[mrepo] changes to warehouse13.mcs.anl.gov (new: 118, removed: 77)
The following changes to mrepo's repositories on warehouse13.mcs.anl.gov have been made: Dist: CentOS 5.10 (i386) (centos-5.10-i386) Repo: epel + drupal6-fivestar-1.21-1.el5.noarch.rpm (88 kiB) + tinc-1.0.23-1.el5.i386.rpm (222 kiB) Repo: updates + ksh-20100621-18.el5_10.1.i386.rpm (1278 kiB) + net-snmp-5.3.2.2-22.el5_10.1.i386.rpm (704 kiB) + net-snmp-devel-5.3.2.2-22.el5_10.1.i386.rpm (1974 kiB) + net-snmp-libs-5.3.2.2-22.el5_10.1.i386.rpm (1306 kiB) + net-snmp-perl-5.3.2.2-22.el5_10.1.i386.rpm (204 kiB) + net-snmp-utils-5.3.2.2-22.el5_10.1.i386.rpm (192 kiB) Dist: CentOS 5.10 (x86_64) (centos-5.10-x86_64) Repo: epel + drupal6-fivestar-1.21-1.el5.noarch.rpm (88 kiB) + tinc-1.0.23-1.el5.x86_64.rpm (225 kiB) Repo: updates + ksh-20100621-18.el5_10.1.x86_64.rpm (1289 kiB) + net-snmp-5.3.2.2-22.el5_10.1.x86_64.rpm (708 kiB) + net-snmp-devel-5.3.2.2-22.el5_10.1.i386.rpm (1974 kiB) + net-snmp-devel-5.3.2.2-22.el5_10.1.x86_64.rpm (2024 kiB) + net-snmp-libs-5.3.2.2-22.el5_10.1.i386.rpm (1306 kiB) + net-snmp-libs-5.3.2.2-22.el5_10.1.x86_64.rpm (1327 kiB) + net-snmp-perl-5.3.2.2-22.el5_10.1.x86_64.rpm (202 kiB) + net-snmp-utils-5.3.2.2-22.el5_10.1.x86_64.rpm (193 kiB) Dist: CentOS 6.5 (x86_64) (centos-6.5-x86_64) Repo: epel + asl-1.42-0.19.bld92.el6.x86_64.rpm (4383 kiB) + asterisk-sounds-core-en-1.4.25-1.el6.noarch.rpm (19 kiB) + asterisk-sounds-core-en-alaw-1.4.25-1.el6.noarch.rpm (7540 kiB) + asterisk-sounds-core-en-g722-1.4.25-1.el6.noarch.rpm (9324 kiB) + asterisk-sounds-core-en-g729-1.4.25-1.el6.noarch.rpm (1356 kiB) + asterisk-sounds-core-en-gsm-1.4.25-1.el6.noarch.rpm (2108 kiB) + asterisk-sounds-core-en-siren14-1.4.25-1.el6.noarch.rpm (7954 kiB) + asterisk-sounds-core-en-siren7-1.4.25-1.el6.noarch.rpm (5041 kiB) + asterisk-sounds-core-en-sln16-1.4.25-1.el6.noarch.rpm (33851 kiB) + asterisk-sounds-core-en-ulaw-1.4.25-1.el6.noarch.rpm (7649 kiB) + asterisk-sounds-core-en-wav-1.4.25-1.el6.noarch.rpm (16332 kiB) + asterisk-sounds-core-en_AU-1.4.25-1.el6.noarch.rpm (20 kiB) + asterisk-sounds-core-en_AU-alaw-1.4.25-1.el6.noarch.rpm (5770 kiB) + asterisk-sounds-core-en_AU-g722-1.4.25-1.el6.noarch.rpm (6884 kiB) + asterisk-sounds-core-en_AU-g729-1.4.25-1.el6.noarch.rpm (1049 kiB) + asterisk-sounds-core-en_AU-gsm-1.4.25-1.el6.noarch.rpm (1526 kiB) + asterisk-sounds-core-en_AU-siren14-1.4.25-1.el6.noarch.rpm (5516 kiB) + asterisk-sounds-core-en_AU-siren7-1.4.25-1.el6.noarch.rpm (3698 