[mrepo] changes to warehouse13.mcs.anl.gov (new: 201, removed: 160)
The following changes to mrepo's repositories on warehouse13.mcs.anl.gov have been made: Dist: CentOS 5.9 (x86_64) (centos-5.9-x86_64) Repo: epel + GMT-static-4.5.6-1.el5.i386.rpm (671 kiB) + arpack-static-3.1.3-1.el5.i386.rpm (158 kiB) + boost141-static-1.41.0-5.el5.i386.rpm (7331 kiB) + cernlib-g77-static-2006-27.el5.i386.rpm (14616 kiB) + cernlib-static-2006-27.el5.i386.rpm (14155 kiB) + classads-static-1.0.8-1.el5.i386.rpm (539 kiB) + ddclient-3.8.1-9.el5.noarch.rpm (52 kiB) + eventlog-static-0.2.12-1.el5.i386.rpm (10 kiB) + factory-static-2.0.5-11.el5.i386.rpm (279 kiB) + fftw3-static-3.2.2-3.el5.i386.rpm (1422 kiB) + flann-static-1.6.11-1.el5.i386.rpm (704 kiB) + ghmm-static-0.7-4.svn2286.el5.i386.rpm (159 kiB) + glpk-static-4.20-2.el5.i386.rpm (306 kiB) + grib_api-static-1.9.8-3.el5.i386.rpm (381 kiB) + hivex-static-1.3.5-5.el5.i386.rpm (48 kiB) + libRmath-static-2.15.2-1.el5.i386.rpm (118 kiB) + libbsd-ctor-static-0.6.0-1.el5.i386.rpm (4 kiB) + libfac-static-2.0.5-8.el5.i386.rpm (137 kiB) + libkni3-static-3.9.2-12.el5.i386.rpm (155 kiB) + libmnl-static-1.0.3-4.el5.i386.rpm (8 kiB) + libsigsegv-static-2.4-6.el5.i386.rpm (6 kiB) + libvmime-static-0.9.2-0.9.20120406git.el5.i386.rpm (1500 kiB) + lrzip-static-0.614-1.el5.i386.rpm (149 kiB) + lua-static-5.1.4-4.el5.i386.rpm (94 kiB) + nco-static-4.0.5-2.el5.i386.rpm (221 kiB) + netcdf-static-3.6.3-1.el5.i386.rpm (270 kiB) + nettle-static-1.15-5.el5.i386.rpm (113 kiB) + openblas-static-0.2.8-1.el5.i386.rpm (18992 kiB) + protobuf-lite-static-2.3.0-7.el5.i386.rpm (73 kiB) + protobuf-static-2.3.0-7.el5.i386.rpm (731 kiB) + suitesparse-static-3.1.0-1.el5.i386.rpm (1077 kiB) + t1lib-static-5.1.1-9.el5.i386.rpm (149 kiB) + ustr-debug-static-1.0.4-6.el5.i386.rpm (82 kiB) + ustr-static-1.0.4-6.el5.i386.rpm (66 kiB) + vamp-plugin-sdk-static-2.1-1.el5.i386.rpm (140 kiB) - ddclient-3.8.1-1.el5.noarch.rpm (51 kiB) - pulseaudio-utils-0.9.10-1.el5.3.i386.rpm (133 kiB) Dist: CentOS 6.3 (x86_64) (centos-6.3-x86_64) Repo: epel + qt5-assistant-5.2.0-1.el6.x86_64.rpm (742 kiB) + qt5-designer-plugin-webkit-5.2.0-1.el6.i686.rpm (12 kiB) + qt5-designer-plugin-webkit-5.2.0-1.el6.x86_64.rpm (12 kiB) + qt5-qdbusviewer-5.2.0-1.el6.x86_64.rpm (50 kiB) + qt5-qtbase-5.2.0-1.el6.i686.rpm (3197 kiB) + qt5-qtbase-5.2.0-1.el6.x86_64.rpm (3195 kiB) + qt5-qtbase-devel-5.2.0-1.el6.i686.rpm (4827 kiB) + qt5-qtbase-devel-5.2.0-1.el6.x86_64.rpm (4738 kiB) + qt5-qtbase-doc-5.2.0-1.el6.noarch.rpm (50534 