[mrepo] changes to warehouse13.mcs.anl.gov (new: 143, removed: 119)
The following changes to mrepo's repositories on warehouse13.mcs.anl.gov have been made: Dist: CentOS 5.10 (i386) (centos-5.10-i386) Repo: epel - duply-1.5.11-1.el5.noarch.rpm (37 kiB) - perl-No-Worries-1.0-1.el5.noarch.rpm (86 kiB) Dist: CentOS 5.10 (x86_64) (centos-5.10-x86_64) Repo: epel - duply-1.5.11-1.el5.noarch.rpm (37 kiB) - perl-No-Worries-1.0-1.el5.noarch.rpm (86 kiB) Dist: CentOS 6.5 (x86_64) (centos-6.5-x86_64) Repo: epel + 2ping-2.0-2.el6.noarch.rpm (33 kiB) + duply-1.6.0-1.el6.noarch.rpm (38 kiB) + emacs-gambit-4.7.2-1.el6.noarch.rpm (23 kiB) + emacs-gambit-el-4.7.2-1.el6.noarch.rpm (12 kiB) + gambit-c-4.7.2-1.el6.x86_64.rpm (5047 kiB) + gambit-c-doc-4.7.2-1.el6.noarch.rpm (1092 kiB) + libpng10-1.0.61-1.el6.i686.rpm (130 kiB) + libpng10-1.0.61-1.el6.x86_64.rpm (128 kiB) + libpng10-devel-1.0.61-1.el6.i686.rpm (102 kiB) + libpng10-devel-1.0.61-1.el6.x86_64.rpm (102 kiB) + nfdump-1.6.11-1.el6.x86_64.rpm (365 kiB) + perl-No-Worries-1.1-1.el6.noarch.rpm (86 kiB) + perl-Test-Carp-0.2-2.el6.noarch.rpm (21 kiB) + perl-pmtools-2.0.0-1.el6.noarch.rpm (104 kiB) + python-nose-parameterized-0.3.3-2.el6.noarch.rpm (23 kiB) + python-rosdep-0.10.25-1.el6.noarch.rpm (99 kiB) + python-rosdistro-0.3.4-1.el6.noarch.rpm (107 kiB) + python-vcstools-0.1.32-1.el6.noarch.rpm (96 kiB) + qt5-assistant-5.2.1-1.el6.x86_64.rpm (742 kiB) + qt5-designer-plugin-webkit-5.2.1-1.el6.i686.rpm (12 kiB) + qt5-designer-plugin-webkit-5.2.1-1.el6.x86_64.rpm (12 kiB) + qt5-qdbusviewer-5.2.1-1.el6.x86_64.rpm (51 kiB) + qt5-qtbase-5.2.1-2.el6.i686.rpm (3200 kiB) + qt5-qtbase-5.2.1-2.el6.x86_64.rpm (3198 kiB) + qt5-qtbase-devel-5.2.1-2.el6.i686.rpm (4832 kiB) + qt5-qtbase-devel-5.2.1-2.el6.x86_64.rpm (4743 kiB) + qt5-qtbase-doc-5.2.1-2.el6.noarch.rpm (50610 kiB) + qt5-qtbase-examples-5.2.1-2.el6.x86_64.rpm (5323 kiB) + qt5-qtbase-gui-5.2.1-2.el6.i686.rpm (4865 kiB) + qt5-qtbase-gui-5.2.1-2.el6.x86_64.rpm (4765 kiB) + qt5-qtbase-mysql-5.2.1-2.el6.i686.rpm (32 kiB) + qt5-qtbase-mysql-5.2.1-2.el6.x86_64.rpm (32 kiB) + qt5-qtbase-odbc-5.2.1-2.el6.i686.rpm (48 kiB) + qt5-qtbase-odbc-5.2.1-2.el6.x86_64.rpm (46 kiB) + qt5-qtbase-postgresql-5.2.1-2.el6.i686.rpm (35 kiB) + qt5-qtbase-postgresql-5.2.1-2.el6.x86_64.rpm (35 kiB) + qt5-qtbase-static-5.2.1-2.el6.i686.rpm (1157 