Logwatch for berlin.mcs.anl.gov (Linux)
################### Logwatch 7.3 (03/24/06) #################### Processing Initiated: Tue Aug 6 04:02:03 2013 Date Range Processed: yesterday ( 2013-Aug-05 ) Period is day. Detail Level of Output: 0 Type of Output: unformatted Logfiles for Host: berlin.mcs.anl.gov ################################################################## --------------------- Selinux Audit Begin ------------------------ Number of audit daemon stops: 1 ---------------------- Selinux Audit End ------------------------- --------------------- Automount Begin ------------------------ **Unmatched Entries** umount_autofs_indirect: ask umount returned busy /mcs/bio: 1 Time(s) umount_autofs_indirect: ask umount returned busy /homes: 1 Time(s) ---------------------- Automount End ------------------------- --------------------- httpd Begin ------------------------ Requests with error response codes 404 Not Found /.cobalt: 1 Time(s) /ControlManager/default.htm: 1 Time(s) /MSWSMTP/Common/Authentication/Logon.aspx: 1 Time(s) /admin.back: 1 Time(s) /cgi-bin/nAx7rQ7ikDsS.asp: 1 Time(s) /cgi-bin/nAx7rQ7ikDsS.cfm: 1 Time(s) /cgi-bin/nAx7rQ7ikDsS.cgi: 1 Time(s) /cgi-bin/nAx7rQ7ikDsS.html: 1 Time(s) /cgi-bin/nAx7rQ7ikDsS.inc: 1 Time(s) /cgi-bin/nAx7rQ7ikDsS.php: 1 Time(s) /cgi-bin/nAx7rQ7ikDsS.php3: 1 Time(s) /cgi-bin/nAx7rQ7ikDsS.pl: 1 Time(s) /cgi-bin/nAx7rQ7ikDsS.sh: 1 Time(s) /cgi-bin/nAx7rQ7ikDsS.shtml: 1 Time(s) /commoncgi/servlet/CCGIServlet?ApHost=PDT_ ... File=logout.htm: 1 Time(s) /file: 1 Time(s) /intruvert/jsp/admin/Login.jsp: 1 Time(s) /login.htm: 1 Time(s) /nAx7rQ7ikDsS.asp: 1 Time(s) /nAx7rQ7ikDsS.cfm: 1 Time(s) /nAx7rQ7ikDsS.cgi: 1 Time(s) /nAx7rQ7ikDsS.html: 1 Time(s) /nAx7rQ7ikDsS.inc: 1 Time(s) /nAx7rQ7ikDsS.php: 1 Time(s) /nAx7rQ7ikDsS.php3: 1 Time(s) /nAx7rQ7ikDsS.pl: 1 Time(s) /nAx7rQ7ikDsS.sh: 1 Time(s) /nAx7rQ7ikDsS.shtml: 1 Time(s) /robots.txt: 1 Time(s) /scripts/nAx7rQ7ikDsS.asp: 1 Time(s) /scripts/nAx7rQ7ikDsS.cfm: 1 Time(s) /scripts/nAx7rQ7ikDsS.cgi: 1 Time(s) /scripts/nAx7rQ7ikDsS.html: 1 Time(s) /scripts/nAx7rQ7ikDsS.inc: 1 Time(s) /scripts/nAx7rQ7ikDsS.php: 1 Time(s) /scripts/nAx7rQ7ikDsS.php3: 1 Time(s) /scripts/nAx7rQ7ikDsS.pl: 1 Time(s) /scripts/nAx7rQ7ikDsS.sh: 1 Time(s) /scripts/nAx7rQ7ikDsS.shtml: 1 Time(s) /sdk: 1 Time(s) /sitemap.xml: 1 Time(s) /wavemaster.internal: 1 Time(s) 501 Not Implemented /: 1 Time(s) ---------------------- httpd End ------------------------- --------------------- OpenVPN Begin ------------------------ Version Information: OpenVPN 2.1.4 x86_64-redhat-linux-gnu [SSL] [LZO2] [EPOLL] [PKCS11] built on Apr 24 2011 **Unmatched Entries** allow_pull_fqdn = DISABLED: 1 Time(s) auth_user_pass_file = '[UNDEF]': 1 Time(s) auth_user_pass_verify_script = '[UNDEF]': 1 Time(s) auth_user_pass_verify_script_via_file = DISABLED: 1 Time(s) authname = 'SHA1': 1 Time(s) authname_defined = ENABLED: 1 Time(s) bind_defined = DISABLED: 1 Time(s) bind_local = ENABLED: 1 Time(s) ca_file = 'keys/ca.crt': 1 Time(s) ca_path = '[UNDEF]': 1 Time(s) ccd_exclusive = DISABLED: 1 Time(s) cd_dir = '/etc/openvpn': 1 Time(s) cert_file = 'keys/berlin.crt': 1 Time(s) cf_max = 0: 1 Time(s) cf_per = 0: 1 Time(s) chroot_dir = '[UNDEF]': 1 Time(s) cipher_list = '[UNDEF]': 1 Time(s) ciphername = 'BF-CBC': 1 Time(s) ciphername_defined = ENABLED: 1 Time(s) client = DISABLED: 1 Time(s) client_config_dir = '[UNDEF]': 1 Time(s) client_connect_script = '[UNDEF]': 1 Time(s) client_disconnect_script = '[UNDEF]': 1 Time(s) config = 'openvpn.conf': 1 Time(s) connect_retry_max = 0: 1 Time(s) connect_retry_seconds = 5: 1 Time(s) connect_timeout = 10: 1 Time(s) crl_file = '[UNDEF]': 1 Time(s) daemon = ENABLED: 1 Time(s) dev = 'tun': 1 Time(s) dev_node = '[UNDEF]': 1 Time(s) dev_type = '[UNDEF]': 1 Time(s) dh_file = 'keys/dh1024.pem': 1 Time(s) down_pre = DISABLED: 1 Time(s) down_script = '[UNDEF]': 1 Time(s) duplicate_cn = ENABLED: 1 Time(s) enable_c2c = ENABLED: 1 Time(s) engine = DISABLED: 1 Time(s) explicit_exit_notification = 0: 1 Time(s) fast_io = DISABLED: 1 Time(s) fragment = 0: 1 Time(s) genkey = DISABLED: 1 Time(s) gremlin = 0: 1 Time(s) groupname = 'users': 1 Time(s) handshake_window = 60: 1 Time(s) ifconfig_local = '172.16.100.1': 1 Time(s) ifconfig_noexec = DISABLED: 1 Time(s) ifconfig_nowarn = DISABLED: 1 Time(s) ifconfig_pool_defined = ENABLED: 1 Time(s) ifconfig_pool_end = 172.16.101.251: 1 Time(s) ifconfig_pool_netmask = 0.0.0.0: 1 Time(s) ifconfig_pool_persist_filename = 'ipp.txt': 1 Time(s) ifconfig_pool_persist_refresh_freq = 600: 1 Time(s) ifconfig_pool_start = 172.16.100.4: 1 Time(s) ifconfig_remote_netmask = '172.16.100.2': 1 Time(s) inactivity_timeout = 0: 1 Time(s) inetd = 0: 1 Time(s) ipchange = '[UNDEF]': 1 Time(s) keepalive_ping = 10: 1 Time(s) keepalive_timeout = 120: 1 Time(s) key_direction = 0: 1 Time(s) key_method = 2: 1 Time(s) key_pass_file = '[UNDEF]': 1 Time(s) keysize = 0: 1 Time(s) learn_address_script = '[UNDEF]': 1 Time(s) link_mtu = 1500: 1 Time(s) link_mtu_defined = DISABLED: 1 Time(s) lladdr = '[UNDEF]': 1 Time(s) local = '[UNDEF]': 1 Time(s) local_port = 1194: 1 Time(s) log = DISABLED: 1 Time(s) lzo = 7: 1 Time(s) management_addr = '[UNDEF]': 1 Time(s) management_client_group = '[UNDEF]': 1 Time(s) management_client_user = '[UNDEF]': 1 Time(s) management_echo_buffer_size = 100: 1 Time(s) management_flags = 0: 1 Time(s) management_log_history_cache = 250: 1 Time(s) management_port = 0: 1 Time(s) management_user_pass = '[UNDEF]': 1 Time(s) management_write_peer_info_file = '[UNDEF]': 1 Time(s) max_clients = 1024: 1 Time(s) max_routes = 100: 1 Time(s) max_routes_per_client = 256: 1 Time(s) mlock = DISABLED: 1 Time(s) mode = 1: 1 Time(s) mssfix = 1450: 1 Time(s) mtu_discover_type = -1: 1 Time(s) mtu_test = 0: 1 Time(s) mute = 0: 1 Time(s) mute_replay_warnings = DISABLED: 1 Time(s) n_bcast_buf = 256: 1 Time(s) nice = 0: 1 Time(s) ns_cert_type = 0: 1 Time(s) occ = ENABLED: 1 Time(s) packet_id_file = '[UNDEF]': 1 Time(s) passtos = DISABLED: 1 Time(s) persist_config = DISABLED: 1 Time(s) persist_key = ENABLED: 1 Time(s) persist_local_ip = DISABLED: 1 Time(s) persist_mode = 1: 1 Time(s) persist_remote_ip = DISABLED: 1 Time(s) persist_tun = ENABLED: 1 Time(s) ping_rec_timeout = 240: 1 Time(s) ping_rec_timeout_action = 2: 1 Time(s) ping_send_timeout = 10: 1 Time(s) ping_timer_remote = DISABLED: 1 Time(s) pkcs11_cert_private = DISABLED: 14 Time(s) pkcs11_id = '[UNDEF]': 1 Time(s) pkcs11_id_management = DISABLED: 1 Time(s) pkcs11_pin_cache_period = -1: 1 Time(s) pkcs11_private_mode = 00000000: 13 Time(s) pkcs11_protected_authentication = DISABLED: 8 Time(s) pkcs12_file = '[UNDEF]': 1 Time(s) port_share_host = '[UNDEF]': 1 Time(s) port_share_port = 0: 1 Time(s) priv_key_file = 'keys/berlin.key': 1 Time(s) prng_hash = 'SHA1': 1 Time(s) prng_nonce_secret_len = 16: 1 Time(s) proto = tcp-server: 1 Time(s) pull = DISABLED: 1 Time(s) push_entry = 'ping 10': 1 Time(s) push_entry = 'ping-restart 120': 1 Time(s) push_entry = 'route 140.221.76.7 255.255.255.255': 1 Time(s) push_entry = 'route 140.221.8.60 255.255.255.255': 1 Time(s) push_entry = 'route 172.16.100.0 255.255.254.0': 1 Time(s) push_entry = 'topology p2p': 1 Time(s) push_ifconfig_defined = DISABLED: 1 Time(s) push_ifconfig_local = 0.0.0.0: 1 Time(s) push_ifconfig_remote_netmask = 0.0.0.0: 1 Time(s) push_peer_info = DISABLED: 1 Time(s) rcvbuf = 65536: 1 Time(s) real_hash_size = 256: 1 Time(s) remap_sigusr1 = 0: 1 Time(s) remote = '[UNDEF]': 1 Time(s) remote_cert_eku = '[UNDEF]': 1 Time(s) remote_cert_ku[i] = 0: 11 Time(s) remote_float = DISABLED: 1 Time(s) remote_port = 1194: 1 Time(s) remote_random = DISABLED: 1 Time(s) renegotiate_bytes = 0: 1 Time(s) renegotiate_packets = 0: 1 Time(s) renegotiate_seconds = 3600: 1 Time(s) replay = ENABLED: 1 Time(s) replay_time = 15: 1 Time(s) replay_window = 64: 1 Time(s) resolve_retry_seconds = 1000000000: 1 Time(s) route 172.16.100.0/255.255.254.0/nil/nil: 1 Time(s) route_default_gateway = '[UNDEF]': 1 Time(s) route_default_metric = 0: 1 Time(s) route_delay = 0: 1 Time(s) route_delay_defined = DISABLED: 1 Time(s) route_delay_window = 30: 1 Time(s) route_gateway_via_dhcp = DISABLED: 1 Time(s) route_noexec = DISABLED: 1 Time(s) route_nopull = DISABLED: 1 Time(s) route_script = '[UNDEF]': 1 Time(s) selinux_context = '[UNDEF]': 1 Time(s) server_bridge_ip = 0.0.0.0: 1 Time(s) server_bridge_netmask = 0.0.0.0: 1 Time(s) server_bridge_pool_end = 0.0.0.0: 1 Time(s) server_bridge_pool_start = 0.0.0.0: 1 Time(s) server_netmask = 255.255.254.0: 1 Time(s) server_network = 172.16.100.0: 1 Time(s) shaper = 0: 1 Time(s) shared_secret_file = '[UNDEF]': 1 Time(s) show_ciphers = DISABLED: 1 Time(s) show_digests = DISABLED: 1 Time(s) show_engines = DISABLED: 1 Time(s) show_tls_ciphers = DISABLED: 1 Time(s) single_session = DISABLED: 1 Time(s) sndbuf = 65536: 1 Time(s) sockflags = 0: 1 Time(s) socks_proxy_port = 0: 1 Time(s) socks_proxy_retry = DISABLED: 1 Time(s) socks_proxy_server = '[UNDEF]': 1 Time(s) ssl_flags = 0: 1 Time(s) status_file = '/var/log/openvpn-status.log': 1 Time(s) status_file_update_freq = 60: 1 Time(s) status_file_version = 1: 1 Time(s) suppress_timestamps = DISABLED: 1 Time(s) tcp_queue_limit = 64: 1 Time(s) test_crypto = DISABLED: 1 Time(s) tls_auth_file = '[UNDEF]': 1 Time(s) tls_client = DISABLED: 1 Time(s) tls_exit = DISABLED: 1 Time(s) tls_remote = '[UNDEF]': 1 Time(s) tls_server = ENABLED: 1 Time(s) tls_timeout = 2: 1 Time(s) tls_verify = '[UNDEF]': 1 Time(s) tmp_dir = '[UNDEF]': 1 Time(s) topology = 2: 1 Time(s) transition_window = 3600: 1 Time(s) tun_ipv6 = DISABLED: 1 Time(s) tun_mtu = 1500: 1 Time(s) tun_mtu_defined = ENABLED: 1 Time(s) tun_mtu_extra = 0: 1 Time(s) tun_mtu_extra_defined = DISABLED: 1 Time(s) up_delay = DISABLED: 1 Time(s) up_restart = DISABLED: 1 Time(s) up_script = '[UNDEF]': 1 Time(s) use_iv = ENABLED: 1 Time(s) username = 'nobody': 1 Time(s) verbosity = 5: 1 Time(s) virtual_hash_size = 256: 1 Time(s) writepid = '/var/run/openvpn/openvpn.pid': 1 Time(s) Common Name,Real Address,Bytes Received,Bytes Sent,Connected Since: 1 Time(s) Connection profiles END: 1 Time(s) Connection profiles [default]:: 1 Time(s) Current Parameter Settings:: 1 Time(s) END: 1 Time(s) ERROR: Linux route delete command failed: external program exited with error status: 2: 1 Time(s) GLOBAL STATS: 1 Time(s) Linux ip addr del failed: external program exited with error status: 2: 1 Time(s) Listening for incoming TCP connection on [undef]:1194: 1 Time(s) MULTI: TCP INIT maxclients=1024 maxevents=1028: 1 Time(s) Max bcast/mcast queue length,0: 1 Time(s) NOTE: the current --script-security setting may allow this configuration to call user-defined scripts: 1 Time(s) OpenVPN CLIENT LIST: 1 Time(s) ROUTE default_gateway=140.221.76.1: 1 Time(s) ROUTING TABLE: 1 Time(s) SIGTERM[hard,] received, process exiting: 1 Time(s) Socket Buffers: R=[87380->131072] S=[16384->131072]: 1 Time(s) TCPv4_SERVER link local (bound): [undef]:1194: 1 Time(s) TCPv4_SERVER link remote: [undef]: 1 Time(s) TUN/TAP TX queue length set to 100: 1 Time(s) Updated,Mon Aug 5 15:42:04 2013: 1 Time(s) Virtual Address,Common Name,Real Address,Last Ref: 1 Time(s) WARNING: --ifconfig-pool-persist will not work with --duplicate-cn: 1 Time(s) ---------------------- OpenVPN End ------------------------- --------------------- pam_unix Begin ------------------------ runuser: Unknown Entries: session closed for user root: 1 Time(s) session opened for user root by (uid=0): 1 Time(s) sshd: Authentication Failures: unknown (anlscan8.cspo.anl.gov): 2 Time(s) Invalid Users: Unknown Account: 2 Time(s) su: Sessions Opened: jbischof(uid=0) -> mgrastprod: 6 Time(s) sudo: Authentication Failures: jbischof(0) -> jbischof: 10 Time(s) jared(0) -> jared: 1 Time(s) jbischof(0) -> mgrastprod: 1 Time(s) Unknown Entries: auth could not identify password for [mgrastprod]: 1 Time(s) conversation failed: 1 Time(s) ---------------------- pam_unix End ------------------------- --------------------- postfix Begin ------------------------ 9591942 bytes transferred 2875 messages sent 2875 messages removed from queue **Unmatched Entries** 53B80140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.1, delays=0.01/0/0.08/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 53B80140192: sender non-delivery notification: 696A8140193 C15C7140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C15C7140192: sender non-delivery notification: C6719140193 43108140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 43108140192: sender non-delivery notification: 48E17140193 A014F140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A014F140192: sender non-delivery notification: A485A140193 25BD5140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 25BD5140192: sender non-delivery notification: 2ABC5140193 86C4E140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.01/0/0.01/0.03, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 86C4E140192: sender non-delivery notification: 912C5140193 0D48D140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 0D48D140192: sender non-delivery notification: 12461140193 6B932140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6B932140192: sender non-delivery notification: 70CAE140193 E34F4140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) E34F4140192: sender non-delivery notification: E73D8140193 66E87140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 66E87140192: sender non-delivery notification: 6BA6D140193 C6189140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C6189140192: sender non-delivery notification: CA98D140193 49F96140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 49F96140192: sender non-delivery notification: 4EFE6140193 A8E3B140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.03/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A8E3B140192: sender non-delivery notification: B1986140193 2A9E8140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.01/0/0.03/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 2A9E8140192: sender non-delivery notification: 35AE6140193 BEF1A140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.11, delays=0.01/0/0.09/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) BEF1A140192: sender non-delivery notification: D8190140193 694D3140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.2, delays=0.02/0/0.18/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 694D3140192: sender non-delivery notification: 96FD8140193 C698E140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.03/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C698E140192: sender non-delivery notification: CF691140193 4C276140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 4C276140192: sender non-delivery notification: 5124A140193 ACCCC140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) ACCCC140192: sender non-delivery notification: B183F140193 332A4140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 332A4140192: sender non-delivery notification: 38160140193 97E98140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 97E98140192: sender non-delivery notification: 9CC44140193 1D83A140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 1D83A140192: sender non-delivery notification: 22ADE140193 7B8B9140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7B8B9140192: sender non-delivery notification: 81482140193 01007140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 01007140192: sender non-delivery notification: 060BF140193 5FBA3140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 5FBA3140192: sender non-delivery notification: 6523A140193 D6F79140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D6F79140192: sender non-delivery notification: DC3D8140193 5CD81140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 5CD81140192: sender non-delivery notification: 61B37140193 BEFFB140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) BEFFB140192: sender non-delivery notification: C3C4F140193 42B27140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 42B27140192: sender non-delivery notification: 4792D140193 A233E140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A233E140192: sender non-delivery notification: A7110140193 2577A140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 2577A140192: sender non-delivery notification: 2A497140193 83C29140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 83C29140192: sender non-delivery notification: 888BF140193 0749B140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 0749B140192: sender non-delivery notification: 0BD18140193 821BA140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.15, delays=0.13/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 821BA140192: sender non-delivery notification: 86AF6140193 06874140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 06874140192: sender non-delivery notification: 0E6AD140193 64F70140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 64F70140192: sender non-delivery notification: 69A2E140193 DF51C140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) DF51C140192: sender non-delivery notification: E3C66140193 62F6C140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 62F6C140192: sender non-delivery notification: 68301140193 EF0CD140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.26, delays=0.01/0/0.23/0.02, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) EF0CD140192: sender non-delivery notification: 378FF140193 7D80D140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.09, delays=0.06/0/0.02/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7D80D140192: sender non-delivery notification: 86B02140193 DDE45140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) DDE45140192: sender non-delivery notification: E29FC140193 6FF9B140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6FF9B140192: sender non-delivery notification: 74AAB140193 CCE95140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) CCE95140192: sender non-delivery notification: D1A25140193 527D8140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 527D8140192: sender non-delivery notification: 57484140193 B1D54140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B1D54140192: sender non-delivery notification: B71F3140193 3558E140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 3558E140192: sender non-delivery notification: 3A8B3140193 96BF6140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.02/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 96BF6140192: sender non-delivery notification: 9E964140193 36BB8140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 36BB8140192: sender non-delivery notification: 3B7DC140193 95E23140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 95E23140192: sender non-delivery notification: 9A638140193 19AA6140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 19AA6140192: sender non-delivery notification: 1EB3C140193 7909D140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7909D140192: sender non-delivery notification: 7DCF7140193 F07A6140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) F07A6140192: sender non-delivery notification: 02497140193 764B2140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 764B2140192: sender non-delivery notification: 7BBF2140193 D5418140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D5418140192: sender non-delivery notification: D9AFA140193 5B742140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 5B742140192: sender non-delivery notification: 60994140193 BA7E1140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) BA7E1140192: sender non-delivery notification: BF5AF140193 52997140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 52997140192: sender non-delivery notification: 5726B140193 B195A140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B195A140192: sender non-delivery notification: B63C3140193 3ADF7140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 3ADF7140192: sender non-delivery notification: 41043140193 9AE6D140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 9AE6D140192: sender non-delivery notification: A11F6140193 287B3140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 287B3140192: sender non-delivery notification: 2D294140193 A1578140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.28, delays=0.02/0/0.25/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A1578140192: sender non-delivery notification: E2AE0140193 24F3E140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.08, delays=0.01/0/0.06/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 24F3E140192: sender non-delivery notification: 36478140193 823B5140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 823B5140192: sender non-delivery notification: 86FC0140193 39980140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 39980140192: sender non-delivery notification: 3E431140193 99BB2140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 99BB2140192: sender non-delivery notification: 9E48F140193 2184B140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 2184B140192: sender non-delivery notification: 2731B140193 82F97140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.02/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 82F97140192: sender non-delivery notification: 8B0F9140193 06CF8140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 06CF8140192: sender non-delivery notification: 0B900140193 65909140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 65909140192: sender non-delivery notification: 6AA25140193 DF45D140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.02/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) DF45D140192: sender non-delivery notification: E5C1F140193 62E38140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 62E38140192: sender non-delivery notification: 67FEF140193 C4400140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C4400140192: sender non-delivery notification: C9259140193 4F4D3140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.09, delays=0.04/0/0.05/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 4F4D3140192: sender non-delivery notification: 5D614140193 AF25B140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) AF25B140192: sender non-delivery notification: B3A1F140193 32C64140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 32C64140192: sender non-delivery notification: 383E1140193 91EBB140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 91EBB140192: sender non-delivery notification: 9A3D9140193 4A48B140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.01/0/0.01/0.02, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 4A48B140192: sender non-delivery notification: 54426140193 A74F4140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A74F4140192: sender non-delivery notification: AB9C5140193 2D393140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 2D393140192: sender non-delivery notification: 33C9F140193 9897C140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 9897C140192: sender non-delivery notification: 9D581140193 1E2DE140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 1E2DE140192: sender non-delivery notification: 23BE2140193 7D636140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7D636140192: sender non-delivery notification: 81E11140193 5676C140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.24, delays=0.01/0/0.21/0.02, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 5676C140192: sender non-delivery notification: 8F70F140193 B5B35140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B5B35140192: sender non-delivery notification: BA984140193 375F8140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 375F8140192: sender non-delivery notification: 3DAA5140193 96452140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 96452140192: sender non-delivery notification: 9B574140193 1C2E4140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 1C2E4140192: sender non-delivery notification: 21452140193 7B9BF140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.07, delays=0.02/0/0.05/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7B9BF140192: sender non-delivery notification: 8A951140193 00E9B140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 00E9B140192: sender non-delivery notification: 05B08140193 60733140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 60733140192: sender non-delivery notification: 65AB0140193 D3F2B140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D3F2B140192: sender non-delivery notification: D9869140193 57CE4140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 57CE4140192: sender non-delivery notification: 5E33F140193 B7565140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.08, delays=0.02/0/0.06/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B7565140192: sender non-delivery notification: C8B76140193 3AB5E140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 3AB5E140192: sender non-delivery notification: 3F81E140193 992A0140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 992A0140192: sender non-delivery notification: 9EE58140193 35E71140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 35E71140192: sender non-delivery notification: 3B07B140193 951E2140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 951E2140192: sender non-delivery notification: 9ABE9140193 1925B140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 1925B140192: sender non-delivery notification: 1EAA4140193 77453140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 77453140192: sender non-delivery notification: 7C1A5140193 EEFB3140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) EEFB3140192: sender non-delivery notification: 003DD140193 73939140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 73939140192: sender non-delivery notification: 78411140193 D2C6F140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D2C6F140192: sender non-delivery notification: D8137140193 56A9D140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 56A9D140192: sender non-delivery notification: 5B502140193 B5A14140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B5A14140192: sender non-delivery notification: BA69D140193 