kiB) + qt5-qtbase-gui-5.2.0-1.el6.i686.rpm (4850 kiB) + qt5-qtbase-gui-5.2.0-1.el6.x86_64.rpm (4750 kiB) + qt5-qtbase-ibase-5.2.0-1.el6.i686.rpm (44 kiB) + qt5-qtbase-ibase-5.2.0-1.el6.x86_64.rpm (42 kiB) + qt5-qtbase-mysql-5.2.0-1.el6.i686.rpm (31 kiB) + qt5-qtbase-mysql-5.2.0-1.el6.x86_64.rpm (31 kiB) + qt5-qtbase-odbc-5.2.0-1.el6.i686.rpm (46 kiB) + qt5-qtbase-odbc-5.2.0-1.el6.x86_64.rpm (45 kiB) + qt5-qtbase-postgresql-5.2.0-1.el6.i686.rpm (33 kiB) + qt5-qtbase-postgresql-5.2.0-1.el6.x86_64.rpm (33 kiB) + qt5-qtbase-static-5.2.0-1.el6.i686.rpm (1154 kiB) + qt5-qtbase-static-5.2.0-1.el6.x86_64.rpm (1124 kiB) + qt5-qtbase-tds-5.2.0-1.el6.i686.rpm (26 kiB) + qt5-qtbase-tds-5.2.0-1.el6.x86_64.rpm (26 kiB) + qt5-qtdeclarative-5.2.0-1.el6.i686.rpm (3987 kiB) + qt5-qtdeclarative-5.2.0-1.el6.x86_64.rpm (2673 kiB) + qt5-qtdeclarative-devel-5.2.0-1.el6.i686.rpm (576 kiB) + qt5-qtdeclarative-devel-5.2.0-1.el6.x86_64.rpm (569 kiB) + qt5-qtdeclarative-doc-5.2.0-1.el6.noarch.rpm (17566 kiB) + qt5-qtdeclarative-static-5.2.0-1.el6.i686.rpm (70 kiB) + qt5-qtdeclarative-static-5.2.0-1.el6.x86_64.rpm (69 kiB) + qt5-qtdoc-5.2.0-1.el6.noarch.rpm (5237 kiB) + qt5-qtgraphicaleffects-5.2.0-1.el6.i686.rpm (55 kiB) + qt5-qtgraphicaleffects-5.2.0-1.el6.x86_64.rpm (55 kiB) + qt5-qtgraphicaleffects-doc-5.2.0-1.el6.noarch.rpm (29547 kiB) + qt5-qtimageformats-5.2.0-1.el6.i686.rpm (47 kiB) + qt5-qtimageformats-5.2.0-1.el6.x86_64.rpm (47 kiB) + qt5-qtimageformats-devel-5.2.0-1.el6.i686.rpm (4 kiB) + qt5-qtimageformats-devel-5.2.0-1.el6.x86_64.rpm (4 kiB) + qt5-qtimageformats-doc-5.2.0-1.el6.noarch.rpm (37 kiB) + qt5-qtmultimedia-5.2.0-1.el6.i686.rpm (576 kiB) + qt5-qtmultimedia-5.2.0-1.el6.x86_64.rpm (562 kiB) + qt5-qtmultimedia-devel-5.2.0-1.el6.i686.rpm (91 kiB) + qt5-qtmultimedia-devel-5.2.0-1.el6.x86_64.rpm (91 kiB) + qt5-qtmultimedia-doc-5.2.0-1.el6.noarch.rpm (5679 kiB) + qt5-qtquick1-5.2.0-1.el6.i686.rpm (1331 kiB) + qt5-qtquick1-5.2.0-1.el6.x86_64.rpm (1305 kiB) + qt5-qtquick1-devel-5.2.0-1.el6.i686.rpm (149 kiB) + qt5-qtquick1-devel-5.2.0-1.el6.x86_64.rpm (149 kiB) + qt5-qtquickcontrols-5.2.0-1.el6.i686.rpm (421 kiB) + qt5-qtquickcontrols-5.2.0-1.el6.x86_64.rpm (418 kiB) + qt5-qtquickcontrols-doc-5.2.0-1.el6.noarch.rpm (1074 kiB) + qt5-qtscript-5.2.0-1.el6.i686.rpm (995 kiB) + qt5-qtscript-5.2.0-1.el6.x86_64.rpm (945 kiB) + qt5-qtscript-devel-5.2.0-1.el6.i686.rpm (78 kiB) + qt5-qtscript-devel-5.2.0-1.el6.x86_64.rpm (78 kiB) + qt5-qtscript-doc-5.2.0-1.el6.noarch.rpm (648 kiB) + qt5-qtsvg-5.2.0-1.el6.i686.rpm (147 