[mrepo] changes to warehouse13.mcs.anl.gov (new: 18, removed: 18)
The following changes to mrepo's repositories on warehouse13.mcs.anl.gov have been made: Dist: CentOS 5.9 (x86_64) (centos-5.9-x86_64) Dist: CentOS 6.3 (x86_64) (centos-6.3-x86_64) Repo: epel + nodejs-hashish-0.0.4-3.el6.noarch.rpm (9 kiB) + nodejs-mysql-2.0.0-alpha9.2.el6.2.noarch.rpm (81 kiB) + nodejs-nan-0.4.4-3.el6.noarch.rpm (19 kiB) + nodejs-node-static-0.7.1-4.el6.noarch.rpm (547 kiB) + nodejs-options-0.0.5-4.el6.noarch.rpm (7 kiB) + nodejs-require-all-0.0.6-3.el6.noarch.rpm (8 kiB) + nodejs-supervisor-0.5.2-5.el6.noarch.rpm (12 kiB) + nodejs-tinycolor-0.0.1-6.el6.noarch.rpm (5 kiB) + python-ase-3.8.1.3440-10.el6.noarch.rpm (1894 kiB) - nodejs-hashish-0.0.4-1.el6.noarch.rpm (9 kiB) - nodejs-mysql-2.0.0-alpha9.2.el6.noarch.rpm (83 kiB) - nodejs-nan-0.4.4-1.el6.noarch.rpm (19 kiB) - nodejs-node-static-0.7.1-2.el6.noarch.rpm (547 kiB) - nodejs-options-0.0.5-2.el6.noarch.rpm (7 kiB) - nodejs-require-all-0.0.6-1.el6.noarch.rpm (8 kiB) - nodejs-supervisor-0.5.2-3.el6.noarch.rpm (12 kiB) - nodejs-tinycolor-0.0.1-4.el6.noarch.rpm (5 kiB) - python-ase-3.7.1.3184-6.el6.noarch.rpm (4027 kiB) Dist: CentOS 6.4 (x86_64) (centos-6.4-x86_64) Repo: epel + nodejs-hashish-0.0.4-3.el6.noarch.rpm (9 kiB) + nodejs-mysql-2.0.0-alpha9.2.el6.2.noarch.rpm (81 kiB) + nodejs-nan-0.4.4-3.el6.noarch.rpm (19 kiB) + nodejs-node-static-0.7.1-4.el6.noarch.rpm (547 kiB) + nodejs-options-0.0.5-4.el6.noarch.rpm (7 kiB) + nodejs-require-all-0.0.6-3.el6.noarch.rpm (8 kiB) + nodejs-supervisor-0.5.2-5.el6.noarch.rpm (12 kiB) + nodejs-tinycolor-0.0.1-6.el6.noarch.rpm (5 kiB) + python-ase-3.8.1.3440-10.el6.noarch.rpm (1894 kiB) - nodejs-hashish-0.0.4-1.el6.noarch.rpm (9 kiB) - nodejs-mysql-2.0.0-alpha9.2.el6.noarch.rpm (83 kiB) - nodejs-nan-0.4.4-1.el6.noarch.rpm (19 kiB) - nodejs-node-static-0.7.1-2.el6.noarch.rpm (547 kiB) - nodejs-options-0.0.5-2.el6.noarch.rpm (7 kiB) - nodejs-require-all-0.0.6-1.el6.noarch.rpm (8 kiB) - nodejs-supervisor-0.5.2-3.el6.noarch.rpm (12 kiB) - nodejs-tinycolor-0.0.1-4.el6.noarch.rpm (5 kiB) - python-ase-3.7.1.3184-6.el6.noarch.rpm (4027 kiB)
participants (1)
mrepoï¼ warehouse13.mcs.anl.gov