kiB) + qt5-qtbase-static-5.2.1-2.el6.x86_64.rpm (1127 kiB) + qt5-qtconnectivity-5.2.1-1.el6.i686.rpm (214 kiB) + qt5-qtconnectivity-5.2.1-1.el6.x86_64.rpm (212 kiB) + qt5-qtconnectivity-devel-5.2.1-1.el6.i686.rpm (50 kiB) + qt5-qtconnectivity-devel-5.2.1-1.el6.x86_64.rpm (51 kiB) + qt5-qtconnectivity-doc-5.2.1-1.el6.noarch.rpm (1130 kiB) + qt5-qtconnectivity-examples-5.2.1-1.el6.x86_64.rpm (168 kiB) + qt5-qtdeclarative-5.2.1-1.el6.i686.rpm (4057 kiB) + qt5-qtdeclarative-5.2.1-1.el6.x86_64.rpm (2723 kiB) + qt5-qtdeclarative-devel-5.2.1-1.el6.i686.rpm (579 kiB) + qt5-qtdeclarative-devel-5.2.1-1.el6.x86_64.rpm (572 kiB) + qt5-qtdeclarative-doc-5.2.1-1.el6.noarch.rpm (17583 kiB) + qt5-qtdeclarative-examples-5.2.1-1.el6.x86_64.rpm (18194 kiB) + qt5-qtdeclarative-static-5.2.1-1.el6.i686.rpm (71 kiB) + qt5-qtdeclarative-static-5.2.1-1.el6.x86_64.rpm (69 kiB) + qt5-qtdoc-5.2.1-1.el6.noarch.rpm (5238 kiB) + qt5-qtgraphicaleffects-5.2.1-1.el6.i686.rpm (56 kiB) + qt5-qtgraphicaleffects-5.2.1-1.el6.x86_64.rpm (56 kiB) + qt5-qtgraphicaleffects-doc-5.2.1-1.el6.noarch.rpm (29316 kiB) + qt5-qtimageformats-5.2.1-1.el6.i686.rpm (47 kiB) + qt5-qtimageformats-5.2.1-1.el6.x86_64.rpm (47 kiB) + qt5-qtimageformats-devel-5.2.1-1.el6.i686.rpm (4 kiB) + qt5-qtimageformats-devel-5.2.1-1.el6.x86_64.rpm (4 kiB) + qt5-qtimageformats-doc-5.2.1-1.el6.noarch.rpm (37 kiB) + qt5-qtlocation-5.2.1-1.el6.i686.rpm (148 kiB) + qt5-qtlocation-5.2.1-1.el6.x86_64.rpm (146 kiB) + qt5-qtlocation-devel-5.2.1-1.el6.i686.rpm (22 kiB) + qt5-qtlocation-devel-5.2.1-1.el6.x86_64.rpm (22 kiB) + qt5-qtlocation-doc-5.2.1-1.el6.noarch.rpm (606 kiB) + qt5-qtlocation-examples-5.2.1-1.el6.x86_64.rpm (1704 kiB) + qt5-qtmultimedia-5.2.1-1.el6.i686.rpm (577 kiB) + qt5-qtmultimedia-5.2.1-1.el6.x86_64.rpm (563 kiB) + qt5-qtmultimedia-devel-5.2.1-1.el6.i686.rpm (91 kiB) + qt5-qtmultimedia-devel-5.2.1-1.el6.x86_64.rpm (91 kiB) + qt5-qtmultimedia-doc-5.2.1-1.el6.noarch.rpm (5680 kiB) + qt5-qtmultimedia-examples-5.2.1-1.el6.x86_64.rpm (683 kiB) + qt5-qtquick1-5.2.1-1.el6.i686.rpm (1331 kiB) + qt5-qtquick1-5.2.1-1.el6.x86_64.rpm (1306 kiB) + qt5-qtquick1-devel-5.2.1-1.el6.i686.rpm (149 kiB) + qt5-qtquick1-devel-5.2.1-1.el6.x86_64.rpm (149 kiB) + qt5-qtquick1-examples-5.2.1-1.el6.i686.rpm (4786 kiB) + qt5-qtquick1-examples-5.2.1-1.el6.x86_64.rpm (4865 kiB) + qt5-qtquickcontrols-5.2.1-1.el6.i686.rpm (422 kiB) + qt5-qtquickcontrols-5.2.1-1.el6.x86_64.rpm (419 kiB) + qt5-qtquickcontrols-doc-5.2.1-1.el6.noarch.rpm (1060 kiB) + qt5-qtscript-5.2.1-1.el6.i686.rpm (995 kiB) + qt5-qtscript-5.2.1-1.el6.x86_64.rpm (946 kiB) + qt5-qtscript-devel-5.2.1-1.el6.i686.rpm (78 kiB) + qt5-qtscript-devel-5.2.1-1.el6.x86_64.rpm (78 kiB) + qt5-qtscript-doc-5.2.1-1.el6.noarch.rpm (648 kiB) + qt5-qtscript-examples-5.2.1-1.el6.x86_64.rpm (440 kiB) + qt5-qtsensors-5.2.1-1.el6.i686.rpm (165 kiB) + qt5-qtsensors-5.2.1-1.el6.x86_64.rpm (161 kiB) + qt5-qtsensors-devel-5.2.1-1.el6.i686.rpm (34 kiB) + qt5-qtsensors-devel-5.2.1-1.el6.x86_64.rpm (33 kiB) + qt5-qtsensors-doc-5.2.1-1.el6.noarch.rpm (3772 kiB) + qt5-qtsensors-examples-5.2.1-1.el6.x86_64.rpm (203 kiB) + qt5-qtserialport-5.2.1-1.el6.i686.rpm (55 kiB) + qt5-qtserialport-5.2.1-1.el6.x86_64.rpm (54 kiB) + qt5-qtserialport-devel-5.2.1-1.el6.i686.rpm (20 kiB) + qt5-qtserialport-devel-5.2.1-1.el6.x86_64.rpm (20 kiB) + qt5-qtserialport-doc-5.2.1-1.el6.noarch.rpm (476 kiB) + qt5-qtsvg-5.2.1-1.el6.i686.rpm (148 kiB) + qt5-qtsvg-5.2.1-1.el6.x86_64.rpm (148 kiB) + qt5-qtsvg-devel-5.2.1-1.el6.i686.rpm (22 kiB) + qt5-qtsvg-devel-5.2.1-1.el6.x86_64.rpm (22 kiB) + qt5-qtsvg-doc-5.2.1-1.el6.noarch.rpm (253 kiB) + qt5-qtsvg-examples-5.2.1-1.el6.x86_64.rpm (1301 kiB) + qt5-qttools-5.2.1-1.el6.i686.rpm (3892 kiB) + qt5-qttools-5.2.1-1.el6.x86_64.rpm (3831 kiB) + qt5-qttools-devel-5.2.1-1.el6.i686.rpm (1487 kiB) + qt5-qttools-devel-5.2.1-1.el6.x86_64.rpm (1454 kiB) + qt5-qttools-doc-5.2.1-1.el6.noarch.rpm (6942 kiB) + qt5-qttools-examples-5.2.1-1.el6.x86_64.rpm (716 kiB) + qt5-qttools-static-5.2.1-1.el6.i686.rpm (199 kiB) + qt5-qttools-static-5.2.1-1.el6.x86_64.rpm (194 kiB) + qt5-qttranslations-5.2.1-1.el6.noarch.rpm (1277 kiB) + qt5-qtwebkit-5.2.1-1.el6.i686.rpm (9425 kiB) + qt5-qtwebkit-5.2.1-1.el6.x86_64.rpm (9306 kiB) + qt5-qtwebkit-devel-5.2.1-1.el6.i686.rpm (52 kiB) + qt5-qtwebkit-devel-5.2.1-1.el6.x86_64.rpm (52 kiB) + qt5-qtwebkit-doc-5.2.1-1.el6.noarch.rpm (418 kiB) + qt5-qtx11extras-5.2.1-1.el6.i686.rpm (27 kiB) + qt5-qtx11extras-5.2.1-1.el6.x86_64.rpm (27 kiB) + qt5-qtx11extras-devel-5.2.1-1.el6.i686.rpm (10 kiB) + qt5-qtx11extras-devel-5.2.1-1.el6.x86_64.rpm (10 kiB) + qt5-qtxmlpatterns-5.2.1-1.el6.i686.rpm (1185 kiB) + qt5-qtxmlpatterns-5.2.1-1.el6.x86_64.rpm (1179 kiB) + qt5-qtxmlpatterns-devel-5.2.1-1.el6.i686.rpm (334 kiB) + qt5-qtxmlpatterns-devel-5.2.1-1.el6.x86_64.rpm (334 kiB) + qt5-qtxmlpatterns-doc-5.2.1-1.el6.noarch.rpm (1231 kiB) + qt5-qtxmlpatterns-examples-5.2.1-1.el6.x86_64.rpm (65 kiB) - duply-1.5.11-1.el6.noarch.rpm (37 kiB) - emacs-gambit-4.6.6-1.el6.noarch.rpm (23 kiB) - emacs-gambit-el-4.6.6-1.el6.noarch.rpm (11 kiB) - gambit-c-4.6.6-1.el6.x86_64.rpm (4632 kiB) - gambit-c-doc-4.6.6-1.el6.noarch.rpm (1091 kiB) - libpng10-1.0.59-1.el6.i686.rpm (127 kiB) - libpng10-1.0.59-1.el6.x86_64.rpm (125 kiB) - libpng10-devel-1.0.59-1.el6.i686.rpm (99 kiB) - libpng10-devel-1.0.59-1.el6.x86_64.rpm (99 kiB) - perl-No-Worries-1.0-1.el6.noarch.rpm (84 kiB) - perl-pmtools-1.54-2.el6.noarch.rpm (102 kiB) - python-vcstools-0.1.30-1.20130318git963c121.el6.noarch.rpm (90 kiB) - qt5-assistant-5.2.0-1.el6.x86_64.rpm (742 kiB) - qt5-designer-plugin-webkit-5.2.0-1.el6.i686.rpm (12 kiB) - qt5-designer-plugin-webkit-5.2.0-1.el6.x86_64.rpm (12 kiB) - qt5-qdbusviewer-5.2.0-1.el6.x86_64.rpm (50 kiB) - qt5-qtbase-5.2.0-1.el6.i686.rpm (3197 kiB) - qt5-qtbase-5.2.0-1.el6.x86_64.rpm (3195 kiB) - qt5-qtbase-devel-5.2.0-1.el6.i686.rpm (4827 kiB) - qt5-qtbase-devel-5.2.0-1.el6.x86_64.rpm (4738 kiB) - qt5-qtbase-doc-5.2.0-1.el6.noarch.rpm (50534 kiB) - qt5-qtbase-gui-5.2.0-1.el6.i686.rpm (4850 kiB) - qt5-qtbase-gui-5.2.0-1.el6.x86_64.rpm (4750 kiB) - qt5-qtbase-ibase-5.2.0-1.el6.i686.rpm (44 kiB) - qt5-qtbase-ibase-5.2.0-1.el6.x86_64.rpm (42 kiB) - qt5-qtbase-mysql-5.2.0-1.el6.i686.rpm (31 kiB) - qt5-qtbase-mysql-5.2.0-1.el6.x86_64.rpm (31 kiB) - qt5-qtbase-odbc-5.2.0-1.el6.i686.rpm (46 kiB) - qt5-qtbase-odbc-5.2.0-1.el6.x86_64.rpm (45 kiB) - qt5-qtbase-postgresql-5.2.0-1.el6.i686.rpm (33 kiB) - qt5-qtbase-postgresql-5.2.0-1.el6.x86_64.rpm (33 kiB) - qt5-qtbase-static-5.2.0-1.el6.i686.rpm (1154 kiB) - qt5-qtbase-static-5.2.0-1.el6.x86_64.rpm (1124 kiB) - qt5-qtbase-tds-5.2.0-1.el6.i686.rpm (26 kiB) - qt5-qtbase-tds-5.2.0-1.el6.x86_64.rpm (26 kiB) - qt5-qtconnectivity-5.2.0-1.el6.i686.rpm (209 kiB) - qt5-qtconnectivity-5.2.0-1.el6.x86_64.rpm (206 kiB) - qt5-qtconnectivity-devel-5.2.0-1.el6.i686.rpm (50 kiB) - qt5-qtconnectivity-devel-5.2.0-1.el6.x86_64.rpm (50 kiB) - qt5-qtconnectivity-doc-5.2.0-1.el6.noarch.rpm (1130 kiB) - qt5-qtdeclarative-5.2.0-2.el6.i686.rpm (4011 