[mrepo] changes to warehouse13.mcs.anl.gov (new: 30, removed: 6)
The following changes to mrepo's repositories on warehouse13.mcs.anl.gov have been made: Dist: CentOS 5.9 (x86_64) (centos-5.9-x86_64) Dist: CentOS 6.3 (x86_64) (centos-6.3-x86_64) Repo: epel + ansible-1.2.3-2.el6.noarch.rpm (520 kiB) + ansible-fireball-1.2.3-2.el6.noarch.rpm (8 kiB) + ansible-node-fireball-1.2.3-2.el6.noarch.rpm (17 kiB) - ansible-1.2.2-1.el6.noarch.rpm (520 kiB) - ansible-fireball-1.2.2-1.el6.noarch.rpm (8 kiB) - ansible-node-fireball-1.2.2-1.el6.noarch.rpm (17 kiB) Dist: CentOS 6.4 (x86_64) (centos-6.4-x86_64) Repo: epel + ansible-1.2.3-2.el6.noarch.rpm (520 kiB) + ansible-fireball-1.2.3-2.el6.noarch.rpm (8 kiB) + ansible-node-fireball-1.2.3-2.el6.noarch.rpm (17 kiB) - ansible-1.2.2-1.el6.noarch.rpm (520 kiB) - ansible-fireball-1.2.2-1.el6.noarch.rpm (8 kiB) - ansible-node-fireball-1.2.2-1.el6.noarch.rpm (17 kiB) Repo: updates + 389-ds-base-1.2.11.15-22.el6_4.x86_64.rpm (1490 kiB) + 389-ds-base-devel-1.2.11.15-22.el6_4.i686.rpm (112 kiB) + 389-ds-base-devel-1.2.11.15-22.el6_4.x86_64.rpm (112 kiB) + 389-ds-base-libs-1.2.11.15-22.el6_4.i686.rpm (398 kiB) + 389-ds-base-libs-1.2.11.15-22.el6_4.x86_64.rpm (393 kiB) + glibc-2.12-1.107.el6_4.4.i686.rpm (4431 kiB) + glibc-2.12-1.107.el6_4.4.x86_64.rpm (3886 kiB) + glibc-common-2.12-1.107.el6_4.4.x86_64.rpm (14524 kiB) + glibc-devel-2.12-1.107.el6_4.4.i686.rpm (974 kiB) + glibc-devel-2.12-1.107.el6_4.4.x86_64.rpm (974 kiB) + glibc-headers-2.12-1.107.el6_4.4.x86_64.rpm (605 kiB) + glibc-static-2.12-1.107.el6_4.4.i686.rpm (1159 kiB) + glibc-static-2.12-1.107.el6_4.4.x86_64.rpm (1410 kiB) + glibc-utils-2.12-1.107.el6_4.4.x86_64.rpm (159 kiB) + kernel-2.6.32-358.18.1.el6.x86_64.rpm (26752 kiB) + kernel-debug-2.6.32-358.18.1.el6.x86_64.rpm (27385 kiB) + kernel-debug-devel-2.6.32-358.18.1.el6.x86_64.rpm (8427 kiB) + kernel-devel-2.6.32-358.18.1.el6.x86_64.rpm (8385 kiB) + kernel-doc-2.6.32-358.18.1.el6.noarch.rpm (10201 kiB) + kernel-firmware-2.6.32-358.18.1.el6.noarch.rpm (11205 kiB) + kernel-headers-2.6.32-358.18.1.el6.x86_64.rpm (2393 kiB) + nscd-2.12-1.107.el6_4.4.x86_64.rpm (212 kiB) + perf-2.6.32-358.18.1.el6.x86_64.rpm (2107 kiB) + python-perf-2.6.32-358.18.1.el6.x86_64.rpm (1699 kiB)
participants (1)
mrepoï¼ warehouse13.mcs.anl.gov