kiB) + asterisk-sounds-core-en_AU-sln16-1.4.25-1.el6.noarch.rpm (23238 kiB) + asterisk-sounds-core-en_AU-ulaw-1.4.25-1.el6.noarch.rpm (5881 kiB) + asterisk-sounds-core-en_AU-wav-1.4.25-1.el6.noarch.rpm (11620 kiB) + asterisk-sounds-core-en_GB-1.4.25-1.el6.noarch.rpm (21 kiB) + asterisk-sounds-core-en_GB-alaw-1.4.25-1.el6.noarch.rpm (7286 kiB) + asterisk-sounds-core-en_GB-g722-1.4.25-1.el6.noarch.rpm (9598 kiB) + asterisk-sounds-core-en_GB-g729-1.4.25-1.el6.noarch.rpm (1428 kiB) + asterisk-sounds-core-en_GB-gsm-1.4.25-1.el6.noarch.rpm (2119 kiB) + asterisk-sounds-core-en_GB-siren14-1.4.25-1.el6.noarch.rpm (8299 kiB) + asterisk-sounds-core-en_GB-siren7-1.4.25-1.el6.noarch.rpm (5390 kiB) + asterisk-sounds-core-en_GB-sln16-1.4.25-1.el6.noarch.rpm (31323 kiB) + asterisk-sounds-core-en_GB-ulaw-1.4.25-1.el6.noarch.rpm (7644 kiB) + asterisk-sounds-core-en_GB-wav-1.4.25-1.el6.noarch.rpm (15418 kiB) + asterisk-sounds-core-es-1.4.25-1.el6.noarch.rpm (20 kiB) + asterisk-sounds-core-es-alaw-1.4.25-1.el6.noarch.rpm (11013 kiB) + asterisk-sounds-core-es-g722-1.4.25-1.el6.noarch.rpm (12931 kiB) + asterisk-sounds-core-es-g729-1.4.25-1.el6.noarch.rpm (1863 kiB) + asterisk-sounds-core-es-gsm-1.4.25-1.el6.noarch.rpm (2942 kiB) + asterisk-sounds-core-es-siren14-1.4.25-1.el6.noarch.rpm (10939 kiB) + asterisk-sounds-core-es-siren7-1.4.25-1.el6.noarch.rpm (7057 kiB) + asterisk-sounds-core-es-sln16-1.4.25-1.el6.noarch.rpm (48038 kiB) + asterisk-sounds-core-es-ulaw-1.4.25-1.el6.noarch.rpm (11143 kiB) + asterisk-sounds-core-es-wav-1.4.25-1.el6.noarch.rpm (23818 kiB) + asterisk-sounds-core-fr-1.4.25-1.el6.noarch.rpm (20 kiB) + asterisk-sounds-core-fr-alaw-1.4.25-1.el6.noarch.rpm (7866 kiB) + asterisk-sounds-core-fr-g722-1.4.25-1.el6.noarch.rpm (9794 kiB) + asterisk-sounds-core-fr-g729-1.4.25-1.el6.noarch.rpm (1429 kiB) + asterisk-sounds-core-fr-gsm-1.4.25-1.el6.noarch.rpm (2202 kiB) + asterisk-sounds-core-fr-siren14-1.4.25-1.el6.noarch.rpm (8380 kiB) + asterisk-sounds-core-fr-siren7-1.4.25-1.el6.noarch.rpm (5332 kiB) + asterisk-sounds-core-fr-sln16-1.4.25-1.el6.noarch.rpm (34895 kiB) + asterisk-sounds-core-fr-ulaw-1.4.25-1.el6.noarch.rpm (8018 kiB) + asterisk-sounds-core-fr-wav-1.4.25-1.el6.noarch.rpm (17138 kiB) + asterisk-sounds-core-it-1.4.25-1.el6.noarch.rpm (15 kiB) + asterisk-sounds-core-it-alaw-1.4.25-1.el6.noarch.rpm (7923 kiB) + asterisk-sounds-core-it-g722-1.4.25-1.el6.noarch.rpm (9180 kiB) + asterisk-sounds-core-it-g729-1.4.25-1.el6.noarch.rpm (1354 