40554140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 40554140192: sender non-delivery notification: 4501E140193 A0578140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A0578140192: sender non-delivery notification: A4FD7140193 572E1140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 572E1140192: sender non-delivery notification: 5D2AC140193 B728F140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B728F140192: sender non-delivery notification: BCA5C140193 3ABC3140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 3ABC3140192: sender non-delivery notification: 3F225140193 982CC140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.01/0/0.03/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 982CC140192: sender non-delivery notification: A35A0140193 1BA98140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 1BA98140192: sender non-delivery notification: 20880140193 7A385140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7A385140192: sender non-delivery notification: 7E829140193 F2295140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) F2295140192: sender non-delivery notification: 0264E140193 760DD140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 760DD140192: sender non-delivery notification: 7B465140193 D5227140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D5227140192: sender non-delivery notification: DA4B1140193 58CAB140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 58CAB140192: sender non-delivery notification: 5E501140193 B5CD4140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B5CD4140192: sender non-delivery notification: BAB2A140193 378C3140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 378C3140192: sender non-delivery notification: 3D067140193 94AA7140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 94AA7140192: sender non-delivery notification: 9929C140193 4B824140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 4B824140192: sender non-delivery notification: 512D7140193 AC50F140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) AC50F140192: sender non-delivery notification: B1B03140193 38539140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 38539140192: sender non-delivery notification: 3E5BF140193 975E2140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 975E2140192: sender non-delivery notification: 9C452140193 191C5140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 191C5140192: sender non-delivery notification: 1E580140193 78510140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 78510140192: sender non-delivery notification: 7E0B3140193 03FB3140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 03FB3140192: sender non-delivery notification: 09B37140193 699E9140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 699E9140192: sender non-delivery notification: 6ED77140193 2420F140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.18, delays=0.02/0/0.16/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 2420F140192: sender non-delivery notification: 4D377140193 B98F7140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B98F7140192: sender non-delivery notification: BDE0A140193 4403E140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 4403E140192: sender non-delivery notification: 48AD8140193 A32D2140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A32D2140192: sender non-delivery notification: A85B1140193 2E024140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.02/0/0.03/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 2E024140192: sender non-delivery notification: 38B8B140193 927D6140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 927D6140192: sender non-delivery notification: 97293140193 1B460140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 1B460140192: sender non-delivery notification: 1FC0B140193 7D546140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7D546140192: sender non-delivery notification: 819D0140193 42311140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 42311140192: sender non-delivery notification: 48FA6140193 A2C43140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A2C43140192: sender non-delivery notification: A8E9A140193 5B028140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 5B028140192: sender non-delivery notification: 609D6140193 BD20E140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) BD20E140192: sender non-delivery notification: C23FC140193 42136140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 42136140192: sender non-delivery notification: 48398140193 A298D140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A298D140192: sender non-delivery notification: A7C62140193 28EBF140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 28EBF140192: sender non-delivery notification: 2DFC1140193 C63E6140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=5, delays=0.02/0/5/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C63E6140192: sender non-delivery notification: CD6CA140193 4EBCB140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.02/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 4EBCB140192: sender non-delivery notification: 54D38140193 B2111140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B2111140192: sender non-delivery notification: B7C64140193 379E0140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 379E0140192: sender non-delivery notification: 3C75E140193 99044140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 99044140192: sender non-delivery notification: 9D4ED140193 4F5BB140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 4F5BB140192: sender non-delivery notification: 548CF140193 B4865140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B4865140192: sender non-delivery notification: BB20A140193 428C3140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 428C3140192: sender non-delivery notification: 482CE140193 B9D10140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.21, delays=0.01/0/0.2/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B9D10140192: sender non-delivery notification: EB8F0140193 743B8140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 743B8140192: sender non-delivery notification: 7B982140193 D3A0E140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D3A0E140192: sender non-delivery notification: D80FF140193 599D2140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 599D2140192: sender non-delivery notification: 5ED1E140193 B666C140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B666C140192: sender non-delivery notification: BB26F140193 38C93140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.08, delays=0.02/0/0.04/0.03, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 38C93140192: sender non-delivery notification: 48FBC140193 95316140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 95316140192: sender non-delivery notification: 99EF5140193 1CD42140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.06, delays=0.01/0/0.04/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 1CD42140192: sender non-delivery notification: 29AE4140193 79F4A140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 79F4A140192: sender non-delivery notification: 7F789140193 F1D2E140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) F1D2E140192: sender non-delivery notification: 01F07140193 73788140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 73788140192: sender non-delivery notification: 788D4140193 D0DAC140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D0DAC140192: sender non-delivery notification: D5BF7140193 52A89140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 52A89140192: sender non-delivery notification: 57507140193 E3E62140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) E3E62140192: sender non-delivery notification: E8F3C140193 6C3BA140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6C3BA140192: sender non-delivery notification: 71B8A140193 CF1BE140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) CF1BE140192: sender non-delivery notification: D5FF8140193 5977C140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 5977C140192: sender non-delivery notification: 5EF36140193 BA832140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) BA832140192: sender non-delivery notification: BFF5C140193 726F6140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.06, delays=0.04/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 726F6140192: sender non-delivery notification: 77A64140193 D2495140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D2495140192: sender non-delivery notification: D7E46140193 5C170140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 5C170140192: sender non-delivery notification: 60F99140193 BD54E140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) BD54E140192: sender non-delivery notification: C2192140193 443F2140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 443F2140192: sender non-delivery notification: 492E5140193 B7BCE140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.4, delays=0.02/0/0.37/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B7BCE140192: sender non-delivery notification: 216A5140193 3D952140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 3D952140192: sender non-delivery notification: 43AB2140193 9FB1A140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 9FB1A140192: sender non-delivery notification: A4C38140193 297EA140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 297EA140192: sender non-delivery notification: 2EF29140193 8B92B140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.09, delays=0.01/0/0.07/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 8B92B140192: sender non-delivery notification: 9E8F2140193 135AA140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 135AA140192: sender non-delivery notification: 188D6140193 74952140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 74952140192: sender non-delivery notification: 79334140193 F1586140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) F1586140192: sender non-delivery notification: 01B04140193 77ED3140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 77ED3140192: sender non-delivery notification: 7D600140193 D7265140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D7265140192: sender non-delivery notification: DE0A7140193 630EB140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.02/0/0.03/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 630EB140192: sender non-delivery notification: 6BCC3140193 C3911140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C3911140192: sender non-delivery notification: CB366140193 49D32140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 49D32140192: sender non-delivery notification: 51356140193 A9074140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A9074140192: sender non-delivery notification: ADE60140193 65791140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 65791140192: sender non-delivery notification: 6B984140193 C4C69140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C4C69140192: sender non-delivery notification: CA3F2140193 508C1140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 508C1140192: sender non-delivery notification: 55132140193 B1916140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B1916140192: sender non-delivery notification: B6A4E140193 39579140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 39579140192: sender non-delivery notification: 3E34E140193 9696A140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 9696A140192: sender non-delivery notification: 9B39E140193 21855140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 21855140192: sender non-delivery notification: 26BAB140193 81B43140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 81B43140192: sender non-delivery notification: 87D42140193 23996140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.29, delays=0.01/0/0.27/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 23996140192: sender non-delivery notification: 68E4B140193 82D33140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 82D33140192: sender non-delivery notification: 8907C140193 0C840140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 0C840140192: sender non-delivery notification: 11B13140193 6BC98140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.01/0/0.02/0.03, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6BC98140192: sender non-delivery notification: 77A56140193 E7A28140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) E7A28140192: sender non-delivery notification: EC108140193 739A2140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 739A2140192: sender non-delivery notification: 78588140193 D2D4F140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D2D4F140192: sender non-delivery notification: D7DFD140193 5A5F2140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.15, delays=0.01/0/0.11/0.03, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 5A5F2140192: sender non-delivery notification: 7D3B6140193 BBB6E140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) BBB6E140192: sender non-delivery notification: C0B29140193 43A3F140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 43A3F140192: sender non-delivery notification: 48827140193 A6E76140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A6E76140192: sender non-delivery notification: AB722140193 2DA69140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 2DA69140192: sender non-delivery notification: 32D9C140193 8DA0D140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 8DA0D140192: sender non-delivery notification: 929AB140193 16A0B140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 16A0B140192: sender non-delivery notification: 1BFA1140193 78E03140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 78E03140192: sender non-delivery notification: 7D7FF140193 F2A4C140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) F2A4C140192: sender non-delivery notification: 032DF140193 7A350140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7A350140192: sender non-delivery notification: 7EACF140193 E3901140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) E3901140192: sender non-delivery notification: E829B140193 7CBEC140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7CBEC140192: sender non-delivery notification: 81BB2140193 E654A140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) E654A140192: sender non-delivery notification: EABA5140193 7BF19140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7BF19140192: sender non-delivery notification: 809C8140193 E1432140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) E1432140192: sender non-delivery notification: E6453140193 772FA140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 772FA140192: sender non-delivery notification: 7CE88140193 40116140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 40116140192: sender non-delivery notification: 4559E140193 BEE9F140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) BEE9F140192: sender non-delivery notification: C3D6C140193 557E1140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.02/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 557E1140192: sender non-delivery notification: 5CCEB140193 C0EA1140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C0EA1140192: sender non-delivery notification: C66D1140193 54658140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 54658140192: sender non-delivery notification: 59465140193 B9696140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B9696140192: sender non-delivery notification: BE1FE140193 4C0AB140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 4C0AB140192: sender non-delivery notification: 52E54140193 B35D0140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B35D0140192: sender non-delivery notification: B99FA140193 49361140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 49361140192: sender non-delivery notification: 4DA3B140193 B0A2A140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B0A2A140192: sender non-delivery notification: B5329140193 447B8140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 447B8140192: sender non-delivery notification: 4962C140193 A9EFB140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A9EFB140192: sender non-delivery notification: AEC21140193 3B98C140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 3B98C140192: sender non-delivery notification: 415B4140193 A30D6140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A30D6140192: sender non-delivery notification: A8F1B140193 36ECF140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 36ECF140192: sender non-delivery notification: 3C0F8140193 9C2F6140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.02/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 9C2F6140192: sender non-delivery notification: A31F9140193 3838A140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 3838A140192: sender non-delivery notification: 3D667140193 A42C3140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A42C3140192: sender non-delivery notification: AA976140193 3BC53140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 3BC53140192: sender non-delivery notification: 414CC140193 A10C0140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.01/0/0.03/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A10C0140192: sender non-delivery notification: AC2EF140193 28E77140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 28E77140192: sender non-delivery notification: 2E811140193 908A9140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 908A9140192: sender non-delivery notification: 95618140193 20329140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 20329140192: sender non-delivery notification: 25186140193 D5224140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=5.5, delays=0.19/0/5.2/0.08, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D5224140192: sender non-delivery notification: 2B5E9140193 92D6A140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 92D6A140192: sender non-delivery notification: 97855140193 255F7140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 255F7140192: sender non-delivery notification: 2B812140193 84C35140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 84C35140192: sender non-delivery notification: 89242140193 4732B140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.06, delays=0.02/0/0.01/0.04, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 4732B140192: sender non-delivery notification: 53B9E140193 AA8AF140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) AA8AF140192: sender non-delivery notification: AF916140193 3992E140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 3992E140192: sender non-delivery notification: 40662140193 A00D7140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A00D7140192: sender non-delivery notification: A4AC1140193 38C9C140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.25, delays=0.01/0/0.01/0.22, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 38C9C140192: sender non-delivery notification: 72B6B140193 A055C140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A055C140192: sender non-delivery notification: A5203140193 35575140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.02/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 35575140192: sender non-delivery notification: 3B8C1140193 9EB9F140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 9EB9F140192: sender non-delivery notification: A368C140193 25061140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 25061140192: sender non-delivery notification: 2B9DB140193 83836140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 83836140192: sender non-delivery notification: 887DE140193 1840B140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 1840B140192: sender non-delivery notification: 20169140193 7F889140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7F889140192: sender non-delivery notification: 85317140193 093E3140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 093E3140192: sender non-delivery notification: 0EF12140193 70763140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 70763140192: sender non-delivery notification: 770CD140193 00362140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 00362140192: sender non-delivery notification: 057F2140193 69CDC140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.06, delays=0.01/0/0.02/0.03, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 69CDC140192: sender non-delivery notification: 756BE140193 227A3140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 227A3140192: sender non-delivery notification: 29253140193 8DBE9140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 8DBE9140192: sender non-delivery notification: 92E8C140193 2B99E140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.02/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 2B99E140192: sender non-delivery notification: 3305E140193 BDEE7140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) BDEE7140192: sender non-delivery notification: C2B92140193 53F3A140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.42, delays=0.02/0/0.39/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 53F3A140192: sender non-delivery notification: B7812140193 C545C140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.02/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C545C140192: sender non-delivery notification: CC450140193 50E90140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 50E90140192: sender non-delivery notification: 56412140193 B033F140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B033F140192: sender non-delivery notification: B5914140193 4A68D140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 4A68D140192: sender non-delivery notification: 4F9DF140193 B1979140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.02/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B1979140192: sender non-delivery notification: B8F0B140193 311D5140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 311D5140192: sender non-delivery notification: 35C1D140193 94173140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 94173140192: sender non-delivery notification: 985C3140193 2829B140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 2829B140192: sender non-delivery notification: 2D135140193 90AEA140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.04/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 90AEA140192: sender non-delivery notification: 954F7140193 2BB23140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 2BB23140192: sender non-delivery notification: 33170140193 92CBF140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 92CBF140192: sender non-delivery notification: 97946140193 18C86140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 18C86140192: sender non-delivery notification: 1E6BB140193 85240140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.02/0/0.02/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 85240140192: sender non-delivery notification: 8F03C140193 1BDF6140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 1BDF6140192: sender non-delivery notification: 21F37140193 831C8140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 831C8140192: sender non-delivery notification: 88F1A140193 054EE140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 054EE140192: sender non-delivery notification: 0B0D2140193 74DC3140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 74DC3140192: sender non-delivery notification: 7CB27140193 4E48C140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.06, delays=0.05/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 4E48C140192: sender non-delivery notification: 54196140193 C0BD2140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C0BD2140192: sender non-delivery notification: C6CCB140193 5FB34140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.25, delays=0.02/0/0.22/0.02, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 5FB34140192: sender non-delivery notification: 9AEB5140193 D287C140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D287C140192: sender non-delivery notification: D750F140193 8FE72140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.37, delays=0.01/0/0.34/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 8FE72140192: sender non-delivery notification: E8B55140193 137A5140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 137A5140192: sender non-delivery notification: 18ACB140193 9F5E9140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 9F5E9140192: sender non-delivery notification: A41AE140193 4698A140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 4698A140192: sender non-delivery notification: 4BCF4140193 BA7F2140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) BA7F2140192: sender non-delivery notification: C03B6140193 5E7CA140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 5E7CA140192: sender non-delivery notification: 6409D140193 CDC9E140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) CDC9E140192: sender non-delivery notification: D2420140193 57DEE140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 57DEE140192: sender non-delivery notification: 5D6E4140193 2A096140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.08, delays=0.05/0/0.02/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 2A096140192: sender non-delivery notification: 32955140193 D10FB140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D10FB140192: sender non-delivery notification: D7C4A140193 56465140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 56465140192: sender non-delivery notification: 5AF7B140193 B3984140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.01/0/0.01/0.03, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B3984140192: sender non-delivery notification: BDF10140193 371EA140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 371EA140192: sender non-delivery notification: 3B8AB140193 98CA4140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 98CA4140192: sender non-delivery notification: 9E300140193 226D7140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.02/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 