word splitting on ${1+"$@"}, which - # is contrary to our usage. Disable this feature. - alias -g '${1+"$@"}'='"$@"' - setopt NO_GLOB_SUBST -else - case `(set -o) 2>/dev/null` in - *posix*) set -o posix ;; -esac - -fi - - -: -(as_func_return () { - (exit $1) -} -as_func_success () { - as_func_return 0 -} -as_func_failure () { - as_func_return 1 -} -as_func_ret_success () { - return 0 -} -as_func_ret_failure () { - return 1 -} - -exitcode=0 -if as_func_success; then - : -else - exitcode=1 - echo as_func_success failed. -fi - -if as_func_failure; then - exitcode=1 - echo as_func_failure succeeded. -fi - -if as_func_ret_success; then - : -else - exitcode=1 - echo as_func_ret_success failed. -fi - -if as_func_ret_failure; then - exitcode=1 - echo as_func_ret_failure succeeded. -fi - -if ( set x; as_func_ret_success y && test x = "$1" ); then - : -else - exitcode=1 - echo positional parameters were not saved. -fi - -test $exitcode = 0) || { (exit 1); exit 1; } - -( - as_lineno_1=$LINENO - as_lineno_2=$LINENO - test "x$as_lineno_1" != "x$as_lineno_2" && - test "x`expr $as_lineno_1 + 1`" = "x$as_lineno_2") || { (exit 1); exit 1; } - -_ASEOF -}; then - break -fi - -fi - - done - - if test "x$CONFIG_SHELL" != x; then - for as_var in BASH_ENV ENV - do ($as_unset $as_var) >/dev/null 2>&1 && $as_unset $as_var - done - export CONFIG_SHELL - exec "$CONFIG_SHELL" "$as_myself" ${1+"$@"} -fi - - - if test $as_have_required = no; then - echo This script requires a shell more modern than all the - echo shells that I found on your system. Please install a - echo modern shell, or manually run the script under such a - echo shell if you do have one. - { (exit 1); exit 1; } -fi - - -fi - -fi - - - -(eval "as_func_return () { - (exit \$1) -} -as_func_success () { - as_func_return 0 -} -as_func_failure () { - as_func_return 1 -} -as_func_ret_success () { - return 0 -} -as_func_ret_failure () { - return 1 -} - -exitcode=0 -if as_func_success; then - : -else - exitcode=1 - echo as_func_success failed. -fi - -if as_func_failure; then - exitcode=1 - echo as_func_failure succeeded. -fi - -if as_func_ret_success; then - : -else - exitcode=1 - echo as_func_ret_success failed. -fi - -if as_func_ret_failure; then - exitcode=1 - echo as_func_ret_failure succeeded. -fi - -if ( set x; as_func_ret_success y && test x = \"\$1\" ); then - : -else - exitcode=1 - echo positional parameters were not saved. -fi - -test \$exitcode = 0") || { - echo No shell found that supports shell functions. - echo Please tell [email protected] about your system, - echo including any error possibly output before this - echo message -} - - - - as_lineno_1=$LINENO - as_lineno_2=$LINENO - test "x$as_lineno_1" != "x$as_lineno_2" && - test "x`expr $as_lineno_1 + 1`" = "x$as_lineno_2" || { - - # Create $as_me.lineno as a copy of $as_myself, but with $LINENO - # uniformly replaced by the line number. The first 'sed' inserts a - # line-number line after each line using $LINENO; the second 'sed' - # does the real work. The second script uses 'N' to pair each - # line-number line with the line containing $LINENO, and appends - # trailing '-' during substitution so that $LINENO is not a special - # case at line end. - # (Raja R Harinath suggested sed '=', and Paul Eggert wrote the - # scripts with optimization help from Paolo Bonzini. Blame Lee - # E. McMahon (1931-1989) for sed's syntax. :-) - sed -n ' - p - /[$]LINENO/= - ' <$as_myself | - sed ' - s/[$]LINENO.*/&-/ - t lineno - b - :lineno - N - :loop - s/[$]LINENO\([^'$as_cr_alnum'_].*\n\)\(.*\)/\2\1\2/ - t loop - s/-\n.*// - ' >$as_me.lineno && - chmod +x "$as_me.lineno" || - { echo "$as_me: error: cannot create $as_me.lineno; rerun with a POSIX shell" >&2 - { (exit 1); exit 1; }; } - - # Don't try to exec as it changes $[0], causing all sort of problems - # (the dirname of $[0] is not the place where we might find the - # original and so on. Autoconf is especially sensitive to this). - . "./$as_me.lineno" - # Exit status is that of the last command. - exit -} - - -if (as_dir=`dirname -- /` && test "X$as_dir" = X/) >/dev/null 2>&1; then - as_dirname=dirname -else - as_dirname=false -fi - -ECHO_C= ECHO_N= ECHO_T= -case `echo -n x` in --n*) - case `echo 'x\c'` in - *c*) ECHO_T=' ';; # ECHO_T is single tab character. - *) ECHO_C='\c';; - esac;; -*) - ECHO_N='-n';; -esac - -if expr a : '\(a\)' >/dev/null 2>&1 && - test "X`expr 00001 : '.*\(...\)'`" = X001; then - as_expr=expr -else - as_expr=false -fi - -rm -f conf$$ conf$$.exe conf$$.file -if test -d conf$$.dir; then - rm -f conf$$.dir/conf$$.file -else - rm -f conf$$.dir - mkdir conf$$.dir -fi -echo >conf$$.file -if ln -s conf$$.file conf$$ 2>/dev/null; then - as_ln_s='ln -s' - # ... but there are two gotchas: - # 1) On MSYS, both `ln -s file dir' and `ln file dir' fail. - # 2) DJGPP < 2.04 has no symlinks; `ln -s' creates a wrapper executable. - # In both cases, we have to default to `cp -p'. - ln -s conf$$.file conf$$.dir 2>/dev/null && test ! -f conf$$.exe || - as_ln_s='cp -p' -elif ln conf$$.file conf$$ 2>/dev/null; then - as_ln_s=ln -else - as_ln_s='cp -p' -fi -rm -f conf$$ conf$$.exe conf$$.dir/conf$$.file conf$$.file -rmdir conf$$.dir 2>/dev/null - -if mkdir -p . 2>/dev/null; then - as_mkdir_p=: -else - test -d ./-p && rmdir ./-p - as_mkdir_p=false -fi - -if test -x / >/dev/null 2>&1; then - as_test_x='test -x' -else - if ls -dL / >/dev/null 2>&1; then - as_ls_L_option=L - else - as_ls_L_option= - fi - as_test_x=' - eval sh -c '\'' - if test -d "$1"; then - test -d "$1/."; - else - case $1 in - -*)set "./$1";; - esac; - case `ls -ld'$as_ls_L_option' "$1" 2>/dev/null` in - ???[sx]*):;;*)false;;esac;fi - '\'' sh - ' -fi -as_executable_p=$as_test_x - -# Sed expression to map a string onto a valid CPP name. -as_tr_cpp="eval sed 'y%*$as_cr_letters%P$as_cr_LETTERS%;s%[^_$as_cr_alnum]%_%g'" - -# Sed expression to map a string onto a valid variable name. -as_tr_sh="eval sed 'y%*+%pp%;s%[^_$as_cr_alnum]%_%g'" - - - -exec 7<&0 </dev/null 6>&1 - -# Name of the host. -# hostname on some systems (SVR3.2, Linux) returns a bogus exit status, -# so uname gets run too. -ac_hostname=`(hostname || uname -n) 2>/dev/null | sed 1q` - -# -# Initializations. -# -ac_default_prefix=/usr/local -ac_clean_files= -ac_config_libobj_dir=. -LIB@&t@OBJS= -cross_compiling=no -subdirs= -MFLAGS= -MAKEFLAGS= -SHELL=${CONFIG_SHELL-/bin/sh} - -# Identity of this package. -PACKAGE_NAME='triton' -PACKAGE_TARNAME='triton' -PACKAGE_VERSION='0.1.1' -PACKAGE_STRING='triton 0.1.1' -PACKAGE_BUGREPORT='[email protected]' - -# Factoring default headers for most tests. -ac_includes_default="\ -#include <stdio.h> -#ifdef HAVE_SYS_TYPES_H -# include <sys/types.h> -#endif -#ifdef HAVE_SYS_STAT_H -# include <sys/stat.h> -#endif -#ifdef STDC_HEADERS -# include <stdlib.h> -# include <stddef.h> -#else -# ifdef HAVE_STDLIB_H -# include <stdlib.h> -# endif -#endif -#ifdef HAVE_STRING_H -# if !defined STDC_HEADERS && defined HAVE_MEMORY_H -# include <memory.h> -# endif -# include <string.h> -#endif -#ifdef HAVE_STRINGS_H -# include <strings.h> -#endif -#ifdef HAVE_INTTYPES_H -# include <inttypes.h> -#endif -#ifdef HAVE_STDINT_H -# include <stdint.h> -#endif -#ifdef HAVE_UNISTD_H -# include <unistd.h> -#endif" - -ac_subst_vars='SHELL -PATH_SEPARATOR -PACKAGE_NAME -PACKAGE_TARNAME -PACKAGE_VERSION -PACKAGE_STRING -PACKAGE_BUGREPORT -exec_prefix -prefix -program_transform_name -bindir -sbindir -libexecdir -datarootdir -datadir -sysconfdir -sharedstatedir -localstatedir -includedir -oldincludedir -docdir -infodir -htmldir -dvidir -pdfdir -psdir -libdir -localedir -mandir -DEFS -ECHO_C -ECHO_N -ECHO_T -LIBS -build_alias -host_alias -target_alias -TRITON_VERSION -INSTALL_PROGRAM -INSTALL_SCRIPT -INSTALL_DATA -CC -CFLAGS -LDFLAGS -CPPFLAGS -ac_ct_CC -EXEEXT -OBJEXT -CPP -GREP -EGREP -GHC -DB_CFLAGS -DB_LIB -MPICC -MPICFLAGS -MPILDFLAGS -MPILIBS -BUILD_MPI -BUILD_ABSOLUTE_TOP -SRC_RELATIVE_TOP -SRC_ABSOLUTE_TOP -QUIET_COMPILE -STRICT_CFLAGS -AE_DEBUG -ENABLE_COVERAGE -LIBCFLAGS -THREAD_LIB -TRITON_SQLITE_INCLUDES -TRITON_SQLITE_LIBS -BUILD_OSD -LIB@&t@OBJS -LTLIBOBJS' -ac_subst_files='' - ac_precious_vars='build_alias -host_alias -target_alias -CC -CFLAGS -LDFLAGS -LIBS -CPPFLAGS -CPP' - - -# Initialize some variables set by options. -ac_init_help= -ac_init_version=false -# The variables have the same names as the options, with -# dashes changed to underlines. -cache_file=/dev/null -exec_prefix=NONE -no_create= -no_recursion= -prefix=NONE -program_prefix=NONE -program_suffix=NONE -program_transform_name=s,x,x, -silent= -site= -srcdir= -verbose= -x_includes=NONE -x_libraries=NONE - -# Installation directory options. -# These are left unexpanded so users can "make install exec_prefix=/foo" -# and all the variables that are supposed to be based on exec_prefix -# by default will actually change. -# Use braces instead of parens because sh, perl, etc. also accept them. -# (The list follows the same order as the GNU Coding Standards.) -bindir='${exec_prefix}/bin' -sbindir='${exec_prefix}/sbin' -libexecdir='${exec_prefix}/libexec' -datarootdir='${prefix}/share' -datadir='${datarootdir}' -sysconfdir='${prefix}/etc' -sharedstatedir='${prefix}/com' -localstatedir='${prefix}/var' -includedir='${prefix}/include' -oldincludedir='/usr/include' -docdir='${datarootdir}/doc/${PACKAGE_TARNAME}' -infodir='${datarootdir}/info' -htmldir='${docdir}' -dvidir='${docdir}' -pdfdir='${docdir}' -psdir='${docdir}' -libdir='${exec_prefix}/lib' -localedir='${datarootdir}/locale' -mandir='${datarootdir}/man' - -ac_prev= -ac_dashdash= -for ac_option -do - # If the previous option needs an argument, assign it. - if test -n "$ac_prev"; then - eval $ac_prev=\$ac_option - ac_prev= - continue - fi - - case $ac_option in - *=*) ac_optarg=`expr "X$ac_option" : '[^=]*=\(.*\)'` ;; - *) ac_optarg=yes ;; - esac - - # Accept the important Cygnus configure options, so we can diagnose typos. - - case $ac_dashdash$ac_option in - --) - ac_dashdash=yes ;; - - -bindir | --bindir | --bindi | --bind | --bin | --bi) - ac_prev=bindir ;; - -bindir=* | --bindir=* | --bindi=* | --bind=* | --bin=* | --bi=*) - bindir=$ac_optarg ;; - - -build | --build | --buil | --bui | --bu) - ac_prev=build_alias ;; - -build=* | --build=* | --buil=* | --bui=* | --bu=*) - build_alias=$ac_optarg ;; - - -cache-file | --cache-file | --cache-fil | --cache-fi \ - | --cache-f | --cache- | --cache | --cach | --cac | --ca | --c) - ac_prev=cache_file ;; - -cache-file=* | --cache-file=* | --cache-fil=* | --cache-fi=* \ - | --cache-f=* | --cache-=* | --cache=* | --cach=* | --cac=* | --ca=* | --c=*) - cache_file=$ac_optarg ;; - - --config-cache | -C) - cache_file=config.cache ;; - - -datadir | --datadir | --datadi | --datad) - ac_prev=datadir ;; - -datadir=* | --datadir=* | --datadi=* | --datad=*) - datadir=$ac_optarg ;; - - -datarootdir | --datarootdir | --datarootdi | --datarootd | --dataroot \ - | --dataroo | --dataro | --datar) - ac_prev=datarootdir ;; - -datarootdir=* | --datarootdir=* | --datarootdi=* | --datarootd=* \ - | --dataroot=* | --dataroo=* | --dataro=* | --datar=*) - datarootdir=$ac_optarg ;; - - -disable-* | --disable-*) - ac_feature=`expr "x$ac_option" : 'x-*disable-\(.*\)'` - # Reject names that are not valid shell variable names. - expr "x$ac_feature" : ".*[^-._$as_cr_alnum]" >/dev/null && - { echo "$as_me: error: invalid feature name: $ac_feature" >&2 - { (exit 1); exit 1; }; } - ac_feature=`echo $ac_feature | sed 's/[-.]/_/g'` - eval enable_$ac_feature=no ;; - - -docdir | --docdir | --docdi | --doc | --do) - ac_prev=docdir ;; - -docdir=* | --docdir=* | --docdi=* | --doc=* | --do=*) - docdir=$ac_optarg ;; - - -dvidir | --dvidir | --dvidi | --dvid | --dvi | --dv) - ac_prev=dvidir ;; - -dvidir=* | --dvidir=* | --dvidi=* | --dvid=* | --dvi=* | --dv=*) - dvidir=$ac_optarg ;; - - -enable-* | --enable-*) - ac_feature=`expr "x$ac_option" : 'x-*enable-\([^=]*\)'` - # Reject names that are not valid shell variable names. - expr "x$ac_feature" : ".*[^-._$as_cr_alnum]" >/dev/null && - { echo "$as_me: error: invalid feature name: $ac_feature" >&2 - { (exit 1); exit 1; }; } - ac_feature=`echo $ac_feature | sed 's/[-.]/_/g'` - eval enable_$ac_feature=\$ac_optarg ;; - - -exec-prefix | --exec_prefix | --exec-prefix | --exec-prefi \ - | --exec-pref | --exec-pre | --exec-pr | --exec-p | --exec- \ - | --exec | --exe | --ex) - ac_prev=exec_prefix ;; - -exec-prefix=* | --exec_prefix=* | --exec-prefix=* | --exec-prefi=* \ - | --exec-pref=* | --exec-pre=* | --exec-pr=* | --exec-p=* | --exec-=* \ - | --exec=* | --exe=* | --ex=*) - exec_prefix=$ac_optarg ;; - - -gas | --gas | --ga | --g) - # Obsolete; use --with-gas. - with_gas=yes ;; - - -help | --help | --hel | --he | -h) - ac_init_help=long ;; - -help=r* | --help=r* | --hel=r* | --he=r* | -hr*) - ac_init_help=recursive ;; - -help=s* | --help=s* | --hel=s* | --he=s* | -hs*) - ac_init_help=short ;; - - -host | --host | --hos | --ho) - ac_prev=host_alias ;; - -host=* | --host=* | --hos=* | --ho=*) - host_alias=$ac_optarg ;; - - -htmldir | --htmldir | --htmldi | --htmld | --html | --htm | --ht) - ac_prev=htmldir ;; - -htmldir=* | --htmldir=* | --htmldi=* | --htmld=* | --html=* | --htm=* \ - | --ht=*) - htmldir=$ac_optarg ;; - - -includedir | --includedir | --includedi | --included | --include \ - | --includ | --inclu | --incl | --inc) - ac_prev=includedir ;; - -includedir=* | --includedir=* | --includedi=* | --included=* | --include=* \ - | --includ=* | --inclu=* | --incl=* | --inc=*) - includedir=$ac_optarg ;; - - -infodir | --infodir | --infodi | --infod | --info | --inf) - ac_prev=infodir ;; - -infodir=* | --infodir=* | --infodi=* | --infod=* | --info=* | --inf=*) - infodir=$ac_optarg ;; - - -libdir | --libdir | --libdi | --libd) - ac_prev=libdir ;; - -libdir=* | --libdir=* | --libdi=* | --libd=*) - libdir=$ac_optarg ;; - - -libexecdir | --libexecdir | --libexecdi | --libexecd | --libexec \ - | --libexe | --libex | --libe) - ac_prev=libexecdir ;; - -libexecdir=* | --libexecdir=* | --libexecdi=* | --libexecd=* | --libexec=* \ - | --libexe=* | --libex=* | --libe=*) - libexecdir=$ac_optarg ;; - - -localedir | --localedir | --localedi | --localed | --locale) - ac_prev=localedir ;; - -localedir=* | --localedir=* | --localedi=* | --localed=* | --locale=*) - localedir=$ac_optarg ;; - - -localstatedir | --localstatedir | --localstatedi | --localstated \ - | --localstate | --localstat | --localsta | --localst | --locals) - ac_prev=localstatedir ;; - -localstatedir=* | --localstatedir=* | --localstatedi=* | --localstated=* \ - | --localstate=* | --localstat=* | --localsta=* | --localst=* | --locals=*) - localstatedir=$ac_optarg ;; - - -mandir | --mandir | --mandi | --mand | --man | --ma | --m) - ac_prev=mandir ;; - -mandir=* | --mandir=* | --mandi=* | --mand=* | --man=* | --ma=* | --m=*) - mandir=$ac_optarg ;; - - -nfp | --nfp | --nf) - # Obsolete; use --without-fp. - with_fp=no ;; - - -no-create | --no-create | --no-creat | --no-crea | --no-cre \ - | --no-cr | --no-c | -n) - no_create=yes ;; - - -no-recursion | --no-recursion | --no-recursio | --no-recursi \ - | --no-recurs | --no-recur | --no-recu | --no-rec | --no-re | --no-r) - no_recursion=yes ;; - - -oldincludedir | --oldincludedir | --oldincludedi | --oldincluded \ - | --oldinclude | --oldinclud | --oldinclu | --oldincl | --oldinc \ - | --oldin | --oldi | --old | --ol | --o) - ac_prev=oldincludedir ;; - -oldincludedir=* | --oldincludedir=* | --oldincludedi=* | --oldincluded=* \ - | --oldinclude=* | --oldinclud=* | --oldinclu=* | --oldincl=* | --oldinc=* \ - | --oldin=* | --oldi=* | --old=* | --ol=* | --o=*) - oldincludedir=$ac_optarg ;; - - -prefix | --prefix | --prefi | --pref | --pre | --pr | --p) - ac_prev=prefix ;; - -prefix=* | --prefix=* | --prefi=* | --pref=* | --pre=* | --pr=* | --p=*) - prefix=$ac_optarg ;; - - -program-prefix | --program-prefix | --program-prefi | --program-pref \ - | --program-pre | --program-pr | --program-p) - ac_prev=program_prefix ;; - -program-prefix=* | --program-prefix=* | --program-prefi=* \ - | --program-pref=* | --program-pre=* | --program-pr=* | --program-p=*) - program_prefix=$ac_optarg ;; - - -program-suffix | --program-suffix | --program-suffi | --program-suff \ - | --program-suf | --program-su | --program-s) - ac_prev=program_suffix ;; - -program-suffix=* | --program-suffix=* | --program-suffi=* \ - | --program-suff=* | --program-suf=* | --program-su=* | --program-s=*) - program_suffix=$ac_optarg ;; - - -program-transform-name | --program-transform-name \ - | --program-transform-nam | --program-transform-na \ - | --program-transform-n | --program-transform- \ - | --program-transform | --program-transfor \ - | --program-transfo | --program-transf \ - | --program-trans | --program-tran \ - | --progr-tra | --program-tr | --program-t) - ac_prev=program_transform_name ;; - -program-transform-name=* | --program-transform-name=* \ - | --program-transform-nam=* | --program-transform-na=* \ - | --program-transform-n=* | --program-transform-=* \ - | --program-transform=* | --program-transfor=* \ - | --program-transfo=* | --program-transf=* \ - | --program-trans=* | --program-tran=* \ - | --progr-tra=* | --program-tr=* | --program-t=*) - program_transform_name=$ac_optarg ;; - - -pdfdir | --pdfdir | --pdfdi | --pdfd | --pdf | --pd) - ac_prev=pdfdir ;; - -pdfdir=* | --pdfdir=* | --pdfdi=* | --pdfd=* | --pdf=* | --pd=*) - pdfdir=$ac_optarg ;; - - -psdir | --psdir | --psdi | --psd | --ps) - ac_prev=psdir ;; - -psdir=* | --psdir=* | --psdi=* | --psd=* | --ps=*) - psdir=$ac_optarg ;; - - -q | -quiet | --quiet | --quie | --qui | --qu | --q \ - | -silent | --silent | --silen | --sile | --sil) - silent=yes ;; - - -sbindir | --sbindir | --sbindi | --sbind | --sbin | --sbi | --sb) - ac_prev=sbindir ;; - -sbindir=* | --sbindir=* | --sbindi=* | --sbind=* | --sbin=* \ - | --sbi=* | --sb=*) - sbindir=$ac_optarg ;; - - -sharedstatedir | --sharedstatedir | --sharedstatedi \ - | --sharedstated | --sharedstate | --sharedstat | --sharedsta \ - | --sharedst | --shareds | --shared | --share | --shar \ - | --sha | --sh) - ac_prev=sharedstatedir ;; - -sharedstatedir=* | --sharedstatedir=* | --sharedstatedi=* \ - | --sharedstated=* | --sharedstate=* | --sharedstat=* | --sharedsta=* \ - | --sharedst=* | --shareds=* | --shared=* | --share=* | --shar=* \ - | --sha=* | --sh=*) - sharedstatedir=$ac_optarg ;; - - -site | --site | --sit) - ac_prev=site ;; - -site=* | --site=* | --sit=*) - site=$ac_optarg ;; - - -srcdir | --srcdir | --srcdi | --srcd | --src | --sr) - ac_prev=srcdir ;; - -srcdir=* | --srcdir=* | --srcdi=* | --srcd=* | --src=* | --sr=*) - srcdir=$ac_optarg ;; - - -sysconfdir | --sysconfdir | --sysconfdi | --sysconfd | --sysconf \ - | --syscon | --sysco | --sysc | --sys | --sy) - ac_prev=sysconfdir ;; - -sysconfdir=* | --sysconfdir=* | --sysconfdi=* | --sysconfd=* | --sysconf=* \ - | --syscon=* | --sysco=* | --sysc=* | --sys=* | --sy=*) - sysconfdir=$ac_optarg ;; - - -target | --target | --targe | --targ | --tar | --ta | --t) - ac_prev=target_alias ;; - -target=* | --target=* | --targe=* | --targ=* | --tar=* | --ta=* | --t=*) - target_alias=$ac_optarg ;; - - -v | -verbose | --verbose | --verbos | --verbo | --verb) - verbose=yes ;; - - -version | --version | --versio | --versi | --vers | -V) - ac_init_version=: ;; - - -with-* | --with-*) - ac_package=`expr "x$ac_option" : 'x-*with-\([^=]*\)'` - # Reject names that are not valid shell variable names. - expr "x$ac_package" : ".*[^-._$as_cr_alnum]" >/dev/null && - { echo "$as_me: error: invalid package name: $ac_package" >&2 - { (exit 1); exit 1; }; } - ac_package=`echo $ac_package | sed 's/[-.]/_/g'` - eval with_$ac_package=\$ac_optarg ;; - - -without-* | --without-*) - ac_package=`expr "x$ac_option" : 'x-*without-\(.*\)'` - # Reject names that are not valid shell variable names. - expr "x$ac_package" : ".*[^-._$as_cr_alnum]" >/dev/null && - { echo "$as_me: error: invalid package name: $ac_package" >&2 - { (exit 1); exit 1; }; } - ac_package=`echo $ac_package | sed 's/[-.]/_/g'` - eval with_$ac_package=no ;; - - --x) - # Obsolete; use --with-x. - with_x=yes ;; - - -x-includes | --x-includes | --x-include | --x-includ | --x-inclu \ - | --x-incl | --x-inc | --x-in | --x-i) - ac_prev=x_includes ;; - -x-includes=* | --x-includes=* | --x-include=* | --x-includ=* | --x-inclu=* \ - | --x-incl=* | --x-inc=* | --x-in=* | --x-i=*) - x_includes=$ac_optarg ;; - - -x-libraries | --x-libraries | --x-librarie | --x-librari \ - | --x-librar | --x-libra | --x-libr | --x-lib | --x-li | --x-l) - ac_prev=x_libraries ;; - -x-libraries=* | --x-libraries=* | --x-librarie=* | --x-librari=* \ - | --x-librar=* | --x-libra=* | --x-libr=* | --x-lib=* | --x-li=* | --x-l=*) - x_libraries=$ac_optarg ;; - - -*) { echo "$as_me: error: unrecognized option: $ac_option -Try \`$0 --help' for more information." >&2 - { (exit 1); exit 1; }; } - ;; - - *=*) - ac_envvar=`expr "x$ac_option" : 'x\([^=]*\)='` - # Reject names that are not valid shell variable names. - expr "x$ac_envvar" : ".*[^_$as_cr_alnum]" >/dev/null && - { echo "$as_me: error: invalid variable name: $ac_envvar" >&2 - { (exit 1); exit 1; }; } - eval $ac_envvar=\$ac_optarg - export $ac_envvar ;; - - *) - # FIXME: should be removed in autoconf 3.0. - echo "$as_me: WARNING: you should use --build, --host, --target" >&2 - expr "x$ac_option" : ".*[^-._$as_cr_alnum]" >/dev/null && - echo "$as_me: WARNING: invalid host type: $ac_option" >&2 - : ${build_alias=$ac_option} ${host_alias=$ac_option} ${target_alias=$ac_option} - ;; - - esac -done - -if test -n "$ac_prev"; then - ac_option=--`echo $ac_prev | sed 's/_/-/g'` - { echo "$as_me: error: missing argument to $ac_option" >&2 - { (exit 1); exit 1; }; } -fi - -# Be sure to have absolute directory names. -for ac_var in exec_prefix prefix bindir sbindir libexecdir datarootdir \ - datadir sysconfdir sharedstatedir localstatedir includedir \ - oldincludedir docdir infodir htmldir dvidir pdfdir psdir \ - libdir localedir mandir -do - eval ac_val=\$$ac_var - case $ac_val in - [\\/$]* | ?:[\\/]* ) continue;; - NONE | '' ) case $ac_var in *prefix ) continue;; esac;; - esac - { echo "$as_me: error: expected an absolute directory name for --$ac_var: $ac_val" >&2 - { (exit 1); exit 1; }; } -done - -# There might be people who depend on the old broken behavior: `$host' -# used to hold the argument of --host etc. -# FIXME: To remove some day. -build=$build_alias -host=$host_alias -target=$target_alias - -# FIXME: To remove some day. -if test "x$host_alias" != x; then - if test "x$build_alias" = x; then - cross_compiling=maybe - echo "$as_me: WARNING: If you wanted to set the --build type, don't use --host. - If a cross compiler is detected then cross compile mode will be used." >&2 - elif test "x$build_alias" != "x$host_alias"; then - cross_compiling=yes - fi -fi - -ac_tool_prefix= -test -n "$host_alias" && ac_tool_prefix=$host_alias- - -test "$silent" = yes && exec 6>/dev/null - - -ac_pwd=`pwd` && test -n "$ac_pwd" && -ac_ls_di=`ls -di .` && -ac_pwd_ls_di=`cd "$ac_pwd" && ls -di .` || - { echo "$as_me: error: Working directory cannot be determined" >&2 - { (exit 1); exit 1; }; } -test "X$ac_ls_di" = "X$ac_pwd_ls_di" || - { echo "$as_me: error: pwd does not report name of working directory" >&2 - { (exit 1); exit 1; }; } - - -# Find the source files, if location was not specified. -if test -z "$srcdir"; then - ac_srcdir_defaulted=yes - # Try the directory containing this script, then the parent directory. - ac_confdir=`$as_dirname -- "$0" || -$as_expr X"$0" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \ - X"$0" : 'X\(//\)[^/]' \| \ - X"$0" : 'X\(//\)$' \| \ - X"$0" : 'X\(/\)' \| . 2>/dev/null || -echo X"$0" | - sed '/^X\(.*[^/]\)\/\/*[^/][^/]*\/*$/{ - s//\1/ - q - } - /^X\(\/\/\)[^/].*/{ - s//\1/ - q - } - /^X\(\/\/\)$/{ - s//\1/ - q - } - /^X\(\/\).*/{ - s//\1/ - q - } - s/.*/./; q'` - srcdir=$ac_confdir - if test ! -r "$srcdir/$ac_unique_file"; then - srcdir=.. - fi -else - ac_srcdir_defaulted=no -fi -if test ! -r "$srcdir/$ac_unique_file"; then - test "$ac_srcdir_defaulted" = yes && srcdir="$ac_confdir or .." - { echo "$as_me: error: cannot find sources ($ac_unique_file) in $srcdir" >&2 - { (exit 1); exit 1; }; } -fi -ac_msg="sources are in $srcdir, but \`cd $srcdir' does not work" -ac_abs_confdir=`( - cd "$srcdir" && test -r "./$ac_unique_file" || { echo "$as_me: error: $ac_msg" >&2 - { (exit 1); exit 1; }; } - pwd)` -# When building in place, set srcdir=. -if test "$ac_abs_confdir" = "$ac_pwd"; then - srcdir=. -fi -# Remove unnecessary trailing slashes from srcdir. -# Double slashes in file names in object file debugging info -# mess up M-x gdb in Emacs. -case $srcdir in -*/) srcdir=`expr "X$srcdir" : 'X\(.*[^/]\)' \| "X$srcdir" : 'X\(.*\)'`;; -esac -for ac_var in $ac_precious_vars; do - eval ac_env_${ac_var}_set=\${${ac_var}+set} - eval ac_env_${ac_var}_value=\$${ac_var} - eval ac_cv_env_${ac_var}_set=\${${ac_var}+set} - eval ac_cv_env_${ac_var}_value=\$${ac_var} -done - -# -# Report the --help message. -# -if test "$ac_init_help" = "long"; then - # Omit some internal or obsolete options to make the list less imposing. - # This message is too long to be a string in the A/UX 3.1 sh. - cat <<_ACEOF -\`configure' configures triton 0.1.1 to adapt to many kinds of systems. - -Usage: $0 [OPTION]... [VAR=VALUE]... - -To assign environment variables (e.g., CC, CFLAGS...), specify them as -VAR=VALUE. See below for descriptions of some of the useful variables. - -Defaults for the options are specified in brackets. - -Configuration: - -h, --help display this help and exit - --help=short display options specific to this package - --help=recursive display the short help of all the included packages - -V, --version display version information and exit - -q, --quiet, --silent do not print \`checking...' messages - --cache-file=FILE cache test results in FILE [disabled] - -C, --config-cache alias for \`--cache-file=config.cache' - -n, --no-create do not create output files - --srcdir=DIR find the sources in DIR [configure dir or \`..'] - -Installation directories: - --prefix=PREFIX install architecture-independent files in PREFIX - [$ac_default_prefix] - --exec-prefix=EPREFIX install architecture-dependent files in EPREFIX - [PREFIX] - -By default, \`make install' will install all the files in -\`$ac_default_prefix/bin', \`$ac_default_prefix/lib' etc. You can specify -an installation prefix other than \`$ac_default_prefix' using \`--prefix', -for instance \`--prefix=\$HOME'. - -For better control, use the options below. - -Fine tuning of the installation directories: - --bindir=DIR user executables [EPREFIX/bin] - --sbindir=DIR system admin executables [EPREFIX/sbin] - --libexecdir=DIR program executables [EPREFIX/libexec] - --sysconfdir=DIR read-only single-machine data [PREFIX/etc] - --sharedstatedir=DIR modifiable architecture-independent data [PREFIX/com] - --localstatedir=DIR modifiable single-machine data [PREFIX/var] - --libdir=DIR object code libraries [EPREFIX/lib] - --includedir=DIR C header files [PREFIX/include] - --oldincludedir=DIR C header files for non-gcc [/usr/include] - --datarootdir=DIR read-only arch.-independent data root [PREFIX/share] - --datadir=DIR read-only architecture-independent data [DATAROOTDIR] - --infodir=DIR info documentation [DATAROOTDIR/info] - --localedir=DIR locale-dependent data [DATAROOTDIR/locale] - --mandir=DIR man documentation [DATAROOTDIR/man] - --docdir=DIR documentation root @<:@DATAROOTDIR/doc/triton@:>@ - --htmldir=DIR html documentation [DOCDIR] - --dvidir=DIR dvi documentation [DOCDIR] - --pdfdir=DIR pdf documentation [DOCDIR] - --psdir=DIR ps documentation [DOCDIR] -_ACEOF - - cat <<\_ACEOF -_ACEOF -fi - -if test -n "$ac_init_help"; then - case $ac_init_help in - short | recursive ) echo "Configuration of triton 0.1.1:";; - esac - cat <<\_ACEOF - -Optional Features: - --disable-FEATURE do not include FEATURE (same as --enable-FEATURE=no) - --enable-FEATURE[=ARG] include FEATURE [ARG=yes] - --enable-verbose Enables verbose output during build process - --enable-strict Turn on strict compiler warnings - --enable-aesop-debug Turn on debugging of the gs-parser - --enable-coverage Enable coverage analysis (disables optimizations) - --disable-thread-safety Disables thread safety in the client library - -Optional Packages: - --with-PACKAGE[=ARG] use PACKAGE [ARG=yes] - --without-PACKAGE do not use PACKAGE (same as --with-PACKAGE=no) - --with-ghc=<dir> Location of installed ghc - --with-db=<dir> Location of installed DB package -(default=/usr) - --with-mpi=<dir> Location of the MPI installation - --with-sqlite=PREFIX Use installed SQLite library or amalgamation file. - -Some influential environment variables: - CC C compiler command - CFLAGS C compiler flags - LDFLAGS linker flags, e.g. -L<lib dir> if you have libraries in a - nonstandard directory <lib dir> - LIBS libraries to pass to the linker, e.g. -l<library> - CPPFLAGS C/C++/Objective C preprocessor flags, e.g. -I<include dir> if - you have headers in a nonstandard directory <include dir> - CPP C preprocessor - -Use these variables to override the choices made by `configure' or to help -it to find libraries and programs with nonstandard names/locations. - -Report bugs to <[email protected]>. -_ACEOF -ac_status=$? -fi - -if test "$ac_init_help" = "recursive"; then - # If there are subdirs, report their specific --help. - for ac_dir in : $ac_subdirs_all; do test "x$ac_dir" = x: && continue - test -d "$ac_dir" || continue - ac_builddir=. - -case "$ac_dir" in -.) ac_dir_suffix= ac_top_builddir_sub=. ac_top_build_prefix= ;; -*) - ac_dir_suffix=/`echo "$ac_dir" | sed 's,^\.[\\/],,'` - # A ".." for each directory in $ac_dir_suffix. - ac_top_builddir_sub=`echo "$ac_dir_suffix" | sed 's,/[^\\/]*,/..,g;s,/,,'` - case $ac_top_builddir_sub in - "") ac_top_builddir_sub=. ac_top_build_prefix= ;; - *) ac_top_build_prefix=$ac_top_builddir_sub/ ;; - esac ;; -esac -ac_abs_top_builddir=$ac_pwd -ac_abs_builddir=$ac_pwd$ac_dir_suffix -# for backward compatibility: -ac_top_builddir=$ac_top_build_prefix - -case $srcdir in - .) # We are building in place. - ac_srcdir=. - ac_top_srcdir=$ac_top_builddir_sub - ac_abs_top_srcdir=$ac_pwd ;; - [\\/]* | ?:[\\/]* ) # Absolute name. - ac_srcdir=$srcdir$ac_dir_suffix; - ac_top_srcdir=$srcdir - ac_abs_top_srcdir=$srcdir ;; - *) # Relative name. - ac_srcdir=$ac_top_build_prefix$srcdir$ac_dir_suffix - ac_top_srcdir=$ac_top_build_prefix$srcdir - ac_abs_top_srcdir=$ac_pwd/$srcdir ;; -esac -ac_abs_srcdir=$ac_abs_top_srcdir$ac_dir_suffix - - cd "$ac_dir" || { ac_status=$?; continue; } - # Check for guested configure. - if test -f "$ac_srcdir/configure.gnu"; then - echo && - $SHELL "$ac_srcdir/configure.gnu" --help=recursive - elif test -f "$ac_srcdir/configure"; then - echo && - $SHELL "$ac_srcdir/configure" --help=recursive - else - echo "$as_me: WARNING: no configuration information is in $ac_dir" >&2 - fi || ac_status=$? - cd "$ac_pwd" || { ac_status=$?; break; } - done -fi - -test -n "$ac_init_help" && exit $ac_status -if $ac_init_version; then - cat <<\_ACEOF -triton configure 0.1.1 -generated by GNU Autoconf 2.61 - -Copyright (C) 1992, 1993, 1994, 1995, 1996, 1998, 1999, 2000, 2001, -2002, 2003, 2004, 2005, 2006 Free Software Foundation, Inc. -This configure script is free software; the Free Software Foundation -gives unlimited permission to copy, distribute and modify it. -_ACEOF - exit -fi -cat >config.log <<_ACEOF -This file contains any messages produced by compilers while -running configure, to aid debugging if configure makes a mistake. - -It was created by triton $as_me 0.1.1, which was -generated by GNU Autoconf 2.61. Invocation command line was - - $ $0 $@ - -_ACEOF -exec 5>>config.log -{ -cat <<_ASUNAME -@%:@@%:@ --------- @%:@@%:@ -@%:@@%:@ Platform. @%:@@%:@ -@%:@@%:@ --------- @%:@@%:@ - -hostname = `(hostname || uname -n) 2>/dev/null | sed 1q` -uname -m = `(uname -m) 2>/dev/null || echo unknown` -uname -r = `(uname -r) 2>/dev/null || echo unknown` -uname -s = `(uname -s) 2>/dev/null || echo unknown` -uname -v = `(uname -v) 2>/dev/null || echo unknown` - -/usr/bin/uname -p = `(/usr/bin/uname -p) 2>/dev/null || echo unknown` -/bin/uname -X = `(/bin/uname -X) 2>/dev/null || echo unknown` - -/bin/arch = `(/bin/arch) 2>/dev/null || echo unknown` -/usr/bin/arch -k = `(/usr/bin/arch -k) 2>/dev/null || echo unknown` -/usr/convex/getsysinfo = `(/usr/convex/getsysinfo) 2>/dev/null || echo unknown` -/usr/bin/hostinfo = `(/usr/bin/hostinfo) 2>/dev/null || echo unknown` -/bin/machine = `(/bin/machine) 2>/dev/null || echo unknown` -/usr/bin/oslevel = `(/usr/bin/oslevel) 2>/dev/null || echo unknown` -/bin/universe = `(/bin/universe) 2>/dev/null || echo unknown` - -_ASUNAME - -as_save_IFS=$IFS; IFS=$PATH_SEPARATOR -for as_dir in $PATH -do - IFS=$as_save_IFS - test -z "$as_dir" && as_dir=. - echo "PATH: $as_dir" -done -IFS=$as_save_IFS - -} >&5 - -cat >&5 <<_ACEOF - - -@%:@@%:@ ----------- @%:@@%:@ -@%:@@%:@ Core tests. @%:@@%:@ -@%:@@%:@ ----------- @%:@@%:@ - -_ACEOF - - -# Keep a trace of the command line. -# Strip out --no-create and --no-recursion so they do not pile up. -# Strip out --silent because we don't want to record it for future runs. -# Also quote any args containing shell meta-characters. -# Make two passes to allow for proper duplicate-argument suppression. -ac_configure_args= -ac_configure_args0= -ac_configure_args1= -ac_must_keep_next=false -for ac_pass in 1 2 -do - for ac_arg - do - case $ac_arg in - -no-create | --no-c* | -n | -no-recursion | --no-r*) continue ;; - -q | -quiet | --quiet | --quie | --qui | --qu | --q \ - | -silent | --silent | --silen | --sile | --sil) - continue ;; - *\'*) - ac_arg=`echo "$ac_arg" | sed "s/'/'\\\\\\\\''/g"` ;; - esac - case $ac_pass in - 1) ac_configure_args0="$ac_configure_args0 '$ac_arg'" ;; - 2) - ac_configure_args1="$ac_configure_args1 '$ac_arg'" - if test $ac_must_keep_next = true; then - ac_must_keep_next=false # Got value, back to normal. - else - case $ac_arg in - *=* | --config-cache | -C | -disable-* | --disable-* \ - | -enable-* | --enable-* | -gas | --g* | -nfp | --nf* \ - | -q | -quiet | --q* | -silent | --sil* | -v | -verb* \ - | -with-* | --with-* | -without-* | --without-* | --x) - case "$ac_configure_args0 " in - "$ac_configure_args1"*" '$ac_arg' "* ) continue ;; - esac - ;; - -* ) ac_must_keep_next=true ;; - esac - fi - ac_configure_args="$ac_configure_args '$ac_arg'" - ;; - esac - done -done -$as_unset ac_configure_args0 || test "${ac_configure_args0+set}" != set || { ac_configure_args0=; export ac_configure_args0; } -$as_unset ac_configure_args1 || test "${ac_configure_args1+set}" != set || { ac_configure_args1=; export ac_configure_args1; } - -# When interrupted or exit'd, cleanup temporary files, and complete -# config.log. We remove comments because anyway the quotes in there -# would cause problems or look ugly. -# WARNING: Use '\'' to represent an apostrophe within the trap. -# WARNING: Do not start the trap code with a newline, due to a FreeBSD 4.0 bug. -trap 'exit_status=$? - # Save into config.log some information that might help in debugging. - { - echo - - cat <<\_ASBOX -@%:@@%:@ ---------------- @%:@@%:@ -@%:@@%:@ Cache variables. @%:@@%:@ -@%:@@%:@ ---------------- @%:@@%:@ -_ASBOX - echo - # The following way of writing the cache mishandles newlines in values, -( - for ac_var in `(set) 2>&1 | sed -n '\''s/^\([a-zA-Z_][a-zA-Z0-9_]*\)=.*/\1/p'\''`; do - eval ac_val=\$$ac_var - case $ac_val in #( - *${as_nl}*) - case $ac_var in #( - *_cv_*) { echo "$as_me:$LINENO: WARNING: Cache variable $ac_var contains a newline." >&5 -echo "$as_me: WARNING: Cache variable $ac_var contains a newline." >&2;} ;; - esac - case $ac_var in #( - _ | IFS | as_nl) ;; #( - *) $as_unset $ac_var ;; - esac ;; - esac - done - (set) 2>&1 | - case $as_nl`(ac_space='\'' '\''; set) 2>&1` in #( - *${as_nl}ac_space=\ *) - sed -n \ - "s/'\''/'\''\\\\'\'''\''/g; - s/^\\([_$as_cr_alnum]*_cv_[_$as_cr_alnum]*\\)=\\(.*\\)/\\1='\''\\2'\''/p" - ;; #( - *) - sed -n "/^[_$as_cr_alnum]*_cv_[_$as_cr_alnum]*=/p" - ;; - esac | - sort -) - echo - - cat <<\_ASBOX -@%:@@%:@ ----------------- @%:@@%:@ -@%:@@%:@ Output variables. @%:@@%:@ -@%:@@%:@ ----------------- @%:@@%:@ -_ASBOX - echo - for ac_var in $ac_subst_vars - do - eval ac_val=\$$ac_var - case $ac_val in - *\'\''*) ac_val=`echo "$ac_val" | sed "s/'\''/'\''\\\\\\\\'\'''\''/g"`;; - esac - echo "$ac_var='\''$ac_val'\''" - done | sort - echo - - if test -n "$ac_subst_files"; then - cat <<\_ASBOX -@%:@@%:@ ------------------- @%:@@%:@ -@%:@@%:@ File substitutions. @%:@@%:@ -@%:@@%:@ ------------------- @%:@@%:@ -_ASBOX - echo - for ac_var in $ac_subst_files - do - eval ac_val=\$$ac_var - case $ac_val in - *\'\''*) ac_val=`echo "$ac_val" | sed "s/'\''/'\''\\\\\\\\'\'''\''/g"`;; - esac - echo "$ac_var='\''$ac_val'\''" - done | sort - echo - fi - - if test -s confdefs.h; then - cat <<\_ASBOX -@%:@@%:@ ----------- @%:@@%:@ -@%:@@%:@ confdefs.h. @%:@@%:@ -@%:@@%:@ ----------- @%:@@%:@ -_ASBOX - echo - cat confdefs.h - echo - fi - test "$ac_signal" != 0 && - echo "$as_me: caught signal $ac_signal" - echo "$as_me: exit $exit_status" - } >&5 - rm -f core *.core core.conftest.* && - rm -f -r conftest* confdefs* conf$$* $ac_clean_files && - exit $exit_status -' 0 -for ac_signal in 1 2 13 15; do - trap 'ac_signal='$ac_signal'; { (exit 1); exit 1; }' $ac_signal -done -ac_signal=0 - -# confdefs.h avoids OS command line length limits that DEFS can exceed. -rm -f -r conftest* confdefs.h - -# Predefined preprocessor variables. - -cat >>confdefs.h <<_ACEOF -@%:@define PACKAGE_NAME "$PACKAGE_NAME" -_ACEOF - - -cat >>confdefs.h <<_ACEOF -@%:@define PACKAGE_TARNAME "$PACKAGE_TARNAME" -_ACEOF - - -cat >>confdefs.h <<_ACEOF -@%:@define PACKAGE_VERSION "$PACKAGE_VERSION" -_ACEOF - - -cat >>confdefs.h <<_ACEOF -@%:@define PACKAGE_STRING "$PACKAGE_STRING" -_ACEOF - - -cat >>confdefs.h <<_ACEOF -@%:@define PACKAGE_BUGREPORT "$PACKAGE_BUGREPORT" -_ACEOF - - -# Let the site file select an alternate cache file if it wants to. -# Prefer explicitly selected file to automatically selected ones. -if test -n "$CONFIG_SITE"; then - set x "$CONFIG_SITE" -elif test "x$prefix" != xNONE; then - set x "$prefix/share/config.site" "$prefix/etc/config.site" -else - set x "$ac_default_prefix/share/config.site" \ - "$ac_default_prefix/etc/config.site" -fi -shift -for ac_site_file -do - if test -r "$ac_site_file"; then - { echo "$as_me:$LINENO: loading site script $ac_site_file" >&5 -echo "$as_me: loading site script $ac_site_file" >&6;} - sed 's/^/| /' "$ac_site_file" >&5 - . "$ac_site_file" - fi -done - -if test -r "$cache_file"; then - # Some versions of bash will fail to source /dev/null (special - # files actually), so we avoid doing that. - if test -f "$cache_file"; then - { echo "$as_me:$LINENO: loading cache $cache_file" >&5 -echo "$as_me: loading cache $cache_file" >&6;} - case $cache_file in - [\\/]* | ?:[\\/]* ) . "$cache_file";; - *) . "./$cache_file";; - esac - fi -else - { echo "$as_me:$LINENO: creating cache $cache_file" >&5 -echo "$as_me: creating cache $cache_file" >&6;} - >$cache_file -fi - -# Check that the precious variables saved in the cache have kept the same -# value. -ac_cache_corrupted=false -for ac_var in $ac_precious_vars; do - eval ac_old_set=\$ac_cv_env_${ac_var}_set - eval ac_new_set=\$ac_env_${ac_var}_set - eval ac_old_val=\$ac_cv_env_${ac_var}_value - eval ac_new_val=\$ac_env_${ac_var}_value - case $ac_old_set,$ac_new_set in - set,) - { echo "$as_me:$LINENO: error: \`$ac_var' was set to \`$ac_old_val' in the previous run" >&5 -echo "$as_me: error: \`$ac_var' was set to \`$ac_old_val' in the previous run" >&2;} - ac_cache_corrupted=: ;; - ,set) - { echo "$as_me:$LINENO: error: \`$ac_var' was not set in the previous run" >&5 -echo "$as_me: error: \`$ac_var' was not set in the previous run" >&2;} - ac_cache_corrupted=: ;; - ,);; - *) - if test "x$ac_old_val" != "x$ac_new_val"; then - { echo "$as_me:$LINENO: error: \`$ac_var' has changed since the previous run:" >&5 -echo "$as_me: error: \`$ac_var' has changed since the previous run:" >&2;} - { echo "$as_me:$LINENO: former value: $ac_old_val" >&5 -echo "$as_me: former value: $ac_old_val" >&2;} - { echo "$as_me:$LINENO: current value: $ac_new_val" >&5 -echo "$as_me: current value: $ac_new_val" >&2;} - ac_cache_corrupted=: - fi;; - esac - # Pass precious variables to config.status. - if test "$ac_new_set" = set; then - case $ac_new_val in - *\'*) ac_arg=$ac_var=`echo "$ac_new_val" | sed "s/'/'\\\\\\\\''/g"` ;; - *) ac_arg=$ac_var=$ac_new_val ;; - esac - case " $ac_configure_args " in - *" '$ac_arg' "*) ;; # Avoid dups. Use of quotes ensures accuracy. - *) ac_configure_args="$ac_configure_args '$ac_arg'" ;; - esac - fi -done -if $ac_cache_corrupted; then - { echo "$as_me:$LINENO: error: changes in the environment can compromise the build" >&5 -echo "$as_me: error: changes in the environment can compromise the build" >&2;} - { { echo "$as_me:$LINENO: error: run \`make distclean' and/or \`rm $cache_file' and start over" >&5 -echo "$as_me: error: run \`make distclean' and/or \`rm $cache_file' and start over" >&2;} - { (exit 1); exit 1; }; } -fi - - - - - - - - - - - - - - - - - - - - - - - - - -ac_ext=c -ac_cpp='$CPP $CPPFLAGS' -ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5' -ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5' -ac_compiler_gnu=$ac_cv_c_compiler_gnu - - - - - - -cat >>confdefs.h <<_ACEOF -@%:@define TRITON_VERSION_MAJOR $TRITON_MAJOR -_ACEOF - - -cat >>confdefs.h <<_ACEOF -@%:@define TRITON_VERSION_MINOR $TRITON_MINOR -_ACEOF - - -cat >>confdefs.h <<_ACEOF -@%:@define TRITON_VERSION_SUB $TRITON_SUB -_ACEOF - - -ac_config_headers="$ac_config_headers triton-config.h" - -ac_aux_dir= -for ac_dir in maint/config "$srcdir"/maint/config; do - if test -f "$ac_dir/install-sh"; then - ac_aux_dir=$ac_dir - ac_install_sh="$ac_aux_dir/install-sh -c" - break - elif test -f "$ac_dir/install.sh"; then - ac_aux_dir=$ac_dir - ac_install_sh="$ac_aux_dir/install.sh -c" - break - elif test -f "$ac_dir/shtool"; then - ac_aux_dir=$ac_dir - ac_install_sh="$ac_aux_dir/shtool install -c" - break - fi -done -if test -z "$ac_aux_dir"; then - { { echo "$as_me:$LINENO: error: cannot find install-sh or install.sh in maint/config \"$srcdir\"/maint/config" >&5 -echo "$as_me: error: cannot find install-sh or install.sh in maint/config \"$srcdir\"/maint/config" >&2;} - { (exit 1); exit 1; }; } -fi - -# These three variables are undocumented and unsupported, -# and are intended to be withdrawn in a future Autoconf release. -# They can cause serious problems if a builder's source tree is in a directory -# whose full name contains unusual characters. -ac_config_guess="$SHELL $ac_aux_dir/config.guess" # Please don't use this var. -ac_config_sub="$SHELL $ac_aux_dir/config.sub" # Please don't use this var. -ac_configure="$SHELL $ac_aux_dir/configure" # Please don't use this var. - - - -# Find a good install program. We prefer a C program (faster), -# so one script is as good as another. But avoid the broken or -# incompatible versions: -# SysV /etc/install, /usr/sbin/install -# SunOS /usr/etc/install -# IRIX /sbin/install -# AIX /bin/install -# AmigaOS /C/install, which installs bootblocks on floppy discs -# AIX 4 /usr/bin/installbsd, which doesn't work without a -g flag -# AFS /usr/afsws/bin/install, which mishandles nonexistent args -# SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff" -# OS/2's system install, which has a completely different semantic -# ./install, which can be erroneously created by make from ./install.sh. -{ echo "$as_me:$LINENO: checking for a BSD-compatible install" >&5 -echo $ECHO_N "checking for a BSD-compatible install... $ECHO_C" >&6; } -if test -z "$INSTALL"; then -if test "${ac_cv_path_install+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - as_save_IFS=$IFS; IFS=$PATH_SEPARATOR -for as_dir in $PATH -do - IFS=$as_save_IFS - test -z "$as_dir" && as_dir=. - # Account for people who put trailing slashes in PATH elements. -case $as_dir/ in - ./ | .// | /cC/* | \ - /etc/* | /usr/sbin/* | /usr/etc/* | /sbin/* | /usr/afsws/bin/* | \ - ?:\\/os2\\/install\\/* | ?:\\/OS2\\/INSTALL\\/* | \ - /usr/ucb/* ) ;; - *) - # OSF1 and SCO ODT 3.0 have their own names for install. - # Don't use installbsd from OSF since it installs stuff as root - # by default. - for ac_prog in ginstall scoinst install; do - for ac_exec_ext in '' $ac_executable_extensions; do - if { test -f "$as_dir/$ac_prog$ac_exec_ext" && $as_test_x "$as_dir/$ac_prog$ac_exec_ext"; }; then - if test $ac_prog = install && - grep dspmsg "$as_dir/$ac_prog$ac_exec_ext" >/dev/null 2>&1; then - # AIX install. It has an incompatible calling convention. - : - elif test $ac_prog = install && - grep pwplus "$as_dir/$ac_prog$ac_exec_ext" >/dev/null 2>&1; then - # program-specific install script used by HP pwplus--don't use. - : - else - ac_cv_path_install="$as_dir/$ac_prog$ac_exec_ext -c" - break 3 - fi - fi - done - done - ;; -esac -done -IFS=$as_save_IFS - - -fi - if test "${ac_cv_path_install+set}" = set; then - INSTALL=$ac_cv_path_install - else - # As a last resort, use the slow shell script. Don't cache a - # value for INSTALL within a source directory, because that will - # break other packages using the cache if that directory is - # removed, or if the value is a relative name. - INSTALL=$ac_install_sh - fi -fi -{ echo "$as_me:$LINENO: result: $INSTALL" >&5 -echo "${ECHO_T}$INSTALL" >&6; } - -# Use test -z because SunOS4 sh mishandles braces in ${var-val}. -# It thinks the first close brace ends the variable substitution. -test -z "$INSTALL_PROGRAM" && INSTALL_PROGRAM='${INSTALL}' - -test -z "$INSTALL_SCRIPT" && INSTALL_SCRIPT='${INSTALL}' - -test -z "$INSTALL_DATA" && INSTALL_DATA='${INSTALL} -m 644' - -ac_ext=c -ac_cpp='$CPP $CPPFLAGS' -ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5' -ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5' -ac_compiler_gnu=$ac_cv_c_compiler_gnu -if test -n "$ac_tool_prefix"; then - # Extract the first word of "${ac_tool_prefix}gcc", so it can be a program name with args. -set dummy ${ac_tool_prefix}gcc; ac_word=$2 -{ echo "$as_me:$LINENO: checking for $ac_word" >&5 -echo $ECHO_N "checking for $ac_word... $ECHO_C" >&6; } -if test "${ac_cv_prog_CC+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - if test -n "$CC"; then - ac_cv_prog_CC="$CC" # Let the user override the test. -else -as_save_IFS=$IFS; IFS=$PATH_SEPARATOR -for as_dir in $PATH -do - IFS=$as_save_IFS - test -z "$as_dir" && as_dir=. - for ac_exec_ext in '' $ac_executable_extensions; do - if { test -f "$as_dir/$ac_word$ac_exec_ext" && $as_test_x "$as_dir/$ac_word$ac_exec_ext"; }; then - ac_cv_prog_CC="${ac_tool_prefix}gcc" - echo "$as_me:$LINENO: found $as_dir/$ac_word$ac_exec_ext" >&5 - break 2 - fi -done -done -IFS=$as_save_IFS - -fi -fi -CC=$ac_cv_prog_CC -if test -n "$CC"; then - { echo "$as_me:$LINENO: result: $CC" >&5 -echo "${ECHO_T}$CC" >&6; } -else - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } -fi - - -fi -if test -z "$ac_cv_prog_CC"; then - ac_ct_CC=$CC - # Extract the first word of "gcc", so it can be a program name with args. -set dummy gcc; ac_word=$2 -{ echo "$as_me:$LINENO: checking for $ac_word" >&5 -echo $ECHO_N "checking for $ac_word... $ECHO_C" >&6; } -if test "${ac_cv_prog_ac_ct_CC+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - if test -n "$ac_ct_CC"; then - ac_cv_prog_ac_ct_CC="$ac_ct_CC" # Let the user override the test. -else -as_save_IFS=$IFS; IFS=$PATH_SEPARATOR -for as_dir in $PATH -do - IFS=$as_save_IFS - test -z "$as_dir" && as_dir=. - for ac_exec_ext in '' $ac_executable_extensions; do - if { test -f "$as_dir/$ac_word$ac_exec_ext" && $as_test_x "$as_dir/$ac_word$ac_exec_ext"; }; then - ac_cv_prog_ac_ct_CC="gcc" - echo "$as_me:$LINENO: found $as_dir/$ac_word$ac_exec_ext" >&5 - break 2 - fi -done -done -IFS=$as_save_IFS - -fi -fi -ac_ct_CC=$ac_cv_prog_ac_ct_CC -if test -n "$ac_ct_CC"; then - { echo "$as_me:$LINENO: result: $ac_ct_CC" >&5 -echo "${ECHO_T}$ac_ct_CC" >&6; } -else - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } -fi - - if test "x$ac_ct_CC" = x; then - CC="" - else - case $cross_compiling:$ac_tool_warned in -yes:) -{ echo "$as_me:$LINENO: WARNING: In the future, Autoconf will not detect cross-tools -whose name does not start with the host triplet. If you think this -configuration is useful to you, please write to [email protected]." >&5 -echo "$as_me: WARNING: In the future, Autoconf will not detect cross-tools -whose name does not start with the host triplet. If you think this -configuration is useful to you, please write to [email protected]." >&2;} -ac_tool_warned=yes ;; -esac - CC=$ac_ct_CC - fi -else - CC="$ac_cv_prog_CC" -fi - -if test -z "$CC"; then - if test -n "$ac_tool_prefix"; then - # Extract the first word of "${ac_tool_prefix}cc", so it can be a program name with args. -set dummy ${ac_tool_prefix}cc; ac_word=$2 -{ echo "$as_me:$LINENO: checking for $ac_word" >&5 -echo $ECHO_N "checking for $ac_word... $ECHO_C" >&6; } -if test "${ac_cv_prog_CC+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - if test -n "$CC"; then - ac_cv_prog_CC="$CC" # Let the user override the test. -else -as_save_IFS=$IFS; IFS=$PATH_SEPARATOR -for as_dir in $PATH -do - IFS=$as_save_IFS - test -z "$as_dir" && as_dir=. - for ac_exec_ext in '' $ac_executable_extensions; do - if { test -f "$as_dir/$ac_word$ac_exec_ext" && $as_test_x "$as_dir/$ac_word$ac_exec_ext"; }; then - ac_cv_prog_CC="${ac_tool_prefix}cc" - echo "$as_me:$LINENO: found $as_dir/$ac_word$ac_exec_ext" >&5 - break 2 - fi -done -done -IFS=$as_save_IFS - -fi -fi -CC=$ac_cv_prog_CC -if test -n "$CC"; then - { echo "$as_me:$LINENO: result: $CC" >&5 -echo "${ECHO_T}$CC" >&6; } -else - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } -fi - - - fi -fi -if test -z "$CC"; then - # Extract the first word of "cc", so it can be a program name with args. -set dummy cc; ac_word=$2 -{ echo "$as_me:$LINENO: checking for $ac_word" >&5 -echo $ECHO_N "checking for $ac_word... $ECHO_C" >&6; } -if test "${ac_cv_prog_CC+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - if test -n "$CC"; then - ac_cv_prog_CC="$CC" # Let the user override the test. -else - ac_prog_rejected=no -as_save_IFS=$IFS; IFS=$PATH_SEPARATOR -for as_dir in $PATH -do - IFS=$as_save_IFS - test -z "$as_dir" && as_dir=. - for ac_exec_ext in '' $ac_executable_extensions; do - if { test -f "$as_dir/$ac_word$ac_exec_ext" && $as_test_x "$as_dir/$ac_word$ac_exec_ext"; }; then - if test "$as_dir/$ac_word$ac_exec_ext" = "/usr/ucb/cc"; then - ac_prog_rejected=yes - continue - fi - ac_cv_prog_CC="cc" - echo "$as_me:$LINENO: found $as_dir/$ac_word$ac_exec_ext" >&5 - break 2 - fi -done -done -IFS=$as_save_IFS - -if test $ac_prog_rejected = yes; then - # We found a bogon in the path, so make sure we never use it. - set dummy $ac_cv_prog_CC - shift - if test $@%:@ != 0; then - # We chose a different compiler from the bogus one. - # However, it has the same basename, so the bogon will be chosen - # first if we set CC to just the basename; use the full file name. - shift - ac_cv_prog_CC="$as_dir/$ac_word${1+' '}$@" - fi -fi -fi -fi -CC=$ac_cv_prog_CC -if test -n "$CC"; then - { echo "$as_me:$LINENO: result: $CC" >&5 -echo "${ECHO_T}$CC" >&6; } -else - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } -fi - - -fi -if test -z "$CC"; then - if test -n "$ac_tool_prefix"; then - for ac_prog in cl.exe - do - # Extract the first word of "$ac_tool_prefix$ac_prog", so it can be a program name with args. -set dummy $ac_tool_prefix$ac_prog; ac_word=$2 -{ echo "$as_me:$LINENO: checking for $ac_word" >&5 -echo $ECHO_N "checking for $ac_word... $ECHO_C" >&6; } -if test "${ac_cv_prog_CC+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - if test -n "$CC"; then - ac_cv_prog_CC="$CC" # Let the user override the test. -else -as_save_IFS=$IFS; IFS=$PATH_SEPARATOR -for as_dir in $PATH -do - IFS=$as_save_IFS - test -z "$as_dir" && as_dir=. - for ac_exec_ext in '' $ac_executable_extensions; do - if { test -f "$as_dir/$ac_word$ac_exec_ext" && $as_test_x "$as_dir/$ac_word$ac_exec_ext"; }; then - ac_cv_prog_CC="$ac_tool_prefix$ac_prog" - echo "$as_me:$LINENO: found $as_dir/$ac_word$ac_exec_ext" >&5 - break 2 - fi -done -done -IFS=$as_save_IFS - -fi -fi -CC=$ac_cv_prog_CC -if test -n "$CC"; then - { echo "$as_me:$LINENO: result: $CC" >&5 -echo "${ECHO_T}$CC" >&6; } -else - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } -fi - - - test -n "$CC" && break - done -fi -if test -z "$CC"; then - ac_ct_CC=$CC - for ac_prog in cl.exe -do - # Extract the first word of "$ac_prog", so it can be a program name with args. -set dummy $ac_prog; ac_word=$2 -{ echo "$as_me:$LINENO: checking for $ac_word" >&5 -echo $ECHO_N "checking for $ac_word... $ECHO_C" >&6; } -if test "${ac_cv_prog_ac_ct_CC+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - if test -n "$ac_ct_CC"; then - ac_cv_prog_ac_ct_CC="$ac_ct_CC" # Let the user override the test. -else -as_save_IFS=$IFS; IFS=$PATH_SEPARATOR -for as_dir in $PATH -do - IFS=$as_save_IFS - test -z "$as_dir" && as_dir=. - for ac_exec_ext in '' $ac_executable_extensions; do - if { test -f "$as_dir/$ac_word$ac_exec_ext" && $as_test_x "$as_dir/$ac_word$ac_exec_ext"; }; then - ac_cv_prog_ac_ct_CC="$ac_prog" - echo "$as_me:$LINENO: found $as_dir/$ac_word$ac_exec_ext" >&5 - break 2 - fi -done -done -IFS=$as_save_IFS - -fi -fi -ac_ct_CC=$ac_cv_prog_ac_ct_CC -if test -n "$ac_ct_CC"; then - { echo "$as_me:$LINENO: result: $ac_ct_CC" >&5 -echo "${ECHO_T}$ac_ct_CC" >&6; } -else - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } -fi - - - test -n "$ac_ct_CC" && break -done - - if test "x$ac_ct_CC" = x; then - CC="" - else - case $cross_compiling:$ac_tool_warned in -yes:) -{ echo "$as_me:$LINENO: WARNING: In the future, Autoconf will not detect cross-tools -whose name does not start with the host triplet. If you think this -configuration is useful to you, please write to [email protected]." >&5 -echo "$as_me: WARNING: In the future, Autoconf will not detect cross-tools -whose name does not start with the host triplet. If you think this -configuration is useful to you, please write to [email protected]." >&2;} -ac_tool_warned=yes ;; -esac - CC=$ac_ct_CC - fi -fi - -fi - - -test -z "$CC" && { { echo "$as_me:$LINENO: error: no acceptable C compiler found in \$PATH -See \`config.log' for more details." >&5 -echo "$as_me: error: no acceptable C compiler found in \$PATH -See \`config.log' for more details." >&2;} - { (exit 1); exit 1; }; } - -# Provide some information about the compiler. -echo "$as_me:$LINENO: checking for C compiler version" >&5 -ac_compiler=`set X $ac_compile; echo $2` -{ (ac_try="$ac_compiler --version >&5" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compiler --version >&5") 2>&5 - ac_status=$? - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } -{ (ac_try="$ac_compiler -v >&5" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compiler -v >&5") 2>&5 - ac_status=$? - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } -{ (ac_try="$ac_compiler -V >&5" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compiler -V >&5") 2>&5 - ac_status=$? - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } - -cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - -int -main () -{ - - ; - return 0; -} -_ACEOF -ac_clean_files_save=$ac_clean_files -ac_clean_files="$ac_clean_files a.out a.exe b.out" -# Try to create an executable without -o first, disregard a.out. -# It will help us diagnose broken compilers, and finding out an intuition -# of exeext. -{ echo "$as_me:$LINENO: checking for C compiler default output file name" >&5 -echo $ECHO_N "checking for C compiler default output file name... $ECHO_C" >&6; } -ac_link_default=`echo "$ac_link" | sed 's/ -o *conftest[^ ]*//'` -# -# List of possible output files, starting from the most likely. -# The algorithm is not robust to junk in `.', hence go to wildcards (a.