kiB) - qt5-qtdeclarative-5.2.0-2.el6.x86_64.rpm (2698 kiB) - qt5-qtdeclarative-devel-5.2.0-2.el6.i686.rpm (576 kiB) - qt5-qtdeclarative-devel-5.2.0-2.el6.x86_64.rpm (569 kiB) - qt5-qtdeclarative-doc-5.2.0-2.el6.noarch.rpm (17530 kiB) - qt5-qtdeclarative-static-5.2.0-2.el6.i686.rpm (71 kiB) - qt5-qtdeclarative-static-5.2.0-2.el6.x86_64.rpm (69 kiB) - qt5-qtdoc-5.2.0-1.el6.noarch.rpm (5237 kiB) - qt5-qtgraphicaleffects-5.2.0-1.el6.i686.rpm (55 kiB) - qt5-qtgraphicaleffects-5.2.0-1.el6.x86_64.rpm (55 kiB) - qt5-qtgraphicaleffects-doc-5.2.0-1.el6.noarch.rpm (29547 kiB) - qt5-qtimageformats-5.2.0-1.el6.i686.rpm (47 kiB) - qt5-qtimageformats-5.2.0-1.el6.x86_64.rpm (47 kiB) - qt5-qtimageformats-devel-5.2.0-1.el6.i686.rpm (4 kiB) - qt5-qtimageformats-devel-5.2.0-1.el6.x86_64.rpm (4 kiB) - qt5-qtimageformats-doc-5.2.0-1.el6.noarch.rpm (37 kiB) - qt5-qtlocation-5.2.0-1.el6.i686.rpm (148 kiB) - qt5-qtlocation-5.2.0-1.el6.x86_64.rpm (145 kiB) - qt5-qtlocation-devel-5.2.0-1.el6.i686.rpm (22 kiB) - qt5-qtlocation-devel-5.2.0-1.el6.x86_64.rpm (22 kiB) - qt5-qtlocation-doc-5.2.0-1.el6.noarch.rpm (597 kiB) - qt5-qtmultimedia-5.2.0-1.el6.i686.rpm (576 kiB) - qt5-qtmultimedia-5.2.0-1.el6.x86_64.rpm (562 kiB) - qt5-qtmultimedia-devel-5.2.0-1.el6.i686.rpm (91 kiB) - qt5-qtmultimedia-devel-5.2.0-1.el6.x86_64.rpm (91 kiB) - qt5-qtmultimedia-doc-5.2.0-1.el6.noarch.rpm (5679 kiB) - qt5-qtquick1-5.2.0-1.el6.i686.rpm (1331 kiB) - qt5-qtquick1-5.2.0-1.el6.x86_64.rpm (1305 kiB) - qt5-qtquick1-devel-5.2.0-1.el6.i686.rpm (149 kiB) - qt5-qtquick1-devel-5.2.0-1.el6.x86_64.rpm (149 kiB) - qt5-qtquickcontrols-5.2.0-1.el6.i686.rpm (421 kiB) - qt5-qtquickcontrols-5.2.0-1.el6.x86_64.rpm (418 kiB) - qt5-qtquickcontrols-doc-5.2.0-1.el6.noarch.rpm (1074 kiB) - qt5-qtscript-5.2.0-1.el6.i686.rpm (995 kiB) - qt5-qtscript-5.2.0-1.el6.x86_64.rpm (945 kiB) - qt5-qtscript-devel-5.2.0-1.el6.i686.rpm (78 kiB) - qt5-qtscript-devel-5.2.0-1.el6.x86_64.rpm (78 kiB) - qt5-qtscript-doc-5.2.0-1.el6.noarch.rpm (648 kiB) - qt5-qtsensors-5.2.0-1.el6.i686.rpm (162 kiB) - qt5-qtsensors-5.2.0-1.el6.x86_64.rpm (159 kiB) - qt5-qtsensors-devel-5.2.0-1.el6.i686.rpm (33 kiB) - qt5-qtsensors-devel-5.2.0-1.el6.x86_64.rpm (33 kiB) - qt5-qtsensors-doc-5.2.0-1.el6.noarch.rpm (3785 kiB) - qt5-qtserialport-5.2.0-1.el6.i686.rpm (52 kiB) - qt5-qtserialport-5.2.0-1.el6.x86_64.rpm (51 