226D7140192: sender non-delivery notification: 2A34A140193 83347140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 83347140192: sender non-delivery notification: 88AEE140193 06C5A140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 06C5A140192: sender non-delivery notification: 0C2B6140193 6669D140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6669D140192: sender non-delivery notification: 6B995140193 04B0E140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.03/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 04B0E140192: sender non-delivery notification: 0B8A1140193 636A0140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 636A0140192: sender non-delivery notification: 684F4140193 E15E3140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) E15E3140192: sender non-delivery notification: E6182140193 69270140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 69270140192: sender non-delivery notification: 6DDEC140193 CE6A3140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.21, delays=0.01/0/0.19/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) CE6A3140192: sender non-delivery notification: 0C2BC140193 B9B18140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B9B18140192: sender non-delivery notification: BEA0A140193 28E27140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 28E27140192: sender non-delivery notification: 2DD9D140193 A0BE3140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A0BE3140192: sender non-delivery notification: A550D140193 2C24E140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 2C24E140192: sender non-delivery notification: 312C6140193 8BAB6140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 8BAB6140192: sender non-delivery notification: 9024D140193 3C5C6140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 3C5C6140192: sender non-delivery notification: 43C3A140193 08953140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.07, delays=0.05/0/0.02/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 08953140192: sender non-delivery notification: 110C6140193 A18C8140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.02/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A18C8140192: sender non-delivery notification: A9761140193 E42D4140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) E42D4140192: sender non-delivery notification: EAFE5140193 71B89140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 71B89140192: sender non-delivery notification: 7932B140193 40F50140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 40F50140192: sender non-delivery notification: 45A9B140193 3861E140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.08, delays=0.06/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 3861E140192: sender non-delivery notification: 3E47B140193 F34D3140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) F34D3140192: sender non-delivery notification: 047A3140193 88909140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.12, delays=0.1/0/0.02/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 88909140192: sender non-delivery notification: 904DB140193 571C0140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.02/0/0.02/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 571C0140192: sender non-delivery notification: 5EB83140193 03C17140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.02/0/0.03/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 03C17140192: sender non-delivery notification: 0E8D9140193 B7084140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.1, delays=0.07/0/0.02/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B7084140192: sender non-delivery notification: BEF2D140193 42F3C140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 42F3C140192: sender non-delivery notification: 478F8140193 DD0BD140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) DD0BD140192: sender non-delivery notification: E2776140193 63423140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 63423140192: sender non-delivery notification: 6827C140193 F300E140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) F300E140192: sender non-delivery notification: 044BC140193 7D4B6140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7D4B6140192: sender non-delivery notification: 82FA6140193 1B036140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.16, delays=0.01/0/0.14/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 1B036140192: sender non-delivery notification: 40798140193 8EBEF140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 8EBEF140192: sender non-delivery notification: 93B8E140193 8BFAC140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.02/0/0.02/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 8BFAC140192: sender non-delivery notification: 947D2140193 EFE38140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) EFE38140192: sender non-delivery notification: 00BF5140193 07400140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 07400140192: sender non-delivery notification: 0E412140193 667B2140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 667B2140192: sender non-delivery notification: 6BB33140193 43C3D140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.01/0/0.01/0.03, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 43C3D140192: sender non-delivery notification: 4ECF8140193 AB3CE140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) AB3CE140192: sender non-delivery notification: B031B140193 9E936140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 9E936140192: sender non-delivery notification: A5873140193 0FB8C140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 0FB8C140192: sender non-delivery notification: 149B2140193 D8E46140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.02/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D8E46140192: sender non-delivery notification: E0D71140193 62D33140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 62D33140192: sender non-delivery notification: 67D7A140193 0AD02140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 0AD02140192: sender non-delivery notification: 1040B140193 8279D140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 8279D140192: sender non-delivery notification: 87617140193 4D186140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 4D186140192: sender non-delivery notification: 53CB2140193 AE80F140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) AE80F140192: sender non-delivery notification: B2EC7140193 A05BE140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A05BE140192: sender non-delivery notification: A63CF140193 0EC5B140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 0EC5B140192: sender non-delivery notification: 13F3D140193 DE6DC140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) DE6DC140192: sender non-delivery notification: E571C140193 66372140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 66372140192: sender non-delivery notification: 6C5EE140193 085E0140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 085E0140192: sender non-delivery notification: 0EC8A140193 7D55F140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7D55F140192: sender non-delivery notification: 818A8140193 8D6FF140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.07, delays=0.05/0/0.02/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 8D6FF140192: sender non-delivery notification: 9486B140193 EF5ED140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) EF5ED140192: sender non-delivery notification: F40EB140193 DC994140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) DC994140192: sender non-delivery notification: E2B45140193 4D238140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 4D238140192: sender non-delivery notification: 52F09140193 21F85140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 21F85140192: sender non-delivery notification: 27CDD140193 83693140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 83693140192: sender non-delivery notification: 88215140193 893C4140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.07, delays=0.03/0/0.01/0.03, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 893C4140192: sender non-delivery notification: 93857140193 EF8C5140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) EF8C5140192: sender non-delivery notification: 0125A140193 0739F140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.02/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 0739F140192: sender non-delivery notification: 0E41E140193 8730E140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 8730E140192: sender non-delivery notification: 8D11B140193 0FA1B140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 0FA1B140192: sender non-delivery notification: 140A6140193 6F1B7140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6F1B7140192: sender non-delivery notification: 73BA8140193 82BFE140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 82BFE140192: sender non-delivery notification: 8861A140193 EC379140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) EC379140192: sender non-delivery notification: F1009140193 6FEB0140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6FEB0140192: sender non-delivery notification: 75BF4140193 D2B5B140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D2B5B140192: sender non-delivery notification: D7246140193 5ACDC140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 5ACDC140192: sender non-delivery notification: 5FDD6140193 BBF54140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) BBF54140192: sender non-delivery notification: C1515140193 476A2140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 476A2140192: sender non-delivery notification: 4BD25140193 AB527140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) AB527140192: sender non-delivery notification: B0401140193 35CBB140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 35CBB140192: sender non-delivery notification: 3A60B140193 D6F6C140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.06, delays=0.02/0/0.03/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D6F6C140192: sender non-delivery notification: E248F140193 5C658140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 5C658140192: sender non-delivery notification: 617BD140193 D24F5140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.07, delays=0.01/0/0.05/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D24F5140192: sender non-delivery notification: E224C140193 151DB140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.42, delays=0.01/0/0.4/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 151DB140192: sender non-delivery notification: 7A947140193 D3B9C140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.02/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D3B9C140192: sender non-delivery notification: DA9BF140193 07FE1140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 07FE1140192: sender non-delivery notification: 0F8B5140193 AA552140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) AA552140192: sender non-delivery notification: B244F140193 DD060140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.02/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) DD060140192: sender non-delivery notification: E43A1140193 8D8D6140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 8D8D6140192: sender non-delivery notification: 93849140193 EC727140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) EC727140192: sender non-delivery notification: F0EBC140193 7243A140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7243A140192: sender non-delivery notification: 77E28140193 CF949140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) CF949140192: sender non-delivery notification: D5761140193 B12A5140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.03/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B12A5140192: sender non-delivery notification: B7C55140193 218FF140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 218FF140192: sender non-delivery notification: 26FA3140193 E0DF5140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.02/0/0.03/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) E0DF5140192: sender non-delivery notification: EA5CA140193 68254140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.07, delays=0.02/0/0.02/0.03, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 68254140192: sender non-delivery notification: 756AF140193 C7DFF140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C7DFF140192: sender non-delivery notification: CEF4A140193 B56B6140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B56B6140192: sender non-delivery notification: BB526140193 59912140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.02/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 59912140192: sender non-delivery notification: 5FFCA140193 C9169140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C9169140192: sender non-delivery notification: CF28E140193 B17CA140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B17CA140192: sender non-delivery notification: B966C140193 54970140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 54970140192: sender non-delivery notification: 5C2AC140193 C5D0D140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C5D0D140192: sender non-delivery notification: CBFC2140193 CEF27140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.02/0/0.03/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) CEF27140192: sender non-delivery notification: D7FDA140193 3D57E140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 3D57E140192: sender non-delivery notification: 4349A140193 E3D52140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.15, delays=0.02/0/0.13/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) E3D52140192: sender non-delivery notification: 11A47140193 68418140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.17, delays=0.03/0/0.14/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 68418140192: sender non-delivery notification: 8D2D3140193 C6786140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C6786140192: sender non-delivery notification: CABAC140193 7D350140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7D350140192: sender non-delivery notification: 81E29140193 DD1D4140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) DD1D4140192: sender non-delivery notification: E4211140193 61EDD140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.07, delays=0.02/0/0.05/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 61EDD140192: sender non-delivery notification: 70302140193 606FF140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 606FF140192: sender non-delivery notification: 66159140193 DC0D3140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) DC0D3140192: sender non-delivery notification: E2B92140193 61C48140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 61C48140192: sender non-delivery notification: 66668140193 C0ABB140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C0ABB140192: sender non-delivery notification: C54CD140193 4475E140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 4475E140192: sender non-delivery notification: 4978E140193 A3BA8140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A3BA8140192: sender non-delivery notification: AA36F140193 294A1140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 294A1140192: sender non-delivery notification: 2E69C140193 88A18140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 88A18140192: sender non-delivery notification: 8FF69140193 0C137140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 0C137140192: sender non-delivery notification: 1125E140193 6B590140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6B590140192: sender non-delivery notification: 709CF140193 E0D15140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) E0D15140192: sender non-delivery notification: E5EAD140193 64C25140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 64C25140192: sender non-delivery notification: 6D26F140193 C190E140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C190E140192: sender non-delivery notification: C6C44140193 451A1140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 451A1140192: sender non-delivery notification: 4B387140193 A29E2140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.01/0/0.01/0.03, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A29E2140192: sender non-delivery notification: AD51C140193 2880F140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 2880F140192: sender non-delivery notification: 2E8D2140193 87B3F140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 87B3F140192: sender non-delivery notification: 8C421140193 1F97A140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.08, delays=0.01/0/0.06/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 1F97A140192: sender non-delivery notification: 30B1C140193 7F9CC140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.06, delays=0.02/0/0.02/0.03, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7F9CC140192: sender non-delivery notification: 8AF0A140193 02550140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 02550140192: sender non-delivery notification: 074C9140193 61E1D140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 61E1D140192: sender non-delivery notification: 670F7140193 D955B140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D955B140192: sender non-delivery notification: DD91E140193 5E641140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 5E641140192: sender non-delivery notification: 62D76140193 BC69C140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) BC69C140192: sender non-delivery notification: C0D41140193 40126140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 40126140192: sender non-delivery notification: 470BC140193 9EFC5140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 9EFC5140192: sender non-delivery notification: A3536140193 22404140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.02/0/0.01/0.03, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 22404140192: sender non-delivery notification: 2CB2B140193 82195140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 82195140192: sender non-delivery notification: 86902140193 07E12140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.06, delays=0.02/0/0.03/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 07E12140192: sender non-delivery notification: 13CAE140193 695D8140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 695D8140192: sender non-delivery notification: 6D64D140193 E0CF5140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) E0CF5140192: sender non-delivery notification: E60F1140193 67990140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 67990140192: sender non-delivery notification: 6CC2E140193 C6D58140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C6D58140192: sender non-delivery notification: CB8FE140193 4A74F140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 4A74F140192: sender non-delivery notification: 4F911140193 A8B2F140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A8B2F140192: sender non-delivery notification: ACFB4140193 2B195140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 2B195140192: sender non-delivery notification: 31009140193 89C8F140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 89C8F140192: sender non-delivery notification: 8F41A140193 0D767140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 0D767140192: sender non-delivery notification: 12AB5140193 6C675140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6C675140192: sender non-delivery notification: 7100A140193 E2A36140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) E2A36140192: sender non-delivery notification: E7AC2140193 68017140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 68017140192: sender non-delivery notification: 6D928140193 E8541140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.43, delays=0.01/0/0.4/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) E8541140192: sender non-delivery notification: 59F93140193 6B90A140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6B90A140192: sender non-delivery notification: 71956140193 C8C73140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C8C73140192: sender non-delivery notification: CD350140193 508F7140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.01/0/0.01/0.03, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 508F7140192: sender non-delivery notification: 5B2F0140193 B1BE9140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B1BE9140192: sender non-delivery notification: B6FCE140193 37B29140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 37B29140192: sender non-delivery notification: 3CC55140193 987F2140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 987F2140192: sender non-delivery notification: 9C753140193 1C15C140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 1C15C140192: sender non-delivery notification: 210C7140193 7970D140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7970D140192: sender non-delivery notification: 7DE9C140193 F15A8140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) F15A8140192: sender non-delivery notification: 01EB9140193 74C0B140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 74C0B140192: sender non-delivery notification: 79D47140193 D3FDB140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D3FDB140192: sender non-delivery notification: D9DB3140193 5BBCD140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 5BBCD140192: sender non-delivery notification: 604BA140193 C144D140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C144D140192: sender non-delivery notification: C6342140193 42F9B140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 42F9B140192: sender non-delivery notification: 4A4B0140193 A39ED140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.02/0/0.01/0.02, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A39ED140192: sender non-delivery notification: AD827140193 45D48140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 45D48140192: sender non-delivery notification: 4AF90140193 A50C4140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A50C4140192: sender non-delivery notification: AC398140193 84E2B140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.02/0/0.03/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 84E2B140192: sender non-delivery notification: 8E07F140193 E5D35140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) E5D35140192: sender non-delivery notification: EBFD3140193 696F5140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 696F5140192: sender non-delivery notification: 6E2CD140193 C8278140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C8278140192: sender non-delivery notification: CCC19140193 6F3BD140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.13, delays=0.01/0/0.11/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6F3BD140192: sender non-delivery notification: 8C4CF140193 CE315140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) CE315140192: sender non-delivery notification: D27CF140193 521F9140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 521F9140192: sender non-delivery notification: 578D9140193 B1599140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B1599140192: sender non-delivery notification: B637F140193 35064140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 35064140192: sender non-delivery notification: 3A66D140193 94030140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 94030140192: sender non-delivery notification: 9A0B8140193 14F03140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 14F03140192: sender non-delivery notification: 19FD3140193 73301140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 73301140192: sender non-delivery notification: 797A4140193 EAE4F140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) EAE4F140192: sender non-delivery notification: EF902140193 6EAAF140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6EAAF140192: sender non-delivery notification: 73FEE140193 CC679140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) CC679140192: sender non-delivery notification: D1357140193 50188140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 50188140192: sender non-delivery notification: 54FF3140193 AF322140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) AF322140192: sender non-delivery notification: B43F4140193 32E1C140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 32E1C140192: sender non-delivery notification: 37C9F140193 A3968140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.1, delays=0.08/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A3968140192: sender non-delivery notification: A9637140193 25C58140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 25C58140192: sender non-delivery notification: 2AEFE140193 84A7A140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 84A7A140192: sender non-delivery notification: 8964A140193 08A3C140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 08A3C140192: sender non-delivery notification: 0E181140193 67A01140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.02/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 67A01140192: sender non-delivery notification: 6E50A140193 DF950140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) DF950140192: sender non-delivery notification: E72D2140193 6332E140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6332E140192: sender non-delivery notification: 69D2A140193 C28A0140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C28A0140192: sender non-delivery notification: C92FA140193 4611B140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 4611B140192: sender non-delivery notification: 4E4AA140193 E62BE140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.4, delays=0.01/0/0.38/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) E62BE140192: sender non-delivery notification: 52053140193 69D6B140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 69D6B140192: sender non-delivery notification: 