*) -# only as a last resort. b.out is created by i960 compilers. -ac_files='a_out.exe a.exe conftest.exe a.out conftest a.* conftest.* b.out' -# -# The IRIX 6 linker writes into existing files which may not be -# executable, retaining their permissions. Remove them first so a -# subsequent execution test works. -ac_rmfiles= -for ac_file in $ac_files -do - case $ac_file in - *.$ac_ext | *.xcoff | *.tds | *.d | *.pdb | *.xSYM | *.bb | *.bbg | *.map | *.inf | *.o | *.obj ) ;; - * ) ac_rmfiles="$ac_rmfiles $ac_file";; - esac -done -rm -f $ac_rmfiles - -if { (ac_try="$ac_link_default" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_link_default") 2>&5 - ac_status=$? - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); }; then - # Autoconf-2.13 could set the ac_cv_exeext variable to `no'. -# So ignore a value of `no', otherwise this would lead to `EXEEXT = no' -# in a Makefile. We should not override ac_cv_exeext if it was cached, -# so that the user can short-circuit this test for compilers unknown to -# Autoconf. -for ac_file in $ac_files '' -do - test -f "$ac_file" || continue - case $ac_file in - *.$ac_ext | *.xcoff | *.tds | *.d | *.pdb | *.xSYM | *.bb | *.bbg | *.map | *.inf | *.o | *.obj ) - ;; - [ab].out ) - # We found the default executable, but exeext='' is most - # certainly right. - break;; - *.* ) - if test "${ac_cv_exeext+set}" = set && test "$ac_cv_exeext" != no; - then :; else - ac_cv_exeext=`expr "$ac_file" : '[^.]*\(\..*\)'` - fi - # We set ac_cv_exeext here because the later test for it is not - # safe: cross compilers may not add the suffix if given an `-o' - # argument, so we may need to know it at that point already. - # Even if this section looks crufty: it has the advantage of - # actually working. - break;; - * ) - break;; - esac -done -test "$ac_cv_exeext" = no && ac_cv_exeext= - -else - ac_file='' -fi - -{ echo "$as_me:$LINENO: result: $ac_file" >&5 -echo "${ECHO_T}$ac_file" >&6; } -if test -z "$ac_file"; then - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - -{ { echo "$as_me:$LINENO: error: C compiler cannot create executables -See \`config.log' for more details." >&5 -echo "$as_me: error: C compiler cannot create executables -See \`config.log' for more details." >&2;} - { (exit 77); exit 77; }; } -fi - -ac_exeext=$ac_cv_exeext - -# Check that the compiler produces executables we can run. If not, either -# the compiler is broken, or we cross compile. -{ echo "$as_me:$LINENO: checking whether the C compiler works" >&5 -echo $ECHO_N "checking whether the C compiler works... $ECHO_C" >&6; } -# FIXME: These cross compiler hacks should be removed for Autoconf 3.0 -# If not cross compiling, check that we can run a simple program. -if test "$cross_compiling" != yes; then - if { ac_try='./$ac_file' - { (case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_try") 2>&5 - ac_status=$? - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); }; }; then - cross_compiling=no - else - if test "$cross_compiling" = maybe; then - cross_compiling=yes - else - { { echo "$as_me:$LINENO: error: cannot run C compiled programs. -If you meant to cross compile, use \`--host'. -See \`config.log' for more details." >&5 -echo "$as_me: error: cannot run C compiled programs. -If you meant to cross compile, use \`--host'. -See \`config.log' for more details." >&2;} - { (exit 1); exit 1; }; } - fi - fi -fi -{ echo "$as_me:$LINENO: result: yes" >&5 -echo "${ECHO_T}yes" >&6; } - -rm -f a.out a.exe conftest$ac_cv_exeext b.out -ac_clean_files=$ac_clean_files_save -# Check that the compiler produces executables we can run. If not, either -# the compiler is broken, or we cross compile. -{ echo "$as_me:$LINENO: checking whether we are cross compiling" >&5 -echo $ECHO_N "checking whether we are cross compiling... $ECHO_C" >&6; } -{ echo "$as_me:$LINENO: result: $cross_compiling" >&5 -echo "${ECHO_T}$cross_compiling" >&6; } - -{ echo "$as_me:$LINENO: checking for suffix of executables" >&5 -echo $ECHO_N "checking for suffix of executables... $ECHO_C" >&6; } -if { (ac_try="$ac_link" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_link") 2>&5 - ac_status=$? - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); }; then - # If both `conftest.exe' and `conftest' are `present' (well, observable) -# catch `conftest.exe'. For instance with Cygwin, `ls conftest' will -# work properly (i.e., refer to `conftest.exe'), while it won't with -# `rm'. -for ac_file in conftest.exe conftest conftest.*; do - test -f "$ac_file" || continue - case $ac_file in - *.$ac_ext | *.xcoff | *.tds | *.d | *.pdb | *.xSYM | *.bb | *.bbg | *.map | *.inf | *.o | *.obj ) ;; - *.* ) ac_cv_exeext=`expr "$ac_file" : '[^.]*\(\..*\)'` - break;; - * ) break;; - esac -done -else - { { echo "$as_me:$LINENO: error: cannot compute suffix of executables: cannot compile and link -See \`config.log' for more details." >&5 -echo "$as_me: error: cannot compute suffix of executables: cannot compile and link -See \`config.log' for more details." >&2;} - { (exit 1); exit 1; }; } -fi - -rm -f conftest$ac_cv_exeext -{ echo "$as_me:$LINENO: result: $ac_cv_exeext" >&5 -echo "${ECHO_T}$ac_cv_exeext" >&6; } - -rm -f conftest.$ac_ext -EXEEXT=$ac_cv_exeext -ac_exeext=$EXEEXT -{ echo "$as_me:$LINENO: checking for suffix of object files" >&5 -echo $ECHO_N "checking for suffix of object files... $ECHO_C" >&6; } -if test "${ac_cv_objext+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - -int -main () -{ - - ; - return 0; -} -_ACEOF -rm -f conftest.o conftest.obj -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>&5 - ac_status=$? - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); }; then - for ac_file in conftest.o conftest.obj conftest.*; do - test -f "$ac_file" || continue; - case $ac_file in - *.$ac_ext | *.xcoff | *.tds | *.d | *.pdb | *.xSYM | *.bb | *.bbg | *.map | *.inf ) ;; - *) ac_cv_objext=`expr "$ac_file" : '.*\.\(.*\)'` - break;; - esac -done -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - -{ { echo "$as_me:$LINENO: error: cannot compute suffix of object files: cannot compile -See \`config.log' for more details." >&5 -echo "$as_me: error: cannot compute suffix of object files: cannot compile -See \`config.log' for more details." >&2;} - { (exit 1); exit 1; }; } -fi - -rm -f conftest.$ac_cv_objext conftest.$ac_ext -fi -{ echo "$as_me:$LINENO: result: $ac_cv_objext" >&5 -echo "${ECHO_T}$ac_cv_objext" >&6; } -OBJEXT=$ac_cv_objext -ac_objext=$OBJEXT -{ echo "$as_me:$LINENO: checking whether we are using the GNU C compiler" >&5 -echo $ECHO_N "checking whether we are using the GNU C compiler... $ECHO_C" >&6; } -if test "${ac_cv_c_compiler_gnu+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - -int -main () -{ -#ifndef __GNUC__ - choke me -#endif - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - ac_compiler_gnu=yes -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - ac_compiler_gnu=no -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext -ac_cv_c_compiler_gnu=$ac_compiler_gnu - -fi -{ echo "$as_me:$LINENO: result: $ac_cv_c_compiler_gnu" >&5 -echo "${ECHO_T}$ac_cv_c_compiler_gnu" >&6; } -GCC=`test $ac_compiler_gnu = yes && echo yes` -ac_test_CFLAGS=${CFLAGS+set} -ac_save_CFLAGS=$CFLAGS -{ echo "$as_me:$LINENO: checking whether $CC accepts -g" >&5 -echo $ECHO_N "checking whether $CC accepts -g... $ECHO_C" >&6; } -if test "${ac_cv_prog_cc_g+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - ac_save_c_werror_flag=$ac_c_werror_flag - ac_c_werror_flag=yes - ac_cv_prog_cc_g=no - CFLAGS="-g" - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - -int -main () -{ - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - ac_cv_prog_cc_g=yes -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - CFLAGS="" - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - -int -main () -{ - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - : -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - ac_c_werror_flag=$ac_save_c_werror_flag - CFLAGS="-g" - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - -int -main () -{ - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - ac_cv_prog_cc_g=yes -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - ac_c_werror_flag=$ac_save_c_werror_flag -fi -{ echo "$as_me:$LINENO: result: $ac_cv_prog_cc_g" >&5 -echo "${ECHO_T}$ac_cv_prog_cc_g" >&6; } -if test "$ac_test_CFLAGS" = set; then - CFLAGS=$ac_save_CFLAGS -elif test $ac_cv_prog_cc_g = yes; then - if test "$GCC" = yes; then - CFLAGS="-g -O2" - else - CFLAGS="-g" - fi -else - if test "$GCC" = yes; then - CFLAGS="-O2" - else - CFLAGS= - fi -fi -{ echo "$as_me:$LINENO: checking for $CC option to accept ISO C89" >&5 -echo $ECHO_N "checking for $CC option to accept ISO C89... $ECHO_C" >&6; } -if test "${ac_cv_prog_cc_c89+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - ac_cv_prog_cc_c89=no -ac_save_CC=$CC -cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -#include <stdarg.h> -#include <stdio.h> -#include <sys/types.h> -#include <sys/stat.h> -/* Most of the following tests are stolen from RCS 5.7's src/conf.sh. */ -struct buf { int x; }; -FILE * (*rcsopen) (struct buf *, struct stat *, int); -static char *e (p, i) - char **p; - int i; -{ - return p[i]; -} -static char *f (char * (*g) (char **, int), char **p, ...) -{ - char *s; - va_list v; - va_start (v,p); - s = g (p, va_arg (v,int)); - va_end (v); - return s; -} - -/* OSF 4.0 Compaq cc is some sort of almost-ANSI by default. It has - function prototypes and stuff, but not '\xHH' hex character constants. - These don't provoke an error unfortunately, instead are silently treated - as 'x'. The following induces an error, until -std is added to get - proper ANSI mode. Curiously '\x00'!='x' always comes out true, for an - array size at least. It's necessary to write '\x00'==0 to get something - that's true only with -std. */ -int osf4_cc_array ['\x00' == 0 ? 1 : -1]; - -/* IBM C 6 for AIX is almost-ANSI by default, but it replaces macro parameters - inside strings and character constants. */ -#define FOO(x) 'x' -int xlc6_cc_array[FOO(a) == 'x' ? 1 : -1]; - -int test (int i, double x); -struct s1 {int (*f) (int a);}; -struct s2 {int (*f) (double a);}; -int pairnames (int, char **, FILE *(*)(struct buf *, struct stat *, int), int, int); -int argc; -char **argv; -int -main () -{ -return f (e, argv, 0) != argv[0] || f (e, argv, 1) != argv[1]; - ; - return 0; -} -_ACEOF -for ac_arg in '' -qlanglvl=extc89 -qlanglvl=ansi -std \ - -Ae "-Aa -D_HPUX_SOURCE" "-Xc -D__EXTENSIONS__" -do - CC="$ac_save_CC $ac_arg" - rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - ac_cv_prog_cc_c89=$ac_arg -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - -fi - -rm -f core conftest.err conftest.$ac_objext - test "x$ac_cv_prog_cc_c89" != "xno" && break -done -rm -f conftest.$ac_ext -CC=$ac_save_CC - -fi -# AC_CACHE_VAL -case "x$ac_cv_prog_cc_c89" in - x) - { echo "$as_me:$LINENO: result: none needed" >&5 -echo "${ECHO_T}none needed" >&6; } ;; - xno) - { echo "$as_me:$LINENO: result: unsupported" >&5 -echo "${ECHO_T}unsupported" >&6; } ;; - *) - CC="$CC $ac_cv_prog_cc_c89" - { echo "$as_me:$LINENO: result: $ac_cv_prog_cc_c89" >&5 -echo "${ECHO_T}$ac_cv_prog_cc_c89" >&6; } ;; -esac - - -ac_ext=c -ac_cpp='$CPP $CPPFLAGS' -ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5' -ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5' -ac_compiler_gnu=$ac_cv_c_compiler_gnu - -ac_ext=c -ac_cpp='$CPP $CPPFLAGS' -ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5' -ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5' -ac_compiler_gnu=$ac_cv_c_compiler_gnu -{ echo "$as_me:$LINENO: checking how to run the C preprocessor" >&5 -echo $ECHO_N "checking how to run the C preprocessor... $ECHO_C" >&6; } -# On Suns, sometimes $CPP names a directory. -if test -n "$CPP" && test -d "$CPP"; then - CPP= -fi -if test -z "$CPP"; then - if test "${ac_cv_prog_CPP+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - # Double quotes because CPP needs to be expanded - for CPP in "$CC -E" "$CC -E -traditional-cpp" "/lib/cpp" - do - ac_preproc_ok=false -for ac_c_preproc_warn_flag in '' yes -do - # Use a header file that comes with gcc, so configuring glibc - # with a fresh cross-compiler works. - # Prefer <limits.h> to <assert.h> if __STDC__ is defined, since - # <limits.h> exists even on freestanding compilers. - # On the NeXT, cc -E runs the code through the compiler's parser, - # not just through cpp. "Syntax error" is here to catch this case. - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -@%:@ifdef __STDC__ -@%:@ include <limits.h> -@%:@else -@%:@ include <assert.h> -@%:@endif - Syntax error -_ACEOF -if { (ac_try="$ac_cpp conftest.$ac_ext" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_cpp conftest.$ac_ext") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } >/dev/null && { - test -z "$ac_c_preproc_warn_flag$ac_c_werror_flag" || - test ! -s conftest.err - }; then - : -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - # Broken: fails on valid input. -continue -fi - -rm -f conftest.err conftest.$ac_ext - - # OK, works on sane cases. Now check whether nonexistent headers - # can be detected and how. - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -@%:@include <ac_nonexistent.h> -_ACEOF -if { (ac_try="$ac_cpp conftest.$ac_ext" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_cpp conftest.$ac_ext") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } >/dev/null && { - test -z "$ac_c_preproc_warn_flag$ac_c_werror_flag" || - test ! -s conftest.err - }; then - # Broken: success on invalid input. -continue -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - # Passes both tests. -ac_preproc_ok=: -break -fi - -rm -f conftest.err conftest.$ac_ext - -done -# Because of `break', _AC_PREPROC_IFELSE's cleaning code was skipped. -rm -f conftest.err conftest.$ac_ext -if $ac_preproc_ok; then - break -fi - - done - ac_cv_prog_CPP=$CPP - -fi - CPP=$ac_cv_prog_CPP -else - ac_cv_prog_CPP=$CPP -fi -{ echo "$as_me:$LINENO: result: $CPP" >&5 -echo "${ECHO_T}$CPP" >&6; } -ac_preproc_ok=false -for ac_c_preproc_warn_flag in '' yes -do - # Use a header file that comes with gcc, so configuring glibc - # with a fresh cross-compiler works. - # Prefer <limits.h> to <assert.h> if __STDC__ is defined, since - # <limits.h> exists even on freestanding compilers. - # On the NeXT, cc -E runs the code through the compiler's parser, - # not just through cpp. "Syntax error" is here to catch this case. - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -@%:@ifdef __STDC__ -@%:@ include <limits.h> -@%:@else -@%:@ include <assert.h> -@%:@endif - Syntax error -_ACEOF -if { (ac_try="$ac_cpp conftest.$ac_ext" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_cpp conftest.$ac_ext") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } >/dev/null && { - test -z "$ac_c_preproc_warn_flag$ac_c_werror_flag" || - test ! -s conftest.err - }; then - : -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - # Broken: fails on valid input. -continue -fi - -rm -f conftest.err conftest.$ac_ext - - # OK, works on sane cases. Now check whether nonexistent headers - # can be detected and how. - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -@%:@include <ac_nonexistent.h> -_ACEOF -if { (ac_try="$ac_cpp conftest.$ac_ext" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_cpp conftest.$ac_ext") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } >/dev/null && { - test -z "$ac_c_preproc_warn_flag$ac_c_werror_flag" || - test ! -s conftest.err - }; then - # Broken: success on invalid input. -continue -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - # Passes both tests. -ac_preproc_ok=: -break -fi - -rm -f conftest.err conftest.$ac_ext - -done -# Because of `break', _AC_PREPROC_IFELSE's cleaning code was skipped. -rm -f conftest.err conftest.$ac_ext -if $ac_preproc_ok; then - : -else - { { echo "$as_me:$LINENO: error: C preprocessor \"$CPP\" fails sanity check -See \`config.log' for more details." >&5 -echo "$as_me: error: C preprocessor \"$CPP\" fails sanity check -See \`config.log' for more details." >&2;} - { (exit 1); exit 1; }; } -fi - -ac_ext=c -ac_cpp='$CPP $CPPFLAGS' -ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5' -ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5' -ac_compiler_gnu=$ac_cv_c_compiler_gnu - - - - -{ echo "$as_me:$LINENO: checking for grep that handles long lines and -e" >&5 -echo $ECHO_N "checking for grep that handles long lines and -e... $ECHO_C" >&6; } -if test "${ac_cv_path_GREP+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - # Extract the first word of "grep ggrep" to use in msg output -if test -z "$GREP"; then -set dummy grep ggrep; ac_prog_name=$2 -if test "${ac_cv_path_GREP+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - ac_path_GREP_found=false -# Loop through the user's path and test for each of PROGNAME-LIST -as_save_IFS=$IFS; IFS=$PATH_SEPARATOR -for as_dir in $PATH$PATH_SEPARATOR/usr/xpg4/bin -do - IFS=$as_save_IFS - test -z "$as_dir" && as_dir=. - for ac_prog in grep ggrep; do - for ac_exec_ext in '' $ac_executable_extensions; do - ac_path_GREP="$as_dir/$ac_prog$ac_exec_ext" - { test -f "$ac_path_GREP" && $as_test_x "$ac_path_GREP"; } || continue - # Check for GNU ac_path_GREP and select it if it is found. - # Check for GNU $ac_path_GREP -case `"$ac_path_GREP" --version 2>&1` in -*GNU*) - ac_cv_path_GREP="$ac_path_GREP" ac_path_GREP_found=:;; -*) - ac_count=0 - echo $ECHO_N "0123456789$ECHO_C" >"conftest.in" - while : - do - cat "conftest.in" "conftest.in" >"conftest.tmp" - mv "conftest.tmp" "conftest.in" - cp "conftest.in" "conftest.nl" - echo 'GREP' >> "conftest.nl" - "$ac_path_GREP" -e 'GREP$' -e '-(cannot match)-' < "conftest.nl" >"conftest.out" 2>/dev/null || break - diff "conftest.out" "conftest.nl" >/dev/null 2>&1 || break - ac_count=`expr $ac_count + 1` - if test $ac_count -gt ${ac_path_GREP_max-0}; then - # Best one so far, save it but keep looking for a better one - ac_cv_path_GREP="$ac_path_GREP" - ac_path_GREP_max=$ac_count - fi - # 10*(2^10) chars as input seems more than enough - test $ac_count -gt 10 && break - done - rm -f conftest.in conftest.tmp conftest.nl conftest.out;; -esac - - - $ac_path_GREP_found && break 3 - done -done - -done -IFS=$as_save_IFS - - -fi - -GREP="$ac_cv_path_GREP" -if test -z "$GREP"; then - { { echo "$as_me:$LINENO: error: no acceptable $ac_prog_name could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" >&5 -echo "$as_me: error: no acceptable $ac_prog_name could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" >&2;} - { (exit 1); exit 1; }; } -fi - -else - ac_cv_path_GREP=$GREP -fi - - -fi -{ echo "$as_me:$LINENO: result: $ac_cv_path_GREP" >&5 -echo "${ECHO_T}$ac_cv_path_GREP" >&6; } - GREP="$ac_cv_path_GREP" - - -{ echo "$as_me:$LINENO: checking for egrep" >&5 -echo $ECHO_N "checking for egrep... $ECHO_C" >&6; } -if test "${ac_cv_path_EGREP+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - if echo a | $GREP -E '(a|b)' >/dev/null 2>&1 - then ac_cv_path_EGREP="$GREP -E" - else - # Extract the first word of "egrep" to use in msg output -if test -z "$EGREP"; then -set dummy egrep; ac_prog_name=$2 -if test "${ac_cv_path_EGREP+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - ac_path_EGREP_found=false -# Loop through the user's path and test for each of PROGNAME-LIST -as_save_IFS=$IFS; IFS=$PATH_SEPARATOR -for as_dir in $PATH$PATH_SEPARATOR/usr/xpg4/bin -do - IFS=$as_save_IFS - test -z "$as_dir" && as_dir=. - for ac_prog in egrep; do - for ac_exec_ext in '' $ac_executable_extensions; do - ac_path_EGREP="$as_dir/$ac_prog$ac_exec_ext" - { test -f "$ac_path_EGREP" && $as_test_x "$ac_path_EGREP"; } || continue - # Check for GNU ac_path_EGREP and select it if it is found. - # Check for GNU $ac_path_EGREP -case `"$ac_path_EGREP" --version 2>&1` in -*GNU*) - ac_cv_path_EGREP="$ac_path_EGREP" ac_path_EGREP_found=:;; -*) - ac_count=0 - echo $ECHO_N "0123456789$ECHO_C" >"conftest.in" - while : - do - cat "conftest.in" "conftest.in" >"conftest.tmp" - mv "conftest.tmp" "conftest.in" - cp "conftest.in" "conftest.nl" - echo 'EGREP' >> "conftest.nl" - "$ac_path_EGREP" 'EGREP$' < "conftest.nl" >"conftest.out" 2>/dev/null || break - diff "conftest.out" "conftest.nl" >/dev/null 2>&1 || break - ac_count=`expr $ac_count + 1` - if test $ac_count -gt ${ac_path_EGREP_max-0}; then - # Best one so far, save it but keep looking for a better one - ac_cv_path_EGREP="$ac_path_EGREP" - ac_path_EGREP_max=$ac_count - fi - # 10*(2^10) chars as input seems more than enough - test $ac_count -gt 10 && break - done - rm -f conftest.in conftest.tmp conftest.nl conftest.out;; -esac - - - $ac_path_EGREP_found && break 3 - done -done - -done -IFS=$as_save_IFS - - -fi - -EGREP="$ac_cv_path_EGREP" -if test -z "$EGREP"; then - { { echo "$as_me:$LINENO: error: no acceptable $ac_prog_name could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" >&5 -echo "$as_me: error: no acceptable $ac_prog_name could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" >&2;} - { (exit 1); exit 1; }; } -fi - -else - ac_cv_path_EGREP=$EGREP -fi - - - fi -fi -{ echo "$as_me:$LINENO: result: $ac_cv_path_EGREP" >&5 -echo "${ECHO_T}$ac_cv_path_EGREP" >&6; } - EGREP="$ac_cv_path_EGREP" - - -{ echo "$as_me:$LINENO: checking for ANSI C header files" >&5 -echo $ECHO_N "checking for ANSI C header files... $ECHO_C" >&6; } -if test "${ac_cv_header_stdc+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -#include <stdlib.h> -#include <stdarg.h> -#include <string.h> -#include <float.h> - -int -main () -{ - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - ac_cv_header_stdc=yes -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - ac_cv_header_stdc=no -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - -if test $ac_cv_header_stdc = yes; then - # SunOS 4.x string.h does not declare mem*, contrary to ANSI. - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -#include <string.h> - -_ACEOF -if (eval "$ac_cpp conftest.$ac_ext") 2>&5 | - $EGREP "memchr" >/dev/null 2>&1; then - : -else - ac_cv_header_stdc=no -fi -rm -f conftest* - -fi - -if test $ac_cv_header_stdc = yes; then - # ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI. - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -#include <stdlib.h> - -_ACEOF -if (eval "$ac_cpp conftest.$ac_ext") 2>&5 | - $EGREP "free" >/dev/null 2>&1; then - : -else - ac_cv_header_stdc=no -fi -rm -f conftest* - -fi - -if test $ac_cv_header_stdc = yes; then - # /bin/cc in Irix-4.0.5 gets non-ANSI ctype macros unless using -ansi. - if test "$cross_compiling" = yes; then - : -else - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -#include <ctype.h> -#include <stdlib.h> -#if ((' ' & 0x0FF) == 0x020) -# define ISLOWER(c) ('a' <= (c) && (c) <= 'z') -# define TOUPPER(c) (ISLOWER(c) ? 'A' + ((c) - 'a') : (c)) -#else -# define ISLOWER(c) \ - (('a' <= (c) && (c) <= 'i') \ - || ('j' <= (c) && (c) <= 'r') \ - || ('s' <= (c) && (c) <= 'z')) -# define TOUPPER(c) (ISLOWER(c) ? ((c) | 0x40) : (c)) -#endif - -#define XOR(e, f) (((e) && !(f)) || (!(e) && (f))) -int -main () -{ - int i; - for (i = 0; i < 256; i++) - if (XOR (islower (i), ISLOWER (i)) - || toupper (i) != TOUPPER (i)) - return 2; - return 0; -} -_ACEOF -rm -f conftest$ac_exeext -if { (ac_try="$ac_link" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_link") 2>&5 - ac_status=$? - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { ac_try='./conftest$ac_exeext' - { (case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_try") 2>&5 - ac_status=$? - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); }; }; then - : -else - echo "$as_me: program exited with status $ac_status" >&5 -echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - -( exit $ac_status ) -ac_cv_header_stdc=no -fi -rm -f core *.core core.conftest.* gmon.out bb.out conftest$ac_exeext conftest.$ac_objext conftest.$ac_ext -fi - - -fi -fi -{ echo "$as_me:$LINENO: result: $ac_cv_header_stdc" >&5 -echo "${ECHO_T}$ac_cv_header_stdc" >&6; } -if test $ac_cv_header_stdc = yes; then - -cat >>confdefs.h <<\_ACEOF -@%:@define STDC_HEADERS 1 -_ACEOF - -fi - -# On IRIX 5.3, sys/types and inttypes.h are conflicting. - - - - - - - - - -for ac_header in sys/types.h sys/stat.h stdlib.h string.h memory.h strings.h \ - inttypes.h stdint.h unistd.h -do -as_ac_Header=`echo "ac_cv_header_$ac_header" | $as_tr_sh` -{ echo "$as_me:$LINENO: checking for $ac_header" >&5 -echo $ECHO_N "checking for $ac_header... $ECHO_C" >&6; } -if { as_var=$as_ac_Header; eval "test \"\${$as_var+set}\" = set"; }; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -$ac_includes_default - -@%:@include <$ac_header> -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - eval "$as_ac_Header=yes" -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - eval "$as_ac_Header=no" -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext -fi -ac_res=`eval echo '${'$as_ac_Header'}'` - { echo "$as_me:$LINENO: result: $ac_res" >&5 -echo "${ECHO_T}$ac_res" >&6; } -if test `eval echo '${'$as_ac_Header'}'` = yes; then - cat >>confdefs.h <<_ACEOF -@%:@define `echo "HAVE_$ac_header" | $as_tr_cpp` 1 -_ACEOF - -fi - -done - - -{ echo "$as_me:$LINENO: checking whether byte ordering is bigendian" >&5 -echo $ECHO_N "checking whether byte ordering is bigendian... $ECHO_C" >&6; } -if test "${ac_cv_c_bigendian+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - # See if sys/param.h defines the BYTE_ORDER macro. -cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -#include <sys/types.h> -#include <sys/param.h> - -int -main () -{ -#if ! (defined BYTE_ORDER && defined BIG_ENDIAN && defined LITTLE_ENDIAN \ - && BYTE_ORDER && BIG_ENDIAN && LITTLE_ENDIAN) - bogus endian macros -#endif - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - # It does; now see whether it defined to BIG_ENDIAN or not. -cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -#include <sys/types.h> -#include <sys/param.h> - -int -main () -{ -#if BYTE_ORDER != BIG_ENDIAN - not big endian -#endif - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - ac_cv_c_bigendian=yes -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - ac_cv_c_bigendian=no -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - # It does not; compile a test program. -if test "$cross_compiling" = yes; then - # try to guess the endianness by grepping values into an object file - ac_cv_c_bigendian=unknown - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -short int ascii_mm[] = { 0x4249, 0x4765, 0x6E44, 0x6961, 0x6E53, 0x7953, 0 }; -short int ascii_ii[] = { 0x694C, 0x5454, 0x656C, 0x6E45, 0x6944, 0x6E61, 0 }; -void _ascii () { char *s = (char *) ascii_mm; s = (char *) ascii_ii; } -short int ebcdic_ii[] = { 0x89D3, 0xE3E3, 0x8593, 0x95C5, 0x89C4, 0x9581, 0 }; -short int ebcdic_mm[] = { 0xC2C9, 0xC785, 0x95C4, 0x8981, 0x95E2, 0xA8E2, 0 }; -void _ebcdic () { char *s = (char *) ebcdic_mm; s = (char *) ebcdic_ii; } -int -main () -{ - _ascii (); _ebcdic (); - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - if grep BIGenDianSyS conftest.$ac_objext >/dev/null ; then - ac_cv_c_bigendian=yes -fi -if grep LiTTleEnDian conftest.$ac_objext >/dev/null ; then - if test "$ac_cv_c_bigendian" = unknown; then - ac_cv_c_bigendian=no - else - # finding both strings is unlikely to happen, but who knows? - ac_cv_c_bigendian=unknown - fi -fi -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext -else - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -$ac_includes_default -int -main () -{ - - /* Are we little or big endian? From Harbison&Steele. */ - union - { - long int l; - char c[sizeof (long int)]; - } u; - u.l = 1; - return u.c[sizeof (long int) - 1] == 1; - - ; - return 0; -} -_ACEOF -rm -f conftest$ac_exeext -if { (ac_try="$ac_link" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_link") 2>&5 - ac_status=$? - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { ac_try='./conftest$ac_exeext' - { (case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_try") 2>&5 - ac_status=$? - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); }; }; then - ac_cv_c_bigendian=no -else - echo "$as_me: program exited with status $ac_status" >&5 -echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - -( exit $ac_status ) -ac_cv_c_bigendian=yes -fi -rm -f core *.core core.conftest.* gmon.out bb.out conftest$ac_exeext conftest.$ac_objext conftest.$ac_ext -fi - - -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext -fi -{ echo "$as_me:$LINENO: result: $ac_cv_c_bigendian" >&5 -echo "${ECHO_T}$ac_cv_c_bigendian" >&6; } -case $ac_cv_c_bigendian in - yes) - -cat >>confdefs.h <<\_ACEOF -@%:@define WORDS_BIGENDIAN 1 -_ACEOF - ;; - no) - ;; - *) - { { echo "$as_me:$LINENO: error: unknown endianness -presetting ac_cv_c_bigendian=no (or yes) will help" >&5 -echo "$as_me: error: unknown endianness -presetting ac_cv_c_bigendian=no (or yes) will help" >&2;} - { (exit 1); exit 1; }; } ;; -esac - - -{ echo "$as_me:$LINENO: checking for long int" >&5 -echo $ECHO_N "checking for long int... $ECHO_C" >&6; } -if test "${ac_cv_type_long_int+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -$ac_includes_default -typedef long int ac__type_new_; -int -main () -{ -if ((ac__type_new_ *) 0) - return 0; -if (sizeof (ac__type_new_)) - return 0; - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - ac_cv_type_long_int=yes -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - ac_cv_type_long_int=no -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext -fi -{ echo "$as_me:$LINENO: result: $ac_cv_type_long_int" >&5 -echo "${ECHO_T}$ac_cv_type_long_int" >&6; } - -# The cast to long int works around a bug in the HP C Compiler -# version HP92453-01 B.11.11.23709.GP, which incorrectly rejects -# declarations like `int a3[[(sizeof (unsigned char)) >= 0]];'. -# This bug is HP SR number 8606223364. -{ echo "$as_me:$LINENO: checking size of long int" >&5 -echo $ECHO_N "checking size of long int... $ECHO_C" >&6; } -if test "${ac_cv_sizeof_long_int+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - if test "$cross_compiling" = yes; then - # Depending upon the size, compute the lo and hi bounds. -cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -$ac_includes_default - typedef long int ac__type_sizeof_; -int -main () -{ -static int test_array @<:@1 - 2 * !(((long int) (sizeof (ac__type_sizeof_))) >= 0)@:>@; -test_array @<:@0@:>@ = 0 - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - ac_lo=0 ac_mid=0 - while :; do - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -$ac_includes_default - typedef long int ac__type_sizeof_; -int -main () -{ -static int test_array @<:@1 - 2 * !(((long int) (sizeof (ac__type_sizeof_))) <= $ac_mid)@:>@; -test_array @<:@0@:>@ = 0 - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - ac_hi=$ac_mid; break -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - ac_lo=`expr $ac_mid + 1` - if test $ac_lo -le $ac_mid; then - ac_lo= ac_hi= - break - fi - ac_mid=`expr 2 '*' $ac_mid + 1` -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - done -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -$ac_includes_default - typedef long int ac__type_sizeof_; -int -main () -{ -static int test_array @<:@1 - 2 * !(((long int) (sizeof (ac__type_sizeof_))) < 0)@:>@; -test_array @<:@0@:>@ = 0 - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - ac_hi=-1 ac_mid=-1 - while :; do - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -$ac_includes_default - typedef long int ac__type_sizeof_; -int -main () -{ -static int test_array @<:@1 - 2 * !(((long int) (sizeof (ac__type_sizeof_))) >= $ac_mid)@:>@; -test_array @<:@0@:>@ = 0 - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - ac_lo=$ac_mid; break -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - ac_hi=`expr '(' $ac_mid ')' - 1` - if test $ac_mid -le $ac_hi; then - ac_lo= ac_hi= - break - fi - ac_mid=`expr 2 '*' $ac_mid` -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - done -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - ac_lo= ac_hi= -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext -# Binary search between lo and hi bounds. -while test "x$ac_lo" != "x$ac_hi"; do - ac_mid=`expr '(' $ac_hi - $ac_lo ')' / 2 + $ac_lo` - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -$ac_includes_default - typedef long int ac__type_sizeof_; -int -main () -{ -static int test_array @<:@1 - 2 * !(((long int) (sizeof (ac__type_sizeof_))) <= $ac_mid)@:>@; -test_array @<:@0@:>@ = 0 - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - ac_hi=$ac_mid -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - ac_lo=`expr '(' $ac_mid ')' + 1` -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext -done -case $ac_lo in -?*) ac_cv_sizeof_long_int=$ac_lo;; -'') if test "$ac_cv_type_long_int" = yes; then - { { echo "$as_me:$LINENO: error: cannot compute sizeof (long int) -See \`config.log' for more details." >&5 -echo "$as_me: error: cannot compute sizeof (long int) -See \`config.log' for more details." >&2;} - { (exit 77); exit 77; }; } - else - ac_cv_sizeof_long_int=0 - fi ;; -esac -else - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -$ac_includes_default - typedef long int ac__type_sizeof_; -static long int longval () { return (long int) (sizeof (ac__type_sizeof_)); } -static unsigned long int ulongval () { return (long int) (sizeof (ac__type_sizeof_)); } -@%:@include <stdio.h> -@%:@include <stdlib.h> -int -main () -{ - - FILE *f = fopen ("conftest.val", "w"); - if (! f) - return 1; - if (((long int) (sizeof (ac__type_sizeof_))) < 0) - { - long int i = longval (); - if (i != ((long int) (sizeof (ac__type_sizeof_)))) - return 1; - fprintf (f, "%ld\n", i); - } - else - { - unsigned long int i = ulongval (); - if (i != ((long int) (sizeof (ac__type_sizeof_)))) - return 1; - fprintf (f, "%lu\n", i); - } - return ferror (f) || fclose (f) != 0; - - ; - return 0; -} -_ACEOF -rm -f conftest$ac_exeext -if { (ac_try="$ac_link" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_link") 2>&5 - ac_status=$? - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { ac_try='./conftest$ac_exeext' - { (case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_try") 2>&5 - ac_status=$? - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); }; }; then - ac_cv_sizeof_long_int=`cat conftest.val` -else - echo "$as_me: program exited with status $ac_status" >&5 -echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - -( exit $ac_status ) -if test "$ac_cv_type_long_int" = yes; then - { { echo "$as_me:$LINENO: error: cannot compute sizeof (long int) -See \`config.log' for more details." >&5 -echo "$as_me: error: cannot compute sizeof (long int) -See \`config.log' for more details." >&2;} - { (exit 77); exit 77; }; } - else - ac_cv_sizeof_long_int=0 - fi -fi -rm -f core *.core core.conftest.* gmon.out bb.out conftest$ac_exeext conftest.$ac_objext conftest.$ac_ext -fi -rm -f conftest.val -fi -{ echo "$as_me:$LINENO: result: $ac_cv_sizeof_long_int" >&5 -echo "${ECHO_T}$ac_cv_sizeof_long_int" >&6; } - - - -cat >>confdefs.h <<_ACEOF -@%:@define SIZEOF_LONG_INT $ac_cv_sizeof_long_int -_ACEOF - - -{ echo "$as_me:$LINENO: checking for void *" >&5 -echo $ECHO_N "checking for void *... $ECHO_C" >&6; } -if test "${ac_cv_type_void_p+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -$ac_includes_default -typedef void * ac__type_new_; -int -main () -{ -if ((ac__type_new_ *) 0) - return 0; -if (sizeof (ac__type_new_)) - return 0; - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - ac_cv_type_void_p=yes -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - ac_cv_type_void_p=no -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext -fi -{ echo "$as_me:$LINENO: result: $ac_cv_type_void_p" >&5 -echo "${ECHO_T}$ac_cv_type_void_p" >&6; } - -# The cast to long int works around a bug in the HP C Compiler -# version HP92453-01 B.11.11.23709.GP, which incorrectly rejects -# declarations like `int a3[[(sizeof (unsigned char)) >= 0]];'. -# This bug is HP SR number 8606223364. -{ echo "$as_me:$LINENO: checking size of void *" >&5 -echo $ECHO_N "checking size of void *... $ECHO_C" >&6; } -if test "${ac_cv_sizeof_void_p+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - if test "$cross_compiling" = yes; then - # Depending upon the size, compute the lo and hi bounds. -cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -$ac_includes_default - typedef void * ac__type_sizeof_; -int -main () -{ -static int test_array @<:@1 - 2 * !(((long int) (sizeof (ac__type_sizeof_))) >= 0)@:>@; -test_array @<:@0@:>@ = 0 - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - ac_lo=0 ac_mid=0 - while :; do - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -$ac_includes_default - typedef void * ac__type_sizeof_; -int -main () -{ -static int test_array @<:@1 - 2 * !(((long int) (sizeof (ac__type_sizeof_))) <= $ac_mid)@:>@; -test_array @<:@0@:>@ = 0 - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - ac_hi=$ac_mid; break -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - ac_lo=`expr $ac_mid + 1` - if test $ac_lo -le $ac_mid; then - ac_lo= ac_hi= - break - fi - ac_mid=`expr 2 '*' $ac_mid + 1` -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - done -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -$ac_includes_default - typedef void * ac__type_sizeof_; -int -main () -{ -static int test_array @<:@1 - 2 * !(((long int) (sizeof (ac__type_sizeof_))) < 0)@:>@; -test_array @<:@0@:>@ = 0 - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - ac_hi=-1 ac_mid=-1 - while :; do - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -$ac_includes_default - typedef void * ac__type_sizeof_; -int -main () -{ -static int test_array @<:@1 - 2 * !(((long int) (sizeof (ac__type_sizeof_))) >= $ac_mid)@:>@; -test_array @<:@0@:>@ = 0 - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - ac_lo=$ac_mid; break -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - ac_hi=`expr '(' $ac_mid ')' - 1` - if test $ac_mid -le $ac_hi; then - ac_lo= ac_hi= - break - fi - ac_mid=`expr 2 '*' $ac_mid` -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - done -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - ac_lo= ac_hi= -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext -# Binary search between lo and hi bounds. -while test "x$ac_lo" != "x$ac_hi"; do - ac_mid=`expr '(' $ac_hi - $ac_lo ')' / 2 + $ac_lo` - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -$ac_includes_default - typedef void * ac__type_sizeof_; -int -main () -{ -static int test_array @<:@1 - 2 * !(((long int) (sizeof (ac__type_sizeof_))) <= $ac_mid)@:>@; -test_array @<:@0@:>@ = 0 - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - ac_hi=$ac_mid -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - ac_lo=`expr '(' $ac_mid ')' + 1` -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext -done -case $ac_lo in -?*) ac_cv_sizeof_void_p=$ac_lo;; -'') if test "$ac_cv_type_void_p" = yes; then - { { echo "$as_me:$LINENO: error: cannot compute sizeof (void *) -See \`config.log' for more details." >&5 -echo "$as_me: error: cannot compute sizeof (void *) -See \`config.log' for more details." >&2;} - { (exit 77); exit 77; }; } - else - ac_cv_sizeof_void_p=0 - fi ;; -esac -else - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -$ac_includes_default - typedef void * ac__type_sizeof_; -static long int longval () { return (long int) (sizeof (ac__type_sizeof_)); } -static unsigned long int ulongval () { return (long int) (sizeof (ac__type_sizeof_)); } -@%:@include <stdio.h> -@%:@include <stdlib.h> -int -main () -{ - - FILE *f = fopen ("conftest.val", "w"); - if (! f) - return 1; - if (((long int) (sizeof (ac__type_sizeof_))) < 0) - { - long int i = longval (); - if (i != ((long int) (sizeof (ac__type_sizeof_)))) - return 1; - fprintf (f, "%ld\n", i); - } - else - { - unsigned long int i = ulongval (); - if (i != ((long int) (sizeof (ac__type_sizeof_)))) - return 1; - fprintf (f, "%lu\n", i); - } - return ferror (f) || fclose (f) != 0; - - ; - return 0; -} -_ACEOF -rm -f conftest$ac_exeext -if { (ac_try="$ac_link" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_link") 2>&5 - ac_status=$? - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { ac_try='./conftest$ac_exeext' - { (case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_try") 2>&5 - ac_status=$? - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); }; }; then - ac_cv_sizeof_void_p=`cat conftest.val` -else - echo "$as_me: program exited with status $ac_status" >&5 -echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - -( exit $ac_status ) -if test "$ac_cv_type_void_p" = yes; then - { { echo "$as_me:$LINENO: error: cannot compute sizeof (void *) -See \`config.log' for more details." >&5 -echo "$as_me: error: cannot compute sizeof (void *) -See \`config.log' for more details." >&2;} - { (exit 77); exit 77; }; } - else - ac_cv_sizeof_void_p=0 - fi -fi -rm -f core *.core core.conftest.* gmon.out bb.out conftest$ac_exeext conftest.$ac_objext conftest.$ac_ext -fi -rm -f conftest.val -fi -{ echo "$as_me:$LINENO: result: $ac_cv_sizeof_void_p" >&5 -echo "${ECHO_T}$ac_cv_sizeof_void_p" >&6; } - - - -cat >>confdefs.h <<_ACEOF -@%:@define SIZEOF_VOID_P $ac_cv_sizeof_void_p -_ACEOF - - - -{ echo "$as_me:$LINENO: checking for required gcc" >&5 -echo $ECHO_N "checking for required gcc... $ECHO_C" >&6; } -if test "x$GCC" = "x"; then - { { echo "$as_me:$LINENO: error: no" >&5 -echo "$as_me: error: no" >&2;} - { (exit 1); exit 1; }; } -fi -{ echo "$as_me:$LINENO: result: yes" >&5 -echo "${ECHO_T}yes" >&6; } - - -# Check whether --with-ghc was given. -if test "${with_ghc+set}" = set; then - withval=$with_ghc; # Extract the first word of "${withval}/bin/ghc", so it can be a program name with args. -set dummy ${withval}/bin/ghc; ac_word=$2 -{ echo "$as_me:$LINENO: checking for $ac_word" >&5 -echo $ECHO_N "checking for $ac_word... $ECHO_C" >&6; } -if test "${ac_cv_path_GHC+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - case $GHC in - [\\/]* | ?:[\\/]*) - ac_cv_path_GHC="$GHC" # Let the user override the test with a path. - ;; - *) - as_save_IFS=$IFS; IFS=$PATH_SEPARATOR -for as_dir in $PATH -do - IFS=$as_save_IFS - test -z "$as_dir" && as_dir=. - for ac_exec_ext in '' $ac_executable_extensions; do - if { test -f "$as_dir/$ac_word$ac_exec_ext" && $as_test_x "$as_dir/$ac_word$ac_exec_ext"; }; then - ac_cv_path_GHC="$as_dir/$ac_word$ac_exec_ext" - echo "$as_me:$LINENO: found $as_dir/$ac_word$ac_exec_ext" >&5 - break 2 - fi -done -done -IFS=$as_save_IFS - - ;; -esac -fi -GHC=$ac_cv_path_GHC -if test -n "$GHC"; then - { echo "$as_me:$LINENO: result: $GHC" >&5 -echo "${ECHO_T}$GHC" >&6; } -else - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } -fi - - -else - # Extract the first word of "ghc", so it can be a program name with args. -set dummy ghc; ac_word=$2 -{ echo "$as_me:$LINENO: checking for $ac_word" >&5 -echo $ECHO_N "checking for $ac_word... $ECHO_C" >&6; } -if test "${ac_cv_path_GHC+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - case $GHC in - [\\/]* | ?:[\\/]*) - ac_cv_path_GHC="$GHC" # Let the user override the test with a path. - ;; - *) - as_save_IFS=$IFS; IFS=$PATH_SEPARATOR -for as_dir in $PATH -do - IFS=$as_save_IFS - test -z "$as_dir" && as_dir=. - for ac_exec_ext in '' $ac_executable_extensions; do - if { test -f "$as_dir/$ac_word$ac_exec_ext" && $as_test_x "$as_dir/$ac_word$ac_exec_ext"; }; then - ac_cv_path_GHC="$as_dir/$ac_word$ac_exec_ext" - echo "$as_me:$LINENO: found $as_dir/$ac_word$ac_exec_ext" >&5 - break 2 - fi -done -done -IFS=$as_save_IFS - - ;; -esac -fi -GHC=$ac_cv_path_GHC -if test -n "$GHC"; then - { echo "$as_me:$LINENO: result: $GHC" >&5 -echo "${ECHO_T}$GHC" >&6; } -else - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } -fi - - -fi - - - - -# Check whether --with-db was given. -if test "${with_db+set}" = set; then - withval=$with_db; - dbpath=${withval} - - DB_LDFLAGS= - { echo "$as_me:$LINENO: checking for db library" >&5 -echo $ECHO_N "checking for db library... $ECHO_C" >&6; } - oldlibs=$LIBS - lib=notfound - - if test "x$dbpath" != "x" ; then - oldcflags=$CFLAGS - for dbheader in db4 db3 notfound; do - cat >conftest.$ac_ext <<_ACEOF -#include "$dbpath/include/$dbheader/db.h" -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - DB_CFLAGS="-I$dbpath/include/$dbheader/" - break -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - done - - if test "x$dbheader" = "xnotfound"; then - cat >conftest.$ac_ext <<_ACEOF -#include "$dbpath/include/db.h" -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - DB_CFLAGS="-I$dbpath/include/" -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - { { echo "$as_me:$LINENO: error: Invalid libdb path specified. No db.h found. -See \`config.log' for more details." >&5 -echo "$as_me: error: Invalid libdb path specified. No db.h found. -See \`config.log' for more details." >&2;} - { (exit 1); exit 1; }; } -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - fi - - DB_LDFLAGS="-L${dbpath}/lib" - LDFLAGS="$DB_LDFLAGS ${LDFLAGS}" - - LIBS="${oldlibs} -ldb -lpthread" - DB_LIB="-ldb" - CFLAGS="$DB_CFLAGS $oldcflags" - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -#include <db.h> -int -main () -{ -DB *dbp; db_create(&dbp, NULL, 0); - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext conftest$ac_exeext -if { (ac_try="$ac_link" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_link") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest$ac_exeext && - $as_test_x conftest$ac_exeext; then - lib=db -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - -fi - -rm -f core conftest.err conftest.$ac_objext conftest_ipa8_conftest.oo \ - conftest$ac_exeext conftest.$ac_ext - CFLAGS=$oldcflags - - else - for lib in db4 db3 db notfound; do - LIBS="${oldlibs} -l$lib -lpthread" - DB_LIB="-l$lib" - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -#include <db.h> -int -main () -{ -DB *dbp; db_create(&dbp, NULL, 0); - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext conftest$ac_exeext -if { (ac_try="$ac_link" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_link") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest$ac_exeext && - $as_test_x conftest$ac_exeext; then - break -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - -fi - -rm -f core conftest.err conftest.$ac_objext conftest_ipa8_conftest.oo \ - conftest$ac_exeext conftest.