Logwatch for berlin.mcs.anl.gov (Linux)
################### Logwatch 7.3 (03/24/06) #################### Processing Initiated: Fri Dec 27 04:02:01 2013 Date Range Processed: yesterday ( 2013-Dec-26 ) Period is day. Detail Level of Output: 0 Type of Output: unformatted Logfiles for Host: berlin.mcs.anl.gov ################################################################## --------------------- httpd Begin ------------------------ A total of 1 sites probed the server 146.137.70.8 Requests with error response codes 404 Not Found /.cobalt: 1 Time(s) /ControlManager/default.htm: 1 Time(s) /MSWSMTP/Common/Authentication/Logon.aspx: 1 Time(s) /Ny4XhjfpNuVv.asp: 1 Time(s) /Ny4XhjfpNuVv.cfm: 1 Time(s) /Ny4XhjfpNuVv.cgi: 1 Time(s) /Ny4XhjfpNuVv.html: 1 Time(s) /Ny4XhjfpNuVv.inc: 1 Time(s) /Ny4XhjfpNuVv.php: 1 Time(s) /Ny4XhjfpNuVv.php3: 1 Time(s) /Ny4XhjfpNuVv.pl: 1 Time(s) /Ny4XhjfpNuVv.sh: 1 Time(s) /Ny4XhjfpNuVv.shtml: 1 Time(s) /admin.back: 1 Time(s) /cgi-bin/Ny4XhjfpNuVv.asp: 1 Time(s) /cgi-bin/Ny4XhjfpNuVv.cfm: 1 Time(s) /cgi-bin/Ny4XhjfpNuVv.cgi: 1 Time(s) /cgi-bin/Ny4XhjfpNuVv.html: 1 Time(s) /cgi-bin/Ny4XhjfpNuVv.inc: 1 Time(s) /cgi-bin/Ny4XhjfpNuVv.php: 1 Time(s) /cgi-bin/Ny4XhjfpNuVv.php3: 1 Time(s) /cgi-bin/Ny4XhjfpNuVv.pl: 1 Time(s) /cgi-bin/Ny4XhjfpNuVv.sh: 1 Time(s) /cgi-bin/Ny4XhjfpNuVv.shtml: 1 Time(s) /commoncgi/servlet/CCGIServlet?ApHost=PDT_ ... File=logout.htm: 1 Time(s) /file: 1 Time(s) /header.php?tab=status: 1 Time(s) /intruvert/jsp/admin/Login.jsp: 1 Time(s) /properties/configuration.php?tab=Status: 1 Time(s) /properties/description.dhtml: 1 Time(s) /robots.txt: 1 Time(s) /scripts/Ny4XhjfpNuVv.asp: 1 Time(s) /scripts/Ny4XhjfpNuVv.cfm: 1 Time(s) /scripts/Ny4XhjfpNuVv.cgi: 1 Time(s) /scripts/Ny4XhjfpNuVv.html: 1 Time(s) /scripts/Ny4XhjfpNuVv.inc: 1 Time(s) /scripts/Ny4XhjfpNuVv.php: 1 Time(s) /scripts/Ny4XhjfpNuVv.php3: 1 Time(s) /scripts/Ny4XhjfpNuVv.pl: 1 Time(s) /scripts/Ny4XhjfpNuVv.sh: 1 Time(s) /scripts/Ny4XhjfpNuVv.shtml: 1 Time(s) /sitemap.xml: 1 Time(s) /wavemaster.internal: 1 Time(s) /xmldata?item=All: 1 Time(s) 501 Not Implemented /: 1 Time(s) null: 1 Time(s) ---------------------- httpd End ------------------------- --------------------- pam_unix Begin ------------------------ sshd: Authentication Failures: unknown (anlscan8.cspo.anl.gov): 2 Time(s) Invalid Users: Unknown Account: 2 Time(s) sudo: Authentication Failures: dsouza(0) -> dsouza: 2 Time(s) ---------------------- pam_unix End ------------------------- --------------------- postfix Begin ------------------------ 5498 bytes transferred 1 messages sent 1 messages removed from queue ---------------------- postfix End ------------------------- --------------------- Smartd Begin ------------------------ Currently unreadable (pending) sectors detected: /dev/sda - 48 Time(s) 2 unreadable sectors detected ---------------------- Smartd End ------------------------- --------------------- SSHD Begin ------------------------ Illegal users from: 146.137.70.8 (anlscan8.cspo.anl.gov): 2 times Users logging in through sshd: dsouza: 130.202.232.229 (anlvpn229.mcs.anl.gov): 4 times 130.202.232.231 (anlvpn231.mcs.anl.gov): 1 time Received disconnect: 11: disconnected by user : 1 Time(s) **Unmatched Entries** pam_succeed_if(sshd:auth): error retrieving information about user Cisco : 1 time(s) pam_succeed_if(sshd:auth): error retrieving information about user cisco : 1 time(s) ---------------------- SSHD End ------------------------- --------------------- Sudo (secure-log) Begin ------------------------ ============================================================================== dsouza => dsouza ------------------------------------------------------------------------------ /bin/zsh /bin/zsh dsouza => root ------------------------------------------------------------------------------ /bin/bash /bin/bash ---------------------- Sudo (secure-log) End ------------------------- --------------------- Disk Space Begin ------------------------ Filesystem Size Used Avail Use% Mounted on /dev/mapper/Vol0-LV00 15G 11G 3.2G 77% / /dev/md0 99M 39M 55M 42% /boot /dev/mapper/Vol0-local 1.8T 141G 1.7T 8% /local ---------------------- Disk Space End ------------------------- ###################### Logwatch End #########################
participants (1)
logwatch@mcs.anl.gov
