[mrepo] changes to warehouse13.mcs.anl.gov (new: 47, removed: 27)
The following changes to mrepo's repositories on warehouse13.mcs.anl.gov have been made: Dist: CentOS 5.9 (x86_64) (centos-5.9-x86_64) Repo: epel + globus-gram-job-manager-lsf-1.1-3.el5.x86_64.rpm (14 kiB) + globus-gram-job-manager-lsf-setup-poll-1.1-3.el5.x86_64.rpm (3 kiB) + globus-gram-job-manager-lsf-setup-seg-1.1-3.el5.i386.rpm (15 kiB) + globus-gram-job-manager-lsf-setup-seg-1.1-3.el5.x86_64.rpm (15 kiB) + globus-gridmap-verify-myproxy-callout-1.0-4.el5.i386.rpm (15 kiB) + globus-gridmap-verify-myproxy-callout-1.0-4.el5.x86_64.rpm (16 kiB) + mozilla-https-everywhere-3.2.4-1.el5.noarch.rpm (479 kiB) + munin-2.0.17-1.el5.noarch.rpm (217 kiB) + munin-async-2.0.17-1.el5.noarch.rpm (23 kiB) + munin-cgi-2.0.17-1.el5.noarch.rpm (18 kiB) + munin-common-2.0.17-1.el5.noarch.rpm (86 kiB) + munin-java-plugins-2.0.17-1.el5.noarch.rpm (83 kiB) + munin-nginx-2.0.17-1.el5.noarch.rpm (18 kiB) + munin-node-2.0.17-1.el5.noarch.rpm (424 kiB) + munin-ruby-plugins-2.0.17-1.el5.noarch.rpm (19 kiB) - mozilla-https-everywhere-3.2.3-1.el5.noarch.rpm (477 kiB) - munin-2.0.16-1.el5.noarch.rpm (217 kiB) - munin-async-2.0.16-1.el5.noarch.rpm (22 kiB) - munin-cgi-2.0.16-1.el5.noarch.rpm (18 kiB) - munin-common-2.0.16-1.el5.noarch.rpm (86 kiB) - munin-java-plugins-2.0.16-1.el5.noarch.rpm (83 kiB) - munin-nginx-2.0.16-1.el5.noarch.rpm (18 kiB) - munin-node-2.0.16-1.el5.noarch.rpm (424 kiB) - munin-ruby-plugins-2.0.16-1.el5.noarch.rpm (19 kiB) Dist: CentOS 6.3 (x86_64) (centos-6.3-x86_64) Repo: epel + globus-gram-job-manager-lsf-1.1-3.el6.i686.rpm (15 kiB) + globus-gram-job-manager-lsf-1.1-3.el6.x86_64.rpm (15 kiB) + globus-gram-job-manager-lsf-setup-poll-1.1-3.el6.noarch.rpm (4 kiB) + globus-gram-job-manager-lsf-setup-seg-1.1-3.el6.i686.rpm (15 kiB) + globus-gram-job-manager-lsf-setup-seg-1.1-3.el6.x86_64.rpm (15 kiB) + globus-gridmap-verify-myproxy-callout-1.0-4.el6.i686.rpm (16 kiB) + globus-gridmap-verify-myproxy-callout-1.0-4.el6.x86_64.rpm (17 kiB) + mozilla-https-everywhere-3.2.4-1.el6.noarch.rpm (465 kiB) + munin-2.0.17-1.el6.noarch.rpm (193 kiB) + munin-async-2.0.17-1.el6.noarch.rpm (24 kiB) + munin-cgi-2.0.17-1.el6.noarch.rpm (19 kiB) + munin-common-2.0.17-1.el6.noarch.rpm (85 kiB) + munin-java-plugins-2.0.17-1.el6.noarch.rpm (84 kiB) + munin-nginx-2.0.17-1.el6.noarch.rpm (19 kiB) + munin-node-2.0.17-1.el6.noarch.rpm (401 kiB) + munin-ruby-plugins-2.0.17-1.el6.noarch.rpm (20 kiB) - mozilla-https-everywhere-3.2.3-1.el6.noarch.rpm (464 kiB) - munin-2.0.16-1.el6.noarch.rpm (193 kiB) - munin-async-2.0.16-1.el6.noarch.rpm (24 kiB) - munin-cgi-2.0.16-1.el6.noarch.rpm (19 kiB) - munin-common-2.0.16-1.el6.noarch.rpm (85 kiB) - munin-java-plugins-2.0.16-1.el6.noarch.rpm (84 kiB) - munin-nginx-2.0.16-1.el6.noarch.rpm (19 kiB) - munin-node-2.0.16-1.el6.noarch.rpm (400 kiB) - munin-ruby-plugins-2.0.16-1.el6.noarch.rpm (20 kiB) Dist: CentOS 6.4 (x86_64) (centos-6.4-x86_64) Repo: epel + globus-gram-job-manager-lsf-1.1-3.el6.i686.rpm (15 kiB) + globus-gram-job-manager-lsf-1.1-3.el6.x86_64.rpm (15 kiB) + globus-gram-job-manager-lsf-setup-poll-1.1-3.el6.noarch.rpm (4 kiB) + globus-gram-job-manager-lsf-setup-seg-1.1-3.el6.i686.rpm (15 kiB) + globus-gram-job-manager-lsf-setup-seg-1.1-3.el6.x86_64.rpm (15 kiB) + globus-gridmap-verify-myproxy-callout-1.0-4.el6.i686.rpm (16 kiB) + globus-gridmap-verify-myproxy-callout-1.0-4.el6.x86_64.rpm (17 kiB) + mozilla-https-everywhere-3.2.4-1.el6.noarch.rpm (465 kiB) + munin-2.0.17-1.el6.noarch.rpm (193 kiB) + munin-async-2.0.17-1.el6.noarch.rpm (24 kiB) + munin-cgi-2.0.17-1.el6.noarch.rpm (19 kiB) + munin-common-2.0.17-1.el6.noarch.rpm (85 kiB) + munin-java-plugins-2.0.17-1.el6.noarch.rpm (84 kiB) + munin-nginx-2.0.17-1.el6.noarch.rpm (19 kiB) + munin-node-2.0.17-1.el6.noarch.rpm (401 kiB) + munin-ruby-plugins-2.0.17-1.el6.noarch.rpm (20 kiB) - mozilla-https-everywhere-3.2.3-1.el6.noarch.rpm (464 kiB) - munin-2.0.16-1.el6.noarch.rpm (193 kiB) - munin-async-2.0.16-1.el6.noarch.rpm (24 kiB) - munin-cgi-2.0.16-1.el6.noarch.rpm (19 kiB) - munin-common-2.0.16-1.el6.noarch.rpm (85 kiB) - munin-java-plugins-2.0.16-1.el6.noarch.rpm (84 kiB) - munin-nginx-2.0.16-1.el6.noarch.rpm (19 kiB) - munin-node-2.0.16-1.el6.noarch.rpm (400 kiB) - munin-ruby-plugins-2.0.16-1.el6.noarch.rpm (20 kiB)
participants (1)
mrepoï¼ warehouse13.mcs.anl.gov