$ac_ext - done - fi - - LIBS=$oldlibs - if test "x$lib" = "xnotfound" ; then - { { echo "$as_me:$LINENO: error: could not find DB libraries" >&5 -echo "$as_me: error: could not find DB libraries" >&2;} - { (exit 1); exit 1; }; } - else - { echo "$as_me:$LINENO: result: $lib" >&5 -echo "${ECHO_T}$lib" >&6; } - fi - - - - - { echo "$as_me:$LINENO: checking for dbenv parameter to DB error callback function" >&5 -echo $ECHO_N "checking for dbenv parameter to DB error callback function... $ECHO_C" >&6; } - oldcflags=$CFLAGS - CFLAGS="$USR_CFLAGS $DB_CFLAGS -Werror" - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - - #include <db.h> - - void error_callback_fn(const DB_ENV *dbenv, - const char *prefix, - const char *message) - { - return; - } - -int -main () -{ - - DB *db; - - db->set_errcall(db, error_callback_fn); - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - { echo "$as_me:$LINENO: result: yes" >&5 -echo "${ECHO_T}yes" >&6; } - -cat >>confdefs.h <<\_ACEOF -@%:@define HAVE_DBENV_PARAMETER_TO_DB_ERROR_CALLBACK 1 -_ACEOF - - have_dbenv_parameter_to_db_error_callback=yes -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } - have_dbenv_parameter_to_db_error_callback=no -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - - if test "x$have_dbenv_parameter_to_db_error_callback" = "xyes" ; then - { echo "$as_me:$LINENO: checking if third parameter to error callback function is const" >&5 -echo $ECHO_N "checking if third parameter to error callback function is const... $ECHO_C" >&6; } - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - - #include <db.h> - - void error_callback_fn(const DB_ENV *dbenv, - const char *prefix, - char *message) - { - return; - } - -int -main () -{ - - DB *db; - - db->set_errcall(db, error_callback_fn); - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - { echo "$as_me:$LINENO: result: yes" >&5 -echo "${ECHO_T}yes" >&6; } - -cat >>confdefs.h <<\_ACEOF -@%:@define HAVE_CONST_THIRD_PARAMETER_TO_DB_ERROR_CALLBACK 1 -_ACEOF - -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - fi - - CFLAGS="$USR_CFLAGS $DB_CFLAGS -Werror" - { echo "$as_me:$LINENO: checking for DB stat with malloc function ptr" >&5 -echo $ECHO_N "checking for DB stat with malloc function ptr... $ECHO_C" >&6; } - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - - #include <db.h> - #include <stdlib.h> - -int -main () -{ - - int ret = 0; - DB *db = db; - int dummy = 0; - u_int32_t flags = 0; - - ret = db->stat(db, &dummy, malloc, flags); - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - { echo "$as_me:$LINENO: result: yes" >&5 -echo "${ECHO_T}yes" >&6; } - -cat >>confdefs.h <<\_ACEOF -@%:@define HAVE_UNKNOWN_PARAMETER_TO_DB_STAT 1 -_ACEOF - - have_db_stat_malloc=yes -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } - have_db_stat_malloc=no -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - - if test "x$have_db_stat_malloc" = "xno" ; then - - { echo "$as_me:$LINENO: checking for txnid parameter to DB stat function" >&5 -echo $ECHO_N "checking for txnid parameter to DB stat function... $ECHO_C" >&6; } - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - - #include <db.h> - -int -main () -{ - - int ret = 0; - DB *db = db; - DB_TXN *txnid = txnid; - u_int32_t flags = 0; - - ret = db->stat(db, txnid, NULL, flags); - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - { echo "$as_me:$LINENO: result: yes" >&5 -echo "${ECHO_T}yes" >&6; } - -cat >>confdefs.h <<\_ACEOF -@%:@define HAVE_TXNID_PARAMETER_TO_DB_STAT 1 -_ACEOF - - have_txnid_param_to_stat=yes -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } - have_txnid_param_to_stat=no -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - - fi - - { echo "$as_me:$LINENO: checking for txnid parameter to DB open function" >&5 -echo $ECHO_N "checking for txnid parameter to DB open function... $ECHO_C" >&6; } - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - - #include <db.h> - -int -main () -{ - - int ret = 0; - DB *db = NULL; - DB_TXN *txnid = NULL; - char *file = NULL; - char *database = NULL; - DBTYPE type = 0; - u_int32_t flags = 0; - int mode = 0; - - ret = db->open(db, txnid, file, database, type, flags, mode); - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - { echo "$as_me:$LINENO: result: yes" >&5 -echo "${ECHO_T}yes" >&6; } - -cat >>confdefs.h <<\_ACEOF -@%:@define HAVE_TXNID_PARAMETER_TO_DB_OPEN 1 -_ACEOF - -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - - { echo "$as_me:$LINENO: checking for DB_DIRTY_READ flag" >&5 -echo $ECHO_N "checking for DB_DIRTY_READ flag... $ECHO_C" >&6; } - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - - #include <db.h> - -int -main () -{ - - u_int32_t flags = DB_DIRTY_READ; - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - { echo "$as_me:$LINENO: result: yes" >&5 -echo "${ECHO_T}yes" >&6; } - -cat >>confdefs.h <<\_ACEOF -@%:@define HAVE_DB_DIRTY_READ 1 -_ACEOF - -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - - { echo "$as_me:$LINENO: checking for DB_BUFFER_SMALL error" >&5 -echo $ECHO_N "checking for DB_BUFFER_SMALL error... $ECHO_C" >&6; } - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - - #include <db.h> - -int -main () -{ - - int res = DB_BUFFER_SMALL; - res++; - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - { echo "$as_me:$LINENO: result: yes" >&5 -echo "${ECHO_T}yes" >&6; } - -cat >>confdefs.h <<\_ACEOF -@%:@define HAVE_DB_BUFFER_SMALL 1 -_ACEOF - -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - - { echo "$as_me:$LINENO: checking for berkeley db get_pagesize function" >&5 -echo $ECHO_N "checking for berkeley db get_pagesize function... $ECHO_C" >&6; } - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - - #include <db.h> - -int -main () -{ - - int ret = 0; - DB *db = NULL; - int pagesize; - - ret = db->get_pagesize(db, &pagesize); - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - { echo "$as_me:$LINENO: result: yes" >&5 -echo "${ECHO_T}yes" >&6; } - -cat >>confdefs.h <<\_ACEOF -@%:@define HAVE_DB_GET_PAGESIZE 1 -_ACEOF - -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - - CFLAGS="$oldcflags" - -else - - dbpath="" - - DB_LDFLAGS= - { echo "$as_me:$LINENO: checking for db library" >&5 -echo $ECHO_N "checking for db library... $ECHO_C" >&6; } - oldlibs=$LIBS - lib=notfound - - if test "x$dbpath" != "x" ; then - oldcflags=$CFLAGS - for dbheader in db4 db3 notfound; do - cat >conftest.$ac_ext <<_ACEOF -#include "$dbpath/include/$dbheader/db.h" -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - DB_CFLAGS="-I$dbpath/include/$dbheader/" - break -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - done - - if test "x$dbheader" = "xnotfound"; then - cat >conftest.$ac_ext <<_ACEOF -#include "$dbpath/include/db.h" -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - DB_CFLAGS="-I$dbpath/include/" -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - { { echo "$as_me:$LINENO: error: Invalid libdb path specified. No db.h found. -See \`config.log' for more details." >&5 -echo "$as_me: error: Invalid libdb path specified. No db.h found. -See \`config.log' for more details." >&2;} - { (exit 1); exit 1; }; } -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - fi - - DB_LDFLAGS="-L${dbpath}/lib" - LDFLAGS="$DB_LDFLAGS ${LDFLAGS}" - - LIBS="${oldlibs} -ldb -lpthread" - DB_LIB="-ldb" - CFLAGS="$DB_CFLAGS $oldcflags" - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -#include <db.h> -int -main () -{ -DB *dbp; db_create(&dbp, NULL, 0); - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext conftest$ac_exeext -if { (ac_try="$ac_link" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_link") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest$ac_exeext && - $as_test_x conftest$ac_exeext; then - lib=db -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - -fi - -rm -f core conftest.err conftest.$ac_objext conftest_ipa8_conftest.oo \ - conftest$ac_exeext conftest.$ac_ext - CFLAGS=$oldcflags - - else - for lib in db4 db3 db notfound; do - LIBS="${oldlibs} -l$lib -lpthread" - DB_LIB="-l$lib" - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -#include <db.h> -int -main () -{ -DB *dbp; db_create(&dbp, NULL, 0); - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext conftest$ac_exeext -if { (ac_try="$ac_link" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_link") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest$ac_exeext && - $as_test_x conftest$ac_exeext; then - break -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - -fi - -rm -f core conftest.err conftest.$ac_objext conftest_ipa8_conftest.oo \ - conftest$ac_exeext conftest.$ac_ext - done - fi - - LIBS=$oldlibs - if test "x$lib" = "xnotfound" ; then - { { echo "$as_me:$LINENO: error: could not find DB libraries" >&5 -echo "$as_me: error: could not find DB libraries" >&2;} - { (exit 1); exit 1; }; } - else - { echo "$as_me:$LINENO: result: $lib" >&5 -echo "${ECHO_T}$lib" >&6; } - fi - - - - - { echo "$as_me:$LINENO: checking for dbenv parameter to DB error callback function" >&5 -echo $ECHO_N "checking for dbenv parameter to DB error callback function... $ECHO_C" >&6; } - oldcflags=$CFLAGS - CFLAGS="$USR_CFLAGS $DB_CFLAGS -Werror" - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - - #include <db.h> - - void error_callback_fn(const DB_ENV *dbenv, - const char *prefix, - const char *message) - { - return; - } - -int -main () -{ - - DB *db; - - db->set_errcall(db, error_callback_fn); - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - { echo "$as_me:$LINENO: result: yes" >&5 -echo "${ECHO_T}yes" >&6; } - -cat >>confdefs.h <<\_ACEOF -@%:@define HAVE_DBENV_PARAMETER_TO_DB_ERROR_CALLBACK 1 -_ACEOF - - have_dbenv_parameter_to_db_error_callback=yes -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } - have_dbenv_parameter_to_db_error_callback=no -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - - if test "x$have_dbenv_parameter_to_db_error_callback" = "xyes" ; then - { echo "$as_me:$LINENO: checking if third parameter to error callback function is const" >&5 -echo $ECHO_N "checking if third parameter to error callback function is const... $ECHO_C" >&6; } - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - - #include <db.h> - - void error_callback_fn(const DB_ENV *dbenv, - const char *prefix, - char *message) - { - return; - } - -int -main () -{ - - DB *db; - - db->set_errcall(db, error_callback_fn); - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - { echo "$as_me:$LINENO: result: yes" >&5 -echo "${ECHO_T}yes" >&6; } - -cat >>confdefs.h <<\_ACEOF -@%:@define HAVE_CONST_THIRD_PARAMETER_TO_DB_ERROR_CALLBACK 1 -_ACEOF - -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - fi - - CFLAGS="$USR_CFLAGS $DB_CFLAGS -Werror" - { echo "$as_me:$LINENO: checking for DB stat with malloc function ptr" >&5 -echo $ECHO_N "checking for DB stat with malloc function ptr... $ECHO_C" >&6; } - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - - #include <db.h> - #include <stdlib.h> - -int -main () -{ - - int ret = 0; - DB *db = db; - int dummy = 0; - u_int32_t flags = 0; - - ret = db->stat(db, &dummy, malloc, flags); - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - { echo "$as_me:$LINENO: result: yes" >&5 -echo "${ECHO_T}yes" >&6; } - -cat >>confdefs.h <<\_ACEOF -@%:@define HAVE_UNKNOWN_PARAMETER_TO_DB_STAT 1 -_ACEOF - - have_db_stat_malloc=yes -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } - have_db_stat_malloc=no -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - - if test "x$have_db_stat_malloc" = "xno" ; then - - { echo "$as_me:$LINENO: checking for txnid parameter to DB stat function" >&5 -echo $ECHO_N "checking for txnid parameter to DB stat function... $ECHO_C" >&6; } - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - - #include <db.h> - -int -main () -{ - - int ret = 0; - DB *db = db; - DB_TXN *txnid = txnid; - u_int32_t flags = 0; - - ret = db->stat(db, txnid, NULL, flags); - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - { echo "$as_me:$LINENO: result: yes" >&5 -echo "${ECHO_T}yes" >&6; } - -cat >>confdefs.h <<\_ACEOF -@%:@define HAVE_TXNID_PARAMETER_TO_DB_STAT 1 -_ACEOF - - have_txnid_param_to_stat=yes -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } - have_txnid_param_to_stat=no -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - - fi - - { echo "$as_me:$LINENO: checking for txnid parameter to DB open function" >&5 -echo $ECHO_N "checking for txnid parameter to DB open function... $ECHO_C" >&6; } - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - - #include <db.h> - -int -main () -{ - - int ret = 0; - DB *db = NULL; - DB_TXN *txnid = NULL; - char *file = NULL; - char *database = NULL; - DBTYPE type = 0; - u_int32_t flags = 0; - int mode = 0; - - ret = db->open(db, txnid, file, database, type, flags, mode); - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - { echo "$as_me:$LINENO: result: yes" >&5 -echo "${ECHO_T}yes" >&6; } - -cat >>confdefs.h <<\_ACEOF -@%:@define HAVE_TXNID_PARAMETER_TO_DB_OPEN 1 -_ACEOF - -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - - { echo "$as_me:$LINENO: checking for DB_DIRTY_READ flag" >&5 -echo $ECHO_N "checking for DB_DIRTY_READ flag... $ECHO_C" >&6; } - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - - #include <db.h> - -int -main () -{ - - u_int32_t flags = DB_DIRTY_READ; - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - { echo "$as_me:$LINENO: result: yes" >&5 -echo "${ECHO_T}yes" >&6; } - -cat >>confdefs.h <<\_ACEOF -@%:@define HAVE_DB_DIRTY_READ 1 -_ACEOF - -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - - { echo "$as_me:$LINENO: checking for DB_BUFFER_SMALL error" >&5 -echo $ECHO_N "checking for DB_BUFFER_SMALL error... $ECHO_C" >&6; } - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - - #include <db.h> - -int -main () -{ - - int res = DB_BUFFER_SMALL; - res++; - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - { echo "$as_me:$LINENO: result: yes" >&5 -echo "${ECHO_T}yes" >&6; } - -cat >>confdefs.h <<\_ACEOF -@%:@define HAVE_DB_BUFFER_SMALL 1 -_ACEOF - -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - - { echo "$as_me:$LINENO: checking for berkeley db get_pagesize function" >&5 -echo $ECHO_N "checking for berkeley db get_pagesize function... $ECHO_C" >&6; } - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - - #include <db.h> - -int -main () -{ - - int ret = 0; - DB *db = NULL; - int pagesize; - - ret = db->get_pagesize(db, &pagesize); - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - { echo "$as_me:$LINENO: result: yes" >&5 -echo "${ECHO_T}yes" >&6; } - -cat >>confdefs.h <<\_ACEOF -@%:@define HAVE_DB_GET_PAGESIZE 1 -_ACEOF - -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - - CFLAGS="$oldcflags" - -fi - - - -# Check whether --with-mpi was given. -if test "${with_mpi+set}" = set; then - withval=$with_mpi; if test x$withval = xyes; then - { { echo "$as_me:$LINENO: error: --with-mpi must be given a pathname" >&5 -echo "$as_me: error: --with-mpi must be given a pathname" >&2;} - { (exit 1); exit 1; }; } - else - MPICC="${withval}/bin/mpicc" - MPICFLAGS="-I${withval}/include" - MPILDFLAGS="-L${withval}/lib" - MPILIBS="-lmpich" - BUILD_MPI="1" - fi - -fi - - - - - - - -BUILD_ABSOLUTE_TOP=${PWD} -SRC_RELATIVE_TOP=$srcdir -SRC_ABSOLUTE_TOP=`cd $srcdir; pwd` - - - - - - - - - - -# Check whether --enable-verbose was given. -if test "${enable_verbose+set}" = set; then - enableval=$enable_verbose; QUIET_COMPILE=0 -else - QUIET_COMPILE=1 -fi - - - -STRICT_CFLAGS= -# Check whether --enable-strict was given. -if test "${enable_strict+set}" = set; then - enableval=$enable_strict; STRICT_CFLAGS=1 -fi - - - -AE_DEBUG= -# Check whether --enable-aesop-debug was given. -if test "${enable_aesop_debug+set}" = set; then - enableval=$enable_aesop_debug; AE_DEBUG=1 -fi - - - -# Check whether --enable-coverage was given. -if test "${enable_coverage+set}" = set; then - enableval=$enable_coverage; CFLAGS="$CFLAGS -g -pg -ftest-coverage -O0" - ENABLE_COVERAGE=1 -fi - - - -{ echo "$as_me:$LINENO: checking for client library thread safety support" >&5 -echo $ECHO_N "checking for client library thread safety support... $ECHO_C" >&6; } -# Check whether --enable-thread-safety was given. -if test "${enable_thread_safety+set}" = set; then - enableval=$enable_thread_safety; if test "x$enableval" = "xno" ; then - LIBCFLAGS="$LIBCFLAGS -D__TRITON_NULL_LOCKING__" - THREAD_LIB="" - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } -fi -else - LIBCFLAGS="$LIBCFLAGS -D__TRITON_POSIX_LOCKING__" - THREAD_LIB="-lpthread" - { echo "$as_me:$LINENO: result: yes" >&5 -echo "${ECHO_T}yes" >&6; } -fi - - - - - - - SQLITE_MINIMUM_VER="3.0.0" - SQLITE_PKGNAME="sqlite3" - BUILD_OSD= - - - sqlite_min_major=`expr $SQLITE_MINIMUM_VER : '\([0-9]*\)'` - sqlite_min_minor=`expr $SQLITE_MINIMUM_VER : '[0-9]*\.\([0-9]*\)'` - sqlite_min_micro=`expr $SQLITE_MINIMUM_VER : '[0-9]*\.[0-9]*\.\([0-9]*\)'` - sqlite_min_ver_num=`expr $sqlite_min_major \* 1000000 \ - \+ $sqlite_min_minor \* 1000 \ - \+ $sqlite_min_micro` - - - { echo "$as_me:$LINENO: checking sqlite library" >&5 -echo "$as_me: checking sqlite library" >&6;} - - -# Check whether --with-sqlite was given. -if test "${with_sqlite+set}" = set; then - withval=$with_sqlite; - if test "$withval" = "yes" ; then - { { echo "$as_me:$LINENO: error: --with-sqlite requires an argument." >&5 -echo "$as_me: error: --with-sqlite requires an argument." >&2;} - { (exit 1); exit 1; }; } - else - sqlite_dir="$withval" - fi - - if test -d $sqlite_dir; then - - if test -z "$sqlite_dir"; then - sqlite_dir="" - sqlite_include="sqlite3.h" - else - sqlite_dir="$sqlite_dir" - sqlite_include="$sqlite_dir/include/sqlite3.h" - fi - - save_CPPFLAGS="$CPPFLAGS" - save_LDFLAGS="$LDFLAGS" - - if test ! -z "$sqlite_dir"; then - CPPFLAGS="$CPPFLAGS -I$sqlite_dir/include" - LDFLAGS="$LDFLAGS -L$sqlite_dir/lib" - fi - - if test "${ac_cv_header_sqlite3_h+set}" = set; then - { echo "$as_me:$LINENO: checking for sqlite3.h" >&5 -echo $ECHO_N "checking for sqlite3.h... $ECHO_C" >&6; } -if test "${ac_cv_header_sqlite3_h+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -fi -{ echo "$as_me:$LINENO: result: $ac_cv_header_sqlite3_h" >&5 -echo "${ECHO_T}$ac_cv_header_sqlite3_h" >&6; } -else - # Is the header compilable? -{ echo "$as_me:$LINENO: checking sqlite3.h usability" >&5 -echo $ECHO_N "checking sqlite3.h usability... $ECHO_C" >&6; } -cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -$ac_includes_default -@%:@include <sqlite3.h> -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - ac_header_compiler=yes -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - ac_header_compiler=no -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext -{ echo "$as_me:$LINENO: result: $ac_header_compiler" >&5 -echo "${ECHO_T}$ac_header_compiler" >&6; } - -# Is the header present? -{ echo "$as_me:$LINENO: checking sqlite3.h presence" >&5 -echo $ECHO_N "checking sqlite3.h presence... $ECHO_C" >&6; } -cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -@%:@include <sqlite3.h> -_ACEOF -if { (ac_try="$ac_cpp conftest.$ac_ext" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_cpp conftest.$ac_ext") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } >/dev/null && { - test -z "$ac_c_preproc_warn_flag$ac_c_werror_flag" || - test ! -s conftest.err - }; then - ac_header_preproc=yes -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - ac_header_preproc=no -fi - -rm -f conftest.err conftest.$ac_ext -{ echo "$as_me:$LINENO: result: $ac_header_preproc" >&5 -echo "${ECHO_T}$ac_header_preproc" >&6; } - -# So? What about this header? -case $ac_header_compiler:$ac_header_preproc:$ac_c_preproc_warn_flag in - yes:no: ) - { echo "$as_me:$LINENO: WARNING: sqlite3.h: accepted by the compiler, rejected by the preprocessor!" >&5 -echo "$as_me: WARNING: sqlite3.h: accepted by the compiler, rejected by the preprocessor!" >&2;} - { echo "$as_me:$LINENO: WARNING: sqlite3.h: proceeding with the compiler's result" >&5 -echo "$as_me: WARNING: sqlite3.h: proceeding with the compiler's result" >&2;} - ac_header_preproc=yes - ;; - no:yes:* ) - { echo "$as_me:$LINENO: WARNING: sqlite3.h: present but cannot be compiled" >&5 -echo "$as_me: WARNING: sqlite3.h: present but cannot be compiled" >&2;} - { echo "$as_me:$LINENO: WARNING: sqlite3.h: check for missing prerequisite headers?" >&5 -echo "$as_me: WARNING: sqlite3.h: check for missing prerequisite headers?" >&2;} - { echo "$as_me:$LINENO: WARNING: sqlite3.h: see the Autoconf documentation" >&5 -echo "$as_me: WARNING: sqlite3.h: see the Autoconf documentation" >&2;} - { echo "$as_me:$LINENO: WARNING: sqlite3.h: section \"Present But Cannot Be Compiled\"" >&5 -echo "$as_me: WARNING: sqlite3.h: section \"Present But Cannot Be Compiled\"" >&2;} - { echo "$as_me:$LINENO: WARNING: sqlite3.h: proceeding with the preprocessor's result" >&5 -echo "$as_me: WARNING: sqlite3.h: proceeding with the preprocessor's result" >&2;} - { echo "$as_me:$LINENO: WARNING: sqlite3.h: in the future, the compiler will take precedence" >&5 -echo "$as_me: WARNING: sqlite3.h: in the future, the compiler will take precedence" >&2;} - ( cat <<\_ASBOX -@%:@@%:@ ------------------------------------- @%:@@%:@ -@%:@@%:@ Report this to [email protected] @%:@@%:@ -@%:@@%:@ ------------------------------------- @%:@@%:@ -_ASBOX - ) | sed "s/^/$as_me: WARNING: /" >&2 - ;; -esac -{ echo "$as_me:$LINENO: checking for sqlite3.h" >&5 -echo $ECHO_N "checking for sqlite3.h... $ECHO_C" >&6; } -if test "${ac_cv_header_sqlite3_h+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - ac_cv_header_sqlite3_h=$ac_header_preproc -fi -{ echo "$as_me:$LINENO: result: $ac_cv_header_sqlite3_h" >&5 -echo "${ECHO_T}$ac_cv_header_sqlite3_h" >&6; } - -fi -if test $ac_cv_header_sqlite3_h = yes; then - - { echo "$as_me:$LINENO: checking sqlite library version (via header)" >&5 -echo $ECHO_N "checking sqlite library version (via header)... $ECHO_C" >&6; } - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - -#include "$sqlite_include" -#if SQLITE_VERSION_NUMBER >= $sqlite_min_ver_num -SQLITE_VERSION_OKAY -#endif -_ACEOF -if (eval "$ac_cpp conftest.$ac_ext") 2>&5 | - $EGREP "SQLITE_VERSION_OKAY" >/dev/null 2>&1; then - { echo "$as_me:$LINENO: result: okay" >&5 -echo "${ECHO_T}okay" >&6; } - { echo "$as_me:$LINENO: checking for sqlite3_close in -lsqlite3" >&5 -echo $ECHO_N "checking for sqlite3_close in -lsqlite3... $ECHO_C" >&6; } -if test "${ac_cv_lib_sqlite3_sqlite3_close+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - ac_check_lib_save_LIBS=$LIBS -LIBS="-lsqlite3 $LIBS" -cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - -/* Override any GCC internal prototype to avoid an error. - Use char because int might match the return type of a GCC - builtin and then its argument prototype would still apply. */ -#ifdef __cplusplus -extern "C" -#endif -char sqlite3_close (); -int -main () -{ -return sqlite3_close (); - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext conftest$ac_exeext -if { (ac_try="$ac_link" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_link") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest$ac_exeext && - $as_test_x conftest$ac_exeext; then - ac_cv_lib_sqlite3_sqlite3_close=yes -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - ac_cv_lib_sqlite3_sqlite3_close=no -fi - -rm -f core conftest.err conftest.$ac_objext conftest_ipa8_conftest.oo \ - conftest$ac_exeext conftest.$ac_ext -LIBS=$ac_check_lib_save_LIBS -fi -{ echo "$as_me:$LINENO: result: $ac_cv_lib_sqlite3_sqlite3_close" >&5 -echo "${ECHO_T}$ac_cv_lib_sqlite3_sqlite3_close" >&6; } -if test $ac_cv_lib_sqlite3_sqlite3_close = yes; then - - triton_lib_sqlite="yes" - if test -z "$sqlite_dir" -o ! -d "$sqlite_dir"; then - TRITON_SQLITE_LIBS="-lsqlite3" - else - TRITON_SQLITE_INCLUDES="-I$sqlite_dir/include" - TRITON_SQLITE_LIBS="-L$sqlite_dir/lib -lsqlite3" - fi - -fi - -else - { echo "$as_me:$LINENO: result: unsupported SQLite version" >&5 -echo "${ECHO_T}unsupported SQLite version" >&6; } -fi -rm -f conftest* - - -fi - - - - CPPFLAGS="$save_CPPFLAGS" - LDFLAGS="$save_LDFLAGS" - - else - { { echo "$as_me:$LINENO: error: $sqlite_dir is not a directory." >&5 -echo "$as_me: error: $sqlite_dir is not a directory." >&2;} - { (exit 1); exit 1; }; } - fi - - # if a --with-sqlite argument was given, then we should complain if we - # can't find it there - if test -z "$triton_lib_sqlite"; then - { { echo "$as_me:$LINENO: error: no suitable sqlite found in $sqlite_dir" >&5 -echo "$as_me: error: no suitable sqlite found in $sqlite_dir" >&2;} - { (exit 1); exit 1; }; } - else - BUILD_OSD=1 - fi - -else - - if test -z "$triton_lib_sqlite"; then - - if test -z ""; then - sqlite_dir="" - sqlite_include="sqlite3.h" - else - sqlite_dir="" - sqlite_include="/include/sqlite3.h" - fi - - save_CPPFLAGS="$CPPFLAGS" - save_LDFLAGS="$LDFLAGS" - - if test ! -z ""; then - CPPFLAGS="$CPPFLAGS -I$sqlite_dir/include" - LDFLAGS="$LDFLAGS -L$sqlite_dir/lib" - fi - - if test "${ac_cv_header_sqlite3_h+set}" = set; then - { echo "$as_me:$LINENO: checking for sqlite3.h" >&5 -echo $ECHO_N "checking for sqlite3.h... $ECHO_C" >&6; } -if test "${ac_cv_header_sqlite3_h+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -fi -{ echo "$as_me:$LINENO: result: $ac_cv_header_sqlite3_h" >&5 -echo "${ECHO_T}$ac_cv_header_sqlite3_h" >&6; } -else - # Is the header compilable? -{ echo "$as_me:$LINENO: checking sqlite3.h usability" >&5 -echo $ECHO_N "checking sqlite3.h usability... $ECHO_C" >&6; } -cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -$ac_includes_default -@%:@include <sqlite3.h> -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - ac_header_compiler=yes -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - ac_header_compiler=no -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext -{ echo "$as_me:$LINENO: result: $ac_header_compiler" >&5 -echo "${ECHO_T}$ac_header_compiler" >&6; } - -# Is the header present? -{ echo "$as_me:$LINENO: checking sqlite3.h presence" >&5 -echo $ECHO_N "checking sqlite3.h presence... $ECHO_C" >&6; } -cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -@%:@include <sqlite3.h> -_ACEOF -if { (ac_try="$ac_cpp conftest.$ac_ext" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_cpp conftest.$ac_ext") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } >/dev/null && { - test -z "$ac_c_preproc_warn_flag$ac_c_werror_flag" || - test ! -s conftest.err - }; then - ac_header_preproc=yes -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - ac_header_preproc=no -fi - -rm -f conftest.err conftest.$ac_ext -{ echo "$as_me:$LINENO: result: $ac_header_preproc" >&5 -echo "${ECHO_T}$ac_header_preproc" >&6; } - -# So? What about this header? -case $ac_header_compiler:$ac_header_preproc:$ac_c_preproc_warn_flag in - yes:no: ) - { echo "$as_me:$LINENO: WARNING: sqlite3.h: accepted by the compiler, rejected by the preprocessor!" >&5 -echo "$as_me: WARNING: sqlite3.h: accepted by the compiler, rejected by the preprocessor!" >&2;} - { echo "$as_me:$LINENO: WARNING: sqlite3.h: proceeding with the compiler's result" >&5 -echo "$as_me: WARNING: sqlite3.h: proceeding with the compiler's result" >&2;} - ac_header_preproc=yes - ;; - no:yes:* ) - { echo "$as_me:$LINENO: WARNING: sqlite3.h: present but cannot be compiled" >&5 -echo "$as_me: WARNING: sqlite3.h: present but cannot be compiled" >&2;} - { echo "$as_me:$LINENO: WARNING: sqlite3.h: check for missing prerequisite headers?" >&5 -echo "$as_me: WARNING: sqlite3.h: check for missing prerequisite headers?" >&2;} - { echo "$as_me:$LINENO: WARNING: sqlite3.h: see the Autoconf documentation" >&5 -echo "$as_me: WARNING: sqlite3.h: see the Autoconf documentation" >&2;} - { echo "$as_me:$LINENO: WARNING: sqlite3.h: section \"Present But Cannot Be Compiled\"" >&5 -echo "$as_me: WARNING: sqlite3.h: section \"Present But Cannot Be Compiled\"" >&2;} - { echo "$as_me:$LINENO: WARNING: sqlite3.h: proceeding with the preprocessor's result" >&5 -echo "$as_me: WARNING: sqlite3.h: proceeding with the preprocessor's result" >&2;} - { echo "$as_me:$LINENO: WARNING: sqlite3.h: in the future, the compiler will take precedence" >&5 -echo "$as_me: WARNING: sqlite3.h: in the future, the compiler will take precedence" >&2;} - ( cat <<\_ASBOX -@%:@@%:@ ------------------------------------- @%:@@%:@ -@%:@@%:@ Report this to [email protected] @%:@@%:@ -@%:@@%:@ ------------------------------------- @%:@@%:@ -_ASBOX - ) | sed "s/^/$as_me: WARNING: /" >&2 - ;; -esac -{ echo "$as_me:$LINENO: checking for sqlite3.h" >&5 -echo $ECHO_N "checking for sqlite3.h... $ECHO_C" >&6; } -if test "${ac_cv_header_sqlite3_h+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - ac_cv_header_sqlite3_h=$ac_header_preproc -fi -{ echo "$as_me:$LINENO: result: $ac_cv_header_sqlite3_h" >&5 -echo "${ECHO_T}$ac_cv_header_sqlite3_h" >&6; } - -fi -if test $ac_cv_header_sqlite3_h = yes; then - - { echo "$as_me:$LINENO: checking sqlite library version (via header)" >&5 -echo $ECHO_N "checking sqlite library version (via header)... $ECHO_C" >&6; } - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - -#include "$sqlite_include" -#if SQLITE_VERSION_NUMBER >= $sqlite_min_ver_num -SQLITE_VERSION_OKAY -#endif -_ACEOF -if (eval "$ac_cpp conftest.$ac_ext") 2>&5 | - $EGREP "SQLITE_VERSION_OKAY" >/dev/null 2>&1; then - { echo "$as_me:$LINENO: result: okay" >&5 -echo "${ECHO_T}okay" >&6; } - { echo "$as_me:$LINENO: checking for sqlite3_close in -lsqlite3" >&5 -echo $ECHO_N "checking for sqlite3_close in -lsqlite3... $ECHO_C" >&6; } -if test "${ac_cv_lib_sqlite3_sqlite3_close+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - ac_check_lib_save_LIBS=$LIBS -LIBS="-lsqlite3 $LIBS" -cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - -/* Override any GCC internal prototype to avoid an error. - Use char because int might match the return type of a GCC - builtin and then its argument prototype would still apply. */ -#ifdef __cplusplus -extern "C" -#endif -char sqlite3_close (); -int -main () -{ -return sqlite3_close (); - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext conftest$ac_exeext -if { (ac_try="$ac_link" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_link") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest$ac_exeext && - $as_test_x conftest$ac_exeext; then - ac_cv_lib_sqlite3_sqlite3_close=yes -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - ac_cv_lib_sqlite3_sqlite3_close=no -fi - -rm -f core conftest.err conftest.$ac_objext conftest_ipa8_conftest.oo \ - conftest$ac_exeext conftest.$ac_ext -LIBS=$ac_check_lib_save_LIBS -fi -{ echo "$as_me:$LINENO: result: $ac_cv_lib_sqlite3_sqlite3_close" >&5 -echo "${ECHO_T}$ac_cv_lib_sqlite3_sqlite3_close" >&6; } -if test $ac_cv_lib_sqlite3_sqlite3_close = yes; then - - triton_lib_sqlite="yes" - if test -z "$sqlite_dir" -o ! -d "$sqlite_dir"; then - TRITON_SQLITE_LIBS="-lsqlite3" - else - TRITON_SQLITE_INCLUDES="-I$sqlite_dir/include" - TRITON_SQLITE_LIBS="-L$sqlite_dir/lib -lsqlite3" - fi - -fi - -else - { echo "$as_me:$LINENO: result: unsupported SQLite version" >&5 -echo "${ECHO_T}unsupported SQLite version" >&6; } -fi -rm -f conftest* - - -fi - - - - CPPFLAGS="$save_CPPFLAGS" - LDFLAGS="$save_LDFLAGS" - - fi - - if test -z "$triton_lib_sqlite"; then - - if test -n "$PKG_CONFIG"; then - { echo "$as_me:$LINENO: checking sqlite library version (via pkg-config)" >&5 -echo $ECHO_N "checking sqlite library version (via pkg-config)... $ECHO_C" >&6; } - sqlite_version=`$PKG_CONFIG $SQLITE_PKGNAME --modversion --silence-errors` - - if test -n "$sqlite_version"; then - - sqlite_major=`expr $sqlite_version : '\([0-9]*\)'` - sqlite_minor=`expr $sqlite_version : '[0-9]*\.\([0-9]*\)'` - sqlite_micro=`expr $sqlite_version : '[0-9]*\.[0-9]*\.\([0-9]*\)'` - if test -z "$sqlite_micro"; then - sqlite_micro=0 - fi - sqlite_ver_num=`expr $sqlite_major \* 1000000 \ - \+ $sqlite_minor \* 1000 \ - \+ $sqlite_micro` - - - if test "$sqlite_ver_num" -ge "$sqlite_min_ver_num"; then - { echo "$as_me:$LINENO: result: $sqlite_version" >&5 -echo "${ECHO_T}$sqlite_version" >&6; } - triton_lib_sqlite="yes" - TRITON_SQLITE_INCLUDES="`$PKG_CONFIG $SQLITE_PKGNAME --cflags`" - TRITON_SQLITE_LIBS="`$PKG_CONFIG $SQLITE_PKGNAME --libs`" - else - { echo "$as_me:$LINENO: result: none or unsupported $sqlite_version" >&5 -echo "${ECHO_T}none or unsupported $sqlite_version" >&6; } - fi - fi - fi - - if test -z "$triton_lib_sqlite"; then - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } - fi - - fi - -# if test -z "$triton_lib_sqlite"; then -# TRITON_DOWNLOAD_SQLITE -# fi - if test -n "$triton_lib_sqlite"; then - BUILD_OSD=1 - fi - -fi - - - - - - - - -ac_config_files="$ac_config_files Makefile src/common/module.mk src/common/tests/module.mk src/common/resources/timer/test/module.mk src/common/resources/timer/module.mk src/common/resources/scheduling/module.mk src/common/resources/scheduling/test/module.mk src/net/module.mk src/net/mpi/module.mk src/net/mpi/test/module.mk src/remote/module.mk src/aesop/module.mk src/aesop/parser/module.mk src/aesop/examples/module.mk src/aesop/parser/tests/remote/module.mk src/aesop/parser/tests/blocking/module.mk" - -cat >confcache <<\_ACEOF -# This file is a shell script that caches the results of configure -# tests run on this system so they can be shared between configure -# scripts and configure runs, see configure's option --config-cache. -# It is not useful on other systems. If it contains results you don't -# want to keep, you may remove or edit it. -# -# config.status only pays attention to the cache file if you give it -# the --recheck option to rerun configure. -# -# `ac_cv_env_foo' variables (set or unset) will be overridden when -# loading this file, other *unset* `ac_cv_foo' will be assigned the -# following values. - -_ACEOF - -# The following way of writing the cache mishandles newlines in values, -# but we know of no workaround that is simple, portable, and efficient. -# So, we kill variables containing newlines. -# Ultrix sh set writes to stderr and can't be redirected directly, -# and sets the high bit in the cache file unless we assign to the vars. -( - for ac_var in `(set) 2>&1 | sed -n 's/^\([a-zA-Z_][a-zA-Z0-9_]*\)=.*/\1/p'`; do - eval ac_val=\$$ac_var - case $ac_val in #( - *${as_nl}*) - case $ac_var in #( - *_cv_*) { echo "$as_me:$LINENO: WARNING: Cache variable $ac_var contains a newline." >&5 -echo "$as_me: WARNING: Cache variable $ac_var contains a newline." >&2;} ;; - esac - case $ac_var in #( - _ | IFS | as_nl) ;; #( - *) $as_unset $ac_var ;; - esac ;; - esac - done - - (set) 2>&1 | - case $as_nl`(ac_space=' '; set) 2>&1` in #( - *${as_nl}ac_space=\ *) - # `set' does not quote correctly, so add quotes (double-quote - # substitution turns \\\\ into \\, and sed turns \\ into \). - sed -n \ - "s/'/'\\\\''/g; - s/^\\([_$as_cr_alnum]*_cv_[_$as_cr_alnum]*\\)=\\(.*\\)/\\1='\\2'/p" - ;; #( - *) - # `set' quotes correctly as required by POSIX, so do not add quotes. - sed -n "/^[_$as_cr_alnum]*_cv_[_$as_cr_alnum]*=/p" - ;; - esac | - sort -) | - sed ' - /^ac_cv_env_/b end - t clear - :clear - s/^\([^=]*\)=\(.*[{}].*\)$/test "${\1+set}" = set || &/ - t end - s/^\([^=]*\)=\(.*\)$/\1=${\1=\2}/ - :end' >>confcache -if diff "$cache_file" confcache >/dev/null 2>&1; then :; else - if test -w "$cache_file"; then - test "x$cache_file" != "x/dev/null" && - { echo "$as_me:$LINENO: updating cache $cache_file" >&5 -echo "$as_me: updating cache $cache_file" >&6;} - cat confcache >$cache_file - else - { echo "$as_me:$LINENO: not updating unwritable cache $cache_file" >&5 -echo "$as_me: not updating unwritable cache $cache_file" >&6;} - fi -fi -rm -f confcache - -test "x$prefix" = xNONE && prefix=$ac_default_prefix -# Let make expand exec_prefix. -test "x$exec_prefix" = xNONE && exec_prefix='${prefix}' - -DEFS=-DHAVE_CONFIG_H - -ac_libobjs= -ac_ltlibobjs= -for ac_i in : $LIB@&t@OBJS; do test "x$ac_i" = x: && continue - # 1. Remove the extension, and $U if already installed. - ac_script='s/\$U\././;s/\.o$//;s/\.obj$//' - ac_i=`echo "$ac_i" | sed "$ac_script"` - # 2. Prepend LIBOBJDIR. When used with automake>=1.10 LIBOBJDIR - # will be set to the directory where LIBOBJS objects are built. - ac_libobjs="$ac_libobjs \${LIBOBJDIR}$ac_i\$U.$ac_objext" - ac_ltlibobjs="$ac_ltlibobjs \${LIBOBJDIR}$ac_i"'$U.lo' -done -LIB@&t@OBJS=$ac_libobjs - -LTLIBOBJS=$ac_ltlibobjs - - - -: ${CONFIG_STATUS=./config.status} -ac_clean_files_save=$ac_clean_files -ac_clean_files="$ac_clean_files $CONFIG_STATUS" -{ echo "$as_me:$LINENO: creating $CONFIG_STATUS" >&5 -echo "$as_me: creating $CONFIG_STATUS" >&6;} -cat >$CONFIG_STATUS <<_ACEOF -#! $SHELL -# Generated by $as_me. -# Run this file to recreate the current configuration. -# Compiler output produced by configure, useful for debugging -# configure, is in config.log if it exists. - -debug=false -ac_cs_recheck=false -ac_cs_silent=false -SHELL=\${CONFIG_SHELL-$SHELL} -_ACEOF - -cat >>$CONFIG_STATUS <<\_ACEOF -## --------------------- ## -## M4sh Initialization. ## -## --------------------- ## - -# Be more Bourne compatible -DUALCASE=1; export DUALCASE # for MKS sh -if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then - emulate sh - NULLCMD=: - # Zsh 3.x and 4.x performs word splitting on ${1+"$@"}, which - # is contrary to our usage. Disable this feature. - alias -g '${1+"$@"}'='"$@"' - setopt NO_GLOB_SUBST -else - case `(set -o) 2>/dev/null` in - *posix*) set -o posix ;; -esac - -fi - - - - -# PATH needs CR -# Avoid depending upon Character Ranges. -as_cr_letters='abcdefghijklmnopqrstuvwxyz' -as_cr_LETTERS='ABCDEFGHIJKLMNOPQRSTUVWXYZ' -as_cr_Letters=$as_cr_letters$as_cr_LETTERS -as_cr_digits='0123456789' -as_cr_alnum=$as_cr_Letters$as_cr_digits - -# The user is always right. -if test "${PATH_SEPARATOR+set}" != set; then - echo "#! /bin/sh" >conf$$.sh - echo "exit 0" >>conf$$.sh - chmod +x conf$$.sh - if (PATH="/nonexistent;."; conf$$.sh) >/dev/null 2>&1; then - PATH_SEPARATOR=';' - else - PATH_SEPARATOR=: - fi - rm -f conf$$.sh -fi - -# Support unset when possible. -if ( (MAIL=60; unset MAIL) || exit) >/dev/null 2>&1; then - as_unset=unset -else - as_unset=false -fi - - -# IFS -# We need space, tab and new line, in precisely that order. Quoting is -# there to prevent editors from complaining about space-tab. -# (If _AS_PATH_WALK were called with IFS unset, it would disable word -# splitting by setting IFS to empty value.) -as_nl=' -' -IFS=" "" $as_nl" - -# Find who we are. Look in the path if we contain no directory separator. -case $0 in - *[\\/]* ) as_myself=$0 ;; - *) as_save_IFS=$IFS; IFS=$PATH_SEPARATOR -for as_dir in $PATH -do - IFS=$as_save_IFS - test -z "$as_dir" && as_dir=. - test -r "$as_dir/$0" && as_myself=$as_dir/$0 && break -done -IFS=$as_save_IFS - - ;; -esac -# We did not find ourselves, most probably we were run as `sh COMMAND' -# in which case we are not to be found in the path. -if test "x$as_myself" = x; then - as_myself=$0 -fi -if test ! -f "$as_myself"; then - echo "$as_myself: error: cannot find myself; rerun with an absolute file name" >&2 - { (exit 1); exit 1; } -fi - -# Work around bugs in pre-3.0 UWIN ksh. -for as_var in ENV MAIL MAILPATH -do ($as_unset $as_var) >/dev/null 2>&1 && $as_unset $as_var -done -PS1='$ ' -PS2='> ' -PS4='+ ' - -# NLS nuisances. -for as_var in \ - LANG LANGUAGE LC_ADDRESS LC_ALL LC_COLLATE LC_CTYPE LC_IDENTIFICATION \ - LC_MEASUREMENT LC_MESSAGES LC_MONETARY LC_NAME LC_NUMERIC LC_PAPER \ - LC_TELEPHONE LC_TIME -do - if (set +x; test -z "`(eval $as_var=C; export $as_var) 2>&1`"); then - eval $as_var=C; export $as_var - else - ($as_unset $as_var) >/dev/null 2>&1 && $as_unset $as_var - fi -done - -# Required to use basename. -if expr a : '\(a\)' >/dev/null 2>&1 && - test "X`expr 00001 : '.*\(...\)'`" = X001; then - as_expr=expr -else - as_expr=false -fi - -if (basename -- /) >/dev/null 2>&1 && test "X`basename -- / 2>&1`" = "X/"; then - as_basename=basename -else - as_basename=false -fi - - -# Name of the executable. -as_me=`$as_basename -- "$0" || -$as_expr X/"$0" : '.*/\([^/][^/]*\)/*$' \| \ - X"$0" : 'X\(//\)$' \| \ - X"$0" : 'X\(/\)' \| . 2>/dev/null || -echo X/"$0" | - sed '/^.*\/\([^/][^/]*\)\/*$/{ - s//\1/ - q - } - /^X\/\(\/\/\)$/{ - s//\1/ - q - } - /^X\/\(\/\).*/{ - s//\1/ - q - } - s/.*/./; q'` - -# CDPATH. -$as_unset CDPATH - - - - as_lineno_1=$LINENO - as_lineno_2=$LINENO - test "x$as_lineno_1" != "x$as_lineno_2" && - test "x`expr $as_lineno_1 + 1`" = "x$as_lineno_2" || { - - # Create $as_me.lineno as a copy of $as_myself, but with $LINENO - # uniformly replaced by the line number. The first 'sed' inserts a - # line-number line after each line using $LINENO; the second 'sed' - # does the real work. The second script uses 'N' to pair each - # line-number line with the line containing $LINENO, and appends - # trailing '-' during substitution so that $LINENO is not a special - # case at line end. - # (Raja R Harinath suggested sed '=', and Paul Eggert wrote the - # scripts with optimization help from Paolo Bonzini. Blame Lee - # E. McMahon (1931-1989) for sed's syntax. :-) - sed -n ' - p - /[$]LINENO/= - ' <$as_myself | - sed ' - s/[$]LINENO.*/&-/ - t lineno - b - :lineno - N - :loop - s/[$]LINENO\([^'$as_cr_alnum'_].*\n\)\(.*\)/\2\1\2/ - t loop - s/-\n.*// - ' >$as_me.lineno && - chmod +x "$as_me.lineno" || - { echo "$as_me: error: cannot create $as_me.lineno; rerun with a POSIX shell" >&2 - { (exit 1); exit 1; }; } - - # Don't try to exec as it changes $[0], causing all sort of problems - # (the dirname of $[0] is not the place where we might find the - # original and so on. Autoconf is especially sensitive to this). - . "./$as_me.lineno" - # Exit status is that of the last command. - exit -} - - -if (as_dir=`dirname -- /` && test "X$as_dir" = X/) >/dev/null 2>&1; then - as_dirname=dirname -else - as_dirname=false -fi - -ECHO_C= ECHO_N= ECHO_T= -case `echo -n x` in --n*) - case `echo 'x\c'` in - *c*) ECHO_T=' ';; # ECHO_T is single tab character. - *) ECHO_C='\c';; - esac;; -*) - ECHO_N='-n';; -esac - -if expr a : '\(a\)' >/dev/null 2>&1 && - test "X`expr 00001 : '.*\(...\)'`" = X001; then - as_expr=expr -else - as_expr=false -fi - -rm -f conf$$ conf$$.exe conf$$.file -if test -d conf$$.dir; then - rm -f conf$$.dir/conf$$.file -else - rm -f conf$$.dir - mkdir conf$$.dir -fi -echo >conf$$.file -if ln -s conf$$.file conf$$ 2>/dev/null; then - as_ln_s='ln -s' - # ... but there are two gotchas: - # 1) On MSYS, both `ln -s file dir' and `ln file dir' fail. - # 2) DJGPP < 2.04 has no symlinks; `ln -s' creates a wrapper executable. - # In both cases, we have to default to `cp -p'. - ln -s conf$$.file conf$$.dir 2>/dev/null && test ! -f conf$$.exe || - as_ln_s='cp -p' -elif ln conf$$.file conf$$ 2>/dev/null; then - as_ln_s=ln -else - as_ln_s='cp -p' -fi -rm -f conf$$ conf$$.exe conf$$.dir/conf$$.file conf$$.file -rmdir conf$$.dir 2>/dev/null - -if mkdir -p . 2>/dev/null; then - as_mkdir_p=: -else - test -d ./-p && rmdir ./-p - as_mkdir_p=false -fi - -if test -x / >/dev/null 2>&1; then - as_test_x='test -x' -else - if ls -dL / >/dev/null 2>&1; then - as_ls_L_option=L - else - as_ls_L_option= - fi - as_test_x=' - eval sh -c '\'' - if test -d "$1"; then - test -d "$1/."; - else - case $1 in - -*)set "./$1";; - esac; - case `ls -ld'$as_ls_L_option' "$1" 2>/dev/null` in - ???[sx]*):;;*)false;;esac;fi - '\'' sh - ' -fi -as_executable_p=$as_test_x - -# Sed expression to map a string onto a valid CPP name. -as_tr_cpp="eval sed 'y%*$as_cr_letters%P$as_cr_LETTERS%;s%[^_$as_cr_alnum]%_%g'" - -# Sed expression to map a string onto a valid variable name. -as_tr_sh="eval sed 'y%*+%pp%;s%[^_$as_cr_alnum]%_%g'" - - -exec 6>&1 - -# Save the log message, to keep $[0] and so on meaningful, and to -# report actual input values of CONFIG_FILES etc. instead of their -# values after options handling. -ac_log=" -This file was extended by triton $as_me 0.1.1, which was -generated by GNU Autoconf 2.61. Invocation command line was - - CONFIG_FILES = $CONFIG_FILES - CONFIG_HEADERS = $CONFIG_HEADERS - CONFIG_LINKS = $CONFIG_LINKS - CONFIG_COMMANDS = $CONFIG_COMMANDS - $ $0 $@ - -on `(hostname || uname -n) 2>/dev/null | sed 1q` -" - -_ACEOF - -cat >>$CONFIG_STATUS <<_ACEOF -# Files that config.status was made for. -config_files="$ac_config_files" -config_headers="$ac_config_headers" - -_ACEOF - -cat >>$CONFIG_STATUS <<\_ACEOF -ac_cs_usage="\ -\`$as_me' instantiates files from templates according to the -current configuration. - -Usage: $0 [OPTIONS] [FILE]... - - -h, --help print this help, then exit - -V, --version print version number and configuration settings, then exit - -q, --quiet do not print progress messages - -d, --debug don't remove temporary files - --recheck update $as_me by reconfiguring in the same conditions - --file=FILE[:TEMPLATE] - instantiate the configuration file FILE - --header=FILE[:TEMPLATE] - instantiate the configuration header FILE - -Configuration files: -$config_files - -Configuration headers: -$config_headers - -Report bugs to <[email protected]>." - -_ACEOF -cat >>$CONFIG_STATUS <<_ACEOF -ac_cs_version="\\ -triton config.status 0.1.1 -configured by $0, generated by GNU Autoconf 2.61, - with options \\"`echo "$ac_configure_args" | sed 's/^ //; s/[\\""\`\$]/\\\\&/g'`\\" - -Copyright (C) 2006 Free Software Foundation, Inc. -This config.status script is free software; the Free Software Foundation -gives unlimited permission to copy, distribute and modify it." - -ac_pwd='$ac_pwd' -srcdir='$srcdir' -INSTALL='$INSTALL' -_ACEOF - -cat >>$CONFIG_STATUS <<\_ACEOF -# If no file are specified by the user, then we need to provide default -# value. By we need to know if files were specified by the user. -ac_need_defaults=: -while test $# != 0 -do - case $1 in - --*=*) - ac_option=`expr "X$1" : 'X\([^=]*\)='` - ac_optarg=`expr "X$1" : 'X[^=]*=\(.*\)'` - ac_shift=: - ;; - *) - ac_option=$1 - ac_optarg=$2 - ac_shift=shift - ;; - esac - - case $ac_option in - # Handling of the options. - -recheck | --recheck | --rechec | --reche | --rech | --rec | --re | --r) - ac_cs_recheck=: ;; - --version | --versio | --versi | --vers | --ver | --ve | --v | -V ) - echo "$ac_cs_version"; exit ;; - --debug | --debu | --deb | --de | --d | -d ) - debug=: ;; - --file | --fil | --fi | --f ) - $ac_shift - CONFIG_FILES="$CONFIG_FILES $ac_optarg" - ac_need_defaults=false;; - --header | --heade | --head | --hea ) - $ac_shift - CONFIG_HEADERS="$CONFIG_HEADERS $ac_optarg" - ac_need_defaults=false;; - --he | --h) - # Conflict between --help and --header - { echo "$as_me: error: ambiguous option: $1 -Try \`$0 --help' for more information." >&2 - { (exit 1); exit 1; }; };; - --help | --hel | -h ) - echo "$ac_cs_usage"; exit ;; - -q | -quiet | --quiet | --quie | --qui | --qu | --q \ - | -silent | --silent | --silen | --sile | --sil | --si | --s) - ac_cs_silent=: ;; - - # This is an error. - -*) { echo "$as_me: error: unrecognized option: $1 -Try \`$0 --help' for more information." >&2 - { (exit 1); exit 1; }; } ;; - - *) ac_config_targets="$ac_config_targets $1" - ac_need_defaults=false ;; - - esac - shift -done - -ac_configure_extra_args= - -if $ac_cs_silent; then - exec 6>/dev/null - ac_configure_extra_args="$ac_configure_extra_args --silent" -fi - -_ACEOF -cat >>$CONFIG_STATUS <<_ACEOF -if \$ac_cs_recheck; then - echo "running CONFIG_SHELL=$SHELL $SHELL $0 "$ac_configure_args \$ac_configure_extra_args " --no-create --no-recursion" >&6 - CONFIG_SHELL=$SHELL - export CONFIG_SHELL - exec $SHELL "$0"$ac_configure_args \$ac_configure_extra_args --no-create --no-recursion -fi - -_ACEOF -cat >>$CONFIG_STATUS <<\_ACEOF -exec 5>>config.log -{ - echo - sed 'h;s/./-/g;s/^.../@%:@@%:@ /;s/...$/ @%:@@%:@/;p;x;p;x' <<_ASBOX -@%:@@%:@ Running $as_me. @%:@@%:@ -_ASBOX - echo "$ac_log" -} >&5 - -_ACEOF -cat >>$CONFIG_STATUS <<_ACEOF -_ACEOF - -cat >>$CONFIG_STATUS <<\_ACEOF - -# Handling of arguments. -for ac_config_target in $ac_config_targets -do - case $ac_config_target in - "triton-config.h") CONFIG_HEADERS="$CONFIG_HEADERS triton-config.h" ;; - "Makefile") CONFIG_FILES="$CONFIG_FILES Makefile" ;; - "src/common/module.mk") CONFIG_FILES="$CONFIG_FILES src/common/module.mk" ;; - "src/common/tests/module.mk") CONFIG_FILES="$CONFIG_FILES src/common/tests/module.mk" ;; - "src/common/resources/timer/test/module.mk") CONFIG_FILES="$CONFIG_FILES src/common/resources/timer/test/module.mk" ;; - "src/common/resources/timer/module.mk") CONFIG_FILES="$CONFIG_FILES src/common/resources/timer/module.mk" ;; - "src/common/resources/scheduling/module.mk") CONFIG_FILES="$CONFIG_FILES src/common/resources/scheduling/module.mk" ;; - "src/common/resources/scheduling/test/module.mk") CONFIG_FILES="$CONFIG_FILES src/common/resources/scheduling/test/module.mk" ;; - "src/net/module.mk") CONFIG_FILES="$CONFIG_FILES src/net/module.mk" ;; - "src/net/mpi/module.mk") CONFIG_FILES="$CONFIG_FILES src/net/mpi/module.mk" ;; - "src/net/mpi/test/module.mk") CONFIG_FILES="$CONFIG_FILES src/net/mpi/test/module.mk" ;; - "src/remote/module.mk") CONFIG_FILES="$CONFIG_FILES src/remote/module.mk" ;; - "src/aesop/module.mk") CONFIG_FILES="$CONFIG_FILES src/aesop/module.mk" ;; - "src/aesop/parser/module.mk") CONFIG_FILES="$CONFIG_FILES src/aesop/parser/module.mk" ;; - "src/aesop/examples/module.mk") CONFIG_FILES="$CONFIG_FILES src/aesop/examples/module.mk" ;; - "src/aesop/parser/tests/remote/module.mk") CONFIG_FILES="$CONFIG_FILES src/aesop/parser/tests/remote/module.mk" ;; - "src/aesop/parser/tests/blocking/module.mk") CONFIG_FILES="$CONFIG_FILES src/aesop/parser/tests/blocking/module.mk" ;; - - *) { { echo "$as_me:$LINENO: error: invalid argument: $ac_config_target" >&5 -echo "$as_me: error: invalid argument: $ac_config_target" >&2;} - { (exit 1); exit 1; }; };; - esac -done - - -# If the user did not use the arguments to specify the items to instantiate, -# then the envvar interface is used. Set only those that are not. -# We use the long form for the default assignment because of an extremely -# bizarre bug on SunOS 4.1.3. -if $ac_need_defaults; then - test "${CONFIG_FILES+set}" = set || CONFIG_FILES=$config_files - test "${CONFIG_HEADERS+set}" = set || CONFIG_HEADERS=$config_headers -fi - -# Have a temporary directory for convenience. Make it in the build tree -# simply because there is no reason against having it here, and in addition, -# creating and moving files from /tmp can sometimes cause problems. -# Hook for its removal unless debugging. -# Note that there is a small window in which the directory will not be cleaned: -# after its creation but before its name has been assigned to `$tmp'. -$debug || -{ - tmp= - trap 'exit_status=$? - { test -z "$tmp" || test ! -d "$tmp" || rm -fr "$tmp"; } && exit $exit_status -' 0 - trap '{ (exit 1); exit 1; }' 1 2 13 15 -} -# Create a (secure) tmp directory for tmp files. - -{ - tmp=`(umask 077 && mktemp -d "./confXXXXXX") 2>/dev/null` && - test -n "$tmp" && test -d "$tmp" -} || -{ - tmp=./conf$$-$RANDOM - (umask 077 && mkdir "$tmp") -} || -{ - echo "$me: cannot create a temporary directory in ." >&2 - { (exit 1); exit 1; } -} - -# -# Set up the sed scripts for CONFIG_FILES section. -# - -# No need to generate the scripts if there are no CONFIG_FILES. -# This happens for instance when ./config.status config.h -if test -n "$CONFIG_FILES"; then - -_ACEOF - - - -ac_delim='%!_!# ' -for ac_last_try in false false false false false :; do - cat >conf$$subs.sed <<_ACEOF -SHELL!$SHELL$ac_delim -PATH_SEPARATOR!$PATH_SEPARATOR$ac_delim -PACKAGE_NAME!$PACKAGE_NAME$ac_delim -PACKAGE_TARNAME!$PACKAGE_TARNAME$ac_delim -PACKAGE_VERSION!$PACKAGE_VERSION$ac_delim -PACKAGE_STRING!$PACKAGE_STRING$ac_delim -PACKAGE_BUGREPORT!$PACKAGE_BUGREPORT$ac_delim -exec_prefix!$exec_prefix$ac_delim -prefix!$prefix$ac_delim -program_transform_name!$program_transform_name$ac_delim -bindir!$bindir$ac_delim -sbindir!$sbindir$ac_delim -libexecdir!$libexecdir$ac_delim -datarootdir!$datarootdir$ac_delim -datadir!$datadir$ac_delim -sysconfdir!$sysconfdir$ac_delim -sharedstatedir!$sharedstatedir$ac_delim -localstatedir!