kiB) + qt5-qtsvg-5.2.0-1.el6.x86_64.rpm (148 kiB) + qt5-qtsvg-devel-5.2.0-1.el6.i686.rpm (21 kiB) + qt5-qtsvg-devel-5.2.0-1.el6.x86_64.rpm (21 kiB) + qt5-qtsvg-doc-5.2.0-1.el6.noarch.rpm (254 kiB) + qt5-qttools-5.2.0-1.el6.i686.rpm (3888 kiB) + qt5-qttools-5.2.0-1.el6.x86_64.rpm (3830 kiB) + qt5-qttools-devel-5.2.0-1.el6.i686.rpm (1463 kiB) + qt5-qttools-devel-5.2.0-1.el6.x86_64.rpm (1429 kiB) + qt5-qttools-doc-5.2.0-1.el6.noarch.rpm (6806 kiB) + qt5-qttools-static-5.2.0-1.el6.i686.rpm (198 kiB) + qt5-qttools-static-5.2.0-1.el6.x86_64.rpm (193 kiB) + qt5-qttranslations-5.2.0-1.el6.noarch.rpm (1277 kiB) + qt5-qtwebkit-5.2.0-1.el6.i686.rpm (9425 kiB) + qt5-qtwebkit-5.2.0-1.el6.x86_64.rpm (9306 kiB) + qt5-qtwebkit-devel-5.2.0-1.el6.i686.rpm (52 kiB) + qt5-qtwebkit-devel-5.2.0-1.el6.x86_64.rpm (52 kiB) + qt5-qtwebkit-doc-5.2.0-1.el6.noarch.rpm (418 kiB) + qt5-qtx11extras-5.2.0-1.el6.i686.rpm (27 kiB) + qt5-qtx11extras-5.2.0-1.el6.x86_64.rpm (27 kiB) + qt5-qtx11extras-devel-5.2.0-1.el6.i686.rpm (10 kiB) + qt5-qtx11extras-devel-5.2.0-1.el6.x86_64.rpm (10 kiB) + qt5-qtxmlpatterns-5.2.0-1.el6.i686.rpm (1185 kiB) + qt5-qtxmlpatterns-5.2.0-1.el6.x86_64.rpm (1178 kiB) + qt5-qtxmlpatterns-devel-5.2.0-1.el6.i686.rpm (334 kiB) + qt5-qtxmlpatterns-devel-5.2.0-1.el6.x86_64.rpm (334 kiB) + qt5-qtxmlpatterns-doc-5.2.0-1.el6.noarch.rpm (1230 kiB) - qt5-assistant-5.2.0-0.10.rc1.el6.x86_64.rpm (742 kiB) - qt5-designer-plugin-webkit-5.2.0-0.10.rc1.el6.i686.rpm (12 kiB) - qt5-designer-plugin-webkit-5.2.0-0.10.rc1.el6.x86_64.rpm (12 kiB) - qt5-qdbusviewer-5.2.0-0.10.rc1.el6.x86_64.rpm (50 kiB) - qt5-qtbase-5.2.0-0.12.rc1.el6.i686.rpm (3197 kiB) - qt5-qtbase-5.2.0-0.12.rc1.el6.x86_64.rpm (3195 kiB) - qt5-qtbase-devel-5.2.0-0.12.rc1.el6.i686.rpm (4823 kiB) - qt5-qtbase-devel-5.2.0-0.12.rc1.el6.x86_64.rpm (4734 kiB) - qt5-qtbase-doc-5.2.0-0.12.rc1.el6.noarch.rpm (50539 kiB) - qt5-qtbase-gui-5.2.0-0.12.rc1.el6.i686.rpm (4850 kiB) - qt5-qtbase-gui-5.2.0-0.12.rc1.el6.x86_64.rpm (4749 kiB) - qt5-qtbase-ibase-5.2.0-0.12.rc1.el6.i686.rpm (44 kiB) - qt5-qtbase-ibase-5.2.0-0.12.rc1.el6.x86_64.rpm (42 kiB) - qt5-qtbase-mysql-5.2.0-0.12.rc1.el6.i686.rpm (31 kiB) - qt5-qtbase-mysql-5.2.0-0.12.rc1.el6.x86_64.rpm (31 kiB) - qt5-qtbase-odbc-5.2.0-0.12.rc1.el6.i686.rpm (46 kiB) - qt5-qtbase-odbc-5.2.0-0.12.rc1.el6.x86_64.rpm (45 kiB) - qt5-qtbase-postgresql-5.2.0-0.12.rc1.el6.i686.rpm (33 kiB) - qt5-qtbase-postgresql-5.2.0-0.12.rc1.el6.x86_64.rpm (33 kiB) - qt5-qtbase-static-5.2.0-0.12.rc1.el6.i686.rpm (1153 