Logwatch for berlin.mcs.anl.gov (Linux)
################### Logwatch 7.3 (03/24/06) #################### Processing Initiated: Fri Dec 6 04:02:02 2013 Date Range Processed: yesterday ( 2013-Dec-05 ) Period is day. Detail Level of Output: 0 Type of Output: unformatted Logfiles for Host: berlin.mcs.anl.gov ################################################################## --------------------- Automount Begin ------------------------ **Unmatched Entries** key "mg" not found in map source(s).: 1 Time(s) key "prd" not found in map source(s).: 1 Time(s) key "prdpi" not found in map source(s).: 1 Time(s) key "mgp" not found in map source(s).: 1 Time(s) ---------------------- Automount End ------------------------- --------------------- httpd Begin ------------------------ A total of 1 sites probed the server 146.137.70.8 Requests with error response codes 404 Not Found /.cobalt: 1 Time(s) /ControlManager/default.htm: 1 Time(s) /FgOIVN3suMmA.asp: 1 Time(s) /FgOIVN3suMmA.cfm: 1 Time(s) /FgOIVN3suMmA.cgi: 1 Time(s) /FgOIVN3suMmA.html: 1 Time(s) /FgOIVN3suMmA.inc: 1 Time(s) /FgOIVN3suMmA.php: 1 Time(s) /FgOIVN3suMmA.php3: 1 Time(s) /FgOIVN3suMmA.pl: 1 Time(s) /FgOIVN3suMmA.sh: 1 Time(s) /FgOIVN3suMmA.shtml: 1 Time(s) /MSWSMTP/Common/Authentication/Logon.aspx: 1 Time(s) /admin.back: 1 Time(s) /cgi-bin/FgOIVN3suMmA.asp: 1 Time(s) /cgi-bin/FgOIVN3suMmA.cfm: 1 Time(s) /cgi-bin/FgOIVN3suMmA.cgi: 1 Time(s) /cgi-bin/FgOIVN3suMmA.html: 1 Time(s) /cgi-bin/FgOIVN3suMmA.inc: 1 Time(s) /cgi-bin/FgOIVN3suMmA.php: 1 Time(s) /cgi-bin/FgOIVN3suMmA.php3: 1 Time(s) /cgi-bin/FgOIVN3suMmA.pl: 1 Time(s) /cgi-bin/FgOIVN3suMmA.sh: 1 Time(s) /cgi-bin/FgOIVN3suMmA.shtml: 1 Time(s) /commoncgi/servlet/CCGIServlet?ApHost=PDT_ ... File=logout.htm: 1 Time(s) /file: 1 Time(s) /header.php?tab=status: 1 Time(s) /intruvert/jsp/admin/Login.jsp: 1 Time(s) /properties/configuration.php?tab=Status: 1 Time(s) /properties/description.dhtml: 1 Time(s) /robots.txt: 1 Time(s) /scripts/FgOIVN3suMmA.asp: 1 Time(s) /scripts/FgOIVN3suMmA.cfm: 1 Time(s) /scripts/FgOIVN3suMmA.cgi: 1 Time(s) /scripts/FgOIVN3suMmA.html: 1 Time(s) /scripts/FgOIVN3suMmA.inc: 1 Time(s) /scripts/FgOIVN3suMmA.php: 1 Time(s) /scripts/FgOIVN3suMmA.php3: 1 Time(s) /scripts/FgOIVN3suMmA.pl: 1 Time(s) /scripts/FgOIVN3suMmA.sh: 1 Time(s) /scripts/FgOIVN3suMmA.shtml: 1 Time(s) /sitemap.xml: 1 Time(s) /wavemaster.internal: 1 Time(s) /xmldata?item=All: 1 Time(s) 501 Not Implemented /: 1 Time(s) null: 1 Time(s) ---------------------- httpd End ------------------------- --------------------- pam_unix Begin ------------------------ sshd: Authentication Failures: unknown (anlscan8.cspo.anl.gov): 2 Time(s) Invalid Users: Unknown Account: 2 Time(s) su: Sessions Opened: jbischof(uid=0) -> mgrastprod: 3 Time(s) sudo: Authentication Failures: jbischof(0) -> jbischof: 7 Time(s) ---------------------- pam_unix End ------------------------- --------------------- postfix Begin ------------------------ 6845 bytes transferred 1 messages sent 1 messages removed from queue ---------------------- postfix End ------------------------- --------------------- Smartd Begin ------------------------ Currently unreadable (pending) sectors detected: /dev/sda - 48 Time(s) 2 unreadable sectors detected ---------------------- Smartd End ------------------------- --------------------- SSHD Begin ------------------------ Illegal users from: 146.137.70.8 (anlscan8.cspo.anl.gov): 2 times Postponed authentication: root/publickey: 140.221.76.5: 4 Time(s) Users logging in through sshd: jbischof: 140.221.11.19 (jbischof.mcs.anl.gov): 2 times root: 140.221.76.5 (berlin.mcs.anl.gov): 4 times tharriso: 130.202.135.155 (mcswl155.mcs.anl.gov): 2 times 192.5.200.107 (dpse.igsb.anl.gov): 1 time Received disconnect: 11: disconnected by user : 2 Time(s) **Unmatched Entries** pam_succeed_if(sshd:auth): error retrieving information about user Cisco : 1 time(s) pam_succeed_if(sshd:auth): error retrieving information about user cisco : 1 time(s) ---------------------- SSHD End ------------------------- --------------------- Sudo (secure-log) Begin ------------------------ ============================================================================== jbischof => root ------------------------------------------------------------------------------ /bin/zsh /bin/zsh /bin/zsh /bin/zsh /bin/zsh /bin/zsh -c ssh root\@dunkirk\.mcs\.anl\.gov \ \/homes\/jbischof\/MCP\/bin\/edit_nginx_config \ \/etc\/nginx\/conf\.d\/api\.metagenomics\.conf \ \/etc\/nginx\/conf\.d\/api\.metagenomics\.up /bin/zsh -c ssh root\@dunkirk\.mcs\.anl\.gov \ \/homes\/jbischof\/MCP\/bin\/edit_nginx_config \ \/etc\/nginx\/conf\.d\/metagenomics\.conf \ \/etc\/nginx\/conf\.d\/metagenomics\.up /bin/zsh -c ssh root\@berlin\.mcs\.anl\.gov \ \/homes\/jbischof\/MCP\/bin\/unlock_upload_page /bin/zsh -c ssh root\@berlin\.mcs\.anl\.gov \ \/homes\/jbischof\/MCP\/bin\/update_upload_status /bin/zsh -c ssh root\@berlin\.mcs\.anl\.gov \ \/homes\/jbischof\/MCP\/bin\/unlock_upload_page /bin/zsh -c ssh root\@berlin\.mcs\.anl\.gov \ \/homes\/jbischof\/MCP\/bin\/update_upload_status /bin/zsh /bin/zsh ---------------------- Sudo (secure-log) End ------------------------- --------------------- Disk Space Begin ------------------------ Filesystem Size Used Avail Use% Mounted on /dev/mapper/Vol0-LV00 15G 11G 3.3G 77% / /dev/md0 99M 39M 55M 42% /boot /dev/mapper/Vol0-local 1.8T 141G 1.7T 8% /local ---------------------- Disk Space End ------------------------- ###################### Logwatch End #########################
participants (1)
logwatch@mcs.anl.gov