$localstatedir$ac_delim -includedir!$includedir$ac_delim -oldincludedir!$oldincludedir$ac_delim -docdir!$docdir$ac_delim -infodir!$infodir$ac_delim -htmldir!$htmldir$ac_delim -dvidir!$dvidir$ac_delim -pdfdir!$pdfdir$ac_delim -psdir!$psdir$ac_delim -libdir!$libdir$ac_delim -localedir!$localedir$ac_delim -mandir!$mandir$ac_delim -DEFS!$DEFS$ac_delim -ECHO_C!$ECHO_C$ac_delim -ECHO_N!$ECHO_N$ac_delim -ECHO_T!$ECHO_T$ac_delim -LIBS!$LIBS$ac_delim -build_alias!$build_alias$ac_delim -host_alias!$host_alias$ac_delim -target_alias!$target_alias$ac_delim -TRITON_VERSION!$TRITON_VERSION$ac_delim -INSTALL_PROGRAM!$INSTALL_PROGRAM$ac_delim -INSTALL_SCRIPT!$INSTALL_SCRIPT$ac_delim -INSTALL_DATA!$INSTALL_DATA$ac_delim -CC!$CC$ac_delim -CFLAGS!$CFLAGS$ac_delim -LDFLAGS!$LDFLAGS$ac_delim -CPPFLAGS!$CPPFLAGS$ac_delim -ac_ct_CC!$ac_ct_CC$ac_delim -EXEEXT!$EXEEXT$ac_delim -OBJEXT!$OBJEXT$ac_delim -CPP!$CPP$ac_delim -GREP!$GREP$ac_delim -EGREP!$EGREP$ac_delim -GHC!$GHC$ac_delim -DB_CFLAGS!$DB_CFLAGS$ac_delim -DB_LIB!$DB_LIB$ac_delim -MPICC!$MPICC$ac_delim -MPICFLAGS!$MPICFLAGS$ac_delim -MPILDFLAGS!$MPILDFLAGS$ac_delim -MPILIBS!$MPILIBS$ac_delim -BUILD_MPI!$BUILD_MPI$ac_delim -BUILD_ABSOLUTE_TOP!$BUILD_ABSOLUTE_TOP$ac_delim -SRC_RELATIVE_TOP!$SRC_RELATIVE_TOP$ac_delim -SRC_ABSOLUTE_TOP!$SRC_ABSOLUTE_TOP$ac_delim -QUIET_COMPILE!$QUIET_COMPILE$ac_delim -STRICT_CFLAGS!$STRICT_CFLAGS$ac_delim -AE_DEBUG!$AE_DEBUG$ac_delim -ENABLE_COVERAGE!$ENABLE_COVERAGE$ac_delim -LIBCFLAGS!$LIBCFLAGS$ac_delim -THREAD_LIB!$THREAD_LIB$ac_delim -TRITON_SQLITE_INCLUDES!$TRITON_SQLITE_INCLUDES$ac_delim -TRITON_SQLITE_LIBS!$TRITON_SQLITE_LIBS$ac_delim -BUILD_OSD!$BUILD_OSD$ac_delim -LIB@&t@OBJS!$LIB@&t@OBJS$ac_delim -LTLIBOBJS!$LTLIBOBJS$ac_delim -_ACEOF - - if test `sed -n "s/.*$ac_delim\$/X/p" conf$$subs.sed | grep -c X` = 73; then - break - elif $ac_last_try; then - { { echo "$as_me:$LINENO: error: could not make $CONFIG_STATUS" >&5 -echo "$as_me: error: could not make $CONFIG_STATUS" >&2;} - { (exit 1); exit 1; }; } - else - ac_delim="$ac_delim!$ac_delim _$ac_delim!! " - fi -done - -ac_eof=`sed -n '/^CEOF[0-9]*$/s/CEOF/0/p' conf$$subs.sed` -if test -n "$ac_eof"; then - ac_eof=`echo "$ac_eof" | sort -nru | sed 1q` - ac_eof=`expr $ac_eof + 1` -fi - -cat >>$CONFIG_STATUS <<_ACEOF -cat >"\$tmp/subs-1.sed" <<\CEOF$ac_eof -/@[a-zA-Z_][a-zA-Z_0-9]*@/!b end -_ACEOF -sed ' -s/[,\\&]/\\&/g; s/@/@|#_!!_#|/g -s/^/s,@/; s/!/@,|#_!!_#|/ -:n -t n -s/'"$ac_delim"'$/,g/; t -s/$/\\/; p -N; s/^.*\n//; s/[,\\&]/\\&/g; s/@/@|#_!!_#|/g; b n -' >>$CONFIG_STATUS <conf$$subs.sed -rm -f conf$$subs.sed -cat >>$CONFIG_STATUS <<_ACEOF -:end -s/|#_!!_#|//g -CEOF$ac_eof -_ACEOF - - -# VPATH may cause trouble with some makes, so we remove $(srcdir), -# ${srcdir} and @srcdir@ from VPATH if srcdir is ".", strip leading and -# trailing colons and then remove the whole line if VPATH becomes empty -# (actually we leave an empty line to preserve line numbers). -if test "x$srcdir" = x.; then - ac_vpsub='/^[ ]*VPATH[ ]*=/{ -s/:*\$(srcdir):*/:/ -s/:*\${srcdir}:*/:/ -s/:*@srcdir@:*/:/ -s/^\([^=]*=[ ]*\):*/\1/ -s/:*$// -s/^[^=]*=[ ]*$// -}' -fi - -cat >>$CONFIG_STATUS <<\_ACEOF -fi # test -n "$CONFIG_FILES" - - -for ac_tag in :F $CONFIG_FILES :H $CONFIG_HEADERS -do - case $ac_tag in - :[FHLC]) ac_mode=$ac_tag; continue;; - esac - case $ac_mode$ac_tag in - :[FHL]*:*);; - :L* | :C*:*) { { echo "$as_me:$LINENO: error: Invalid tag $ac_tag." >&5 -echo "$as_me: error: Invalid tag $ac_tag." >&2;} - { (exit 1); exit 1; }; };; - :[FH]-) ac_tag=-:-;; - :[FH]*) ac_tag=$ac_tag:$ac_tag.in;; - esac - ac_save_IFS=$IFS - IFS=: - set x $ac_tag - IFS=$ac_save_IFS - shift - ac_file=$1 - shift - - case $ac_mode in - :L) ac_source=$1;; - :[FH]) - ac_file_inputs= - for ac_f - do - case $ac_f in - -) ac_f="$tmp/stdin";; - *) # Look for the file first in the build tree, then in the source tree - # (if the path is not absolute). The absolute path cannot be DOS-style, - # because $ac_f cannot contain `:'. - test -f "$ac_f" || - case $ac_f in - [\\/$]*) false;; - *) test -f "$srcdir/$ac_f" && ac_f="$srcdir/$ac_f";; - esac || - { { echo "$as_me:$LINENO: error: cannot find input file: $ac_f" >&5 -echo "$as_me: error: cannot find input file: $ac_f" >&2;} - { (exit 1); exit 1; }; };; - esac - ac_file_inputs="$ac_file_inputs $ac_f" - done - - # Let's still pretend it is `configure' which instantiates (i.e., don't - # use $as_me), people would be surprised to read: - # /* config.h. Generated by config.status. */ - configure_input="Generated from "`IFS=: - echo $* | sed 's|^[^:]*/||;s|:[^:]*/|, |g'`" by configure." - if test x"$ac_file" != x-; then - configure_input="$ac_file. $configure_input" - { echo "$as_me:$LINENO: creating $ac_file" >&5 -echo "$as_me: creating $ac_file" >&6;} - fi - - case $ac_tag in - *:-:* | *:-) cat >"$tmp/stdin";; - esac - ;; - esac - - ac_dir=`$as_dirname -- "$ac_file" || -$as_expr X"$ac_file" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \ - X"$ac_file" : 'X\(//\)[^/]' \| \ - X"$ac_file" : 'X\(//\)$' \| \ - X"$ac_file" : 'X\(/\)' \| . 2>/dev/null || -echo X"$ac_file" | - sed '/^X\(.*[^/]\)\/\/*[^/][^/]*\/*$/{ - s//\1/ - q - } - /^X\(\/\/\)[^/].*/{ - s//\1/ - q - } - /^X\(\/\/\)$/{ - s//\1/ - q - } - /^X\(\/\).*/{ - s//\1/ - q - } - s/.*/./; q'` - { as_dir="$ac_dir" - case $as_dir in #( - -*) as_dir=./$as_dir;; - esac - test -d "$as_dir" || { $as_mkdir_p && mkdir -p "$as_dir"; } || { - as_dirs= - while :; do - case $as_dir in #( - *\'*) as_qdir=`echo "$as_dir" | sed "s/'/'\\\\\\\\''/g"`;; #( - *) as_qdir=$as_dir;; - esac - as_dirs="'$as_qdir' $as_dirs" - as_dir=`$as_dirname -- "$as_dir" || -$as_expr X"$as_dir" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \ - X"$as_dir" : 'X\(//\)[^/]' \| \ - X"$as_dir" : 'X\(//\)$' \| \ - X"$as_dir" : 'X\(/\)' \| . 2>/dev/null || -echo X"$as_dir" | - sed '/^X\(.*[^/]\)\/\/*[^/][^/]*\/*$/{ - s//\1/ - q - } - /^X\(\/\/\)[^/].*/{ - s//\1/ - q - } - /^X\(\/\/\)$/{ - s//\1/ - q - } - /^X\(\/\).*/{ - s//\1/ - q - } - s/.*/./; q'` - test -d "$as_dir" && break - done - test -z "$as_dirs" || eval "mkdir $as_dirs" - } || test -d "$as_dir" || { { echo "$as_me:$LINENO: error: cannot create directory $as_dir" >&5 -echo "$as_me: error: cannot create directory $as_dir" >&2;} - { (exit 1); exit 1; }; }; } - ac_builddir=. - -case "$ac_dir" in -.) ac_dir_suffix= ac_top_builddir_sub=. ac_top_build_prefix= ;; -*) - ac_dir_suffix=/`echo "$ac_dir" | sed 's,^\.[\\/],,'` - # A ".." for each directory in $ac_dir_suffix. - ac_top_builddir_sub=`echo "$ac_dir_suffix" | sed 's,/[^\\/]*,/..,g;s,/,,'` - case $ac_top_builddir_sub in - "") ac_top_builddir_sub=. ac_top_build_prefix= ;; - *) ac_top_build_prefix=$ac_top_builddir_sub/ ;; - esac ;; -esac -ac_abs_top_builddir=$ac_pwd -ac_abs_builddir=$ac_pwd$ac_dir_suffix -# for backward compatibility: -ac_top_builddir=$ac_top_build_prefix - -case $srcdir in - .) # We are building in place. - ac_srcdir=. - ac_top_srcdir=$ac_top_builddir_sub - ac_abs_top_srcdir=$ac_pwd ;; - [\\/]* | ?:[\\/]* ) # Absolute name. - ac_srcdir=$srcdir$ac_dir_suffix; - ac_top_srcdir=$srcdir - ac_abs_top_srcdir=$srcdir ;; - *) # Relative name. - ac_srcdir=$ac_top_build_prefix$srcdir$ac_dir_suffix - ac_top_srcdir=$ac_top_build_prefix$srcdir - ac_abs_top_srcdir=$ac_pwd/$srcdir ;; -esac -ac_abs_srcdir=$ac_abs_top_srcdir$ac_dir_suffix - - - case $ac_mode in - :F) - # - # CONFIG_FILE - # - - case $INSTALL in - [\\/$]* | ?:[\\/]* ) ac_INSTALL=$INSTALL ;; - *) ac_INSTALL=$ac_top_build_prefix$INSTALL ;; - esac -_ACEOF - -cat >>$CONFIG_STATUS <<\_ACEOF -# If the template does not know about datarootdir, expand it. -# FIXME: This hack should be removed a few years after 2.60. -ac_datarootdir_hack=; ac_datarootdir_seen= - -case `sed -n '/datarootdir/ { - p - q -} -/@datadir@/p -/@docdir@/p -/@infodir@/p -/@localedir@/p -/@mandir@/p -' $ac_file_inputs` in -*datarootdir*) ac_datarootdir_seen=yes;; -*@datadir@*|*@docdir@*|*@infodir@*|*@localedir@*|*@mandir@*) - { echo "$as_me:$LINENO: WARNING: $ac_file_inputs seems to ignore the --datarootdir setting" >&5 -echo "$as_me: WARNING: $ac_file_inputs seems to ignore the --datarootdir setting" >&2;} -_ACEOF -cat >>$CONFIG_STATUS <<_ACEOF - ac_datarootdir_hack=' - s&@datadir@&$datadir&g - s&@docdir@&$docdir&g - s&@infodir@&$infodir&g - s&@localedir@&$localedir&g - s&@mandir@&$mandir&g - s&\\\${datarootdir}&$datarootdir&g' ;; -esac -_ACEOF - -# Neutralize VPATH when `$srcdir' = `.'. -# Shell code in configure.ac might set extrasub. -# FIXME: do we really want to maintain this feature? -cat >>$CONFIG_STATUS <<_ACEOF - sed "$ac_vpsub -$extrasub -_ACEOF -cat >>$CONFIG_STATUS <<\_ACEOF -:t -/@[a-zA-Z_][a-zA-Z_0-9]*@/!b -s&@configure_input@&$configure_input&;t t -s&@top_builddir@&$ac_top_builddir_sub&;t t -s&@srcdir@&$ac_srcdir&;t t -s&@abs_srcdir@&$ac_abs_srcdir&;t t -s&@top_srcdir@&$ac_top_srcdir&;t t -s&@abs_top_srcdir@&$ac_abs_top_srcdir&;t t -s&@builddir@&$ac_builddir&;t t -s&@abs_builddir@&$ac_abs_builddir&;t t -s&@abs_top_builddir@&$ac_abs_top_builddir&;t t -s&@INSTALL@&$ac_INSTALL&;t t -$ac_datarootdir_hack -" $ac_file_inputs | sed -f "$tmp/subs-1.sed" >$tmp/out - -test -z "$ac_datarootdir_hack$ac_datarootdir_seen" && - { ac_out=`sed -n '/\${datarootdir}/p' "$tmp/out"`; test -n "$ac_out"; } && - { ac_out=`sed -n '/^[ ]*datarootdir[ ]*:*=/p' "$tmp/out"`; test -z "$ac_out"; } && - { echo "$as_me:$LINENO: WARNING: $ac_file contains a reference to the variable \`datarootdir' -which seems to be undefined. Please make sure it is defined." >&5 -echo "$as_me: WARNING: $ac_file contains a reference to the variable \`datarootdir' -which seems to be undefined. Please make sure it is defined." >&2;} - - rm -f "$tmp/stdin" - case $ac_file in - -) cat "$tmp/out"; rm -f "$tmp/out";; - *) rm -f "$ac_file"; mv "$tmp/out" $ac_file;; - esac - ;; - :H) - # - # CONFIG_HEADER - # -_ACEOF - -# Transform confdefs.h into a sed script `conftest.defines', that -# substitutes the proper values into config.h.in to produce config.h. -rm -f conftest.defines conftest.tail -# First, append a space to every undef/define line, to ease matching. -echo 's/$/ /' >conftest.defines -# Then, protect against being on the right side of a sed subst, or in -# an unquoted here document, in config.status. If some macros were -# called several times there might be several #defines for the same -# symbol, which is useless. But do not sort them, since the last -# AC_DEFINE must be honored. -ac_word_re=[_$as_cr_Letters][_$as_cr_alnum]* -# These sed commands are passed to sed as "A NAME B PARAMS C VALUE D", where -# NAME is the cpp macro being defined, VALUE is the value it is being given. -# PARAMS is the parameter list in the macro definition--in most cases, it's -# just an empty string. -ac_dA='s,^\\([ #]*\\)[^ ]*\\([ ]*' -ac_dB='\\)[ (].*,\\1define\\2' -ac_dC=' ' -ac_dD=' ,' - -uniq confdefs.h | - sed -n ' - t rset - :rset - s/^[ ]*#[ ]*define[ ][ ]*// - t ok - d - :ok - s/[\\&,]/\\&/g - s/^\('"$ac_word_re"'\)\(([^()]*)\)[ ]*\(.*\)/ '"$ac_dA"'\1'"$ac_dB"'\2'"${ac_dC}"'\3'"$ac_dD"'/p - s/^\('"$ac_word_re"'\)[ ]*\(.*\)/'"$ac_dA"'\1'"$ac_dB$ac_dC"'\2'"$ac_dD"'/p - ' >>conftest.defines - -# Remove the space that was appended to ease matching. -# Then replace #undef with comments. This is necessary, for -# example, in the case of _POSIX_SOURCE, which is predefined and required -# on some systems where configure will not decide to define it. -# (The regexp can be short, since the line contains either #define or #undef.) -echo 's/ $// -s,^[ #]*u.*,/* & */,' >>conftest.defines - -# Break up conftest.defines: -ac_max_sed_lines=50 - -# First sed command is: sed -f defines.sed $ac_file_inputs >"$tmp/out1" -# Second one is: sed -f defines.sed "$tmp/out1" >"$tmp/out2" -# Third one will be: sed -f defines.sed "$tmp/out2" >"$tmp/out1" -# et cetera. -ac_in='$ac_file_inputs' -ac_out='"$tmp/out1"' -ac_nxt='"$tmp/out2"' - -while : -do - # Write a here document: - cat >>$CONFIG_STATUS <<_ACEOF - # First, check the format of the line: - cat >"\$tmp/defines.sed" <<\\CEOF -/^[ ]*#[ ]*undef[ ][ ]*$ac_word_re[ ]*\$/b def -/^[ ]*#[ ]*define[ ][ ]*$ac_word_re[( ]/b def -b -:def -_ACEOF - sed ${ac_max_sed_lines}q conftest.defines >>$CONFIG_STATUS - echo 'CEOF - sed -f "$tmp/defines.sed"' "$ac_in >$ac_out" >>$CONFIG_STATUS - ac_in=$ac_out; ac_out=$ac_nxt; ac_nxt=$ac_in - sed 1,${ac_max_sed_lines}d conftest.defines >conftest.tail - grep . conftest.tail >/dev/null || break - rm -f conftest.defines - mv conftest.tail conftest.defines -done -rm -f conftest.defines conftest.tail - -echo "ac_result=$ac_in" >>$CONFIG_STATUS -cat >>$CONFIG_STATUS <<\_ACEOF - if test x"$ac_file" != x-; then - echo "/* $configure_input */" >"$tmp/config.h" - cat "$ac_result" >>"$tmp/config.h" - if diff $ac_file "$tmp/config.h" >/dev/null 2>&1; then - { echo "$as_me:$LINENO: $ac_file is unchanged" >&5 -echo "$as_me: $ac_file is unchanged" >&6;} - else - rm -f $ac_file - mv "$tmp/config.h" $ac_file - fi - else - echo "/* $configure_input */" - cat "$ac_result" - fi - rm -f "$tmp/out12" - ;; - - - esac - -done # for ac_tag - - -{ (exit 0); exit 0; } -_ACEOF -chmod +x $CONFIG_STATUS -ac_clean_files=$ac_clean_files_save - - -# configure is writing to config.log, and then calls config.status. -# config.status does its own redirection, appending to config.log. -# Unfortunately, on DOS this fails, as config.log is still kept open -# by configure, so config.status won't be able to write to it; its -# output is simply discarded. So we exec the FD to /dev/null, -# effectively closing config.log, so it can be properly (re)opened and -# appended to by config.status. When coming back to configure, we -# need to make the FD available again. -if test "$no_create" != yes; then - ac_cs_success=: - ac_config_status_args= - test "$silent" = yes && - ac_config_status_args="$ac_config_status_args --quiet" - exec 5>/dev/null - $SHELL $CONFIG_STATUS $ac_config_status_args || ac_cs_success=false - exec 5>>config.log - # Use ||, not &&, to avoid exiting from the if with $? = 1, which - # would make configure fail if this is the last instruction. - $ac_cs_success || { (exit 1); exit 1; } -fi - diff --git a/code/autom4te.cache/output.1 b/code/autom4te.cache/output.1 deleted file mode 100644 index 1845017..0000000 --- a/code/autom4te.cache/output.1 +++ /dev/null @@ -1,7798 +0,0 @@ -@%:@! /bin/sh -@%:@ Guess values for system-dependent variables and create Makefiles. -@%:@ Generated by GNU Autoconf 2.61 for triton 0.1.1. -@%:@ -@%:@ Report bugs to <[email protected]>. -@%:@ -@%:@ Copyright (C) 1992, 1993, 1994, 1995, 1996, 1998, 1999, 2000, 2001, -@%:@ 2002, 2003, 2004, 2005, 2006 Free Software Foundation, Inc. -@%:@ This configure script is free software; the Free Software Foundation -@%:@ gives unlimited permission to copy, distribute and modify it. -## --------------------- ## -## M4sh Initialization. ## -## --------------------- ## - -# Be more Bourne compatible -DUALCASE=1; export DUALCASE # for MKS sh -if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then - emulate sh - NULLCMD=: - # Zsh 3.x and 4.x performs word splitting on ${1+"$@"}, which - # is contrary to our usage. Disable this feature. - alias -g '${1+"$@"}'='"$@"' - setopt NO_GLOB_SUBST -else - case `(set -o) 2>/dev/null` in - *posix*) set -o posix ;; -esac - -fi - - - - -# PATH needs CR -# Avoid depending upon Character Ranges. -as_cr_letters='abcdefghijklmnopqrstuvwxyz' -as_cr_LETTERS='ABCDEFGHIJKLMNOPQRSTUVWXYZ' -as_cr_Letters=$as_cr_letters$as_cr_LETTERS -as_cr_digits='0123456789' -as_cr_alnum=$as_cr_Letters$as_cr_digits - -# The user is always right. -if test "${PATH_SEPARATOR+set}" != set; then - echo "#! /bin/sh" >conf$$.sh - echo "exit 0" >>conf$$.sh - chmod +x conf$$.sh - if (PATH="/nonexistent;."; conf$$.sh) >/dev/null 2>&1; then - PATH_SEPARATOR=';' - else - PATH_SEPARATOR=: - fi - rm -f conf$$.sh -fi - -# Support unset when possible. -if ( (MAIL=60; unset MAIL) || exit) >/dev/null 2>&1; then - as_unset=unset -else - as_unset=false -fi - - -# IFS -# We need space, tab and new line, in precisely that order. Quoting is -# there to prevent editors from complaining about space-tab. -# (If _AS_PATH_WALK were called with IFS unset, it would disable word -# splitting by setting IFS to empty value.) -as_nl=' -' -IFS=" "" $as_nl" - -# Find who we are. Look in the path if we contain no directory separator. -case $0 in - *[\\/]* ) as_myself=$0 ;; - *) as_save_IFS=$IFS; IFS=$PATH_SEPARATOR -for as_dir in $PATH -do - IFS=$as_save_IFS - test -z "$as_dir" && as_dir=. - test -r "$as_dir/$0" && as_myself=$as_dir/$0 && break -done -IFS=$as_save_IFS - - ;; -esac -# We did not find ourselves, most probably we were run as `sh COMMAND' -# in which case we are not to be found in the path. -if test "x$as_myself" = x; then - as_myself=$0 -fi -if test ! -f "$as_myself"; then - echo "$as_myself: error: cannot find myself; rerun with an absolute file name" >&2 - { (exit 1); exit 1; } -fi - -# Work around bugs in pre-3.0 UWIN ksh. -for as_var in ENV MAIL MAILPATH -do ($as_unset $as_var) >/dev/null 2>&1 && $as_unset $as_var -done -PS1='$ ' -PS2='> ' -PS4='+ ' - -# NLS nuisances. -for as_var in \ - LANG LANGUAGE LC_ADDRESS LC_ALL LC_COLLATE LC_CTYPE LC_IDENTIFICATION \ - LC_MEASUREMENT LC_MESSAGES LC_MONETARY LC_NAME LC_NUMERIC LC_PAPER \ - LC_TELEPHONE LC_TIME -do - if (set +x; test -z "`(eval $as_var=C; export $as_var) 2>&1`"); then - eval $as_var=C; export $as_var - else - ($as_unset $as_var) >/dev/null 2>&1 && $as_unset $as_var - fi -done - -# Required to use basename. -if expr a : '\(a\)' >/dev/null 2>&1 && - test "X`expr 00001 : '.*\(...\)'`" = X001; then - as_expr=expr -else - as_expr=false -fi - -if (basename -- /) >/dev/null 2>&1 && test "X`basename -- / 2>&1`" = "X/"; then - as_basename=basename -else - as_basename=false -fi - - -# Name of the executable. -as_me=`$as_basename -- "$0" || -$as_expr X/"$0" : '.*/\([^/][^/]*\)/*$' \| \ - X"$0" : 'X\(//\)$' \| \ - X"$0" : 'X\(/\)' \| . 2>/dev/null || -echo X/"$0" | - sed '/^.*\/\([^/][^/]*\)\/*$/{ - s//\1/ - q - } - /^X\/\(\/\/\)$/{ - s//\1/ - q - } - /^X\/\(\/\).*/{ - s//\1/ - q - } - s/.*/./; q'` - -# CDPATH. -$as_unset CDPATH - - -if test "x$CONFIG_SHELL" = x; then - if (eval ":") 2>/dev/null; then - as_have_required=yes -else - as_have_required=no -fi - - if test $as_have_required = yes && (eval ": -(as_func_return () { - (exit \$1) -} -as_func_success () { - as_func_return 0 -} -as_func_failure () { - as_func_return 1 -} -as_func_ret_success () { - return 0 -} -as_func_ret_failure () { - return 1 -} - -exitcode=0 -if as_func_success; then - : -else - exitcode=1 - echo as_func_success failed. -fi - -if as_func_failure; then - exitcode=1 - echo as_func_failure succeeded. -fi - -if as_func_ret_success; then - : -else - exitcode=1 - echo as_func_ret_success failed. -fi - -if as_func_ret_failure; then - exitcode=1 - echo as_func_ret_failure succeeded. -fi - -if ( set x; as_func_ret_success y && test x = \"\$1\" ); then - : -else - exitcode=1 - echo positional parameters were not saved. -fi - -test \$exitcode = 0) || { (exit 1); exit 1; } - -( - as_lineno_1=\$LINENO - as_lineno_2=\$LINENO - test \"x\$as_lineno_1\" != \"x\$as_lineno_2\" && - test \"x\`expr \$as_lineno_1 + 1\`\" = \"x\$as_lineno_2\") || { (exit 1); exit 1; } -") 2> /dev/null; then - : -else - as_candidate_shells= - as_save_IFS=$IFS; IFS=$PATH_SEPARATOR -for as_dir in /bin$PATH_SEPARATOR/usr/bin$PATH_SEPARATOR$PATH -do - IFS=$as_save_IFS - test -z "$as_dir" && as_dir=. - case $as_dir in - /*) - for as_base in sh bash ksh sh5; do - as_candidate_shells="$as_candidate_shells $as_dir/$as_base" - done;; - esac -done -IFS=$as_save_IFS - - - for as_shell in $as_candidate_shells $SHELL; do - # Try only shells that exist, to save several forks. - if { test -f "$as_shell" || test -f "$as_shell.exe"; } && - { ("$as_shell") 2> /dev/null <<\_ASEOF -if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then - emulate sh - NULLCMD=: - # Zsh 3.x and 4.x performs word splitting on ${1+"$@"}, which - # is contrary to our usage. Disable this feature. - alias -g '${1+"$@"}'='"$@"' - setopt NO_GLOB_SUBST -else - case `(set -o) 2>/dev/null` in - *posix*) set -o posix ;; -esac - -fi - - -: -_ASEOF -}; then - CONFIG_SHELL=$as_shell - as_have_required=yes - if { "$as_shell" 2> /dev/null <<\_ASEOF -if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then - emulate sh - NULLCMD=: - # Zsh 3.x and 4.x performs word splitting on ${1+"$@"}, which - # is contrary to our usage. Disable this feature. - alias -g '${1+"$@"}'='"$@"' - setopt NO_GLOB_SUBST -else - case `(set -o) 2>/dev/null` in - *posix*) set -o posix ;; -esac - -fi - - -: -(as_func_return () { - (exit $1) -} -as_func_success () { - as_func_return 0 -} -as_func_failure () { - as_func_return 1 -} -as_func_ret_success () { - return 0 -} -as_func_ret_failure () { - return 1 -} - -exitcode=0 -if as_func_success; then - : -else - exitcode=1 - echo as_func_success failed. -fi - -if as_func_failure; then - exitcode=1 - echo as_func_failure succeeded. -fi - -if as_func_ret_success; then - : -else - exitcode=1 - echo as_func_ret_success failed. -fi - -if as_func_ret_failure; then - exitcode=1 - echo as_func_ret_failure succeeded. -fi - -if ( set x; as_func_ret_success y && test x = "$1" ); then - : -else - exitcode=1 - echo positional parameters were not saved. -fi - -test $exitcode = 0) || { (exit 1); exit 1; } - -( - as_lineno_1=$LINENO - as_lineno_2=$LINENO - test "x$as_lineno_1" != "x$as_lineno_2" && - test "x`expr $as_lineno_1 + 1`" = "x$as_lineno_2") || { (exit 1); exit 1; } - -_ASEOF -}; then - break -fi - -fi - - done - - if test "x$CONFIG_SHELL" != x; then - for as_var in BASH_ENV ENV - do ($as_unset $as_var) >/dev/null 2>&1 && $as_unset $as_var - done - export CONFIG_SHELL - exec "$CONFIG_SHELL" "$as_myself" ${1+"$@"} -fi - - - if test $as_have_required = no; then - echo This script requires a shell more modern than all the - echo shells that I found on your system. Please install a - echo modern shell, or manually run the script under such a - echo shell if you do have one. - { (exit 1); exit 1; } -fi - - -fi - -fi - - - -(eval "as_func_return () { - (exit \$1) -} -as_func_success () { - as_func_return 0 -} -as_func_failure () { - as_func_return 1 -} -as_func_ret_success () { - return 0 -} -as_func_ret_failure () { - return 1 -} - -exitcode=0 -if as_func_success; then - : -else - exitcode=1 - echo as_func_success failed. -fi - -if as_func_failure; then - exitcode=1 - echo as_func_failure succeeded. -fi - -if as_func_ret_success; then - : -else - exitcode=1 - echo as_func_ret_success failed. -fi - -if as_func_ret_failure; then - exitcode=1 - echo as_func_ret_failure succeeded. -fi - -if ( set x; as_func_ret_success y && test x = \"\$1\" ); then - : -else - exitcode=1 - echo positional parameters were not saved. -fi - -test \$exitcode = 0") || { - echo No shell found that supports shell functions. - echo Please tell [email protected] about your system, - echo including any error possibly output before this - echo message -} - - - - as_lineno_1=$LINENO - as_lineno_2=$LINENO - test "x$as_lineno_1" != "x$as_lineno_2" && - test "x`expr $as_lineno_1 + 1`" = "x$as_lineno_2" || { - - # Create $as_me.lineno as a copy of $as_myself, but with $LINENO - # uniformly replaced by the line number. The first 'sed' inserts a - # line-number line after each line using $LINENO; the second 'sed' - # does the real work. The second script uses 'N' to pair each - # line-number line with the line containing $LINENO, and appends - # trailing '-' during substitution so that $LINENO is not a special - # case at line end. - # (Raja R Harinath suggested sed '=', and Paul Eggert wrote the - # scripts with optimization help from Paolo Bonzini. Blame Lee - # E. McMahon (1931-1989) for sed's syntax. :-) - sed -n ' - p - /[$]LINENO/= - ' <$as_myself | - sed ' - s/[$]LINENO.*/&-/ - t lineno - b - :lineno - N - :loop - s/[$]LINENO\([^'$as_cr_alnum'_].*\n\)\(.*\)/\2\1\2/ - t loop - s/-\n.*// - ' >$as_me.lineno && - chmod +x "$as_me.lineno" || - { echo "$as_me: error: cannot create $as_me.lineno; rerun with a POSIX shell" >&2 - { (exit 1); exit 1; }; } - - # Don't try to exec as it changes $[0], causing all sort of problems - # (the dirname of $[0] is not the place where we might find the - # original and so on. Autoconf is especially sensitive to this). - . "./$as_me.lineno" - # Exit status is that of the last command. - exit -} - - -if (as_dir=`dirname -- /` && test "X$as_dir" = X/) >/dev/null 2>&1; then - as_dirname=dirname -else - as_dirname=false -fi - -ECHO_C= ECHO_N= ECHO_T= -case `echo -n x` in --n*) - case `echo 'x\c'` in - *c*) ECHO_T=' ';; # ECHO_T is single tab character. - *) ECHO_C='\c';; - esac;; -*) - ECHO_N='-n';; -esac - -if expr a : '\(a\)' >/dev/null 2>&1 && - test "X`expr 00001 : '.*\(...\)'`" = X001; then - as_expr=expr -else - as_expr=false -fi - -rm -f conf$$ conf$$.exe conf$$.file -if test -d conf$$.dir; then - rm -f conf$$.dir/conf$$.file -else - rm -f conf$$.dir - mkdir conf$$.dir -fi -echo >conf$$.file -if ln -s conf$$.file conf$$ 2>/dev/null; then - as_ln_s='ln -s' - # ... but there are two gotchas: - # 1) On MSYS, both `ln -s file dir' and `ln file dir' fail. - # 2) DJGPP < 2.04 has no symlinks; `ln -s' creates a wrapper executable. - # In both cases, we have to default to `cp -p'. - ln -s conf$$.file conf$$.dir 2>/dev/null && test ! -f conf$$.exe || - as_ln_s='cp -p' -elif ln conf$$.file conf$$ 2>/dev/null; then - as_ln_s=ln -else - as_ln_s='cp -p' -fi -rm -f conf$$ conf$$.exe conf$$.dir/conf$$.file conf$$.file -rmdir conf$$.dir 2>/dev/null - -if mkdir -p . 2>/dev/null; then - as_mkdir_p=: -else - test -d ./-p && rmdir ./-p - as_mkdir_p=false -fi - -if test -x / >/dev/null 2>&1; then - as_test_x='test -x' -else - if ls -dL / >/dev/null 2>&1; then - as_ls_L_option=L - else - as_ls_L_option= - fi - as_test_x=' - eval sh -c '\'' - if test -d "$1"; then - test -d "$1/."; - else - case $1 in - -*)set "./$1";; - esac; - case `ls -ld'$as_ls_L_option' "$1" 2>/dev/null` in - ???[sx]*):;;*)false;;esac;fi - '\'' sh - ' -fi -as_executable_p=$as_test_x - -# Sed expression to map a string onto a valid CPP name. -as_tr_cpp="eval sed 'y%*$as_cr_letters%P$as_cr_LETTERS%;s%[^_$as_cr_alnum]%_%g'" - -# Sed expression to map a string onto a valid variable name. -as_tr_sh="eval sed 'y%*+%pp%;s%[^_$as_cr_alnum]%_%g'" - - - -exec 7<&0 </dev/null 6>&1 - -# Name of the host. -# hostname on some systems (SVR3.2, Linux) returns a bogus exit status, -# so uname gets run too. -ac_hostname=`(hostname || uname -n) 2>/dev/null | sed 1q` - -# -# Initializations. -# -ac_default_prefix=/usr/local -ac_clean_files= -ac_config_libobj_dir=. -LIB@&t@OBJS= -cross_compiling=no -subdirs= -MFLAGS= -MAKEFLAGS= -SHELL=${CONFIG_SHELL-/bin/sh} - -# Identity of this package. -PACKAGE_NAME='triton' -PACKAGE_TARNAME='triton' -PACKAGE_VERSION='0.1.1' -PACKAGE_STRING='triton 0.1.1' -PACKAGE_BUGREPORT='[email protected]' - -# Factoring default headers for most tests. -ac_includes_default="\ -#include <stdio.h> -#ifdef HAVE_SYS_TYPES_H -# include <sys/types.h> -#endif -#ifdef HAVE_SYS_STAT_H -# include <sys/stat.h> -#endif -#ifdef STDC_HEADERS -# include <stdlib.h> -# include <stddef.h> -#else -# ifdef HAVE_STDLIB_H -# include <stdlib.h> -# endif -#endif -#ifdef HAVE_STRING_H -# if !defined STDC_HEADERS && defined HAVE_MEMORY_H -# include <memory.h> -# endif -# include <string.h> -#endif -#ifdef HAVE_STRINGS_H -# include <strings.h> -#endif -#ifdef HAVE_INTTYPES_H -# include <inttypes.h> -#endif -#ifdef HAVE_STDINT_H -# include <stdint.h> -#endif -#ifdef HAVE_UNISTD_H -# include <unistd.h> -#endif" - -ac_subst_vars='SHELL -PATH_SEPARATOR -PACKAGE_NAME -PACKAGE_TARNAME -PACKAGE_VERSION -PACKAGE_STRING -PACKAGE_BUGREPORT -exec_prefix -prefix -program_transform_name -bindir -sbindir -libexecdir -datarootdir -datadir -sysconfdir -sharedstatedir -localstatedir -includedir -oldincludedir -docdir -infodir -htmldir -dvidir -pdfdir -psdir -libdir -localedir -mandir -DEFS -ECHO_C -ECHO_N -ECHO_T -LIBS -build_alias -host_alias -target_alias -TRITON_VERSION -INSTALL_PROGRAM -INSTALL_SCRIPT -INSTALL_DATA -CC -CFLAGS -LDFLAGS -CPPFLAGS -ac_ct_CC -EXEEXT -OBJEXT -CPP -GREP -EGREP -GHC -DB_CFLAGS -DB_LIB -MPICC -MPICFLAGS -MPILDFLAGS -MPILIBS -BUILD_MPI -BUILD_ABSOLUTE_TOP -SRC_RELATIVE_TOP -SRC_ABSOLUTE_TOP -QUIET_COMPILE -STRICT_CFLAGS -AE_DEBUG -ENABLE_COVERAGE -LIBCFLAGS -THREAD_LIB -TRITON_SQLITE_INCLUDES -TRITON_SQLITE_LIBS -BUILD_OSD -LIB@&t@OBJS -LTLIBOBJS' -ac_subst_files='' - ac_precious_vars='build_alias -host_alias -target_alias -CC -CFLAGS -LDFLAGS -LIBS -CPPFLAGS -CPP' - - -# Initialize some variables set by options. -ac_init_help= -ac_init_version=false -# The variables have the same names as the options, with -# dashes changed to underlines. -cache_file=/dev/null -exec_prefix=NONE -no_create= -no_recursion= -prefix=NONE -program_prefix=NONE -program_suffix=NONE -program_transform_name=s,x,x, -silent= -site= -srcdir= -verbose= -x_includes=NONE -x_libraries=NONE - -# Installation directory options. -# These are left unexpanded so users can "make install exec_prefix=/foo" -# and all the variables that are supposed to be based on exec_prefix -# by default will actually change. -# Use braces instead of parens because sh, perl, etc. also accept them. -# (The list follows the same order as the GNU Coding Standards.) -bindir='${exec_prefix}/bin' -sbindir='${exec_prefix}/sbin' -libexecdir='${exec_prefix}/libexec' -datarootdir='${prefix}/share' -datadir='${datarootdir}' -sysconfdir='${prefix}/etc' -sharedstatedir='${prefix}/com' -localstatedir='${prefix}/var' -includedir='${prefix}/include' -oldincludedir='/usr/include' -docdir='${datarootdir}/doc/${PACKAGE_TARNAME}' -infodir='${datarootdir}/info' -htmldir='${docdir}' -dvidir='${docdir}' -pdfdir='${docdir}' -psdir='${docdir}' -libdir='${exec_prefix}/lib' -localedir='${datarootdir}/locale' -mandir='${datarootdir}/man' - -ac_prev= -ac_dashdash= -for ac_option -do - # If the previous option needs an argument, assign it. - if test -n "$ac_prev"; then - eval $ac_prev=\$ac_option - ac_prev= - continue - fi - - case $ac_option in - *=*) ac_optarg=`expr "X$ac_option" : '[^=]*=\(.*\)'` ;; - *) ac_optarg=yes ;; - esac - - # Accept the important Cygnus configure options, so we can diagnose typos. - - case $ac_dashdash$ac_option in - --) - ac_dashdash=yes ;; - - -bindir | --bindir | --bindi | --bind | --bin | --bi) - ac_prev=bindir ;; - -bindir=* | --bindir=* | --bindi=* | --bind=* | --bin=* | --bi=*) - bindir=$ac_optarg ;; - - -build | --build | --buil | --bui | --bu) - ac_prev=build_alias ;; - -build=* | --build=* | --buil=* | --bui=* | --bu=*) - build_alias=$ac_optarg ;; - - -cache-file | --cache-file | --cache-fil | --cache-fi \ - | --cache-f | --cache- | --cache | --cach | --cac | --ca | --c) - ac_prev=cache_file ;; - -cache-file=* | --cache-file=* | --cache-fil=* | --cache-fi=* \ - | --cache-f=* | --cache-=* | --cache=* | --cach=* | --cac=* | --ca=* | --c=*) - cache_file=$ac_optarg ;; - - --config-cache | -C) - cache_file=config.cache ;; - - -datadir | --datadir | --datadi | --datad) - ac_prev=datadir ;; - -datadir=* | --datadir=* | --datadi=* | --datad=*) - datadir=$ac_optarg ;; - - -datarootdir | --datarootdir | --datarootdi | --datarootd | --dataroot \ - | --dataroo | --dataro | --datar) - ac_prev=datarootdir ;; - -datarootdir=* | --datarootdir=* | --datarootdi=* | --datarootd=* \ - | --dataroot=* | --dataroo=* | --dataro=* | --datar=*) - datarootdir=$ac_optarg ;; - - -disable-* | --disable-*) - ac_feature=`expr "x$ac_option" : 'x-*disable-\(.*\)'` - # Reject names that are not valid shell variable names. - expr "x$ac_feature" : ".*[^-._$as_cr_alnum]" >/dev/null && - { echo "$as_me: error: invalid feature name: $ac_feature" >&2 - { (exit 1); exit 1; }; } - ac_feature=`echo $ac_feature | sed 's/[-.]/_/g'` - eval enable_$ac_feature=no ;; - - -docdir | --docdir | --docdi | --doc | --do) - ac_prev=docdir ;; - -docdir=* | --docdir=* | --docdi=* | --doc=* | --do=*) - docdir=$ac_optarg ;; - - -dvidir | --dvidir | --dvidi | --dvid | --dvi | --dv) - ac_prev=dvidir ;; - -dvidir=* | --dvidir=* | --dvidi=* | --dvid=* | --dvi=* | --dv=*) - dvidir=$ac_optarg ;; - - -enable-* | --enable-*) - ac_feature=`expr "x$ac_option" : 'x-*enable-\([^=]*\)'` - # Reject names that are not valid shell variable names. - expr "x$ac_feature" : ".*[^-._$as_cr_alnum]" >/dev/null && - { echo "$as_me: error: invalid feature name: $ac_feature" >&2 - { (exit 1); exit 1; }; } - ac_feature=`echo $ac_feature | sed 's/[-.]/_/g'` - eval enable_$ac_feature=\$ac_optarg ;; - - -exec-prefix | --exec_prefix | --exec-prefix | --exec-prefi \ - | --exec-pref | --exec-pre | --exec-pr | --exec-p | --exec- \ - | --exec | --exe | --ex) - ac_prev=exec_prefix ;; - -exec-prefix=* | --exec_prefix=* | --exec-prefix=* | --exec-prefi=* \ - | --exec-pref=* | --exec-pre=* | --exec-pr=* | --exec-p=* | --exec-=* \ - | --exec=* | --exe=* | --ex=*) - exec_prefix=$ac_optarg ;; - - -gas | --gas | --ga | --g) - # Obsolete; use --with-gas. - with_gas=yes ;; - - -help | --help | --hel | --he | -h) - ac_init_help=long ;; - -help=r* | --help=r* | --hel=r* | --he=r* | -hr*) - ac_init_help=recursive ;; - -help=s* | --help=s* | --hel=s* | --he=s* | -hs*) - ac_init_help=short ;; - - -host | --host | --hos | --ho) - ac_prev=host_alias ;; - -host=* | --host=* | --hos=* | --ho=*) - host_alias=$ac_optarg ;; - - -htmldir | --htmldir | --htmldi | --htmld | --html | --htm | --ht) - ac_prev=htmldir ;; - -htmldir=* | --htmldir=* | --htmldi=* | --htmld=* | --html=* | --htm=* \ - | --ht=*) - htmldir=$ac_optarg ;; - - -includedir | --includedir | --includedi | --included | --include \ - | --includ | --inclu | --incl | --inc) - ac_prev=includedir ;; - -includedir=* | --includedir=* | --includedi=* | --included=* | --include=* \ - | --includ=* | --inclu=* | --incl=* | --inc=*) - includedir=$ac_optarg ;; - - -infodir | --infodir | --infodi | --infod | --info | --inf) - ac_prev=infodir ;; - -infodir=* | --infodir=* | --infodi=* | --infod=* | --info=* | --inf=*) - infodir=$ac_optarg ;; - - -libdir | --libdir | --libdi | --libd) - ac_prev=libdir ;; - -libdir=* | --libdir=* | --libdi=* | --libd=*) - libdir=$ac_optarg ;; - - -libexecdir | --libexecdir | --libexecdi | --libexecd | --libexec \ - | --libexe | --libex | --libe) - ac_prev=libexecdir ;; - -libexecdir=* | --libexecdir=* | --libexecdi=* | --libexecd=* | --libexec=* \ - | --libexe=* | --libex=* | --libe=*) - libexecdir=$ac_optarg ;; - - -localedir | --localedir | --localedi | --localed | --locale) - ac_prev=localedir ;; - -localedir=* | --localedir=* | --localedi=* | --localed=* | --locale=*) - localedir=$ac_optarg ;; - - -localstatedir | --localstatedir | --localstatedi | --localstated \ - | --localstate | --localstat | --localsta | --localst | --locals) - ac_prev=localstatedir ;; - -localstatedir=* | --localstatedir=* | --localstatedi=* | --localstated=* \ - | --localstate=* | --localstat=* | --localsta=* | --localst=* | --locals=*) - localstatedir=$ac_optarg ;; - - -mandir | --mandir | --mandi | --mand | --man | --ma | --m) - ac_prev=mandir ;; - -mandir=* | --mandir=* | --mandi=* | --mand=* | --man=* | --ma=* | --m=*) - mandir=$ac_optarg ;; - - -nfp | --nfp | --nf) - # Obsolete; use --without-fp. - with_fp=no ;; - - -no-create | --no-create | --no-creat | --no-crea | --no-cre \ - | --no-cr | --no-c | -n) - no_create=yes ;; - - -no-recursion | --no-recursion | --no-recursio | --no-recursi \ - | --no-recurs | --no-recur | --no-recu | --no-rec | --no-re | --no-r) - no_recursion=yes ;; - - -oldincludedir | --oldincludedir | --oldincludedi | --oldincluded \ - | --oldinclude | --oldinclud | --oldinclu | --oldincl | --oldinc \ - | --oldin | --oldi | --old | --ol | --o) - ac_prev=oldincludedir ;; - -oldincludedir=* | --oldincludedir=* | --oldincludedi=* | --oldincluded=* \ - | --oldinclude=* | --oldinclud=* | --oldinclu=* | --oldincl=* | --oldinc=* \ - | --oldin=* | --oldi=* | --old=* | --ol=* | --o=*) - oldincludedir=$ac_optarg ;; - - -prefix | --prefix | --prefi | --pref | --pre | --pr | --p) - ac_prev=prefix ;; - -prefix=* | --prefix=* | --prefi=* | --pref=* | --pre=* | --pr=* | --p=*) - prefix=$ac_optarg ;; - - -program-prefix | --program-prefix | --program-prefi | --program-pref \ - | --program-pre | --program-pr | --program-p) - ac_prev=program_prefix ;; - -program-prefix=* | --program-prefix=* | --program-prefi=* \ - | --program-pref=* | --program-pre=* | --program-pr=* | --program-p=*) - program_prefix=$ac_optarg ;; - - -program-suffix | --program-suffix | --program-suffi | --program-suff \ - | --program-suf | --program-su | --program-s) - ac_prev=program_suffix ;; - -program-suffix=* | --program-suffix=* | --program-suffi=* \ - | --program-suff=* | --program-suf=* | --program-su=* | --program-s=*) - program_suffix=$ac_optarg ;; - - -program-transform-name | --program-transform-name \ - | --program-transform-nam | --program-transform-na \ - | --program-transform-n | --program-transform- \ - | --program-transform | --program-transfor \ - | --program-transfo | --program-transf \ - | --program-trans | --program-tran \ - | --progr-tra | --program-tr | --program-t) - ac_prev=program_transform_name ;; - -program-transform-name=* | --program-transform-name=* \ - | --program-transform-nam=* | --program-transform-na=* \ - | --program-transform-n=* | --program-transform-=* \ - | --program-transform=* | --program-transfor=* \ - | --program-transfo=* | --program-transf=* \ - | --program-trans=* | --program-tran=* \ - | --progr-tra=* | --program-tr=* | --program-t=*) - program_transform_name=$ac_optarg ;; - - -pdfdir | --pdfdir | --pdfdi | --pdfd | --pdf | --pd) - ac_prev=pdfdir ;; - -pdfdir=* | --pdfdir=* | --pdfdi=* | --pdfd=* | --pdf=* | --pd=*) - pdfdir=$ac_optarg ;; - - -psdir | --psdir | --psdi | --psd | --ps) - ac_prev=psdir ;; - -psdir=* | --psdir=* | --psdi=* | --psd=* | --ps=*) - psdir=$ac_optarg ;; - - -q | -quiet | --quiet | --quie | --qui | --qu | --q \ - | -silent | --silent | --silen | --sile | --sil) - silent=yes ;; - - -sbindir | --sbindir | --sbindi | --sbind | --sbin | --sbi | --sb) - ac_prev=sbindir ;; - -sbindir=* | --sbindir=* | --sbindi=* | --sbind=* | --sbin=* \ - | --sbi=* | --sb=*) - sbindir=$ac_optarg ;; - - -sharedstatedir | --sharedstatedir | --sharedstatedi \ - | --sharedstated | --sharedstate | --sharedstat | --sharedsta \ - | --sharedst | --shareds | --shared | --share | --shar \ - | --sha | --sh) - ac_prev=sharedstatedir ;; - -sharedstatedir=* | --sharedstatedir=* | --sharedstatedi=* \ - | --sharedstated=* | --sharedstate=* | --sharedstat=* | --sharedsta=* \ - | --sharedst=* | --shareds=* | --shared=* | --share=* | --shar=* \ - | --sha=* | --sh=*) - sharedstatedir=$ac_optarg ;; - - -site | --site | --sit) - ac_prev=site ;; - -site=* | --site=* | --sit=*) - site=$ac_optarg ;; - - -srcdir | --srcdir | --srcdi | --srcd | --src | --sr) - ac_prev=srcdir ;; - -srcdir=* | --srcdir=* | --srcdi=* | --srcd=* | --src=* | --sr=*) - srcdir=$ac_optarg ;; - - -sysconfdir | --sysconfdir | --sysconfdi | --sysconfd | --sysconf \ - | --syscon | --sysco | --sysc | --sys | --sy) - ac_prev=sysconfdir ;; - -sysconfdir=* | --sysconfdir=* | --sysconfdi=* | --sysconfd=* | --sysconf=* \ - | --syscon=* | --sysco=* | --sysc=* | --sys=* | --sy=*) - sysconfdir=$ac_optarg ;; - - -target | --target | --targe | --targ | --tar | --ta | --t) - ac_prev=target_alias ;; - -target=* | --target=* | --targe=* | --targ=* | --tar=* | --ta=* | --t=*) - target_alias=$ac_optarg ;; - - -v | -verbose | --verbose | --verbos | --verbo | --verb) - verbose=yes ;; - - -version | --version | --versio | --versi | --vers | -V) - ac_init_version=: ;; - - -with-* | --with-*) - ac_package=`expr "x$ac_option" : 'x-*with-\([^=]*\)'` - # Reject names that are not valid shell variable names. - expr "x$ac_package" : ".*[^-._$as_cr_alnum]" >/dev/null && - { echo "$as_me: error: invalid package name: $ac_package" >&2 - { (exit 1); exit 1; }; } - ac_package=`echo $ac_package | sed 's/[-.]/_/g'` - eval with_$ac_package=\$ac_optarg ;; - - -without-* | --without-*) - ac_package=`expr "x$ac_option" : 'x-*without-\(.*\)'` - # Reject names that are not valid shell variable names. - expr "x$ac_package" : ".*[^-._$as_cr_alnum]" >/dev/null && - { echo "$as_me: error: invalid package name: $ac_package" >&2 - { (exit 1); exit 1; }; } - ac_package=`echo $ac_package | sed 's/[-.]/_/g'` - eval with_$ac_package=no ;; - - --x) - # Obsolete; use --with-x. - with_x=yes ;; - - -x-includes | --x-includes | --x-include | --x-includ | --x-inclu \ - | --x-incl | --x-inc | --x-in | --x-i) - ac_prev=x_includes ;; - -x-includes=* | --x-includes=* | --x-include=* | --x-includ=* | --x-inclu=* \ - | --x-incl=* | --x-inc=* | --x-in=* | --x-i=*) - x_includes=$ac_optarg ;; - - -x-libraries | --x-libraries | --x-librarie | --x-librari \ - | --x-librar | --x-libra | --x-libr | --x-lib | --x-li | --x-l) - ac_prev=x_libraries ;; - -x-libraries=* | --x-libraries=* | --x-librarie=* | --x-librari=* \ - | --x-librar=* | --x-libra=* | --x-libr=* | --x-lib=* | --x-li=* | --x-l=*) - x_libraries=$ac_optarg ;; - - -*) { echo "$as_me: error: unrecognized option: $ac_option -Try \`$0 --help' for more information." >&2 - { (exit 1); exit 1; }; } - ;; - - *=*) - ac_envvar=`expr "x$ac_option" : 'x\([^=]*\)='` - # Reject names that are not valid shell variable names. - expr "x$ac_envvar" : ".*[^_$as_cr_alnum]" >/dev/null && - { echo "$as_me: error: invalid variable name: $ac_envvar" >&2 - { (exit 1); exit 1; }; } - eval $ac_envvar=\$ac_optarg - export $ac_envvar ;; - - *) - # FIXME: should be removed in autoconf 3.0. - echo "$as_me: WARNING: you should use --build, --host, --target" >&2 - expr "x$ac_option" : ".*[^-._$as_cr_alnum]" >/dev/null && - echo "$as_me: WARNING: invalid host type: $ac_option" >&2 - : ${build_alias=$ac_option} ${host_alias=$ac_option} ${target_alias=$ac_option} - ;; - - esac -done - -if test -n "$ac_prev"; then - ac_option=--`echo $ac_prev | sed 's/_/-/g'` - { echo "$as_me: error: missing argument to $ac_option" >&2 - { (exit 1); exit 1; }; } -fi - -# Be sure to have absolute directory names. -for ac_var in exec_prefix prefix bindir sbindir libexecdir datarootdir \ - datadir sysconfdir sharedstatedir localstatedir includedir \ - oldincludedir docdir infodir htmldir dvidir pdfdir psdir \ - libdir localedir mandir -do - eval ac_val=\$$ac_var - case $ac_val in - [\\/$]* | ?:[\\/]* ) continue;; - NONE | '' ) case $ac_var in *prefix ) continue;; esac;; - esac - { echo "$as_me: error: expected an absolute directory name for --$ac_var: $ac_val" >&2 - { (exit 1); exit 1; }; } -done - -# There might be people who depend on the old broken behavior: `$host' -# used to hold the argument of --host etc. -# FIXME: To remove some day. -build=$build_alias -host=$host_alias -target=$target_alias - -# FIXME: To remove some day. -if test "x$host_alias" != x; then - if test "x$build_alias" = x; then - cross_compiling=maybe - echo "$as_me: WARNING: If you wanted to set the --build type, don't use --host. - If a cross compiler is detected then cross compile mode will be used." >&2 - elif test "x$build_alias" != "x$host_alias"; then - cross_compiling=yes - fi -fi - -ac_tool_prefix= -test -n "$host_alias" && ac_tool_prefix=$host_alias- - -test "$silent" = yes && exec 6>/dev/null - - -ac_pwd=`pwd` && test -n "$ac_pwd" && -ac_ls_di=`ls -di .` && -ac_pwd_ls_di=`cd "$ac_pwd" && ls -di .` || - { echo "$as_me: error: Working directory cannot be determined" >&2 - { (exit 1); exit 1; }; } -test "X$ac_ls_di" = "X$ac_pwd_ls_di" || - { echo "$as_me: error: pwd does not report name of working directory" >&2 - { (exit 1); exit 1; }; } - - -# Find the source files, if location was not specified. -if test -z "$srcdir"; then - ac_srcdir_defaulted=yes - # Try the directory containing this script, then the parent directory. - ac_confdir=`$as_dirname -- "$0" || -$as_expr X"$0" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \ - X"$0" : 'X\(//\)[^/]' \| \ - X"$0" : 'X\(//\)$' \| \ - X"$0" : 'X\(/\)' \| . 2>/dev/null || -echo X"$0" | - sed '/^X\(.*[^/]\)\/\/*[^/][^/]*\/*$/{ - s//\1/ - q - } - /^X\(\/\/\)[^/].*/{ - s//\1/ - q - } - /^X\(\/\/\)$/{ - s//\1/ - q - } - /^X\(\/\).*/{ - s//\1/ - q - } - s/.*/./; q'` - srcdir=$ac_confdir - if test ! -r "$srcdir/$ac_unique_file"; then - srcdir=.. - fi -else - ac_srcdir_defaulted=no -fi -if test ! -r "$srcdir/$ac_unique_file"; then - test "$ac_srcdir_defaulted" = yes && srcdir="$ac_confdir or .." - { echo "$as_me: error: cannot find sources ($ac_unique_file) in $srcdir" >&2 - { (exit 1); exit 1; }; } -fi -ac_msg="sources are in $srcdir, but \`cd $srcdir' does not work" -ac_abs_confdir=`( - cd "$srcdir" && test -r "./$ac_unique_file" || { echo "$as_me: error: $ac_msg" >&2 - { (exit 1); exit 1; }; } - pwd)` -# When building in place, set srcdir=. -if test "$ac_abs_confdir" = "$ac_pwd"; then - srcdir=. -fi -# Remove unnecessary trailing slashes from srcdir. -# Double slashes in file names in object file debugging info -# mess up M-x gdb in Emacs. -case $srcdir in -*/) srcdir=`expr "X$srcdir" : 'X\(.*[^/]\)' \| "X$srcdir" : 'X\(.*\)'`;; -esac -for ac_var in $ac_precious_vars; do - eval ac_env_${ac_var}_set=\${${ac_var}+set} - eval ac_env_${ac_var}_value=\$${ac_var} - eval ac_cv_env_${ac_var}_set=\${${ac_var}+set} - eval ac_cv_env_${ac_var}_value=\$${ac_var} -done - -# -# Report the --help message. -# -if test "$ac_init_help" = "long"; then - # Omit some internal or obsolete options to make the list less imposing. - # This message is too long to be a string in the A/UX 3.1 sh. - cat <<_ACEOF -\`configure' configures triton 0.1.1 to adapt to many kinds of systems. - -Usage: $0 [OPTION]... [VAR=VALUE]... - -To assign environment variables (e.g., CC, CFLAGS...), specify them as -VAR=VALUE. See below for descriptions of some of the useful variables. - -Defaults for the options are specified in brackets. - -Configuration: - -h, --help display this help and exit - --help=short display options specific to this package - --help=recursive display the short help of all the included packages - -V, --version display version information and exit - -q, --quiet, --silent do not print \`checking...' messages - --cache-file=FILE cache test results in FILE [disabled] - -C, --config-cache alias for \`--cache-file=config.cache' - -n, --no-create do not create output files - --srcdir=DIR find the sources in DIR [configure dir or \`..'] - -Installation directories: - --prefix=PREFIX install architecture-independent files in PREFIX - [$ac_default_prefix] - --exec-prefix=EPREFIX install architecture-dependent files in EPREFIX - [PREFIX] - -By default, \`make install' will install all the files in -\`$ac_default_prefix/bin', \`$ac_default_prefix/lib' etc. You can specify -an installation prefix other than \`$ac_default_prefix' using \`--prefix', -for instance \`--prefix=\$HOME'. - -For better control, use the options below. - -Fine tuning of the installation directories: - --bindir=DIR user executables [EPREFIX/bin] - --sbindir=DIR system admin executables [EPREFIX/sbin] - --libexecdir=DIR program executables [EPREFIX/libexec] - --sysconfdir=DIR read-only single-machine data [PREFIX/etc] - --sharedstatedir=DIR modifiable architecture-independent data [PREFIX/com] - --localstatedir=DIR modifiable single-machine data [PREFIX/var] - --libdir=DIR object code libraries [EPREFIX/lib] - --includedir=DIR C header files [PREFIX/include] - --oldincludedir=DIR C header files for non-gcc [/usr/include] - --datarootdir=DIR read-only arch.-independent data root [PREFIX/share] - --datadir=DIR read-only architecture-independent data [DATAROOTDIR] - --infodir=DIR info documentation [DATAROOTDIR/info] - --localedir=DIR locale-dependent data [DATAROOTDIR/locale] - --mandir=DIR man documentation [DATAROOTDIR/man] - --docdir=DIR documentation root @<:@DATAROOTDIR/doc/triton@:>@ - --htmldir=DIR html documentation [DOCDIR] - --dvidir=DIR dvi documentation [DOCDIR] - --pdfdir=DIR pdf documentation [DOCDIR] - --psdir=DIR ps documentation [DOCDIR] -_ACEOF - - cat <<\_ACEOF -_ACEOF -fi - -if test -n "$ac_init_help"; then - case $ac_init_help in - short | recursive ) echo "Configuration of triton 0.1.1:";; - esac - cat <<\_ACEOF - -Optional Features: - --disable-FEATURE do not include FEATURE (same as --enable-FEATURE=no) - --enable-FEATURE[=ARG] include FEATURE [ARG=yes] - --enable-verbose Enables verbose output during build process - --enable-strict Turn on strict compiler warnings - --enable-aesop-debug Turn on debugging of the gs-parser - --enable-coverage Enable coverage analysis (disables optimizations) - --disable-thread-safety Disables thread safety in the client library - -Optional Packages: - --with-PACKAGE[=ARG] use PACKAGE [ARG=yes] - --without-PACKAGE do not use PACKAGE (same as --with-PACKAGE=no) - --with-ghc=<dir> Location of installed ghc - --with-db=<dir> Location of installed DB package -(default=/usr) - --with-mpi=<dir> Location of the MPI installation - --with-sqlite=PREFIX Use installed SQLite library or amalgamation file. - -Some influential environment variables: - CC C compiler command - CFLAGS C compiler flags - LDFLAGS linker flags, e.g. -L<lib dir> if you have libraries in a - nonstandard directory <lib dir> - LIBS libraries to pass to the linker, e.g. -l<library> - CPPFLAGS C/C++/Objective C preprocessor flags, e.g. -I<include dir> if - you have headers in a nonstandard directory <include dir> - CPP C preprocessor - -Use these variables to override the choices made by `configure' or to help -it to find libraries and programs with nonstandard names/locations. - -Report bugs to <[email protected]>. -_ACEOF -ac_status=$? -fi - -if test "$ac_init_help" = "recursive"; then - # If there are subdirs, report their specific --help. - for ac_dir in : $ac_subdirs_all; do test "x$ac_dir" = x: && continue - test -d "$ac_dir" || continue - ac_builddir=. - -case "$ac_dir" in -.) ac_dir_suffix= ac_top_builddir_sub=. ac_top_build_prefix= ;; -*) - ac_dir_suffix=/`echo "$ac_dir" | sed 's,^\.