Logwatch for berlin.mcs.anl.gov (Linux)
################### Logwatch 7.3 (03/24/06) #################### Processing Initiated: Sat Feb 22 04:02:02 2014 Date Range Processed: yesterday ( 2014-Feb-21 ) Period is day. Detail Level of Output: 0 Type of Output: unformatted Logfiles for Host: berlin.mcs.anl.gov ################################################################## --------------------- Automount Begin ------------------------ **Unmatched Entries** key "job" not found in map source(s).: 1 Time(s) key ".svn" not found in map source(s).: 1 Time(s) key "omg" not found in map source(s).: 1 Time(s) ---------------------- Automount End ------------------------- --------------------- pam_unix Begin ------------------------ su: Sessions Opened: jbischof(uid=0) -> mgrastprod: 8 Time(s) sudo: Authentication Failures: jbischof(0) -> jbischof: 7 Time(s) dsouza(0) -> dsouza: 2 Time(s) ---------------------- pam_unix End ------------------------- --------------------- postfix Begin ------------------------ 7813 bytes transferred 11 messages sent 11 messages removed from queue ---------------------- postfix End ------------------------- --------------------- Smartd Begin ------------------------ Currently unreadable (pending) sectors detected: /dev/sda - 48 Time(s) 1 unreadable sectors detected ---------------------- Smartd End ------------------------- --------------------- SSHD Begin ------------------------ Postponed authentication: tharriso/publickey: 140.221.76.22: 1 Time(s) Users logging in through sshd: dsouza: 140.221.10.82 (dsouza.mcs.anl.gov): 1 time jbischof: 140.221.11.19 (jbischof.mcs.anl.gov): 1 time root: 192.5.200.126 (warehouse13.mcs.anl.gov): 4 times tharriso: 140.221.76.22 (kursk-3.mcs.anl.gov): 1 time Received disconnect: 11: disconnected by user : 1 Time(s) **Unmatched Entries** fatal: Access denied for user root by PAM account configuration : 1 time(s) pam_access(sshd:account): access denied for user `root' from `majestic12.igsb.anl.gov' : 1 time(s) ---------------------- SSHD End ------------------------- --------------------- Sudo (secure-log) Begin ------------------------ ============================================================================== dsouza => mgrastprod ------------------------------------------------------------------------------ /bin/zsh dsouza => root ------------------------------------------------------------------------------ /bin/bash ============================================================================== jbischof => root ------------------------------------------------------------------------------ /bin/zsh /bin/zsh /bin/zsh /bin/zsh /bin/zsh /bin/zsh /bin/zsh ---------------------- Sudo (secure-log) End ------------------------- --------------------- yum Begin ------------------------ Packages Installed: python26-libs-2.6.8-2.el5.x86_64 python26-2.6.8-2.el5.x86_64 salt-minion-0.17.5-1.el5.noarch sshpass-1.05-1.el5.x86_64 python26-zmq-2.1.9-3.el5.x86_64 python26-crypto-2.3-5.el5.x86_64 python26-m2crypto-0.21.1-5.el5.x86_64 python26-jinja2-2.5.5-4.el5.noarch zeromq-2.1.9-1.el5.x86_64 python26-PyYAML-3.08-4.el5.x86_64 libyaml-0.1.2-3.el5.x86_64 python26-babel-0.9.5-2.el5.noarch yum-utils-1.1.16-21.el5.centos.noarch libffi-3.0.5-1.el5.x86_64 salt-0.17.5-1.el5.noarch python26-markupsafe-0.11-3.el5.x86_64 python26-msgpack-0.1.12-2.el5.x86_64 ---------------------- yum End ------------------------- --------------------- Disk Space Begin ------------------------ Filesystem Size Used Avail Use% Mounted on /dev/mapper/Vol0-LV00 15G 11G 3.0G 78% / /dev/md0 99M 39M 55M 42% /boot /dev/mapper/Vol0-local 1.8T 141G 1.7T 8% /local ---------------------- Disk Space End ------------------------- ###################### Logwatch End #########################
participants (1)
logwatch@mcs.anl.gov
