[mrepo] changes to warehouse13.mcs.anl.gov (new: 35, removed: 0)
The following changes to mrepo's repositories on warehouse13.mcs.anl.gov have been made: Dist: CentOS 5.9 (x86_64) (centos-5.9-x86_64) Dist: CentOS 6.3 (x86_64) (centos-6.3-x86_64) Dist: CentOS 6.4 (x86_64) (centos-6.4-x86_64) Repo: updates + cmirror-2.02.98-9.el6_4.3.x86_64.rpm (126 kiB) + device-mapper-1.02.77-9.el6_4.3.x86_64.rpm (144 kiB) + device-mapper-devel-1.02.77-9.el6_4.3.i686.rpm (98 kiB) + device-mapper-devel-1.02.77-9.el6_4.3.x86_64.rpm (98 kiB) + device-mapper-event-1.02.77-9.el6_4.3.x86_64.rpm (96 kiB) + device-mapper-event-devel-1.02.77-9.el6_4.3.i686.rpm (85 kiB) + device-mapper-event-devel-1.02.77-9.el6_4.3.x86_64.rpm (85 kiB) + device-mapper-event-libs-1.02.77-9.el6_4.3.i686.rpm (91 kiB) + device-mapper-event-libs-1.02.77-9.el6_4.3.x86_64.rpm (91 kiB) + device-mapper-libs-1.02.77-9.el6_4.3.i686.rpm (170 kiB) + device-mapper-libs-1.02.77-9.el6_4.3.x86_64.rpm (172 kiB) + e2fsprogs-1.41.12-14.el6_4.4.x86_64.rpm (551 kiB) + e2fsprogs-devel-1.41.12-14.el6_4.4.i686.rpm (159 kiB) + e2fsprogs-devel-1.41.12-14.el6_4.4.x86_64.rpm (159 kiB) + e2fsprogs-libs-1.41.12-14.el6_4.4.i686.rpm (126 kiB) + e2fsprogs-libs-1.41.12-14.el6_4.4.x86_64.rpm (119 kiB) + java-1.6.0-openjdk-1.6.0.0-1.65.1.11.14.el6_4.x86_64.rpm (25829 kiB) + java-1.6.0-openjdk-demo-1.6.0.0-1.65.1.11.14.el6_4.x86_64.rpm (1996 kiB) + java-1.6.0-openjdk-devel-1.6.0.0-1.65.1.11.14.el6_4.x86_64.rpm (8904 kiB) + java-1.6.0-openjdk-javadoc-1.6.0.0-1.65.1.11.14.el6_4.x86_64.rpm (14977 kiB) + java-1.6.0-openjdk-src-1.6.0.0-1.65.1.11.14.el6_4.x86_64.rpm (39693 kiB) + libcom_err-1.41.12-14.el6_4.4.i686.rpm (36 kiB) + libcom_err-1.41.12-14.el6_4.4.x86_64.rpm (36 kiB) + libcom_err-devel-1.41.12-14.el6_4.4.i686.rpm (31 kiB) + libcom_err-devel-1.41.12-14.el6_4.4.x86_64.rpm (31 kiB) + libss-1.41.12-14.el6_4.4.i686.rpm (40 kiB) + libss-1.41.12-14.el6_4.4.x86_64.rpm (40 kiB) + libss-devel-1.41.12-14.el6_4.4.i686.rpm (35 kiB) + libss-devel-1.41.12-14.el6_4.4.x86_64.rpm (35 kiB) + lvm2-2.02.98-9.el6_4.3.x86_64.rpm (655 kiB) + lvm2-cluster-2.02.98-9.el6_4.3.x86_64.rpm (362 kiB) + lvm2-devel-2.02.98-9.el6_4.3.i686.rpm (92 kiB) + lvm2-devel-2.02.98-9.el6_4.3.x86_64.rpm (92 kiB) + lvm2-libs-2.02.98-9.el6_4.3.i686.rpm (731 kiB) + lvm2-libs-2.02.98-9.el6_4.3.x86_64.rpm (713 kiB)
participants (1)
mrepoï¼ warehouse13.mcs.anl.gov