[\\/],,'` - # A ".." for each directory in $ac_dir_suffix. - ac_top_builddir_sub=`echo "$ac_dir_suffix" | sed 's,/[^\\/]*,/..,g;s,/,,'` - case $ac_top_builddir_sub in - "") ac_top_builddir_sub=. ac_top_build_prefix= ;; - *) ac_top_build_prefix=$ac_top_builddir_sub/ ;; - esac ;; -esac -ac_abs_top_builddir=$ac_pwd -ac_abs_builddir=$ac_pwd$ac_dir_suffix -# for backward compatibility: -ac_top_builddir=$ac_top_build_prefix - -case $srcdir in - .) # We are building in place. - ac_srcdir=. - ac_top_srcdir=$ac_top_builddir_sub - ac_abs_top_srcdir=$ac_pwd ;; - [\\/]* | ?:[\\/]* ) # Absolute name. - ac_srcdir=$srcdir$ac_dir_suffix; - ac_top_srcdir=$srcdir - ac_abs_top_srcdir=$srcdir ;; - *) # Relative name. - ac_srcdir=$ac_top_build_prefix$srcdir$ac_dir_suffix - ac_top_srcdir=$ac_top_build_prefix$srcdir - ac_abs_top_srcdir=$ac_pwd/$srcdir ;; -esac -ac_abs_srcdir=$ac_abs_top_srcdir$ac_dir_suffix - - cd "$ac_dir" || { ac_status=$?; continue; } - # Check for guested configure. - if test -f "$ac_srcdir/configure.gnu"; then - echo && - $SHELL "$ac_srcdir/configure.gnu" --help=recursive - elif test -f "$ac_srcdir/configure"; then - echo && - $SHELL "$ac_srcdir/configure" --help=recursive - else - echo "$as_me: WARNING: no configuration information is in $ac_dir" >&2 - fi || ac_status=$? - cd "$ac_pwd" || { ac_status=$?; break; } - done -fi - -test -n "$ac_init_help" && exit $ac_status -if $ac_init_version; then - cat <<\_ACEOF -triton configure 0.1.1 -generated by GNU Autoconf 2.61 - -Copyright (C) 1992, 1993, 1994, 1995, 1996, 1998, 1999, 2000, 2001, -2002, 2003, 2004, 2005, 2006 Free Software Foundation, Inc. -This configure script is free software; the Free Software Foundation -gives unlimited permission to copy, distribute and modify it. -_ACEOF - exit -fi -cat >config.log <<_ACEOF -This file contains any messages produced by compilers while -running configure, to aid debugging if configure makes a mistake. - -It was created by triton $as_me 0.1.1, which was -generated by GNU Autoconf 2.61. Invocation command line was - - $ $0 $@ - -_ACEOF -exec 5>>config.log -{ -cat <<_ASUNAME -@%:@@%:@ --------- @%:@@%:@ -@%:@@%:@ Platform. @%:@@%:@ -@%:@@%:@ --------- @%:@@%:@ - -hostname = `(hostname || uname -n) 2>/dev/null | sed 1q` -uname -m = `(uname -m) 2>/dev/null || echo unknown` -uname -r = `(uname -r) 2>/dev/null || echo unknown` -uname -s = `(uname -s) 2>/dev/null || echo unknown` -uname -v = `(uname -v) 2>/dev/null || echo unknown` - -/usr/bin/uname -p = `(/usr/bin/uname -p) 2>/dev/null || echo unknown` -/bin/uname -X = `(/bin/uname -X) 2>/dev/null || echo unknown` - -/bin/arch = `(/bin/arch) 2>/dev/null || echo unknown` -/usr/bin/arch -k = `(/usr/bin/arch -k) 2>/dev/null || echo unknown` -/usr/convex/getsysinfo = `(/usr/convex/getsysinfo) 2>/dev/null || echo unknown` -/usr/bin/hostinfo = `(/usr/bin/hostinfo) 2>/dev/null || echo unknown` -/bin/machine = `(/bin/machine) 2>/dev/null || echo unknown` -/usr/bin/oslevel = `(/usr/bin/oslevel) 2>/dev/null || echo unknown` -/bin/universe = `(/bin/universe) 2>/dev/null || echo unknown` - -_ASUNAME - -as_save_IFS=$IFS; IFS=$PATH_SEPARATOR -for as_dir in $PATH -do - IFS=$as_save_IFS - test -z "$as_dir" && as_dir=. - echo "PATH: $as_dir" -done -IFS=$as_save_IFS - -} >&5 - -cat >&5 <<_ACEOF - - -@%:@@%:@ ----------- @%:@@%:@ -@%:@@%:@ Core tests. @%:@@%:@ -@%:@@%:@ ----------- @%:@@%:@ - -_ACEOF - - -# Keep a trace of the command line. -# Strip out --no-create and --no-recursion so they do not pile up. -# Strip out --silent because we don't want to record it for future runs. -# Also quote any args containing shell meta-characters. -# Make two passes to allow for proper duplicate-argument suppression. -ac_configure_args= -ac_configure_args0= -ac_configure_args1= -ac_must_keep_next=false -for ac_pass in 1 2 -do - for ac_arg - do - case $ac_arg in - -no-create | --no-c* | -n | -no-recursion | --no-r*) continue ;; - -q | -quiet | --quiet | --quie | --qui | --qu | --q \ - | -silent | --silent | --silen | --sile | --sil) - continue ;; - *\'*) - ac_arg=`echo "$ac_arg" | sed "s/'/'\\\\\\\\''/g"` ;; - esac - case $ac_pass in - 1) ac_configure_args0="$ac_configure_args0 '$ac_arg'" ;; - 2) - ac_configure_args1="$ac_configure_args1 '$ac_arg'" - if test $ac_must_keep_next = true; then - ac_must_keep_next=false # Got value, back to normal. - else - case $ac_arg in - *=* | --config-cache | -C | -disable-* | --disable-* \ - | -enable-* | --enable-* | -gas | --g* | -nfp | --nf* \ - | -q | -quiet | --q* | -silent | --sil* | -v | -verb* \ - | -with-* | --with-* | -without-* | --without-* | --x) - case "$ac_configure_args0 " in - "$ac_configure_args1"*" '$ac_arg' "* ) continue ;; - esac - ;; - -* ) ac_must_keep_next=true ;; - esac - fi - ac_configure_args="$ac_configure_args '$ac_arg'" - ;; - esac - done -done -$as_unset ac_configure_args0 || test "${ac_configure_args0+set}" != set || { ac_configure_args0=; export ac_configure_args0; } -$as_unset ac_configure_args1 || test "${ac_configure_args1+set}" != set || { ac_configure_args1=; export ac_configure_args1; } - -# When interrupted or exit'd, cleanup temporary files, and complete -# config.log. We remove comments because anyway the quotes in there -# would cause problems or look ugly. -# WARNING: Use '\'' to represent an apostrophe within the trap. -# WARNING: Do not start the trap code with a newline, due to a FreeBSD 4.0 bug. -trap 'exit_status=$? - # Save into config.log some information that might help in debugging. - { - echo - - cat <<\_ASBOX -@%:@@%:@ ---------------- @%:@@%:@ -@%:@@%:@ Cache variables. @%:@@%:@ -@%:@@%:@ ---------------- @%:@@%:@ -_ASBOX - echo - # The following way of writing the cache mishandles newlines in values, -( - for ac_var in `(set) 2>&1 | sed -n '\''s/^\([a-zA-Z_][a-zA-Z0-9_]*\)=.*/\1/p'\''`; do - eval ac_val=\$$ac_var - case $ac_val in #( - *${as_nl}*) - case $ac_var in #( - *_cv_*) { echo "$as_me:$LINENO: WARNING: Cache variable $ac_var contains a newline." >&5 -echo "$as_me: WARNING: Cache variable $ac_var contains a newline." >&2;} ;; - esac - case $ac_var in #( - _ | IFS | as_nl) ;; #( - *) $as_unset $ac_var ;; - esac ;; - esac - done - (set) 2>&1 | - case $as_nl`(ac_space='\'' '\''; set) 2>&1` in #( - *${as_nl}ac_space=\ *) - sed -n \ - "s/'\''/'\''\\\\'\'''\''/g; - s/^\\([_$as_cr_alnum]*_cv_[_$as_cr_alnum]*\\)=\\(.*\\)/\\1='\''\\2'\''/p" - ;; #( - *) - sed -n "/^[_$as_cr_alnum]*_cv_[_$as_cr_alnum]*=/p" - ;; - esac | - sort -) - echo - - cat <<\_ASBOX -@%:@@%:@ ----------------- @%:@@%:@ -@%:@@%:@ Output variables. @%:@@%:@ -@%:@@%:@ ----------------- @%:@@%:@ -_ASBOX - echo - for ac_var in $ac_subst_vars - do - eval ac_val=\$$ac_var - case $ac_val in - *\'\''*) ac_val=`echo "$ac_val" | sed "s/'\''/'\''\\\\\\\\'\'''\''/g"`;; - esac - echo "$ac_var='\''$ac_val'\''" - done | sort - echo - - if test -n "$ac_subst_files"; then - cat <<\_ASBOX -@%:@@%:@ ------------------- @%:@@%:@ -@%:@@%:@ File substitutions. @%:@@%:@ -@%:@@%:@ ------------------- @%:@@%:@ -_ASBOX - echo - for ac_var in $ac_subst_files - do - eval ac_val=\$$ac_var - case $ac_val in - *\'\''*) ac_val=`echo "$ac_val" | sed "s/'\''/'\''\\\\\\\\'\'''\''/g"`;; - esac - echo "$ac_var='\''$ac_val'\''" - done | sort - echo - fi - - if test -s confdefs.h; then - cat <<\_ASBOX -@%:@@%:@ ----------- @%:@@%:@ -@%:@@%:@ confdefs.h. @%:@@%:@ -@%:@@%:@ ----------- @%:@@%:@ -_ASBOX - echo - cat confdefs.h - echo - fi - test "$ac_signal" != 0 && - echo "$as_me: caught signal $ac_signal" - echo "$as_me: exit $exit_status" - } >&5 - rm -f core *.core core.conftest.* && - rm -f -r conftest* confdefs* conf$$* $ac_clean_files && - exit $exit_status -' 0 -for ac_signal in 1 2 13 15; do - trap 'ac_signal='$ac_signal'; { (exit 1); exit 1; }' $ac_signal -done -ac_signal=0 - -# confdefs.h avoids OS command line length limits that DEFS can exceed. -rm -f -r conftest* confdefs.h - -# Predefined preprocessor variables. - -cat >>confdefs.h <<_ACEOF -@%:@define PACKAGE_NAME "$PACKAGE_NAME" -_ACEOF - - -cat >>confdefs.h <<_ACEOF -@%:@define PACKAGE_TARNAME "$PACKAGE_TARNAME" -_ACEOF - - -cat >>confdefs.h <<_ACEOF -@%:@define PACKAGE_VERSION "$PACKAGE_VERSION" -_ACEOF - - -cat >>confdefs.h <<_ACEOF -@%:@define PACKAGE_STRING "$PACKAGE_STRING" -_ACEOF - - -cat >>confdefs.h <<_ACEOF -@%:@define PACKAGE_BUGREPORT "$PACKAGE_BUGREPORT" -_ACEOF - - -# Let the site file select an alternate cache file if it wants to. -# Prefer explicitly selected file to automatically selected ones. -if test -n "$CONFIG_SITE"; then - set x "$CONFIG_SITE" -elif test "x$prefix" != xNONE; then - set x "$prefix/share/config.site" "$prefix/etc/config.site" -else - set x "$ac_default_prefix/share/config.site" \ - "$ac_default_prefix/etc/config.site" -fi -shift -for ac_site_file -do - if test -r "$ac_site_file"; then - { echo "$as_me:$LINENO: loading site script $ac_site_file" >&5 -echo "$as_me: loading site script $ac_site_file" >&6;} - sed 's/^/| /' "$ac_site_file" >&5 - . "$ac_site_file" - fi -done - -if test -r "$cache_file"; then - # Some versions of bash will fail to source /dev/null (special - # files actually), so we avoid doing that. - if test -f "$cache_file"; then - { echo "$as_me:$LINENO: loading cache $cache_file" >&5 -echo "$as_me: loading cache $cache_file" >&6;} - case $cache_file in - [\\/]* | ?:[\\/]* ) . "$cache_file";; - *) . "./$cache_file";; - esac - fi -else - { echo "$as_me:$LINENO: creating cache $cache_file" >&5 -echo "$as_me: creating cache $cache_file" >&6;} - >$cache_file -fi - -# Check that the precious variables saved in the cache have kept the same -# value. -ac_cache_corrupted=false -for ac_var in $ac_precious_vars; do - eval ac_old_set=\$ac_cv_env_${ac_var}_set - eval ac_new_set=\$ac_env_${ac_var}_set - eval ac_old_val=\$ac_cv_env_${ac_var}_value - eval ac_new_val=\$ac_env_${ac_var}_value - case $ac_old_set,$ac_new_set in - set,) - { echo "$as_me:$LINENO: error: \`$ac_var' was set to \`$ac_old_val' in the previous run" >&5 -echo "$as_me: error: \`$ac_var' was set to \`$ac_old_val' in the previous run" >&2;} - ac_cache_corrupted=: ;; - ,set) - { echo "$as_me:$LINENO: error: \`$ac_var' was not set in the previous run" >&5 -echo "$as_me: error: \`$ac_var' was not set in the previous run" >&2;} - ac_cache_corrupted=: ;; - ,);; - *) - if test "x$ac_old_val" != "x$ac_new_val"; then - { echo "$as_me:$LINENO: error: \`$ac_var' has changed since the previous run:" >&5 -echo "$as_me: error: \`$ac_var' has changed since the previous run:" >&2;} - { echo "$as_me:$LINENO: former value: $ac_old_val" >&5 -echo "$as_me: former value: $ac_old_val" >&2;} - { echo "$as_me:$LINENO: current value: $ac_new_val" >&5 -echo "$as_me: current value: $ac_new_val" >&2;} - ac_cache_corrupted=: - fi;; - esac - # Pass precious variables to config.status. - if test "$ac_new_set" = set; then - case $ac_new_val in - *\'*) ac_arg=$ac_var=`echo "$ac_new_val" | sed "s/'/'\\\\\\\\''/g"` ;; - *) ac_arg=$ac_var=$ac_new_val ;; - esac - case " $ac_configure_args " in - *" '$ac_arg' "*) ;; # Avoid dups. Use of quotes ensures accuracy. - *) ac_configure_args="$ac_configure_args '$ac_arg'" ;; - esac - fi -done -if $ac_cache_corrupted; then - { echo "$as_me:$LINENO: error: changes in the environment can compromise the build" >&5 -echo "$as_me: error: changes in the environment can compromise the build" >&2;} - { { echo "$as_me:$LINENO: error: run \`make distclean' and/or \`rm $cache_file' and start over" >&5 -echo "$as_me: error: run \`make distclean' and/or \`rm $cache_file' and start over" >&2;} - { (exit 1); exit 1; }; } -fi - - - - - - - - - - - - - - - - - - - - - - - - - -ac_ext=c -ac_cpp='$CPP $CPPFLAGS' -ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5' -ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5' -ac_compiler_gnu=$ac_cv_c_compiler_gnu - - - - - - -cat >>confdefs.h <<_ACEOF -@%:@define TRITON_VERSION_MAJOR $TRITON_MAJOR -_ACEOF - - -cat >>confdefs.h <<_ACEOF -@%:@define TRITON_VERSION_MINOR $TRITON_MINOR -_ACEOF - - -cat >>confdefs.h <<_ACEOF -@%:@define TRITON_VERSION_SUB $TRITON_SUB -_ACEOF - - -ac_config_headers="$ac_config_headers triton-config.h" - -ac_aux_dir= -for ac_dir in maint/config "$srcdir"/maint/config; do - if test -f "$ac_dir/install-sh"; then - ac_aux_dir=$ac_dir - ac_install_sh="$ac_aux_dir/install-sh -c" - break - elif test -f "$ac_dir/install.sh"; then - ac_aux_dir=$ac_dir - ac_install_sh="$ac_aux_dir/install.sh -c" - break - elif test -f "$ac_dir/shtool"; then - ac_aux_dir=$ac_dir - ac_install_sh="$ac_aux_dir/shtool install -c" - break - fi -done -if test -z "$ac_aux_dir"; then - { { echo "$as_me:$LINENO: error: cannot find install-sh or install.sh in maint/config \"$srcdir\"/maint/config" >&5 -echo "$as_me: error: cannot find install-sh or install.sh in maint/config \"$srcdir\"/maint/config" >&2;} - { (exit 1); exit 1; }; } -fi - -# These three variables are undocumented and unsupported, -# and are intended to be withdrawn in a future Autoconf release. -# They can cause serious problems if a builder's source tree is in a directory -# whose full name contains unusual characters. -ac_config_guess="$SHELL $ac_aux_dir/config.guess" # Please don't use this var. -ac_config_sub="$SHELL $ac_aux_dir/config.sub" # Please don't use this var. -ac_configure="$SHELL $ac_aux_dir/configure" # Please don't use this var. - - - -# Find a good install program. We prefer a C program (faster), -# so one script is as good as another. But avoid the broken or -# incompatible versions: -# SysV /etc/install, /usr/sbin/install -# SunOS /usr/etc/install -# IRIX /sbin/install -# AIX /bin/install -# AmigaOS /C/install, which installs bootblocks on floppy discs -# AIX 4 /usr/bin/installbsd, which doesn't work without a -g flag -# AFS /usr/afsws/bin/install, which mishandles nonexistent args -# SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff" -# OS/2's system install, which has a completely different semantic -# ./install, which can be erroneously created by make from ./install.sh. -{ echo "$as_me:$LINENO: checking for a BSD-compatible install" >&5 -echo $ECHO_N "checking for a BSD-compatible install... $ECHO_C" >&6; } -if test -z "$INSTALL"; then -if test "${ac_cv_path_install+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - as_save_IFS=$IFS; IFS=$PATH_SEPARATOR -for as_dir in $PATH -do - IFS=$as_save_IFS - test -z "$as_dir" && as_dir=. - # Account for people who put trailing slashes in PATH elements. -case $as_dir/ in - ./ | .// | /cC/* | \ - /etc/* | /usr/sbin/* | /usr/etc/* | /sbin/* | /usr/afsws/bin/* | \ - ?:\\/os2\\/install\\/* | ?:\\/OS2\\/INSTALL\\/* | \ - /usr/ucb/* ) ;; - *) - # OSF1 and SCO ODT 3.0 have their own names for install. - # Don't use installbsd from OSF since it installs stuff as root - # by default. - for ac_prog in ginstall scoinst install; do - for ac_exec_ext in '' $ac_executable_extensions; do - if { test -f "$as_dir/$ac_prog$ac_exec_ext" && $as_test_x "$as_dir/$ac_prog$ac_exec_ext"; }; then - if test $ac_prog = install && - grep dspmsg "$as_dir/$ac_prog$ac_exec_ext" >/dev/null 2>&1; then - # AIX install. It has an incompatible calling convention. - : - elif test $ac_prog = install && - grep pwplus "$as_dir/$ac_prog$ac_exec_ext" >/dev/null 2>&1; then - # program-specific install script used by HP pwplus--don't use. - : - else - ac_cv_path_install="$as_dir/$ac_prog$ac_exec_ext -c" - break 3 - fi - fi - done - done - ;; -esac -done -IFS=$as_save_IFS - - -fi - if test "${ac_cv_path_install+set}" = set; then - INSTALL=$ac_cv_path_install - else - # As a last resort, use the slow shell script. Don't cache a - # value for INSTALL within a source directory, because that will - # break other packages using the cache if that directory is - # removed, or if the value is a relative name. - INSTALL=$ac_install_sh - fi -fi -{ echo "$as_me:$LINENO: result: $INSTALL" >&5 -echo "${ECHO_T}$INSTALL" >&6; } - -# Use test -z because SunOS4 sh mishandles braces in ${var-val}. -# It thinks the first close brace ends the variable substitution. -test -z "$INSTALL_PROGRAM" && INSTALL_PROGRAM='${INSTALL}' - -test -z "$INSTALL_SCRIPT" && INSTALL_SCRIPT='${INSTALL}' - -test -z "$INSTALL_DATA" && INSTALL_DATA='${INSTALL} -m 644' - -ac_ext=c -ac_cpp='$CPP $CPPFLAGS' -ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5' -ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5' -ac_compiler_gnu=$ac_cv_c_compiler_gnu -if test -n "$ac_tool_prefix"; then - # Extract the first word of "${ac_tool_prefix}gcc", so it can be a program name with args. -set dummy ${ac_tool_prefix}gcc; ac_word=$2 -{ echo "$as_me:$LINENO: checking for $ac_word" >&5 -echo $ECHO_N "checking for $ac_word... $ECHO_C" >&6; } -if test "${ac_cv_prog_CC+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - if test -n "$CC"; then - ac_cv_prog_CC="$CC" # Let the user override the test. -else -as_save_IFS=$IFS; IFS=$PATH_SEPARATOR -for as_dir in $PATH -do - IFS=$as_save_IFS - test -z "$as_dir" && as_dir=. - for ac_exec_ext in '' $ac_executable_extensions; do - if { test -f "$as_dir/$ac_word$ac_exec_ext" && $as_test_x "$as_dir/$ac_word$ac_exec_ext"; }; then - ac_cv_prog_CC="${ac_tool_prefix}gcc" - echo "$as_me:$LINENO: found $as_dir/$ac_word$ac_exec_ext" >&5 - break 2 - fi -done -done -IFS=$as_save_IFS - -fi -fi -CC=$ac_cv_prog_CC -if test -n "$CC"; then - { echo "$as_me:$LINENO: result: $CC" >&5 -echo "${ECHO_T}$CC" >&6; } -else - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } -fi - - -fi -if test -z "$ac_cv_prog_CC"; then - ac_ct_CC=$CC - # Extract the first word of "gcc", so it can be a program name with args. -set dummy gcc; ac_word=$2 -{ echo "$as_me:$LINENO: checking for $ac_word" >&5 -echo $ECHO_N "checking for $ac_word... $ECHO_C" >&6; } -if test "${ac_cv_prog_ac_ct_CC+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - if test -n "$ac_ct_CC"; then - ac_cv_prog_ac_ct_CC="$ac_ct_CC" # Let the user override the test. -else -as_save_IFS=$IFS; IFS=$PATH_SEPARATOR -for as_dir in $PATH -do - IFS=$as_save_IFS - test -z "$as_dir" && as_dir=. - for ac_exec_ext in '' $ac_executable_extensions; do - if { test -f "$as_dir/$ac_word$ac_exec_ext" && $as_test_x "$as_dir/$ac_word$ac_exec_ext"; }; then - ac_cv_prog_ac_ct_CC="gcc" - echo "$as_me:$LINENO: found $as_dir/$ac_word$ac_exec_ext" >&5 - break 2 - fi -done -done -IFS=$as_save_IFS - -fi -fi -ac_ct_CC=$ac_cv_prog_ac_ct_CC -if test -n "$ac_ct_CC"; then - { echo "$as_me:$LINENO: result: $ac_ct_CC" >&5 -echo "${ECHO_T}$ac_ct_CC" >&6; } -else - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } -fi - - if test "x$ac_ct_CC" = x; then - CC="" - else - case $cross_compiling:$ac_tool_warned in -yes:) -{ echo "$as_me:$LINENO: WARNING: In the future, Autoconf will not detect cross-tools -whose name does not start with the host triplet. If you think this -configuration is useful to you, please write to [email protected]." >&5 -echo "$as_me: WARNING: In the future, Autoconf will not detect cross-tools -whose name does not start with the host triplet. If you think this -configuration is useful to you, please write to [email protected]." >&2;} -ac_tool_warned=yes ;; -esac - CC=$ac_ct_CC - fi -else - CC="$ac_cv_prog_CC" -fi - -if test -z "$CC"; then - if test -n "$ac_tool_prefix"; then - # Extract the first word of "${ac_tool_prefix}cc", so it can be a program name with args. -set dummy ${ac_tool_prefix}cc; ac_word=$2 -{ echo "$as_me:$LINENO: checking for $ac_word" >&5 -echo $ECHO_N "checking for $ac_word... $ECHO_C" >&6; } -if test "${ac_cv_prog_CC+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - if test -n "$CC"; then - ac_cv_prog_CC="$CC" # Let the user override the test. -else -as_save_IFS=$IFS; IFS=$PATH_SEPARATOR -for as_dir in $PATH -do - IFS=$as_save_IFS - test -z "$as_dir" && as_dir=. - for ac_exec_ext in '' $ac_executable_extensions; do - if { test -f "$as_dir/$ac_word$ac_exec_ext" && $as_test_x "$as_dir/$ac_word$ac_exec_ext"; }; then - ac_cv_prog_CC="${ac_tool_prefix}cc" - echo "$as_me:$LINENO: found $as_dir/$ac_word$ac_exec_ext" >&5 - break 2 - fi -done -done -IFS=$as_save_IFS - -fi -fi -CC=$ac_cv_prog_CC -if test -n "$CC"; then - { echo "$as_me:$LINENO: result: $CC" >&5 -echo "${ECHO_T}$CC" >&6; } -else - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } -fi - - - fi -fi -if test -z "$CC"; then - # Extract the first word of "cc", so it can be a program name with args. -set dummy cc; ac_word=$2 -{ echo "$as_me:$LINENO: checking for $ac_word" >&5 -echo $ECHO_N "checking for $ac_word... $ECHO_C" >&6; } -if test "${ac_cv_prog_CC+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - if test -n "$CC"; then - ac_cv_prog_CC="$CC" # Let the user override the test. -else - ac_prog_rejected=no -as_save_IFS=$IFS; IFS=$PATH_SEPARATOR -for as_dir in $PATH -do - IFS=$as_save_IFS - test -z "$as_dir" && as_dir=. - for ac_exec_ext in '' $ac_executable_extensions; do - if { test -f "$as_dir/$ac_word$ac_exec_ext" && $as_test_x "$as_dir/$ac_word$ac_exec_ext"; }; then - if test "$as_dir/$ac_word$ac_exec_ext" = "/usr/ucb/cc"; then - ac_prog_rejected=yes - continue - fi - ac_cv_prog_CC="cc" - echo "$as_me:$LINENO: found $as_dir/$ac_word$ac_exec_ext" >&5 - break 2 - fi -done -done -IFS=$as_save_IFS - -if test $ac_prog_rejected = yes; then - # We found a bogon in the path, so make sure we never use it. - set dummy $ac_cv_prog_CC - shift - if test $@%:@ != 0; then - # We chose a different compiler from the bogus one. - # However, it has the same basename, so the bogon will be chosen - # first if we set CC to just the basename; use the full file name. - shift - ac_cv_prog_CC="$as_dir/$ac_word${1+' '}$@" - fi -fi -fi -fi -CC=$ac_cv_prog_CC -if test -n "$CC"; then - { echo "$as_me:$LINENO: result: $CC" >&5 -echo "${ECHO_T}$CC" >&6; } -else - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } -fi - - -fi -if test -z "$CC"; then - if test -n "$ac_tool_prefix"; then - for ac_prog in cl.exe - do - # Extract the first word of "$ac_tool_prefix$ac_prog", so it can be a program name with args. -set dummy $ac_tool_prefix$ac_prog; ac_word=$2 -{ echo "$as_me:$LINENO: checking for $ac_word" >&5 -echo $ECHO_N "checking for $ac_word... $ECHO_C" >&6; } -if test "${ac_cv_prog_CC+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - if test -n "$CC"; then - ac_cv_prog_CC="$CC" # Let the user override the test. -else -as_save_IFS=$IFS; IFS=$PATH_SEPARATOR -for as_dir in $PATH -do - IFS=$as_save_IFS - test -z "$as_dir" && as_dir=. - for ac_exec_ext in '' $ac_executable_extensions; do - if { test -f "$as_dir/$ac_word$ac_exec_ext" && $as_test_x "$as_dir/$ac_word$ac_exec_ext"; }; then - ac_cv_prog_CC="$ac_tool_prefix$ac_prog" - echo "$as_me:$LINENO: found $as_dir/$ac_word$ac_exec_ext" >&5 - break 2 - fi -done -done -IFS=$as_save_IFS - -fi -fi -CC=$ac_cv_prog_CC -if test -n "$CC"; then - { echo "$as_me:$LINENO: result: $CC" >&5 -echo "${ECHO_T}$CC" >&6; } -else - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } -fi - - - test -n "$CC" && break - done -fi -if test -z "$CC"; then - ac_ct_CC=$CC - for ac_prog in cl.exe -do - # Extract the first word of "$ac_prog", so it can be a program name with args. -set dummy $ac_prog; ac_word=$2 -{ echo "$as_me:$LINENO: checking for $ac_word" >&5 -echo $ECHO_N "checking for $ac_word... $ECHO_C" >&6; } -if test "${ac_cv_prog_ac_ct_CC+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - if test -n "$ac_ct_CC"; then - ac_cv_prog_ac_ct_CC="$ac_ct_CC" # Let the user override the test. -else -as_save_IFS=$IFS; IFS=$PATH_SEPARATOR -for as_dir in $PATH -do - IFS=$as_save_IFS - test -z "$as_dir" && as_dir=. - for ac_exec_ext in '' $ac_executable_extensions; do - if { test -f "$as_dir/$ac_word$ac_exec_ext" && $as_test_x "$as_dir/$ac_word$ac_exec_ext"; }; then - ac_cv_prog_ac_ct_CC="$ac_prog" - echo "$as_me:$LINENO: found $as_dir/$ac_word$ac_exec_ext" >&5 - break 2 - fi -done -done -IFS=$as_save_IFS - -fi -fi -ac_ct_CC=$ac_cv_prog_ac_ct_CC -if test -n "$ac_ct_CC"; then - { echo "$as_me:$LINENO: result: $ac_ct_CC" >&5 -echo "${ECHO_T}$ac_ct_CC" >&6; } -else - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } -fi - - - test -n "$ac_ct_CC" && break -done - - if test "x$ac_ct_CC" = x; then - CC="" - else - case $cross_compiling:$ac_tool_warned in -yes:) -{ echo "$as_me:$LINENO: WARNING: In the future, Autoconf will not detect cross-tools -whose name does not start with the host triplet. If you think this -configuration is useful to you, please write to [email protected]." >&5 -echo "$as_me: WARNING: In the future, Autoconf will not detect cross-tools -whose name does not start with the host triplet. If you think this -configuration is useful to you, please write to [email protected]." >&2;} -ac_tool_warned=yes ;; -esac - CC=$ac_ct_CC - fi -fi - -fi - - -test -z "$CC" && { { echo "$as_me:$LINENO: error: no acceptable C compiler found in \$PATH -See \`config.log' for more details." >&5 -echo "$as_me: error: no acceptable C compiler found in \$PATH -See \`config.log' for more details." >&2;} - { (exit 1); exit 1; }; } - -# Provide some information about the compiler. -echo "$as_me:$LINENO: checking for C compiler version" >&5 -ac_compiler=`set X $ac_compile; echo $2` -{ (ac_try="$ac_compiler --version >&5" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compiler --version >&5") 2>&5 - ac_status=$? - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } -{ (ac_try="$ac_compiler -v >&5" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compiler -v >&5") 2>&5 - ac_status=$? - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } -{ (ac_try="$ac_compiler -V >&5" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compiler -V >&5") 2>&5 - ac_status=$? - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } - -cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - -int -main () -{ - - ; - return 0; -} -_ACEOF -ac_clean_files_save=$ac_clean_files -ac_clean_files="$ac_clean_files a.out a.exe b.out" -# Try to create an executable without -o first, disregard a.out. -# It will help us diagnose broken compilers, and finding out an intuition -# of exeext. -{ echo "$as_me:$LINENO: checking for C compiler default output file name" >&5 -echo $ECHO_N "checking for C compiler default output file name... $ECHO_C" >&6; } -ac_link_default=`echo "$ac_link" | sed 's/ -o *conftest[^ ]*//'` -# -# List of possible output files, starting from the most likely. -# The algorithm is not robust to junk in `.', hence go to wildcards (a.*) -# only as a last resort. b.out is created by i960 compilers. -ac_files='a_out.exe a.exe conftest.exe a.out conftest a.* conftest.* b.out' -# -# The IRIX 6 linker writes into existing files which may not be -# executable, retaining their permissions. Remove them first so a -# subsequent execution test works. -ac_rmfiles= -for ac_file in $ac_files -do - case $ac_file in - *.$ac_ext | *.xcoff | *.tds | *.d | *.pdb | *.xSYM | *.bb | *.bbg | *.map | *.inf | *.o | *.obj ) ;; - * ) ac_rmfiles="$ac_rmfiles $ac_file";; - esac -done -rm -f $ac_rmfiles - -if { (ac_try="$ac_link_default" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_link_default") 2>&5 - ac_status=$? - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); }; then - # Autoconf-2.13 could set the ac_cv_exeext variable to `no'. -# So ignore a value of `no', otherwise this would lead to `EXEEXT = no' -# in a Makefile. We should not override ac_cv_exeext if it was cached, -# so that the user can short-circuit this test for compilers unknown to -# Autoconf. -for ac_file in $ac_files '' -do - test -f "$ac_file" || continue - case $ac_file in - *.$ac_ext | *.xcoff | *.tds | *.d | *.pdb | *.xSYM | *.bb | *.bbg | *.map | *.inf | *.o | *.obj ) - ;; - [ab].out ) - # We found the default executable, but exeext='' is most - # certainly right. - break;; - *.* ) - if test "${ac_cv_exeext+set}" = set && test "$ac_cv_exeext" != no; - then :; else - ac_cv_exeext=`expr "$ac_file" : '[^.]*\(\..*\)'` - fi - # We set ac_cv_exeext here because the later test for it is not - # safe: cross compilers may not add the suffix if given an `-o' - # argument, so we may need to know it at that point already. - # Even if this section looks crufty: it has the advantage of - # actually working. - break;; - * ) - break;; - esac -done -test "$ac_cv_exeext" = no && ac_cv_exeext= - -else - ac_file='' -fi - -{ echo "$as_me:$LINENO: result: $ac_file" >&5 -echo "${ECHO_T}$ac_file" >&6; } -if test -z "$ac_file"; then - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - -{ { echo "$as_me:$LINENO: error: C compiler cannot create executables -See \`config.log' for more details." >&5 -echo "$as_me: error: C compiler cannot create executables -See \`config.log' for more details." >&2;} - { (exit 77); exit 77; }; } -fi - -ac_exeext=$ac_cv_exeext - -# Check that the compiler produces executables we can run. If not, either -# the compiler is broken, or we cross compile. -{ echo "$as_me:$LINENO: checking whether the C compiler works" >&5 -echo $ECHO_N "checking whether the C compiler works... $ECHO_C" >&6; } -# FIXME: These cross compiler hacks should be removed for Autoconf 3.0 -# If not cross compiling, check that we can run a simple program. -if test "$cross_compiling" != yes; then - if { ac_try='./$ac_file' - { (case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_try") 2>&5 - ac_status=$? - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); }; }; then - cross_compiling=no - else - if test "$cross_compiling" = maybe; then - cross_compiling=yes - else - { { echo "$as_me:$LINENO: error: cannot run C compiled programs. -If you meant to cross compile, use \`--host'. -See \`config.log' for more details." >&5 -echo "$as_me: error: cannot run C compiled programs. -If you meant to cross compile, use \`--host'. -See \`config.log' for more details." >&2;} - { (exit 1); exit 1; }; } - fi - fi -fi -{ echo "$as_me:$LINENO: result: yes" >&5 -echo "${ECHO_T}yes" >&6; } - -rm -f a.out a.exe conftest$ac_cv_exeext b.out -ac_clean_files=$ac_clean_files_save -# Check that the compiler produces executables we can run. If not, either -# the compiler is broken, or we cross compile. -{ echo "$as_me:$LINENO: checking whether we are cross compiling" >&5 -echo $ECHO_N "checking whether we are cross compiling... $ECHO_C" >&6; } -{ echo "$as_me:$LINENO: result: $cross_compiling" >&5 -echo "${ECHO_T}$cross_compiling" >&6; } - -{ echo "$as_me:$LINENO: checking for suffix of executables" >&5 -echo $ECHO_N "checking for suffix of executables... $ECHO_C" >&6; } -if { (ac_try="$ac_link" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_link") 2>&5 - ac_status=$? - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); }; then - # If both `conftest.exe' and `conftest' are `present' (well, observable) -# catch `conftest.exe'. For instance with Cygwin, `ls conftest' will -# work properly (i.e., refer to `conftest.exe'), while it won't with -# `rm'. -for ac_file in conftest.exe conftest conftest.*; do - test -f "$ac_file" || continue - case $ac_file in - *.$ac_ext | *.xcoff | *.tds | *.d | *.pdb | *.xSYM | *.bb | *.bbg | *.map | *.inf | *.o | *.obj ) ;; - *.* ) ac_cv_exeext=`expr "$ac_file" : '[^.]*\(\..*\)'` - break;; - * ) break;; - esac -done -else - { { echo "$as_me:$LINENO: error: cannot compute suffix of executables: cannot compile and link -See \`config.log' for more details." >&5 -echo "$as_me: error: cannot compute suffix of executables: cannot compile and link -See \`config.log' for more details." >&2;} - { (exit 1); exit 1; }; } -fi - -rm -f conftest$ac_cv_exeext -{ echo "$as_me:$LINENO: result: $ac_cv_exeext" >&5 -echo "${ECHO_T}$ac_cv_exeext" >&6; } - -rm -f conftest.$ac_ext -EXEEXT=$ac_cv_exeext -ac_exeext=$EXEEXT -{ echo "$as_me:$LINENO: checking for suffix of object files" >&5 -echo $ECHO_N "checking for suffix of object files... $ECHO_C" >&6; } -if test "${ac_cv_objext+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - -int -main () -{ - - ; - return 0; -} -_ACEOF -rm -f conftest.o conftest.obj -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>&5 - ac_status=$? - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); }; then - for ac_file in conftest.o conftest.obj conftest.*; do - test -f "$ac_file" || continue; - case $ac_file in - *.$ac_ext | *.xcoff | *.tds | *.d | *.pdb | *.xSYM | *.bb | *.bbg | *.map | *.inf ) ;; - *) ac_cv_objext=`expr "$ac_file" : '.*\.\(.*\)'` - break;; - esac -done -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - -{ { echo "$as_me:$LINENO: error: cannot compute suffix of object files: cannot compile -See \`config.log' for more details." >&5 -echo "$as_me: error: cannot compute suffix of object files: cannot compile -See \`config.log' for more details." >&2;} - { (exit 1); exit 1; }; } -fi - -rm -f conftest.$ac_cv_objext conftest.$ac_ext -fi -{ echo "$as_me:$LINENO: result: $ac_cv_objext" >&5 -echo "${ECHO_T}$ac_cv_objext" >&6; } -OBJEXT=$ac_cv_objext -ac_objext=$OBJEXT -{ echo "$as_me:$LINENO: checking whether we are using the GNU C compiler" >&5 -echo $ECHO_N "checking whether we are using the GNU C compiler... $ECHO_C" >&6; } -if test "${ac_cv_c_compiler_gnu+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - -int -main () -{ -#ifndef __GNUC__ - choke me -#endif - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - ac_compiler_gnu=yes -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - ac_compiler_gnu=no -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext -ac_cv_c_compiler_gnu=$ac_compiler_gnu - -fi -{ echo "$as_me:$LINENO: result: $ac_cv_c_compiler_gnu" >&5 -echo "${ECHO_T}$ac_cv_c_compiler_gnu" >&6; } -GCC=`test $ac_compiler_gnu = yes && echo yes` -ac_test_CFLAGS=${CFLAGS+set} -ac_save_CFLAGS=$CFLAGS -{ echo "$as_me:$LINENO: checking whether $CC accepts -g" >&5 -echo $ECHO_N "checking whether $CC accepts -g... $ECHO_C" >&6; } -if test "${ac_cv_prog_cc_g+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - ac_save_c_werror_flag=$ac_c_werror_flag - ac_c_werror_flag=yes - ac_cv_prog_cc_g=no - CFLAGS="-g" - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - -int -main () -{ - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - ac_cv_prog_cc_g=yes -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - CFLAGS="" - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - -int -main () -{ - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - : -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - ac_c_werror_flag=$ac_save_c_werror_flag - CFLAGS="-g" - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - -int -main () -{ - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - ac_cv_prog_cc_g=yes -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - ac_c_werror_flag=$ac_save_c_werror_flag -fi -{ echo "$as_me:$LINENO: result: $ac_cv_prog_cc_g" >&5 -echo "${ECHO_T}$ac_cv_prog_cc_g" >&6; } -if test "$ac_test_CFLAGS" = set; then - CFLAGS=$ac_save_CFLAGS -elif test $ac_cv_prog_cc_g = yes; then - if test "$GCC" = yes; then - CFLAGS="-g -O2" - else - CFLAGS="-g" - fi -else - if test "$GCC" = yes; then - CFLAGS="-O2" - else - CFLAGS= - fi -fi -{ echo "$as_me:$LINENO: checking for $CC option to accept ISO C89" >&5 -echo $ECHO_N "checking for $CC option to accept ISO C89... $ECHO_C" >&6; } -if test "${ac_cv_prog_cc_c89+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - ac_cv_prog_cc_c89=no -ac_save_CC=$CC -cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -#include <stdarg.h> -#include <stdio.h> -#include <sys/types.h> -#include <sys/stat.h> -/* Most of the following tests are stolen from RCS 5.7's src/conf.sh. */ -struct buf { int x; }; -FILE * (*rcsopen) (struct buf *, struct stat *, int); -static char *e (p, i) - char **p; - int i; -{ - return p[i]; -} -static char *f (char * (*g) (char **, int), char **p, ...) -{ - char *s; - va_list v; - va_start (v,p); - s = g (p, va_arg (v,int)); - va_end (v); - return s; -} - -/* OSF 4.0 Compaq cc is some sort of almost-ANSI by default. It has - function prototypes and stuff, but not '\xHH' hex character constants. - These don't provoke an error unfortunately, instead are silently treated - as 'x'. The following induces an error, until -std is added to get - proper ANSI mode. Curiously '\x00'!='x' always comes out true, for an - array size at least. It's necessary to write '\x00'==0 to get something - that's true only with -std. */ -int osf4_cc_array ['\x00' == 0 ? 1 : -1]; - -/* IBM C 6 for AIX is almost-ANSI by default, but it replaces macro parameters - inside strings and character constants. */ -#define FOO(x) 'x' -int xlc6_cc_array[FOO(a) == 'x' ? 1 : -1]; - -int test (int i, double x); -struct s1 {int (*f) (int a);}; -struct s2 {int (*f) (double a);}; -int pairnames (int, char **, FILE *(*)(struct buf *, struct stat *, int), int, int); -int argc; -char **argv; -int -main () -{ -return f (e, argv, 0) != argv[0] || f (e, argv, 1) != argv[1]; - ; - return 0; -} -_ACEOF -for ac_arg in '' -qlanglvl=extc89 -qlanglvl=ansi -std \ - -Ae "-Aa -D_HPUX_SOURCE" "-Xc -D__EXTENSIONS__" -do - CC="$ac_save_CC $ac_arg" - rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - ac_cv_prog_cc_c89=$ac_arg -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - -fi - -rm -f core conftest.err conftest.$ac_objext - test "x$ac_cv_prog_cc_c89" != "xno" && break -done -rm -f conftest.$ac_ext -CC=$ac_save_CC - -fi -# AC_CACHE_VAL -case "x$ac_cv_prog_cc_c89" in - x) - { echo "$as_me:$LINENO: result: none needed" >&5 -echo "${ECHO_T}none needed" >&6; } ;; - xno) - { echo "$as_me:$LINENO: result: unsupported" >&5 -echo "${ECHO_T}unsupported" >&6; } ;; - *) - CC="$CC $ac_cv_prog_cc_c89" - { echo "$as_me:$LINENO: result: $ac_cv_prog_cc_c89" >&5 -echo "${ECHO_T}$ac_cv_prog_cc_c89" >&6; } ;; -esac - - -ac_ext=c -ac_cpp='$CPP $CPPFLAGS' -ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5' -ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5' -ac_compiler_gnu=$ac_cv_c_compiler_gnu - -ac_ext=c -ac_cpp='$CPP $CPPFLAGS' -ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5' -ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5' -ac_compiler_gnu=$ac_cv_c_compiler_gnu -{ echo "$as_me:$LINENO: checking how to run the C preprocessor" >&5 -echo $ECHO_N "checking how to run the C preprocessor... $ECHO_C" >&6; } -# On Suns, sometimes $CPP names a directory. -if test -n "$CPP" && test -d "$CPP"; then - CPP= -fi -if test -z "$CPP"; then - if test "${ac_cv_prog_CPP+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - # Double quotes because CPP needs to be expanded - for CPP in "$CC -E" "$CC -E -traditional-cpp" "/lib/cpp" - do - ac_preproc_ok=false -for ac_c_preproc_warn_flag in '' yes -do - # Use a header file that comes with gcc, so configuring glibc - # with a fresh cross-compiler works. - # Prefer <limits.h> to <assert.h> if __STDC__ is defined, since - # <limits.h> exists even on freestanding compilers. - # On the NeXT, cc -E runs the code through the compiler's parser, - # not just through cpp. "Syntax error" is here to catch this case. - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -@%:@ifdef __STDC__ -@%:@ include <limits.h> -@%:@else -@%:@ include <assert.h> -@%:@endif - Syntax error -_ACEOF -if { (ac_try="$ac_cpp conftest.$ac_ext" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_cpp conftest.$ac_ext") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } >/dev/null && { - test -z "$ac_c_preproc_warn_flag$ac_c_werror_flag" || - test ! -s conftest.err - }; then - : -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - # Broken: fails on valid input. -continue -fi - -rm -f conftest.err conftest.$ac_ext - - # OK, works on sane cases. Now check whether nonexistent headers - # can be detected and how. - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -@%:@include <ac_nonexistent.h> -_ACEOF -if { (ac_try="$ac_cpp conftest.$ac_ext" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_cpp conftest.$ac_ext") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } >/dev/null && { - test -z "$ac_c_preproc_warn_flag$ac_c_werror_flag" || - test ! -s conftest.err - }; then - # Broken: success on invalid input. -continue -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - # Passes both tests. -ac_preproc_ok=: -break -fi - -rm -f conftest.err conftest.$ac_ext - -done -# Because of `break', _AC_PREPROC_IFELSE's cleaning code was skipped. -rm -f conftest.err conftest.$ac_ext -if $ac_preproc_ok; then - break -fi - - done - ac_cv_prog_CPP=$CPP - -fi - CPP=$ac_cv_prog_CPP -else - ac_cv_prog_CPP=$CPP -fi -{ echo "$as_me:$LINENO: result: $CPP" >&5 -echo "${ECHO_T}$CPP" >&6; } -ac_preproc_ok=false -for ac_c_preproc_warn_flag in '' yes -do - # Use a header file that comes with gcc, so configuring glibc - # with a fresh cross-compiler works. - # Prefer <limits.h> to <assert.h> if __STDC__ is defined, since - # <limits.h> exists even on freestanding compilers. - # On the NeXT, cc -E runs the code through the compiler's parser, - # not just through cpp. "Syntax error" is here to catch this case. - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -@%:@ifdef __STDC__ -@%:@ include <limits.h> -@%:@else -@%:@ include <assert.h> -@%:@endif - Syntax error -_ACEOF -if { (ac_try="$ac_cpp conftest.$ac_ext" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_cpp conftest.$ac_ext") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } >/dev/null && { - test -z "$ac_c_preproc_warn_flag$ac_c_werror_flag" || - test ! -s conftest.err - }; then - : -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - # Broken: fails on valid input. -continue -fi - -rm -f conftest.err conftest.$ac_ext - - # OK, works on sane cases. Now check whether nonexistent headers - # can be detected and how. - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -@%:@include <ac_nonexistent.h> -_ACEOF -if { (ac_try="$ac_cpp conftest.$ac_ext" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_cpp conftest.$ac_ext") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } >/dev/null && { - test -z "$ac_c_preproc_warn_flag$ac_c_werror_flag" || - test ! -s conftest.err - }; then - # Broken: success on invalid input. -continue -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - # Passes both tests. -ac_preproc_ok=: -break -fi - -rm -f conftest.err conftest.$ac_ext - -done -# Because of `break', _AC_PREPROC_IFELSE's cleaning code was skipped. -rm -f conftest.err conftest.$ac_ext -if $ac_preproc_ok; then - : -else - { { echo "$as_me:$LINENO: error: C preprocessor \"$CPP\" fails sanity check -See \`config.log' for more details." >&5 -echo "$as_me: error: C preprocessor \"$CPP\" fails sanity check -See \`config.log' for more details." >&2;} - { (exit 1); exit 1; }; } -fi - -ac_ext=c -ac_cpp='$CPP $CPPFLAGS' -ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5' -ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5' -ac_compiler_gnu=$ac_cv_c_compiler_gnu - - - - -{ echo "$as_me:$LINENO: checking for grep that handles long lines and -e" >&5 -echo $ECHO_N "checking for grep that handles long lines and -e... $ECHO_C" >&6; } -if test "${ac_cv_path_GREP+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - # Extract the first word of "grep ggrep" to use in msg output -if test -z "$GREP"; then -set dummy grep ggrep; ac_prog_name=$2 -if test "${ac_cv_path_GREP+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - ac_path_GREP_found=false -# Loop through the user's path and test for each of PROGNAME-LIST -as_save_IFS=$IFS; IFS=$PATH_SEPARATOR -for as_dir in $PATH$PATH_SEPARATOR/usr/xpg4/bin -do - IFS=$as_save_IFS - test -z "$as_dir" && as_dir=. - for ac_prog in grep ggrep; do - for ac_exec_ext in '' $ac_executable_extensions; do - ac_path_GREP="$as_dir/$ac_prog$ac_exec_ext" - { test -f "$ac_path_GREP" && $as_test_x "$ac_path_GREP"; } || continue - # Check for GNU ac_path_GREP and select it if it is found. - # Check for GNU $ac_path_GREP -case `"$ac_path_GREP" --version 2>&1` in -*GNU*) - ac_cv_path_GREP="$ac_path_GREP" ac_path_GREP_found=:;; -*) - ac_count=0 - echo $ECHO_N "0123456789$ECHO_C" >"conftest.in" - while : - do - cat "conftest.in" "conftest.in" >"conftest.tmp" - mv "conftest.tmp" "conftest.in" - cp "conftest.in" "conftest.nl" - echo 'GREP' >> "conftest.nl" - "$ac_path_GREP" -e 'GREP$' -e '-(cannot match)-' < "conftest.nl" >"conftest.out" 2>/dev/null || break - diff "conftest.out" "conftest.nl" >/dev/null 2>&1 || break - ac_count=`expr $ac_count + 1` - if test $ac_count -gt ${ac_path_GREP_max-0}; then - # Best one so far, save it but keep looking for a better one - ac_cv_path_GREP="$ac_path_GREP" - ac_path_GREP_max=$ac_count - fi - # 10*(2^10) chars as input seems more than enough - test $ac_count -gt 10 && break - done - rm -f conftest.in conftest.tmp conftest.nl conftest.out;; -esac - - - $ac_path_GREP_found && break 3 - done -done - -done -IFS=$as_save_IFS - - -fi - -GREP="$ac_cv_path_GREP" -if test -z "$GREP"; then - { { echo "$as_me:$LINENO: error: no acceptable $ac_prog_name could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" >&5 -echo "$as_me: error: no acceptable $ac_prog_name could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" >&2;} - { (exit 1); exit 1; }; } -fi - -else - ac_cv_path_GREP=$GREP -fi - - -fi -{ echo "$as_me:$LINENO: result: $ac_cv_path_GREP" >&5 -echo "${ECHO_T}$ac_cv_path_GREP" >&6; } - GREP="$ac_cv_path_GREP" - - -{ echo "$as_me:$LINENO: checking for egrep" >&5 -echo $ECHO_N "checking for egrep... $ECHO_C" >&6; } -if test "${ac_cv_path_EGREP+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - if echo a | $GREP -E '(a|b)' >/dev/null 2>&1 - then ac_cv_path_EGREP="$GREP -E" - else - # Extract the first word of "egrep" to use in msg output -if test -z "$EGREP"; then -set dummy egrep; ac_prog_name=$2 -if test "${ac_cv_path_EGREP+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - ac_path_EGREP_found=false -# Loop through the user's path and test for each of PROGNAME-LIST -as_save_IFS=$IFS; IFS=$PATH_SEPARATOR -for as_dir in $PATH$PATH_SEPARATOR/usr/xpg4/bin -do - IFS=$as_save_IFS - test -z "$as_dir" && as_dir=. - for ac_prog in egrep; do - for ac_exec_ext in '' $ac_executable_extensions; do - ac_path_EGREP="$as_dir/$ac_prog$ac_exec_ext" - { test -f "$ac_path_EGREP" && $as_test_x "$ac_path_EGREP"; } || continue - # Check for GNU ac_path_EGREP and select it if it is found. - # Check for GNU $ac_path_EGREP -case `"$ac_path_EGREP" --version 2>&1` in -*GNU*) - ac_cv_path_EGREP="$ac_path_EGREP" ac_path_EGREP_found=:;; -*) - ac_count=0 - echo $ECHO_N "0123456789$ECHO_C" >"conftest.in" - while : - do - cat "conftest.in" "conftest.in" >"conftest.tmp" - mv "conftest.tmp" "conftest.in" - cp "conftest.in" "conftest.nl" - echo 'EGREP' >> "conftest.nl" - "$ac_path_EGREP" 'EGREP$' < "conftest.nl" >"conftest.out" 2>/dev/null || break - diff "conftest.out" "conftest.nl" >/dev/null 2>&1 || break - ac_count=`expr $ac_count + 1` - if test $ac_count -gt ${ac_path_EGREP_max-0}; then - # Best one so far, save it but keep looking for a better one - ac_cv_path_EGREP="$ac_path_EGREP" - ac_path_EGREP_max=$ac_count - fi - # 10*(2^10) chars as input seems more than enough - test $ac_count -gt 10 && break - done - rm -f conftest.in conftest.tmp conftest.nl conftest.out;; -esac - - - $ac_path_EGREP_found && break 3 - done -done - -done -IFS=$as_save_IFS - - -fi - -EGREP="$ac_cv_path_EGREP" -if test -z "$EGREP"; then - { { echo "$as_me:$LINENO: error: no acceptable $ac_prog_name could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" >&5 -echo "$as_me: error: no acceptable $ac_prog_name could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" >&2;} - { (exit 1); exit 1; }; } -fi - -else - ac_cv_path_EGREP=$EGREP -fi - - - fi -fi -{ echo "$as_me:$LINENO: result: $ac_cv_path_EGREP" >&5 -echo "${ECHO_T}$ac_cv_path_EGREP" >&6; } - EGREP="$ac_cv_path_EGREP" - - -{ echo "$as_me:$LINENO: checking for ANSI C header files" >&5 -echo $ECHO_N "checking for ANSI C header files... $ECHO_C" >&6; } -if test "${ac_cv_header_stdc+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -#include <stdlib.h> -#include <stdarg.h> -#include <string.h> -#include <float.h> - -int -main () -{ - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - ac_cv_header_stdc=yes -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - ac_cv_header_stdc=no -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - -if test $ac_cv_header_stdc = yes; then - # SunOS 4.x string.h does not declare mem*, contrary to ANSI. - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -#include <string.h> - -_ACEOF -if (eval "$ac_cpp conftest.$ac_ext") 2>&5 | - $EGREP "memchr" >/dev/null 2>&1; then - : -else - ac_cv_header_stdc=no -fi -rm -f conftest* - -fi - -if test $ac_cv_header_stdc = yes; then - # ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI. - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -#include <stdlib.h> - -_ACEOF -if (eval "$ac_cpp conftest.$ac_ext") 2>&5 | - $EGREP "free" >/dev/null 2>&1; then - : -else - ac_cv_header_stdc=no -fi -rm -f conftest* - -fi - -if test $ac_cv_header_stdc = yes; then - # /bin/cc in Irix-4.0.5 gets non-ANSI ctype macros unless using -ansi. - if test "$cross_compiling" = yes; then - : -else - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -#include <ctype.h> -#include <stdlib.h> -#if ((' ' & 0x0FF) == 0x020) -# define ISLOWER(c) ('a' <= (c) && (c) <= 'z') -# define TOUPPER(c) (ISLOWER(c) ? 'A' + ((c) - 'a') : (c)) -#else -# define ISLOWER(c) \ - (('a' <= (c) && (c) <= 'i') \ - || ('j' <= (c) && (c) <= 'r') \ - || ('s' <= (c) && (c) <= 'z')) -# define TOUPPER(c) (ISLOWER(c) ? ((c) | 0x40) : (c)) -#endif - -#define XOR(e, f) (((e) && !(f)) || (!(e) && (f))) -int -main () -{ - int i; - for (i = 0; i < 256; i++) - if (XOR (islower (i), ISLOWER (i)) - || toupper (i) != TOUPPER (i)) - return 2; - return 0; -} -_ACEOF -rm -f conftest$ac_exeext -if { (ac_try="$ac_link" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_link") 2>&5 - ac_status=$? - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { ac_try='./conftest$ac_exeext' - { (case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_try") 2>&5 - ac_status=$? - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); }; }; then - : -else - echo "$as_me: program exited with status $ac_status" >&5 -echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - -( exit $ac_status ) -ac_cv_header_stdc=no -fi -rm -f core *.core core.conftest.* gmon.out bb.out conftest$ac_exeext conftest.$ac_objext conftest.$ac_ext -fi - - -fi -fi -{ echo "$as_me:$LINENO: result: $ac_cv_header_stdc" >&5 -echo "${ECHO_T}$ac_cv_header_stdc" >&6; } -if test $ac_cv_header_stdc = yes; then - -cat >>confdefs.h <<\_ACEOF -@%:@define STDC_HEADERS 1 -_ACEOF - -fi - -# On IRIX 5.3, sys/types and inttypes.h are conflicting. - - - - - - - - - -for ac_header in sys/types.h sys/stat.h stdlib.h string.h memory.h strings.h \ - inttypes.h stdint.h unistd.h -do -as_ac_Header=`echo "ac_cv_header_$ac_header" | $as_tr_sh` -{ echo "$as_me:$LINENO: checking for $ac_header" >&5 -echo $ECHO_N "checking for $ac_header... $ECHO_C" >&6; } -if { as_var=$as_ac_Header; eval "test \"\${$as_var+set}\" = set"; }; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -$ac_includes_default - -@%:@include <$ac_header> -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - eval "$as_ac_Header=yes" -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - eval "$as_ac_Header=no" -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext -fi -ac_res=`eval echo '${'$as_ac_Header'}'` - { echo "$as_me:$LINENO: result: $ac_res" >&5 -echo "${ECHO_T}$ac_res" >&6; } -if test `eval echo '${'$as_ac_Header'}'` = yes; then - cat >>confdefs.h <<_ACEOF -@%:@define `echo "HAVE_$ac_header" | $as_tr_cpp` 1 -_ACEOF - -fi - -done - - -{ echo "$as_me:$LINENO: checking whether byte ordering is bigendian" >&5 -echo $ECHO_N "checking whether byte ordering is bigendian... $ECHO_C" >&6; } -if test "${ac_cv_c_bigendian+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - # See if sys/param.h defines the BYTE_ORDER macro. -cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -#include <sys/types.h> -#include <sys/param.h> - -int -main () -{ -#if ! (defined BYTE_ORDER && defined BIG_ENDIAN && defined LITTLE_ENDIAN \ - && BYTE_ORDER && BIG_ENDIAN && LITTLE_ENDIAN) - bogus endian macros -#endif - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - # It does; now see whether it defined to BIG_ENDIAN or not. -cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -#include <sys/types.h> -#include <sys/param.h> - -int -main () -{ -#if BYTE_ORDER != BIG_ENDIAN - not big endian -#endif - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - ac_cv_c_bigendian=yes -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - ac_cv_c_bigendian=no -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - # It does not; compile a test program. -if test "$cross_compiling" = yes; then - # try to guess the endianness by grepping values into an object file - ac_cv_c_bigendian=unknown - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -short int ascii_mm[] = { 0x4249, 0x4765, 0x6E44, 0x6961, 0x6E53, 0x7953, 0 }; -short int ascii_ii[] = { 0x694C, 0x5454, 0x656C, 0x6E45, 0x6944, 0x6E61, 0 }; -void _ascii () { char *s = (char *) ascii_mm; s = (char *) ascii_ii; } -short int ebcdic_ii[] = { 0x89D3, 0xE3E3, 0x8593, 0x95C5, 0x89C4, 0x9581, 0 }; -short int ebcdic_mm[] = { 0xC2C9, 0xC785, 0x95C4, 0x8981, 0x95E2, 0xA8E2, 0 }; -void _ebcdic () { char *s = (char *) ebcdic_mm; s = (char *) ebcdic_ii; } -int -main () -{ - _ascii (); _ebcdic (); - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - if grep BIGenDianSyS conftest.