[mrepo] changes to warehouse13.mcs.anl.gov (new: 89, removed: 80)
The following changes to mrepo's repositories on warehouse13.mcs.anl.gov have been made: Dist: CentOS 5.9 (x86_64) (centos-5.9-x86_64) Repo: epel + canl-c-2.1.2-1.el5.i386.rpm (69 kiB) + canl-c-2.1.2-1.el5.x86_64.rpm (70 kiB) + canl-c-devel-2.1.2-1.el5.i386.rpm (6 kiB) + canl-c-devel-2.1.2-1.el5.x86_64.rpm (6 kiB) + canl-c-doc-2.1.2-1.el5.x86_64.rpm (107 kiB) + canl-c-examples-2.1.2-1.el5.x86_64.rpm (13 kiB) + munin-2.0.17-6.el5.noarch.rpm (218 kiB) + munin-async-2.0.17-6.el5.noarch.rpm (23 kiB) + munin-cgi-2.0.17-6.el5.noarch.rpm (18 kiB) + munin-common-2.0.17-6.el5.noarch.rpm (86 kiB) + munin-java-plugins-2.0.17-6.el5.noarch.rpm (84 kiB) + munin-netip-plugins-2.0.17-6.el5.noarch.rpm (21 kiB) + munin-nginx-2.0.17-6.el5.noarch.rpm (19 kiB) + munin-node-2.0.17-6.el5.noarch.rpm (422 kiB) + munin-ruby-plugins-2.0.17-6.el5.noarch.rpm (20 kiB) + perl-Test-Portability-Files-0.06-1.el5.noarch.rpm (19 kiB) + safekeep-client-1.4.2-3.el5.noarch.rpm (6 kiB) + safekeep-common-1.4.2-3.el5.noarch.rpm (40 kiB) + safekeep-server-1.4.2-3.el5.noarch.rpm (19 kiB) - munin-2.0.17-1.el5.noarch.rpm (217 kiB) - munin-async-2.0.17-1.el5.noarch.rpm (23 kiB) - munin-cgi-2.0.17-1.el5.noarch.rpm (18 kiB) - munin-common-2.0.17-1.el5.noarch.rpm (86 kiB) - munin-java-plugins-2.0.17-1.el5.noarch.rpm (83 kiB) - munin-nginx-2.0.17-1.el5.noarch.rpm (18 kiB) - munin-node-2.0.17-1.el5.noarch.rpm (424 kiB) - munin-ruby-plugins-2.0.17-1.el5.noarch.rpm (19 kiB) - perl-Test-Portability-Files-0.05-3.el5.noarch.rpm (20 kiB) - safekeep-client-1.4.2-1.el5.noarch.rpm (5 kiB) - safekeep-common-1.4.2-1.el5.noarch.rpm (39 kiB) - safekeep-server-1.4.2-1.el5.noarch.rpm (18 kiB) Dist: CentOS 6.3 (x86_64) (centos-6.3-x86_64) Repo: epel + munin-2.0.17-6.el6.noarch.rpm (194 kiB) + munin-async-2.0.17-6.el6.noarch.rpm (24 kiB) + munin-cgi-2.0.17-6.el6.noarch.rpm (19 kiB) + munin-common-2.0.17-6.el6.noarch.rpm (85 kiB) + munin-java-plugins-2.0.17-6.el6.noarch.rpm (84 kiB) + munin-netip-plugins-2.0.17-6.el6.noarch.rpm (22 kiB) + munin-nginx-2.0.17-6.el6.noarch.rpm (20 kiB) + munin-node-2.0.17-6.el6.noarch.rpm (398 kiB) + munin-ruby-plugins-2.0.17-6.el6.noarch.rpm (21 kiB) + perl-Test-Portability-Files-0.06-1.el6.noarch.rpm (20 kiB) + python-cpopen-1.2.3-2.el6.x86_64.rpm (17 kiB) + python-xml2rfc-2.4.2-4.el6.noarch.rpm (111 kiB) + safekeep-client-1.4.2-3.el6.noarch.rpm (7 kiB) + safekeep-common-1.4.2-3.el6.noarch.rpm (40 kiB) + safekeep-server-1.4.2-3.el6.noarch.rpm (20 kiB) + unbound-1.4.21-1.el6.x86_64.rpm (1084 kiB) + unbound-devel-1.4.21-1.el6.i686.rpm (34 kiB) + unbound-devel-1.4.21-1.el6.x86_64.rpm (34 kiB) + unbound-libs-1.4.21-1.el6.i686.rpm (299 kiB) + unbound-libs-1.4.21-1.el6.x86_64.rpm (298 kiB) + unbound-munin-1.4.21-1.el6.noarch.rpm (19 kiB) + unbound-python-1.4.21-1.el6.x86_64.rpm (67 kiB) + xpaint-2.9.9.4-1.el6.x86_64.rpm (814 kiB) + zabbix20-2.0.8-3.el6.x86_64.rpm (180 kiB) + zabbix20-agent-2.0.8-3.el6.x86_64.rpm (140 kiB) + zabbix20-proxy-2.0.8-3.el6.x86_64.rpm (23 kiB) + zabbix20-proxy-mysql-2.0.8-3.el6.x86_64.rpm (1398 kiB) + zabbix20-proxy-pgsql-2.0.8-3.el6.x86_64.rpm (1383 kiB) + zabbix20-proxy-sqlite3-2.0.8-3.el6.x86_64.rpm (290 kiB) + zabbix20-server-2.0.8-3.el6.x86_64.rpm (23 kiB) + zabbix20-server-mysql-2.0.8-3.el6.x86_64.rpm (1430 kiB) + zabbix20-server-pgsql-2.0.8-3.el6.x86_64.rpm (1413 kiB) + zabbix20-web-2.0.8-3.el6.noarch.rpm (3716 kiB) + zabbix20-web-mysql-2.0.8-3.el6.noarch.rpm (14 kiB) + zabbix20-web-pgsql-2.0.8-3.el6.noarch.rpm (14 kiB) - munin-2.0.17-1.el6.noarch.rpm (193 kiB) - munin-async-2.0.17-1.el6.noarch.rpm (24 kiB) - munin-cgi-2.0.17-1.el6.noarch.rpm (19 kiB) - munin-common-2.0.17-1.el6.noarch.rpm (85 kiB) - munin-java-plugins-2.0.17-1.el6.noarch.rpm (84 kiB) - munin-nginx-2.0.17-1.el6.noarch.rpm (19 kiB) - munin-node-2.0.17-1.el6.noarch.rpm (401 kiB) - munin-ruby-plugins-2.0.17-1.el6.noarch.rpm (20 kiB) - perl-Test-Portability-Files-0.05-8.el6.noarch.rpm (21 kiB) - python-cpopen-1.2.2-1.el6.x86_64.rpm (17 kiB) - safekeep-client-1.4.2-1.el6.noarch.rpm (6 kiB) - safekeep-common-1.4.2-1.el6.noarch.rpm (40 kiB) - safekeep-server-1.4.2-1.el6.noarch.rpm (20 kiB) - unbound-1.4.19-1.el6.x86_64.rpm (1060 kiB) - unbound-devel-1.4.19-1.el6.i686.rpm (32 kiB) - unbound-devel-1.4.19-1.el6.x86_64.rpm (32 kiB) - unbound-libs-1.4.19-1.el6.i686.rpm (294 kiB) - unbound-libs-1.4.19-1.el6.x86_64.rpm (293 kiB) - unbound-munin-1.4.19-1.el6.x86_64.rpm (18 kiB) - unbound-python-1.4.19-1.el6.x86_64.rpm (66 kiB) - xpaint-2.9.8.3-1.el6.i686.rpm (922 kiB) - xpaint-2.9.8.3-1.el6.x86_64.rpm (934 kiB) - zabbix20-2.0.8-2.el6.x86_64.rpm (180 kiB) - zabbix20-agent-2.0.8-2.el6.x86_64.rpm (140 kiB) - zabbix20-proxy-2.0.8-2.el6.x86_64.rpm (23 kiB) - zabbix20-proxy-mysql-2.0.8-2.el6.x86_64.rpm (1398 kiB) - zabbix20-proxy-pgsql-2.0.8-2.el6.x86_64.rpm (1383 kiB) - zabbix20-proxy-sqlite3-2.0.8-2.el6.x86_64.rpm (290 kiB) - zabbix20-server-2.0.8-2.el6.x86_64.rpm (23 kiB) - zabbix20-server-mysql-2.0.8-2.el6.x86_64.rpm (1430 kiB) - zabbix20-server-pgsql-2.0.8-2.el6.x86_64.rpm (1413 kiB) - zabbix20-web-2.0.8-2.el6.noarch.rpm (3715 kiB) - zabbix20-web-mysql-2.0.8-2.el6.noarch.rpm (14 kiB) - zabbix20-web-pgsql-2.0.8-2.el6.noarch.rpm (14 kiB) Dist: CentOS 6.4 (x86_64) (centos-6.4-x86_64) Repo: epel + munin-2.0.17-6.el6.noarch.rpm (194 kiB) + munin-async-2.0.17-6.el6.noarch.rpm (24 kiB) + munin-cgi-2.0.17-6.el6.noarch.rpm (19 kiB) + munin-common-2.0.17-6.el6.noarch.rpm (85 kiB) + munin-java-plugins-2.0.17-6.el6.noarch.rpm (84 kiB) + munin-netip-plugins-2.0.17-6.el6.noarch.rpm (22 kiB) + munin-nginx-2.0.17-6.el6.noarch.rpm (20 kiB) + munin-node-2.0.17-6.el6.noarch.rpm (398 kiB) + munin-ruby-plugins-2.0.17-6.el6.noarch.rpm (21 kiB) + perl-Test-Portability-Files-0.06-1.el6.noarch.rpm (20 kiB) + python-cpopen-1.2.3-2.el6.x86_64.rpm (17 kiB) + python-xml2rfc-2.4.2-4.el6.noarch.rpm (111 kiB) + safekeep-client-1.4.2-3.el6.noarch.rpm (7 kiB) + safekeep-common-1.4.2-3.el6.noarch.rpm (40 kiB) + safekeep-server-1.4.2-3.el6.noarch.rpm (20 kiB) + unbound-1.4.21-1.el6.x86_64.rpm (1084 kiB) + unbound-devel-1.4.21-1.el6.i686.rpm (34 kiB) + unbound-devel-1.4.21-1.el6.x86_64.rpm (34 kiB) + unbound-libs-1.4.21-1.el6.i686.rpm (299 kiB) + unbound-libs-1.4.21-1.el6.x86_64.rpm (298 kiB) + unbound-munin-1.4.21-1.el6.noarch.rpm (19 kiB) + unbound-python-1.4.21-1.el6.x86_64.rpm (67 kiB) + xpaint-2.9.9.4-1.el6.x86_64.rpm (814 kiB) + zabbix20-2.0.8-3.el6.x86_64.rpm (180 kiB) + zabbix20-agent-2.0.8-3.el6.x86_64.rpm (140 kiB) + zabbix20-proxy-2.0.8-3.el6.x86_64.rpm (23 kiB) + zabbix20-proxy-mysql-2.0.8-3.el6.x86_64.rpm (1398 kiB) + zabbix20-proxy-pgsql-2.0.8-3.el6.x86_64.rpm (1383 kiB) + zabbix20-proxy-sqlite3-2.0.8-3.el6.x86_64.rpm (290 kiB) + zabbix20-server-2.0.8-3.el6.x86_64.rpm (23 kiB) + zabbix20-server-mysql-2.0.8-3.el6.x86_64.rpm (1430 kiB) + zabbix20-server-pgsql-2.0.8-3.el6.x86_64.rpm (1413 kiB) + zabbix20-web-2.0.8-3.el6.noarch.rpm (3716 kiB) + zabbix20-web-mysql-2.0.8-3.el6.noarch.rpm (14 kiB) + zabbix20-web-pgsql-2.0.8-3.el6.noarch.rpm (14 kiB) - munin-2.0.17-1.el6.noarch.rpm (193 kiB) - munin-async-2.0.17-1.el6.noarch.rpm (24 kiB) - munin-cgi-2.0.17-1.el6.noarch.rpm (19 kiB) - munin-common-2.0.17-1.el6.noarch.rpm (85 kiB) - munin-java-plugins-2.0.17-1.el6.noarch.rpm (84 kiB) - munin-nginx-2.0.17-1.el6.noarch.rpm (19 kiB) - munin-node-2.0.17-1.el6.noarch.rpm (401 kiB) - munin-ruby-plugins-2.0.17-1.el6.noarch.rpm (20 kiB) - perl-Test-Portability-Files-0.05-8.el6.noarch.rpm (21 kiB) - python-cpopen-1.2.2-1.el6.x86_64.rpm (17 kiB) - safekeep-client-1.4.2-1.el6.noarch.rpm (6 kiB) - safekeep-common-1.4.2-1.el6.noarch.rpm (40 kiB) - safekeep-server-1.4.2-1.el6.noarch.rpm (20 kiB) - unbound-1.4.19-1.el6.x86_64.rpm (1060 kiB) - unbound-devel-1.4.19-1.el6.i686.rpm (32 kiB) - unbound-devel-1.4.19-1.el6.x86_64.rpm (32 kiB) - unbound-libs-1.4.19-1.el6.i686.rpm (294 kiB) - unbound-libs-1.4.19-1.el6.x86_64.rpm (293 kiB) - unbound-munin-1.4.19-1.el6.x86_64.rpm (18 kiB) - unbound-python-1.4.19-1.el6.x86_64.rpm (66 kiB) - xpaint-2.9.8.3-1.el6.i686.rpm (922 kiB) - xpaint-2.9.8.3-1.el6.x86_64.rpm (934 kiB) - zabbix20-2.0.8-2.el6.x86_64.rpm (180 kiB) - zabbix20-agent-2.0.8-2.el6.x86_64.rpm (140 kiB) - zabbix20-proxy-2.0.8-2.el6.x86_64.rpm (23 kiB) - zabbix20-proxy-mysql-2.0.8-2.el6.x86_64.rpm (1398 kiB) - zabbix20-proxy-pgsql-2.0.8-2.el6.x86_64.rpm (1383 kiB) - zabbix20-proxy-sqlite3-2.0.8-2.el6.x86_64.rpm (290 kiB) - zabbix20-server-2.0.8-2.el6.x86_64.rpm (23 kiB) - zabbix20-server-mysql-2.0.8-2.el6.x86_64.rpm (1430 kiB) - zabbix20-server-pgsql-2.0.8-2.el6.x86_64.rpm (1413 kiB) - zabbix20-web-2.0.8-2.el6.noarch.rpm (3715 kiB) - zabbix20-web-mysql-2.0.8-2.el6.noarch.rpm (14 kiB) - zabbix20-web-pgsql-2.0.8-2.el6.noarch.rpm (14 kiB)
participants (1)
mrepoï¼ warehouse13.mcs.anl.gov