kiB) + asterisk-sounds-core-it-gsm-1.4.25-1.el6.noarch.rpm (2086 kiB) + asterisk-sounds-core-it-siren14-1.4.25-1.el6.noarch.rpm (7600 kiB) + asterisk-sounds-core-it-siren7-1.4.25-1.el6.noarch.rpm (5040 kiB) + asterisk-sounds-core-it-sln16-1.4.25-1.el6.noarch.rpm (34612 kiB) + asterisk-sounds-core-it-ulaw-1.4.25-1.el6.noarch.rpm (8009 kiB) + asterisk-sounds-core-it-wav-1.4.25-1.el6.noarch.rpm (17036 kiB) + asterisk-sounds-core-ru-1.4.25-1.el6.noarch.rpm (15 kiB) + asterisk-sounds-core-ru-alaw-1.4.25-1.el6.noarch.rpm (6981 kiB) + asterisk-sounds-core-ru-g722-1.4.25-1.el6.noarch.rpm (8237 kiB) + asterisk-sounds-core-ru-g729-1.4.25-1.el6.noarch.rpm (1249 kiB) + asterisk-sounds-core-ru-gsm-1.4.25-1.el6.noarch.rpm (1948 kiB) + asterisk-sounds-core-ru-siren14-1.4.25-1.el6.noarch.rpm (6801 kiB) + asterisk-sounds-core-ru-siren7-1.4.25-1.el6.noarch.rpm (4623 kiB) + asterisk-sounds-core-ru-sln16-1.4.25-1.el6.noarch.rpm (30170 kiB) + asterisk-sounds-core-ru-ulaw-1.4.25-1.el6.noarch.rpm (7148 kiB) + asterisk-sounds-core-ru-wav-1.4.25-1.el6.noarch.rpm (14918 kiB) + cabal-rpm-0.8.10-1.el6.x86_64.rpm (70 kiB) + datagrepper-0.4.0-2.el6.noarch.rpm (126 kiB) + drupal6-fivestar-1.21-1.el6.noarch.rpm (87 kiB) + nodejs-requirejs-2.1.11-1.el6.noarch.rpm (208 kiB) + opensmtpd-5.4.2p1-1.el6.x86_64.rpm (343 kiB) + openstack-swift-1.12.0-2.el6.noarch.rpm (516 kiB) + openstack-swift-account-1.12.0-2.el6.noarch.rpm (23 kiB) + openstack-swift-container-1.12.0-2.el6.noarch.rpm (62 kiB) + openstack-swift-doc-1.12.0-2.el6.noarch.rpm (1170 kiB) + openstack-swift-object-1.12.0-2.el6.noarch.rpm (27 kiB) + openstack-swift-proxy-1.12.0-2.el6.noarch.rpm (92 kiB) + perl-MooseX-Role-Parameterized-0.27-2.el6.noarch.rpm (38 kiB) + php-JsonSchema-1.3.6-1.el6.noarch.rpm (26 kiB) + python-fedbadges-0.4.1-1.el6.noarch.rpm (35 kiB) + python-remoteobjects-1.2.1-1.el6.noarch.rpm (36 kiB) + python-sure-1.2.5-1.el6.noarch.rpm (47 kiB) + python-tahrir-api-0.6.0-2.el6.noarch.rpm (53 kiB) + python-taskw-0.8.1-1.el6.noarch.rpm (38 kiB) + tinc-1.0.23-1.el6.x86_64.rpm (213 kiB) - asl-1.42-0.8.bld81.el6.x86_64.rpm (4344 kiB) - asterisk-sounds-core-en-1.4.24-1.el6.noarch.rpm (19 kiB) - asterisk-sounds-core-en-alaw-1.4.24-1.el6.noarch.rpm (7507 kiB) - asterisk-sounds-core-en-g722-1.4.24-1.el6.noarch.rpm (9284 kiB) - asterisk-sounds-core-en-g729-1.4.24-1.el6.noarch.rpm (1350 kiB) - asterisk-sounds-core-en-gsm-1.4.24-1.el6.noarch.rpm (2098 kiB) - asterisk-sounds-core-en-siren14-1.4.24-1.el6.noarch.rpm (7920 