$ac_objext >/dev/null ; then - ac_cv_c_bigendian=yes -fi -if grep LiTTleEnDian conftest.$ac_objext >/dev/null ; then - if test "$ac_cv_c_bigendian" = unknown; then - ac_cv_c_bigendian=no - else - # finding both strings is unlikely to happen, but who knows? - ac_cv_c_bigendian=unknown - fi -fi -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext -else - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -$ac_includes_default -int -main () -{ - - /* Are we little or big endian? From Harbison&Steele. */ - union - { - long int l; - char c[sizeof (long int)]; - } u; - u.l = 1; - return u.c[sizeof (long int) - 1] == 1; - - ; - return 0; -} -_ACEOF -rm -f conftest$ac_exeext -if { (ac_try="$ac_link" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_link") 2>&5 - ac_status=$? - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { ac_try='./conftest$ac_exeext' - { (case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_try") 2>&5 - ac_status=$? - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); }; }; then - ac_cv_c_bigendian=no -else - echo "$as_me: program exited with status $ac_status" >&5 -echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - -( exit $ac_status ) -ac_cv_c_bigendian=yes -fi -rm -f core *.core core.conftest.* gmon.out bb.out conftest$ac_exeext conftest.$ac_objext conftest.$ac_ext -fi - - -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext -fi -{ echo "$as_me:$LINENO: result: $ac_cv_c_bigendian" >&5 -echo "${ECHO_T}$ac_cv_c_bigendian" >&6; } -case $ac_cv_c_bigendian in - yes) - -cat >>confdefs.h <<\_ACEOF -@%:@define WORDS_BIGENDIAN 1 -_ACEOF - ;; - no) - ;; - *) - { { echo "$as_me:$LINENO: error: unknown endianness -presetting ac_cv_c_bigendian=no (or yes) will help" >&5 -echo "$as_me: error: unknown endianness -presetting ac_cv_c_bigendian=no (or yes) will help" >&2;} - { (exit 1); exit 1; }; } ;; -esac - - -{ echo "$as_me:$LINENO: checking for long int" >&5 -echo $ECHO_N "checking for long int... $ECHO_C" >&6; } -if test "${ac_cv_type_long_int+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -$ac_includes_default -typedef long int ac__type_new_; -int -main () -{ -if ((ac__type_new_ *) 0) - return 0; -if (sizeof (ac__type_new_)) - return 0; - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - ac_cv_type_long_int=yes -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - ac_cv_type_long_int=no -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext -fi -{ echo "$as_me:$LINENO: result: $ac_cv_type_long_int" >&5 -echo "${ECHO_T}$ac_cv_type_long_int" >&6; } - -# The cast to long int works around a bug in the HP C Compiler -# version HP92453-01 B.11.11.23709.GP, which incorrectly rejects -# declarations like `int a3[[(sizeof (unsigned char)) >= 0]];'. -# This bug is HP SR number 8606223364. -{ echo "$as_me:$LINENO: checking size of long int" >&5 -echo $ECHO_N "checking size of long int... $ECHO_C" >&6; } -if test "${ac_cv_sizeof_long_int+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - if test "$cross_compiling" = yes; then - # Depending upon the size, compute the lo and hi bounds. -cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -$ac_includes_default - typedef long int ac__type_sizeof_; -int -main () -{ -static int test_array @<:@1 - 2 * !(((long int) (sizeof (ac__type_sizeof_))) >= 0)@:>@; -test_array @<:@0@:>@ = 0 - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - ac_lo=0 ac_mid=0 - while :; do - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -$ac_includes_default - typedef long int ac__type_sizeof_; -int -main () -{ -static int test_array @<:@1 - 2 * !(((long int) (sizeof (ac__type_sizeof_))) <= $ac_mid)@:>@; -test_array @<:@0@:>@ = 0 - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - ac_hi=$ac_mid; break -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - ac_lo=`expr $ac_mid + 1` - if test $ac_lo -le $ac_mid; then - ac_lo= ac_hi= - break - fi - ac_mid=`expr 2 '*' $ac_mid + 1` -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - done -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -$ac_includes_default - typedef long int ac__type_sizeof_; -int -main () -{ -static int test_array @<:@1 - 2 * !(((long int) (sizeof (ac__type_sizeof_))) < 0)@:>@; -test_array @<:@0@:>@ = 0 - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - ac_hi=-1 ac_mid=-1 - while :; do - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -$ac_includes_default - typedef long int ac__type_sizeof_; -int -main () -{ -static int test_array @<:@1 - 2 * !(((long int) (sizeof (ac__type_sizeof_))) >= $ac_mid)@:>@; -test_array @<:@0@:>@ = 0 - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - ac_lo=$ac_mid; break -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - ac_hi=`expr '(' $ac_mid ')' - 1` - if test $ac_mid -le $ac_hi; then - ac_lo= ac_hi= - break - fi - ac_mid=`expr 2 '*' $ac_mid` -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - done -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - ac_lo= ac_hi= -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext -# Binary search between lo and hi bounds. -while test "x$ac_lo" != "x$ac_hi"; do - ac_mid=`expr '(' $ac_hi - $ac_lo ')' / 2 + $ac_lo` - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -$ac_includes_default - typedef long int ac__type_sizeof_; -int -main () -{ -static int test_array @<:@1 - 2 * !(((long int) (sizeof (ac__type_sizeof_))) <= $ac_mid)@:>@; -test_array @<:@0@:>@ = 0 - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - ac_hi=$ac_mid -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - ac_lo=`expr '(' $ac_mid ')' + 1` -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext -done -case $ac_lo in -?*) ac_cv_sizeof_long_int=$ac_lo;; -'') if test "$ac_cv_type_long_int" = yes; then - { { echo "$as_me:$LINENO: error: cannot compute sizeof (long int) -See \`config.log' for more details." >&5 -echo "$as_me: error: cannot compute sizeof (long int) -See \`config.log' for more details." >&2;} - { (exit 77); exit 77; }; } - else - ac_cv_sizeof_long_int=0 - fi ;; -esac -else - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -$ac_includes_default - typedef long int ac__type_sizeof_; -static long int longval () { return (long int) (sizeof (ac__type_sizeof_)); } -static unsigned long int ulongval () { return (long int) (sizeof (ac__type_sizeof_)); } -@%:@include <stdio.h> -@%:@include <stdlib.h> -int -main () -{ - - FILE *f = fopen ("conftest.val", "w"); - if (! f) - return 1; - if (((long int) (sizeof (ac__type_sizeof_))) < 0) - { - long int i = longval (); - if (i != ((long int) (sizeof (ac__type_sizeof_)))) - return 1; - fprintf (f, "%ld\n", i); - } - else - { - unsigned long int i = ulongval (); - if (i != ((long int) (sizeof (ac__type_sizeof_)))) - return 1; - fprintf (f, "%lu\n", i); - } - return ferror (f) || fclose (f) != 0; - - ; - return 0; -} -_ACEOF -rm -f conftest$ac_exeext -if { (ac_try="$ac_link" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_link") 2>&5 - ac_status=$? - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { ac_try='./conftest$ac_exeext' - { (case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_try") 2>&5 - ac_status=$? - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); }; }; then - ac_cv_sizeof_long_int=`cat conftest.val` -else - echo "$as_me: program exited with status $ac_status" >&5 -echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - -( exit $ac_status ) -if test "$ac_cv_type_long_int" = yes; then - { { echo "$as_me:$LINENO: error: cannot compute sizeof (long int) -See \`config.log' for more details." >&5 -echo "$as_me: error: cannot compute sizeof (long int) -See \`config.log' for more details." >&2;} - { (exit 77); exit 77; }; } - else - ac_cv_sizeof_long_int=0 - fi -fi -rm -f core *.core core.conftest.* gmon.out bb.out conftest$ac_exeext conftest.$ac_objext conftest.$ac_ext -fi -rm -f conftest.val -fi -{ echo "$as_me:$LINENO: result: $ac_cv_sizeof_long_int" >&5 -echo "${ECHO_T}$ac_cv_sizeof_long_int" >&6; } - - - -cat >>confdefs.h <<_ACEOF -@%:@define SIZEOF_LONG_INT $ac_cv_sizeof_long_int -_ACEOF - - -{ echo "$as_me:$LINENO: checking for void *" >&5 -echo $ECHO_N "checking for void *... $ECHO_C" >&6; } -if test "${ac_cv_type_void_p+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -$ac_includes_default -typedef void * ac__type_new_; -int -main () -{ -if ((ac__type_new_ *) 0) - return 0; -if (sizeof (ac__type_new_)) - return 0; - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - ac_cv_type_void_p=yes -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - ac_cv_type_void_p=no -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext -fi -{ echo "$as_me:$LINENO: result: $ac_cv_type_void_p" >&5 -echo "${ECHO_T}$ac_cv_type_void_p" >&6; } - -# The cast to long int works around a bug in the HP C Compiler -# version HP92453-01 B.11.11.23709.GP, which incorrectly rejects -# declarations like `int a3[[(sizeof (unsigned char)) >= 0]];'. -# This bug is HP SR number 8606223364. -{ echo "$as_me:$LINENO: checking size of void *" >&5 -echo $ECHO_N "checking size of void *... $ECHO_C" >&6; } -if test "${ac_cv_sizeof_void_p+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - if test "$cross_compiling" = yes; then - # Depending upon the size, compute the lo and hi bounds. -cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -$ac_includes_default - typedef void * ac__type_sizeof_; -int -main () -{ -static int test_array @<:@1 - 2 * !(((long int) (sizeof (ac__type_sizeof_))) >= 0)@:>@; -test_array @<:@0@:>@ = 0 - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - ac_lo=0 ac_mid=0 - while :; do - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -$ac_includes_default - typedef void * ac__type_sizeof_; -int -main () -{ -static int test_array @<:@1 - 2 * !(((long int) (sizeof (ac__type_sizeof_))) <= $ac_mid)@:>@; -test_array @<:@0@:>@ = 0 - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - ac_hi=$ac_mid; break -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - ac_lo=`expr $ac_mid + 1` - if test $ac_lo -le $ac_mid; then - ac_lo= ac_hi= - break - fi - ac_mid=`expr 2 '*' $ac_mid + 1` -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - done -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -$ac_includes_default - typedef void * ac__type_sizeof_; -int -main () -{ -static int test_array @<:@1 - 2 * !(((long int) (sizeof (ac__type_sizeof_))) < 0)@:>@; -test_array @<:@0@:>@ = 0 - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - ac_hi=-1 ac_mid=-1 - while :; do - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -$ac_includes_default - typedef void * ac__type_sizeof_; -int -main () -{ -static int test_array @<:@1 - 2 * !(((long int) (sizeof (ac__type_sizeof_))) >= $ac_mid)@:>@; -test_array @<:@0@:>@ = 0 - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - ac_lo=$ac_mid; break -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - ac_hi=`expr '(' $ac_mid ')' - 1` - if test $ac_mid -le $ac_hi; then - ac_lo= ac_hi= - break - fi - ac_mid=`expr 2 '*' $ac_mid` -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - done -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - ac_lo= ac_hi= -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext -# Binary search between lo and hi bounds. -while test "x$ac_lo" != "x$ac_hi"; do - ac_mid=`expr '(' $ac_hi - $ac_lo ')' / 2 + $ac_lo` - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -$ac_includes_default - typedef void * ac__type_sizeof_; -int -main () -{ -static int test_array @<:@1 - 2 * !(((long int) (sizeof (ac__type_sizeof_))) <= $ac_mid)@:>@; -test_array @<:@0@:>@ = 0 - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - ac_hi=$ac_mid -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - ac_lo=`expr '(' $ac_mid ')' + 1` -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext -done -case $ac_lo in -?*) ac_cv_sizeof_void_p=$ac_lo;; -'') if test "$ac_cv_type_void_p" = yes; then - { { echo "$as_me:$LINENO: error: cannot compute sizeof (void *) -See \`config.log' for more details." >&5 -echo "$as_me: error: cannot compute sizeof (void *) -See \`config.log' for more details." >&2;} - { (exit 77); exit 77; }; } - else - ac_cv_sizeof_void_p=0 - fi ;; -esac -else - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -$ac_includes_default - typedef void * ac__type_sizeof_; -static long int longval () { return (long int) (sizeof (ac__type_sizeof_)); } -static unsigned long int ulongval () { return (long int) (sizeof (ac__type_sizeof_)); } -@%:@include <stdio.h> -@%:@include <stdlib.h> -int -main () -{ - - FILE *f = fopen ("conftest.val", "w"); - if (! f) - return 1; - if (((long int) (sizeof (ac__type_sizeof_))) < 0) - { - long int i = longval (); - if (i != ((long int) (sizeof (ac__type_sizeof_)))) - return 1; - fprintf (f, "%ld\n", i); - } - else - { - unsigned long int i = ulongval (); - if (i != ((long int) (sizeof (ac__type_sizeof_)))) - return 1; - fprintf (f, "%lu\n", i); - } - return ferror (f) || fclose (f) != 0; - - ; - return 0; -} -_ACEOF -rm -f conftest$ac_exeext -if { (ac_try="$ac_link" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_link") 2>&5 - ac_status=$? - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { ac_try='./conftest$ac_exeext' - { (case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_try") 2>&5 - ac_status=$? - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); }; }; then - ac_cv_sizeof_void_p=`cat conftest.val` -else - echo "$as_me: program exited with status $ac_status" >&5 -echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - -( exit $ac_status ) -if test "$ac_cv_type_void_p" = yes; then - { { echo "$as_me:$LINENO: error: cannot compute sizeof (void *) -See \`config.log' for more details." >&5 -echo "$as_me: error: cannot compute sizeof (void *) -See \`config.log' for more details." >&2;} - { (exit 77); exit 77; }; } - else - ac_cv_sizeof_void_p=0 - fi -fi -rm -f core *.core core.conftest.* gmon.out bb.out conftest$ac_exeext conftest.$ac_objext conftest.$ac_ext -fi -rm -f conftest.val -fi -{ echo "$as_me:$LINENO: result: $ac_cv_sizeof_void_p" >&5 -echo "${ECHO_T}$ac_cv_sizeof_void_p" >&6; } - - - -cat >>confdefs.h <<_ACEOF -@%:@define SIZEOF_VOID_P $ac_cv_sizeof_void_p -_ACEOF - - - -{ echo "$as_me:$LINENO: checking for required gcc" >&5 -echo $ECHO_N "checking for required gcc... $ECHO_C" >&6; } -if test "x$GCC" = "x"; then - { { echo "$as_me:$LINENO: error: no" >&5 -echo "$as_me: error: no" >&2;} - { (exit 1); exit 1; }; } -fi -{ echo "$as_me:$LINENO: result: yes" >&5 -echo "${ECHO_T}yes" >&6; } - - -# Check whether --with-ghc was given. -if test "${with_ghc+set}" = set; then - withval=$with_ghc; # Extract the first word of "${withval}/bin/ghc", so it can be a program name with args. -set dummy ${withval}/bin/ghc; ac_word=$2 -{ echo "$as_me:$LINENO: checking for $ac_word" >&5 -echo $ECHO_N "checking for $ac_word... $ECHO_C" >&6; } -if test "${ac_cv_path_GHC+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - case $GHC in - [\\/]* | ?:[\\/]*) - ac_cv_path_GHC="$GHC" # Let the user override the test with a path. - ;; - *) - as_save_IFS=$IFS; IFS=$PATH_SEPARATOR -for as_dir in $PATH -do - IFS=$as_save_IFS - test -z "$as_dir" && as_dir=. - for ac_exec_ext in '' $ac_executable_extensions; do - if { test -f "$as_dir/$ac_word$ac_exec_ext" && $as_test_x "$as_dir/$ac_word$ac_exec_ext"; }; then - ac_cv_path_GHC="$as_dir/$ac_word$ac_exec_ext" - echo "$as_me:$LINENO: found $as_dir/$ac_word$ac_exec_ext" >&5 - break 2 - fi -done -done -IFS=$as_save_IFS - - ;; -esac -fi -GHC=$ac_cv_path_GHC -if test -n "$GHC"; then - { echo "$as_me:$LINENO: result: $GHC" >&5 -echo "${ECHO_T}$GHC" >&6; } -else - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } -fi - - -else - # Extract the first word of "ghc", so it can be a program name with args. -set dummy ghc; ac_word=$2 -{ echo "$as_me:$LINENO: checking for $ac_word" >&5 -echo $ECHO_N "checking for $ac_word... $ECHO_C" >&6; } -if test "${ac_cv_path_GHC+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - case $GHC in - [\\/]* | ?:[\\/]*) - ac_cv_path_GHC="$GHC" # Let the user override the test with a path. - ;; - *) - as_save_IFS=$IFS; IFS=$PATH_SEPARATOR -for as_dir in $PATH -do - IFS=$as_save_IFS - test -z "$as_dir" && as_dir=. - for ac_exec_ext in '' $ac_executable_extensions; do - if { test -f "$as_dir/$ac_word$ac_exec_ext" && $as_test_x "$as_dir/$ac_word$ac_exec_ext"; }; then - ac_cv_path_GHC="$as_dir/$ac_word$ac_exec_ext" - echo "$as_me:$LINENO: found $as_dir/$ac_word$ac_exec_ext" >&5 - break 2 - fi -done -done -IFS=$as_save_IFS - - ;; -esac -fi -GHC=$ac_cv_path_GHC -if test -n "$GHC"; then - { echo "$as_me:$LINENO: result: $GHC" >&5 -echo "${ECHO_T}$GHC" >&6; } -else - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } -fi - - -fi - - - - -# Check whether --with-db was given. -if test "${with_db+set}" = set; then - withval=$with_db; - dbpath=${withval} - - DB_LDFLAGS= - { echo "$as_me:$LINENO: checking for db library" >&5 -echo $ECHO_N "checking for db library... $ECHO_C" >&6; } - oldlibs=$LIBS - lib=notfound - - if test "x$dbpath" != "x" ; then - oldcflags=$CFLAGS - for dbheader in db4 db3 notfound; do - cat >conftest.$ac_ext <<_ACEOF -#include "$dbpath/include/$dbheader/db.h" -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - DB_CFLAGS="-I$dbpath/include/$dbheader/" - break -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - done - - if test "x$dbheader" = "xnotfound"; then - cat >conftest.$ac_ext <<_ACEOF -#include "$dbpath/include/db.h" -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - DB_CFLAGS="-I$dbpath/include/" -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - { { echo "$as_me:$LINENO: error: Invalid libdb path specified. No db.h found. -See \`config.log' for more details." >&5 -echo "$as_me: error: Invalid libdb path specified. No db.h found. -See \`config.log' for more details." >&2;} - { (exit 1); exit 1; }; } -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - fi - - DB_LDFLAGS="-L${dbpath}/lib" - LDFLAGS="$DB_LDFLAGS ${LDFLAGS}" - - LIBS="${oldlibs} -ldb -lpthread" - DB_LIB="-ldb" - CFLAGS="$DB_CFLAGS $oldcflags" - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -#include <db.h> -int -main () -{ -DB *dbp; db_create(&dbp, NULL, 0); - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext conftest$ac_exeext -if { (ac_try="$ac_link" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_link") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest$ac_exeext && - $as_test_x conftest$ac_exeext; then - lib=db -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - -fi - -rm -f core conftest.err conftest.$ac_objext conftest_ipa8_conftest.oo \ - conftest$ac_exeext conftest.$ac_ext - CFLAGS=$oldcflags - - else - for lib in db4 db3 db notfound; do - LIBS="${oldlibs} -l$lib -lpthread" - DB_LIB="-l$lib" - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -#include <db.h> -int -main () -{ -DB *dbp; db_create(&dbp, NULL, 0); - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext conftest$ac_exeext -if { (ac_try="$ac_link" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_link") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest$ac_exeext && - $as_test_x conftest$ac_exeext; then - break -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - -fi - -rm -f core conftest.err conftest.$ac_objext conftest_ipa8_conftest.oo \ - conftest$ac_exeext conftest.$ac_ext - done - fi - - LIBS=$oldlibs - if test "x$lib" = "xnotfound" ; then - { { echo "$as_me:$LINENO: error: could not find DB libraries" >&5 -echo "$as_me: error: could not find DB libraries" >&2;} - { (exit 1); exit 1; }; } - else - { echo "$as_me:$LINENO: result: $lib" >&5 -echo "${ECHO_T}$lib" >&6; } - fi - - - - - { echo "$as_me:$LINENO: checking for dbenv parameter to DB error callback function" >&5 -echo $ECHO_N "checking for dbenv parameter to DB error callback function... $ECHO_C" >&6; } - oldcflags=$CFLAGS - CFLAGS="$USR_CFLAGS $DB_CFLAGS -Werror" - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - - #include <db.h> - - void error_callback_fn(const DB_ENV *dbenv, - const char *prefix, - const char *message) - { - return; - } - -int -main () -{ - - DB *db; - - db->set_errcall(db, error_callback_fn); - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - { echo "$as_me:$LINENO: result: yes" >&5 -echo "${ECHO_T}yes" >&6; } - -cat >>confdefs.h <<\_ACEOF -@%:@define HAVE_DBENV_PARAMETER_TO_DB_ERROR_CALLBACK 1 -_ACEOF - - have_dbenv_parameter_to_db_error_callback=yes -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } - have_dbenv_parameter_to_db_error_callback=no -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - - if test "x$have_dbenv_parameter_to_db_error_callback" = "xyes" ; then - { echo "$as_me:$LINENO: checking if third parameter to error callback function is const" >&5 -echo $ECHO_N "checking if third parameter to error callback function is const... $ECHO_C" >&6; } - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - - #include <db.h> - - void error_callback_fn(const DB_ENV *dbenv, - const char *prefix, - char *message) - { - return; - } - -int -main () -{ - - DB *db; - - db->set_errcall(db, error_callback_fn); - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - { echo "$as_me:$LINENO: result: yes" >&5 -echo "${ECHO_T}yes" >&6; } - -cat >>confdefs.h <<\_ACEOF -@%:@define HAVE_CONST_THIRD_PARAMETER_TO_DB_ERROR_CALLBACK 1 -_ACEOF - -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - fi - - CFLAGS="$USR_CFLAGS $DB_CFLAGS -Werror" - { echo "$as_me:$LINENO: checking for DB stat with malloc function ptr" >&5 -echo $ECHO_N "checking for DB stat with malloc function ptr... $ECHO_C" >&6; } - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - - #include <db.h> - #include <stdlib.h> - -int -main () -{ - - int ret = 0; - DB *db = db; - int dummy = 0; - u_int32_t flags = 0; - - ret = db->stat(db, &dummy, malloc, flags); - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - { echo "$as_me:$LINENO: result: yes" >&5 -echo "${ECHO_T}yes" >&6; } - -cat >>confdefs.h <<\_ACEOF -@%:@define HAVE_UNKNOWN_PARAMETER_TO_DB_STAT 1 -_ACEOF - - have_db_stat_malloc=yes -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } - have_db_stat_malloc=no -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - - if test "x$have_db_stat_malloc" = "xno" ; then - - { echo "$as_me:$LINENO: checking for txnid parameter to DB stat function" >&5 -echo $ECHO_N "checking for txnid parameter to DB stat function... $ECHO_C" >&6; } - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - - #include <db.h> - -int -main () -{ - - int ret = 0; - DB *db = db; - DB_TXN *txnid = txnid; - u_int32_t flags = 0; - - ret = db->stat(db, txnid, NULL, flags); - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - { echo "$as_me:$LINENO: result: yes" >&5 -echo "${ECHO_T}yes" >&6; } - -cat >>confdefs.h <<\_ACEOF -@%:@define HAVE_TXNID_PARAMETER_TO_DB_STAT 1 -_ACEOF - - have_txnid_param_to_stat=yes -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } - have_txnid_param_to_stat=no -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - - fi - - { echo "$as_me:$LINENO: checking for txnid parameter to DB open function" >&5 -echo $ECHO_N "checking for txnid parameter to DB open function... $ECHO_C" >&6; } - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - - #include <db.h> - -int -main () -{ - - int ret = 0; - DB *db = NULL; - DB_TXN *txnid = NULL; - char *file = NULL; - char *database = NULL; - DBTYPE type = 0; - u_int32_t flags = 0; - int mode = 0; - - ret = db->open(db, txnid, file, database, type, flags, mode); - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - { echo "$as_me:$LINENO: result: yes" >&5 -echo "${ECHO_T}yes" >&6; } - -cat >>confdefs.h <<\_ACEOF -@%:@define HAVE_TXNID_PARAMETER_TO_DB_OPEN 1 -_ACEOF - -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - - { echo "$as_me:$LINENO: checking for DB_DIRTY_READ flag" >&5 -echo $ECHO_N "checking for DB_DIRTY_READ flag... $ECHO_C" >&6; } - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - - #include <db.h> - -int -main () -{ - - u_int32_t flags = DB_DIRTY_READ; - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - { echo "$as_me:$LINENO: result: yes" >&5 -echo "${ECHO_T}yes" >&6; } - -cat >>confdefs.h <<\_ACEOF -@%:@define HAVE_DB_DIRTY_READ 1 -_ACEOF - -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - - { echo "$as_me:$LINENO: checking for DB_BUFFER_SMALL error" >&5 -echo $ECHO_N "checking for DB_BUFFER_SMALL error... $ECHO_C" >&6; } - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - - #include <db.h> - -int -main () -{ - - int res = DB_BUFFER_SMALL; - res++; - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - { echo "$as_me:$LINENO: result: yes" >&5 -echo "${ECHO_T}yes" >&6; } - -cat >>confdefs.h <<\_ACEOF -@%:@define HAVE_DB_BUFFER_SMALL 1 -_ACEOF - -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - - { echo "$as_me:$LINENO: checking for berkeley db get_pagesize function" >&5 -echo $ECHO_N "checking for berkeley db get_pagesize function... $ECHO_C" >&6; } - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - - #include <db.h> - -int -main () -{ - - int ret = 0; - DB *db = NULL; - int pagesize; - - ret = db->get_pagesize(db, &pagesize); - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - { echo "$as_me:$LINENO: result: yes" >&5 -echo "${ECHO_T}yes" >&6; } - -cat >>confdefs.h <<\_ACEOF -@%:@define HAVE_DB_GET_PAGESIZE 1 -_ACEOF - -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - - CFLAGS="$oldcflags" - -else - - dbpath="" - - DB_LDFLAGS= - { echo "$as_me:$LINENO: checking for db library" >&5 -echo $ECHO_N "checking for db library... $ECHO_C" >&6; } - oldlibs=$LIBS - lib=notfound - - if test "x$dbpath" != "x" ; then - oldcflags=$CFLAGS - for dbheader in db4 db3 notfound; do - cat >conftest.$ac_ext <<_ACEOF -#include "$dbpath/include/$dbheader/db.h" -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - DB_CFLAGS="-I$dbpath/include/$dbheader/" - break -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - done - - if test "x$dbheader" = "xnotfound"; then - cat >conftest.$ac_ext <<_ACEOF -#include "$dbpath/include/db.h" -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - DB_CFLAGS="-I$dbpath/include/" -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - { { echo "$as_me:$LINENO: error: Invalid libdb path specified. No db.h found. -See \`config.log' for more details." >&5 -echo "$as_me: error: Invalid libdb path specified. No db.h found. -See \`config.log' for more details." >&2;} - { (exit 1); exit 1; }; } -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - fi - - DB_LDFLAGS="-L${dbpath}/lib" - LDFLAGS="$DB_LDFLAGS ${LDFLAGS}" - - LIBS="${oldlibs} -ldb -lpthread" - DB_LIB="-ldb" - CFLAGS="$DB_CFLAGS $oldcflags" - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -#include <db.h> -int -main () -{ -DB *dbp; db_create(&dbp, NULL, 0); - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext conftest$ac_exeext -if { (ac_try="$ac_link" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_link") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest$ac_exeext && - $as_test_x conftest$ac_exeext; then - lib=db -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - -fi - -rm -f core conftest.err conftest.$ac_objext conftest_ipa8_conftest.oo \ - conftest$ac_exeext conftest.$ac_ext - CFLAGS=$oldcflags - - else - for lib in db4 db3 db notfound; do - LIBS="${oldlibs} -l$lib -lpthread" - DB_LIB="-l$lib" - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -#include <db.h> -int -main () -{ -DB *dbp; db_create(&dbp, NULL, 0); - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext conftest$ac_exeext -if { (ac_try="$ac_link" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_link") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest$ac_exeext && - $as_test_x conftest$ac_exeext; then - break -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - -fi - -rm -f core conftest.err conftest.$ac_objext conftest_ipa8_conftest.oo \ - conftest$ac_exeext conftest.$ac_ext - done - fi - - LIBS=$oldlibs - if test "x$lib" = "xnotfound" ; then - { { echo "$as_me:$LINENO: error: could not find DB libraries" >&5 -echo "$as_me: error: could not find DB libraries" >&2;} - { (exit 1); exit 1; }; } - else - { echo "$as_me:$LINENO: result: $lib" >&5 -echo "${ECHO_T}$lib" >&6; } - fi - - - - - { echo "$as_me:$LINENO: checking for dbenv parameter to DB error callback function" >&5 -echo $ECHO_N "checking for dbenv parameter to DB error callback function... $ECHO_C" >&6; } - oldcflags=$CFLAGS - CFLAGS="$USR_CFLAGS $DB_CFLAGS -Werror" - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - - #include <db.h> - - void error_callback_fn(const DB_ENV *dbenv, - const char *prefix, - const char *message) - { - return; - } - -int -main () -{ - - DB *db; - - db->set_errcall(db, error_callback_fn); - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - { echo "$as_me:$LINENO: result: yes" >&5 -echo "${ECHO_T}yes" >&6; } - -cat >>confdefs.h <<\_ACEOF -@%:@define HAVE_DBENV_PARAMETER_TO_DB_ERROR_CALLBACK 1 -_ACEOF - - have_dbenv_parameter_to_db_error_callback=yes -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } - have_dbenv_parameter_to_db_error_callback=no -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - - if test "x$have_dbenv_parameter_to_db_error_callback" = "xyes" ; then - { echo "$as_me:$LINENO: checking if third parameter to error callback function is const" >&5 -echo $ECHO_N "checking if third parameter to error callback function is const... $ECHO_C" >&6; } - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - - #include <db.h> - - void error_callback_fn(const DB_ENV *dbenv, - const char *prefix, - char *message) - { - return; - } - -int -main () -{ - - DB *db; - - db->set_errcall(db, error_callback_fn); - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - { echo "$as_me:$LINENO: result: yes" >&5 -echo "${ECHO_T}yes" >&6; } - -cat >>confdefs.h <<\_ACEOF -@%:@define HAVE_CONST_THIRD_PARAMETER_TO_DB_ERROR_CALLBACK 1 -_ACEOF - -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - fi - - CFLAGS="$USR_CFLAGS $DB_CFLAGS -Werror" - { echo "$as_me:$LINENO: checking for DB stat with malloc function ptr" >&5 -echo $ECHO_N "checking for DB stat with malloc function ptr... $ECHO_C" >&6; } - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - - #include <db.h> - #include <stdlib.h> - -int -main () -{ - - int ret = 0; - DB *db = db; - int dummy = 0; - u_int32_t flags = 0; - - ret = db->stat(db, &dummy, malloc, flags); - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - { echo "$as_me:$LINENO: result: yes" >&5 -echo "${ECHO_T}yes" >&6; } - -cat >>confdefs.h <<\_ACEOF -@%:@define HAVE_UNKNOWN_PARAMETER_TO_DB_STAT 1 -_ACEOF - - have_db_stat_malloc=yes -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } - have_db_stat_malloc=no -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - - if test "x$have_db_stat_malloc" = "xno" ; then - - { echo "$as_me:$LINENO: checking for txnid parameter to DB stat function" >&5 -echo $ECHO_N "checking for txnid parameter to DB stat function... $ECHO_C" >&6; } - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - - #include <db.h> - -int -main () -{ - - int ret = 0; - DB *db = db; - DB_TXN *txnid = txnid; - u_int32_t flags = 0; - - ret = db->stat(db, txnid, NULL, flags); - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - { echo "$as_me:$LINENO: result: yes" >&5 -echo "${ECHO_T}yes" >&6; } - -cat >>confdefs.h <<\_ACEOF -@%:@define HAVE_TXNID_PARAMETER_TO_DB_STAT 1 -_ACEOF - - have_txnid_param_to_stat=yes -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } - have_txnid_param_to_stat=no -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - - fi - - { echo "$as_me:$LINENO: checking for txnid parameter to DB open function" >&5 -echo $ECHO_N "checking for txnid parameter to DB open function... $ECHO_C" >&6; } - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - - #include <db.h> - -int -main () -{ - - int ret = 0; - DB *db = NULL; - DB_TXN *txnid = NULL; - char *file = NULL; - char *database = NULL; - DBTYPE type = 0; - u_int32_t flags = 0; - int mode = 0; - - ret = db->open(db, txnid, file, database, type, flags, mode); - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - { echo "$as_me:$LINENO: result: yes" >&5 -echo "${ECHO_T}yes" >&6; } - -cat >>confdefs.h <<\_ACEOF -@%:@define HAVE_TXNID_PARAMETER_TO_DB_OPEN 1 -_ACEOF - -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - - { echo "$as_me:$LINENO: checking for DB_DIRTY_READ flag" >&5 -echo $ECHO_N "checking for DB_DIRTY_READ flag... $ECHO_C" >&6; } - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - - #include <db.h> - -int -main () -{ - - u_int32_t flags = DB_DIRTY_READ; - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - { echo "$as_me:$LINENO: result: yes" >&5 -echo "${ECHO_T}yes" >&6; } - -cat >>confdefs.h <<\_ACEOF -@%:@define HAVE_DB_DIRTY_READ 1 -_ACEOF - -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - - { echo "$as_me:$LINENO: checking for DB_BUFFER_SMALL error" >&5 -echo $ECHO_N "checking for DB_BUFFER_SMALL error... $ECHO_C" >&6; } - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - - #include <db.h> - -int -main () -{ - - int res = DB_BUFFER_SMALL; - res++; - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - { echo "$as_me:$LINENO: result: yes" >&5 -echo "${ECHO_T}yes" >&6; } - -cat >>confdefs.h <<\_ACEOF -@%:@define HAVE_DB_BUFFER_SMALL 1 -_ACEOF - -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - - { echo "$as_me:$LINENO: checking for berkeley db get_pagesize function" >&5 -echo $ECHO_N "checking for berkeley db get_pagesize function... $ECHO_C" >&6; } - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - - #include <db.h> - -int -main () -{ - - int ret = 0; - DB *db = NULL; - int pagesize; - - ret = db->get_pagesize(db, &pagesize); - - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - { echo "$as_me:$LINENO: result: yes" >&5 -echo "${ECHO_T}yes" >&6; } - -cat >>confdefs.h <<\_ACEOF -@%:@define HAVE_DB_GET_PAGESIZE 1 -_ACEOF - -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext - - CFLAGS="$oldcflags" - -fi - - - -# Check whether --with-mpi was given. -if test "${with_mpi+set}" = set; then - withval=$with_mpi; if test x$withval = xyes; then - { { echo "$as_me:$LINENO: error: --with-mpi must be given a pathname" >&5 -echo "$as_me: error: --with-mpi must be given a pathname" >&2;} - { (exit 1); exit 1; }; } - else - MPICC="${withval}/bin/mpicc" - MPICFLAGS="-I${withval}/include" - MPILDFLAGS="-L${withval}/lib" - MPILIBS="-lmpich" - BUILD_MPI="1" - fi - -fi - - - - - - - -BUILD_ABSOLUTE_TOP=${PWD} -SRC_RELATIVE_TOP=$srcdir -SRC_ABSOLUTE_TOP=`cd $srcdir; pwd` - - - - - - - - - - -# Check whether --enable-verbose was given. -if test "${enable_verbose+set}" = set; then - enableval=$enable_verbose; QUIET_COMPILE=0 -else - QUIET_COMPILE=1 -fi - - - -STRICT_CFLAGS= -# Check whether --enable-strict was given. -if test "${enable_strict+set}" = set; then - enableval=$enable_strict; STRICT_CFLAGS=1 -fi - - - -AE_DEBUG= -# Check whether --enable-aesop-debug was given. -if test "${enable_aesop_debug+set}" = set; then - enableval=$enable_aesop_debug; AE_DEBUG=1 -fi - - - -# Check whether --enable-coverage was given. -if test "${enable_coverage+set}" = set; then - enableval=$enable_coverage; CFLAGS="$CFLAGS -g -pg -ftest-coverage -O0" - ENABLE_COVERAGE=1 -fi - - - -{ echo "$as_me:$LINENO: checking for client library thread safety support" >&5 -echo $ECHO_N "checking for client library thread safety support... $ECHO_C" >&6; } -# Check whether --enable-thread-safety was given. -if test "${enable_thread_safety+set}" = set; then - enableval=$enable_thread_safety; if test "x$enableval" = "xno" ; then - LIBCFLAGS="$LIBCFLAGS -D__TRITON_NULL_LOCKING__" - THREAD_LIB="" - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } -fi -else - LIBCFLAGS="$LIBCFLAGS -D__TRITON_POSIX_LOCKING__" - THREAD_LIB="-lpthread" - { echo "$as_me:$LINENO: result: yes" >&5 -echo "${ECHO_T}yes" >&6; } -fi - - - - - - - SQLITE_MINIMUM_VER="3.0.0" - SQLITE_PKGNAME="sqlite3" - BUILD_OSD= - - - sqlite_min_major=`expr $SQLITE_MINIMUM_VER : '\([0-9]*\)'` - sqlite_min_minor=`expr $SQLITE_MINIMUM_VER : '[0-9]*\.\([0-9]*\)'` - sqlite_min_micro=`expr $SQLITE_MINIMUM_VER : '[0-9]*\.[0-9]*\.\([0-9]*\)'` - sqlite_min_ver_num=`expr $sqlite_min_major \* 1000000 \ - \+ $sqlite_min_minor \* 1000 \ - \+ $sqlite_min_micro` - - - { echo "$as_me:$LINENO: checking sqlite library" >&5 -echo "$as_me: checking sqlite library" >&6;} - - -# Check whether --with-sqlite was given. -if test "${with_sqlite+set}" = set; then - withval=$with_sqlite; - if test "$withval" = "yes" ; then - { { echo "$as_me:$LINENO: error: --with-sqlite requires an argument." >&5 -echo "$as_me: error: --with-sqlite requires an argument." >&2;} - { (exit 1); exit 1; }; } - else - sqlite_dir="$withval" - fi - - if test -d $sqlite_dir; then - - if test -z "$sqlite_dir"; then - sqlite_dir="" - sqlite_include="sqlite3.h" - else - sqlite_dir="$sqlite_dir" - sqlite_include="$sqlite_dir/include/sqlite3.h" - fi - - save_CPPFLAGS="$CPPFLAGS" - save_LDFLAGS="$LDFLAGS" - - if test ! -z "$sqlite_dir"; then - CPPFLAGS="$CPPFLAGS -I$sqlite_dir/include" - LDFLAGS="$LDFLAGS -L$sqlite_dir/lib" - fi - - if test "${ac_cv_header_sqlite3_h+set}" = set; then - { echo "$as_me:$LINENO: checking for sqlite3.h" >&5 -echo $ECHO_N "checking for sqlite3.h... $ECHO_C" >&6; } -if test "${ac_cv_header_sqlite3_h+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -fi -{ echo "$as_me:$LINENO: result: $ac_cv_header_sqlite3_h" >&5 -echo "${ECHO_T}$ac_cv_header_sqlite3_h" >&6; } -else - # Is the header compilable? -{ echo "$as_me:$LINENO: checking sqlite3.h usability" >&5 -echo $ECHO_N "checking sqlite3.h usability... $ECHO_C" >&6; } -cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -$ac_includes_default -@%:@include <sqlite3.h> -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - ac_header_compiler=yes -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - ac_header_compiler=no -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext -{ echo "$as_me:$LINENO: result: $ac_header_compiler" >&5 -echo "${ECHO_T}$ac_header_compiler" >&6; } - -# Is the header present? -{ echo "$as_me:$LINENO: checking sqlite3.h presence" >&5 -echo $ECHO_N "checking sqlite3.h presence... $ECHO_C" >&6; } -cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -@%:@include <sqlite3.h> -_ACEOF -if { (ac_try="$ac_cpp conftest.$ac_ext" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_cpp conftest.$ac_ext") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } >/dev/null && { - test -z "$ac_c_preproc_warn_flag$ac_c_werror_flag" || - test ! -s conftest.err - }; then - ac_header_preproc=yes -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - ac_header_preproc=no -fi - -rm -f conftest.err conftest.$ac_ext -{ echo "$as_me:$LINENO: result: $ac_header_preproc" >&5 -echo "${ECHO_T}$ac_header_preproc" >&6; } - -# So? What about this header? -case $ac_header_compiler:$ac_header_preproc:$ac_c_preproc_warn_flag in - yes:no: ) - { echo "$as_me:$LINENO: WARNING: sqlite3.h: accepted by the compiler, rejected by the preprocessor!" >&5 -echo "$as_me: WARNING: sqlite3.h: accepted by the compiler, rejected by the preprocessor!" >&2;} - { echo "$as_me:$LINENO: WARNING: sqlite3.h: proceeding with the compiler's result" >&5 -echo "$as_me: WARNING: sqlite3.h: proceeding with the compiler's result" >&2;} - ac_header_preproc=yes - ;; - no:yes:* ) - { echo "$as_me:$LINENO: WARNING: sqlite3.h: present but cannot be compiled" >&5 -echo "$as_me: WARNING: sqlite3.h: present but cannot be compiled" >&2;} - { echo "$as_me:$LINENO: WARNING: sqlite3.h: check for missing prerequisite headers?" >&5 -echo "$as_me: WARNING: sqlite3.h: check for missing prerequisite headers?" >&2;} - { echo "$as_me:$LINENO: WARNING: sqlite3.h: see the Autoconf documentation" >&5 -echo "$as_me: WARNING: sqlite3.h: see the Autoconf documentation" >&2;} - { echo "$as_me:$LINENO: WARNING: sqlite3.h: section \"Present But Cannot Be Compiled\"" >&5 -echo "$as_me: WARNING: sqlite3.h: section \"Present But Cannot Be Compiled\"" >&2;} - { echo "$as_me:$LINENO: WARNING: sqlite3.h: proceeding with the preprocessor's result" >&5 -echo "$as_me: WARNING: sqlite3.h: proceeding with the preprocessor's result" >&2;} - { echo "$as_me:$LINENO: WARNING: sqlite3.h: in the future, the compiler will take precedence" >&5 -echo "$as_me: WARNING: sqlite3.h: in the future, the compiler will take precedence" >&2;} - ( cat <<\_ASBOX -@%:@@%:@ ------------------------------------- @%:@@%:@ -@%:@@%:@ Report this to [email protected] @%:@@%:@ -@%:@@%:@ ------------------------------------- @%:@@%:@ -_ASBOX - ) | sed "s/^/$as_me: WARNING: /" >&2 - ;; -esac -{ echo "$as_me:$LINENO: checking for sqlite3.h" >&5 -echo $ECHO_N "checking for sqlite3.h... $ECHO_C" >&6; } -if test "${ac_cv_header_sqlite3_h+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - ac_cv_header_sqlite3_h=$ac_header_preproc -fi -{ echo "$as_me:$LINENO: result: $ac_cv_header_sqlite3_h" >&5 -echo "${ECHO_T}$ac_cv_header_sqlite3_h" >&6; } - -fi -if test $ac_cv_header_sqlite3_h = yes; then - - { echo "$as_me:$LINENO: checking sqlite library version (via header)" >&5 -echo $ECHO_N "checking sqlite library version (via header)... $ECHO_C" >&6; } - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - -#include "$sqlite_include" -#if SQLITE_VERSION_NUMBER >= $sqlite_min_ver_num -SQLITE_VERSION_OKAY -#endif -_ACEOF -if (eval "$ac_cpp conftest.$ac_ext") 2>&5 | - $EGREP "SQLITE_VERSION_OKAY" >/dev/null 2>&1; then - { echo "$as_me:$LINENO: result: okay" >&5 -echo "${ECHO_T}okay" >&6; } - { echo "$as_me:$LINENO: checking for sqlite3_close in -lsqlite3" >&5 -echo $ECHO_N "checking for sqlite3_close in -lsqlite3... $ECHO_C" >&6; } -if test "${ac_cv_lib_sqlite3_sqlite3_close+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - ac_check_lib_save_LIBS=$LIBS -LIBS="-lsqlite3 $LIBS" -cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - -/* Override any GCC internal prototype to avoid an error. - Use char because int might match the return type of a GCC - builtin and then its argument prototype would still apply. */ -#ifdef __cplusplus -extern "C" -#endif -char sqlite3_close (); -int -main () -{ -return sqlite3_close (); - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext conftest$ac_exeext -if { (ac_try="$ac_link" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_link") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest$ac_exeext && - $as_test_x conftest$ac_exeext; then - ac_cv_lib_sqlite3_sqlite3_close=yes -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - ac_cv_lib_sqlite3_sqlite3_close=no -fi - -rm -f core conftest.err conftest.$ac_objext conftest_ipa8_conftest.oo \ - conftest$ac_exeext conftest.$ac_ext -LIBS=$ac_check_lib_save_LIBS -fi -{ echo "$as_me:$LINENO: result: $ac_cv_lib_sqlite3_sqlite3_close" >&5 -echo "${ECHO_T}$ac_cv_lib_sqlite3_sqlite3_close" >&6; } -if test $ac_cv_lib_sqlite3_sqlite3_close = yes; then - - triton_lib_sqlite="yes" - if test -z "$sqlite_dir" -o ! -d "$sqlite_dir"; then - TRITON_SQLITE_LIBS="-lsqlite3" - else - TRITON_SQLITE_INCLUDES="-I$sqlite_dir/include" - TRITON_SQLITE_LIBS="-L$sqlite_dir/lib -lsqlite3" - fi - -fi - -else - { echo "$as_me:$LINENO: result: unsupported SQLite version" >&5 -echo "${ECHO_T}unsupported SQLite version" >&6; } -fi -rm -f conftest* - - -fi - - - - CPPFLAGS="$save_CPPFLAGS" - LDFLAGS="$save_LDFLAGS" - - else - { { echo "$as_me:$LINENO: error: $sqlite_dir is not a directory." >&5 -echo "$as_me: error: $sqlite_dir is not a directory." >&2;} - { (exit 1); exit 1; }; } - fi - - # if a --with-sqlite argument was given, then we should complain if we - # can't find it there - if test -z "$triton_lib_sqlite"; then - { { echo "$as_me:$LINENO: error: no suitable sqlite found in $sqlite_dir" >&5 -echo "$as_me: error: no suitable sqlite found in $sqlite_dir" >&2;} - { (exit 1); exit 1; }; } - else - BUILD_OSD=1 - fi - -else - - if test -z "$triton_lib_sqlite"; then - - if test -z ""; then - sqlite_dir="" - sqlite_include="sqlite3.h" - else - sqlite_dir="" - sqlite_include="/include/sqlite3.h" - fi - - save_CPPFLAGS="$CPPFLAGS" - save_LDFLAGS="$LDFLAGS" - - if test ! -z ""; then - CPPFLAGS="$CPPFLAGS -I$sqlite_dir/include" - LDFLAGS="$LDFLAGS -L$sqlite_dir/lib" - fi - - if test "${ac_cv_header_sqlite3_h+set}" = set; then - { echo "$as_me:$LINENO: checking for sqlite3.h" >&5 -echo $ECHO_N "checking for sqlite3.h... $ECHO_C" >&6; } -if test "${ac_cv_header_sqlite3_h+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -fi -{ echo "$as_me:$LINENO: result: $ac_cv_header_sqlite3_h" >&5 -echo "${ECHO_T}$ac_cv_header_sqlite3_h" >&6; } -else - # Is the header compilable? -{ echo "$as_me:$LINENO: checking sqlite3.h usability" >&5 -echo $ECHO_N "checking sqlite3.h usability... $ECHO_C" >&6; } -cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -$ac_includes_default -@%:@include <sqlite3.h> -_ACEOF -rm -f conftest.$ac_objext -if { (ac_try="$ac_compile" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_compile") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest.$ac_objext; then - ac_header_compiler=yes -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - ac_header_compiler=no -fi - -rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext -{ echo "$as_me:$LINENO: result: $ac_header_compiler" >&5 -echo "${ECHO_T}$ac_header_compiler" >&6; } - -# Is the header present? -{ echo "$as_me:$LINENO: checking sqlite3.h presence" >&5 -echo $ECHO_N "checking sqlite3.h presence... $ECHO_C" >&6; } -cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ -@%:@include <sqlite3.h> -_ACEOF -if { (ac_try="$ac_cpp conftest.$ac_ext" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_cpp conftest.$ac_ext") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } >/dev/null && { - test -z "$ac_c_preproc_warn_flag$ac_c_werror_flag" || - test ! -s conftest.err - }; then - ac_header_preproc=yes -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - ac_header_preproc=no -fi - -rm -f conftest.err conftest.$ac_ext -{ echo "$as_me:$LINENO: result: $ac_header_preproc" >&5 -echo "${ECHO_T}$ac_header_preproc" >&6; } - -# So? What about this header? -case $ac_header_compiler:$ac_header_preproc:$ac_c_preproc_warn_flag in - yes:no: ) - { echo "$as_me:$LINENO: WARNING: sqlite3.h: accepted by the compiler, rejected by the preprocessor!" >&5 -echo "$as_me: WARNING: sqlite3.h: accepted by the compiler, rejected by the preprocessor!" >&2;} - { echo "$as_me:$LINENO: WARNING: sqlite3.h: proceeding with the compiler's result" >&5 -echo "$as_me: WARNING: sqlite3.h: proceeding with the compiler's result" >&2;} - ac_header_preproc=yes - ;; - no:yes:* ) - { echo "$as_me:$LINENO: WARNING: sqlite3.h: present but cannot be compiled" >&5 -echo "$as_me: WARNING: sqlite3.h: present but cannot be compiled" >&2;} - { echo "$as_me:$LINENO: WARNING: sqlite3.h: check for missing prerequisite headers?" >&5 -echo "$as_me: WARNING: sqlite3.h: check for missing prerequisite headers?" >&2;} - { echo "$as_me:$LINENO: WARNING: sqlite3.h: see the Autoconf documentation" >&5 -echo "$as_me: WARNING: sqlite3.h: see the Autoconf documentation" >&2;} - { echo "$as_me:$LINENO: WARNING: sqlite3.h: section \"Present But Cannot Be Compiled\"" >&5 -echo "$as_me: WARNING: sqlite3.h: section \"Present But Cannot Be Compiled\"" >&2;} - { echo "$as_me:$LINENO: WARNING: sqlite3.h: proceeding with the preprocessor's result" >&5 -echo "$as_me: WARNING: sqlite3.h: proceeding with the preprocessor's result" >&2;} - { echo "$as_me:$LINENO: WARNING: sqlite3.h: in the future, the compiler will take precedence" >&5 -echo "$as_me: WARNING: sqlite3.h: in the future, the compiler will take precedence" >&2;} - ( cat <<\_ASBOX -@%:@@%:@ ------------------------------------- @%:@@%:@ -@%:@@%:@ Report this to [email protected] @%:@@%:@ -@%:@@%:@ ------------------------------------- @%:@@%:@ -_ASBOX - ) | sed "s/^/$as_me: WARNING: /" >&2 - ;; -esac -{ echo "$as_me:$LINENO: checking for sqlite3.h" >&5 -echo $ECHO_N "checking for sqlite3.h... $ECHO_C" >&6; } -if test "${ac_cv_header_sqlite3_h+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - ac_cv_header_sqlite3_h=$ac_header_preproc -fi -{ echo "$as_me:$LINENO: result: $ac_cv_header_sqlite3_h" >&5 -echo "${ECHO_T}$ac_cv_header_sqlite3_h" >&6; } - -fi -if test $ac_cv_header_sqlite3_h = yes; then - - { echo "$as_me:$LINENO: checking sqlite library version (via header)" >&5 -echo $ECHO_N "checking sqlite library version (via header)... $ECHO_C" >&6; } - cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - -#include "$sqlite_include" -#if SQLITE_VERSION_NUMBER >= $sqlite_min_ver_num -SQLITE_VERSION_OKAY -#endif -_ACEOF -if (eval "$ac_cpp conftest.$ac_ext") 2>&5 | - $EGREP "SQLITE_VERSION_OKAY" >/dev/null 2>&1; then - { echo "$as_me:$LINENO: result: okay" >&5 -echo "${ECHO_T}okay" >&6; } - { echo "$as_me:$LINENO: checking for sqlite3_close in -lsqlite3" >&5 -echo $ECHO_N "checking for sqlite3_close in -lsqlite3... $ECHO_C" >&6; } -if test "${ac_cv_lib_sqlite3_sqlite3_close+set}" = set; then - echo $ECHO_N "(cached) $ECHO_C" >&6 -else - ac_check_lib_save_LIBS=$LIBS -LIBS="-lsqlite3 $LIBS" -cat >conftest.$ac_ext <<_ACEOF -/* confdefs.h. */ -_ACEOF -cat confdefs.h >>conftest.$ac_ext -cat >>conftest.$ac_ext <<_ACEOF -/* end confdefs.h. */ - -/* Override any GCC internal prototype to avoid an error. - Use char because int might match the return type of a GCC - builtin and then its argument prototype would still apply. */ -#ifdef __cplusplus -extern "C" -#endif -char sqlite3_close (); -int -main () -{ -return sqlite3_close (); - ; - return 0; -} -_ACEOF -rm -f conftest.$ac_objext conftest$ac_exeext -if { (ac_try="$ac_link" -case "(($ac_try" in - *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;; - *) ac_try_echo=$ac_try;; -esac -eval "echo \"\$as_me:$LINENO: $ac_try_echo\"") >&5 - (eval "$ac_link") 2>conftest.er1 - ac_status=$? - grep -v '^ *+' conftest.er1 >conftest.err - rm -f conftest.er1 - cat conftest.err >&5 - echo "$as_me:$LINENO: \$? = $ac_status" >&5 - (exit $ac_status); } && { - test -z "$ac_c_werror_flag" || - test ! -s conftest.err - } && test -s conftest$ac_exeext && - $as_test_x conftest$ac_exeext; then - ac_cv_lib_sqlite3_sqlite3_close=yes -else - echo "$as_me: failed program was:" >&5 -sed 's/^/| /' conftest.$ac_ext >&5 - - ac_cv_lib_sqlite3_sqlite3_close=no -fi - -rm -f core conftest.err conftest.$ac_objext conftest_ipa8_conftest.oo \ - conftest$ac_exeext conftest.