[mrepo] changes to warehouse13.mcs.anl.gov (new: 120, removed: 92)
The following changes to mrepo's repositories on warehouse13.mcs.anl.gov have been made: Dist: CentOS 5.9 (x86_64) (centos-5.9-x86_64) Repo: epel + erfa-1.0.1-1.el5.1.i386.rpm (124 kiB) + erfa-1.0.1-1.el5.1.x86_64.rpm (126 kiB) + erfa-devel-1.0.1-1.el5.1.i386.rpm (8 kiB) + erfa-devel-1.0.1-1.el5.1.x86_64.rpm (8 kiB) + salt-0.17.2-2.el5.noarch.rpm (2450 kiB) + salt-master-0.17.2-2.el5.noarch.rpm (31 kiB) + salt-minion-0.17.2-2.el5.noarch.rpm (19 kiB) + xrootd-3.3.4-1.el5.x86_64.rpm (518 kiB) + xrootd-client-3.3.4-1.el5.x86_64.rpm (207 kiB) + xrootd-client-admin-perl-3.3.4-1.el5.x86_64.rpm (28 kiB) + xrootd-client-devel-3.3.4-1.el5.i386.rpm (50 kiB) + xrootd-client-devel-3.3.4-1.el5.x86_64.rpm (50 kiB) + xrootd-client-libs-3.3.4-1.el5.i386.rpm (511 kiB) + xrootd-client-libs-3.3.4-1.el5.x86_64.rpm (504 kiB) + xrootd-devel-3.3.4-1.el5.i386.rpm (88 kiB) + xrootd-devel-3.3.4-1.el5.x86_64.rpm (88 kiB) + xrootd-doc-3.3.4-1.el5.x86_64.rpm (2135 kiB) + xrootd-fuse-3.3.4-1.el5.x86_64.rpm (18 kiB) + xrootd-libs-3.3.4-1.el5.i386.rpm (536 kiB) + xrootd-libs-3.3.4-1.el5.x86_64.rpm (550 kiB) + xrootd-private-devel-3.3.4-1.el5.i386.rpm (36 kiB) + xrootd-private-devel-3.3.4-1.el5.x86_64.rpm (36 kiB) + xrootd-server-devel-3.3.4-1.el5.i386.rpm (23 kiB) + xrootd-server-devel-3.3.4-1.el5.x86_64.rpm (23 kiB) + xrootd-server-libs-3.3.4-1.el5.i386.rpm (350 kiB) + xrootd-server-libs-3.3.4-1.el5.x86_64.rpm (351 kiB) - salt-0.17.1-1.el5.noarch.rpm (2422 kiB) - salt-master-0.17.1-1.el5.noarch.rpm (30 kiB) - salt-minion-0.17.1-1.el5.noarch.rpm (19 kiB) - xrootd-3.3.3-1.el5.x86_64.rpm (517 kiB) - xrootd-client-3.3.3-1.el5.x86_64.rpm (207 kiB) - xrootd-client-admin-perl-3.3.3-1.el5.x86_64.rpm (28 kiB) - xrootd-client-devel-3.3.3-1.el5.i386.rpm (50 kiB) - xrootd-client-devel-3.3.3-1.el5.x86_64.rpm (50 kiB) - xrootd-client-libs-3.3.3-1.el5.i386.rpm (511 kiB) - xrootd-client-libs-3.3.3-1.el5.x86_64.rpm (504 kiB) - xrootd-devel-3.3.3-1.el5.i386.rpm (87 kiB) - xrootd-devel-3.3.3-1.el5.x86_64.rpm (88 kiB) - xrootd-doc-3.3.3-1.el5.x86_64.rpm (2135 kiB) - xrootd-fuse-3.3.3-1.el5.x86_64.rpm (18 kiB) - xrootd-libs-3.3.3-1.el5.i386.rpm (534 kiB) - xrootd-libs-3.3.3-1.el5.x86_64.rpm (548 kiB) - xrootd-private-devel-3.3.3-1.el5.i386.rpm (36 kiB) - xrootd-private-devel-3.3.3-1.el5.x86_64.rpm (36 kiB) - xrootd-server-devel-3.3.3-1.el5.i386.rpm (23 kiB) - xrootd-server-devel-3.3.3-1.el5.x86_64.rpm (23 kiB) - xrootd-server-libs-3.3.3-1.el5.i386.rpm (350 kiB) - xrootd-server-libs-3.3.3-1.el5.x86_64.rpm (351 kiB) Dist: CentOS 6.3 (x86_64) (centos-6.3-x86_64) Repo: epel + erfa-1.0.1-1.el6.i686.rpm (113 kiB) + erfa-1.0.1-1.el6.x86_64.rpm (114 kiB) + erfa-devel-1.0.1-1.el6.i686.rpm (9 kiB) + erfa-devel-1.0.1-1.el6.x86_64.rpm (9 kiB) + guacd-0.8.3-4.el6.x86_64.rpm (15 kiB) + heat-cfntools-1.2.6-1.el6.noarch.rpm (111 kiB) + libguac-0.8.3-4.el6.i686.rpm (33 kiB) + libguac-0.8.3-4.el6.x86_64.rpm (33 kiB) + libguac-client-rdp-0.8.3-4.el6.i686.rpm (30 kiB) + libguac-client-rdp-0.8.3-4.el6.x86_64.rpm (30 kiB) + libguac-client-ssh-0.8.3-4.el6.i686.rpm (23 kiB) + libguac-client-ssh-0.8.3-4.el6.x86_64.rpm (24 kiB) + libguac-client-vnc-0.8.3-4.el6.i686.rpm (11 kiB) + libguac-client-vnc-0.8.3-4.el6.x86_64.rpm (12 kiB) + libguac-devel-0.8.3-4.el6.i686.rpm (105 kiB) + libguac-devel-0.8.3-4.el6.x86_64.rpm (105 kiB) + lua-lxc-0.9.0-2.el6.x86_64.rpm (13 kiB) + lxc-0.9.0-2.el6.x86_64.rpm (78 kiB) + lxc-devel-0.9.0-2.el6.i686.rpm (19 kiB) + lxc-devel-0.9.0-2.el6.x86_64.rpm (19 kiB) + lxc-doc-0.9.0-2.el6.noarch.rpm (18 kiB) + lxc-libs-0.9.0-2.el6.i686.rpm (115 kiB) + lxc-libs-0.9.0-2.el6.x86_64.rpm (115 kiB) + lxc-templates-0.9.0-2.el6.x86_64.rpm (29 kiB) + monitorix-3.4.0-1.el6.noarch.rpm (161 kiB) + python-fsmonitor-0.1-3.el6.noarch.rpm (19 kiB) + salt-0.17.2-2.el6.noarch.rpm (2105 kiB) + salt-master-0.17.2-2.el6.noarch.rpm (31 kiB) + salt-minion-0.17.2-2.el6.noarch.rpm (20 kiB) + xrootd-3.3.4-1.el6.x86_64.rpm (373 kiB) + xrootd-client-3.3.4-1.el6.x86_64.rpm (154 kiB) + xrootd-client-admin-perl-3.3.4-1.el6.x86_64.rpm (25 kiB) + xrootd-client-devel-3.3.4-1.el6.i686.rpm (49 kiB) + xrootd-client-devel-3.3.4-1.el6.x86_64.rpm (49 kiB) + xrootd-client-libs-3.3.4-1.el6.i686.rpm (412 kiB) + xrootd-client-libs-3.3.4-1.el6.x86_64.rpm (400 kiB) + xrootd-devel-3.3.4-1.el6.i686.rpm (84 kiB) + xrootd-devel-3.3.4-1.el6.x86_64.rpm (84 kiB) + xrootd-doc-3.3.4-1.el6.noarch.rpm (4687 kiB) + xrootd-fuse-3.3.4-1.el6.x86_64.rpm (17 kiB) + xrootd-libs-3.3.4-1.el6.i686.rpm (457 kiB) + xrootd-libs-3.3.4-1.el6.x86_64.rpm (455 kiB) + xrootd-private-devel-3.3.4-1.el6.noarch.rpm (36 kiB) + xrootd-server-devel-3.3.4-1.el6.i686.rpm (23 kiB) + xrootd-server-devel-3.3.4-1.el6.x86_64.rpm (23 kiB) + xrootd-server-libs-3.3.4-1.el6.i686.rpm (300 kiB) + xrootd-server-libs-3.3.4-1.el6.x86_64.rpm (296 kiB) - guacd-0.8.3-3.el6.x86_64.rpm (15 kiB) - heat-cfntools-1.2.3-1.el6.noarch.rpm (44 kiB) - libguac-0.8.3-3.el6.i686.rpm (33 kiB) - libguac-0.8.3-3.el6.x86_64.rpm (33 kiB) - libguac-client-rdp-0.8.3-3.el6.i686.rpm (30 kiB) - libguac-client-rdp-0.8.3-3.el6.x86_64.rpm (30 kiB) - libguac-client-ssh-0.8.3-3.el6.i686.rpm (23 kiB) - libguac-client-ssh-0.8.3-3.el6.x86_64.rpm (24 kiB) - libguac-client-vnc-0.8.3-3.el6.i686.rpm (11 kiB) - libguac-client-vnc-0.8.3-3.el6.x86_64.rpm (11 kiB) - libguac-devel-0.8.3-3.el6.i686.rpm (105 kiB) - libguac-devel-0.8.3-3.el6.x86_64.rpm (105 kiB) - monitorix-3.3.1-1.el6.noarch.rpm (154 kiB) - python-fsmonitor-0.1-1.el6.noarch.rpm (18 kiB) - salt-0.17.1-1.el6.noarch.rpm (2082 kiB) - salt-master-0.17.1-1.el6.noarch.rpm (30 kiB) - salt-minion-0.17.1-1.el6.noarch.rpm (20 kiB) - xrootd-3.3.3-1.el6.x86_64.rpm (373 kiB) - xrootd-client-3.3.3-1.el6.x86_64.rpm (154 kiB) - xrootd-client-admin-perl-3.3.3-1.el6.x86_64.rpm (25 kiB) - xrootd-client-devel-3.3.3-1.el6.i686.rpm (49 kiB) - xrootd-client-devel-3.3.3-1.el6.x86_64.rpm (49 kiB) - xrootd-client-libs-3.3.3-1.el6.i686.rpm (412 kiB) - xrootd-client-libs-3.3.3-1.el6.x86_64.rpm (400 kiB) - xrootd-devel-3.3.3-1.el6.i686.rpm (84 kiB) - xrootd-devel-3.3.3-1.el6.x86_64.rpm (84 kiB) - xrootd-doc-3.3.3-1.el6.noarch.rpm (4687 kiB) - xrootd-fuse-3.3.3-1.el6.x86_64.rpm (17 kiB) - xrootd-libs-3.3.3-1.el6.i686.rpm (456 kiB) - xrootd-libs-3.3.3-1.el6.x86_64.rpm (454 kiB) - xrootd-private-devel-3.3.3-1.el6.noarch.rpm (36 kiB) - xrootd-server-devel-3.3.3-1.el6.i686.rpm (23 kiB) - xrootd-server-devel-3.3.3-1.el6.x86_64.rpm (23 kiB) - xrootd-server-libs-3.3.3-1.el6.i686.rpm (299 kiB) - xrootd-server-libs-3.3.3-1.el6.x86_64.rpm (296 kiB) Dist: CentOS 6.4 (x86_64) (centos-6.4-x86_64) Repo: epel + erfa-1.0.1-1.el6.i686.rpm (113 kiB) + erfa-1.0.1-1.el6.x86_64.rpm (114 kiB) + erfa-devel-1.0.1-1.el6.i686.rpm (9 kiB) + erfa-devel-1.0.1-1.el6.x86_64.rpm (9 kiB) + guacd-0.8.3-4.el6.x86_64.rpm (15 kiB) + heat-cfntools-1.2.6-1.el6.noarch.rpm (111 kiB) + libguac-0.8.3-4.el6.i686.rpm (33 kiB) + libguac-0.8.3-4.el6.x86_64.rpm (33 kiB) + libguac-client-rdp-0.8.3-4.el6.i686.rpm (30 kiB) + libguac-client-rdp-0.8.3-4.el6.x86_64.rpm (30 kiB) + libguac-client-ssh-0.8.3-4.el6.i686.rpm (23 kiB) + libguac-client-ssh-0.8.3-4.el6.x86_64.rpm (24 kiB) + libguac-client-vnc-0.8.3-4.el6.i686.rpm (11 kiB) + libguac-client-vnc-0.8.3-4.el6.x86_64.rpm (12 kiB) + libguac-devel-0.8.3-4.el6.i686.rpm (105 kiB) + libguac-devel-0.8.3-4.el6.x86_64.rpm (105 kiB) + lua-lxc-0.9.0-2.el6.x86_64.rpm (13 kiB) + lxc-0.9.0-2.el6.x86_64.rpm (78 kiB) + lxc-devel-0.9.0-2.el6.i686.rpm (19 kiB) + lxc-devel-0.9.0-2.el6.x86_64.rpm (19 kiB) + lxc-doc-0.9.0-2.el6.noarch.rpm (18 kiB) + lxc-libs-0.9.0-2.el6.i686.rpm (115 kiB) + lxc-libs-0.9.0-2.el6.x86_64.rpm (115 kiB) + lxc-templates-0.9.0-2.el6.x86_64.rpm (29 kiB) + monitorix-3.4.0-1.el6.noarch.rpm (161 kiB) + python-fsmonitor-0.1-3.el6.noarch.rpm (19 kiB) + salt-0.17.2-2.el6.noarch.rpm (2105 kiB) + salt-master-0.17.2-2.el6.noarch.rpm (31 kiB) + salt-minion-0.17.2-2.el6.noarch.rpm (20 kiB) + xrootd-3.3.4-1.el6.x86_64.rpm (373 kiB) + xrootd-client-3.3.4-1.el6.x86_64.rpm (154 kiB) + xrootd-client-admin-perl-3.3.4-1.el6.x86_64.rpm (25 kiB) + xrootd-client-devel-3.3.4-1.el6.i686.rpm (49 kiB) + xrootd-client-devel-3.3.4-1.el6.x86_64.rpm (49 kiB) + xrootd-client-libs-3.3.4-1.el6.i686.rpm (412 kiB) + xrootd-client-libs-3.3.4-1.el6.x86_64.rpm (400 kiB) + xrootd-devel-3.3.4-1.el6.i686.rpm (84 kiB) + xrootd-devel-3.3.4-1.el6.x86_64.rpm (84 kiB) + xrootd-doc-3.3.4-1.el6.noarch.rpm (4687 kiB) + xrootd-fuse-3.3.4-1.el6.x86_64.rpm (17 kiB) + xrootd-libs-3.3.4-1.el6.i686.rpm (457 kiB) + xrootd-libs-3.3.4-1.el6.x86_64.rpm (455 kiB) + xrootd-private-devel-3.3.4-1.el6.noarch.rpm (36 kiB) + xrootd-server-devel-3.3.4-1.el6.i686.rpm (23 kiB) + xrootd-server-devel-3.3.4-1.el6.x86_64.rpm (23 kiB) + xrootd-server-libs-3.3.4-1.el6.i686.rpm (300 kiB) + xrootd-server-libs-3.3.4-1.el6.x86_64.rpm (296 kiB) - guacd-0.8.3-3.el6.x86_64.rpm (15 kiB) - heat-cfntools-1.2.3-1.el6.noarch.rpm (44 kiB) - libguac-0.8.3-3.el6.i686.rpm (33 kiB) - libguac-0.8.3-3.el6.x86_64.rpm (33 kiB) - libguac-client-rdp-0.8.3-3.el6.i686.rpm (30 kiB) - libguac-client-rdp-0.8.3-3.el6.x86_64.rpm (30 kiB) - libguac-client-ssh-0.8.3-3.el6.i686.rpm (23 kiB) - libguac-client-ssh-0.8.3-3.el6.x86_64.rpm (24 kiB) - libguac-client-vnc-0.8.3-3.el6.i686.rpm (11 kiB) - libguac-client-vnc-0.8.3-3.el6.x86_64.rpm (11 kiB) - libguac-devel-0.8.3-3.el6.i686.rpm (105 kiB) - libguac-devel-0.8.3-3.el6.x86_64.rpm (105 kiB) - monitorix-3.3.1-1.el6.noarch.rpm (154 kiB) - python-fsmonitor-0.1-1.el6.noarch.rpm (18 kiB) - salt-0.17.1-1.el6.noarch.rpm (2082 kiB) - salt-master-0.17.1-1.el6.noarch.rpm (30 kiB) - salt-minion-0.17.1-1.el6.noarch.rpm (20 kiB) - xrootd-3.3.3-1.el6.x86_64.rpm (373 kiB) - xrootd-client-3.3.3-1.el6.x86_64.rpm (154 kiB) - xrootd-client-admin-perl-3.3.3-1.el6.x86_64.rpm (25 kiB) - xrootd-client-devel-3.3.3-1.el6.i686.rpm (49 kiB) - xrootd-client-devel-3.3.3-1.el6.x86_64.rpm (49 kiB) - xrootd-client-libs-3.3.3-1.el6.i686.rpm (412 kiB) - xrootd-client-libs-3.3.3-1.el6.x86_64.rpm (400 kiB) - xrootd-devel-3.3.3-1.el6.i686.rpm (84 kiB) - xrootd-devel-3.3.3-1.el6.x86_64.rpm (84 kiB) - xrootd-doc-3.3.3-1.el6.noarch.rpm (4687 kiB) - xrootd-fuse-3.3.3-1.el6.x86_64.rpm (17 kiB) - xrootd-libs-3.3.3-1.el6.i686.rpm (456 kiB) - xrootd-libs-3.3.3-1.el6.x86_64.rpm (454 kiB) - xrootd-private-devel-3.3.3-1.el6.noarch.rpm (36 kiB) - xrootd-server-devel-3.3.3-1.el6.i686.rpm (23 kiB) - xrootd-server-devel-3.3.3-1.el6.x86_64.rpm (23 kiB) - xrootd-server-libs-3.3.3-1.el6.i686.rpm (299 kiB) - xrootd-server-libs-3.3.3-1.el6.x86_64.rpm (296 kiB)
participants (1)
mrepoï¼ warehouse13.mcs.anl.gov