kiB) - qt5-qtserialport-devel-5.2.0-1.el6.i686.rpm (20 kiB) - qt5-qtserialport-devel-5.2.0-1.el6.x86_64.rpm (20 kiB) - qt5-qtserialport-doc-5.2.0-1.el6.noarch.rpm (466 kiB) - qt5-qtsvg-5.2.0-1.el6.i686.rpm (147 kiB) - qt5-qtsvg-5.2.0-1.el6.x86_64.rpm (148 kiB) - qt5-qtsvg-devel-5.2.0-1.el6.i686.rpm (21 kiB) - qt5-qtsvg-devel-5.2.0-1.el6.x86_64.rpm (21 kiB) - qt5-qtsvg-doc-5.2.0-1.el6.noarch.rpm (254 kiB) - qt5-qttools-5.2.0-1.el6.i686.rpm (3888 kiB) - qt5-qttools-5.2.0-1.el6.x86_64.rpm (3830 kiB) - qt5-qttools-devel-5.2.0-1.el6.i686.rpm (1463 kiB) - qt5-qttools-devel-5.2.0-1.el6.x86_64.rpm (1429 kiB) - qt5-qttools-doc-5.2.0-1.el6.noarch.rpm (6806 kiB) - qt5-qttools-static-5.2.0-1.el6.i686.rpm (198 kiB) - qt5-qttools-static-5.2.0-1.el6.x86_64.rpm (193 kiB) - qt5-qttranslations-5.2.0-1.el6.noarch.rpm (1277 kiB) - qt5-qtwebkit-5.2.0-1.el6.i686.rpm (9425 kiB) - qt5-qtwebkit-5.2.0-1.el6.x86_64.rpm (9306 kiB) - qt5-qtwebkit-devel-5.2.0-1.el6.i686.rpm (52 kiB) - qt5-qtwebkit-devel-5.2.0-1.el6.x86_64.rpm (52 kiB) - qt5-qtwebkit-doc-5.2.0-1.el6.noarch.rpm (418 kiB) - qt5-qtx11extras-5.2.0-1.el6.i686.rpm (27 kiB) - qt5-qtx11extras-5.2.0-1.el6.x86_64.rpm (27 kiB) - qt5-qtx11extras-devel-5.2.0-1.el6.i686.rpm (10 kiB) - qt5-qtx11extras-devel-5.2.0-1.el6.x86_64.rpm (10 kiB) - qt5-qtxmlpatterns-5.2.0-1.el6.i686.rpm (1185 kiB) - qt5-qtxmlpatterns-5.2.0-1.el6.x86_64.rpm (1178 kiB) - qt5-qtxmlpatterns-devel-5.2.0-1.el6.i686.rpm (334 kiB) - qt5-qtxmlpatterns-devel-5.2.0-1.el6.x86_64.rpm (334 kiB) - qt5-qtxmlpatterns-doc-5.2.0-1.el6.noarch.rpm (1230 kiB) Repo: extras + bakefile-0.2.8-3.el6.centos.x86_64.rpm (250 kiB) + centos-release-SCL-6-5.el6.centos.x86_64.rpm (3 kiB) + centos-release-cr-6-0.el6.centos.x86_64.rpm (3 kiB) + centos-release-xen-6-2.el6.centos.x86_64.rpm (3 kiB) + freenx-0.7.3-9.4.el6.centos.x86_64.rpm (96 kiB) + jfsutils-1.1.13-9.el6.x86_64.rpm (238 kiB) + nx-3.5.0-2.1.el6.centos.x86_64.rpm (2742 kiB) + opennx-0.16-724.el6.centos.1.x86_64.rpm (1215 kiB) + python-empy-3.3-5.el6.centos.noarch.rpm (102 kiB) + wxBase-2.8.12-1.el6.centos.x86_64.rpm (572 kiB) + wxGTK-2.8.12-1.el6.centos.x86_64.rpm (3009 kiB) + wxGTK-devel-2.8.12-1.el6.centos.x86_64.rpm (981 kiB) + wxGTK-gl-2.8.12-1.el6.centos.x86_64.rpm (31 kiB) + wxGTK-media-2.8.12-1.el6.centos.x86_64.rpm (37 kiB)
participants (1)
mrepoï¼ warehouse13.mcs.anl.gov