$ac_ext -LIBS=$ac_check_lib_save_LIBS -fi -{ echo "$as_me:$LINENO: result: $ac_cv_lib_sqlite3_sqlite3_close" >&5 -echo "${ECHO_T}$ac_cv_lib_sqlite3_sqlite3_close" >&6; } -if test $ac_cv_lib_sqlite3_sqlite3_close = yes; then - - triton_lib_sqlite="yes" - if test -z "$sqlite_dir" -o ! -d "$sqlite_dir"; then - TRITON_SQLITE_LIBS="-lsqlite3" - else - TRITON_SQLITE_INCLUDES="-I$sqlite_dir/include" - TRITON_SQLITE_LIBS="-L$sqlite_dir/lib -lsqlite3" - fi - -fi - -else - { echo "$as_me:$LINENO: result: unsupported SQLite version" >&5 -echo "${ECHO_T}unsupported SQLite version" >&6; } -fi -rm -f conftest* - - -fi - - - - CPPFLAGS="$save_CPPFLAGS" - LDFLAGS="$save_LDFLAGS" - - fi - - if test -z "$triton_lib_sqlite"; then - - if test -n "$PKG_CONFIG"; then - { echo "$as_me:$LINENO: checking sqlite library version (via pkg-config)" >&5 -echo $ECHO_N "checking sqlite library version (via pkg-config)... $ECHO_C" >&6; } - sqlite_version=`$PKG_CONFIG $SQLITE_PKGNAME --modversion --silence-errors` - - if test -n "$sqlite_version"; then - - sqlite_major=`expr $sqlite_version : '\([0-9]*\)'` - sqlite_minor=`expr $sqlite_version : '[0-9]*\.\([0-9]*\)'` - sqlite_micro=`expr $sqlite_version : '[0-9]*\.[0-9]*\.\([0-9]*\)'` - if test -z "$sqlite_micro"; then - sqlite_micro=0 - fi - sqlite_ver_num=`expr $sqlite_major \* 1000000 \ - \+ $sqlite_minor \* 1000 \ - \+ $sqlite_micro` - - - if test "$sqlite_ver_num" -ge "$sqlite_min_ver_num"; then - { echo "$as_me:$LINENO: result: $sqlite_version" >&5 -echo "${ECHO_T}$sqlite_version" >&6; } - triton_lib_sqlite="yes" - TRITON_SQLITE_INCLUDES="`$PKG_CONFIG $SQLITE_PKGNAME --cflags`" - TRITON_SQLITE_LIBS="`$PKG_CONFIG $SQLITE_PKGNAME --libs`" - else - { echo "$as_me:$LINENO: result: none or unsupported $sqlite_version" >&5 -echo "${ECHO_T}none or unsupported $sqlite_version" >&6; } - fi - fi - fi - - if test -z "$triton_lib_sqlite"; then - { echo "$as_me:$LINENO: result: no" >&5 -echo "${ECHO_T}no" >&6; } - fi - - fi - -# if test -z "$triton_lib_sqlite"; then -# TRITON_DOWNLOAD_SQLITE -# fi - if test -n "$triton_lib_sqlite"; then - BUILD_OSD=1 - fi - -fi - - - - - - - - -ac_config_files="$ac_config_files Makefile src/common/module.mk src/common/tests/module.mk src/common/resources/timer/test/module.mk src/common/resources/timer/module.mk src/common/resources/scheduling/module.mk src/common/resources/scheduling/test/module.mk src/net/module.mk src/net/mpi/module.mk src/net/mpi/test/module.mk src/remote/module.mk src/aesop/module.mk src/aesop/parser/module.mk src/aesop/examples/module.mk src/aesop/parser/tests/remote/module.mk src/aesop/parser/tests/blocking/module.mk" - -cat >confcache <<\_ACEOF -# This file is a shell script that caches the results of configure -# tests run on this system so they can be shared between configure -# scripts and configure runs, see configure's option --config-cache. -# It is not useful on other systems. If it contains results you don't -# want to keep, you may remove or edit it. -# -# config.status only pays attention to the cache file if you give it -# the --recheck option to rerun configure. -# -# `ac_cv_env_foo' variables (set or unset) will be overridden when -# loading this file, other *unset* `ac_cv_foo' will be assigned the -# following values. - -_ACEOF - -# The following way of writing the cache mishandles newlines in values, -# but we know of no workaround that is simple, portable, and efficient. -# So, we kill variables containing newlines. -# Ultrix sh set writes to stderr and can't be redirected directly, -# and sets the high bit in the cache file unless we assign to the vars. -( - for ac_var in `(set) 2>&1 | sed -n 's/^\([a-zA-Z_][a-zA-Z0-9_]*\)=.*/\1/p'`; do - eval ac_val=\$$ac_var - case $ac_val in #( - *${as_nl}*) - case $ac_var in #( - *_cv_*) { echo "$as_me:$LINENO: WARNING: Cache variable $ac_var contains a newline." >&5 -echo "$as_me: WARNING: Cache variable $ac_var contains a newline." >&2;} ;; - esac - case $ac_var in #( - _ | IFS | as_nl) ;; #( - *) $as_unset $ac_var ;; - esac ;; - esac - done - - (set) 2>&1 | - case $as_nl`(ac_space=' '; set) 2>&1` in #( - *${as_nl}ac_space=\ *) - # `set' does not quote correctly, so add quotes (double-quote - # substitution turns \\\\ into \\, and sed turns \\ into \). - sed -n \ - "s/'/'\\\\''/g; - s/^\\([_$as_cr_alnum]*_cv_[_$as_cr_alnum]*\\)=\\(.*\\)/\\1='\\2'/p" - ;; #( - *) - # `set' quotes correctly as required by POSIX, so do not add quotes. - sed -n "/^[_$as_cr_alnum]*_cv_[_$as_cr_alnum]*=/p" - ;; - esac | - sort -) | - sed ' - /^ac_cv_env_/b end - t clear - :clear - s/^\([^=]*\)=\(.*[{}].*\)$/test "${\1+set}" = set || &/ - t end - s/^\([^=]*\)=\(.*\)$/\1=${\1=\2}/ - :end' >>confcache -if diff "$cache_file" confcache >/dev/null 2>&1; then :; else - if test -w "$cache_file"; then - test "x$cache_file" != "x/dev/null" && - { echo "$as_me:$LINENO: updating cache $cache_file" >&5 -echo "$as_me: updating cache $cache_file" >&6;} - cat confcache >$cache_file - else - { echo "$as_me:$LINENO: not updating unwritable cache $cache_file" >&5 -echo "$as_me: not updating unwritable cache $cache_file" >&6;} - fi -fi -rm -f confcache - -test "x$prefix" = xNONE && prefix=$ac_default_prefix -# Let make expand exec_prefix. -test "x$exec_prefix" = xNONE && exec_prefix='${prefix}' - -DEFS=-DHAVE_CONFIG_H - -ac_libobjs= -ac_ltlibobjs= -for ac_i in : $LIB@&t@OBJS; do test "x$ac_i" = x: && continue - # 1. Remove the extension, and $U if already installed. - ac_script='s/\$U\././;s/\.o$//;s/\.obj$//' - ac_i=`echo "$ac_i" | sed "$ac_script"` - # 2. Prepend LIBOBJDIR. When used with automake>=1.10 LIBOBJDIR - # will be set to the directory where LIBOBJS objects are built. - ac_libobjs="$ac_libobjs \${LIBOBJDIR}$ac_i\$U.$ac_objext" - ac_ltlibobjs="$ac_ltlibobjs \${LIBOBJDIR}$ac_i"'$U.lo' -done -LIB@&t@OBJS=$ac_libobjs - -LTLIBOBJS=$ac_ltlibobjs - - - -: ${CONFIG_STATUS=./config.status} -ac_clean_files_save=$ac_clean_files -ac_clean_files="$ac_clean_files $CONFIG_STATUS" -{ echo "$as_me:$LINENO: creating $CONFIG_STATUS" >&5 -echo "$as_me: creating $CONFIG_STATUS" >&6;} -cat >$CONFIG_STATUS <<_ACEOF -#! $SHELL -# Generated by $as_me. -# Run this file to recreate the current configuration. -# Compiler output produced by configure, useful for debugging -# configure, is in config.log if it exists. - -debug=false -ac_cs_recheck=false -ac_cs_silent=false -SHELL=\${CONFIG_SHELL-$SHELL} -_ACEOF - -cat >>$CONFIG_STATUS <<\_ACEOF -## --------------------- ## -## M4sh Initialization. ## -## --------------------- ## - -# Be more Bourne compatible -DUALCASE=1; export DUALCASE # for MKS sh -if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then - emulate sh - NULLCMD=: - # Zsh 3.x and 4.x performs word splitting on ${1+"$@"}, which - # is contrary to our usage. Disable this feature. - alias -g '${1+"$@"}'='"$@"' - setopt NO_GLOB_SUBST -else - case `(set -o) 2>/dev/null` in - *posix*) set -o posix ;; -esac - -fi - - - - -# PATH needs CR -# Avoid depending upon Character Ranges. -as_cr_letters='abcdefghijklmnopqrstuvwxyz' -as_cr_LETTERS='ABCDEFGHIJKLMNOPQRSTUVWXYZ' -as_cr_Letters=$as_cr_letters$as_cr_LETTERS -as_cr_digits='0123456789' -as_cr_alnum=$as_cr_Letters$as_cr_digits - -# The user is always right. -if test "${PATH_SEPARATOR+set}" != set; then - echo "#! /bin/sh" >conf$$.sh - echo "exit 0" >>conf$$.sh - chmod +x conf$$.sh - if (PATH="/nonexistent;."; conf$$.sh) >/dev/null 2>&1; then - PATH_SEPARATOR=';' - else - PATH_SEPARATOR=: - fi - rm -f conf$$.sh -fi - -# Support unset when possible. -if ( (MAIL=60; unset MAIL) || exit) >/dev/null 2>&1; then - as_unset=unset -else - as_unset=false -fi - - -# IFS -# We need space, tab and new line, in precisely that order. Quoting is -# there to prevent editors from complaining about space-tab. -# (If _AS_PATH_WALK were called with IFS unset, it would disable word -# splitting by setting IFS to empty value.) -as_nl=' -' -IFS=" "" $as_nl" - -# Find who we are. Look in the path if we contain no directory separator. -case $0 in - *[\\/]* ) as_myself=$0 ;; - *) as_save_IFS=$IFS; IFS=$PATH_SEPARATOR -for as_dir in $PATH -do - IFS=$as_save_IFS - test -z "$as_dir" && as_dir=. - test -r "$as_dir/$0" && as_myself=$as_dir/$0 && break -done -IFS=$as_save_IFS - - ;; -esac -# We did not find ourselves, most probably we were run as `sh COMMAND' -# in which case we are not to be found in the path. -if test "x$as_myself" = x; then - as_myself=$0 -fi -if test ! -f "$as_myself"; then - echo "$as_myself: error: cannot find myself; rerun with an absolute file name" >&2 - { (exit 1); exit 1; } -fi - -# Work around bugs in pre-3.0 UWIN ksh. -for as_var in ENV MAIL MAILPATH -do ($as_unset $as_var) >/dev/null 2>&1 && $as_unset $as_var -done -PS1='$ ' -PS2='> ' -PS4='+ ' - -# NLS nuisances. -for as_var in \ - LANG LANGUAGE LC_ADDRESS LC_ALL LC_COLLATE LC_CTYPE LC_IDENTIFICATION \ - LC_MEASUREMENT LC_MESSAGES LC_MONETARY LC_NAME LC_NUMERIC LC_PAPER \ - LC_TELEPHONE LC_TIME -do - if (set +x; test -z "`(eval $as_var=C; export $as_var) 2>&1`"); then - eval $as_var=C; export $as_var - else - ($as_unset $as_var) >/dev/null 2>&1 && $as_unset $as_var - fi -done - -# Required to use basename. -if expr a : '\(a\)' >/dev/null 2>&1 && - test "X`expr 00001 : '.*\(...\)'`" = X001; then - as_expr=expr -else - as_expr=false -fi - -if (basename -- /) >/dev/null 2>&1 && test "X`basename -- / 2>&1`" = "X/"; then - as_basename=basename -else - as_basename=false -fi - - -# Name of the executable. -as_me=`$as_basename -- "$0" || -$as_expr X/"$0" : '.*/\([^/][^/]*\)/*$' \| \ - X"$0" : 'X\(//\)$' \| \ - X"$0" : 'X\(/\)' \| . 2>/dev/null || -echo X/"$0" | - sed '/^.*\/\([^/][^/]*\)\/*$/{ - s//\1/ - q - } - /^X\/\(\/\/\)$/{ - s//\1/ - q - } - /^X\/\(\/\).*/{ - s//\1/ - q - } - s/.*/./; q'` - -# CDPATH. -$as_unset CDPATH - - - - as_lineno_1=$LINENO - as_lineno_2=$LINENO - test "x$as_lineno_1" != "x$as_lineno_2" && - test "x`expr $as_lineno_1 + 1`" = "x$as_lineno_2" || { - - # Create $as_me.lineno as a copy of $as_myself, but with $LINENO - # uniformly replaced by the line number. The first 'sed' inserts a - # line-number line after each line using $LINENO; the second 'sed' - # does the real work. The second script uses 'N' to pair each - # line-number line with the line containing $LINENO, and appends - # trailing '-' during substitution so that $LINENO is not a special - # case at line end. - # (Raja R Harinath suggested sed '=', and Paul Eggert wrote the - # scripts with optimization help from Paolo Bonzini. Blame Lee - # E. McMahon (1931-1989) for sed's syntax. :-) - sed -n ' - p - /[$]LINENO/= - ' <$as_myself | - sed ' - s/[$]LINENO.*/&-/ - t lineno - b - :lineno - N - :loop - s/[$]LINENO\([^'$as_cr_alnum'_].*\n\)\(.*\)/\2\1\2/ - t loop - s/-\n.*// - ' >$as_me.lineno && - chmod +x "$as_me.lineno" || - { echo "$as_me: error: cannot create $as_me.lineno; rerun with a POSIX shell" >&2 - { (exit 1); exit 1; }; } - - # Don't try to exec as it changes $[0], causing all sort of problems - # (the dirname of $[0] is not the place where we might find the - # original and so on. Autoconf is especially sensitive to this). - . "./$as_me.lineno" - # Exit status is that of the last command. - exit -} - - -if (as_dir=`dirname -- /` && test "X$as_dir" = X/) >/dev/null 2>&1; then - as_dirname=dirname -else - as_dirname=false -fi - -ECHO_C= ECHO_N= ECHO_T= -case `echo -n x` in --n*) - case `echo 'x\c'` in - *c*) ECHO_T=' ';; # ECHO_T is single tab character. - *) ECHO_C='\c';; - esac;; -*) - ECHO_N='-n';; -esac - -if expr a : '\(a\)' >/dev/null 2>&1 && - test "X`expr 00001 : '.*\(...\)'`" = X001; then - as_expr=expr -else - as_expr=false -fi - -rm -f conf$$ conf$$.exe conf$$.file -if test -d conf$$.dir; then - rm -f conf$$.dir/conf$$.file -else - rm -f conf$$.dir - mkdir conf$$.dir -fi -echo >conf$$.file -if ln -s conf$$.file conf$$ 2>/dev/null; then - as_ln_s='ln -s' - # ... but there are two gotchas: - # 1) On MSYS, both `ln -s file dir' and `ln file dir' fail. - # 2) DJGPP < 2.04 has no symlinks; `ln -s' creates a wrapper executable. - # In both cases, we have to default to `cp -p'. - ln -s conf$$.file conf$$.dir 2>/dev/null && test ! -f conf$$.exe || - as_ln_s='cp -p' -elif ln conf$$.file conf$$ 2>/dev/null; then - as_ln_s=ln -else - as_ln_s='cp -p' -fi -rm -f conf$$ conf$$.exe conf$$.dir/conf$$.file conf$$.file -rmdir conf$$.dir 2>/dev/null - -if mkdir -p . 2>/dev/null; then - as_mkdir_p=: -else - test -d ./-p && rmdir ./-p - as_mkdir_p=false -fi - -if test -x / >/dev/null 2>&1; then - as_test_x='test -x' -else - if ls -dL / >/dev/null 2>&1; then - as_ls_L_option=L - else - as_ls_L_option= - fi - as_test_x=' - eval sh -c '\'' - if test -d "$1"; then - test -d "$1/."; - else - case $1 in - -*)set "./$1";; - esac; - case `ls -ld'$as_ls_L_option' "$1" 2>/dev/null` in - ???[sx]*):;;*)false;;esac;fi - '\'' sh - ' -fi -as_executable_p=$as_test_x - -# Sed expression to map a string onto a valid CPP name. -as_tr_cpp="eval sed 'y%*$as_cr_letters%P$as_cr_LETTERS%;s%[^_$as_cr_alnum]%_%g'" - -# Sed expression to map a string onto a valid variable name. -as_tr_sh="eval sed 'y%*+%pp%;s%[^_$as_cr_alnum]%_%g'" - - -exec 6>&1 - -# Save the log message, to keep $[0] and so on meaningful, and to -# report actual input values of CONFIG_FILES etc. instead of their -# values after options handling. -ac_log=" -This file was extended by triton $as_me 0.1.1, which was -generated by GNU Autoconf 2.61. Invocation command line was - - CONFIG_FILES = $CONFIG_FILES - CONFIG_HEADERS = $CONFIG_HEADERS - CONFIG_LINKS = $CONFIG_LINKS - CONFIG_COMMANDS = $CONFIG_COMMANDS - $ $0 $@ - -on `(hostname || uname -n) 2>/dev/null | sed 1q` -" - -_ACEOF - -cat >>$CONFIG_STATUS <<_ACEOF -# Files that config.status was made for. -config_files="$ac_config_files" -config_headers="$ac_config_headers" - -_ACEOF - -cat >>$CONFIG_STATUS <<\_ACEOF -ac_cs_usage="\ -\`$as_me' instantiates files from templates according to the -current configuration. - -Usage: $0 [OPTIONS] [FILE]... - - -h, --help print this help, then exit - -V, --version print version number and configuration settings, then exit - -q, --quiet do not print progress messages - -d, --debug don't remove temporary files - --recheck update $as_me by reconfiguring in the same conditions - --file=FILE[:TEMPLATE] - instantiate the configuration file FILE - --header=FILE[:TEMPLATE] - instantiate the configuration header FILE - -Configuration files: -$config_files - -Configuration headers: -$config_headers - -Report bugs to <[email protected]>." - -_ACEOF -cat >>$CONFIG_STATUS <<_ACEOF -ac_cs_version="\\ -triton config.status 0.1.1 -configured by $0, generated by GNU Autoconf 2.61, - with options \\"`echo "$ac_configure_args" | sed 's/^ //; s/[\\""\`\$]/\\\\&/g'`\\" - -Copyright (C) 2006 Free Software Foundation, Inc. -This config.status script is free software; the Free Software Foundation -gives unlimited permission to copy, distribute and modify it." - -ac_pwd='$ac_pwd' -srcdir='$srcdir' -INSTALL='$INSTALL' -_ACEOF - -cat >>$CONFIG_STATUS <<\_ACEOF -# If no file are specified by the user, then we need to provide default -# value. By we need to know if files were specified by the user. -ac_need_defaults=: -while test $# != 0 -do - case $1 in - --*=*) - ac_option=`expr "X$1" : 'X\([^=]*\)='` - ac_optarg=`expr "X$1" : 'X[^=]*=\(.*\)'` - ac_shift=: - ;; - *) - ac_option=$1 - ac_optarg=$2 - ac_shift=shift - ;; - esac - - case $ac_option in - # Handling of the options. - -recheck | --recheck | --rechec | --reche | --rech | --rec | --re | --r) - ac_cs_recheck=: ;; - --version | --versio | --versi | --vers | --ver | --ve | --v | -V ) - echo "$ac_cs_version"; exit ;; - --debug | --debu | --deb | --de | --d | -d ) - debug=: ;; - --file | --fil | --fi | --f ) - $ac_shift - CONFIG_FILES="$CONFIG_FILES $ac_optarg" - ac_need_defaults=false;; - --header | --heade | --head | --hea ) - $ac_shift - CONFIG_HEADERS="$CONFIG_HEADERS $ac_optarg" - ac_need_defaults=false;; - --he | --h) - # Conflict between --help and --header - { echo "$as_me: error: ambiguous option: $1 -Try \`$0 --help' for more information." >&2 - { (exit 1); exit 1; }; };; - --help | --hel | -h ) - echo "$ac_cs_usage"; exit ;; - -q | -quiet | --quiet | --quie | --qui | --qu | --q \ - | -silent | --silent | --silen | --sile | --sil | --si | --s) - ac_cs_silent=: ;; - - # This is an error. - -*) { echo "$as_me: error: unrecognized option: $1 -Try \`$0 --help' for more information." >&2 - { (exit 1); exit 1; }; } ;; - - *) ac_config_targets="$ac_config_targets $1" - ac_need_defaults=false ;; - - esac - shift -done - -ac_configure_extra_args= - -if $ac_cs_silent; then - exec 6>/dev/null - ac_configure_extra_args="$ac_configure_extra_args --silent" -fi - -_ACEOF -cat >>$CONFIG_STATUS <<_ACEOF -if \$ac_cs_recheck; then - echo "running CONFIG_SHELL=$SHELL $SHELL $0 "$ac_configure_args \$ac_configure_extra_args " --no-create --no-recursion" >&6 - CONFIG_SHELL=$SHELL - export CONFIG_SHELL - exec $SHELL "$0"$ac_configure_args \$ac_configure_extra_args --no-create --no-recursion -fi - -_ACEOF -cat >>$CONFIG_STATUS <<\_ACEOF -exec 5>>config.log -{ - echo - sed 'h;s/./-/g;s/^.../@%:@@%:@ /;s/...$/ @%:@@%:@/;p;x;p;x' <<_ASBOX -@%:@@%:@ Running $as_me. @%:@@%:@ -_ASBOX - echo "$ac_log" -} >&5 - -_ACEOF -cat >>$CONFIG_STATUS <<_ACEOF -_ACEOF - -cat >>$CONFIG_STATUS <<\_ACEOF - -# Handling of arguments. -for ac_config_target in $ac_config_targets -do - case $ac_config_target in - "triton-config.h") CONFIG_HEADERS="$CONFIG_HEADERS triton-config.h" ;; - "Makefile") CONFIG_FILES="$CONFIG_FILES Makefile" ;; - "src/common/module.mk") CONFIG_FILES="$CONFIG_FILES src/common/module.mk" ;; - "src/common/tests/module.mk") CONFIG_FILES="$CONFIG_FILES src/common/tests/module.mk" ;; - "src/common/resources/timer/test/module.mk") CONFIG_FILES="$CONFIG_FILES src/common/resources/timer/test/module.mk" ;; - "src/common/resources/timer/module.mk") CONFIG_FILES="$CONFIG_FILES src/common/resources/timer/module.mk" ;; - "src/common/resources/scheduling/module.mk") CONFIG_FILES="$CONFIG_FILES src/common/resources/scheduling/module.mk" ;; - "src/common/resources/scheduling/test/module.mk") CONFIG_FILES="$CONFIG_FILES src/common/resources/scheduling/test/module.mk" ;; - "src/net/module.mk") CONFIG_FILES="$CONFIG_FILES src/net/module.mk" ;; - "src/net/mpi/module.mk") CONFIG_FILES="$CONFIG_FILES src/net/mpi/module.mk" ;; - "src/net/mpi/test/module.mk") CONFIG_FILES="$CONFIG_FILES src/net/mpi/test/module.mk" ;; - "src/remote/module.mk") CONFIG_FILES="$CONFIG_FILES src/remote/module.mk" ;; - "src/aesop/module.mk") CONFIG_FILES="$CONFIG_FILES src/aesop/module.mk" ;; - "src/aesop/parser/module.mk") CONFIG_FILES="$CONFIG_FILES src/aesop/parser/module.mk" ;; - "src/aesop/examples/module.mk") CONFIG_FILES="$CONFIG_FILES src/aesop/examples/module.mk" ;; - "src/aesop/parser/tests/remote/module.mk") CONFIG_FILES="$CONFIG_FILES src/aesop/parser/tests/remote/module.mk" ;; - "src/aesop/parser/tests/blocking/module.mk") CONFIG_FILES="$CONFIG_FILES src/aesop/parser/tests/blocking/module.mk" ;; - - *) { { echo "$as_me:$LINENO: error: invalid argument: $ac_config_target" >&5 -echo "$as_me: error: invalid argument: $ac_config_target" >&2;} - { (exit 1); exit 1; }; };; - esac -done - - -# If the user did not use the arguments to specify the items to instantiate, -# then the envvar interface is used. Set only those that are not. -# We use the long form for the default assignment because of an extremely -# bizarre bug on SunOS 4.1.3. -if $ac_need_defaults; then - test "${CONFIG_FILES+set}" = set || CONFIG_FILES=$config_files - test "${CONFIG_HEADERS+set}" = set || CONFIG_HEADERS=$config_headers -fi - -# Have a temporary directory for convenience. Make it in the build tree -# simply because there is no reason against having it here, and in addition, -# creating and moving files from /tmp can sometimes cause problems. -# Hook for its removal unless debugging. -# Note that there is a small window in which the directory will not be cleaned: -# after its creation but before its name has been assigned to `$tmp'. -$debug || -{ - tmp= - trap 'exit_status=$? - { test -z "$tmp" || test ! -d "$tmp" || rm -fr "$tmp"; } && exit $exit_status -' 0 - trap '{ (exit 1); exit 1; }' 1 2 13 15 -} -# Create a (secure) tmp directory for tmp files. - -{ - tmp=`(umask 077 && mktemp -d "./confXXXXXX") 2>/dev/null` && - test -n "$tmp" && test -d "$tmp" -} || -{ - tmp=./conf$$-$RANDOM - (umask 077 && mkdir "$tmp") -} || -{ - echo "$me: cannot create a temporary directory in ." >&2 - { (exit 1); exit 1; } -} - -# -# Set up the sed scripts for CONFIG_FILES section. -# - -# No need to generate the scripts if there are no CONFIG_FILES. -# This happens for instance when ./config.status config.h -if test -n "$CONFIG_FILES"; then - -_ACEOF - - - -ac_delim='%!_!# ' -for ac_last_try in false false false false false :; do - cat >conf$$subs.sed <<_ACEOF -SHELL!$SHELL$ac_delim -PATH_SEPARATOR!$PATH_SEPARATOR$ac_delim -PACKAGE_NAME!$PACKAGE_NAME$ac_delim -PACKAGE_TARNAME!$PACKAGE_TARNAME$ac_delim -PACKAGE_VERSION!$PACKAGE_VERSION$ac_delim -PACKAGE_STRING!$PACKAGE_STRING$ac_delim -PACKAGE_BUGREPORT!$PACKAGE_BUGREPORT$ac_delim -exec_prefix!$exec_prefix$ac_delim -prefix!$prefix$ac_delim -program_transform_name!$program_transform_name$ac_delim -bindir!$bindir$ac_delim -sbindir!$sbindir$ac_delim -libexecdir!$libexecdir$ac_delim -datarootdir!$datarootdir$ac_delim -datadir!$datadir$ac_delim -sysconfdir!$sysconfdir$ac_delim -sharedstatedir!$sharedstatedir$ac_delim -localstatedir!$localstatedir$ac_delim -includedir!$includedir$ac_delim -oldincludedir!$oldincludedir$ac_delim -docdir!$docdir$ac_delim -infodir!$infodir$ac_delim -htmldir!$htmldir$ac_delim -dvidir!$dvidir$ac_delim -pdfdir!$pdfdir$ac_delim -psdir!$psdir$ac_delim -libdir!$libdir$ac_delim -localedir!$localedir$ac_delim -mandir!$mandir$ac_delim -DEFS!$DEFS$ac_delim -ECHO_C!$ECHO_C$ac_delim -ECHO_N!$ECHO_N$ac_delim -ECHO_T!$ECHO_T$ac_delim -LIBS!$LIBS$ac_delim -build_alias!$build_alias$ac_delim -host_alias!$host_alias$ac_delim -target_alias!$target_alias$ac_delim -TRITON_VERSION!$TRITON_VERSION$ac_delim -INSTALL_PROGRAM!$INSTALL_PROGRAM$ac_delim -INSTALL_SCRIPT!$INSTALL_SCRIPT$ac_delim -INSTALL_DATA!$INSTALL_DATA$ac_delim -CC!$CC$ac_delim -CFLAGS!$CFLAGS$ac_delim -LDFLAGS!$LDFLAGS$ac_delim -CPPFLAGS!$CPPFLAGS$ac_delim -ac_ct_CC!$ac_ct_CC$ac_delim -EXEEXT!$EXEEXT$ac_delim -OBJEXT!$OBJEXT$ac_delim -CPP!$CPP$ac_delim -GREP!$GREP$ac_delim -EGREP!$EGREP$ac_delim -GHC!$GHC$ac_delim -DB_CFLAGS!$DB_CFLAGS$ac_delim -DB_LIB!$DB_LIB$ac_delim -MPICC!$MPICC$ac_delim -MPICFLAGS!$MPICFLAGS$ac_delim -MPILDFLAGS!$MPILDFLAGS$ac_delim -MPILIBS!$MPILIBS$ac_delim -BUILD_MPI!$BUILD_MPI$ac_delim -BUILD_ABSOLUTE_TOP!$BUILD_ABSOLUTE_TOP$ac_delim -SRC_RELATIVE_TOP!$SRC_RELATIVE_TOP$ac_delim -SRC_ABSOLUTE_TOP!$SRC_ABSOLUTE_TOP$ac_delim -QUIET_COMPILE!$QUIET_COMPILE$ac_delim -STRICT_CFLAGS!$STRICT_CFLAGS$ac_delim -AE_DEBUG!$AE_DEBUG$ac_delim -ENABLE_COVERAGE!$ENABLE_COVERAGE$ac_delim -LIBCFLAGS!$LIBCFLAGS$ac_delim -THREAD_LIB!$THREAD_LIB$ac_delim -TRITON_SQLITE_INCLUDES!$TRITON_SQLITE_INCLUDES$ac_delim -TRITON_SQLITE_LIBS!$TRITON_SQLITE_LIBS$ac_delim -BUILD_OSD!$BUILD_OSD$ac_delim -LIB@&t@OBJS!$LIB@&t@OBJS$ac_delim -LTLIBOBJS!$LTLIBOBJS$ac_delim -_ACEOF - - if test `sed -n "s/.*$ac_delim\$/X/p" conf$$subs.sed | grep -c X` = 73; then - break - elif $ac_last_try; then - { { echo "$as_me:$LINENO: error: could not make $CONFIG_STATUS" >&5 -echo "$as_me: error: could not make $CONFIG_STATUS" >&2;} - { (exit 1); exit 1; }; } - else - ac_delim="$ac_delim!$ac_delim _$ac_delim!! " - fi -done - -ac_eof=`sed -n '/^CEOF[0-9]*$/s/CEOF/0/p' conf$$subs.sed` -if test -n "$ac_eof"; then - ac_eof=`echo "$ac_eof" | sort -nru | sed 1q` - ac_eof=`expr $ac_eof + 1` -fi - -cat >>$CONFIG_STATUS <<_ACEOF -cat >"\$tmp/subs-1.sed" <<\CEOF$ac_eof -/@[a-zA-Z_][a-zA-Z_0-9]*@/!b end -_ACEOF -sed ' -s/[,\\&]/\\&/g; s/@/@|#_!!_#|/g -s/^/s,@/; s/!/@,|#_!!_#|/ -:n -t n -s/'"$ac_delim"'$/,g/; t -s/$/\\/; p -N; s/^.*\n//; s/[,\\&]/\\&/g; s/@/@|#_!!_#|/g; b n -' >>$CONFIG_STATUS <conf$$subs.sed -rm -f conf$$subs.sed -cat >>$CONFIG_STATUS <<_ACEOF -:end -s/|#_!!_#|//g -CEOF$ac_eof -_ACEOF - - -# VPATH may cause trouble with some makes, so we remove $(srcdir), -# ${srcdir} and @srcdir@ from VPATH if srcdir is ".", strip leading and -# trailing colons and then remove the whole line if VPATH becomes empty -# (actually we leave an empty line to preserve line numbers). -if test "x$srcdir" = x.; then - ac_vpsub='/^[ ]*VPATH[ ]*=/{ -s/:*\$(srcdir):*/:/ -s/:*\${srcdir}:*/:/ -s/:*@srcdir@:*/:/ -s/^\([^=]*=[ ]*\):*/\1/ -s/:*$// -s/^[^=]*=[ ]*$// -}' -fi - -cat >>$CONFIG_STATUS <<\_ACEOF -fi # test -n "$CONFIG_FILES" - - -for ac_tag in :F $CONFIG_FILES :H $CONFIG_HEADERS -do - case $ac_tag in - :[FHLC]) ac_mode=$ac_tag; continue;; - esac - case $ac_mode$ac_tag in - :[FHL]*:*);; - :L* | :C*:*) { { echo "$as_me:$LINENO: error: Invalid tag $ac_tag." >&5 -echo "$as_me: error: Invalid tag $ac_tag." >&2;} - { (exit 1); exit 1; }; };; - :[FH]-) ac_tag=-:-;; - :[FH]*) ac_tag=$ac_tag:$ac_tag.in;; - esac - ac_save_IFS=$IFS - IFS=: - set x $ac_tag - IFS=$ac_save_IFS - shift - ac_file=$1 - shift - - case $ac_mode in - :L) ac_source=$1;; - :[FH]) - ac_file_inputs= - for ac_f - do - case $ac_f in - -) ac_f="$tmp/stdin";; - *) # Look for the file first in the build tree, then in the source tree - # (if the path is not absolute). The absolute path cannot be DOS-style, - # because $ac_f cannot contain `:'. - test -f "$ac_f" || - case $ac_f in - [\\/$]*) false;; - *) test -f "$srcdir/$ac_f" && ac_f="$srcdir/$ac_f";; - esac || - { { echo "$as_me:$LINENO: error: cannot find input file: $ac_f" >&5 -echo "$as_me: error: cannot find input file: $ac_f" >&2;} - { (exit 1); exit 1; }; };; - esac - ac_file_inputs="$ac_file_inputs $ac_f" - done - - # Let's still pretend it is `configure' which instantiates (i.e., don't - # use $as_me), people would be surprised to read: - # /* config.h. Generated by config.status. */ - configure_input="Generated from "`IFS=: - echo $* | sed 's|^[^:]*/||;s|:[^:]*/|, |g'`" by configure." - if test x"$ac_file" != x-; then - configure_input="$ac_file. $configure_input" - { echo "$as_me:$LINENO: creating $ac_file" >&5 -echo "$as_me: creating $ac_file" >&6;} - fi - - case $ac_tag in - *:-:* | *:-) cat >"$tmp/stdin";; - esac - ;; - esac - - ac_dir=`$as_dirname -- "$ac_file" || -$as_expr X"$ac_file" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \ - X"$ac_file" : 'X\(//\)[^/]' \| \ - X"$ac_file" : 'X\(//\)$' \| \ - X"$ac_file" : 'X\(/\)' \| . 2>/dev/null || -echo X"$ac_file" | - sed '/^X\(.*[^/]\)\/\/*[^/][^/]*\/*$/{ - s//\1/ - q - } - /^X\(\/\/\)[^/].*/{ - s//\1/ - q - } - /^X\(\/\/\)$/{ - s//\1/ - q - } - /^X\(\/\).*/{ - s//\1/ - q - } - s/.*/./; q'` - { as_dir="$ac_dir" - case $as_dir in #( - -*) as_dir=./$as_dir;; - esac - test -d "$as_dir" || { $as_mkdir_p && mkdir -p "$as_dir"; } || { - as_dirs= - while :; do - case $as_dir in #( - *\'*) as_qdir=`echo "$as_dir" | sed "s/'/'\\\\\\\\''/g"`;; #( - *) as_qdir=$as_dir;; - esac - as_dirs="'$as_qdir' $as_dirs" - as_dir=`$as_dirname -- "$as_dir" || -$as_expr X"$as_dir" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \ - X"$as_dir" : 'X\(//\)[^/]' \| \ - X"$as_dir" : 'X\(//\)$' \| \ - X"$as_dir" : 'X\(/\)' \| . 2>/dev/null || -echo X"$as_dir" | - sed '/^X\(.*[^/]\)\/\/*[^/][^/]*\/*$/{ - s//\1/ - q - } - /^X\(\/\/\)[^/].*/{ - s//\1/ - q - } - /^X\(\/\/\)$/{ - s//\1/ - q - } - /^X\(\/\).*/{ - s//\1/ - q - } - s/.*/./; q'` - test -d "$as_dir" && break - done - test -z "$as_dirs" || eval "mkdir $as_dirs" - } || test -d "$as_dir" || { { echo "$as_me:$LINENO: error: cannot create directory $as_dir" >&5 -echo "$as_me: error: cannot create directory $as_dir" >&2;} - { (exit 1); exit 1; }; }; } - ac_builddir=. - -case "$ac_dir" in -.) ac_dir_suffix= ac_top_builddir_sub=. ac_top_build_prefix= ;; -*) - ac_dir_suffix=/`echo "$ac_dir" | sed 's,^\.[\\/],,'` - # A ".." for each directory in $ac_dir_suffix. - ac_top_builddir_sub=`echo "$ac_dir_suffix" | sed 's,/[^\\/]*,/..,g;s,/,,'` - case $ac_top_builddir_sub in - "") ac_top_builddir_sub=. ac_top_build_prefix= ;; - *) ac_top_build_prefix=$ac_top_builddir_sub/ ;; - esac ;; -esac -ac_abs_top_builddir=$ac_pwd -ac_abs_builddir=$ac_pwd$ac_dir_suffix -# for backward compatibility: -ac_top_builddir=$ac_top_build_prefix - -case $srcdir in - .) # We are building in place. - ac_srcdir=. - ac_top_srcdir=$ac_top_builddir_sub - ac_abs_top_srcdir=$ac_pwd ;; - [\\/]* | ?:[\\/]* ) # Absolute name. - ac_srcdir=$srcdir$ac_dir_suffix; - ac_top_srcdir=$srcdir - ac_abs_top_srcdir=$srcdir ;; - *) # Relative name. - ac_srcdir=$ac_top_build_prefix$srcdir$ac_dir_suffix - ac_top_srcdir=$ac_top_build_prefix$srcdir - ac_abs_top_srcdir=$ac_pwd/$srcdir ;; -esac -ac_abs_srcdir=$ac_abs_top_srcdir$ac_dir_suffix - - - case $ac_mode in - :F) - # - # CONFIG_FILE - # - - case $INSTALL in - [\\/$]* | ?:[\\/]* ) ac_INSTALL=$INSTALL ;; - *) ac_INSTALL=$ac_top_build_prefix$INSTALL ;; - esac -_ACEOF - -cat >>$CONFIG_STATUS <<\_ACEOF -# If the template does not know about datarootdir, expand it. -# FIXME: This hack should be removed a few years after 2.60. -ac_datarootdir_hack=; ac_datarootdir_seen= - -case `sed -n '/datarootdir/ { - p - q -} -/@datadir@/p -/@docdir@/p -/@infodir@/p -/@localedir@/p -/@mandir@/p -' $ac_file_inputs` in -*datarootdir*) ac_datarootdir_seen=yes;; -*@datadir@*|*@docdir@*|*@infodir@*|*@localedir@*|*@mandir@*) - { echo "$as_me:$LINENO: WARNING: $ac_file_inputs seems to ignore the --datarootdir setting" >&5 -echo "$as_me: WARNING: $ac_file_inputs seems to ignore the --datarootdir setting" >&2;} -_ACEOF -cat >>$CONFIG_STATUS <<_ACEOF - ac_datarootdir_hack=' - s&@datadir@&$datadir&g - s&@docdir@&$docdir&g - s&@infodir@&$infodir&g - s&@localedir@&$localedir&g - s&@mandir@&$mandir&g - s&\\\${datarootdir}&$datarootdir&g' ;; -esac -_ACEOF - -# Neutralize VPATH when `$srcdir' = `.'. -# Shell code in configure.ac might set extrasub. -# FIXME: do we really want to maintain this feature? -cat >>$CONFIG_STATUS <<_ACEOF - sed "$ac_vpsub -$extrasub -_ACEOF -cat >>$CONFIG_STATUS <<\_ACEOF -:t -/@[a-zA-Z_][a-zA-Z_0-9]*@/!b -s&@configure_input@&$configure_input&;t t -s&@top_builddir@&$ac_top_builddir_sub&;t t -s&@srcdir@&$ac_srcdir&;t t -s&@abs_srcdir@&$ac_abs_srcdir&;t t -s&@top_srcdir@&$ac_top_srcdir&;t t -s&@abs_top_srcdir@&$ac_abs_top_srcdir&;t t -s&@builddir@&$ac_builddir&;t t -s&@abs_builddir@&$ac_abs_builddir&;t t -s&@abs_top_builddir@&$ac_abs_top_builddir&;t t -s&@INSTALL@&$ac_INSTALL&;t t -$ac_datarootdir_hack -" $ac_file_inputs | sed -f "$tmp/subs-1.sed" >$tmp/out - -test -z "$ac_datarootdir_hack$ac_datarootdir_seen" && - { ac_out=`sed -n '/\${datarootdir}/p' "$tmp/out"`; test -n "$ac_out"; } && - { ac_out=`sed -n '/^[ ]*datarootdir[ ]*:*=/p' "$tmp/out"`; test -z "$ac_out"; } && - { echo "$as_me:$LINENO: WARNING: $ac_file contains a reference to the variable \`datarootdir' -which seems to be undefined. Please make sure it is defined." >&5 -echo "$as_me: WARNING: $ac_file contains a reference to the variable \`datarootdir' -which seems to be undefined. Please make sure it is defined." >&2;} - - rm -f "$tmp/stdin" - case $ac_file in - -) cat "$tmp/out"; rm -f "$tmp/out";; - *) rm -f "$ac_file"; mv "$tmp/out" $ac_file;; - esac - ;; - :H) - # - # CONFIG_HEADER - # -_ACEOF - -# Transform confdefs.h into a sed script `conftest.defines', that -# substitutes the proper values into config.h.in to produce config.h. -rm -f conftest.defines conftest.tail -# First, append a space to every undef/define line, to ease matching. -echo 's/$/ /' >conftest.defines -# Then, protect against being on the right side of a sed subst, or in -# an unquoted here document, in config.status. If some macros were -# called several times there might be several #defines for the same -# symbol, which is useless. But do not sort them, since the last -# AC_DEFINE must be honored. -ac_word_re=[_$as_cr_Letters][_$as_cr_alnum]* -# These sed commands are passed to sed as "A NAME B PARAMS C VALUE D", where -# NAME is the cpp macro being defined, VALUE is the value it is being given. -# PARAMS is the parameter list in the macro definition--in most cases, it's -# just an empty string. -ac_dA='s,^\\([ #]*\\)[^ ]*\\([ ]*' -ac_dB='\\)[ (].*,\\1define\\2' -ac_dC=' ' -ac_dD=' ,' - -uniq confdefs.h | - sed -n ' - t rset - :rset - s/^[ ]*#[ ]*define[ ][ ]*// - t ok - d - :ok - s/[\\&,]/\\&/g - s/^\('"$ac_word_re"'\)\(([^()]*)\)[ ]*\(.*\)/ '"$ac_dA"'\1'"$ac_dB"'\2'"${ac_dC}"'\3'"$ac_dD"'/p - s/^\('"$ac_word_re"'\)[ ]*\(.*\)/'"$ac_dA"'\1'"$ac_dB$ac_dC"'\2'"$ac_dD"'/p - ' >>conftest.defines - -# Remove the space that was appended to ease matching. -# Then replace #undef with comments. This is necessary, for -# example, in the case of _POSIX_SOURCE, which is predefined and required -# on some systems where configure will not decide to define it. -# (The regexp can be short, since the line contains either #define or #undef.) -echo 's/ $// -s,^[ #]*u.*,/* & */,' >>conftest.defines - -# Break up conftest.defines: -ac_max_sed_lines=50 - -# First sed command is: sed -f defines.sed $ac_file_inputs >"$tmp/out1" -# Second one is: sed -f defines.sed "$tmp/out1" >"$tmp/out2" -# Third one will be: sed -f defines.sed "$tmp/out2" >"$tmp/out1" -# et cetera. -ac_in='$ac_file_inputs' -ac_out='"$tmp/out1"' -ac_nxt='"$tmp/out2"' - -while : -do - # Write a here document: - cat >>$CONFIG_STATUS <<_ACEOF - # First, check the format of the line: - cat >"\$tmp/defines.sed" <<\\CEOF -/^[ ]*#[ ]*undef[ ][ ]*$ac_word_re[ ]*\$/b def -/^[ ]*#[ ]*define[ ][ ]*$ac_word_re[( ]/b def -b -:def -_ACEOF - sed ${ac_max_sed_lines}q conftest.defines >>$CONFIG_STATUS - echo 'CEOF - sed -f "$tmp/defines.sed"' "$ac_in >$ac_out" >>$CONFIG_STATUS - ac_in=$ac_out; ac_out=$ac_nxt; ac_nxt=$ac_in - sed 1,${ac_max_sed_lines}d conftest.defines >conftest.tail - grep . conftest.tail >/dev/null || break - rm -f conftest.defines - mv conftest.tail conftest.defines -done -rm -f conftest.defines conftest.tail - -echo "ac_result=$ac_in" >>$CONFIG_STATUS -cat >>$CONFIG_STATUS <<\_ACEOF - if test x"$ac_file" != x-; then - echo "/* $configure_input */" >"$tmp/config.h" - cat "$ac_result" >>"$tmp/config.h" - if diff $ac_file "$tmp/config.h" >/dev/null 2>&1; then - { echo "$as_me:$LINENO: $ac_file is unchanged" >&5 -echo "$as_me: $ac_file is unchanged" >&6;} - else - rm -f $ac_file - mv "$tmp/config.h" $ac_file - fi - else - echo "/* $configure_input */" - cat "$ac_result" - fi - rm -f "$tmp/out12" - ;; - - - esac - -done # for ac_tag - - -{ (exit 0); exit 0; } -_ACEOF -chmod +x $CONFIG_STATUS -ac_clean_files=$ac_clean_files_save - - -# configure is writing to config.log, and then calls config.status. -# config.status does its own redirection, appending to config.log. -# Unfortunately, on DOS this fails, as config.log is still kept open -# by configure, so config.status won't be able to write to it; its -# output is simply discarded. So we exec the FD to /dev/null, -# effectively closing config.log, so it can be properly (re)opened and -# appended to by config.status. When coming back to configure, we -# need to make the FD available again. -if test "$no_create" != yes; then - ac_cs_success=: - ac_config_status_args= - test "$silent" = yes && - ac_config_status_args="$ac_config_status_args --quiet" - exec 5>/dev/null - $SHELL $CONFIG_STATUS $ac_config_status_args || ac_cs_success=false - exec 5>>config.log - # Use ||, not &&, to avoid exiting from the if with $? = 1, which - # would make configure fail if this is the last instruction. - $ac_cs_success || { (exit 1); exit 1; } -fi - diff --git a/code/autom4te.cache/requests b/code/autom4te.cache/requests deleted file mode 100644 index 2500fb6..0000000 --- a/code/autom4te.cache/requests +++ /dev/null @@ -1,95 +0,0 @@ -# This file was generated by Autom4te Sat Apr 28 03:44:04 GMT 2007. -# It contains the lists of macros which have been traced. -# It can be safely removed. - -@request = ( - bless( [ - '0', - 1, - [ - '/usr/share/autoconf' - ], - [ - '/usr/share/autoconf/autoconf/autoconf.m4f', - 'maint/config/bdb.m4', - 'maint/config/sqlite.m4', - 'configure.ac' - ], - { - '_AM_AUTOCONF_VERSION' => 1, - 'm4_pattern_allow' => 1, - 'm4_pattern_forbid' => 1, - 'include' => 1, - 'AC_DEFUN_ONCE' => 1, - 'AC_DEFUN' => 1, - 'AX_BERKELEY_DB' => 1, - 'TRITON_SQLITE_VERNUM_PARSE' => 1, - 'TRITON_LIB_SQLITE' => 1, - 'm4_include' => 1, - 'TRITON_SQLITE_PKG_CONFIG' => 1, - 'TRITON_SQLITE_DIR_CONFIG' => 1, - '_m4_warn' => 1, - 'AU_DEFUN' => 1, - 'TRITON_DOWNLOAD_SQLITE' => 1, - 'TRITON_SQLITE_MIN_VERNUM_PARSE' => 1 - } - ], 'Autom4te::Request' ), - bless( [ - '1', - 1, - [ - '/usr/share/autoconf' - ], - [ - '/usr/share/autoconf/autoconf/autoconf.m4f', - 'aclocal.m4', - 'configure.ac' - ], - { - '_LT_AC_TAGCONFIG' => 1, - 'AM_PROG_F77_C_O' => 1, - 'AC_INIT' => 1, - 'm4_pattern_forbid' => 1, - 'AC_CANONICAL_TARGET' => 1, - 'AC_SUBST' => 1, - 'AC_CONFIG_LIBOBJ_DIR' => 1, - 'AC_FC_SRCEXT' => 1, - 'AC_CANONICAL_HOST' => 1, - 'AC_PROG_LIBTOOL' => 1, - 'AM_INIT_AUTOMAKE' => 1, - 'AC_CONFIG_SUBDIRS' => 1, - 'AM_AUTOMAKE_VERSION' => 1, - 'LT_CONFIG_LTDL_DIR' => 1, - 'AC_REQUIRE_AUX_FILE' => 1, - 'AC_CONFIG_LINKS' => 1, - 'm4_sinclude' => 1, - 'LT_SUPPORTED_TAG' => 1, - 'AM_MAINTAINER_MODE' => 1, - 'AM_GNU_GETTEXT_INTL_SUBDIR' => 1, - '_m4_warn' => 1, - 'AM_PROG_CXX_C_O' => 1, - 'AM_ENABLE_MULTILIB' => 1, - 'AC_CONFIG_FILES' => 1, - 'include' => 1, - 'LT_INIT' => 1, - 'AM_GNU_GETTEXT' => 1, - 'AC_LIBSOURCE' => 1, - 'AM_PROG_FC_C_O' => 1, - 'AC_CANONICAL_BUILD' => 1, - 'AC_FC_FREEFORM' => 1, - 'AH_OUTPUT' => 1, - '_AM_SUBST_NOTMAKE' => 1, - 'AC_CONFIG_AUX_DIR' => 1, - 'sinclude' => 1, - 'AM_PROG_CC_C_O' => 1, - 'm4_pattern_allow' => 1, - 'AC_CANONICAL_SYSTEM' => 1, - 'AM_CONDITIONAL' => 1, - 'AC_CONFIG_HEADERS' => 1, - 'AC_DEFINE_TRACE_LITERAL' => 1, - 'm4_include' => 1, - 'AC_SUBST_TRACE' => 1 - } - ], 'Autom4te::Request' ) - ); - diff --git a/code/autom4te.cache/traces.0 b/code/autom4te.cache/traces.0 deleted file mode 100644 index 9b2bf29..0000000 --- a/code/autom4te.cache/traces.0 +++ /dev/null @@ -1,635 +0,0 @@ -m4trace:maint/config/bdb.m4:2: -1- AC_DEFUN([AX_BERKELEY_DB], [ - dbpath=ifelse([$1], ,,$1) - - DB_LDFLAGS= - dnl - dnl if the db is specified, try to link with -ldb - dnl otherwise try -ldb4, then -ldb3, then -ldb - dnl $lib set to notfound on link failure - dnl - AC_MSG_CHECKING([for db library]) - oldlibs=$LIBS - lib=notfound - - if test "x$dbpath" != "x" ; then - oldcflags=$CFLAGS - for dbheader in db4 db3 notfound; do - AC_COMPILE_IFELSE( - [#include "$dbpath/include/$dbheader/db.h"], - [DB_CFLAGS="-I$dbpath/include/$dbheader/" - break]) - done - - if test "x$dbheader" = "xnotfound"; then - AC_COMPILE_IFELSE( - [#include "$dbpath/include/db.h"], - [DB_CFLAGS="-I$dbpath/include/"], - [AC_MSG_FAILURE( - Invalid libdb path specified. No db.h found.)]) - fi - - DB_LDFLAGS="-L${dbpath}/lib" - LDFLAGS="$DB_LDFLAGS ${LDFLAGS}" - - LIBS="${oldlibs} -ldb -lpthread" - DB_LIB="-ldb" - CFLAGS="$DB_CFLAGS $oldcflags" - AC_TRY_LINK( - [#include <db.h>], - [DB *dbp; db_create(&dbp, NULL, 0);], - lib=db) - CFLAGS=$oldcflags - - else - for lib in db4 db3 db notfound; do - LIBS="${oldlibs} -l$lib -lpthread" - DB_LIB="-l$lib" - AC_TRY_LINK( - [#include <db.h>], - [DB *dbp; db_create(&dbp, NULL, 0);], - [break]) - done - fi - - dnl reset LIBS value and just report through DB_LIB - LIBS=$oldlibs - if test "x$lib" = "xnotfound" ; then - AC_MSG_ERROR(could not find DB libraries) - else - AC_MSG_RESULT($lib) - fi - AC_SUBST(DB_CFLAGS) - AC_SUBST(DB_LIB) - - dnl See if we have a new enough version of Berkeley DB; needed for - dnl compilation of trove-dbpf component - dnl AC_MSG_CHECKING(whether version of Berkeley DB is new enough) - dnl AC_TRY_COMPILE([ - dnl #include <db.h> - dnl ], [ - dnl #if DB_VERSION_MAJOR < 4 - dnl #error "DB_VERSION_MAJOR < 4; need newer Berkeley DB implementation" - dnl #endif - dnl ], AC_MSG_RESULT(yes), - dnl AC_MSG_RESULT(no) - dnl AC_MSG_ERROR(Need newer (4.x.x or later) version of Berkeley DB. - dnl try: http://www.sleepycat.com/download/index.shtml - dnl or: /parl/pcarns/rpms/db4-4.0.14-1mdk.src.rpm (to build rpm)) - dnl ) - - dnl Test to check for DB_ENV variable to error callback fn. Then - dnl test to see if third parameter must be const (related but not - dnl exactly the same). - AC_MSG_CHECKING(for dbenv parameter to DB error callback function) - oldcflags=$CFLAGS - CFLAGS="$USR_CFLAGS $DB_CFLAGS -Werror" - AC_TRY_COMPILE([ - #include <db.h> - - void error_callback_fn(const DB_ENV *dbenv, - const char *prefix, - const char *message) - { - return; - } - ], [ - DB *db; - - db->set_errcall(db, error_callback_fn); - ], AC_MSG_RESULT(yes) - AC_DEFINE(HAVE_DBENV_PARAMETER_TO_DB_ERROR_CALLBACK, 1, - Define if DB error callback function takes dbenv parameter) - have_dbenv_parameter_to_db_error_callback=yes, - AC_MSG_RESULT(no) - have_dbenv_parameter_to_db_error_callback=no) - - if test "x$have_dbenv_parameter_to_db_error_callback" = "xyes" ; then - dnl Test if compilation succeeds without const; we expect that it will - dnl not. - dnl NOTE: still using -Werror! - AC_MSG_CHECKING(if third parameter to error callback function is const) - AC_TRY_COMPILE([ - #include <db.h> - - void error_callback_fn(const DB_ENV *dbenv, - const char *prefix, - char *message) - { - return; - } - ], [ - DB *db; - - db->set_errcall(db, error_callback_fn); - ], AC_MSG_RESULT(no), - AC_MSG_RESULT(yes) - AC_DEFINE(HAVE_CONST_THIRD_PARAMETER_TO_DB_ERROR_CALLBACK, 1, - Define if third param (message) to DB error callback function is const)) - fi - - CFLAGS="$USR_CFLAGS $DB_CFLAGS -Werror" - dnl Test to check for unknown third param to DB stat (four params - dnl total). The unknown parameter is a function ptr so that the - dnl the user can pass in a replcaement for malloc. - dnl Note: this is a holdover from relatively old DB implementations, - dnl while the txnid parameter is new. So we don't test for the old - dnl unknown parameter if we found the new one. - AC_MSG_CHECKING(for DB stat with malloc function ptr) - AC_TRY_COMPILE([ - #include <db.h> - #include <stdlib.h> - ], [ - int ret = 0; - DB *db = db; - int dummy = 0; - u_int32_t flags = 0; - - ret = db->stat(db, &dummy, malloc, flags); - ], AC_MSG_RESULT(yes) - AC_DEFINE(HAVE_UNKNOWN_PARAMETER_TO_DB_STAT, 1, - Define if DB stat function takes malloc function ptr) - have_db_stat_malloc=yes, - AC_MSG_RESULT(no) - have_db_stat_malloc=no) - - dnl Test to check for txnid parameter to DB stat (DB 4.3.xx+) - if test "x$have_db_stat_malloc" = "xno" ; then - - AC_MSG_CHECKING(for txnid parameter to DB stat function) - AC_TRY_COMPILE([ - #include <db.h> - ], [ - int ret = 0; - DB *db = db; - DB_TXN *txnid = txnid; - u_int32_t flags = 0; - - ret = db->stat(db, txnid, NULL, flags); - ], AC_MSG_RESULT(yes) - AC_DEFINE(HAVE_TXNID_PARAMETER_TO_DB_STAT, 1, - Define if DB stat function takes txnid parameter) - have_txnid_param_to_stat=yes, - AC_MSG_RESULT(no) - have_txnid_param_to_stat=no) - - fi - - dnl Test to check for txnid parameter to DB open (DB4.1+) - AC_MSG_CHECKING(for txnid parameter to DB open function) - AC_TRY_COMPILE([ - #include <db.h> - ], [ - int ret = 0; - DB *db = NULL; - DB_TXN *txnid = NULL; - char *file = NULL; - char *database = NULL; - DBTYPE type = 0; - u_int32_t flags = 0; - int mode = 0; - - ret = db->open(db, txnid, file, database, type, flags, mode); - ], AC_MSG_RESULT(yes) - AC_DEFINE(HAVE_TXNID_PARAMETER_TO_DB_OPEN, 1, - Define if DB open function takes a txnid parameter), - AC_MSG_RESULT(no)) - - dnl check for DB_DIRTY_READ (it is not in db-3.2.9, for example) - AC_MSG_CHECKING(for DB_DIRTY_READ flag) - AC_TRY_COMPILE([ - #include <db.h> - ], [ - u_int32_t flags = DB_DIRTY_READ; - ], AC_MSG_RESULT(yes) - AC_DEFINE(HAVE_DB_DIRTY_READ, 1, [Define if db library has DB_DIRTY_READ flag]), - AC_MSG_RESULT(no)) - - dnl check for DB_BUFFER_SMALL (it is returned by dbp->get in db-4.4 and up) - AC_MSG_CHECKING(for DB_BUFFER_SMALL error) - AC_TRY_COMPILE([ - #include <db.h> - ], [ - int res = DB_BUFFER_SMALL; - res++; - ], AC_MSG_RESULT(yes) - AC_DEFINE(HAVE_DB_BUFFER_SMALL, 1, [Define if db library has DB_BUFFER_SMALL error]), - AC_MSG_RESULT(no)) - - dnl Test to check for db->get_pagesize - AC_MSG_CHECKING(for berkeley db get_pagesize function) - AC_TRY_COMPILE([ - #include <db.h> - ], [ - int ret = 0; - DB *db = NULL; - int pagesize; - - ret = db->get_pagesize(db, &pagesize); - ], AC_MSG_RESULT(yes) - AC_DEFINE(HAVE_DB_GET_PAGESIZE, 1, [Define if DB has get_pagesize function]), - AC_MSG_RESULT(no)) - - CFLAGS="$oldcflags" -]) -m4trace:maint/config/sqlite.m4:12: -1- AC_DEFUN([TRITON_LIB_SQLITE], [ - SQLITE_MINIMUM_VER="$1" - SQLITE_PKGNAME="sqlite3" - BUILD_OSD= - - TRITON_SQLITE_MIN_VERNUM_PARSE - - AC_MSG_NOTICE([checking sqlite library]) - - AC_ARG_WITH(sqlite, - AS_HELP_STRING([--with-sqlite=PREFIX], - [Use installed SQLite library or amalgamation file.]), - [ - if test "$withval" = "yes" ; then - AC_MSG_ERROR([--with-sqlite requires an argument.]) - else - sqlite_dir="$withval" - fi - - if test -d $sqlite_dir; then - dnl pointed at an sqlite installation - TRITON_SQLITE_DIR_CONFIG($sqlite_dir) - else - AC_MSG_ERROR([$sqlite_dir is not a directory.]) - fi - - # if a --with-sqlite argument was given, then we should complain if we - # can't find it there - if test -z "$triton_lib_sqlite"; then - AC_MSG_ERROR([no suitable sqlite found in $sqlite_dir]) - else - BUILD_OSD=1 - fi - ], - [ - if test -z "$triton_lib_sqlite"; then - dnl check the "standard" location of /usr - TRITON_SQLITE_DIR_CONFIG() - fi - - if test -z "$triton_lib_sqlite"; then - dnl no --with-sqlite switch, and no sqlite subdir, look in PATH - TRITON_SQLITE_PKG_CONFIG - fi - -# if test -z "$triton_lib_sqlite"; then -# TRITON_DOWNLOAD_SQLITE -# fi - if test -n "$triton_lib_sqlite"; then - BUILD_OSD=1 - fi - ]) - - AC_SUBST(TRITON_SQLITE_INCLUDES) - AC_SUBST(TRITON_SQLITE_LIBS) - AC_SUBST(BUILD_OSD) -]) -m4trace:maint/config/sqlite.m4:74: -1- AC_DEFUN([TRITON_SQLITE_PKG_CONFIG], [ - if test -n "$PKG_CONFIG"; then - AC_MSG_CHECKING([sqlite library version (via pkg-config)]) - sqlite_version=`$PKG_CONFIG $SQLITE_PKGNAME --modversion --silence-errors` - - if test -n "$sqlite_version"; then - TRITON_SQLITE_VERNUM_PARSE - - if test "$sqlite_ver_num" -ge "$sqlite_min_ver_num"; then - AC_MSG_RESULT([$sqlite_version]) - triton_lib_sqlite="yes" - TRITON_SQLITE_INCLUDES="`$PKG_CONFIG $SQLITE_PKGNAME --cflags`" - TRITON_SQLITE_LIBS="`$PKG_CONFIG $SQLITE_PKGNAME --libs`" - else - AC_MSG_RESULT([none or unsupported $sqlite_version]) - fi - fi - fi - - if test -z "$triton_lib_sqlite"; then - AC_MSG_RESULT(no) - fi -]) -m4trace:maint/config/sqlite.m4:103: -1- AC_DEFUN([TRITON_SQLITE_DIR_CONFIG], [ - if test -z "$1"; then - sqlite_dir="" - sqlite_include="sqlite3.h" - else - sqlite_dir="$1" - sqlite_include="$1/include/sqlite3.h" - fi - - save_CPPFLAGS="$CPPFLAGS" - save_LDFLAGS="$LDFLAGS" - - if test ! -z "$1"; then - CPPFLAGS="$CPPFLAGS -I$sqlite_dir/include" - LDFLAGS="$LDFLAGS -L$sqlite_dir/lib" - fi - - AC_CHECK_HEADER(sqlite3.h, - [ - AC_MSG_CHECKING([sqlite library version (via header)]) - AC_EGREP_CPP(SQLITE_VERSION_OKAY,[ -#include "$sqlite_include" -#if SQLITE_VERSION_NUMBER >= $sqlite_min_ver_num -SQLITE_VERSION_OKAY -#endif], - [AC_MSG_RESULT([okay]) - AC_CHECK_LIB(sqlite3, sqlite3_close, [ - triton_lib_sqlite="yes" - if test -z "$sqlite_dir" -o ! -d "$sqlite_dir"; then - TRITON_SQLITE_LIBS="-lsqlite3" - else - TRITON_SQLITE_INCLUDES="-I$sqlite_dir/include" - TRITON_SQLITE_LIBS="-L$sqlite_dir/lib -lsqlite3" - fi - ])], [AC_MSG_RESULT([unsupported SQLite version])]) - ]) - - CPPFLAGS="$save_CPPFLAGS" - LDFLAGS="$save_LDFLAGS" -]) -m4trace:maint/config/sqlite.m4:148: -1- AC_DEFUN([TRITON_SQLITE_VERNUM_PARSE], [ - sqlite_major=`expr $sqlite_version : '\([[0-9]]*\)'` - sqlite_minor=`expr $sqlite_version : '[[0-9]]*\.\([[0-9]]*\)'` - sqlite_micro=`expr $sqlite_version : '[[0-9]]*\.[[0-9]]*\.\([[0-9]]*\)'` - if test -z "$sqlite_micro"; then - sqlite_micro=0 - fi - sqlite_ver_num=`expr $sqlite_major \* 1000000 \ - \+ $sqlite_minor \* 1000 \ - \+ $sqlite_micro` -]) -m4trace:maint/config/sqlite.m4:165: -1- AC_DEFUN([TRITON_SQLITE_MIN_VERNUM_PARSE], [ - sqlite_min_major=`expr $SQLITE_MINIMUM_VER : '\([[0-9]]*\)'` - sqlite_min_minor=`expr $SQLITE_MINIMUM_VER : '[[0-9]]*\.\([[0-9]]*\)'` - sqlite_min_micro=`expr $SQLITE_MINIMUM_VER : '[[0-9]]*\.[[0-9]]*\.