71BED140193 C9084140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.02/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C9084140192: sender non-delivery notification: D015E140193 50C8C140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.02/0/0.03/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 50C8C140192: sender non-delivery notification: 5B72E140193 B00E1140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B00E1140192: sender non-delivery notification: B61EE140193 31AEA140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 31AEA140192: sender non-delivery notification: 38AD5140193 8F02F140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.01/0/0.03/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 8F02F140192: sender non-delivery notification: 9A740140193 3355C140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 3355C140192: sender non-delivery notification: 38ABC140193 90AD1140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 90AD1140192: sender non-delivery notification: 95A38140193 14007140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 14007140192: sender non-delivery notification: 19A9D140193 72B7B140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 72B7B140192: sender non-delivery notification: 77DD1140193 EAAB5140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) EAAB5140192: sender non-delivery notification: F09F1140193 6CD66140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6CD66140192: sender non-delivery notification: 71ABE140193 D4314140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.01/0/0.03/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D4314140192: sender non-delivery notification: DE627140193 58FC8140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 58FC8140192: sender non-delivery notification: 5E329140193 B921D140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B921D140192: sender non-delivery notification: BDE34140193 3CC14140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.02/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 3CC14140192: sender non-delivery notification: 44994140193 9BC36140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 9BC36140192: sender non-delivery notification: A29D3140193 4D9B0140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.06, delays=0.02/0/0.02/0.03, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 4D9B0140192: sender non-delivery notification: 5A837140193 ADAE9140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.02/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) ADAE9140192: sender non-delivery notification: B41E9140193 3389D140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 3389D140192: sender non-delivery notification: 39D2B140193 93CF0140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 93CF0140192: sender non-delivery notification: 99DF7140193 17139140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 17139140192: sender non-delivery notification: 1E41E140193 92EB7140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.41, delays=0.01/0/0.39/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 92EB7140192: sender non-delivery notification: 007C8140193 16834140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 16834140192: sender non-delivery notification: 1CD9E140193 76EF4140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 76EF4140192: sender non-delivery notification: 7D18D140193 EF55F140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.03/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) EF55F140192: sender non-delivery notification: 03154140193 72312140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 72312140192: sender non-delivery notification: 787BD140193 D22B8140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D22B8140192: sender non-delivery notification: D966F140193 55CBA140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 55CBA140192: sender non-delivery notification: 5D000140193 B4CCC140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B4CCC140192: sender non-delivery notification: BBD8E140193 385DB140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 385DB140192: sender non-delivery notification: 3E2A6140193 96950140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 96950140192: sender non-delivery notification: 9DBBF140193 1B1E1140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 1B1E1140192: sender non-delivery notification: 22BCE140193 787DE140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 787DE140192: sender non-delivery notification: 7DB07140193 EFF1F140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.02/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) EFF1F140192: sender non-delivery notification: 037B4140193 75C9C140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 75C9C140192: sender non-delivery notification: 7BD5B140193 D2FF4140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D2FF4140192: sender non-delivery notification: D7C95140193 60EE9140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.07, delays=0.02/0/0.05/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 60EE9140192: sender non-delivery notification: 6F63C140193 C1CFB140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C1CFB140192: sender non-delivery notification: C6CFD140193 45A97140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 45A97140192: sender non-delivery notification: 4A9AB140193 A4F39140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A4F39140192: sender non-delivery notification: A9EED140193 288C3140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 288C3140192: sender non-delivery notification: 2F7D5140193 85A57140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 85A57140192: sender non-delivery notification: 8A15C140193 076BB140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 076BB140192: sender non-delivery notification: 0DCFC140193 64CDE140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 64CDE140192: sender non-delivery notification: 6A2D0140193 ECD1B140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.42, delays=0.01/0/0.37/0.03, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) ECD1B140192: sender non-delivery notification: 5C91C140193 7033C140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7033C140192: sender non-delivery notification: 77388140193 CF76C140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.01/0/0.01/0.03, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) CF76C140192: sender non-delivery notification: D9741140193 534B9140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 534B9140192: sender non-delivery notification: 5997E140193 B08EB140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B08EB140192: sender non-delivery notification: B581D140193 341F1140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 341F1140192: sender non-delivery notification: 3A5FB140193 914FD140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 914FD140192: sender non-delivery notification: 97543140193 47D89140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 47D89140192: sender non-delivery notification: 4CB3F140193 A8457140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.1, delays=0.01/0/0.08/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A8457140192: sender non-delivery notification: BF140140193 2C2D3140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.02/0/0.03/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 2C2D3140192: sender non-delivery notification: 36392140193 8BCA4140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 8BCA4140192: sender non-delivery notification: 91966140193 13A2B140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 13A2B140192: sender non-delivery notification: 183F5140193 76E80140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.08, delays=0.02/0/0.06/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 76E80140192: sender non-delivery notification: 8747B140193 5E759140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 5E759140192: sender non-delivery notification: 63CEA140193 C209C140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C209C140192: sender non-delivery notification: C7A11140193 45863140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 45863140192: sender non-delivery notification: 4AB66140193 A6A65140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A6A65140192: sender non-delivery notification: AC399140193 34992140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.06, delays=0.04/0/0.02/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 34992140192: sender non-delivery notification: 3C240140193 38F77140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.07, delays=0.05/0/0.02/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 38F77140192: sender non-delivery notification: 3FDE0140193 BCBE3140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.1, delays=0.08/0/0.02/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) BCBE3140192: sender non-delivery notification: C4E97140193 3FAF2140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 3FAF2140192: sender non-delivery notification: 44D63140193 A7CD9140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A7CD9140192: sender non-delivery notification: ACE80140193 2B8D7140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 2B8D7140192: sender non-delivery notification: 30CB6140193 87A36140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 87A36140192: sender non-delivery notification: 8C8C5140193 22781140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.19, delays=0.01/0/0.17/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 22781140192: sender non-delivery notification: 4E5C5140193 81DFE140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 81DFE140192: sender non-delivery notification: 86A49140193 0DB78140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 0DB78140192: sender non-delivery notification: 1386C140193 6D034140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6D034140192: sender non-delivery notification: 7143B140193 E4326140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.02/0/0.03/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) E4326140192: sender non-delivery notification: EDC2A140193 642BE140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 642BE140192: sender non-delivery notification: 69015140193 C3997140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C3997140192: sender non-delivery notification: C851D140193 45425140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 45425140192: sender non-delivery notification: 4A5CE140193 A4363140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A4363140192: sender non-delivery notification: AA02E140193 282DA140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 282DA140192: sender non-delivery notification: 2D1CF140193 8B9E9140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 8B9E9140192: sender non-delivery notification: 90D1E140193 0B26E140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 0B26E140192: sender non-delivery notification: 10228140193 6D2CF140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6D2CF140192: sender non-delivery notification: 7169F140193 E40F5140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) E40F5140192: sender non-delivery notification: E8B70140193 69FD8140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 69FD8140192: sender non-delivery notification: 6EC21140193 C94D6140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C94D6140192: sender non-delivery notification: CE06B140193 6179A140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.06, delays=0.01/0/0.04/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6179A140192: sender non-delivery notification: 6D0DC140193 BE87E140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) BE87E140192: sender non-delivery notification: C2EA6140193 4266D140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 4266D140192: sender non-delivery notification: 47171140193 9F9AB140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 9F9AB140192: sender non-delivery notification: A5492140193 217E9140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 217E9140192: sender non-delivery notification: 26F79140193 7E911140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7E911140192: sender non-delivery notification: 82EBC140193 028C9140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 028C9140192: sender non-delivery notification: 07735140193 67DE2140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.4, delays=0.02/0/0.37/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 67DE2140192: sender non-delivery notification: C5A43140193 DFA2D140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) DFA2D140192: sender non-delivery notification: E5C2F140193 6288B140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6288B140192: sender non-delivery notification: 67E46140193 C2770140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C2770140192: sender non-delivery notification: C8B29140193 47E99140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 47E99140192: sender non-delivery notification: 4D1E3140193 A71E5140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A71E5140192: sender non-delivery notification: AF88D140193 2C5A4140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 2C5A4140192: sender non-delivery notification: 3154F140193 8BC50140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 8BC50140192: sender non-delivery notification: 91F10140193 1264E140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 1264E140192: sender non-delivery notification: 17361140193 70E1F140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 70E1F140192: sender non-delivery notification: 76258140193 E895C140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) E895C140192: sender non-delivery notification: ED43E140193 6D133140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6D133140192: sender non-delivery notification: 7213A140193 CB5B8140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) CB5B8140192: sender non-delivery notification: D0565140193 4F391140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 4F391140192: sender non-delivery notification: 54D3C140193 AD9BB140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) AD9BB140192: sender non-delivery notification: B3F3D140193 3837B140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 3837B140192: sender non-delivery notification: 3D036140193 98B69140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 98B69140192: sender non-delivery notification: 9D72F140193 1D005140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 1D005140192: sender non-delivery notification: 21ADE140193 7E9D9140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7E9D9140192: sender non-delivery notification: 85677140193 01C4E140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 01C4E140192: sender non-delivery notification: 0613D140193 61682140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 61682140192: sender non-delivery notification: 65CE3140193 D90D4140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D90D4140192: sender non-delivery notification: DD83D140193 5ECE3140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 5ECE3140192: sender non-delivery notification: 63758140193 D2856140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.41, delays=0.02/0/0.38/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D2856140192: sender non-delivery notification: 40420140193 58157140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 58157140192: sender non-delivery notification: 5D1A6140193 B7007140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.07, delays=0.02/0/0.04/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B7007140192: sender non-delivery notification: C4056140193 3B09F140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 3B09F140192: sender non-delivery notification: 3FC73140193 4EF9B140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.07, delays=0.05/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 4EF9B140192: sender non-delivery notification: 540E4140193 AE23D140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) AE23D140192: sender non-delivery notification: B282B140193 2DD90140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 2DD90140192: sender non-delivery notification: 32AE2140193 EEB9D140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) EEB9D140192: sender non-delivery notification: F362E140193 70533140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 70533140192: sender non-delivery notification: 75913140193 1631C140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 1631C140192: sender non-delivery notification: 1AA73140193 593DC140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.09, delays=0.07/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 593DC140192: sender non-delivery notification: 5FB86140193 0ECEB140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.1, delays=0.08/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 0ECEB140192: sender non-delivery notification: 1376A140193 6F322140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6F322140192: sender non-delivery notification: 7481F140193 D2A9B140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D2A9B140192: sender non-delivery notification: D783D140193 3DE13140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 3DE13140192: sender non-delivery notification: 42BCC140193 BBD83140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) BBD83140192: sender non-delivery notification: C00A8140193 97A52140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.06, delays=0.05/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 97A52140192: sender non-delivery notification: 9C0B2140193 0202C140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 0202C140192: sender non-delivery notification: 06BB2140193 6F6B8140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6F6B8140192: sender non-delivery notification: 73A74140193 D1224140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D1224140192: sender non-delivery notification: D5EDA140193 427BC140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 427BC140192: sender non-delivery notification: 473A3140193 B1F57140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B1F57140192: sender non-delivery notification: B6AE3140193 35A2C140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 35A2C140192: sender non-delivery notification: 3A863140193 964CE140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.19, delays=0.01/0/0.17/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 964CE140192: sender non-delivery notification: C30DF140193 6BF6E140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6BF6E140192: sender non-delivery notification: 70824140193 C9603140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C9603140192: sender non-delivery notification: CE1B0140193 A6CBF140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.07, delays=0.06/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A6CBF140192: sender non-delivery notification: AC7CF140193 159A2140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 159A2140192: sender non-delivery notification: 19E88140193 8766D140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 8766D140192: sender non-delivery notification: 8DC9D140193 0B3A9140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 0B3A9140192: sender non-delivery notification: 10DBB140193 6BB0B140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6BB0B140192: sender non-delivery notification: 70AD3140193 E4309140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) E4309140192: sender non-delivery notification: E9F14140193 67F20140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 67F20140192: sender non-delivery notification: 6CD2F140193 C7163140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C7163140192: sender non-delivery notification: CC0C9140193 49BBE140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 49BBE140192: sender non-delivery notification: 4F360140193 AC18F140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) AC18F140192: sender non-delivery notification: B0526140193 3218B140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 3218B140192: sender non-delivery notification: 365B6140193 66709140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 66709140192: sender non-delivery notification: 6D5D5140193 C49EC140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C49EC140192: sender non-delivery notification: C97D1140193 47A4A140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 47A4A140192: sender non-delivery notification: 4DC80140193 AE931140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) AE931140192: sender non-delivery notification: B34D3140193 1A6D2140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 1A6D2140192: sender non-delivery notification: 1F3E1140193 E3D05140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) E3D05140192: sender non-delivery notification: E8BD7140193 88710140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 88710140192: sender non-delivery notification: 8E4D0140193 18373140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.09, delays=0.08/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 18373140192: sender non-delivery notification: 1D47E140193 85530140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 85530140192: sender non-delivery notification: 8A0F6140193 895D0140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 895D0140192: sender non-delivery notification: 8F3C4140193 2105A140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.19, delays=0.01/0/0.17/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 2105A140192: sender non-delivery notification: 4DC9E140193 43A1C140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 43A1C140192: sender non-delivery notification: 48D8B140193 A07D1140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.12, delays=0.1/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A07D1140192: sender non-delivery notification: A5FB3140193 0F85B140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 0F85B140192: sender non-delivery notification: 14279140193 75150140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 75150140192: sender non-delivery notification: 79D24140193 35C30140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.09, delays=0.04/0/0.03/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 35C30140192: sender non-delivery notification: 4179E140193 00B41140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.02/0/0.01/0.03, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 00B41140192: sender non-delivery notification: 0AEAA140193 ACFE2140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) ACFE2140192: sender non-delivery notification: B198F140193 8FEC2140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 8FEC2140192: sender non-delivery notification: 94DAB140193 9287F140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.1, delays=0.08/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 9287F140192: sender non-delivery notification: 974C5140193 83943140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.04/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 83943140192: sender non-delivery notification: 8832E140193 2BFEA140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.03/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 2BFEA140192: sender non-delivery notification: 3147C140193 688D7140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.06, delays=0.04/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 688D7140192: sender non-delivery notification: 6D324140193 583AB140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 583AB140192: sender non-delivery notification: 5D061140193 85770140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.11, delays=0.09/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 85770140192: sender non-delivery notification: 8A940140193 E3D9E140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) E3D9E140192: sender non-delivery notification: E864A140193 9A72C140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 9A72C140192: sender non-delivery notification: 9FE1A140193 054C6140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 054C6140192: sender non-delivery notification: 0A65C140193 771CD140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 771CD140192: sender non-delivery notification: 7BA98140193 0793F140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 0793F140192: sender non-delivery notification: 0CA30140193 66473140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 66473140192: sender non-delivery notification: 6AED1140193 D6023140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D6023140192: sender non-delivery notification: DBCA9140193 6E04F140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.29, delays=0.01/0/0.26/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6E04F140192: sender non-delivery notification: B365C140193 92301140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.45, delays=0.02/0/0.41/0.02, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 92301140192: sender non-delivery notification: 08501140193 15E94140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 15E94140192: sender non-delivery notification: 1AC78140193 745B4140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 745B4140192: sender non-delivery notification: 78E14140193 ED27B140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) ED27B140192: sender non-delivery notification: F27D0140193 75D0B140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 75D0B140192: sender non-delivery notification: 7AC27140193 D5124140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D5124140192: sender non-delivery notification: DA55C140193 58AE4140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 58AE4140192: sender non-delivery notification: 5D509140193 BAFD2140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.06, delays=0.01/0/0.04/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) BAFD2140192: sender non-delivery notification: C7197140193 40D1E140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 40D1E140192: sender non-delivery notification: 46BB8140193 9FAC8140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 9FAC8140192: sender non-delivery notification: A5331140193 3AA35140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 3AA35140192: sender non-delivery notification: 3F0B0140193 99098140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 99098140192: sender non-delivery notification: 9D8BE140193 1EEE9140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.02/0/0.01/0.03, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 1EEE9140192: sender non-delivery notification: 291AB140193 7DFFB140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7DFFB140192: sender non-delivery notification: 834A3140193 02197140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 02197140192: sender non-delivery notification: 08C7D140193 62D34140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 62D34140192: sender non-delivery notification: 67970140193 DAAA6140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) DAAA6140192: sender non-delivery notification: DFF86140193 715BF140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 715BF140192: sender non-delivery notification: 75793140193 D0350140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D0350140192: sender non-delivery notification: D4EE3140193 53FFC140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 53FFC140192: sender non-delivery notification: 589BC140193 B3293140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B3293140192: sender non-delivery notification: B9141140193 38AC3140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 38AC3140192: sender non-delivery notification: 3D4E0140193 BA99D140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.42, delays=0.01/0/0.39/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) BA99D140192: sender non-delivery notification: 2A434140193 3E134140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 3E134140192: sender non-delivery notification: 42A9F140193 9B394140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 9B394140192: sender non-delivery notification: 9FC40140193 1F218140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 1F218140192: sender non-delivery notification: 24399140193 7DCA6140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7DCA6140192: sender non-delivery notification: 827CF140193 03CD1140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 03CD1140192: sender non-delivery notification: 0AA1B140193 62F31140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 62F31140192: sender non-delivery notification: 687B5140193 D6B38140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D6B38140192: sender non-delivery notification: DBA40140193 7903B140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7903B140192: sender non-delivery notification: 7D8D3140193 D8061140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D8061140192: sender non-delivery notification: DC648140193 6E0E7140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6E0E7140192: sender non-delivery notification: 73117140193 CD3BD140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) CD3BD140192: sender non-delivery notification: D20B0140193 83D68140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.09, delays=0.01/0/0.07/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 83D68140192: sender non-delivery notification: 96BDE140193 E3289140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) E3289140192: sender non-delivery notification: E7A09140193 6698E140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6698E140192: sender non-delivery notification: 6B895140193 C61A2140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C61A2140192: sender non-delivery notification: CAE77140193 45D8D140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 45D8D140192: sender non-delivery notification: 4B5B5140193 A8A59140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A8A59140192: sender non-delivery notification: ACA3D140193 2C74D140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 2C74D140192: sender non-delivery notification: 3166A140193 8B825140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 8B825140192: sender non-delivery notification: 907AA140193 0B219140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 0B219140192: sender non-delivery notification: 100AD140193 6E1C2140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6E1C2140192: sender non-delivery notification: 72D73140193 F2454140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) F2454140192: sender non-delivery notification: 02F1D140193 A6CA4140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.16, delays=0.01/0/0.14/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A6CA4140192: sender non-delivery notification: CBC8F140193 18C67140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 18C67140192: sender non-delivery notification: 1D901140193 87347140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 87347140192: sender non-delivery notification: 8B349140193 0D0AC140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 0D0AC140192: sender non-delivery notification: 11596140193 6FD8C140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6FD8C140192: sender non-delivery notification: 740CB140193 E7FF7140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) E7FF7140192: sender non-delivery notification: ECA62140193 6ABF8140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6ABF8140192: sender non-delivery notification: 6FB50140193 C898F140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C898F140192: sender non-delivery notification: CD2A6140193 4C60B140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 4C60B140192: sender non-delivery notification: 513BA140193 AB89C140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) AB89C140192: sender non-delivery notification: B0790140193 93CE9140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 93CE9140192: sender non-delivery notification: 993AE140193 F1F91140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) F1F91140192: sender non-delivery notification: 03469140193 7E7E6140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7E7E6140192: sender non-delivery notification: 87311140193 E3F3D140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) E3F3D140192: sender non-delivery notification: E9773140193 6DD2B140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6DD2B140192: sender non-delivery notification: 737C7140193 D471F140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D471F140192: sender non-delivery notification: D9660140193 5E830140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 5E830140192: sender non-delivery notification: 63332140193 C3547140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C3547140192: sender non-delivery notification: C7CF3140193 4DBE1140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 4DBE1140192: sender non-delivery notification: 52FF2140193 B3278140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B3278140192: sender non-delivery notification: B7EDC140193 3CACF140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 3CACF140192: sender non-delivery notification: 41878140193 096A8140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 096A8140192: sender non-delivery notification: 0DCA0140193 BE4F0140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.25, delays=0.01/0/0.2/0.03, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) BE4F0140192: sender non-delivery notification: 04E3B140193 7D8A0140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.2, delays=0.03/0/0.16/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7D8A0140192: sender non-delivery notification: A7850140193 E5A39140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) E5A39140192: sender non-delivery notification: E98FF140193 719C7140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 719C7140192: sender non-delivery notification: 75FEE140193 D755B140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D755B140192: sender non-delivery notification: DBDC2140193 6336F140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6336F140192: sender non-delivery notification: 6812F140193 C885E140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C885E140192: sender non-delivery notification: CD429140193 53FC2140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 53FC2140192: sender non-delivery notification: 587F6140193 B9523140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B9523140192: sender non-delivery notification: BE185140193 4965A140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 4965A140192: sender non-delivery notification: 4EC12140193 C2E35140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C2E35140192: sender non-delivery notification: C7993140193 60D86140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 60D86140192: sender non-delivery notification: 656EA140193 D6860140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D6860140192: sender non-delivery notification: DB030140193 80DEB140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 80DEB140192: sender non-delivery notification: 857FC140193 08BF1140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 08BF1140192: sender non-delivery notification: 0D90A140193 B501A140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B501A140192: sender non-delivery notification: B90D8140193 CD85A140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) CD85A140192: sender non-delivery notification: D3A86140193 59431140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 59431140192: sender non-delivery notification: 5EA5F140193 7DB08140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.04/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7DB08140192: sender non-delivery notification: 836DA140193 21E71140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 21E71140192: sender non-delivery notification: 27A98140193 9D44E140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 9D44E140192: sender non-delivery notification: A19DE140193 47CE6140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 47CE6140192: sender non-delivery notification: 4CD22140193 CB2B0140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) CB2B0140192: sender non-delivery notification: D08A4140193 F0078140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) F0078140192: sender non-delivery notification: 00EB2140193 8F521140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 8F521140192: sender non-delivery notification: 94E78140193 1517E140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 1517E140192: sender non-delivery notification: 19C2B140193 A5C57140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A5C57140192: sender non-delivery notification: ADF30140193 497B3140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.02/0/0.03/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 497B3140192: sender non-delivery notification: 522E7140193 CAFA7140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) CAFA7140192: sender non-delivery notification: D08B0140193 70E90140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 70E90140192: sender non-delivery notification: 7899A140193 EB1CA140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) EB1CA140192: sender non-delivery notification: EFC38140193 8C1E3140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 8C1E3140192: sender non-delivery notification: 91035140193 18D70140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 18D70140192: sender non-delivery notification: 1FD6C140193 B41A4140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.03/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B41A4140192: sender non-delivery notification: B8EE1140193 58559140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 58559140192: sender non-delivery notification: 5C7B8140193 D0D54140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D0D54140192: sender non-delivery notification: D5C25140193 76671140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 76671140192: sender non-delivery notification: 7DEA7140193 00A5E140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 00A5E140192: sender non-delivery notification: 04E0C140193 8CEBB140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 8CEBB140192: sender non-delivery notification: 91888140193 2D0BD140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 2D0BD140192: sender non-delivery notification: 31A42140193 A6B60140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A6B60140192: sender non-delivery notification: ABC3C140193 42A4E140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 42A4E140192: sender non-delivery notification: 48747140193 E3046140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.02/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) E3046140192: sender non-delivery notification: EA071140193 D1CDD140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.03/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D1CDD140192: sender non-delivery notification: D65FA140193 561D6140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 561D6140192: sender non-delivery notification: 5ADF4140193 E5B16140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) E5B16140192: sender non-delivery notification: EC662140193 4ED61140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.22, delays=0.02/0/0.19/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 4ED61140192: sender non-delivery notification: 807FB140193 C6F18140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C6F18140192: sender non-delivery notification: CBA2F140193 62F26140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 62F26140192: sender non-delivery notification: 679B9140193 DAC72140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) DAC72140192: sender non-delivery notification: DF3ED140193 7CC14140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7CC14140192: sender non-delivery notification: 81663140193 02559140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 02559140192: sender non-delivery notification: 07A60140193 8C4AE140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 8C4AE140192: sender non-delivery notification: 91B49140193 2A928140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 2A928140192: sender non-delivery notification: 2F9F1140193 A1F20140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A1F20140192: sender non-delivery notification: A6F9C140193 41059140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 41059140192: sender non-delivery notification: 45B49140193 B9E5E140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B9E5E140192: sender non-delivery notification: BEE3C140193 5A3A0140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 5A3A0140192: sender non-delivery notification: 5F137140193 D1B62140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D1B62140192: sender non-delivery notification: D62AF140193 73C9E140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 73C9E140192: sender non-delivery notification: 7888E140193 1A12F140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 1A12F140192: sender non-delivery notification: 1F116140193 A85FC140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A85FC140192: sender non-delivery notification: AE2DC140193 B4273140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B4273140192: sender non-delivery notification: B93BC140193 C834D140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.09, delays=0.08/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C834D140192: sender non-delivery notification: CE01F140193 DC092140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.06, delays=0.04/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) DC092140192: sender non-delivery notification: E1727140193 70439140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 70439140192: sender non-delivery notification: 759FB140193 100AA140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 100AA140192: sender non-delivery notification: 15B27140193 8FED0140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 8FED0140192: sender non-delivery notification: 94C01140193 2E20C140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 2E20C140192: sender non-delivery notification: 32610140193 DB057140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.17, delays=0.16/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) DB057140192: sender non-delivery notification: E0087140193 746B2140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 746B2140192: sender non-delivery notification: 78F6A140193 03469140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.03/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 03469140192: sender non-delivery notification: 0894C140193 90B90140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 90B90140192: sender non-delivery notification: 953AD140193 372A1140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 372A1140192: sender non-delivery notification: 3BB0A140193 B0BD9140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B0BD9140192: sender non-delivery notification: B6642140193 4E3DB140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 4E3DB140192: sender non-delivery notification: 53360140193 C5CDF140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C5CDF140192: sender non-delivery notification: CA507140193 65E9F140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 65E9F140192: sender non-delivery notification: 6ACD8140193 F1DBC140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) F1DBC140192: sender non-delivery notification: 02307140193 960EE140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 960EE140192: sender non-delivery notification: 9AE70140193 1BAFB140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 1BAFB140192: sender non-delivery notification: 20524140193 A7716140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A7716140192: sender non-delivery notification: ABBF1140193 7AAD7140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7AAD7140192: sender non-delivery notification: 7F6CE140193 1FDEC140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 1FDEC140192: sender non-delivery notification: 24842140193 ACE12140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) ACE12140192: sender non-delivery notification: B164D140193 4CF4A140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 4CF4A140192: sender non-delivery notification: 51E3D140193 C5BC7140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C5BC7140192: sender non-delivery notification: CA81E140193 64ABD140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 64ABD140192: sender non-delivery notification: 698C4140193 ECB5E140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) ECB5E140192: sender non-delivery notification: F232E140193 8C17F140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 8C17F140192: sender non-delivery notification: 910FE140193 11B48140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 11B48140192: sender non-delivery notification: 16753140193 9E618140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 9E618140192: sender non-delivery notification: A4C5A140193 1813E140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.25, delays=0.01/0/0.21/0.03, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 1813E140192: sender non-delivery notification: 52E4B140193 910A3140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 910A3140192: sender non-delivery notification: 9580C140193 2F852140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 2F852140192: sender non-delivery notification: 34AF0140193 ADAD5140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) ADAD5140192: sender non-delivery notification: B2CFC140193 51A5F140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 51A5F140192: sender non-delivery notification: 56519140193 CD34A140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) CD34A140192: sender non-delivery notification: D1AD5140193 6B315140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6B315140192: sender non-delivery notification: 704DC140193 E2C82140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) E2C82140192: sender non-delivery notification: E790F140193 7F33F140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7F33F140192: sender non-delivery notification: 84173140193 06AD0140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 06AD0140192: sender non-delivery notification: 0BDD4140193 948D7140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 948D7140192: sender non-delivery notification: 99052140193 34F14140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 34F14140192: sender non-delivery notification: 394BB140193 B0898140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B0898140192: sender non-delivery notification: B52D0140193 52E54140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 52E54140192: sender non-delivery notification: 57B78140193 D88AD140192: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D88AD140192: sender non-delivery notification: DD3F3140193 EB906140163: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.2, delays=0.11/0.04/0.01/0.04, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) EB906140163: sender non-delivery notification: 13729140167 7D0CC140163: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7D0CC140163: sender non-delivery notification: 81D5F140167 0EA82140163: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 0EA82140163: sender non-delivery notification: 135E5140167 A11AD140163: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A11AD140163: sender non-delivery notification: A6148140167 7E524140163: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7E524140163: sender non-delivery notification: 82EE2140167 EE398140163: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.2, delays=0.04/0/0.15/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) EE398140163: sender non-delivery notification: 2069A140167 8C46D140163: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 8C46D140163: sender non-delivery notification: 91C0D140167 547FA140163: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.34, delays=0.32/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 547FA140163: sender non-delivery notification: 603E0140167 E14E9140163: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) E14E9140163: sender non-delivery notification: E6641140167 84A24140163: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 84A24140163: sender non-delivery notification: 89DCB140167 1776D140163: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.03/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 1776D140163: sender non-delivery notification: 1CDE6140167 A9A57140163: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A9A57140163: sender non-delivery notification: AE60B140167 7BB3A140163: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7BB3A140163: sender non-delivery notification: 803AD140167 5A6B6140163: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.42, delays=0.4/0/0.02/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 5A6B6140163: sender non-delivery notification: 62519140167 0E761140163: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.16, delays=0.12/0/0.01/0.02, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 0E761140163: sender non-delivery notification: 17E66140167 84C18140163: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 84C18140163: sender non-delivery notification: 899F5140167 6C0C8140163: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.34, delays=0.32/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6C0C8140163: sender non-delivery notification: 71E21140167 E6CAE140167: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.14, delays=0.12/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) E6CAE140167: sender non-delivery notification: 10C43140168 830FB140167: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 830FB140167: sender non-delivery notification: 87CB1140168 96B75140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.63, delays=0.61/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 96B75140168: sender non-delivery notification: 9B7CE14016A 31D55140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 31D55140168: sender non-delivery notification: 367B414016A ACCCE140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) ACCCE140168: sender non-delivery notification: B370814016A C9FF4140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.56, delays=0.54/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C9FF4140168: sender non-delivery notification: CF46014016A 69785140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 69785140168: sender non-delivery notification: 6DF6414016A E334E140167: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) E334E140167: sender non-delivery notification: EB12C140168 05912140167: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.18, delays=0.16/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 05912140167: sender non-delivery notification: 0EE07140168 7A8B2140167: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7A8B2140167: sender non-delivery notification: 80715140168 15057140167: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 15057140167: sender non-delivery notification: 197DE140168 186B0140167: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.06, delays=0.05/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 186B0140167: sender non-delivery notification: 1CFA1140168 AAA99140167: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) AAA99140167: sender non-delivery notification: B083F140168 4A7D6140167: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.02/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 4A7D6140167: sender non-delivery notification: 52C7A140168 C2355140167: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C2355140167: sender non-delivery notification: C71C6140168 