################### Logwatch 7.3 (03/24/06) #################### Processing Initiated: Sat Apr 5 04:02:01 2014 Date Range Processed: yesterday ( 2014-Apr-04 ) Period is day. Detail Level of Output: 0 Type of Output: unformatted Logfiles for Host: berlin.mcs.anl.gov ################################################################## --------------------- Automount Begin ------------------------ **Unmatched Entries** key "jobsf" not found in map source(s).: 1 Time(s) ---------------------- Automount End ------------------------- --------------------- pam_unix Begin ------------------------ sudo: Authentication Failures: dsouza(0) -> dsouza: 2 Time(s) jbischof(0) -> jbischof: 1 Time(s) ---------------------- pam_unix End ------------------------- --------------------- postfix Begin ------------------------ 3932 bytes transferred 1 messages sent 1 messages removed from queue ---------------------- postfix End ------------------------- --------------------- Smartd Begin ------------------------ Currently unreadable (pending) sectors detected: /dev/sda - 48 Time(s) 1 unreadable sectors detected ---------------------- Smartd End ------------------------- --------------------- SSHD Begin ------------------------ Postponed authentication: jbischof/publickey: 140.221.9.206: 1 Time(s) Users logging in through sshd: dsouza: 140.221.10.82 (dsouza.mcs.anl.gov): 2 times jbischof: 140.221.11.19 (jbischof.mcs.anl.gov): 3 times 140.221.9.206 (login4.mcs.anl.gov): 1 time tharriso: 130.202.135.155 (mcswl155.mcs.anl.gov): 1 time Received disconnect: 11: disconnected by user : 6 Time(s) **Unmatched Entries** userauth_hostbased: unsupported public key algorithm: ecdsa-sha2-nistp256 : 1 time(s) ---------------------- SSHD End ------------------------- --------------------- Sudo (secure-log) Begin ------------------------ ============================================================================== dsouza => mgrastprod ------------------------------------------------------------------------------ /bin/bash dsouza => root ------------------------------------------------------------------------------ /bin/bash ============================================================================== jbischof => root ------------------------------------------------------------------------------ /bin/zsh ---------------------- Sudo (secure-log) End ------------------------- --------------------- Disk Space Begin ------------------------ Filesystem Size Used Avail Use% Mounted on /dev/mapper/Vol0-LV00 15G 12G 2.4G 83% / /dev/md0 99M 39M 55M 42% /boot /dev/mapper/Vol0-local 1.8T 141G 1.7T 8% /local ---------------------- Disk Space End ------------------------- ###################### Logwatch End #########################
participants (1)
logwatch@mcs.anl.gov