\([[0-9]]*\)'` - sqlite_min_ver_num=`expr $sqlite_min_major \* 1000000 \ - \+ $sqlite_min_minor \* 1000 \ - \+ $sqlite_min_micro` -]) -m4trace:maint/config/sqlite.m4:177: -1- AC_DEFUN([TRITON_DOWNLOAD_SQLITE], [ - echo "" - echo "An appropriate version of sqlite could not be found. We require" - echo "at least ${SQLITE_MINIMUM_VER}. Please install a newer sqlite " - echo "on this system." - echo "" - AC_MSG_ERROR([Grayskull requires SQLite]) -]) -m4trace:configure.ac:16: -1- m4_pattern_forbid([^_?A[CHUM]_]) -m4trace:configure.ac:16: -1- m4_pattern_forbid([_AC_]) -m4trace:configure.ac:16: -1- m4_pattern_forbid([^LIBOBJS$], [do not use LIBOBJS directly, use AC_LIBOBJ (see section `AC_LIBOBJ vs LIBOBJS']) -m4trace:configure.ac:16: -1- m4_pattern_allow([^AS_FLAGS$]) -m4trace:configure.ac:16: -1- m4_pattern_forbid([^_?m4_]) -m4trace:configure.ac:16: -1- m4_pattern_forbid([^dnl$]) -m4trace:configure.ac:16: -1- m4_pattern_forbid([^_?AS_]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^SHELL$]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^PATH_SEPARATOR$]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^PACKAGE_NAME$]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^PACKAGE_TARNAME$]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^PACKAGE_VERSION$]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^PACKAGE_STRING$]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^PACKAGE_BUGREPORT$]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^exec_prefix$]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^prefix$]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^program_transform_name$]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^bindir$]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^sbindir$]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^libexecdir$]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^datarootdir$]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^datadir$]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^sysconfdir$]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^sharedstatedir$]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^localstatedir$]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^includedir$]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^oldincludedir$]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^docdir$]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^infodir$]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^htmldir$]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^dvidir$]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^pdfdir$]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^psdir$]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^libdir$]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^localedir$]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^mandir$]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^PACKAGE_NAME$]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^PACKAGE_TARNAME$]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^PACKAGE_VERSION$]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^PACKAGE_STRING$]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^PACKAGE_BUGREPORT$]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^DEFS$]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^ECHO_C$]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^ECHO_N$]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^ECHO_T$]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^LIBS$]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^build_alias$]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^host_alias$]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^target_alias$]) -m4trace:configure.ac:18: -1- m4_pattern_allow([^TRITON_VERSION$]) -m4trace:configure.ac:20: -1- m4_pattern_allow([^TRITON_VERSION_MAJOR$]) -m4trace:configure.ac:21: -1- m4_pattern_allow([^TRITON_VERSION_MINOR$]) -m4trace:configure.ac:22: -1- m4_pattern_allow([^TRITON_VERSION_SUB$]) -m4trace:configure.ac:27: -1- m4_pattern_allow([^INSTALL_PROGRAM$]) -m4trace:configure.ac:27: -1- m4_pattern_allow([^INSTALL_SCRIPT$]) -m4trace:configure.ac:27: -1- m4_pattern_allow([^INSTALL_DATA$]) -m4trace:configure.ac:28: -1- m4_pattern_allow([^CC$]) -m4trace:configure.ac:28: -1- m4_pattern_allow([^CFLAGS$]) -m4trace:configure.ac:28: -1- m4_pattern_allow([^LDFLAGS$]) -m4trace:configure.ac:28: -1- m4_pattern_allow([^LIBS$]) -m4trace:configure.ac:28: -1- m4_pattern_allow([^CPPFLAGS$]) -m4trace:configure.ac:28: -1- m4_pattern_allow([^CC$]) -m4trace:configure.ac:28: -1- m4_pattern_allow([^CC$]) -m4trace:configure.ac:28: -1- m4_pattern_allow([^CC$]) -m4trace:configure.ac:28: -1- m4_pattern_allow([^CC$]) -m4trace:configure.ac:28: -1- m4_pattern_allow([^ac_ct_CC$]) -m4trace:configure.ac:28: -1- m4_pattern_allow([^EXEEXT$]) -m4trace:configure.ac:28: -1- m4_pattern_allow([^OBJEXT$]) -m4trace:configure.ac:29: -1- m4_pattern_allow([^CPP$]) -m4trace:configure.ac:29: -1- m4_pattern_allow([^CPPFLAGS$]) -m4trace:configure.ac:29: -1- m4_pattern_allow([^CPP$]) -m4trace:configure.ac:31: -1- m4_pattern_allow([^GREP$]) -m4trace:configure.ac:31: -1- m4_pattern_allow([^GREP$]) -m4trace:configure.ac:31: -1- m4_pattern_allow([^EGREP$]) -m4trace:configure.ac:31: -1- m4_pattern_allow([^EGREP$]) -m4trace:configure.ac:31: -1- m4_pattern_allow([^STDC_HEADERS$]) -m4trace:configure.ac:31: -1- m4_pattern_allow([^WORDS_BIGENDIAN$]) -m4trace:configure.ac:33: -1- m4_pattern_allow([^SIZEOF_LONG_INT$]) -m4trace:configure.ac:34: -1- m4_pattern_allow([^SIZEOF_VOID_P$]) -m4trace:configure.ac:42: -1- m4_pattern_allow([^GHC$]) -m4trace:configure.ac:42: -1- m4_pattern_allow([^GHC$]) -m4trace:configure.ac:46: -1- m4_pattern_allow([^GHC$]) -m4trace:configure.ac:52: -1- AX_BERKELEY_DB([${withval}]) -m4trace:configure.ac:52: -1- _m4_warn([obsolete], [The macro `AC_TRY_LINK' is obsolete. -You should run autoupdate.], [../../lib/autoconf/general.m4:2414: AC_TRY_LINK is expanded from... -maint/config/bdb.m4:2: AX_BERKELEY_DB is expanded from... -../../lib/m4sugar/m4sh.m4:516: AS_IF is expanded from... -../../lib/autoconf/general.m4:1382: AC_ARG_WITH is expanded from... -configure.ac:52: the top level]) -m4trace:configure.ac:52: -1- _m4_warn([obsolete], [The macro `AC_TRY_LINK' is obsolete. -You should run autoupdate.], [../../lib/autoconf/general.m4:2414: AC_TRY_LINK is expanded from... -maint/config/bdb.m4:2: AX_BERKELEY_DB is expanded from... -../../lib/m4sugar/m4sh.m4:516: AS_IF is expanded from... -../../lib/autoconf/general.m4:1382: AC_ARG_WITH is expanded from... -configure.ac:52: the top level]) -m4trace:configure.ac:52: -1- m4_pattern_allow([^DB_CFLAGS$]) -m4trace:configure.ac:52: -1- m4_pattern_allow([^DB_LIB$]) -m4trace:configure.ac:52: -2- m4_pattern_allow([^HAVE_DBENV_PARAMETER_TO_DB_ERROR_CALLBACK$]) -m4trace:configure.ac:52: -1- _m4_warn([obsolete], [The macro `AC_TRY_COMPILE' is obsolete. -You should run autoupdate.], [../../lib/autoconf/general.m4:2367: AC_TRY_COMPILE is expanded from... -maint/config/bdb.m4:2: AX_BERKELEY_DB is expanded from... -../../lib/m4sugar/m4sh.m4:516: AS_IF is expanded from... -../../lib/autoconf/general.m4:1382: AC_ARG_WITH is expanded from... -configure.ac:52: the top level]) -m4trace:configure.ac:52: -2- m4_pattern_allow([^HAVE_CONST_THIRD_PARAMETER_TO_DB_ERROR_CALLBACK$]) -m4trace:configure.ac:52: -1- _m4_warn([obsolete], [The macro `AC_TRY_COMPILE' is obsolete. -You should run autoupdate.], [../../lib/autoconf/general.m4:2367: AC_TRY_COMPILE is expanded from... -maint/config/bdb.m4:2: AX_BERKELEY_DB is expanded from... -../../lib/m4sugar/m4sh.m4:516: AS_IF is expanded from... -../../lib/autoconf/general.m4:1382: AC_ARG_WITH is expanded from... -configure.ac:52: the top level]) -m4trace:configure.ac:52: -2- m4_pattern_allow([^HAVE_UNKNOWN_PARAMETER_TO_DB_STAT$]) -m4trace:configure.ac:52: -1- _m4_warn([obsolete], [The macro `AC_TRY_COMPILE' is obsolete. -You should run autoupdate.], [../../lib/autoconf/general.m4:2367: AC_TRY_COMPILE is expanded from... -maint/config/bdb.m4:2: AX_BERKELEY_DB is expanded from... -../../lib/m4sugar/m4sh.m4:516: AS_IF is expanded from... -../../lib/autoconf/general.m4:1382: AC_ARG_WITH is expanded from... -configure.ac:52: the top level]) -m4trace:configure.ac:52: -2- m4_pattern_allow([^HAVE_TXNID_PARAMETER_TO_DB_STAT$]) -m4trace:configure.ac:52: -1- _m4_warn([obsolete], [The macro `AC_TRY_COMPILE' is obsolete. -You should run autoupdate.], [../../lib/autoconf/general.m4:2367: AC_TRY_COMPILE is expanded from... -maint/config/bdb.m4:2: AX_BERKELEY_DB is expanded from... -../../lib/m4sugar/m4sh.m4:516: AS_IF is expanded from... -../../lib/autoconf/general.m4:1382: AC_ARG_WITH is expanded from... -configure.ac:52: the top level]) -m4trace:configure.ac:52: -2- m4_pattern_allow([^HAVE_TXNID_PARAMETER_TO_DB_OPEN$]) -m4trace:configure.ac:52: -1- _m4_warn([obsolete], [The macro `AC_TRY_COMPILE' is obsolete. -You should run autoupdate.], [../../lib/autoconf/general.m4:2367: AC_TRY_COMPILE is expanded from... -maint/config/bdb.m4:2: AX_BERKELEY_DB is expanded from... -../../lib/m4sugar/m4sh.m4:516: AS_IF is expanded from... -../../lib/autoconf/general.m4:1382: AC_ARG_WITH is expanded from... -configure.ac:52: the top level]) -m4trace:configure.ac:52: -2- m4_pattern_allow([^HAVE_DB_DIRTY_READ$]) -m4trace:configure.ac:52: -1- _m4_warn([obsolete], [The macro `AC_TRY_COMPILE' is obsolete. -You should run autoupdate.], [../../lib/autoconf/general.m4:2367: AC_TRY_COMPILE is expanded from... -maint/config/bdb.m4:2: AX_BERKELEY_DB is expanded from... -../../lib/m4sugar/m4sh.m4:516: AS_IF is expanded from... -../../lib/autoconf/general.m4:1382: AC_ARG_WITH is expanded from... -configure.ac:52: the top level]) -m4trace:configure.ac:52: -2- m4_pattern_allow([^HAVE_DB_BUFFER_SMALL$]) -m4trace:configure.ac:52: -1- _m4_warn([obsolete], [The macro `AC_TRY_COMPILE' is obsolete. -You should run autoupdate.], [../../lib/autoconf/general.m4:2367: AC_TRY_COMPILE is expanded from... -maint/config/bdb.m4:2: AX_BERKELEY_DB is expanded from... -../../lib/m4sugar/m4sh.m4:516: AS_IF is expanded from... -../../lib/autoconf/general.m4:1382: AC_ARG_WITH is expanded from... -configure.ac:52: the top level]) -m4trace:configure.ac:52: -2- m4_pattern_allow([^HAVE_DB_GET_PAGESIZE$]) -m4trace:configure.ac:52: -1- _m4_warn([obsolete], [The macro `AC_TRY_COMPILE' is obsolete. -You should run autoupdate.], [../../lib/autoconf/general.m4:2367: AC_TRY_COMPILE is expanded from... -maint/config/bdb.m4:2: AX_BERKELEY_DB is expanded from... -../../lib/m4sugar/m4sh.m4:516: AS_IF is expanded from... -../../lib/autoconf/general.m4:1382: AC_ARG_WITH is expanded from... -configure.ac:52: the top level]) -m4trace:configure.ac:52: -1- AX_BERKELEY_DB([""]) -m4trace:configure.ac:52: -1- _m4_warn([obsolete], [The macro `AC_TRY_LINK' is obsolete. -You should run autoupdate.], [../../lib/autoconf/general.m4:2414: AC_TRY_LINK is expanded from... -maint/config/bdb.m4:2: AX_BERKELEY_DB is expanded from... -../../lib/m4sugar/m4sh.m4:516: AS_IF is expanded from... -../../lib/autoconf/general.m4:1382: AC_ARG_WITH is expanded from... -configure.ac:52: the top level]) -m4trace:configure.ac:52: -1- _m4_warn([obsolete], [The macro `AC_TRY_LINK' is obsolete. -You should run autoupdate.], [../../lib/autoconf/general.m4:2414: AC_TRY_LINK is expanded from... -maint/config/bdb.m4:2: AX_BERKELEY_DB is expanded from... -../../lib/m4sugar/m4sh.m4:516: AS_IF is expanded from... -../../lib/autoconf/general.m4:1382: AC_ARG_WITH is expanded from... -configure.ac:52: the top level]) -m4trace:configure.ac:52: -1- m4_pattern_allow([^DB_CFLAGS$]) -m4trace:configure.ac:52: -1- m4_pattern_allow([^DB_LIB$]) -m4trace:configure.ac:52: -2- m4_pattern_allow([^HAVE_DBENV_PARAMETER_TO_DB_ERROR_CALLBACK$]) -m4trace:configure.ac:52: -1- _m4_warn([obsolete], [The macro `AC_TRY_COMPILE' is obsolete. -You should run autoupdate.], [../../lib/autoconf/general.m4:2367: AC_TRY_COMPILE is expanded from... -maint/config/bdb.m4:2: AX_BERKELEY_DB is expanded from... -../../lib/m4sugar/m4sh.m4:516: AS_IF is expanded from... -../../lib/autoconf/general.m4:1382: AC_ARG_WITH is expanded from... -configure.ac:52: the top level]) -m4trace:configure.ac:52: -2- m4_pattern_allow([^HAVE_CONST_THIRD_PARAMETER_TO_DB_ERROR_CALLBACK$]) -m4trace:configure.ac:52: -1- _m4_warn([obsolete], [The macro `AC_TRY_COMPILE' is obsolete. -You should run autoupdate.], [../../lib/autoconf/general.m4:2367: AC_TRY_COMPILE is expanded from... -maint/config/bdb.m4:2: AX_BERKELEY_DB is expanded from... -../../lib/m4sugar/m4sh.m4:516: AS_IF is expanded from... -../../lib/autoconf/general.m4:1382: AC_ARG_WITH is expanded from... -configure.ac:52: the top level]) -m4trace:configure.ac:52: -2- m4_pattern_allow([^HAVE_UNKNOWN_PARAMETER_TO_DB_STAT$]) -m4trace:configure.ac:52: -1- _m4_warn([obsolete], [The macro `AC_TRY_COMPILE' is obsolete. -You should run autoupdate.], [../../lib/autoconf/general.m4:2367: AC_TRY_COMPILE is expanded from... -maint/config/bdb.m4:2: AX_BERKELEY_DB is expanded from... -../../lib/m4sugar/m4sh.m4:516: AS_IF is expanded from... -../../lib/autoconf/general.m4:1382: AC_ARG_WITH is expanded from... -configure.ac:52: the top level]) -m4trace:configure.ac:52: -2- m4_pattern_allow([^HAVE_TXNID_PARAMETER_TO_DB_STAT$]) -m4trace:configure.ac:52: -1- _m4_warn([obsolete], [The macro `AC_TRY_COMPILE' is obsolete. -You should run autoupdate.], [../../lib/autoconf/general.m4:2367: AC_TRY_COMPILE is expanded from... -maint/config/bdb.m4:2: AX_BERKELEY_DB is expanded from... -../../lib/m4sugar/m4sh.m4:516: AS_IF is expanded from... -../../lib/autoconf/general.m4:1382: AC_ARG_WITH is expanded from... -configure.ac:52: the top level]) -m4trace:configure.ac:52: -2- m4_pattern_allow([^HAVE_TXNID_PARAMETER_TO_DB_OPEN$]) -m4trace:configure.ac:52: -1- _m4_warn([obsolete], [The macro `AC_TRY_COMPILE' is obsolete. -You should run autoupdate.], [../../lib/autoconf/general.m4:2367: AC_TRY_COMPILE is expanded from... -maint/config/bdb.m4:2: AX_BERKELEY_DB is expanded from... -../../lib/m4sugar/m4sh.m4:516: AS_IF is expanded from... -../../lib/autoconf/general.m4:1382: AC_ARG_WITH is expanded from... -configure.ac:52: the top level]) -m4trace:configure.ac:52: -2- m4_pattern_allow([^HAVE_DB_DIRTY_READ$]) -m4trace:configure.ac:52: -1- _m4_warn([obsolete], [The macro `AC_TRY_COMPILE' is obsolete. -You should run autoupdate.], [../../lib/autoconf/general.m4:2367: AC_TRY_COMPILE is expanded from... -maint/config/bdb.m4:2: AX_BERKELEY_DB is expanded from... -../../lib/m4sugar/m4sh.m4:516: AS_IF is expanded from... -../../lib/autoconf/general.m4:1382: AC_ARG_WITH is expanded from... -configure.ac:52: the top level]) -m4trace:configure.ac:52: -2- m4_pattern_allow([^HAVE_DB_BUFFER_SMALL$]) -m4trace:configure.ac:52: -1- _m4_warn([obsolete], [The macro `AC_TRY_COMPILE' is obsolete. -You should run autoupdate.], [../../lib/autoconf/general.m4:2367: AC_TRY_COMPILE is expanded from... -maint/config/bdb.m4:2: AX_BERKELEY_DB is expanded from... -../../lib/m4sugar/m4sh.m4:516: AS_IF is expanded from... -../../lib/autoconf/general.m4:1382: AC_ARG_WITH is expanded from... -configure.ac:52: the top level]) -m4trace:configure.ac:52: -2- m4_pattern_allow([^HAVE_DB_GET_PAGESIZE$]) -m4trace:configure.ac:52: -1- _m4_warn([obsolete], [The macro `AC_TRY_COMPILE' is obsolete. -You should run autoupdate.], [../../lib/autoconf/general.m4:2367: AC_TRY_COMPILE is expanded from... -maint/config/bdb.m4:2: AX_BERKELEY_DB is expanded from... -../../lib/m4sugar/m4sh.m4:516: AS_IF is expanded from... -../../lib/autoconf/general.m4:1382: AC_ARG_WITH is expanded from... -configure.ac:52: the top level]) -m4trace:configure.ac:70: -1- m4_pattern_allow([^MPICC$]) -m4trace:configure.ac:71: -1- m4_pattern_allow([^MPICFLAGS$]) -m4trace:configure.ac:72: -1- m4_pattern_allow([^MPILDFLAGS$]) -m4trace:configure.ac:73: -1- m4_pattern_allow([^MPILIBS$]) -m4trace:configure.ac:74: -1- m4_pattern_allow([^BUILD_MPI$]) -m4trace:configure.ac:80: -1- m4_pattern_allow([^BUILD_ABSOLUTE_TOP$]) -m4trace:configure.ac:81: -1- m4_pattern_allow([^SRC_RELATIVE_TOP$]) -m4trace:configure.ac:82: -1- m4_pattern_allow([^SRC_ABSOLUTE_TOP$]) -m4trace:configure.ac:84: -1- m4_pattern_allow([^CFLAGS$]) -m4trace:configure.ac:85: -1- m4_pattern_allow([^LDFLAGS$]) -m4trace:configure.ac:86: -1- m4_pattern_allow([^LIBS$]) -m4trace:configure.ac:87: -1- m4_pattern_allow([^CPPFLAGS$]) -m4trace:configure.ac:93: -1- m4_pattern_allow([^QUIET_COMPILE$]) -m4trace:configure.ac:99: -1- m4_pattern_allow([^STRICT_CFLAGS$]) -m4trace:configure.ac:105: -1- m4_pattern_allow([^AE_DEBUG$]) -m4trace:configure.ac:112: -1- m4_pattern_allow([^ENABLE_COVERAGE$]) -m4trace:configure.ac:127: -1- m4_pattern_allow([^LIBCFLAGS$]) -m4trace:configure.ac:128: -1- m4_pattern_allow([^THREAD_LIB$]) -m4trace:configure.ac:130: -1- TRITON_LIB_SQLITE([3.0.0]) -m4trace:configure.ac:130: -1- TRITON_SQLITE_MIN_VERNUM_PARSE -m4trace:configure.ac:130: -1- TRITON_SQLITE_DIR_CONFIG([$sqlite_dir]) -m4trace:configure.ac:130: -1- TRITON_SQLITE_DIR_CONFIG([]) -m4trace:configure.ac:130: -1- TRITON_SQLITE_PKG_CONFIG -m4trace:configure.ac:130: -1- TRITON_SQLITE_VERNUM_PARSE -m4trace:configure.ac:130: -1- m4_pattern_allow([^TRITON_SQLITE_INCLUDES$]) -m4trace:configure.ac:130: -1- m4_pattern_allow([^TRITON_SQLITE_LIBS$]) -m4trace:configure.ac:130: -1- m4_pattern_allow([^BUILD_OSD$]) -m4trace:configure.ac:138: -1- _m4_warn([obsolete], [AC_OUTPUT should be used without arguments. -You should run autoupdate.], []) -m4trace:configure.ac:138: -1- m4_pattern_allow([^LIB@&t@OBJS$]) -m4trace:configure.ac:138: -1- m4_pattern_allow([^LTLIBOBJS$]) diff --git a/code/autom4te.cache/traces.1 b/code/autom4te.cache/traces.1 deleted file mode 100644 index 812502e..0000000 --- a/code/autom4te.cache/traces.1 +++ /dev/null @@ -1,563 +0,0 @@ -m4trace:aclocal.m4:14: -1- m4_include([maint/config/bdb.m4]) -m4trace:aclocal.m4:15: -1- m4_include([maint/config/sqlite.m4]) -m4trace:configure.ac:16: -1- AC_INIT([triton], [0.1.1], [[email protected]]) -m4trace:configure.ac:16: -1- m4_pattern_forbid([^_?A[CHUM]_]) -m4trace:configure.ac:16: -1- m4_pattern_forbid([_AC_]) -m4trace:configure.ac:16: -1- m4_pattern_forbid([^LIBOBJS$], [do not use LIBOBJS directly, use AC_LIBOBJ (see section `AC_LIBOBJ vs LIBOBJS']) -m4trace:configure.ac:16: -1- m4_pattern_allow([^AS_FLAGS$]) -m4trace:configure.ac:16: -1- m4_pattern_forbid([^_?m4_]) -m4trace:configure.ac:16: -1- m4_pattern_forbid([^dnl$]) -m4trace:configure.ac:16: -1- m4_pattern_forbid([^_?AS_]) -m4trace:configure.ac:16: -1- AC_SUBST([SHELL], [${CONFIG_SHELL-/bin/sh}]) -m4trace:configure.ac:16: -1- AC_SUBST_TRACE([SHELL]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^SHELL$]) -m4trace:configure.ac:16: -1- AC_SUBST([PATH_SEPARATOR]) -m4trace:configure.ac:16: -1- AC_SUBST_TRACE([PATH_SEPARATOR]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^PATH_SEPARATOR$]) -m4trace:configure.ac:16: -1- AC_SUBST([PACKAGE_NAME], [m4_ifdef([AC_PACKAGE_NAME], ['AC_PACKAGE_NAME'])]) -m4trace:configure.ac:16: -1- AC_SUBST_TRACE([PACKAGE_NAME]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^PACKAGE_NAME$]) -m4trace:configure.ac:16: -1- AC_SUBST([PACKAGE_TARNAME], [m4_ifdef([AC_PACKAGE_TARNAME], ['AC_PACKAGE_TARNAME'])]) -m4trace:configure.ac:16: -1- AC_SUBST_TRACE([PACKAGE_TARNAME]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^PACKAGE_TARNAME$]) -m4trace:configure.ac:16: -1- AC_SUBST([PACKAGE_VERSION], [m4_ifdef([AC_PACKAGE_VERSION], ['AC_PACKAGE_VERSION'])]) -m4trace:configure.ac:16: -1- AC_SUBST_TRACE([PACKAGE_VERSION]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^PACKAGE_VERSION$]) -m4trace:configure.ac:16: -1- AC_SUBST([PACKAGE_STRING], [m4_ifdef([AC_PACKAGE_STRING], ['AC_PACKAGE_STRING'])]) -m4trace:configure.ac:16: -1- AC_SUBST_TRACE([PACKAGE_STRING]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^PACKAGE_STRING$]) -m4trace:configure.ac:16: -1- AC_SUBST([PACKAGE_BUGREPORT], [m4_ifdef([AC_PACKAGE_BUGREPORT], ['AC_PACKAGE_BUGREPORT'])]) -m4trace:configure.ac:16: -1- AC_SUBST_TRACE([PACKAGE_BUGREPORT]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^PACKAGE_BUGREPORT$]) -m4trace:configure.ac:16: -1- AC_SUBST([exec_prefix], [NONE]) -m4trace:configure.ac:16: -1- AC_SUBST_TRACE([exec_prefix]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^exec_prefix$]) -m4trace:configure.ac:16: -1- AC_SUBST([prefix], [NONE]) -m4trace:configure.ac:16: -1- AC_SUBST_TRACE([prefix]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^prefix$]) -m4trace:configure.ac:16: -1- AC_SUBST([program_transform_name], [s,x,x,]) -m4trace:configure.ac:16: -1- AC_SUBST_TRACE([program_transform_name]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^program_transform_name$]) -m4trace:configure.ac:16: -1- AC_SUBST([bindir], ['${exec_prefix}/bin']) -m4trace:configure.ac:16: -1- AC_SUBST_TRACE([bindir]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^bindir$]) -m4trace:configure.ac:16: -1- AC_SUBST([sbindir], ['${exec_prefix}/sbin']) -m4trace:configure.ac:16: -1- AC_SUBST_TRACE([sbindir]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^sbindir$]) -m4trace:configure.ac:16: -1- AC_SUBST([libexecdir], ['${exec_prefix}/libexec']) -m4trace:configure.ac:16: -1- AC_SUBST_TRACE([libexecdir]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^libexecdir$]) -m4trace:configure.ac:16: -1- AC_SUBST([datarootdir], ['${prefix}/share']) -m4trace:configure.ac:16: -1- AC_SUBST_TRACE([datarootdir]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^datarootdir$]) -m4trace:configure.ac:16: -1- AC_SUBST([datadir], ['${datarootdir}']) -m4trace:configure.ac:16: -1- AC_SUBST_TRACE([datadir]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^datadir$]) -m4trace:configure.ac:16: -1- AC_SUBST([sysconfdir], ['${prefix}/etc']) -m4trace:configure.ac:16: -1- AC_SUBST_TRACE([sysconfdir]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^sysconfdir$]) -m4trace:configure.ac:16: -1- AC_SUBST([sharedstatedir], ['${prefix}/com']) -m4trace:configure.ac:16: -1- AC_SUBST_TRACE([sharedstatedir]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^sharedstatedir$]) -m4trace:configure.ac:16: -1- AC_SUBST([localstatedir], ['${prefix}/var']) -m4trace:configure.ac:16: -1- AC_SUBST_TRACE([localstatedir]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^localstatedir$]) -m4trace:configure.ac:16: -1- AC_SUBST([includedir], ['${prefix}/include']) -m4trace:configure.ac:16: -1- AC_SUBST_TRACE([includedir]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^includedir$]) -m4trace:configure.ac:16: -1- AC_SUBST([oldincludedir], ['/usr/include']) -m4trace:configure.ac:16: -1- AC_SUBST_TRACE([oldincludedir]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^oldincludedir$]) -m4trace:configure.ac:16: -1- AC_SUBST([docdir], [m4_ifset([AC_PACKAGE_TARNAME], - ['${datarootdir}/doc/${PACKAGE_TARNAME}'], - ['${datarootdir}/doc/${PACKAGE}'])]) -m4trace:configure.ac:16: -1- AC_SUBST_TRACE([docdir]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^docdir$]) -m4trace:configure.ac:16: -1- AC_SUBST([infodir], ['${datarootdir}/info']) -m4trace:configure.ac:16: -1- AC_SUBST_TRACE([infodir]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^infodir$]) -m4trace:configure.ac:16: -1- AC_SUBST([htmldir], ['${docdir}']) -m4trace:configure.ac:16: -1- AC_SUBST_TRACE([htmldir]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^htmldir$]) -m4trace:configure.ac:16: -1- AC_SUBST([dvidir], ['${docdir}']) -m4trace:configure.ac:16: -1- AC_SUBST_TRACE([dvidir]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^dvidir$]) -m4trace:configure.ac:16: -1- AC_SUBST([pdfdir], ['${docdir}']) -m4trace:configure.ac:16: -1- AC_SUBST_TRACE([pdfdir]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^pdfdir$]) -m4trace:configure.ac:16: -1- AC_SUBST([psdir], ['${docdir}']) -m4trace:configure.ac:16: -1- AC_SUBST_TRACE([psdir]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^psdir$]) -m4trace:configure.ac:16: -1- AC_SUBST([libdir], ['${exec_prefix}/lib']) -m4trace:configure.ac:16: -1- AC_SUBST_TRACE([libdir]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^libdir$]) -m4trace:configure.ac:16: -1- AC_SUBST([localedir], ['${datarootdir}/locale']) -m4trace:configure.ac:16: -1- AC_SUBST_TRACE([localedir]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^localedir$]) -m4trace:configure.ac:16: -1- AC_SUBST([mandir], ['${datarootdir}/man']) -m4trace:configure.ac:16: -1- AC_SUBST_TRACE([mandir]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^mandir$]) -m4trace:configure.ac:16: -1- AC_DEFINE_TRACE_LITERAL([PACKAGE_NAME]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^PACKAGE_NAME$]) -m4trace:configure.ac:16: -1- AH_OUTPUT([PACKAGE_NAME], [/* Define to the full name of this package. */ -#undef PACKAGE_NAME]) -m4trace:configure.ac:16: -1- AC_DEFINE_TRACE_LITERAL([PACKAGE_TARNAME]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^PACKAGE_TARNAME$]) -m4trace:configure.ac:16: -1- AH_OUTPUT([PACKAGE_TARNAME], [/* Define to the one symbol short name of this package. */ -#undef PACKAGE_TARNAME]) -m4trace:configure.ac:16: -1- AC_DEFINE_TRACE_LITERAL([PACKAGE_VERSION]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^PACKAGE_VERSION$]) -m4trace:configure.ac:16: -1- AH_OUTPUT([PACKAGE_VERSION], [/* Define to the version of this package. */ -#undef PACKAGE_VERSION]) -m4trace:configure.ac:16: -1- AC_DEFINE_TRACE_LITERAL([PACKAGE_STRING]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^PACKAGE_STRING$]) -m4trace:configure.ac:16: -1- AH_OUTPUT([PACKAGE_STRING], [/* Define to the full name and version of this package. */ -#undef PACKAGE_STRING]) -m4trace:configure.ac:16: -1- AC_DEFINE_TRACE_LITERAL([PACKAGE_BUGREPORT]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^PACKAGE_BUGREPORT$]) -m4trace:configure.ac:16: -1- AH_OUTPUT([PACKAGE_BUGREPORT], [/* Define to the address where bug reports for this package should be sent. */ -#undef PACKAGE_BUGREPORT]) -m4trace:configure.ac:16: -1- AC_SUBST([DEFS]) -m4trace:configure.ac:16: -1- AC_SUBST_TRACE([DEFS]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^DEFS$]) -m4trace:configure.ac:16: -1- AC_SUBST([ECHO_C]) -m4trace:configure.ac:16: -1- AC_SUBST_TRACE([ECHO_C]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^ECHO_C$]) -m4trace:configure.ac:16: -1- AC_SUBST([ECHO_N]) -m4trace:configure.ac:16: -1- AC_SUBST_TRACE([ECHO_N]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^ECHO_N$]) -m4trace:configure.ac:16: -1- AC_SUBST([ECHO_T]) -m4trace:configure.ac:16: -1- AC_SUBST_TRACE([ECHO_T]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^ECHO_T$]) -m4trace:configure.ac:16: -1- AC_SUBST([LIBS]) -m4trace:configure.ac:16: -1- AC_SUBST_TRACE([LIBS]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^LIBS$]) -m4trace:configure.ac:16: -1- AC_SUBST([build_alias]) -m4trace:configure.ac:16: -1- AC_SUBST_TRACE([build_alias]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^build_alias$]) -m4trace:configure.ac:16: -1- AC_SUBST([host_alias]) -m4trace:configure.ac:16: -1- AC_SUBST_TRACE([host_alias]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^host_alias$]) -m4trace:configure.ac:16: -1- AC_SUBST([target_alias]) -m4trace:configure.ac:16: -1- AC_SUBST_TRACE([target_alias]) -m4trace:configure.ac:16: -1- m4_pattern_allow([^target_alias$]) -m4trace:configure.ac:18: -1- AC_SUBST([TRITON_VERSION]) -m4trace:configure.ac:18: -1- AC_SUBST_TRACE([TRITON_VERSION]) -m4trace:configure.ac:18: -1- m4_pattern_allow([^TRITON_VERSION$]) -m4trace:configure.ac:20: -1- AC_DEFINE_TRACE_LITERAL([TRITON_VERSION_MAJOR]) -m4trace:configure.ac:20: -1- m4_pattern_allow([^TRITON_VERSION_MAJOR$]) -m4trace:configure.ac:20: -1- AH_OUTPUT([TRITON_VERSION_MAJOR], [/* major version number */ -#undef TRITON_VERSION_MAJOR]) -m4trace:configure.ac:21: -1- AC_DEFINE_TRACE_LITERAL([TRITON_VERSION_MINOR]) -m4trace:configure.ac:21: -1- m4_pattern_allow([^TRITON_VERSION_MINOR$]) -m4trace:configure.ac:21: -1- AH_OUTPUT([TRITON_VERSION_MINOR], [/* minor version number */ -#undef TRITON_VERSION_MINOR]) -m4trace:configure.ac:22: -1- AC_DEFINE_TRACE_LITERAL([TRITON_VERSION_SUB]) -m4trace:configure.ac:22: -1- m4_pattern_allow([^TRITON_VERSION_SUB$]) -m4trace:configure.ac:22: -1- AH_OUTPUT([TRITON_VERSION_SUB], [/* sub version number */ -#undef TRITON_VERSION_SUB]) -m4trace:configure.ac:24: -1- AC_CONFIG_HEADERS([triton-config.h]) -m4trace:configure.ac:25: -1- AC_CONFIG_AUX_DIR([maint/config]) -m4trace:configure.ac:27: -1- AC_REQUIRE_AUX_FILE([install-sh]) -m4trace:configure.ac:27: -1- AC_SUBST([INSTALL_PROGRAM]) -m4trace:configure.ac:27: -1- AC_SUBST_TRACE([INSTALL_PROGRAM]) -m4trace:configure.ac:27: -1- m4_pattern_allow([^INSTALL_PROGRAM$]) -m4trace:configure.ac:27: -1- AC_SUBST([INSTALL_SCRIPT]) -m4trace:configure.ac:27: -1- AC_SUBST_TRACE([INSTALL_SCRIPT]) -m4trace:configure.ac:27: -1- m4_pattern_allow([^INSTALL_SCRIPT$]) -m4trace:configure.ac:27: -1- AC_SUBST([INSTALL_DATA]) -m4trace:configure.ac:27: -1- AC_SUBST_TRACE([INSTALL_DATA]) -m4trace:configure.ac:27: -1- m4_pattern_allow([^INSTALL_DATA$]) -m4trace:configure.ac:28: -1- AC_SUBST([CC]) -m4trace:configure.ac:28: -1- AC_SUBST_TRACE([CC]) -m4trace:configure.ac:28: -1- m4_pattern_allow([^CC$]) -m4trace:configure.ac:28: -1- AC_SUBST([CFLAGS]) -m4trace:configure.ac:28: -1- AC_SUBST_TRACE([CFLAGS]) -m4trace:configure.ac:28: -1- m4_pattern_allow([^CFLAGS$]) -m4trace:configure.ac:28: -1- AC_SUBST([LDFLAGS]) -m4trace:configure.ac:28: -1- AC_SUBST_TRACE([LDFLAGS]) -m4trace:configure.ac:28: -1- m4_pattern_allow([^LDFLAGS$]) -m4trace:configure.ac:28: -1- AC_SUBST([LIBS]) -m4trace:configure.ac:28: -1- AC_SUBST_TRACE([LIBS]) -m4trace:configure.ac:28: -1- m4_pattern_allow([^LIBS$]) -m4trace:configure.ac:28: -1- AC_SUBST([CPPFLAGS]) -m4trace:configure.ac:28: -1- AC_SUBST_TRACE([CPPFLAGS]) -m4trace:configure.ac:28: -1- m4_pattern_allow([^CPPFLAGS$]) -m4trace:configure.ac:28: -1- AC_SUBST([CC]) -m4trace:configure.ac:28: -1- AC_SUBST_TRACE([CC]) -m4trace:configure.ac:28: -1- m4_pattern_allow([^CC$]) -m4trace:configure.ac:28: -1- AC_SUBST([CC]) -m4trace:configure.ac:28: -1- AC_SUBST_TRACE([CC]) -m4trace:configure.ac:28: -1- m4_pattern_allow([^CC$]) -m4trace:configure.ac:28: -1- AC_SUBST([CC]) -m4trace:configure.ac:28: -1- AC_SUBST_TRACE([CC]) -m4trace:configure.ac:28: -1- m4_pattern_allow([^CC$]) -m4trace:configure.ac:28: -1- AC_SUBST([CC]) -m4trace:configure.ac:28: -1- AC_SUBST_TRACE([CC]) -m4trace:configure.ac:28: -1- m4_pattern_allow([^CC$]) -m4trace:configure.ac:28: -1- AC_SUBST([ac_ct_CC]) -m4trace:configure.ac:28: -1- AC_SUBST_TRACE([ac_ct_CC]) -m4trace:configure.ac:28: -1- m4_pattern_allow([^ac_ct_CC$]) -m4trace:configure.ac:28: -1- AC_SUBST([EXEEXT], [$ac_cv_exeext]) -m4trace:configure.ac:28: -1- AC_SUBST_TRACE([EXEEXT]) -m4trace:configure.ac:28: -1- m4_pattern_allow([^EXEEXT$]) -m4trace:configure.ac:28: -1- AC_SUBST([OBJEXT], [$ac_cv_objext]) -m4trace:configure.ac:28: -1- AC_SUBST_TRACE([OBJEXT]) -m4trace:configure.ac:28: -1- m4_pattern_allow([^OBJEXT$]) -m4trace:configure.ac:29: -1- AC_SUBST([CPP]) -m4trace:configure.ac:29: -1- AC_SUBST_TRACE([CPP]) -m4trace:configure.ac:29: -1- m4_pattern_allow([^CPP$]) -m4trace:configure.ac:29: -1- AC_SUBST([CPPFLAGS]) -m4trace:configure.ac:29: -1- AC_SUBST_TRACE([CPPFLAGS]) -m4trace:configure.ac:29: -1- m4_pattern_allow([^CPPFLAGS$]) -m4trace:configure.ac:29: -1- AC_SUBST([CPP]) -m4trace:configure.ac:29: -1- AC_SUBST_TRACE([CPP]) -m4trace:configure.ac:29: -1- m4_pattern_allow([^CPP$]) -m4trace:configure.ac:31: -1- AC_SUBST([GREP]) -m4trace:configure.ac:31: -1- AC_SUBST_TRACE([GREP]) -m4trace:configure.ac:31: -1- m4_pattern_allow([^GREP$]) -m4trace:configure.ac:31: -1- AC_SUBST([GREP]) -m4trace:configure.ac:31: -1- AC_SUBST_TRACE([GREP]) -m4trace:configure.ac:31: -1- m4_pattern_allow([^GREP$]) -m4trace:configure.ac:31: -1- AC_SUBST([EGREP]) -m4trace:configure.ac:31: -1- AC_SUBST_TRACE([EGREP]) -m4trace:configure.ac:31: -1- m4_pattern_allow([^EGREP$]) -m4trace:configure.ac:31: -1- AC_SUBST([EGREP]) -m4trace:configure.ac:31: -1- AC_SUBST_TRACE([EGREP]) -m4trace:configure.ac:31: -1- m4_pattern_allow([^EGREP$]) -m4trace:configure.ac:31: -1- AC_DEFINE_TRACE_LITERAL([STDC_HEADERS]) -m4trace:configure.ac:31: -1- m4_pattern_allow([^STDC_HEADERS$]) -m4trace:configure.ac:31: -1- AH_OUTPUT([STDC_HEADERS], [/* Define to 1 if you have the ANSI C header files. */ -#undef STDC_HEADERS]) -m4trace:configure.ac:31: -1- AH_OUTPUT([HAVE_SYS_TYPES_H], [/* Define to 1 if you have the <sys/types.h> header file. */ -#undef HAVE_SYS_TYPES_H]) -m4trace:configure.ac:31: -1- AH_OUTPUT([HAVE_SYS_STAT_H], [/* Define to 1 if you have the <sys/stat.h> header file. */ -#undef HAVE_SYS_STAT_H]) -m4trace:configure.ac:31: -1- AH_OUTPUT([HAVE_STDLIB_H], [/* Define to 1 if you have the <stdlib.h> header file. */ -#undef HAVE_STDLIB_H]) -m4trace:configure.ac:31: -1- AH_OUTPUT([HAVE_STRING_H], [/* Define to 1 if you have the <string.h> header file. */ -#undef HAVE_STRING_H]) -m4trace:configure.ac:31: -1- AH_OUTPUT([HAVE_MEMORY_H], [/* Define to 1 if you have the <memory.h> header file. */ -#undef HAVE_MEMORY_H]) -m4trace:configure.ac:31: -1- AH_OUTPUT([HAVE_STRINGS_H], [/* Define to 1 if you have the <strings.h> header file. */ -#undef HAVE_STRINGS_H]) -m4trace:configure.ac:31: -1- AH_OUTPUT([HAVE_INTTYPES_H], [/* Define to 1 if you have the <inttypes.h> header file. */ -#undef HAVE_INTTYPES_H]) -m4trace:configure.ac:31: -1- AH_OUTPUT([HAVE_STDINT_H], [/* Define to 1 if you have the <stdint.h> header file. */ -#undef HAVE_STDINT_H]) -m4trace:configure.ac:31: -1- AH_OUTPUT([HAVE_UNISTD_H], [/* Define to 1 if you have the <unistd.h> header file. */ -#undef HAVE_UNISTD_H]) -m4trace:configure.ac:31: -1- AC_DEFINE_TRACE_LITERAL([WORDS_BIGENDIAN]) -m4trace:configure.ac:31: -1- m4_pattern_allow([^WORDS_BIGENDIAN$]) -m4trace:configure.ac:31: -1- AH_OUTPUT([WORDS_BIGENDIAN], [/* Define to 1 if your processor stores words with the most significant byte - first (like Motorola and SPARC, unlike Intel and VAX). */ -#undef WORDS_BIGENDIAN]) -m4trace:configure.ac:33: -1- AC_DEFINE_TRACE_LITERAL([SIZEOF_LONG_INT]) -m4trace:configure.ac:33: -1- m4_pattern_allow([^SIZEOF_LONG_INT$]) -m4trace:configure.ac:33: -1- AH_OUTPUT([SIZEOF_LONG_INT], [/* The size of `long int\', as computed by sizeof. */ -#undef SIZEOF_LONG_INT]) -m4trace:configure.ac:34: -1- AC_DEFINE_TRACE_LITERAL([SIZEOF_VOID_P]) -m4trace:configure.ac:34: -1- m4_pattern_allow([^SIZEOF_VOID_P$]) -m4trace:configure.ac:34: -1- AH_OUTPUT([SIZEOF_VOID_P], [/* The size of `void *\', as computed by sizeof. */ -#undef SIZEOF_VOID_P]) -m4trace:configure.ac:42: -1- AC_SUBST([GHC]) -m4trace:configure.ac:42: -1- AC_SUBST_TRACE([GHC]) -m4trace:configure.ac:42: -1- m4_pattern_allow([^GHC$]) -m4trace:configure.ac:42: -1- AC_SUBST([GHC]) -m4trace:configure.ac:42: -1- AC_SUBST_TRACE([GHC]) -m4trace:configure.ac:42: -1- m4_pattern_allow([^GHC$]) -m4trace:configure.ac:46: -1- AC_SUBST([GHC]) -m4trace:configure.ac:46: -1- AC_SUBST_TRACE([GHC]) -m4trace:configure.ac:46: -1- m4_pattern_allow([^GHC$]) -m4trace:configure.ac:52: -1- _m4_warn([obsolete], [The macro `AC_TRY_LINK' is obsolete. -You should run autoupdate.], [../../lib/autoconf/general.m4:2414: AC_TRY_LINK is expanded from... -maint/config/bdb.m4:2: AX_BERKELEY_DB is expanded from... -../../lib/m4sugar/m4sh.m4:516: AS_IF is expanded from... -../../lib/autoconf/general.m4:1382: AC_ARG_WITH is expanded from... -configure.ac:52: the top level]) -m4trace:configure.ac:52: -1- _m4_warn([obsolete], [The macro `AC_TRY_LINK' is obsolete. -You should run autoupdate.], [../../lib/autoconf/general.m4:2414: AC_TRY_LINK is expanded from... -maint/config/bdb.m4:2: AX_BERKELEY_DB is expanded from... -../../lib/m4sugar/m4sh.m4:516: AS_IF is expanded from... -../../lib/autoconf/general.m4:1382: AC_ARG_WITH is expanded from... -configure.ac:52: the top level]) -m4trace:configure.ac:52: -1- AC_SUBST([DB_CFLAGS]) -m4trace:configure.ac:52: -1- AC_SUBST_TRACE([DB_CFLAGS]) -m4trace:configure.ac:52: -1- m4_pattern_allow([^DB_CFLAGS$]) -m4trace:configure.ac:52: -1- AC_SUBST([DB_LIB]) -m4trace:configure.ac:52: -1- AC_SUBST_TRACE([DB_LIB]) -m4trace:configure.ac:52: -1- m4_pattern_allow([^DB_LIB$]) -m4trace:configure.ac:52: -2- AC_DEFINE_TRACE_LITERAL([HAVE_DBENV_PARAMETER_TO_DB_ERROR_CALLBACK]) -m4trace:configure.ac:52: -2- m4_pattern_allow([^HAVE_DBENV_PARAMETER_TO_DB_ERROR_CALLBACK$]) -m4trace:configure.ac:52: -2- AH_OUTPUT([HAVE_DBENV_PARAMETER_TO_DB_ERROR_CALLBACK], [/* Define if DB error callback function takes dbenv parameter */ -#undef HAVE_DBENV_PARAMETER_TO_DB_ERROR_CALLBACK]) -m4trace:configure.ac:52: -1- _m4_warn([obsolete], [The macro `AC_TRY_COMPILE' is obsolete. -You should run autoupdate.], [../../lib/autoconf/general.m4:2367: AC_TRY_COMPILE is expanded from... -maint/config/bdb.m4:2: AX_BERKELEY_DB is expanded from... -../../lib/m4sugar/m4sh.m4:516: AS_IF is expanded from... -../../lib/autoconf/general.m4:1382: AC_ARG_WITH is expanded from... -configure.ac:52: the top level]) -m4trace:configure.ac:52: -2- AC_DEFINE_TRACE_LITERAL([HAVE_CONST_THIRD_PARAMETER_TO_DB_ERROR_CALLBACK]) -m4trace:configure.ac:52: -2- m4_pattern_allow([^HAVE_CONST_THIRD_PARAMETER_TO_DB_ERROR_CALLBACK$]) -m4trace:configure.ac:52: -2- AH_OUTPUT([HAVE_CONST_THIRD_PARAMETER_TO_DB_ERROR_CALLBACK], [/* Define if third param (message) to DB error callback function is const */ -#undef HAVE_CONST_THIRD_PARAMETER_TO_DB_ERROR_CALLBACK]) -m4trace:configure.ac:52: -1- _m4_warn([obsolete], [The macro `AC_TRY_COMPILE' is obsolete. -You should run autoupdate.], [../../lib/autoconf/general.m4:2367: AC_TRY_COMPILE is expanded from... -maint/config/bdb.m4:2: AX_BERKELEY_DB is expanded from... -../../lib/m4sugar/m4sh.m4:516: AS_IF is expanded from... -../../lib/autoconf/general.m4:1382: AC_ARG_WITH is expanded from... -configure.ac:52: the top level]) -m4trace:configure.ac:52: -2- AC_DEFINE_TRACE_LITERAL([HAVE_UNKNOWN_PARAMETER_TO_DB_STAT]) -m4trace:configure.ac:52: -2- m4_pattern_allow([^HAVE_UNKNOWN_PARAMETER_TO_DB_STAT$]) -m4trace:configure.ac:52: -2- AH_OUTPUT([HAVE_UNKNOWN_PARAMETER_TO_DB_STAT], [/* Define if DB stat function takes malloc function ptr */ -#undef HAVE_UNKNOWN_PARAMETER_TO_DB_STAT]) -m4trace:configure.ac:52: -1- _m4_warn([obsolete], [The macro `AC_TRY_COMPILE' is obsolete. -You should run autoupdate.], [../../lib/autoconf/general.m4:2367: AC_TRY_COMPILE is expanded from... -maint/config/bdb.m4:2: AX_BERKELEY_DB is expanded from... -../../lib/m4sugar/m4sh.m4:516: AS_IF is expanded from... -../../lib/autoconf/general.m4:1382: AC_ARG_WITH is expanded from... -configure.ac:52: the top level]) -m4trace:configure.ac:52: -2- AC_DEFINE_TRACE_LITERAL([HAVE_TXNID_PARAMETER_TO_DB_STAT]) -m4trace:configure.ac:52: -2- m4_pattern_allow([^HAVE_TXNID_PARAMETER_TO_DB_STAT$]) -m4trace:configure.ac:52: -2- AH_OUTPUT([HAVE_TXNID_PARAMETER_TO_DB_STAT], [/* Define if DB stat function takes txnid parameter */ -#undef HAVE_TXNID_PARAMETER_TO_DB_STAT]) -m4trace:configure.ac:52: -1- _m4_warn([obsolete], [The macro `AC_TRY_COMPILE' is obsolete. -You should run autoupdate.], [../../lib/autoconf/general.m4:2367: AC_TRY_COMPILE is expanded from... -maint/config/bdb.m4:2: AX_BERKELEY_DB is expanded from... -../../lib/m4sugar/m4sh.m4:516: AS_IF is expanded from... -../../lib/autoconf/general.m4:1382: AC_ARG_WITH is expanded from... -configure.ac:52: the top level]) -m4trace:configure.ac:52: -2- AC_DEFINE_TRACE_LITERAL([HAVE_TXNID_PARAMETER_TO_DB_OPEN]) -m4trace:configure.ac:52: -2- m4_pattern_allow([^HAVE_TXNID_PARAMETER_TO_DB_OPEN$]) -m4trace:configure.ac:52: -2- AH_OUTPUT([HAVE_TXNID_PARAMETER_TO_DB_OPEN], [/* Define if DB open function takes a txnid parameter */ -#undef HAVE_TXNID_PARAMETER_TO_DB_OPEN]) -m4trace:configure.ac:52: -1- _m4_warn([obsolete], [The macro `AC_TRY_COMPILE' is obsolete. -You should run autoupdate.], [../../lib/autoconf/general.m4:2367: AC_TRY_COMPILE is expanded from... -maint/config/bdb.m4:2: AX_BERKELEY_DB is expanded from... -../../lib/m4sugar/m4sh.m4:516: AS_IF is expanded from... -../../lib/autoconf/general.m4:1382: AC_ARG_WITH is expanded from... -configure.ac:52: the top level]) -m4trace:configure.ac:52: -2- AC_DEFINE_TRACE_LITERAL([HAVE_DB_DIRTY_READ]) -m4trace:configure.ac:52: -2- m4_pattern_allow([^HAVE_DB_DIRTY_READ$]) -m4trace:configure.ac:52: -2- AH_OUTPUT([HAVE_DB_DIRTY_READ], [/* Define if db library has DB_DIRTY_READ flag */ -#undef HAVE_DB_DIRTY_READ]) -m4trace:configure.ac:52: -1- _m4_warn([obsolete], [The macro `AC_TRY_COMPILE' is obsolete. -You should run autoupdate.], [../../lib/autoconf/general.m4:2367: AC_TRY_COMPILE is expanded from... -maint/config/bdb.m4:2: AX_BERKELEY_DB is expanded from... -../../lib/m4sugar/m4sh.m4:516: AS_IF is expanded from... -../../lib/autoconf/general.m4:1382: AC_ARG_WITH is expanded from... -configure.ac:52: the top level]) -m4trace:configure.ac:52: -2- AC_DEFINE_TRACE_LITERAL([HAVE_DB_BUFFER_SMALL]) -m4trace:configure.ac:52: -2- m4_pattern_allow([^HAVE_DB_BUFFER_SMALL$]) -m4trace:configure.ac:52: -2- AH_OUTPUT([HAVE_DB_BUFFER_SMALL], [/* Define if db library has DB_BUFFER_SMALL error */ -#undef HAVE_DB_BUFFER_SMALL]) -m4trace:configure.ac:52: -1- _m4_warn([obsolete], [The macro `AC_TRY_COMPILE' is obsolete. -You should run autoupdate.], [../../lib/autoconf/general.m4:2367: AC_TRY_COMPILE is expanded from... -maint/config/bdb.m4:2: AX_BERKELEY_DB is expanded from... -../../lib/m4sugar/m4sh.m4:516: AS_IF is expanded from... -../../lib/autoconf/general.m4:1382: AC_ARG_WITH is expanded from... -configure.ac:52: the top level]) -m4trace:configure.ac:52: -2- AC_DEFINE_TRACE_LITERAL([HAVE_DB_GET_PAGESIZE]) -m4trace:configure.ac:52: -2- m4_pattern_allow([^HAVE_DB_GET_PAGESIZE$]) -m4trace:configure.ac:52: -2- AH_OUTPUT([HAVE_DB_GET_PAGESIZE], [/* Define if DB has get_pagesize function */ -#undef HAVE_DB_GET_PAGESIZE]) -m4trace:configure.ac:52: -1- _m4_warn([obsolete], [The macro `AC_TRY_COMPILE' is obsolete. -You should run autoupdate.], [../../lib/autoconf/general.m4:2367: AC_TRY_COMPILE is expanded from... -maint/config/bdb.m4:2: AX_BERKELEY_DB is expanded from... -../../lib/m4sugar/m4sh.m4:516: AS_IF is expanded from... -../../lib/autoconf/general.m4:1382: AC_ARG_WITH is expanded from... -configure.ac:52: the top level]) -m4trace:configure.ac:52: -1- _m4_warn([obsolete], [The macro `AC_TRY_LINK' is obsolete. -You should run autoupdate.], [../../lib/autoconf/general.m4:2414: AC_TRY_LINK is expanded from... -maint/config/bdb.m4:2: AX_BERKELEY_DB is expanded from... -../../lib/m4sugar/m4sh.m4:516: AS_IF is expanded from... -../../lib/autoconf/general.m4:1382: AC_ARG_WITH is expanded from... -configure.ac:52: the top level]) -m4trace:configure.ac:52: -1- _m4_warn([obsolete], [The macro `AC_TRY_LINK' is obsolete. -You should run autoupdate.], [../../lib/autoconf/general.m4:2414: AC_TRY_LINK is expanded from... -maint/config/bdb.m4:2: AX_BERKELEY_DB is expanded from... -../../lib/m4sugar/m4sh.m4:516: AS_IF is expanded from... -../../lib/autoconf/general.m4:1382: AC_ARG_WITH is expanded from... -configure.ac:52: the top level]) -m4trace:configure.ac:52: -1- AC_SUBST([DB_CFLAGS]) -m4trace:configure.ac:52: -1- AC_SUBST_TRACE([DB_CFLAGS]) -m4trace:configure.ac:52: -1- m4_pattern_allow([^DB_CFLAGS$]) -m4trace:configure.ac:52: -1- AC_SUBST([DB_LIB]) -m4trace:configure.ac:52: -1- AC_SUBST_TRACE([DB_LIB]) -m4trace:configure.ac:52: -1- m4_pattern_allow([^DB_LIB$]) -m4trace:configure.ac:52: -2- AC_DEFINE_TRACE_LITERAL([HAVE_DBENV_PARAMETER_TO_DB_ERROR_CALLBACK]) -m4trace:configure.ac:52: -2- m4_pattern_allow([^HAVE_DBENV_PARAMETER_TO_DB_ERROR_CALLBACK$]) -m4trace:configure.ac:52: -2- AH_OUTPUT([HAVE_DBENV_PARAMETER_TO_DB_ERROR_CALLBACK], [/* Define if DB error callback function takes dbenv parameter */ -#undef HAVE_DBENV_PARAMETER_TO_DB_ERROR_CALLBACK]) -m4trace:configure.ac:52: -1- _m4_warn([obsolete], [The macro `AC_TRY_COMPILE' is obsolete. -You should run autoupdate.], [../../lib/autoconf/general.m4:2367: AC_TRY_COMPILE is expanded from... -maint/config/bdb.m4:2: AX_BERKELEY_DB is expanded from... -../../lib/m4sugar/m4sh.m4:516: AS_IF is expanded from... -../../lib/autoconf/general.m4:1382: AC_ARG_WITH is expanded from... -configure.ac:52: the top level]) -m4trace:configure.ac:52: -2- AC_DEFINE_TRACE_LITERAL([HAVE_CONST_THIRD_PARAMETER_TO_DB_ERROR_CALLBACK]) -m4trace:configure.ac:52: -2- m4_pattern_allow([^HAVE_CONST_THIRD_PARAMETER_TO_DB_ERROR_CALLBACK$]) -m4trace:configure.ac:52: -2- AH_OUTPUT([HAVE_CONST_THIRD_PARAMETER_TO_DB_ERROR_CALLBACK], [/* Define if third param (message) to DB error callback function is const */ -#undef HAVE_CONST_THIRD_PARAMETER_TO_DB_ERROR_CALLBACK]) -m4trace:configure.ac:52: -1- _m4_warn([obsolete], [The macro `AC_TRY_COMPILE' is obsolete. -You should run autoupdate.], [../../lib/autoconf/general.m4:2367: AC_TRY_COMPILE is expanded from... -maint/config/bdb.m4:2: AX_BERKELEY_DB is expanded from... -../../lib/m4sugar/m4sh.m4:516: AS_IF is expanded from... -../../lib/autoconf/general.m4:1382: AC_ARG_WITH is expanded from... -configure.ac:52: the top level]) -m4trace:configure.ac:52: -2- AC_DEFINE_TRACE_LITERAL([HAVE_UNKNOWN_PARAMETER_TO_DB_STAT]) -m4trace:configure.ac:52: -2- m4_pattern_allow([^HAVE_UNKNOWN_PARAMETER_TO_DB_STAT$]) -m4trace:configure.ac:52: -2- AH_OUTPUT([HAVE_UNKNOWN_PARAMETER_TO_DB_STAT], [/* Define if DB stat function takes malloc function ptr */ -#undef HAVE_UNKNOWN_PARAMETER_TO_DB_STAT]) -m4trace:configure.ac:52: -1- _m4_warn([obsolete], [The macro `AC_TRY_COMPILE' is obsolete. -You should run autoupdate.], [../../lib/autoconf/general.m4:2367: AC_TRY_COMPILE is expanded from... -maint/config/bdb.m4:2: AX_BERKELEY_DB is expanded from... -../../lib/m4sugar/m4sh.m4:516: AS_IF is expanded from... -../../lib/autoconf/general.m4:1382: AC_ARG_WITH is expanded from... -configure.ac:52: the top level]) -m4trace:configure.ac:52: -2- AC_DEFINE_TRACE_LITERAL([HAVE_TXNID_PARAMETER_TO_DB_STAT]) -m4trace:configure.ac:52: -2- m4_pattern_allow([^HAVE_TXNID_PARAMETER_TO_DB_STAT$]) -m4trace:configure.ac:52: -2- AH_OUTPUT([HAVE_TXNID_PARAMETER_TO_DB_STAT], [/* Define if DB stat function takes txnid parameter */ -#undef HAVE_TXNID_PARAMETER_TO_DB_STAT]) -m4trace:configure.ac:52: -1- _m4_warn([obsolete], [The macro `AC_TRY_COMPILE' is obsolete. -You should run autoupdate.], [../../lib/autoconf/general.m4:2367: AC_TRY_COMPILE is expanded from... -maint/config/bdb.m4:2: AX_BERKELEY_DB is expanded from... -../../lib/m4sugar/m4sh.m4:516: AS_IF is expanded from... -../../lib/autoconf/general.m4:1382: AC_ARG_WITH is expanded from... -configure.ac:52: the top level]) -m4trace:configure.ac:52: -2- AC_DEFINE_TRACE_LITERAL([HAVE_TXNID_PARAMETER_TO_DB_OPEN]) -m4trace:configure.ac:52: -2- m4_pattern_allow([^HAVE_TXNID_PARAMETER_TO_DB_OPEN$]) -m4trace:configure.ac:52: -2- AH_OUTPUT([HAVE_TXNID_PARAMETER_TO_DB_OPEN], [/* Define if DB open function takes a txnid parameter */ -#undef HAVE_TXNID_PARAMETER_TO_DB_OPEN]) -m4trace:configure.ac:52: -1- _m4_warn([obsolete], [The macro `AC_TRY_COMPILE' is obsolete. -You should run autoupdate.], [../../lib/autoconf/general.m4:2367: AC_TRY_COMPILE is expanded from... -maint/config/bdb.m4:2: AX_BERKELEY_DB is expanded from... -../../lib/m4sugar/m4sh.m4:516: AS_IF is expanded from... -../../lib/autoconf/general.m4:1382: AC_ARG_WITH is expanded from... -configure.ac:52: the top level]) -m4trace:configure.ac:52: -2- AC_DEFINE_TRACE_LITERAL([HAVE_DB_DIRTY_READ]) -m4trace:configure.ac:52: -2- m4_pattern_allow([^HAVE_DB_DIRTY_READ$]) -m4trace:configure.ac:52: -2- AH_OUTPUT([HAVE_DB_DIRTY_READ], [/* Define if db library has DB_DIRTY_READ flag */ -#undef HAVE_DB_DIRTY_READ]) -m4trace:configure.ac:52: -1- _m4_warn([obsolete], [The macro `AC_TRY_COMPILE' is obsolete. -You should run autoupdate.], [../../lib/autoconf/general.m4:2367: AC_TRY_COMPILE is expanded from... -maint/config/bdb.m4:2: AX_BERKELEY_DB is expanded from... -../../lib/m4sugar/m4sh.m4:516: AS_IF is expanded from... -../../lib/autoconf/general.m4:1382: AC_ARG_WITH is expanded from... -configure.ac:52: the top level]) -m4trace:configure.ac:52: -2- AC_DEFINE_TRACE_LITERAL([HAVE_DB_BUFFER_SMALL]) -m4trace:configure.ac:52: -2- m4_pattern_allow([^HAVE_DB_BUFFER_SMALL$]) -m4trace:configure.ac:52: -2- AH_OUTPUT([HAVE_DB_BUFFER_SMALL], [/* Define if db library has DB_BUFFER_SMALL error */ -#undef HAVE_DB_BUFFER_SMALL]) -m4trace:configure.ac:52: -1- _m4_warn([obsolete], [The macro `AC_TRY_COMPILE' is obsolete. -You should run autoupdate.], [../../lib/autoconf/general.m4:2367: AC_TRY_COMPILE is expanded from... -maint/config/bdb.m4:2: AX_BERKELEY_DB is expanded from... -../../lib/m4sugar/m4sh.m4:516: AS_IF is expanded from... -../../lib/autoconf/general.m4:1382: AC_ARG_WITH is expanded from... -configure.ac:52: the top level]) -m4trace:configure.ac:52: -2- AC_DEFINE_TRACE_LITERAL([HAVE_DB_GET_PAGESIZE]) -m4trace:configure.ac:52: -2- m4_pattern_allow([^HAVE_DB_GET_PAGESIZE$]) -m4trace:configure.ac:52: -2- AH_OUTPUT([HAVE_DB_GET_PAGESIZE], [/* Define if DB has get_pagesize function */ -#undef HAVE_DB_GET_PAGESIZE]) -m4trace:configure.ac:52: -1- _m4_warn([obsolete], [The macro `AC_TRY_COMPILE' is obsolete. -You should run autoupdate.], [../../lib/autoconf/general.m4:2367: AC_TRY_COMPILE is expanded from... -maint/config/bdb.m4:2: AX_BERKELEY_DB is expanded from... -../../lib/m4sugar/m4sh.m4:516: AS_IF is expanded from... -../../lib/autoconf/general.m4:1382: AC_ARG_WITH is expanded from... -configure.ac:52: the top level]) -m4trace:configure.ac:70: -1- AC_SUBST([MPICC]) -m4trace:configure.ac:70: -1- AC_SUBST_TRACE([MPICC]) -m4trace:configure.ac:70: -1- m4_pattern_allow([^MPICC$]) -m4trace:configure.ac:71: -1- AC_SUBST([MPICFLAGS]) -m4trace:configure.ac:71: -1- AC_SUBST_TRACE([MPICFLAGS]) -m4trace:configure.ac:71: -1- m4_pattern_allow([^MPICFLAGS$]) -m4trace:configure.ac:72: -1- AC_SUBST([MPILDFLAGS]) -m4trace:configure.ac:72: -1- AC_SUBST_TRACE([MPILDFLAGS]) -m4trace:configure.ac:72: -1- m4_pattern_allow([^MPILDFLAGS$]) -m4trace:configure.ac:73: -1- AC_SUBST([MPILIBS]) -m4trace:configure.ac:73: -1- AC_SUBST_TRACE([MPILIBS]) -m4trace:configure.ac:73: -1- m4_pattern_allow([^MPILIBS$]) -m4trace:configure.ac:74: -1- AC_SUBST([BUILD_MPI]) -m4trace:configure.ac:74: -1- AC_SUBST_TRACE([BUILD_MPI]) -m4trace:configure.ac:74: -1- m4_pattern_allow([^BUILD_MPI$]) -m4trace:configure.ac:80: -1- AC_SUBST([BUILD_ABSOLUTE_TOP]) -m4trace:configure.ac:80: -1- AC_SUBST_TRACE([BUILD_ABSOLUTE_TOP]) -m4trace:configure.ac:80: -1- m4_pattern_allow([^BUILD_ABSOLUTE_TOP$]) -m4trace:configure.ac:81: -1- AC_SUBST([SRC_RELATIVE_TOP]) -m4trace:configure.ac:81: -1- AC_SUBST_TRACE([SRC_RELATIVE_TOP]) -m4trace:configure.ac:81: -1- m4_pattern_allow([^SRC_RELATIVE_TOP$]) -m4trace:configure.ac:82: -1- AC_SUBST([SRC_ABSOLUTE_TOP]) -m4trace:configure.ac:82: -1- AC_SUBST_TRACE([SRC_ABSOLUTE_TOP]) -m4trace:configure.ac:82: -1- m4_pattern_allow([^SRC_ABSOLUTE_TOP$]) -m4trace:configure.ac:84: -1- AC_SUBST([CFLAGS]) -m4trace:configure.ac:84: -1- AC_SUBST_TRACE([CFLAGS]) -m4trace:configure.ac:84: -1- m4_pattern_allow([^CFLAGS$]) -m4trace:configure.ac:85: -1- AC_SUBST([LDFLAGS]) -m4trace:configure.ac:85: -1- AC_SUBST_TRACE([LDFLAGS]) -m4trace:configure.ac:85: -1- m4_pattern_allow([^LDFLAGS$]) -m4trace:configure.ac:86: -1- AC_SUBST([LIBS]) -m4trace:configure.ac:86: -1- AC_SUBST_TRACE([LIBS]) -m4trace:configure.ac:86: -1- m4_pattern_allow([^LIBS$]) -m4trace:configure.ac:87: -1- AC_SUBST([CPPFLAGS]) -m4trace:configure.ac:87: -1- AC_SUBST_TRACE([CPPFLAGS]) -m4trace:configure.ac:87: -1- m4_pattern_allow([^CPPFLAGS$]) -m4trace:configure.ac:93: -1- AC_SUBST([QUIET_COMPILE]) -m4trace:configure.ac:93: -1- AC_SUBST_TRACE([QUIET_COMPILE]) -m4trace:configure.ac:93: -1- m4_pattern_allow([^QUIET_COMPILE$]) -m4trace:configure.ac:99: -1- AC_SUBST([STRICT_CFLAGS]) -m4trace:configure.ac:99: -1- AC_SUBST_TRACE([STRICT_CFLAGS]) -m4trace:configure.ac:99: -1- m4_pattern_allow([^STRICT_CFLAGS$]) -m4trace:configure.ac:105: -1- AC_SUBST([AE_DEBUG]) -m4trace:configure.ac:105: -1- AC_SUBST_TRACE([AE_DEBUG]) -m4trace:configure.ac:105: -1- m4_pattern_allow([^AE_DEBUG$]) -m4trace:configure.ac:112: -1- AC_SUBST([ENABLE_COVERAGE]) -m4trace:configure.ac:112: -1- AC_SUBST_TRACE([ENABLE_COVERAGE]) -m4trace:configure.ac:112: -1- m4_pattern_allow([^ENABLE_COVERAGE$]) -m4trace:configure.ac:127: -1- AC_SUBST([LIBCFLAGS]) -m4trace:configure.ac:127: -1- AC_SUBST_TRACE([LIBCFLAGS]) -m4trace:configure.ac:127: -1- m4_pattern_allow([^LIBCFLAGS$]) -m4trace:configure.ac:128: -1- AC_SUBST([THREAD_LIB]) -m4trace:configure.ac:128: -1- AC_SUBST_TRACE([THREAD_LIB]) -m4trace:configure.ac:128: -1- m4_pattern_allow([^THREAD_LIB$]) -m4trace:configure.ac:130: -1- AC_SUBST([TRITON_SQLITE_INCLUDES]) -m4trace:configure.ac:130: -1- AC_SUBST_TRACE([TRITON_SQLITE_INCLUDES]) -m4trace:configure.ac:130: -1- m4_pattern_allow([^TRITON_SQLITE_INCLUDES$]) -m4trace:configure.ac:130: -1- AC_SUBST([TRITON_SQLITE_LIBS]) -m4trace:configure.ac:130: -1- AC_SUBST_TRACE([TRITON_SQLITE_LIBS]) -m4trace:configure.ac:130: -1- m4_pattern_allow([^TRITON_SQLITE_LIBS$]) -m4trace:configure.ac:130: -1- AC_SUBST([BUILD_OSD]) -m4trace:configure.ac:130: -1- AC_SUBST_TRACE([BUILD_OSD]) -m4trace:configure.ac:130: -1- m4_pattern_allow([^BUILD_OSD$]) -m4trace:configure.ac:138: -1- AC_CONFIG_FILES([Makefile -src/common/module.mk -src/common/tests/module.mk -src/common/resources/timer/test/module.mk -src/common/resources/timer/module.mk -src/common/resources/scheduling/module.mk -src/common/resources/scheduling/test/module.mk -src/net/module.mk -src/net/mpi/module.mk -src/net/mpi/test/module.mk -src/remote/module.mk -src/aesop/module.mk -src/aesop/parser/module.mk -src/aesop/examples/module.mk -src/aesop/parser/tests/remote/module.mk -src/aesop/parser/tests/blocking/module.mk]) -m4trace:configure.ac:138: -1- _m4_warn([obsolete], [AC_OUTPUT should be used without arguments. -You should run autoupdate.], []) -m4trace:configure.ac:138: -1- AC_SUBST([LIB@&t@OBJS], [$ac_libobjs]) -m4trace:configure.ac:138: -1- AC_SUBST_TRACE([LIB@&t@OBJS]) -m4trace:configure.ac:138: -1- m4_pattern_allow([^LIB@&t@OBJS$]) -m4trace:configure.ac:138: -1- AC_SUBST([LTLIBOBJS], [$ac_ltlibobjs]) -m4trace:configure.ac:138: -1- AC_SUBST_TRACE([LTLIBOBJS]) -m4trace:configure.ac:138: -1- m4_pattern_allow([^LTLIBOBJS$]) -m4trace:configure.ac:138: -1- AC_SUBST_TRACE([top_builddir]) -m4trace:configure.ac:138: -1- AC_SUBST_TRACE([srcdir]) -m4trace:configure.ac:138: -1- AC_SUBST_TRACE([abs_srcdir]) -m4trace:configure.ac:138: -1- AC_SUBST_TRACE([top_srcdir]) -m4trace:configure.ac:138: -1- AC_SUBST_TRACE([abs_top_srcdir]) -m4trace:configure.ac:138: -1- AC_SUBST_TRACE([builddir]) -m4trace:configure.ac:138: -1- AC_SUBST_TRACE([abs_builddir]) -m4trace:configure.ac:138: -1- AC_SUBST_TRACE([abs_top_builddir]) -m4trace:configure.ac:138: -1- AC_SUBST_TRACE([INSTALL]) hooks/post-receive -- Triton Repository
participants (1)
noreply@mcs.anl.gov