kiB) - asterisk-sounds-core-en-siren7-1.4.24-1.el6.noarch.rpm (5019 kiB) - asterisk-sounds-core-en-sln16-1.4.24-1.el6.noarch.rpm (33711 kiB) - asterisk-sounds-core-en-ulaw-1.4.24-1.el6.noarch.rpm (7615 kiB) - asterisk-sounds-core-en-wav-1.4.24-1.el6.noarch.rpm (16263 kiB) - asterisk-sounds-core-en_AU-1.4.24-1.el6.noarch.rpm (20 kiB) - asterisk-sounds-core-en_AU-alaw-1.4.24-1.el6.noarch.rpm (5770 kiB) - asterisk-sounds-core-en_AU-g722-1.4.24-1.el6.noarch.rpm (6884 kiB) - asterisk-sounds-core-en_AU-g729-1.4.24-1.el6.noarch.rpm (1049 kiB) - asterisk-sounds-core-en_AU-gsm-1.4.24-1.el6.noarch.rpm (1526 kiB) - asterisk-sounds-core-en_AU-siren14-1.4.24-1.el6.noarch.rpm (5516 kiB) - asterisk-sounds-core-en_AU-siren7-1.4.24-1.el6.noarch.rpm (3698 kiB) - asterisk-sounds-core-en_AU-sln16-1.4.24-1.el6.noarch.rpm (23238 kiB) - asterisk-sounds-core-en_AU-ulaw-1.4.24-1.el6.noarch.rpm (5881 kiB) - asterisk-sounds-core-en_AU-wav-1.4.24-1.el6.noarch.rpm (11620 kiB) - asterisk-sounds-core-es-1.4.24-1.el6.noarch.rpm (19 kiB) - asterisk-sounds-core-es-alaw-1.4.24-1.el6.noarch.rpm (11013 kiB) - asterisk-sounds-core-es-g722-1.4.24-1.el6.noarch.rpm (12931 kiB) - asterisk-sounds-core-es-g729-1.4.24-1.el6.noarch.rpm (1863 kiB) - asterisk-sounds-core-es-gsm-1.4.24-1.el6.noarch.rpm (2942 kiB) - asterisk-sounds-core-es-siren14-1.4.24-1.el6.noarch.rpm (10939 kiB) - asterisk-sounds-core-es-siren7-1.4.24-1.el6.noarch.rpm (7057 kiB) - asterisk-sounds-core-es-sln16-1.4.24-1.el6.noarch.rpm (48038 kiB) - asterisk-sounds-core-es-ulaw-1.4.24-1.el6.noarch.rpm (11143 kiB) - asterisk-sounds-core-es-wav-1.4.24-1.el6.noarch.rpm (23818 kiB) - asterisk-sounds-core-fr-1.4.24-1.el6.noarch.rpm (19 kiB) - asterisk-sounds-core-fr-alaw-1.4.24-1.el6.noarch.rpm (7842 kiB) - asterisk-sounds-core-fr-g722-1.4.24-1.el6.noarch.rpm (9763 kiB) - asterisk-sounds-core-fr-g729-1.4.24-1.el6.noarch.rpm (1424 kiB) - asterisk-sounds-core-fr-gsm-1.4.24-1.el6.noarch.rpm (2195 kiB) - asterisk-sounds-core-fr-siren14-1.4.24-1.el6.noarch.rpm (8354 kiB) - asterisk-sounds-core-fr-siren7-1.4.24-1.el6.noarch.rpm (5315 kiB) - asterisk-sounds-core-fr-sln16-1.4.24-1.el6.noarch.rpm (34788 kiB) - asterisk-sounds-core-fr-ulaw-1.4.24-1.el6.noarch.rpm (7994 kiB) - asterisk-sounds-core-fr-wav-1.4.24-1.el6.noarch.rpm (17085 kiB) - asterisk-sounds-core-it-1.4.24-1.el6.noarch.rpm (14 kiB) - asterisk-sounds-core-it-alaw-1.4.24-1.el6.noarch.rpm (7947 kiB) - asterisk-sounds-core-it-g722-1.4.24-1.el6.noarch.rpm (9209 kiB) - asterisk-sounds-core-it-g729-1.4.24-1.el6.noarch.rpm (1357 kiB) - asterisk-sounds-core-it-gsm-1.4.24-1.el6.noarch.rpm (2092 kiB) - asterisk-sounds-core-it-siren14-1.4.24-1.el6.noarch.rpm (7623 kiB) - asterisk-sounds-core-it-siren7-1.4.24-1.el6.noarch.rpm (5055 kiB) - asterisk-sounds-core-it-sln16-1.4.24-1.el6.noarch.rpm (34723 kiB) - asterisk-sounds-core-it-ulaw-1.4.24-1.el6.noarch.rpm (8034 kiB) - asterisk-sounds-core-it-wav-1.4.24-1.el6.noarch.rpm (17091 kiB) - asterisk-sounds-core-ru-1.4.24-1.el6.noarch.rpm (15 kiB) - asterisk-sounds-core-ru-alaw-1.4.24-1.el6.noarch.rpm (6981 kiB) - asterisk-sounds-core-ru-g722-1.4.24-1.el6.noarch.rpm (8237 kiB) - asterisk-sounds-core-ru-g729-1.4.24-1.el6.noarch.rpm (1249 kiB) - asterisk-sounds-core-ru-gsm-1.4.24-1.el6.noarch.rpm (1948 kiB) - asterisk-sounds-core-ru-siren14-1.4.24-1.el6.noarch.rpm (6801 kiB) - asterisk-sounds-core-ru-siren7-1.4.24-1.el6.noarch.rpm (4623 kiB) - asterisk-sounds-core-ru-sln16-1.4.24-1.el6.noarch.rpm (30170 kiB) - asterisk-sounds-core-ru-ulaw-1.4.24-1.el6.noarch.rpm (7148 kiB) - asterisk-sounds-core-ru-wav-1.4.24-1.el6.noarch.rpm (14918 kiB) - cabal-rpm-0.8.6-1.el6.x86_64.rpm (63 kiB) - datagrepper-0.3.0-1.el6.noarch.rpm (92 kiB) - drupal6-fivestar-1.20-2.el6.noarch.rpm (86 kiB) - nodejs-requirejs-2.1.8-1.el6.noarch.rpm (199 kiB) - opensmtpd-5.4.1p1-1.el6.x86_64.rpm (288 kiB) - openstack-swift-1.7.4-3.el6.noarch.rpm (276 kiB) - openstack-swift-account-1.7.4-3.el6.noarch.rpm (39 kiB) - openstack-swift-container-1.7.4-3.el6.noarch.rpm (49 kiB) - openstack-swift-doc-1.7.4-3.el6.noarch.rpm (807 kiB) - openstack-swift-object-1.7.4-3.el6.noarch.rpm (65 kiB) - openstack-swift-proxy-1.7.4-3.el6.noarch.rpm (64 kiB) - php-JsonSchema-1.3.5-1.el6.noarch.rpm (26 kiB) - python-fedbadges-0.3.0-1.el6.noarch.rpm (32 kiB) - python-remoteobjects-1.1-1.el6.noarch.rpm (35 kiB) - python-tahrir-api-0.5.0-4.el6.noarch.rpm (53 kiB) - python-taskw-0.7.2-1.el6.noarch.rpm (33 kiB) Repo: updates + grep-2.6.3-4.el6_5.1.x86_64.rpm (228 kiB) + net-snmp-5.5-49.el6_5.1.x86_64.rpm (305 kiB) + net-snmp-devel-5.5-49.el6_5.1.i686.rpm (303 kiB) + net-snmp-devel-5.5-49.el6_5.1.x86_64.rpm (303 kiB) + net-snmp-libs-5.5-49.el6_5.1.i686.rpm (1540 kiB) + net-snmp-libs-5.5-49.el6_5.1.x86_64.rpm (1578 kiB) + net-snmp-perl-5.5-49.el6_5.1.x86_64.rpm (321 kiB) + net-snmp-python-5.5-49.el6_5.1.x86_64.rpm (73 kiB) + net-snmp-utils-5.5-49.el6_5.1.x86_64.rpm (173 kiB) + spice-vdagent-0.14.0-3.el6_5.x86_64.rpm (61 kiB)
participants (1)
mrepoï¼ warehouse13.mcs.anl.gov
