################### Logwatch 7.3 (03/24/06) #################### Processing Initiated: Thu Mar 13 04:02:01 2014 Date Range Processed: yesterday ( 2014-Mar-12 ) Period is day. Detail Level of Output: 0 Type of Output: unformatted Logfiles for Host: berlin.mcs.anl.gov ################################################################## --------------------- pam_unix Begin ------------------------ su: Sessions Opened: jbischof(uid=0) -> mgrastprod: 2 Time(s) sudo: Authentication Failures: dsouza(0) -> dsouza: 3 Time(s) jbischof(0) -> jbischof: 3 Time(s) ---------------------- pam_unix End ------------------------- --------------------- postfix Begin ------------------------ 3454 bytes transferred 1 messages sent 1 messages removed from queue ---------------------- postfix End ------------------------- --------------------- Smartd Begin ------------------------ Currently unreadable (pending) sectors detected: /dev/sda - 48 Time(s) 1 unreadable sectors detected ---------------------- Smartd End ------------------------- --------------------- SSHD Begin ------------------------ Users logging in through sshd: dsouza: 140.221.10.82 (dsouza.mcs.anl.gov): 3 times jbischof: 130.202.135.146 (mcswl146.mcs.anl.gov): 1 time 140.221.11.19 (jbischof.mcs.anl.gov): 1 time Received disconnect: 11: disconnected by user : 3 Time(s) ---------------------- SSHD End ------------------------- --------------------- Sudo (secure-log) Begin ------------------------ ============================================================================== dsouza => mgrastprod ------------------------------------------------------------------------------ /bin/bash dsouza => root ------------------------------------------------------------------------------ /bin/bash /bin/bash /bin/bash -c ssh root\@dunkirk\.mcs\.anl\.gov \ \/homes\/dsouza\/MCP\/bin\/edit_nginx_config \ \/etc\/nginx\/conf\.d\/metagenomics\.conf \ \/etc\/nginx\/conf\.d\/metagenomics\.down /bin/bash -c ssh root\@dunkirk\.mcs\.anl\.gov \ \/homes\/dsouza\/MCP\/bin\/edit_nginx_config \ \/etc\/nginx\/conf\.d\/metagenomics\.conf \ \/etc\/nginx\/conf\.d\/metagenomics\.up ============================================================================== jbischof => root ------------------------------------------------------------------------------ /bin/zsh /bin/zsh /bin/zsh ---------------------- Sudo (secure-log) End ------------------------- --------------------- Disk Space Begin ------------------------ Filesystem Size Used Avail Use% Mounted on /dev/mapper/Vol0-LV00 15G 12G 2.4G 83% / /dev/md0 99M 39M 55M 42% /boot /dev/mapper/Vol0-local 1.8T 141G 1.7T 8% /local ---------------------- Disk Space End ------------------------- ###################### Logwatch End #########################
participants (1)
logwatch@mcs.anl.gov