5A3B0140167: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 5A3B0140167: sender non-delivery notification: 5E87F140168 E215C140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) E215C140168: sender non-delivery notification: E7C6014016A 7E03B140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7E03B140168: sender non-delivery notification: 83A6414016A 0C169140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.07, delays=0.05/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 0C169140168: sender non-delivery notification: 10FB314016A 97DE2140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 97DE2140168: sender non-delivery notification: 9C74E14016A 3BF2F140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 3BF2F140168: sender non-delivery notification: 40D2814016A C4382140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.1, delays=0.01/0/0.08/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C4382140168: sender non-delivery notification: DA40B14016A 60247140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 60247140168: sender non-delivery notification: 658A014016A DDD70140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) DDD70140168: sender non-delivery notification: E260214016A 7FF71140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7FF71140168: sender non-delivery notification: 8529114016A 052A2140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 052A2140168: sender non-delivery notification: 09D3214016A 8FD70140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 8FD70140168: sender non-delivery notification: 949DD14016A 70FCB140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 70FCB140168: sender non-delivery notification: 753FD14016A EEAB6140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) EEAB6140168: sender non-delivery notification: F31AB14016A 8EA11140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 8EA11140168: sender non-delivery notification: 93C0A14016A 29801140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.13, delays=0.11/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 29801140168: sender non-delivery notification: 2E49214016A B6BFD140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B6BFD140168: sender non-delivery notification: BB7A914016A 58F74140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 58F74140168: sender non-delivery notification: 5DC4814016A 1A5A0140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 1A5A0140168: sender non-delivery notification: 203CF14016A A392C140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A392C140168: sender non-delivery notification: A7EB214016A 4186A140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 4186A140168: sender non-delivery notification: 46A2714016A B94F7140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B94F7140168: sender non-delivery notification: BDF7914016A 55E6A140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 55E6A140168: sender non-delivery notification: 5A7BB14016A D0128140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D0128140168: sender non-delivery notification: D4BE214016A 6F3F2140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6F3F2140168: sender non-delivery notification: 7413414016A 6CB3B140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.53, delays=0.52/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6CB3B140168: sender non-delivery notification: 7177714016A 23D9D140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.14, delays=0.12/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 23D9D140168: sender non-delivery notification: 289B614016A 9B155140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 9B155140168: sender non-delivery notification: A0B6114016A 449C4140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.09, delays=0.08/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 449C4140168: sender non-delivery notification: 4AF5814016A BF6C3140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) BF6C3140168: sender non-delivery notification: C3E3614016A 5F244140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 5F244140168: sender non-delivery notification: 6389D14016A D92AD140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D92AD140168: sender non-delivery notification: DE23E14016A 776A1140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 776A1140168: sender non-delivery notification: 7C4CD14016A 2988B140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.23, delays=0.21/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 2988B140168: sender non-delivery notification: 2F54514016A BDB53140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) BDB53140168: sender non-delivery notification: C1EAF14016A 5BB73140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 5BB73140168: sender non-delivery notification: 609D614016A D15E3140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D15E3140168: sender non-delivery notification: D5EB114016A 73A4D140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 73A4D140168: sender non-delivery notification: 78BC214016A 56C7D140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.41, delays=0.4/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 56C7D140168: sender non-delivery notification: 5B18214016A 2F52C140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.26, delays=0.24/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 2F52C140168: sender non-delivery notification: 347FB14016A A953F140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A953F140168: sender non-delivery notification: ADDDD14016A 496D3140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 496D3140168: sender non-delivery notification: 4E6F414016A BF4DF140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.44, delays=0.02/0/0.41/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) BF4DF140168: sender non-delivery notification: 32EDB14016A 59337140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.01/0.03, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 59337140168: sender non-delivery notification: 6309B14016A D0D49140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D0D49140168: sender non-delivery notification: D5C4014016A BC33A140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) BC33A140168: sender non-delivery notification: C1D3D14016A 40A71140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 40A71140168: sender non-delivery notification: 451FE14016A C9BFE140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C9BFE140168: sender non-delivery notification: CF35914016A 88615140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 88615140168: sender non-delivery notification: 8D36014016A 3C8A5140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.25, delays=0.21/0/0.04/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 3C8A5140168: sender non-delivery notification: 48A2914016A C6D42140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C6D42140168: sender non-delivery notification: CBED814016A 6AF2B140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.03/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6AF2B140168: sender non-delivery notification: 6F60914016A E4ABB140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.47, delays=0.02/0/0.01/0.45, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) E4ABB140168: sender non-delivery notification: 6156414016A 85088140168: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 85088140168: sender non-delivery notification: 8958414016A 158D214016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.08, delays=0.06/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 158D214016A: sender non-delivery notification: 1BED114016B A2A6214016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A2A6214016A: sender non-delivery notification: A6B4614016B 3CC7814016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 3CC7814016A: sender non-delivery notification: 4113F14016B B4A0F14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B4A0F14016A: sender non-delivery notification: B98F914016B 519FE14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 519FE14016A: sender non-delivery notification: 5649D14016B C85F914016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.09, delays=0.02/0/0.07/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C85F914016A: sender non-delivery notification: DB7F314016B 674A914016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.07, delays=0.01/0/0.05/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 674A914016A: sender non-delivery notification: 7633C14016B E531614016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) E531614016A: sender non-delivery notification: EAD2214016B 8530714016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 8530714016A: sender non-delivery notification: 8A0AD14016B 287CD14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.15, delays=0.14/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 287CD14016A: sender non-delivery notification: 2EB9F14016B B656514016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B656514016A: sender non-delivery notification: BB18114016B 1A2E614016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.22, delays=0.01/0/0.2/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 1A2E614016A: sender non-delivery notification: 4CBFD14016B 9850214016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 9850214016A: sender non-delivery notification: 9D22B14016B 381B214016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 381B214016A: sender non-delivery notification: 3E3CD14016B 0C6CF14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 0C6CF14016A: sender non-delivery notification: 12F1A14016B 94E5914016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 94E5914016A: sender non-delivery notification: 98E6414016B 3B5B914016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.06, delays=0.04/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 3B5B914016A: sender non-delivery notification: 4167F14016B B4DC114016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B4DC114016A: sender non-delivery notification: B92E614016B 54DE714016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 54DE714016A: sender non-delivery notification: 59C5514016B CC4F414016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.01/0/0.01/0.03, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) CC4F414016A: sender non-delivery notification: D5B4714016B 6C6CE14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6C6CE14016A: sender non-delivery notification: 71FD414016B 25C2314016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 25C2314016A: sender non-delivery notification: 2C65514016B B327414016B: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.01/0/0.03/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B327414016B: sender non-delivery notification: BDE5814016C 77BB714016B: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 77BB714016B: sender non-delivery notification: 7DD7414016C F0C4214016B: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) F0C4214016B: sender non-delivery notification: 01A7D14016C 9363814016B: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 9363814016B: sender non-delivery notification: 9844714016C 6907214016B: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.36, delays=0.35/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6907214016B: sender non-delivery notification: 6DDFD14016C 0363614016B: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 0363614016B: sender non-delivery notification: 081C814016C 7A7FC14016B: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7A7FC14016B: sender non-delivery notification: 7F66614016C 4AC1314016B: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.24, delays=0.23/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 4AC1314016B: sender non-delivery notification: 5172314016C D31E814016B: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D31E814016B: sender non-delivery notification: DA3C214016C 7544214016B: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7544214016B: sender non-delivery notification: 79E1D14016C 82F2B14016B: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.59, delays=0.57/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 82F2B14016B: sender non-delivery notification: 88A6614016C 21AEE14016B: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 21AEE14016B: sender non-delivery notification: 2627014016C A735114016B: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.22, delays=0.03/0/0.19/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A735114016B: sender non-delivery notification: D7A4E14016C 5E5FB14016B: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.13, delays=0.11/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 5E5FB14016B: sender non-delivery notification: 655ED14016C E355A14016B: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.09, delays=0.01/0/0.01/0.06, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) E355A14016B: sender non-delivery notification: 0155514016C C74A814016B: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C74A814016B: sender non-delivery notification: CBD0F14016C 4F92914016B: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 4F92914016B: sender non-delivery notification: 5439A14016C 4F22014016B: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 4F22014016B: sender non-delivery notification: 5385E14016C E550D14016B: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.25, delays=0.24/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) E550D14016B: sender non-delivery notification: 2D31B14016C 89A5F14016B: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.04/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 89A5F14016B: sender non-delivery notification: 8E9EE14016C 0BF0F14016B: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 0BF0F14016B: sender non-delivery notification: 1112D14016C 9C49914016B: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 9C49914016B: sender non-delivery notification: A1A6014016C 3C7D314016B: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 3C7D314016B: sender non-delivery notification: 41C4714016C BAFFF14016B: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) BAFFF14016B: sender non-delivery notification: BFB1B14016C 5C4C014016B: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 5C4C014016B: sender non-delivery notification: 60EE114016C D8F0314016B: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D8F0314016B: sender non-delivery notification: DDCC214016C 7A2CB14016B: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7A2CB14016B: sender non-delivery notification: 7FA6014016C 2159014016B: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.16, delays=0.12/0/0.01/0.03, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 2159014016B: sender non-delivery notification: 2B4BE14016C AE51914016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) AE51914016A: sender non-delivery notification: B2B9414016B 4E6F814016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 4E6F814016A: sender non-delivery notification: 5329B14016B C4E5014016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C4E5014016A: sender non-delivery notification: C9F9F14016B 6682714016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6682714016A: sender non-delivery notification: 6B78814016B DE74F14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) DE74F14016A: sender non-delivery notification: E2E4A14016B 7C40014016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7C40014016A: sender non-delivery notification: 8114914016B 7A50114016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7A50114016A: sender non-delivery notification: 7F33E14016B 8179014016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.79, delays=0.44/0/0.34/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 8179014016A: sender non-delivery notification: D7B6614016B 1F2B414016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 1F2B414016A: sender non-delivery notification: 23DFC14016B 9590614016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 9590614016A: sender non-delivery notification: 9A26E14016B B9C7914016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.54, delays=0.52/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B9C7914016A: sender non-delivery notification: BEB6114016B 5805A14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 5805A14016A: sender non-delivery notification: 5D86214016B CF73914016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) CF73914016A: sender non-delivery notification: D3F2814016B 1E38014016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 1E38014016A: sender non-delivery notification: 22F3B14016B 94BD114016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 94BD114016A: sender non-delivery notification: 9B5B414016B 3473114016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 3473114016A: sender non-delivery notification: 3946D14016B AB84514016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) AB84514016A: sender non-delivery notification: E339214016B 4BE2A14016B: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 4BE2A14016B: sender non-delivery notification: 5050514016C C3A6414016B: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C3A6414016B: sender non-delivery notification: C849414016C 9208A14016B: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.22, delays=0.2/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 9208A14016B: sender non-delivery notification: 9792114016C 2FAB514016B: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.03/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 2FAB514016B: sender non-delivery notification: 3710B14016C BC8C114016B: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) BC8C114016B: sender non-delivery notification: C183214016C 5951214016B: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 5951214016B: sender non-delivery notification: 5E41414016C D048314016B: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D048314016B: sender non-delivery notification: D531D14016C 7AC2414016B: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.08, delays=0.06/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7AC2414016B: sender non-delivery notification: 7FA1314016C 4C11A14016B: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.34, delays=0.32/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 4C11A14016B: sender non-delivery notification: 50E7514016C D9A7614016B: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D9A7614016B: sender non-delivery notification: DE0B714016C B0BB714016B: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B0BB714016B: sender non-delivery notification: B584014016C 3676414016B: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 3676414016B: sender non-delivery notification: 3B9B114016C 28EC714016B: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 28EC714016B: sender non-delivery notification: 2DCE214016C A7AB814016B: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A7AB814016B: sender non-delivery notification: AC5AB14016C 46EEC14016B: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 46EEC14016B: sender non-delivery notification: 4BE6D14016C C04A414016B: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C04A414016B: sender non-delivery notification: C4D5814016C 60B1014016B: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 60B1014016B: sender non-delivery notification: 6579014016C DB77914016B: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) DB77914016B: sender non-delivery notification: DFE1A14016C 7A0B214016B: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7A0B214016B: sender non-delivery notification: 7F2C614016C F2EC214016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) F2EC214016A: sender non-delivery notification: 0380F14016B 9624614016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 9624614016A: sender non-delivery notification: 9B8EF14016B 3CE6A14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.16, delays=0.15/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 3CE6A14016A: sender non-delivery notification: 4189D14016B CA13314016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) CA13314016A: sender non-delivery notification: CE9BA14016B 66CDF14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 66CDF14016A: sender non-delivery notification: 6C1FC14016B DF6AA14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.48, delays=0.02/0/0.01/0.45, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) DF6AA14016A: sender non-delivery notification: 5C3BE14016B 7DD8114016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7DD8114016A: sender non-delivery notification: 8214B14016B F375614016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) F375614016A: sender non-delivery notification: 046FE14016B 9154714016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 9154714016A: sender non-delivery notification: 9603F14016B 1263414016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 1263414016A: sender non-delivery notification: 1763B14016B 9CB8414016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 9CB8414016A: sender non-delivery notification: A146114016B 409A614016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 409A614016A: sender non-delivery notification: 44FC914016B BAA7F14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) BAA7F14016A: sender non-delivery notification: C190514016B 58DDC14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 58DDC14016A: sender non-delivery notification: 5E1CA14016B DEADF14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.62, delays=0.01/0/0.01/0.6, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) DEADF14016A: sender non-delivery notification: 819E514016B 7CA5514016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7CA5514016A: sender non-delivery notification: 81BE114016B AD58114016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.2, delays=0.01/0/0.18/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) AD58114016A: sender non-delivery notification: DC6BF14016B 8001314016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 8001314016A: sender non-delivery notification: 84D0814016B 0E06614016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 0E06614016A: sender non-delivery notification: 13FB814016B D8FD414016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.49, delays=0.05/0/0.07/0.38, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D8FD414016A: sender non-delivery notification: 5312914016B 7997214016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7997214016A: sender non-delivery notification: 7E6CE14016B F2F3D14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) F2F3D14016A: sender non-delivery notification: 0353414016B 1473D14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 1473D14016A: sender non-delivery notification: 19F8814016B 8E95C14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 8E95C14016A: sender non-delivery notification: 93A4814016B 2CC7114016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 2CC7114016A: sender non-delivery notification: 3128614016B A472914016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A472914016A: sender non-delivery notification: A960714016B 5F03214016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.15, delays=0.14/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 5F03214016A: sender non-delivery notification: 63E7714016B DC3F214016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) DC3F214016A: sender non-delivery notification: E12B114016B AC4BB14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) AC4BB14016A: sender non-delivery notification: B20C114016B 92FD414016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 92FD414016A: sender non-delivery notification: 9763414016B 3306F14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 3306F14016A: sender non-delivery notification: 3950814016B ACE6514016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) ACE6514016A: sender non-delivery notification: B1D0214016B 55B1F14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.07, delays=0.06/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 55B1F14016A: sender non-delivery notification: 5A5C614016B CDBE914016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) CDBE914016A: sender non-delivery notification: D20CC14016B 8146514016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 8146514016A: sender non-delivery notification: 86A2D14016B 886C314016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.63, delays=0.55/0/0.07/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 886C314016A: sender non-delivery notification: 9BF7E14016B 2706A14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 2706A14016A: sender non-delivery notification: 2C27914016B B101014016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B101014016A: sender non-delivery notification: B582014016B 520CC14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 520CC14016A: sender non-delivery notification: 56CB014016B 8672414016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 8672414016A: sender non-delivery notification: 8B4E414016B 2494914016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 2494914016A: sender non-delivery notification: 292EF14016B 9A1BB14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 9A1BB14016A: sender non-delivery notification: 9E52E14016B 3A0EA14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 3A0EA14016A: sender non-delivery notification: 3EC3214016B B1EC314016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B1EC314016A: sender non-delivery notification: B694E14016B 51F2F14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 51F2F14016A: sender non-delivery notification: 5742914016B C944D14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C944D14016A: sender non-delivery notification: CE01214016B 984E514016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 984E514016A: sender non-delivery notification: 9D12114016B 1B56014016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 1B56014016A: sender non-delivery notification: 200C414016B