[mrepo] changes to warehouse13.mcs.anl.gov (new: 24, removed: 19)
The following changes to mrepo's repositories on warehouse13.mcs.anl.gov have been made: Dist: CentOS 5.10 (i386) (centos-5.10-i386) Repo: epel + byobu-5.73-4.el5.noarch.rpm (171 kiB) + mod_auth_shadow-2.3-2.el5.i386.rpm (19 kiB) + python-dirq-1.6.1-1.el5.noarch.rpm (56 kiB) + python26-dirq-1.6.1-1.el5.noarch.rpm (65 kiB) + sec-2.7.5-0.el5.noarch.rpm (150 kiB) - byobu-5.21-4.el5.noarch.rpm (121 kiB) - mod_auth_shadow-2.3-1.el5.i386.rpm (19 kiB) - python-dirq-1.5-1.el5.noarch.rpm (54 kiB) - python26-dirq-1.5-1.el5.noarch.rpm (63 kiB) - sec-2.7.4-0.el5.noarch.rpm (144 kiB) Dist: CentOS 5.10 (x86_64) (centos-5.10-x86_64) Repo: epel + byobu-5.73-4.el5.noarch.rpm (171 kiB) + mod_auth_shadow-2.3-2.el5.x86_64.rpm (19 kiB) + python-dirq-1.6.1-1.el5.noarch.rpm (56 kiB) + python26-dirq-1.6.1-1.el5.noarch.rpm (65 kiB) + sec-2.7.5-0.el5.noarch.rpm (150 kiB) - byobu-5.21-4.el5.noarch.rpm (121 kiB) - mod_auth_shadow-2.3-1.el5.x86_64.rpm (19 kiB) - python-dirq-1.5-1.el5.noarch.rpm (54 kiB) - python26-dirq-1.5-1.el5.noarch.rpm (63 kiB) - sec-2.7.4-0.el5.noarch.rpm (144 kiB) Dist: CentOS 6.5 (x86_64) (centos-6.5-x86_64) Repo: epel + ansible-1.5-1.el6.noarch.rpm (666 kiB) + byobu-5.73-4.el6.noarch.rpm (155 kiB) + docker-registry-0.6.5-1.el6.noarch.rpm (101 kiB) + mod_auth_shadow-2.3-2.el6.x86_64.rpm (19 kiB) + nodejs-css-parse-1.7.0-2.el6.noarch.rpm (9 kiB) + nodejs-stylus-0.42.2-1.el6.noarch.rpm (205 kiB) + perl-Encode-DoubleEncodedUTF8-0.05-1.el6.noarch.rpm (8 kiB) + perl-Time-Out-0.11-1.el6.noarch.rpm (9 kiB) + python-dirq-1.6.1-1.el6.noarch.rpm (49 kiB) + python-flask-0.9-7.el6.noarch.rpm (189 kiB) + python-flask-doc-0.9-7.el6.noarch.rpm (764 kiB) + python-tashaphyne-0.2-1.el6.noarch.rpm (20 kiB) + ripright-0.9-2.el6.x86_64.rpm (38 kiB) + sec-2.7.5-0.el6.noarch.rpm (144 kiB) - ansible-1.4.3-1.el6.noarch.rpm (782 kiB) - byobu-5.21-4.el6.noarch.rpm (118 kiB) - docker-registry-0.6.0-4.el6.noarch.rpm (57 kiB) - mod_auth_shadow-2.3-1.el6.x86_64.rpm (19 kiB) - nodejs-stylus-0.35.1-1.el6.noarch.rpm (113 kiB) - python-dirq-1.5-1.el6.noarch.rpm (47 kiB) - python-flask-0.9-5.el6.noarch.rpm (189 kiB) - python-flask-doc-0.9-5.el6.noarch.rpm (764 kiB) - sec-2.7.4-0.el6.noarch.rpm (139 kiB)
participants (1)
mrepoï¼ warehouse13.mcs.anl.gov