kiB) - qt5-qtbase-static-5.2.0-0.12.rc1.el6.x86_64.rpm (1124 kiB) - qt5-qtbase-tds-5.2.0-0.12.rc1.el6.i686.rpm (25 kiB) - qt5-qtbase-tds-5.2.0-0.12.rc1.el6.x86_64.rpm (26 kiB) - qt5-qtdeclarative-5.2.0-0.12.rc1.el6.i686.rpm (3985 kiB) - qt5-qtdeclarative-5.2.0-0.12.rc1.el6.x86_64.rpm (2670 kiB) - qt5-qtdeclarative-devel-5.2.0-0.12.rc1.el6.i686.rpm (576 kiB) - qt5-qtdeclarative-devel-5.2.0-0.12.rc1.el6.x86_64.rpm (569 kiB) - qt5-qtdeclarative-doc-5.2.0-0.12.rc1.el6.noarch.rpm (17518 kiB) - qt5-qtdeclarative-static-5.2.0-0.12.rc1.el6.i686.rpm (70 kiB) - qt5-qtdeclarative-static-5.2.0-0.12.rc1.el6.x86_64.rpm (69 kiB) - qt5-qtdoc-5.2.0-0.10.rc1.el6.noarch.rpm (5223 kiB) - qt5-qtgraphicaleffects-5.2.0-0.10.rc1.el6.i686.rpm (55 kiB) - qt5-qtgraphicaleffects-5.2.0-0.10.rc1.el6.x86_64.rpm (55 kiB) - qt5-qtgraphicaleffects-doc-5.2.0-0.10.rc1.el6.noarch.rpm (29475 kiB) - qt5-qtimageformats-5.2.0-0.10.rc1.el6.i686.rpm (47 kiB) - qt5-qtimageformats-5.2.0-0.10.rc1.el6.x86_64.rpm (47 kiB) - qt5-qtimageformats-devel-5.2.0-0.10.rc1.el6.i686.rpm (4 kiB) - qt5-qtimageformats-devel-5.2.0-0.10.rc1.el6.x86_64.rpm (4 kiB) - qt5-qtimageformats-doc-5.2.0-0.10.rc1.el6.noarch.rpm (37 kiB) - qt5-qtmultimedia-5.2.0-0.10.rc1.el6.i686.rpm (576 kiB) - qt5-qtmultimedia-5.2.0-0.10.rc1.el6.x86_64.rpm (562 kiB) - qt5-qtmultimedia-devel-5.2.0-0.10.rc1.el6.i686.rpm (91 kiB) - qt5-qtmultimedia-devel-5.2.0-0.10.rc1.el6.x86_64.rpm (91 kiB) - qt5-qtmultimedia-doc-5.2.0-0.10.rc1.el6.noarch.rpm (5682 kiB) - qt5-qtquick1-5.2.0-0.10.rc1.el6.i686.rpm (1331 kiB) - qt5-qtquick1-5.2.0-0.10.rc1.el6.x86_64.rpm (1306 kiB) - qt5-qtquick1-devel-5.2.0-0.10.rc1.el6.i686.rpm (149 kiB) - qt5-qtquick1-devel-5.2.0-0.10.rc1.el6.x86_64.rpm (149 kiB) - qt5-qtquickcontrols-5.2.0-0.10.rc1.el6.i686.rpm (423 kiB) - qt5-qtquickcontrols-5.2.0-0.10.rc1.el6.x86_64.rpm (419 kiB) - qt5-qtquickcontrols-doc-5.2.0-0.10.rc1.el6.noarch.rpm (1075 kiB) - qt5-qtscript-5.2.0-0.10.rc1.el6.i686.rpm (995 kiB) - qt5-qtscript-5.2.0-0.10.rc1.el6.x86_64.rpm (945 kiB) - qt5-qtscript-devel-5.2.0-0.10.rc1.el6.i686.rpm (78 kiB) - qt5-qtscript-devel-5.2.0-0.10.rc1.el6.x86_64.rpm (78 kiB) - qt5-qtscript-doc-5.2.0-0.10.rc1.el6.noarch.rpm (648 kiB) - qt5-qtsvg-5.2.0-0.10.rc1.el6.i686.rpm (147 kiB) - qt5-qtsvg-5.2.0-0.10.rc1.el6.x86_64.rpm (147 kiB) - qt5-qtsvg-devel-5.2.0-0.10.rc1.el6.i686.rpm (21 kiB) - qt5-qtsvg-devel-5.2.0-0.10.rc1.el6.x86_64.rpm (21 kiB) - qt5-qtsvg-doc-5.2.0-0.10.rc1.el6.noarch.rpm (253 kiB) - qt5-qttools-5.2.0-0.10.rc1.el6.i686.rpm (3889 kiB) - qt5-qttools-5.2.0-0.10.rc1.el6.x86_64.rpm (3830 kiB) - qt5-qttools-devel-5.2.0-0.10.rc1.el6.i686.rpm (1463 kiB) - qt5-qttools-devel-5.2.0-0.10.rc1.el6.x86_64.rpm (1429 kiB) - qt5-qttools-doc-5.2.0-0.10.rc1.el6.noarch.rpm (6840 kiB) - qt5-qttools-static-5.2.0-0.10.rc1.el6.i686.rpm (198 kiB) - qt5-qttools-static-5.2.0-0.10.rc1.el6.x86_64.rpm (193 kiB) - qt5-qttranslations-5.2.0-0.10.rc1.el6.noarch.rpm (1277 kiB) - qt5-qtwebkit-5.2.0-0.10.rc1.el6.i686.rpm (9439 kiB) - qt5-qtwebkit-5.2.0-0.10.rc1.el6.x86_64.rpm (9305 kiB) - qt5-qtwebkit-devel-5.2.0-0.10.rc1.el6.i686.rpm (52 kiB) - qt5-qtwebkit-devel-5.2.0-0.10.rc1.el6.x86_64.rpm (52 kiB) - qt5-qtwebkit-doc-5.2.0-0.10.rc1.el6.noarch.rpm (418 kiB) - qt5-qtxmlpatterns-5.2.0-0.10.rc1.el6.i686.rpm (1185 kiB) - qt5-qtxmlpatterns-5.2.0-0.10.rc1.el6.x86_64.rpm (1178 kiB) - qt5-qtxmlpatterns-devel-5.2.0-0.10.rc1.el6.i686.rpm (334 kiB) - qt5-qtxmlpatterns-devel-5.2.0-0.10.rc1.el6.x86_64.rpm (333 kiB) - qt5-qtxmlpatterns-doc-5.2.0-0.10.rc1.el6.noarch.rpm (1231 kiB) Dist: CentOS 6.4 (x86_64) (centos-6.4-x86_64) Repo: epel + qt5-assistant-5.2.0-1.el6.x86_64.rpm (742 kiB) + qt5-designer-plugin-webkit-5.2.0-1.el6.i686.rpm (12 kiB) + qt5-designer-plugin-webkit-5.2.0-1.el6.x86_64.rpm (12 kiB) + qt5-qdbusviewer-5.2.0-1.el6.x86_64.rpm (50 kiB) + qt5-qtbase-5.2.0-1.el6.i686.rpm (3197 kiB) + qt5-qtbase-5.2.0-1.el6.x86_64.rpm (3195 kiB) + qt5-qtbase-devel-5.2.0-1.el6.i686.rpm (4827 kiB) + qt5-qtbase-devel-5.2.0-1.el6.x86_64.rpm (4738 kiB) + qt5-qtbase-doc-5.2.0-1.el6.noarch.rpm (50534 kiB) + qt5-qtbase-gui-5.2.0-1.el6.i686.rpm (4850 kiB) + qt5-qtbase-gui-5.2.0-1.el6.x86_64.rpm (4750 kiB) + qt5-qtbase-ibase-5.2.0-1.el6.i686.rpm (44 kiB) + qt5-qtbase-ibase-5.2.0-1.el6.x86_64.rpm (42 kiB) + qt5-qtbase-mysql-5.2.0-1.el6.i686.rpm (31 kiB) + qt5-qtbase-mysql-5.2.0-1.el6.x86_64.rpm (31 kiB) + qt5-qtbase-odbc-5.2.0-1.el6.i686.rpm (46 kiB) + qt5-qtbase-odbc-5.2.0-1.el6.x86_64.rpm (45 kiB) + qt5-qtbase-postgresql-5.2.0-1.el6.i686.rpm (33 kiB) + qt5-qtbase-postgresql-5.2.0-1.el6.x86_64.rpm (33 kiB) + qt5-qtbase-static-5.2.0-1.el6.i686.rpm (1154 kiB) + qt5-qtbase-static-5.2.0-1.el6.x86_64.rpm (1124 kiB) + qt5-qtbase-tds-5.2.0-1.el6.i686.rpm (26 kiB) + qt5-qtbase-tds-5.2.0-1.el6.x86_64.rpm (26 kiB) + qt5-qtdeclarative-5.2.0-1.el6.i686.rpm (3987 kiB) + qt5-qtdeclarative-5.2.0-1.el6.x86_64.rpm (2673 kiB) + qt5-qtdeclarative-devel-5.2.0-1.el6.i686.rpm (576 kiB) + qt5-qtdeclarative-devel-5.2.0-1.el6.x86_64.rpm (569 kiB) + qt5-qtdeclarative-doc-5.2.0-1.el6.noarch.rpm (17566 kiB) + qt5-qtdeclarative-static-5.2.0-1.el6.i686.rpm (70 kiB) + qt5-qtdeclarative-static-5.2.0-1.el6.x86_64.rpm (69 kiB) + qt5-qtdoc-5.2.0-1.el6.noarch.rpm (5237 kiB) + qt5-qtgraphicaleffects-5.2.0-1.el6.i686.rpm (55 kiB) + qt5-qtgraphicaleffects-5.2.0-1.el6.x86_64.rpm (55 kiB) + qt5-qtgraphicaleffects-doc-5.2.0-1.el6.noarch.rpm (29547 kiB) + qt5-qtimageformats-5.2.0-1.el6.i686.rpm (47 kiB) + qt5-qtimageformats-5.2.0-1.el6.x86_64.rpm (47 kiB) + qt5-qtimageformats-devel-5.2.0-1.el6.i686.rpm (4 kiB) + qt5-qtimageformats-devel-5.2.0-1.el6.x86_64.rpm (4 kiB) + qt5-qtimageformats-doc-5.2.0-1.el6.noarch.rpm (37 kiB) + qt5-qtmultimedia-5.2.0-1.el6.i686.rpm (576 kiB) + qt5-qtmultimedia-5.2.0-1.el6.x86_64.rpm (562 kiB) + qt5-qtmultimedia-devel-5.2.0-1.el6.i686.rpm (91 kiB) + qt5-qtmultimedia-devel-5.2.0-1.el6.x86_64.rpm (91 kiB) + qt5-qtmultimedia-doc-5.2.0-1.el6.noarch.rpm (5679 kiB) + qt5-qtquick1-5.2.0-1.el6.i686.rpm (1331 kiB) + qt5-qtquick1-5.2.0-1.el6.x86_64.rpm (1305 kiB) + qt5-qtquick1-devel-5.2.0-1.el6.i686.rpm (149 kiB) + qt5-qtquick1-devel-5.2.0-1.el6.x86_64.rpm (149 kiB) + qt5-qtquickcontrols-5.2.0-1.el6.i686.rpm (421 kiB) + qt5-qtquickcontrols-5.2.0-1.el6.x86_64.rpm (418 kiB) + qt5-qtquickcontrols-doc-5.2.0-1.el6.noarch.rpm (1074 kiB) + qt5-qtscript-5.2.0-1.el6.i686.rpm (995 kiB) + qt5-qtscript-5.2.0-1.el6.x86_64.rpm (945 kiB) + qt5-qtscript-devel-5.2.0-1.el6.i686.rpm (78 kiB) + qt5-qtscript-devel-5.2.0-1.el6.x86_64.rpm (78 kiB) + qt5-qtscript-doc-5.2.0-1.el6.noarch.rpm (648 kiB) + qt5-qtsvg-5.2.0-1.el6.i686.rpm (147 kiB) + qt5-qtsvg-5.2.0-1.el6.x86_64.rpm (148 kiB) + qt5-qtsvg-devel-5.2.0-1.el6.i686.rpm (21 kiB) + qt5-qtsvg-devel-5.2.0-1.el6.x86_64.rpm (21 kiB) + qt5-qtsvg-doc-5.2.0-1.el6.noarch.rpm (254 kiB) + qt5-qttools-5.2.0-1.el6.i686.rpm (3888 kiB) + qt5-qttools-5.2.0-1.el6.x86_64.rpm (3830 kiB) + qt5-qttools-devel-5.2.0-1.el6.i686.rpm (1463 kiB) + qt5-qttools-devel-5.2.0-1.el6.x86_64.rpm (1429 kiB) + qt5-qttools-doc-5.2.0-1.el6.noarch.rpm (6806 kiB) + qt5-qttools-static-5.2.0-1.el6.i686.rpm (198 kiB) + qt5-qttools-static-5.2.0-1.el6.x86_64.rpm (193 kiB) + qt5-qttranslations-5.2.0-1.el6.noarch.rpm (1277 kiB) + qt5-qtwebkit-5.2.0-1.el6.i686.rpm (9425 kiB) + qt5-qtwebkit-5.2.0-1.el6.x86_64.rpm (9306 kiB) + qt5-qtwebkit-devel-5.2.0-1.el6.i686.rpm (52 kiB) + qt5-qtwebkit-devel-5.2.0-1.el6.x86_64.rpm (52 kiB) + qt5-qtwebkit-doc-5.2.0-1.el6.noarch.rpm (418 kiB) + qt5-qtx11extras-5.2.0-1.el6.i686.rpm (27 kiB) + qt5-qtx11extras-5.2.0-1.el6.x86_64.rpm (27 kiB) + qt5-qtx11extras-devel-5.2.0-1.el6.i686.rpm (10 