A805614016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A805614016A: sender non-delivery notification: AD02814016B 53EC014016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 53EC014016A: sender non-delivery notification: 5928214016B CBD1414016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) CBD1414016A: sender non-delivery notification: D065314016B 9AA3214016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 9AA3214016A: sender non-delivery notification: 9FC4E14016B 1D17D14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 1D17D14016A: sender non-delivery notification: 222D914016B A63B114016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.01/0/0.01/0.03, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A63B114016A: sender non-delivery notification: B057914016B 544D414016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 544D414016A: sender non-delivery notification: 5A57E14016B CC27614016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) CC27614016A: sender non-delivery notification: D0C7714016B 6A65D14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6A65D14016A: sender non-delivery notification: 6F24014016B 4999314016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.42, delays=0.39/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 4999314016A: sender non-delivery notification: 51F3414016B D56DA14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D56DA14016A: sender non-delivery notification: D996F14016B 73A3114016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=5, delays=0.02/0/5/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 73A3114016A: sender non-delivery notification: 78D7E14016B EA87214016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.01/0/0.01/0.03, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) EA87214016A: sender non-delivery notification: 014FD14016B 8984714016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=5, delays=0.02/0/5/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 8984714016A: sender non-delivery notification: 8EA6414016B A5A9614016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.02/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A5A9614016A: sender non-delivery notification: AC4F514016B 3DF1214016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 3DF1214016A: sender non-delivery notification: 4395314016B B69E214016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B69E214016A: sender non-delivery notification: BB86414016B 5676E14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 5676E14016A: sender non-delivery notification: 5BA2314016B CD2C914016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) CD2C914016A: sender non-delivery notification: D1DF714016B 6C29B14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6C29B14016A: sender non-delivery notification: 707B514016B E3C8114016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) E3C8114016A: sender non-delivery notification: E832C14016B 8B08414016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 8B08414016A: sender non-delivery notification: 8FEA614016B 0FD5314016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 0FD5314016A: sender non-delivery notification: 144A614016B 9ADD414016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 9ADD414016A: sender non-delivery notification: 9F8AD14016B 5506A14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 5506A14016A: sender non-delivery notification: 5AEE214016B D7EEC14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D7EEC14016A: sender non-delivery notification: DCDE414016B 79B4014016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 79B4014016A: sender non-delivery notification: 800BE14016B 0F83814016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.1, delays=0.08/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 0F83814016A: sender non-delivery notification: 1462614016B D01A214016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D01A214016A: sender non-delivery notification: D506C14016B 6E28814016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6E28814016A: sender non-delivery notification: 737DF14016B E6CA714016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) E6CA714016A: sender non-delivery notification: EDDBF14016B 849E814016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 849E814016A: sender non-delivery notification: 898FB14016B 0A52814016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 0A52814016A: sender non-delivery notification: 0EF2314016B 9804914016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 9804914016A: sender non-delivery notification: 9CFEF14016B 384D914016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 384D914016A: sender non-delivery notification: 3D99414016B AFCC514016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) AFCC514016A: sender non-delivery notification: B50D514016B 53AB014016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 53AB014016A: sender non-delivery notification: 58BAD14016B 189A814016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 189A814016A: sender non-delivery notification: 1D2DA14016B A25EC14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A25EC14016A: sender non-delivery notification: A727A14016B 4D0DF14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 4D0DF14016A: sender non-delivery notification: 5212914016B C860314016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C860314016A: sender non-delivery notification: CDED414016B 6878814016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.01/0/0.03/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6878814016A: sender non-delivery notification: 72D4114016B 19C7114016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.19, delays=0.17/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 19C7114016A: sender non-delivery notification: 1E27314016B D9B4714016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D9B4714016A: sender non-delivery notification: DE9AE14016B 79F2914016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 79F2914016A: sender non-delivery notification: 7F3E114016B F0E1614016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) F0E1614016A: sender non-delivery notification: 010D414016B 9550C14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 9550C14016A: sender non-delivery notification: 9A55914016B 82B1614016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.46, delays=0.45/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 82B1614016A: sender non-delivery notification: 8811514016B 1868914016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 1868914016A: sender non-delivery notification: 1D65914016B 8EBA814016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 8EBA814016A: sender non-delivery notification: 9368214016B 7022B14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.29, delays=0.28/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7022B14016A: sender non-delivery notification: 74E2F14016B EBD0914016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) EBD0914016A: sender non-delivery notification: F044514016B 8FE1714016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 8FE1714016A: sender non-delivery notification: 94C2E14016B 194A714016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.04/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 194A714016A: sender non-delivery notification: 1E0B114016B DA8CC14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) DA8CC14016A: sender non-delivery notification: E0C7614016B 79E0614016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 79E0614016A: sender non-delivery notification: 7EC5314016B 2B1DB14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.21, delays=0.19/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 2B1DB14016A: sender non-delivery notification: 3093B14016B BA3BF14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) BA3BF14016A: sender non-delivery notification: BF02F14016B 982FA14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 982FA14016A: sender non-delivery notification: 9D96C14016B 1CB7D14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 1CB7D14016A: sender non-delivery notification: 21EFC14016B C66F914016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C66F914016A: sender non-delivery notification: CD71514016B 2DA4514016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.21, delays=0.02/0/0.18/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 2DA4514016A: sender non-delivery notification: 5CDA914016B A51AC14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A51AC14016A: sender non-delivery notification: A916E14016B 4603414016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 4603414016A: sender non-delivery notification: 4AA7914016B BE09F14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) BE09F14016A: sender non-delivery notification: C2ABA14016B 5BEC614016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 5BEC614016A: sender non-delivery notification: 60C9C14016B D355514016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D355514016A: sender non-delivery notification: D807714016B C2C9014016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.34, delays=0.33/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C2C9014016A: sender non-delivery notification: C7FD214016B 817DF14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 817DF14016A: sender non-delivery notification: 8606C14016B 3F06D14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.18, delays=0.17/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 3F06D14016A: sender non-delivery notification: 4454614016B B7BFC14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B7BFC14016A: sender non-delivery notification: BC6A414016B 5F84714016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 5F84714016A: sender non-delivery notification: 6410C14016B D727114016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.5, delays=0.02/0/0.01/0.47, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D727114016A: sender non-delivery notification: 59F8D14016B 7550314016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7550314016A: sender non-delivery notification: 7A0D914016B 07FC114016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.09, delays=0.08/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 07FC114016A: sender non-delivery notification: 0E02D14016B 9536914016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 9536914016A: sender non-delivery notification: 99AAC14016B 3756314016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 3756314016A: sender non-delivery notification: 3C36114016B AD06114016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) AD06114016A: sender non-delivery notification: B19DD14016B 5FF1714016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.11, delays=0.1/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 5FF1714016A: sender non-delivery notification: 64C5414016B 4A26F14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.44, delays=0.43/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 4A26F14016A: sender non-delivery notification: 4FE1914016B D55D614016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D55D614016A: sender non-delivery notification: DBAD314016B A3A1C14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A3A1C14016A: sender non-delivery notification: A8FB914016B 3006014016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.04/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 3006014016A: sender non-delivery notification: 34B0214016B C95CE14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C95CE14016A: sender non-delivery notification: CDEEC14016B 3AACA14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.2, delays=0.02/0/0.18/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 3AACA14016A: sender non-delivery notification: 6890614016B B4C8014016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B4C8014016A: sender non-delivery notification: B929514016B 5470814016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 5470814016A: sender non-delivery notification: 58F4914016B CC97C14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) CC97C14016A: sender non-delivery notification: D190E14016B 6AA9D14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6AA9D14016A: sender non-delivery notification: 6F1BA14016B E32C714016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) E32C714016A: sender non-delivery notification: E82EA14016B 825D114016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 825D114016A: sender non-delivery notification: 871A114016B 08E4214016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 08E4214016A: sender non-delivery notification: 0E54014016B 9836F14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 9836F14016A: sender non-delivery notification: 9CBA314016B 376E114016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 376E114016A: sender non-delivery notification: 3C82D14016B B02D414016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B02D414016A: sender non-delivery notification: B4BAF14016B 51BD214016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.03/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 51BD214016A: sender non-delivery notification: 56E4E14016B C973314016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C973314016A: sender non-delivery notification: CE4E014016B 6AD6214016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6AD6214016A: sender non-delivery notification: 6F1F014016B E1BCB14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) E1BCB14016A: sender non-delivery notification: E675D14016B 84BED14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 84BED14016A: sender non-delivery notification: 8A11414016B 074DE14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 074DE14016A: sender non-delivery notification: 0CE8914016B 95F1514016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 95F1514016A: sender non-delivery notification: 9A97014016B 4E92D14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 4E92D14016A: sender non-delivery notification: 5372B14016B C630E14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C630E14016A: sender non-delivery notification: CAEE514016B 63DC314016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 63DC314016A: sender non-delivery notification: 689B114016B 40F2C14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.39, delays=0.38/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 40F2C14016A: sender non-delivery notification: 46E2814016B CF7CC14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) CF7CC14016A: sender non-delivery notification: D535E14016B 44B6F14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.16, delays=0.01/0/0.14/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 44B6F14016A: sender non-delivery notification: 6943C14016B BC4CD14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) BC4CD14016A: sender non-delivery notification: C136314016B 5A81014016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 5A81014016A: sender non-delivery notification: 5F75214016B D1E4314016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D1E4314016A: sender non-delivery notification: D6DB414016B 7A39614016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7A39614016A: sender non-delivery notification: 7FBCE14016B F3F0D14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) F3F0D14016A: sender non-delivery notification: 0657214016B B070914016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B070914016A: sender non-delivery notification: B4FD614016B 31CFC14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 31CFC14016A: sender non-delivery notification: 362DF14016B F010B14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) F010B14016A: sender non-delivery notification: 0012A14016B 8EF8714016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 8EF8714016A: sender non-delivery notification: 943B814016B 104E914016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 104E914016A: sender non-delivery notification: 14E9F14016B 9A53E14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 9A53E14016A: sender non-delivery notification: 9E9BD14016B 380F814016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 380F814016A: sender non-delivery notification: 3CC0B14016B B026314016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B026314016A: sender non-delivery notification: B4BEC14016B 9195714016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 9195714016A: sender non-delivery notification: 9727314016B 174DB14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 174DB14016A: sender non-delivery notification: 1BFF414016B A339D14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A339D14016A: sender non-delivery notification: A7F4814016B 42AFB14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 42AFB14016A: sender non-delivery notification: 49DB614016B BC52614016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.02/0/0.01/0.03, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) BC52614016A: sender non-delivery notification: C69E014016B 5F7C514016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 5F7C514016A: sender non-delivery notification: 6477714016B E569314016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.08, delays=0.07/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) E569314016A: sender non-delivery notification: EA51314016B 865EC14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 865EC14016A: sender non-delivery notification: 8AF9414016B 0C1A214016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 0C1A214016A: sender non-delivery notification: 10C7D14016B 8E76114016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.33, delays=0.02/0/0.3/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 8E76114016A: sender non-delivery notification: DC33A14016B 2CCF014016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 2CCF014016A: sender non-delivery notification: 31F6914016B A54C514016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A54C514016A: sender non-delivery notification: A981214016B 44C4014016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 44C4014016A: sender non-delivery notification: 496F614016B BC7C114016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) BC7C114016A: sender non-delivery notification: C11DA14016B 5AA6E14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 5AA6E14016A: sender non-delivery notification: 5F58914016B D655014016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.15, delays=0.02/0/0.01/0.12, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D655014016A: sender non-delivery notification: 0404214016B 7851E14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7851E14016A: sender non-delivery notification: 7CAE914016B EFC6914016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) EFC6914016A: sender non-delivery notification: 0007A14016B 8EB0414016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 8EB0414016A: sender non-delivery notification: 938D714016B 12C7D14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 12C7D14016A: sender non-delivery notification: 1757714016B A215614016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A215614016A: sender non-delivery notification: A7F5E14016B 4473814016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 4473814016A: sender non-delivery notification: 4AE2A14016B C234A14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C234A14016A: sender non-delivery notification: C8EE214016B 644F014016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 644F014016A: sender non-delivery notification: 6AFE614016B E1D7314016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) E1D7314016A: sender non-delivery notification: E87AA14016B 85FDF14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 85FDF14016A: sender non-delivery notification: 8CCF114016B 070E214016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 070E214016A: sender non-delivery notification: 0BB0A14016B 9371014016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 9371014016A: sender non-delivery notification: 9866714016B 33A0E14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 33A0E14016A: sender non-delivery notification: 3822C14016B AB3FA14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) AB3FA14016A: sender non-delivery notification: AFCE214016B 8082E14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 8082E14016A: sender non-delivery notification: 8593B14016B 06F2614016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 06F2614016A: sender non-delivery notification: 0D2F414016B 2829914016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.25, delays=0.02/0/0.23/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 2829914016A: sender non-delivery notification: 631C214016B BE62214016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) BE62214016A: sender non-delivery notification: C307114016B 5C8CD14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 5C8CD14016A: sender non-delivery notification: 61E8B14016B D44CC14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D44CC14016A: sender non-delivery notification: D8FDB14016B 71B6C14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 71B6C14016A: sender non-delivery notification: 760C114016B 22C9614016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.21, delays=0.19/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 22C9614016A: sender non-delivery notification: 2746314016B B2B7014016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B2B7014016A: sender non-delivery notification: B826D14016B 50EAC14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 50EAC14016A: sender non-delivery notification: 5609314016B C9F4214016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C9F4214016A: sender non-delivery notification: CE98014016B 6BAB314016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6BAB314016A: sender non-delivery notification: 7057314016B E555614016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) E555614016A: sender non-delivery notification: EA66A14016B 83D7F14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 83D7F14016A: sender non-delivery notification: 887C114016B 0A3AB14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 0A3AB14016A: sender non-delivery notification: 0EB4614016B 9631214016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 9631214016A: sender non-delivery notification: 9AA0E14016B 370B214016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 370B214016A: sender non-delivery notification: 3BCC614016B C530C14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C530C14016A: sender non-delivery notification: C9EB014016B 95B0314016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 95B0314016A: sender non-delivery notification: 9A14314016B 1AB0314016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 1AB0314016A: sender non-delivery notification: 2023614016B A79E814016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A79E814016A: sender non-delivery notification: AC52214016B 459F214016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 459F214016A: sender non-delivery notification: 4A01414016B BD7B914016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) BD7B914016A: sender non-delivery notification: C205B14016B 5D7E414016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 5D7E414016A: sender non-delivery notification: 6247014016B D703E14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D703E14016A: sender non-delivery notification: DC0C314016B 7ED6B14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7ED6B14016A: sender non-delivery notification: 83F8914016B C41FC14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.2, delays=0.01/0/0.19/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C41FC14016A: sender non-delivery notification: F3D5014016B 620EB14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 620EB14016A: sender non-delivery notification: 668D414016B D93D914016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.09, delays=0.01/0/0.01/0.07, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D93D914016A: sender non-delivery notification: ED32E14016B AB3C514016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) AB3C514016A: sender non-delivery notification: B1ACD14016B 2E25C14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 2E25C14016A: sender non-delivery notification: 336DE14016B BC1C614016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) BC1C614016A: sender non-delivery notification: C10F714016B 5A34A14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 5A34A14016A: sender non-delivery notification: 5EBE314016B D1C3C14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.15, delays=0.01/0/0.07/0.07, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D1C3C14016A: sender non-delivery notification: 0129514016B 71F7E14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 71F7E14016A: sender non-delivery notification: 771B614016B E8A9C14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) E8A9C14016A: sender non-delivery notification: ED70C14016B 859B914016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 859B914016A: sender non-delivery notification: 8AF2114016B 06F2A14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 06F2A14016A: sender non-delivery notification: 0BDDF14016B 9322D14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 9322D14016A: sender non-delivery notification: 97AB514016B 3342014016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 3342014016A: sender non-delivery notification: 382EA14016B AD2D714016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) AD2D714016A: sender non-delivery notification: B1CEB14016B 4B1E614016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 4B1E614016A: sender non-delivery notification: 5039D14016B C2C8714016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C2C8714016A: sender non-delivery notification: C76F314016B 6128D14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6128D14016A: sender non-delivery notification: 659D014016B DA0EA14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.03/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) DA0EA14016A: sender non-delivery notification: E1C1914016B 7AB9F14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7AB9F14016A: sender non-delivery notification: 7FE6414016B 39C2414016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.27, delays=0.25/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 39C2414016A: sender non-delivery notification: 3E0B514016B C74B414016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C74B414016A: sender non-delivery notification: CC0E614016B 71EA514016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.08, delays=0.07/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 71EA514016A: sender non-delivery notification: 76D6014016B D102414016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.2, delays=0.01/0/0.18/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D102414016A: sender non-delivery notification: 0C82414016B 7019314016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7019314016A: sender non-delivery notification: 753A414016B E7BDE14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) E7BDE14016A: sender non-delivery notification: EC89414016B 86FDC14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 86FDC14016A: sender non-delivery notification: 8B62614016B 09BA814016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 09BA814016A: sender non-delivery notification: 0EBFB14016B 9531314016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 9531314016A: sender non-delivery notification: 9961814016B 312A714016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 312A714016A: sender non-delivery notification: 3587314016B AA16B14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) AA16B14016A: sender non-delivery notification: AE8BB14016B 7D39114016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7D39114016A: sender non-delivery notification: 8267114016B 0149414016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 0149414016A: sender non-delivery notification: 05B0114016B 8CBD714016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 8CBD714016A: sender non-delivery notification: 9192614016B 3193714016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.07, delays=0.01/0/0.05/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 3193714016A: sender non-delivery notification: 4133914016B AD0AD14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) AD0AD14016A: sender non-delivery notification: B2BFF14016B 4B44814016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 4B44814016A: sender non-delivery notification: 4FAB014016B CAC5214016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) CAC5214016A: sender non-delivery notification: CF38114016B 68B5A14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 68B5A14016A: sender non-delivery notification: 6DB0714016B 0082314016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 0082314016A: sender non-delivery notification: 05C8D14016B 8CFF014016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 8CFF014016A: sender non-delivery notification: 916E914016B 32C6D14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 32C6D14016A: sender non-delivery notification: 37B9614016B A86A614016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A86A614016A: sender non-delivery notification: AD08314016B 4479714016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 4479714016A: sender non-delivery notification: 4975F14016B BC55F14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) BC55F14016A: sender non-delivery notification: C121B14016B 5C46A14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 5C46A14016A: sender non-delivery notification: 6163414016B BDCA114016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.4, delays=0.07/0/0.32/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) BDCA114016A: sender non-delivery notification: 1CB5E14016B 5DD8D14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 5DD8D14016A: sender non-delivery notification: 62FA714016B D785A14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D785A14016A: sender non-delivery notification: DE8EE14016B 79D8614016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 79D8614016A: sender non-delivery notification: 7F16A14016B 0338B14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 0338B14016A: sender non-delivery notification: 07D6314016B 8F6CC14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 8F6CC14016A: sender non-delivery notification: 93FA014016B 2EA0514016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 2EA0514016A: sender non-delivery notification: 3404E14016B B264214016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B264214016A: sender non-delivery notification: B8D4614016B 6B15814016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.08, delays=0.06/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6B15814016A: sender non-delivery notification: 6FFF814016B 1DF1514016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.07, delays=0.05/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 1DF1514016A: sender non-delivery notification: 250AA14016B B082914016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B082914016A: sender non-delivery notification: B514014016B 51D8814016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 51D8814016A: sender non-delivery notification: 56A5014016B CA4B514016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) CA4B514016A: sender non-delivery notification: CEBCC14016B 6F88514016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6F88514016A: sender non-delivery notification: 74C9114016B EA20414016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) EA20414016A: sender non-delivery notification: EEE1F14016B 8C7AA14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 8C7AA14016A: sender non-delivery notification: 9180714016B 156A214016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 156A214016A: sender non-delivery notification: 19EBA14016B AC15E14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) AC15E14016A: sender non-delivery notification: B0EE914016B 4E73614016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 4E73614016A: sender non-delivery notification: 534ED14016B C625014016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C625014016A: sender non-delivery notification: CAD6814016B 64AFC14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 64AFC14016A: sender non-delivery notification: 699C814016B 152F614016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.2, delays=0.17/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 152F614016A: sender non-delivery notification: 1C37014016B ACABF14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.02/0/0.01/0.03, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) ACABF14016A: sender non-delivery notification: B6EA314016B 4186F14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.27, delays=0.02/0/0.24/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 4186F14016A: sender non-delivery notification: 8070E14016B BF27E14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) BF27E14016A: sender non-delivery notification: C454314016B 6732E14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6732E14016A: sender non-delivery notification: 6BC4B14016B 07A6314016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.12, delays=0.1/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 07A6314016A: sender non-delivery notification: 0E63A14016B 8EB3714016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.03/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 8EB3714016A: sender non-delivery notification: 935C014016B 372BD14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 372BD14016A: sender non-delivery notification: 3BDA214016B B541614016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B541614016A: sender non-delivery notification: BB97314016B 5D4D414016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 5D4D414016A: sender non-delivery notification: 6281414016B F247014016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.1, delays=0.08/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) F247014016A: sender non-delivery notification: 0292414016B 9155514016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.06, delays=0.01/0/0.04/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 9155514016A: sender non-delivery notification: 9CE8B14016B 1BFFB14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 1BFFB14016A: sender non-delivery notification: 20E6F14016B A710E14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A710E14016A: sender non-delivery notification: ABC5014016B 559D714016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.1, delays=0.09/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 559D714016A: sender non-delivery notification: 5A4BE14016B D52A214016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D52A214016A: sender non-delivery notification: D99AE14016B 7F98E14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7F98E14016A: sender non-delivery notification: 841BA14016B 5793C14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 5793C14016A: sender non-delivery notification: 5BDAC14016B E67C914016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) E67C914016A: sender non-delivery notification: EAF7214016B 88DF014016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 88DF014016A: sender non-delivery notification: 8D7C714016B 674A414016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.34, delays=0.32/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 674A414016A: sender non-delivery notification: 6C46714016B F3AA914016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) F3AA914016A: sender non-delivery notification: 0464714016B 9A25414016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 9A25414016A: sender non-delivery notification: 9ED9014016B 4F36714016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.17, delays=0.15/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 4F36714016A: sender non-delivery notification: 5480F14016B E5BA714016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) E5BA714016A: sender non-delivery notification: EA7B714016B 1070414016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.02/0/0.01/0.02, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 1070414016A: sender non-delivery notification: 1A34B14016B 869F514016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 869F514016A: sender non-delivery notification: 8B5A314016B 35B2514016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 35B2514016A: sender non-delivery notification: 3AB0014016B B1F3A14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B1F3A14016A: sender non-delivery notification: B661214016B 5301014016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 5301014016A: sender non-delivery notification: 5787514016B 0E66214016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.15, delays=0.13/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 0E66214016A: sender non-delivery notification: 132C714016B 9B7C014016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.02/0/0.01/0.03, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 9B7C014016A: sender non-delivery notification: A515C14016B 3A67214016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 3A67214016A: sender non-delivery notification: 3ED7E14016B BC4DC14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) BC4DC14016A: sender non-delivery notification: C11FB14016B 5B94514016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 5B94514016A: sender non-delivery notification: 639F114016B D41AC14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D41AC14016A: sender non-delivery notification: D86F614016B 74BFF14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 74BFF14016A: sender non-delivery notification: 7A97414016B 07AC914016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 07AC914016A: sender non-delivery notification: 0CF6614016B 91E8814016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.06, delays=0.02/0/0.04/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 91E8814016A: sender non-delivery notification: 9D3E514016B 2F3E014016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 2F3E014016A: sender non-delivery notification: 3402614016B A74B014016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A74B014016A: sender non-delivery notification: AC10414016B 4340914016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 4340914016A: sender non-delivery notification: 4839514016B BAFD214016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) BAFD214016A: sender non-delivery notification: BFC1814016B 60C4614016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 60C4614016A: sender non-delivery notification: 6615F14016B D8E8E14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D8E8E14016A: sender non-delivery notification: DD9BC14016B A996914016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A996914016A: sender non-delivery notification: AF65F14016B 2B39614016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 2B39614016A: sender non-delivery notification: 3013314016B F203914016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.07, delays=0.05/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) F203914016A: sender non-delivery notification: 02C7414016B 9837B14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 9837B14016A: sender non-delivery notification: 9F56B14016B D52C414016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.2, delays=0.01/0/0.18/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D52C414016A: sender non-delivery notification: 0FAD214016B 730E814016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 730E814016A: sender non-delivery notification: 77E9314016B EC2FC14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) EC2FC14016A: sender non-delivery notification: F17A214016B 8ADA414016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 8ADA414016A: sender non-delivery notification: 8FC0C14016B 09F8414016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 09F8414016A: sender non-delivery notification: 0EDBC14016B 9652914016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 9652914016A: sender non-delivery notification: 9B2DD14016B 6D93014016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6D93014016A: sender non-delivery notification: 72E0414016B 5DE4814016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.45, delays=0.43/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 5DE4814016A: sender non-delivery notification: 6218014016B 3972814016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.07, delays=0.06/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 3972814016A: sender non-delivery notification: 3E20E14016B 02F7914016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 02F7914016A: sender non-delivery notification: 07DBE14016B 9107214016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 9107214016A: sender non-delivery notification: 95A0414016B 311F414016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 311F414016A: sender non-delivery notification: 3673A14016B A882914016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.01/0/0.01/0.03, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A882914016A: sender non-delivery notification: B260B14016B 46B2A14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 46B2A14016A: sender non-delivery notification: 4B5CB14016B C1D1114016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.02/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C1D1114016A: sender non-delivery notification: C8C2114016B D5BA014016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D5BA014016A: sender non-delivery notification: DAFD414016B 686F514016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 686F514016A: sender non-delivery notification: 6D0B214016B EE79714016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) EE79714016A: sender non-delivery notification: F31D514016B 8D6FB14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 8D6FB14016A: sender non-delivery notification: 927E014016B 11A5D14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 11A5D14016A: sender non-delivery notification: 16EFB14016B 9CDA214016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 9CDA214016A: sender non-delivery notification: A11F514016B 395FE14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 395FE14016A: sender non-delivery notification: 3E3B114016B B089614016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B089614016A: sender non-delivery notification: B4FA214016B 23BDB14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.41, delays=0.01/0/0.38/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 23BDB14016A: sender non-delivery notification: 8505C14016B 9D66214016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 9D66214016A: sender non-delivery notification: A231D14016B 3D93514016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 3D93514016A: sender non-delivery notification: 4235514016B B8A9714016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B8A9714016A: sender non-delivery notification: BD4FE14016B 58E4C14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 58E4C14016A: sender non-delivery notification: 5D65B14016B E0B0914016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.08, delays=0.07/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) E0B0914016A: sender non-delivery notification: E576314016B 813BE14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 813BE14016A: sender non-delivery notification: 8621D14016B 02C6514016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 02C6514016A: sender non-delivery notification: 075E314016B 92F2814016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 92F2814016A: sender non-delivery notification: 97D7314016B 3317814016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.03/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 3317814016A: sender non-delivery notification: 382EB14016B AC71F14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) AC71F14016A: sender non-delivery notification: B23E714016B 4AB0214016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 4AB0214016A: sender non-delivery notification: 4EE8A14016B C242D14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.01/0/0.03/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C242D14016A: sender non-delivery notification: CBEB614016B 76AB214016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 76AB214016A: sender non-delivery notification: 7C31314016B 1A65214016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.15, delays=0.13/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 1A65214016A: sender non-delivery notification: 209AC14016B AEFC414016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) AEFC414016A: sender non-delivery notification: B467214016B 4CE2014016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 4CE2014016A: sender non-delivery notification: 518C014016B C6CC314016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C6CC314016A: sender non-delivery notification: CB87114016B 64F6B14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 64F6B14016A: sender non-delivery notification: 6976814016B DE57514016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.01/0/0.01/0.03, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) DE57514016A: sender non-delivery notification: E808514016B 80B5814016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 80B5814016A: sender non-delivery notification: 85C2314016B 01D0F14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 01D0F14016A: sender non-delivery notification: 06D5514016B C8DB114016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) C8DB114016A: sender non-delivery notification: CDC4114016B 101EC14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.4, delays=0.01/0/0.38/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 101EC14016A: sender non-delivery notification: 6F6BA14016B 8AF4A14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 8AF4A14016A: sender non-delivery notification: 9054C14016B 292A414016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 292A414016A: sender non-delivery notification: 2D92414016B A199F14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) A199F14016A: sender non-delivery notification: A658414016B 3E8D514016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.04, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 3E8D514016A: sender non-delivery notification: 4597814016B B639014016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) B639014016A: sender non-delivery notification: BAB2614016B 5479414016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.09, delays=0.01/0/0.07/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 5479414016A: sender non-delivery notification: 67BCC14016B CE0F414016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) CE0F414016A: sender non-delivery notification: D289C14016B 6C32E14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 6C32E14016A: sender non-delivery notification: 70E7714016B E3A8814016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) E3A8814016A: sender non-delivery notification: E81AB14016B 80E7614016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 80E7614016A: sender non-delivery notification: 855A414016B 065F914016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 065F914016A: sender non-delivery notification: 0B09014016B D18FA14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.26, delays=0.25/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) D18FA14016A: sender non-delivery notification: 0F93014016B 0EAEE14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 0EAEE14016A: sender non-delivery notification: 1347C14016B 8591C14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 8591C14016A: sender non-delivery notification: 8A4A614016B 23BD614016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 23BD614016A: sender non-delivery notification: 28AC614016B 9D91C14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 9D91C14016A: sender non-delivery notification: A25E314016B 484BE14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 484BE14016A: sender non-delivery notification: 4DE5014016B BF6E114016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) BF6E114016A: sender non-delivery notification: C41DD14016B 5ABB914016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.05, delays=0.01/0/0.04/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 5ABB914016A: sender non-delivery notification: 672F014016B DFA4814016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.08, delays=0.06/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) DFA4814016A: sender non-delivery notification: E442514016B 7D87614016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.03, delays=0.02/0/0.01/0.01, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 7D87614016A: sender non-delivery notification: 826F414016B F402514016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) F402514016A: sender non-delivery notification: 053DF14016B 8114714016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.15, delays=0.09/0/0.05/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 8114714016A: sender non-delivery notification: 90B6C14016B 01E4E14016A: to=<[email protected]>, orig_to=<mgrastprod>, relay=newman-1.mcs.anl.gov[140.221.6.6]:25, delay=0.02, delays=0.01/0/0.01/0, dsn=5.1.1, status=bounced (host newman-1.mcs.anl.gov[140.221.6.6] said: 550 5.1.1 <[email protected]>: Recipient address rejected: User unknown in relay recipient table (in reply to RCPT TO command)) 01E4E14016A: sender non-delivery notification: 06B6514016B ---------------------- postfix End ------------------------- --------------------- Smartd Begin ------------------------ **Unmatched Entries** Problem creating device name scan list Device /dev/sda: using '-d sat' for ATA disk behind SAT layer. Device /dev/sdb: using '-d sat' for ATA disk behind SAT layer. ---------------------- Smartd End ------------------------- --------------------- SSHD Begin ------------------------ SSHD Killed: 1 Time(s) SSHD Started: 2 Time(s) Illegal users from: 146.137.70.8 (anlscan8.cspo.anl.gov): 2 times Postponed authentication: jared/publickey: 140.221.9.199: 1 Time(s) Users logging in through sshd: jared: 140.221.9.199 (login1.mcs.anl.gov): 1 time jbischof: 140.221.11.19 (jbischof.mcs.anl.gov): 5 times root: 192.5.200.126 (warehouse13.mcs.anl.gov): 5 times Received disconnect: 11: disconnected by user : 5 Time(s) **Unmatched Entries** userauth_hostbased: unsupported public key algorithm: ecdsa-sha2-nistp256 : 1 time(s) Exiting on signal 15 : 4 time(s) pam_succeed_if(sshd:auth): error retrieving information about user Cisco : 1 time(s) pam_succeed_if(sshd:auth): error retrieving information about user cisco : 1 time(s) ---------------------- SSHD End ------------------------- --------------------- Sudo (secure-log) Begin ------------------------ ============================================================================== jared => root ------------------------------------------------------------------------------ /bin/zsh ============================================================================== jbischof => root ------------------------------------------------------------------------------ /bin/zsh /bin/zsh /bin/zsh /bin/zsh /bin/zsh /bin/zsh /bin/zsh /bin/zsh /bin/zsh /bin/zsh ---------------------- Sudo (secure-log) End ------------------------- --------------------- XNTPD Begin ------------------------ XNTPD Killed: 1 Time(s) XNTPD Started: 1 Time(s) Time Reset 1 times (total: -0.733114 s average: -0.733114 s) Total interfaces 7 (non-local: 3) Total synchronizations 2 (hosts: 1) ---------------------- XNTPD End ------------------------- --------------------- Disk Space Begin ------------------------ Filesystem Size Used Avail Use% Mounted on /dev/mapper/Vol0-LV00 15G 9.8G 3.7G 73% / /dev/md0 99M 39M 55M 42% /boot /dev/mapper/Vol0-local 1.8T 141G 1.7T 8% /local ---------------------- Disk Space End ------------------------- ###################### Logwatch End #########################
participants (1)
logwatch@mcs.anl.gov