kiB) + qt5-qtx11extras-devel-5.2.0-1.el6.x86_64.rpm (10 kiB) + qt5-qtxmlpatterns-5.2.0-1.el6.i686.rpm (1185 kiB) + qt5-qtxmlpatterns-5.2.0-1.el6.x86_64.rpm (1178 kiB) + qt5-qtxmlpatterns-devel-5.2.0-1.el6.i686.rpm (334 kiB) + qt5-qtxmlpatterns-devel-5.2.0-1.el6.x86_64.rpm (334 kiB) + qt5-qtxmlpatterns-doc-5.2.0-1.el6.noarch.rpm (1230 kiB) - qt5-assistant-5.2.0-0.10.rc1.el6.x86_64.rpm (742 kiB) - qt5-designer-plugin-webkit-5.2.0-0.10.rc1.el6.i686.rpm (12 kiB) - qt5-designer-plugin-webkit-5.2.0-0.10.rc1.el6.x86_64.rpm (12 kiB) - qt5-qdbusviewer-5.2.0-0.10.rc1.el6.x86_64.rpm (50 kiB) - qt5-qtbase-5.2.0-0.12.rc1.el6.i686.rpm (3197 kiB) - qt5-qtbase-5.2.0-0.12.rc1.el6.x86_64.rpm (3195 kiB) - qt5-qtbase-devel-5.2.0-0.12.rc1.el6.i686.rpm (4823 kiB) - qt5-qtbase-devel-5.2.0-0.12.rc1.el6.x86_64.rpm (4734 kiB) - qt5-qtbase-doc-5.2.0-0.12.rc1.el6.noarch.rpm (50539 kiB) - qt5-qtbase-gui-5.2.0-0.12.rc1.el6.i686.rpm (4850 kiB) - qt5-qtbase-gui-5.2.0-0.12.rc1.el6.x86_64.rpm (4749 kiB) - qt5-qtbase-ibase-5.2.0-0.12.rc1.el6.i686.rpm (44 kiB) - qt5-qtbase-ibase-5.2.0-0.12.rc1.el6.x86_64.rpm (42 kiB) - qt5-qtbase-mysql-5.2.0-0.12.rc1.el6.i686.rpm (31 kiB) - qt5-qtbase-mysql-5.2.0-0.12.rc1.el6.x86_64.rpm (31 kiB) - qt5-qtbase-odbc-5.2.0-0.12.rc1.el6.i686.rpm (46 kiB) - qt5-qtbase-odbc-5.2.0-0.12.rc1.el6.x86_64.rpm (45 kiB) - qt5-qtbase-postgresql-5.2.0-0.12.rc1.el6.i686.rpm (33 kiB) - qt5-qtbase-postgresql-5.2.0-0.12.rc1.el6.x86_64.rpm (33 kiB) - qt5-qtbase-static-5.2.0-0.12.rc1.el6.i686.rpm (1153 kiB) - qt5-qtbase-static-5.2.0-0.12.rc1.el6.x86_64.rpm (1124 kiB) - qt5-qtbase-tds-5.2.0-0.12.rc1.el6.i686.rpm (25 kiB) - qt5-qtbase-tds-5.2.0-0.12.rc1.el6.x86_64.rpm (26 kiB) - qt5-qtdeclarative-5.2.0-0.12.rc1.el6.i686.rpm (3985 kiB) - qt5-qtdeclarative-5.2.0-0.12.rc1.el6.x86_64.rpm (2670 kiB) - qt5-qtdeclarative-devel-5.2.0-0.12.rc1.el6.i686.rpm (576 kiB) - qt5-qtdeclarative-devel-5.2.0-0.12.rc1.el6.x86_64.rpm (569 kiB) - qt5-qtdeclarative-doc-5.2.0-0.12.rc1.el6.noarch.rpm (17518 kiB) - qt5-qtdeclarative-static-5.2.0-0.12.rc1.el6.i686.rpm (70 kiB) - qt5-qtdeclarative-static-5.2.0-0.12.rc1.el6.x86_64.rpm (69 kiB) - qt5-qtdoc-5.2.0-0.10.rc1.el6.noarch.rpm (5223 kiB) - qt5-qtgraphicaleffects-5.2.0-0.10.rc1.el6.i686.rpm (55 kiB) - qt5-qtgraphicaleffects-5.2.0-0.10.rc1.el6.x86_64.rpm (55 kiB) - qt5-qtgraphicaleffects-doc-5.2.0-0.10.rc1.el6.noarch.rpm (29475 kiB) - qt5-qtimageformats-5.2.0-0.10.rc1.el6.i686.rpm (47 kiB) - qt5-qtimageformats-5.2.0-0.10.rc1.el6.x86_64.rpm (47 kiB) - qt5-qtimageformats-devel-5.2.0-0.10.rc1.el6.i686.rpm (4 kiB) - qt5-qtimageformats-devel-5.2.0-0.10.rc1.el6.x86_64.rpm (4 kiB) - qt5-qtimageformats-doc-5.2.0-0.10.rc1.el6.noarch.rpm (37 kiB) - qt5-qtmultimedia-5.2.0-0.10.rc1.el6.i686.rpm (576 kiB) - qt5-qtmultimedia-5.2.0-0.10.rc1.el6.x86_64.rpm (562 kiB) - qt5-qtmultimedia-devel-5.2.0-0.10.rc1.el6.i686.rpm (91 kiB) - qt5-qtmultimedia-devel-5.2.0-0.10.rc1.el6.x86_64.rpm (91 kiB) - qt5-qtmultimedia-doc-5.2.0-0.10.rc1.el6.noarch.rpm (5682 kiB) - qt5-qtquick1-5.2.0-0.10.rc1.el6.i686.rpm (1331 kiB) - qt5-qtquick1-5.2.0-0.10.rc1.el6.x86_64.rpm (1306 kiB) - qt5-qtquick1-devel-5.2.0-0.10.rc1.el6.i686.rpm (149 kiB) - qt5-qtquick1-devel-5.2.0-0.10.rc1.el6.x86_64.rpm (149 kiB) - qt5-qtquickcontrols-5.2.0-0.10.rc1.el6.i686.rpm (423 kiB) - qt5-qtquickcontrols-5.2.0-0.10.rc1.el6.x86_64.rpm (419 kiB) - qt5-qtquickcontrols-doc-5.2.0-0.10.rc1.el6.noarch.rpm (1075 kiB) - qt5-qtscript-5.2.0-0.10.rc1.el6.i686.rpm (995 kiB) - qt5-qtscript-5.2.0-0.10.rc1.el6.x86_64.rpm (945 kiB) - qt5-qtscript-devel-5.2.0-0.10.rc1.el6.i686.rpm (78 kiB) - qt5-qtscript-devel-5.2.0-0.10.rc1.el6.x86_64.rpm (78 kiB) - qt5-qtscript-doc-5.2.0-0.10.rc1.el6.noarch.rpm (648 kiB) - qt5-qtsvg-5.2.0-0.10.rc1.el6.i686.rpm (147 kiB) - qt5-qtsvg-5.2.0-0.10.rc1.el6.x86_64.rpm (147 kiB) - qt5-qtsvg-devel-5.2.0-0.10.rc1.el6.i686.rpm (21 kiB) - qt5-qtsvg-devel-5.2.0-0.10.rc1.el6.x86_64.rpm (21 kiB) - qt5-qtsvg-doc-5.2.0-0.10.rc1.el6.noarch.rpm (253 kiB) - qt5-qttools-5.2.0-0.10.rc1.el6.i686.rpm (3889 kiB) - qt5-qttools-5.2.0-0.10.rc1.el6.x86_64.rpm (3830 kiB) - qt5-qttools-devel-5.2.0-0.10.rc1.el6.i686.rpm (1463 kiB) - qt5-qttools-devel-5.2.0-0.10.rc1.el6.x86_64.rpm (1429 kiB) - qt5-qttools-doc-5.2.0-0.10.rc1.el6.noarch.rpm (6840 kiB) - qt5-qttools-static-5.2.0-0.10.rc1.el6.i686.rpm (198 kiB) - qt5-qttools-static-5.2.0-0.10.rc1.el6.x86_64.rpm (193 kiB) - qt5-qttranslations-5.2.0-0.10.rc1.el6.noarch.rpm (1277 kiB) - qt5-qtwebkit-5.2.0-0.10.rc1.el6.i686.rpm (9439 kiB) - qt5-qtwebkit-5.2.0-0.10.rc1.el6.x86_64.rpm (9305 kiB) - qt5-qtwebkit-devel-5.2.0-0.10.rc1.el6.i686.rpm (52 kiB) - qt5-qtwebkit-devel-5.2.0-0.10.rc1.el6.x86_64.rpm (52 kiB) - qt5-qtwebkit-doc-5.2.0-0.10.rc1.el6.noarch.rpm (418 kiB) - qt5-qtxmlpatterns-5.2.0-0.10.rc1.el6.i686.rpm (1185 kiB) - qt5-qtxmlpatterns-5.2.0-0.10.rc1.el6.x86_64.rpm (1178 kiB) - qt5-qtxmlpatterns-devel-5.2.0-0.10.rc1.el6.i686.rpm (334 kiB) - qt5-qtxmlpatterns-devel-5.2.0-0.10.rc1.el6.x86_64.rpm (333 kiB) - qt5-qtxmlpatterns-doc-5.2.0-0.10.rc1.el6.noarch.rpm (1231 kiB)
participants (1)
mrepoï¼ warehouse13.mcs.anl.gov
